BK/HRJ-LES-FUSE
BK/HRJ-LES-FUSE
    EATON(伊顿)
    BK/HRJ-LES-FUSE
BK/HRJ-LES-FUSE 数据手册
Effective November 2019 Supersedes June 2017 Technical Data 2122 HR and HM 1/4" x various length and SFE in-line fuse holder Product features • • • • Bayonet type knob Maximum current rating 20 amps; voltage rating 32 volts AC Holders available as complete assembly consisting of in-line holder with 8" or 14" of #14 insulated wire and installed fuses Replacement springs – BK/1A1853 Part Number Amps Volts AC Includes Fuse Wire HRJ* SFE-20 __________ ____________________ HRI SFE-14 __________ ____________________ HRH SFE-9 __________ ____________________ 19∑ of #14 HRE SFE-7⁄Ω™ __________ ___________________ _ HRG SFE-6 __________ ____________________ HRF SFE-4 __________ __________________________________ _____ 20 32 HMJ** SFE-20 __________ ____________________ HMI SFE-14 __________ ____________________ HMH SFE-9 __________ ____________________ 8∑ of #14 HME SFE-7⁄Ω™ __________ ___________________ _ HMG SFE-6 __________ ____________________ HMF SFE-4 *Also available as in-line fuseholder only with lead wire contacts, HRJ-Less-Fuse. **Also available as in-line fuseholder only with lead wire contacts, HMJ-Less-Fuse. Environmental data: Temperature Rating (RTI): +140 °C Agency information: No agency listing Dimensions: in (mm): All dimensions ±0.015" 2.19" (55.6mm) 0.75" (19.1mm) 0.69" (17.5mm) 1.56" (39.7mm) Packaging code prefix Blank BK- 0.38" (9.5mm) Description 10 Fuse holders with components bagged separately 100 Fuse holders with components bagged separately Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2019 Eaton All Rights Reserved Printed in USA Publication No. 2122 SB98107 November 2019 Eaton is a registered trademark. All other trademarks are property of their respective owners.
BK/HRJ-LES-FUSE 价格&库存
很抱歉,暂时无法提供与“BK/HRJ-LES-FUSE”相匹配的价格&库存,您可以联系我们找货
