Fuse Holders for 1⁄4" x 1 1⁄4" and 5 x 20mm Fuses
HTB Panel Mount Series
Description
• For 1⁄4" x 1 1⁄4" and 5 x 20mm fuses
• All holder bodies have the option of using
1
⁄4" x 1 1⁄4" or 5 x 20mm carriers
• Withstands 15 to 20 Lb-In torque to mounting
nut when mounting fuse holder to panel
• High temperature, flame retardant,
Thermoplastic meets UL 94V0
Specifications
Product UL Rating CSA Rating
Code
(amps)
(amps)
HTB-X2I
HTB-X4I
HTB-X6I
HTB-X8I
HTB-X2M
16
16
HTB-X4M
16
16
HTB-X6M
16
16
HTB-X8M
16
16
Voltage
Rating
250
250
250
250
250
250
250
250
Fuse
Quick
Size
Connect
1
3
⁄4" x 1 1⁄4"
⁄16"
1
3
⁄4" x 1 1⁄4"
⁄16"
1
1
⁄4" x 1 1⁄4"
⁄4"
1
1
⁄4" x 1 1⁄4"
⁄4"
5 x 20mm 3⁄16"
5 x 20mm 3⁄16"
1
5 x 20mm
⁄4"
1
5 x 20mm
⁄4"
Maximum Panel Thickness
Body Type
HTB-2
HTB-3
HTB-4
HTB-5
HTB-6
HTB-8
HTB-9
Inch
0.30
0.30
0.125
0.125
0.30
0.125
0.125
Agency Information
• UL Recognized: IZLT2, E14853
• CSA Component Acceptance:
Class 6225-01, File 47235
• VDE Certified: 136128, HTB-XXM
• SEMKO Certification: Ref. #0146149/01, HTB-XXM
• CE
Mounting Dimensions - in (mm)
Replacement Parts
mm
7.62
7.62
3.18
3.18
7.62
3.18
3.18
Terminal Options
Knob Type Carrier
Solder/
3
⁄16˝ Quick-Connect
Maximum
Panel
Thickness
Common Dimensional Data:
Length (Knob Type) - 1.69
(42.9mm) Plus In-Line Terminal
NOTE: Plus In-Line Terminal
0.47"
1.125"
(11.9mm)
(28.6mm)
0.30˝
7.62mm
Low Profile
Rear Hex Nut
0.09" NOM.
(2.4mm)
0.69"
0.91"
(17.5mm)
(23.0mm)
In-Line
Rt. Angle
In-Line
Rt. Angle
0.34"
0.33"
(8.7mm)
(8.3mm)
HTB-22I-R
HTB-24I-R
0.47"
(11.9mm)
HTB-4
0.67"
0.92"
(17.1mm)
(23.4mm)
5 x 20mm
(“M” Equals Metric)
Knob
0.45"
(11.5mm)
HTB-26I-R
HTB-28I-R
3
HTB-26M-R
HTB-28M-R
3
HTB-42I-R
HTB-44I-R
HTB-46I-R
HTB-48I-R
3
HTB-42M-R
HTB-44M-R
HTB-46M-R
HTB-48M-R
3
HTB-62I-R
HTB-64I-R
HTB-66I-R
HTB-68I-R
3
HTB-62M-R
HTB-64M-R
HTB-66M-R
HTB-68M-R
3
HTB-82I-R
HTB-84I-R
HTB-86I-R
HTB-88I-R
3
HTB-82M-R
HTB-84M-R
HTB-86M-R
HTB-88M-R
3
0.125˝
3.18mm
High
Profile
Rear Hex Nut
1
⁄4˝ x 1 1⁄4˝
(“I” Equals Inches)
Knob
HTB-22M-R HTB-24M-R
HTB-2
Carrier Options
⁄4˝ Quick-Connect
1
0.30˝
7.62mm
Front
Hex Nut
HTB-6
0.47"
1.125"
(11.9mm)
(28.6mm)
0.125˝
3.18mm
Low Profile
Snap-In
HTB-8
Fuseholders and fuse carriers may be ordered separately.
0709
BU-SB09620
Page 1 of 2
Data Sheet 2119
Terminal Options
Screwdriver Type Carrier
⁄16˝
3
Maximum
Panel
Thickness
(Screwdriver Slotted)
1.75˝ (44.5mm)
0.17"
1.58"
(4.37mm)
(40.03mm)
Low Profile
Rear Hex Nut
0.41"
1.34"
(34.13mm)
⁄4˝ Quick-Connect
1
Rt. Angle
In-Line
1
⁄4˝ x 1⁄4˝
(“I” Equals Inches)
Rt. Angle
Screwdriver
0.34"
HTB-3
(10.31mm)
In-Line
(8.7mm)
0.30˝
7.62mm
Carrier Options
Solder/
Quick-Connect
0.47"
0.33"
(11.5mm)
HTB-32I-R
HTB-34I-R
HTB-36I-R
HTB-38I-R
3
HTB-32M-R
HTB-34M-R
HTB-36M-R
HTB-38M-R
3
HTB-52I-R
HTB-54I-R
HTB-56I-R
HTB-58I-R
3
HTB-52M-R
HTB-54M-R
HTB-56M-R
HTB-58M-R
3
HTB-92I-R
HTB-94I-R
HTB-96I-R
HTB-98I-R
3
HTB-92M-R
HTB-94M-R
HTB-96M-R
HTB-98M-R
3
0.125˝
3.18mm
High Profile
Rear Hex Nut
HTB-5
0.17"
1.59"
(4.37mm)
(40.08mm)
Screwdriver
0.45"
(11.9mm)
(8.3mm)
5 x 20mm
(“M” Equals Metric)
0.125˝
3.18mm
Low-Profile
Snap-In
HTB-9
Ordering Information
FUSE CARRIER ONLY
HTB-
Packing
(Blank) – Std.
BK/ – Bulk
Product
Symbol
Body Configuration and Mounting
Knob Holders
2 — Low Profile (Rear Panel Hex-Nut)
4 — High Profile
* 6 — (Front Panel Hex-Nut)
8 — Low Profile (Snap-In)
Screwdriver Slotted Holders
3 — Low Profile
5 — High Profile
9 — Low Profile (Snap-In)
P
S
Fuse Carrier
I — 1/4˝ x 1 1/4˝
M — 5 x 20mm
Rear Terminal Configuration
2 — Solder / 3/16˝ Quick-Connect
(In-Line)
4 — Solder / 3/16˝ Quick-Connect
(Right Angle)
6 — 1/4˝ Quick-Connect (In-Line)
8 — 1/4˝ Quick-Connect (Right Angle)
Splash Proof
Cap with O-Ring
(Optional on Knob
Holders Only)
-R
RoHS
Compliant
Packaging
(Blank) – Std.
BK/ – Bulk
Product
Symbol
FT — Knob Type
(For 20, 40, 60,
and 80 Series
Only)
ST — Screwdriver
Slotted (For 30,
50, and 90 Series
Only)
Fuse Carrier
I — 1/4 ˝ x 11/4 ˝
M — 5mm x 20mm
*Profile varies with panel thickness. Holder installs thru rear of panel.
Packaging
Packaging Code Prefix
Blank
BK
Description
10 fuse holders packed into a carton
100 fuse holders packed into a cardboard shelf package
The only controlled copy of this Data Sheet is the electronic read-only version located on the Cooper Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is
intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Cooper Bussmann reserves the right, without notice, to change
design or construction of any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice, any technical information contained
in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
Life Support Policy: Cooper Bussmann does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support
systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in
significant injury to the user.
© 2009 Cooper Bussmann
St. Louis, MO 63178
www.cooperbussmann.com
0709
BU-SB09620
Page 2 of 2
Data Sheet 2119
很抱歉,暂时无法提供与“BK/HTB-22I”相匹配的价格&库存,您可以联系我们找货
