Technical Data 2119
Effective January 2024
Supersedes December 2020
HTB
1/4” x 1-1/4” and 5 mm x 20 mm Panel-mount fuse
holders
Ordering part number
Fuse holder:
BK-HTB -3 -6 -M -R
(a)
(b)
(c) (d) (e) (f)
(a) Packaging prefix
Product features
For 1⁄4” x 1 1⁄4” and 5 mm x 20 mm fuses
All holder bodies have the option of using 1⁄4” x
1 1⁄4” or 5 mm x 20 mm carriers
Withstands 15 Lb-In torque to mounting nut
when mounting fuse holder to panel
High temperature, flame retardant
thermoplastic meets UL 94 V-0
IP53 for -SP option
Operating temperature: -55 °C to +85 °C
Agency information
UL Recognized: File E14853, Guide IZLT2,
CSA: File 47235, Class 6225-01,
VDE: Certificate 136128 (M version, 5 x 20 mm
only)
CE
(b) Product code
(c) Body configuration and mounting
Knob holders
-2 Low profile (rear panel hex-nut)
-4 High profile
-6 Front panel hex-nut (Profile
varies with panel thickness.
Holder installs through rear of
panel)
-8 Low profile (snap-in)
Screwdriver slotted holders
-3 Low profile
-5 High Profile
-9 Low profile (snap-in)
(d) Rear terminal configuration
-2 Solder or 3/16” Quick-connect
(in-line)
-4 Solder or 3/16” Quick-connect
(right angle)
-6 Quick-connect (in-line)
-8 Quick-connect (right angle)
(e) Fuse carrier
-I 1/4” x 1 1/4”
-M 5 mm x 2o mm
(f) Option code
-R (RoHS compliant)
-SP (Splash proof (Cap with O-ring,
IP53 rating, option on Knob
holders only)
Fuse carrier only:
Environmental compliance
BK-FT M
(g) (h)
(i)
(g) Packaging prefix
(h) Product code
FT Knob type for HTB-2, 4, 6,
and 8 only
ST Screwdriver slotted type for
HTB-3, 5 and 9 only
(i) Fuse carrier
-I 1/4” x 1 1/4”
-M 5 mm x 20 mm
HTB
1/4” x 1-1/4” and 5 mm x 20 mm Panel-mount fuseholders
Technical Data 2119
Packaging information
Type
Packaging prefix
Description
Fuse holder
blank
10 parts per box, 30 boxes per carton
Fuse holder
BK-
100 parts per box, 4 boxes per carton
Fuse carrier
blank
10 parts per box, 50 boxes per carton
Fuse carrier
BK-
100 parts per polybag, 20 bags per carton
Specifications
Part number
UL Current
rating
(A)
CSA Current
rating
(A)
VDE Rated power Voltage
acceptance
rating
(W)
(V)
UL Voltage
rating
(V)
Fuse size
Quck-connect
HTB-x2I
na
250
300
1/4” x 1-1/4”
3/16” in-line
HTB-x4I
na
250
300
1/4” x 1-1/4”
3/16” right-angle
HTB-x6I
na
250
300
1/4” x 1-1/4”
1/4” in-line
HTB-x8I
na
250
300
1/4” x 1-1/4”
1/4” right-angle
HTB-x2M
16
16
4
250
300
5 mm x 20 mm
3/16” in-line
HTB-x4M
16
16
4
250
300
5 mm x 20 mm
3/16” right-angle
HTB-x6M
16
16
4
250
300
5 mm x 20 mm
1/4” in-line
HTB-x8M
16
16
4
250
300
5 mm x 20 mm
1/4” right-angle
Dimensions- inches
Screwdriver type
Knob type
Mounting- inches
HTB-2x, -3x, -4x, -5x and -6x
Double “D” hole
or
“D” hole
HTB-8 and -9x
HTB-2x
HTB-3x
HTB-4x
Solder or 3/16”quick connect
Panel
HTB-5x
HTB-6x
HTB-9x
HTB-8x
In-line
Maximum panel thickness
Right-angle
1/4”Quick connect
Body type
Inches
mm
HTB-2x
0.30
7.62
HTB-3x
0.30
7.62
HTB-4x
0.125
3.18
HTB-5x
0.125
3.18
HTB-6x
0.30
7.62
HTB-8x
0.125
3.18
HTB-9x
0.125
3.18
In-line
2
www.eaton.com/electronics
Right-angle
HTB
Technical Data 2119
1/4” Quick-connect
Carrier options-Knob type
Knob type
In-line
Right-angle
In-line
Right-angle
1/4” x 1-1/4”
5 mm x 20 mm
HTB-2x
HTB-22I-R
HTB-24I-R
HTB-26I-R
HTB-28I-R
x
HTB-22M-R
HTB-24M-R
HTB-26M-R
HTB-28M-R
x
HTB-4x
HTB-42I-R
HTB-44I-R
HTB-46I-R
HTB-48I-R
x
HTB-42M-R
HTB-44M-R
HTB-46M-R
HTB-48M-R
x
HTB-62I-R
HTB-64I-R
HTB-66I-R
HTB-68I-R
x
HTB-62M-R
HTB-64M-R
HTB-66M-R
HTB-68M-R
x
HTB-82I-R
HTB-84I-R
HTB-86I-R
HTB-88I-R
x
HTB-82M-R
HTB-84M-R
HTB-86M-R
HTB-88M-R
x
HTB-6x
HTB-8x
Screwdriver type
HTB-3x
1/4” Quick-connect
Carrier options- Screwdriver type
In-line
Right-angle
In-line
Right-angle
1/4” x 1-1/4”
5 mm x 20 mm
HTB-32I-R
HTB-34I-R
HTB-36I-R
HTB-38I-R
x
HTB-32M-R
HTB-34M-R
HTB-36M-R
HTB-38M-R
x
HTB-5x
HTB-52I-R
HTB-54I-R
HTB-56I-R
HTB-58I-R
x
HTB-52M-R
HTB-54M-R
HTB-56M-R
HTB-58M-R
x
HTB-9x
HTB-92I-R
HTB-94I-R
HTB-96I-R
HTB-98I-R
x
HTB-92M-R
HTB-94M-R
HTB-96M-R
HTB-98M-R
x
Replacement parts
Knob
1/4” x 1-1/4”
5 mm x 20 mm
Screwdriver
1/4” x 1-1/4”
5 mm x 20 mm
HTB-2x, 3x, 4x,
HTB-2x, 3x,
5x, and 8x
4x, 5x,
BK-1A4287-1
BK-1A4806-2
BK-1A3322
Plastic nut
Metal nut
Metal nut
HTB-6x
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used
in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com/electronics
© 2024 Eaton
All Rights Reserved
Printed in USA
Publication No. 2119 PCN24002
January 2024
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“BK/HTB-42M-SP”相匹配的价格&库存,您可以联系我们找货
