Technical Data 10653
Effective February 2017
HHN
1/4” x 1 1/4” in-line fuse holder
Dimensions- mm [in]
#12 UL3266
Yellow wire
Fuseholder body
Compression spring
Fuseholder cap
HHN
9.50
[.375]
Terminal contacts
114.30
[4.50]
266.70
[10.500]
(When assembled)
Product specifications
HHN-1K0198
Part Voltage Current
number
rating (V)
rating (A)
HHN 32
Product features
For ¼” diameter x 1 ¼” small
dimension fuses
#12 AWG unplated copper wire with
yellow insulation
Nylon body with bayonet type
assembly
Tin plated brass contacts
30
Ordering Options
Ordering
code Description
HHN 10 fuse holders packed
into a carton
HHN-1K0198 10 fuse holders with AGC-30 fuse
packed into a carton
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used
in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
www.eaton.com/electronics
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 10653 BU-MC17001
February 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“HHN”相匹配的价格&库存,您可以联系我们找货
