HTB-28M
HTB-28M
    EATON(伊顿)
    HTB-28M
HTB-28M 数据手册
Technical Data 2119 Effective January 2024 Supersedes December 2020 HTB 1/4” x 1-1/4” and 5 mm x 20 mm Panel-mount fuse holders Ordering part number Fuse holder: BK-HTB -3 -6 -M -R (a) (b) (c) (d) (e) (f) (a) Packaging prefix Product features • For 1⁄4” x 1 1⁄4” and 5 mm x 20 mm fuses • All holder bodies have the option of using 1⁄4” x 1 1⁄4” or 5 mm x 20 mm carriers • Withstands 15 Lb-In torque to mounting nut when mounting fuse holder to panel • High temperature, flame retardant thermoplastic meets UL 94 V-0 • IP53 for -SP option • Operating temperature: -55 °C to +85 °C Agency information • UL Recognized: File E14853, Guide IZLT2, • CSA: File 47235, Class 6225-01, • VDE: Certificate 136128 (M version, 5 x 20 mm only) • CE (b) Product code (c) Body configuration and mounting Knob holders -2 Low profile (rear panel hex-nut) -4 High profile -6 Front panel hex-nut (Profile varies with panel thickness. Holder installs through rear of panel) -8 Low profile (snap-in) Screwdriver slotted holders -3 Low profile -5 High Profile -9 Low profile (snap-in) (d) Rear terminal configuration -2 Solder or 3/16” Quick-connect (in-line) -4 Solder or 3/16” Quick-connect (right angle) -6 Quick-connect (in-line) -8 Quick-connect (right angle) (e) Fuse carrier -I 1/4” x 1 1/4” -M 5 mm x 2o mm (f) Option code -R (RoHS compliant) -SP (Splash proof (Cap with O-ring, IP53 rating, option on Knob holders only) Fuse carrier only: Environmental compliance BK-FT M (g) (h) (i) (g) Packaging prefix (h) Product code FT Knob type for HTB-2, 4, 6, and 8 only ST Screwdriver slotted type for HTB-3, 5 and 9 only (i) Fuse carrier -I 1/4” x 1 1/4” -M 5 mm x 20 mm HTB 1/4” x 1-1/4” and 5 mm x 20 mm Panel-mount fuseholders  Technical Data 2119 Effective January 2024 Packaging information Type Packaging prefix Description Fuse holder blank 10 parts per box, 30 boxes per carton Fuse holder BK- 100 parts per box, 4 boxes per carton Fuse carrier blank 10 parts per box, 50 boxes per carton Fuse carrier BK- 100 parts per polybag, 20 bags per carton Specifications Part number UL Current rating (A) CSA Current rating (A) VDE Rated power Voltage acceptance rating (W) (V) UL Voltage rating (V) Fuse size Quck-connect HTB-x2I 20 16 na 250 300 1/4” x 1-1/4” 3/16” in-line HTB-x4I 20 16 na 250 300 1/4” x 1-1/4” 3/16” right-angle HTB-x6I 20 16 na 250 300 1/4” x 1-1/4” 1/4” in-line HTB-x8I 20 16 na 250 300 1/4” x 1-1/4” 1/4” right-angle HTB-x2M 16 16 4 250 300 5 mm x 20 mm 3/16” in-line HTB-x4M 16 16 4 250 300 5 mm x 20 mm 3/16” right-angle HTB-x6M 16 16 4 250 300 5 mm x 20 mm 1/4” in-line HTB-x8M 16 16 4 250 300 5 mm x 20 mm 1/4” right-angle Dimensions- inches Screwdriver type Knob type Mounting- inches HTB-2x, -3x, -4x, -5x and -6x Double “D” hole or “D” hole HTB-8 and -9x HTB-2x HTB-3x HTB-4x Solder or 3/16”quick connect Panel HTB-5x HTB-6x HTB-9x HTB-8x In-line Maximum panel thickness Right-angle 1/4”Quick connect Body type Inches mm HTB-2x 0.30 7.62 HTB-3x 0.30 7.62 HTB-4x 0.125 3.18 HTB-5x 0.125 3.18 HTB-6x 0.30 7.62 HTB-8x 0.125 3.18 HTB-9x 0.125 3.18 In-line 2 www.eaton.com/electronics Right-angle HTB 1/4” x 1-1/4” and 5 mm x 20 mm Panel-mount fuseholders  Technical Data 2119 Effective January 2024  Solder or 3/16” Quick-connect 1/4” Quick-connect Carrier options-Knob type Knob type In-line Right-angle In-line Right-angle 1/4” x 1-1/4” 5 mm x 20 mm HTB-2x HTB-22I-R HTB-24I-R HTB-26I-R HTB-28I-R x - HTB-22M-R HTB-24M-R HTB-26M-R HTB-28M-R - x HTB-4x HTB-42I-R HTB-44I-R HTB-46I-R HTB-48I-R x - HTB-42M-R HTB-44M-R HTB-46M-R HTB-48M-R - x HTB-62I-R HTB-64I-R HTB-66I-R HTB-68I-R x - HTB-62M-R HTB-64M-R HTB-66M-R HTB-68M-R - x HTB-82I-R HTB-84I-R HTB-86I-R HTB-88I-R x - HTB-82M-R HTB-84M-R HTB-86M-R HTB-88M-R - x HTB-6x HTB-8x Screwdriver type HTB-3x Solder or 3/16” Quick-connect 1/4” Quick-connect Carrier options- Screwdriver type In-line Right-angle In-line Right-angle 1/4” x 1-1/4” 5 mm x 20 mm HTB-32I-R HTB-34I-R HTB-36I-R HTB-38I-R x - HTB-32M-R HTB-34M-R HTB-36M-R HTB-38M-R - x HTB-5x HTB-52I-R HTB-54I-R HTB-56I-R HTB-58I-R x - HTB-52M-R HTB-54M-R HTB-56M-R HTB-58M-R - x HTB-9x HTB-92I-R HTB-94I-R HTB-96I-R HTB-98I-R x - HTB-92M-R HTB-94M-R HTB-96M-R HTB-98M-R - x Replacement parts Knob 1/4” x 1-1/4” 5 mm x 20 mm Screwdriver 1/4” x 1-1/4” 5 mm x 20 mm HTB-2x, 3x, 4x, HTB-2x, 3x, 5x, and 8x 4x, 5x, BK-1A4287-1 BK-1A4806-2 BK-1A3322 Plastic nut Metal nut Metal nut HTB-6x Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2024 Eaton All Rights Reserved Printed in USA Publication No. 2119 PCN24002 January 2024 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
HTB-28M 价格&库存
很抱歉,暂时无法提供与“HTB-28M”相匹配的价格&库存,您可以联系我们找货
