Effective July 2023
Supersedes June 2017
Technical Data 2106
HKP
1/4” x 1 1/4” Panel-mount fuse holders
Agency information
• UL Recognized: IZLT2, E14853
• CSA Component Acceptance: Class 6225-01, File 47235
• CE (HKP, HKP-L, HKP-W, HKP-OO)
Environmental data
Product features
For 1⁄4" x 1 1⁄4" (6.3 mm x 32 mm) fuses
Maximum panel thickness 5⁄16" (7.9 mm) thick
Bayonet-type knob
Vibration resistant
Military version is designated FHN26G1
Standard plastic nut
Optional metal nut
Cap – BK-9435-1-2
Neoprene washer – 9732
Product
code
HKP-R
HKP-BBHH-R
HKP-HH-R
HKP-L-R
HKP-LW-HH-R
HKP-OO-R
HKP-W-R
Feature
• Temperature rating (RTI): The mounting body for all devices
has a temperature rating of 150 °C. The knob for these
devices are molded plastic with a temperature rating of 150 °C.
• Meets UL 94HB
• Terminal Strength: 5 pounds
• Torque: Mounting – 20 inch-pound
• Salt Spray (corrosion): Test condition B
Ordering information
• Specify packaging prefix and product code
• Optional metal nut, order separately part number
1A4806-2 (100 parts minimum)
Specifications
Standard
⁄4" Quick-Connects, nut and washer assembled
1
⁄4" Quick-Connects
2250 stand-off barrier
Drip-proof knob, 2250V stand-off barrier and 1⁄4" quick connects1
Snap-lock
Drip-proof knob1
1
1. IP53 rating for exposed locations
Voltage
rating
250 V
250 V
250 V
250 V
250 V
250 V
250 V
Current
rating
30 A
15 A
15 A
30 A
15 A
30 A
30 A
HKP
Technical Data 2106
Effective July 2023
Dimensions - in (mm)
Drawing Not to Scale
HKP-BBHH-R, HKP-HH-R, HKPLW-HH-R
HKP, HKP-L-R, and HKP-W-R
HKP-OO-R
Component
Terminal
Body
Cap
Nut
Material
Tin-Plated Brass
Thermoset
Thermoset
Thermoplastic
Packaging code prefix
BK-
Packaging
Description
100 fuseholder components packed separately into a carton
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com/electronics
© 2023 Eaton
All Rights Reserved
Printed in USA
Publication No. 2106 PCN23014M
July 2023
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“HKP-J”相匹配的价格&库存,您可以联系我们找货
