BK/HLRGMF-1.6
BK/HLRGMF-1.6
    EATON(伊顿)
    BK/HLRGMF-1.6
BK/HLRGMF-1.6 数据手册
Volume 4C: Circuit Protection Bussmann series solutions Don't miss a sale or an opportunity to upgrade your fuse protection Three tiers offer distinct levels of circuit protection 1. Ultimate - Unique element designs deliver a powerful combination of operating characteristics in one fuse — fast shortcircuit protection, current limitation, and time-delay with up to 300 kA interrupting ratings. 2. Advanced - Choose between fast-acting, short-circuit, current limiting protection or time-delay energy efficient, current limiting protection based on the application with 200 kA interrupting ratings. Ultimate 3. Basic - Basic single-element protection for service, feeder and branch circuit applications with up to 100 kA interrupting ratings. The arrows below show you the way CUBEFuse™ protection For finger-safe protection in a small footprint up to 600 V and 100 A, upgrade to the time-delay or fast-acting CUBEFuse. Amp rating rejection feature helps prevent overfusing in the CUBEFuse holder (page 1-11) or CCP2-CF UL 98 disconnect switch (page 11-6). Advanced Advanced FRN-R-(amp) Class RK5 - 250 V See page 1-23 LPN-RK-(amp)SP Class RK1 - 250 V See page 1-18 NON-(amp) Class H(K) - 250 V See page 1-15 KTN-R-(amp) Class RK1 - 250 V See page 1-21 FRS-R-(amp) Class RK5 - 600 V See page 1-23 LPS-RK-(amp)SP Class RK1 - 600 V See page 1-18 FCF(amp) Class CF fast-acting finger-safe CUBEFuse up to 100 A with amp rating rejecting holders to help prevent overfusing See page 1-9 TCF(amp) Class CF time-delay Finger-safe CUBEFuse up to 100 A with amp rating rejecting holders to help prevent overfusing See page 1-8 Basic NOS-(amp) Class H(K) - 600 V See page 1-15 KTS-R-(amp) Class RK1 - 600 V See page 1-21 LPJ-(amp)SP Class J time-delay See page 1-13 JKS-(amp) Class J fast-acting See page 1-14 LP-CC-(amp) Class CC time-delay See page 1-5 FNQ-R-(amp)* KTK-R-(amp) Class CC time-delay Class CC fast-acting See page 1-6 See page 1-7 KRP-C-(amp)SP Class L time-delay See page 1-16 KTU-(amp) KLU-(amp) Class L fast-acting Class L time-delay See page 1-17 See page 1-18 * FNQ-R fuses are suggested on primary of control transformers - do NOT upgrade to LP-CC. Introduction Contents Description Catalog section Selecting fused circuit protection The power of space From the revolutionary BussmannTM series CUBEFuse to its unique fuse holder or Compact Circuit Protector, we’re continually innovating to give you products that help you go big, by going small. Introduction Low voltage branch circuit fuses 1 Low voltage supplemental fuses and limiters 2 Electronic, PCB and small dimension fuses 3 High speed fuses 4 IEC and British Standard fuses 5 Photovoltaic fuses, holders and blocks 6 Medium voltage fuses 7 Fuse blocks and holders 8 Power distribution and terminal blocks 9 Connector products 10 Disconnect switches 11 Quik-Spec™ electrical gear 12 Surge protective devices 13 Telecom protection products 14 Accessories 15 Fuse sizing for 600 V building electrical systems Selective coordination Low voltage, branch circuit fuse types and classes Glossary of common electrical terms 16 Electrical formulas Fuse and fuse block cross reference Catalog number index Low-Peak™ Upgrade program and fuse inventory consolidation Inside back cover Bussmann series circuit protection solutions comply with major industrial standards and agency requirements such as: BS, IEC, DIN, UL, NEMA, CSA, CE, C-UL, etc. and are manufactured at facilities that are ISO 9000 certified. This catalog is intended to present product data and provide technical information that will help the end user with design application. Eaton reserves the right, without notice, to change design or construction or any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this catalog. Once a product has been selected, it should be tested by the user in all possible applications. Further, Eaton takes no responsibility for errors or omissions contained in this catalog, or for misapplication of any Eaton product. Extensive product information is available in the Eaton product data sheets available on line at Eaton.com/bussmannseries. ©2018 Eaton BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries i Introduction Selecting fused circuit protection The following fuse selection tables are based on the 2017 NEC and provide fuse recommendations for the listed applications. Application Engineering can be reached via phone (toll-free 855-2877626 ) and email (FuseTech@Eaton.com). These are only suggestions. Final fuse selection should be performed by qualified personnel able to fully assess an application's circuit protection requirements. To locate the recommended fuse product pages, use the index starting on page 16-4. If you need assistance in selecting a fuse, contact the Eaton Application Engineering team Monday through Friday, 7:00 a.m. — 5:00 p.m. Central time. Ballasts Location Type Fluorescent Notes Fuse recommendation Fuse holder recommendation Consult fixture manufacturer for size and type GLR, GMF, GRF HLR GLQ, GMQ HLQ BAF, KTK, FNM, FNQ HPF, HPS KTK-R, FNQ-R, LP-CC HPS-RR, HPF-RR Indoor All other (mercury, sodium, etc.) Outdoor Mercury, sodium, etc. Consult fixture manufacturer for size and type Consult fixture manufacturer for size and type. BBS HPS-L, HPF-L SC up to 15 amps HPF-EE, HPS-EE SC 20 amp HPF-JJ, HPS-JJ SC 25-30 amps HPF-FF, HPS-FF BAF, KTK, FNM, FNQ HEB, HEX, HPC-D KTK-R, FNQ-R, LP-CC HEY, HEZ Capacitors (NEC 460) Protected by Sizing Time-delay fuses 150% to 175% of Full Load Current (FLC) Non time-delay fuses 250% to 300% of Full Load Current (FLC) Fuse/volt recommendation Up to 250 V: LPN-RK_SP, FRN-R Up to 600 V: LPS-RK_SP, FRS-R, LPJ_SP, LP-CC, FNQ-R, TCF Up to 250 V: KTN-R Up to 300 V: JJN Up to 600 V: KTS-R, JKS, KTK-R, JJS, FCF_RN On loadside of motor running overcurrent device Protection recommended as shown, but not required — Electric heat (NEC 424) Heating type Sizing Fuse/volt recommendation Space heating 125% or next size larger but in no case larger than 60 amps for each subdivided load Up to 250 V: LPN-RK_SP, FRN-R, NON Boilers (ASME rated and stamped vessel) 125% or next size larger but in no case larger than 150 amps for each subdivided load ii Up to 300 V: JJN Up to 480 V; SC 25 to SC 60 Up to 600 V: LPS-RK_SP, FRS-R, NOS, JJS, LPJ_SP, LP-CC, FNQ-R, JKS, KTK-R, TCF, SC 1/2 to SC 20, FCF_RN BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Introduction Mains, feeders, branches (NEC 430) Circuit type Circuit loads Sizing Fuse/volt recommendation Up to 250 V: LPN-RK_SP, FRN-R Feeder circuits ≤ 600 A Main, branch and feeder circuits (601-6000 A) Up to 300V: JJN No motor load 100% of non-continuous load plus 125% of continuous load Combination motor and other loads 150% of the FLA of largest motor (if there are two or more motors of same size, one is considered to be the largest) plus the sum of all the FLA for all other motors plus 100% of non-continuous, non-motor load plus 125% of continuous, nonmotor load. A maximum of 175% (or the next standard size if 175% does not correspond to a standard size) is allowed for all but wound rotor and all DC motors. Up to 600 V: LPS-RK_SP, FRS-R, JJS, LPJ_SP, LP-CC, JKS, KTK-R Motor loads 150% of the FLA of largest motor (if there are two or more motors of same size, one is considered to be the largest) plus the sum of all the FLA for all other motors. A maximum of 175% (or the next standard size if 175% does not correspond to a standard size) is allowed for all but wound rotor and all DC motors. — 150% to 225% of full load current of largest motor plus 100% of full load current of all other motors plus 125% of continuous non-motor load plus 100% of non-continuous non-motor load Up to 250 V: LPN-RK_SP, FRN-R Up to 600 V: LPS-RK_SP, FRS-R, LPJ- SP, LP-CC Up to 600 V: KRP-C_SP Motor loads (NEC 430) Circuit voltage Fuse type Fuse sized for Backup overload with motor starter and shortcircuit protection Time-delay fuses Above 600 V — Fuse/volt recommendation Up to 250 V: FRN-R 125% of motor FLA or next size larger Up to 600 V: FRS-R Up to 250 V: LPN-RK_SP 130% of motor FLA or next size larger Up to 600 V: LPS-RK_SP Short-circuit only 175% of motor FLA or next size larger. (If 175% does not correspond to a standard size). If this will not allow motor to start, due to higher than normal inrush currents or longer than normal acceleration times (5 seconds or greater), fuse may be sized up to 225% or next size smaller. NOTE: 150% for wound rotor and all DC motors. Short-circuit only Maximum of 300% of motor FLA or next size larger (if 300% does not correspond to a standard size). If this will not allow motor to start due to higher than normal inrush currents or longer than normal acceleration times (5 seconds or greater), fuses through 600 amps may be sized up to 400% or next size smaller. Note: 150% for wound rotor and all DC motors. — Compare the minimum melting time-current characteristics of the fuses with the timecurrent characteristics of the overload relay curve. The size fuse which is selected should be such that short-circuit protection is provided by the fuse and overload protection is provided by the controller overload relays. 600 V and less Non-time delay and all Class CC fuses Sizing Up to 250 V: LPN-RK_SP, FRN-R Up to 600 V: LPS-RK_SP, FRS-R, LPJ_SP, TCF Up to 250 V: KTN-R Up to 300 V: JJN Up to 600 V: KTS-R, JJS, LP-CC, JKS, KTK-R, FCF_RN Up to 2400 V: JCH, JCK, JCK-A, JCK-B, 2ACLS, 2BCLS, 2CLS, 2HCLS Up to 4800 V: JCL, JCL-A, JCL-B, 5ACLS, 5BCLS, 5CLS, 5HCLS Up to 7200 V: 7BCLS, 7.2WKMSJ, 8ACLS, 8CLS Solenoids (coils) Fuse type Sizing Branch circuit Size at 125% or next size smaller Fuse/volt recommendation Up to 250 V: LPN-RK_SP, FRN-R (best) Up to 600 V: LPS-RK_SP, FRS-R, LPJ_SP, LP-CC, FNQ-R, TCF Up to 32 V: MDL 9-30 A, FNM 20-30 A Supplemental Size at 125% or next size larger Up to 125 V: MDA 25-30 A, FNM 12-15 A Up to 250 V: MDL 1/16-8 A, MDA 2/10-20 A, FNM 1/10-10 A, MDQ 1/100-7 A Up to 500 V: FNQ 1/10-30 A BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries iii Introduction Transformers 600 V nominal or less (NEC 450.3) Protection type Primary only (Note: components on the secondary still need overcurrent protection) Thermal overload protection — Without Transformer impedance — — ≤ 6% Primary and secondary Rated current Optimum protection* NEC maximums Primary < 2 amps 125% or next size larger 300% or next size smaller (see NEC 430.72(C) for control circuit transformer maximum of 500%) Primary ≥ 2 amps but < 9 amps 125% or next size larger 167% or next size smaller Primary ≥ 9 amps 125% or next size larger 125% or next size larger** Secondary < 9 amps (see A) A = 250% Secondary < 9 amps (see C) C = 600% Secondary < 9 amps (see E) With > 6% but < 10% % of primary FLA (or next FLA size smaller) Secondary ≥ 9 amps (see B) Secondary ≥ 9 amps (see D) Fuse/volt recommendation Up to 250 V: LPN-RK_SP, FRN-R B = 250% Primary and secondary fuses at 125% of primary and secondary FLA or next size larger Up to 600 V: KRP-C_SP, LPJ_SP, LPS-RK_SP, FNQ-R, FRS-R, TCF D = 600% E = 400% F = 400% % of secondary FLA A = 167% or next size smaller B = 125% or next size larger** C = 167% or next size smaller Secondary ≥ 9 amps (see F) D = 125% or next size larger** E = 167% or next size smaller F = 125% or next size larger** * When sizing the primary fuse for optimum protection, verify the inrush current with the transformer manufacturer and review fuse time-current characteristics. ** When 125% of FLA corresponds to a standard rating, the next larger size is not permitted. iv BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Introduction Transformers over 600 V nominal (NEC 450.3) Supervised installations Protection for Primary only Transformer impedance Primary Sizing N/A Code maximum of 250% or next standard size if 250% does not correspond to a standard rating Note: Components on the secondary still need overcurrent protection ≤ 6% Secondary volts Secondary sizing Up to 250 V: LPN-RK_SP, FRN-R N/A Up to 600 V: LPS-RK_SP, LPJ-_SP, KRP-C_SP, FRS-R, FNQ-R, TCF N/A Up to 2.475 kV: 2NCLPT, 2CLPT Up to 2.75 kV: 2CLE, 2HLE Up to 2750/5500 V: JCW > 600 V At code maximum of 250% ≤ 600 V At code maximum of 250% Up to 5.5 kV: 5HLE, 5CLE, 5HCL, 5BHCL, 5BHLE, 5AHLE, JCY, MV05, 5.5 ABWNA, 5.5 AMWNA, 5.5 FFN > 600 V At code maximum of 225% 7 Up to 7.2 kV:.2 AMWNA, 7.2 TDLSJ, 7.2 TFLSJ At code maximum of 300% Primary and secondary > 6% but < 10% Fuse/volt recommendation At code maximum of 300% ≤ 600 V At code maximum of 250% Up to 8.3 kV: 8HLE, 8CLE, 8BHLE, 8AHLE, 8CLPT, 8NCLPT, 8HCL, 8.25 FFN Up to 15.5 kV: 15CLPT, 15NCLPT, 15CLE, 15HLE, 15BHLE, 15LHLE, 15HCL, 15BHCL, MV155, 15.5 CAVH Up to 17.5 kV: 17.5 CAV, 17.5 TDM Up to 24 kV: 24 TDM, 24 TFM, 24 FFM Up to 36 kV: 36 CAV, 36 TDQ, 36 TFQ Up to 38 kV: 38CLPT, 38 CAV Unsupervised installations Transformer impedance ≤ 6% Primary Sizing At code maximum of 300% or next standard size if 300% does not correspond to a standard rating Secondary volts Secondary sizing Fuse/volts recommendation Up to 250 V: LPN-RK_SP, FRN-R > 600 V At code maximum of 250% or next standard size if 250% does not correspond to a standard rating Up to 2475 V: 2NCLPT, 2CLPT ≤ 600 V At code maximum of 125% or next standard size if 125% does not correspond to a standard rating At code maximum of 225% or next standard size if 225% does not correspond to a standard rating Up to 5.5 kV: 5HLE, 5CLE, 5HCL, 5BHCL, 5BHLE, 5AHLE, JCY, MV05, 5.5 ABWNA, 5.5 AMWNA, 5.5 FFN > 600 V > 6% but < 10% At code maximum of 300% or next standard size if 300% does not correspond to a standard rating ≤ 600 V At code maximum of 125% or next standard size if 125% does not correspond to a standard rating Up to 600 V: LPS-RK_SP, LPJ-_SP, KRP-C_SP, FRS-R, FNQ-R, TCF Up to 2.75 kV: 2CLE, 2HLE Up to 2750/5500 V: JCW Up to 7.2 kV: 7.2 AMWNA, 7.2 TDLSJ, 7.2 TFLSJ Up to 8.3 kV: 8HLE, 8CLE, 8BHLE, 8AHLE, 8CLPT, 8NCLPT, 8HCL, 8.25 FFN Up to 15.5 kV: 15CLPT, 15NCLPT, 15CLE, 15HLE, 15BHLE, 15LHLE, 15HCL, 15BHCL, MV155, 15.5 CAVH Up to 17.5 kV: 17.5 CAV, 17.5 TDM Up to 24 kV: 24 TDM, 24 TFM, 24 FFM Up to 36 kV: 36 CAV, 36 TDQ, 36 TFQ Up to 38 kV: 38CLPT, 38 CAV Solid state devices (diodes, SCRs, triacs, transistors) Protection type Sizing Fuse/volts recommendation Up to 130 V: FWA Up to 250 V: FWX Short-circuit only F, S, K, and 170M fuse families sized up to several sizes larger than full load RMS or DC rating of device Up to 500 V: FWH Up to 600 V: FWC, KAC, KBC Up to 700 V: FWP, 170M_, SPP Up to 1000 V: FWJ, 170M_, SPJ BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries v BUSSMANN SERIES Do you know about the new 2017 NEC® SCCR requirements? Finding out is easy. Eaton’s Bussmann™ series handbook Code changes affecting Short-Circuit Current Ratings based on the 2017 NEC will help you: Know why SCCR is important. Understand hazards associated with insufficient SCCR. Know what specific NEC chapters, articles, parts and sections are involved. Comply with Code requirements for marking and documenting SCCR. If you’re designing, installing or inspecting equipment, download your copy at Eaton.com/nec2017sccr. Or, check out our comprehensive SCCR resources at Eaton.com/bussmannseries/SCCR. Follow us on social media to get the latest product and support information. Low voltage, branch circuit fuses — 1 Section page Description Fuse holder and block selection guide 2 Fuse reducers Branch circuit fuse dimensions Fuse class The power of space Catalog symbol LP-CC CC 5 FNQ-R 600 V 6 KTK-R 7 TCF The revolutionary BussmannTM series Low-PeakTM CUBEFuseTM delivers the smallest footprint compared to any Class J or RK fuse solution — requiring up to 70% less space when combined with its unique fuse holder. 3-4 Volts CF G 600 V FCF WCF 690 V 11 600 V 12-17 SC 600/480 V LPJ-_SPI indicator 600 V JKS H(K) 250 V NOS 600 V KRP-CL (225 to 600 A) KTU LPN-RK_SPI indicator LPS-RK_SP LPS-RK_SPI indicator 600 V 24-26 600 V 250 V KTS-R 600 V FRN-R_ID indicator FRS-R FRS-R_ID indicator 29-30 600 V JJN 300 V JJS 600 V 31-32 33 P, S, T and TC MB Edison base circuit breakers 27-28 250 V SL, TL and W Plug fuses 23 250 V KTN-R FRN-R T 21 24 LPN-RK_SP RK5 19 22 KLU RK1 18 20 NON KRP-C_SP L 10 TCFH_ Class CF holders LPJ-_SP J 8-9 34 125 V SA fuse adapters Box cover units 35 36 For conductor protection, see cable limiters in Section 2, page 3. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 1-1 Low voltage, branch circuit fuses Contents 1 — Low voltage, branch circuit fuses Fuse holder and block selection guide Catalog pages for the blocks and holders are denoted parenthetically "()" next to their catalog symbol. Fuse class Catalog symbol Blocks DIN-Rail holders Panel mount holders In-line holders CC FNQ-R KTK-R LP-CC BCM (8-6) 3743 (8-14) 4421 (8-14) 4515 (8-14) CHCC (8-8) OPM-1038 (8-12) OPM-NG (8-13) CCP2-CC††† (11-2) HPF-RR (8-43) HPS-RR (8-45) CCPLP††† (30 A) (11-32) HEY (8-53) HEZ (8-52) CF FCF TCF WCF†† TCFH (1-13) TCFHNW (1-13) (Panel and DIN-Rail mount) CCP2-CF††† (11-6) CCP2B††† (11-29) — — HEC (30 A) (8-49) HEG (15 A) (8-49) HEH (20 A) (8-49) HEJ (60 A) (8-49) G SC BG (8-15) G (8-15) — CCPLP††† (20 A) (11-32) HPG-EE (15 A) (8-44) HPS-EE (15 A) (8-45) HPS-FF (30 A) (8-45) HPS-JJ (20 A) (8-45) H(K) 250 V NON (250 V) HM25_ (8-19) HM25060_MW* (8-24) — — — H(K) 600 V NOS (600 V) HM60_ (8-19) HM60030_MW* (8-24) — — — J LPJ JKS JM60_ (8-31) JM60_MW* (8-33) JP60030 (8-30) CH_J (8-28) JT(N) (8-29) — — L KRP-C KRP-CL KLU KTU 51215** 51235** — — — RK1 250 V LPN-RK KTN-R RM25_ (8-21) RM25_MW* (8-26) — — — RK1 600 V LPS-RK KTS-R RM60_ (8-21) RM60_MW* (8-26) — — — RK5 250 V FRN-R RM25_ (8-21) RM25_MW* (8-26) — — — RK5 600 V FRS-R RM60_ (8-21) RM60_MW* (8-26) — — — T 300 V JJN T300 (8-35) T 600 V JJS T600 (8-37) — — — T up to 600 V JJN/JJS BH-0_, BH-1_, BH-3_† (8-39) P, T, TC, TL, W Edison base Box cover units (1-30) — — — S, SL rejection base SA adapters (1-29) — — — Plug fuses * Power distribution fuse blocks. ** Up to 800 A, contact customer satisfaction at 855-287-7626 for more information. † Various blade bolt-on up to 700 A, see data sheets for limitations. †† WCF (wind CUBEFuse) is rated to 690 V and is not a UL Listed Class CF fuse and can only be applied in the TCFHNW holder. ††† UL 98 Listed disconnect switch, available in 1-, 2- and 3-pole versions. 250 V Class R fuse reducers Equipment fuse clip amps Desired fuse (case) amp size 60 100 200 400 600 * Single reducer only (pair not required). 1-2 600 V Class R fuse reducers Catalog no. (pairs) Equipment fuse clip amps 30 NO.263-R 60 30 NO.213-R 60 NO.216-R 60 NO.226-R 100 NO.2621-R 100 NO.2641-R 200 NO.242-R 100 NO.2661-R 200 NO.2662-R 400 NO.2664-R* Desired fuse (case) amp size 100 200 400 600 Catalog no. (pairs) 30 NO.663-R 30 NO.216-R 60 NO.616-R 60 NO.626-R 100 NO.2621-R 100 NO.2641-R 200 NO.642-R 100 NO.2661-R 200 NO.2662-R 400 NO.2664-R* * Single reducer only (pair not required). BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Branch circuit fuse dimensions Class J — in (mm) Class CC — in (mm) LPJ and JKS LP-CC, FNQ-R, KTK-R and LP-CC A A C D E B A B Amp range E H A B 1.5 (38) 0.41 (10) Amp range B G 70 to 600A 1 to 60A Up to 30 I F Low voltage, branch circuit fuses Low voltage, branch circuit fuses — 1 A B C D E F G H I Class CF — in (mm) 1-30 2.25 (57) 0.81 (21) — — 0.5 (13) — — — — TCF, FCF and WCF 35-60 2.38 (60) 1.06 (27) — — 0.63 (16) — — — — 70-100 4.63 (118) 1.13 (29) 3.63 (92) 2.63 (67) 1.0 (25) 0.75 (29) 0.13 (3) 0.41 (10) 0.28 (7) 110200 5.75 (146) 1.63 (41) 4.38 (111) 3.0 (76) 1.38 (35) 1.13 (29) 0.19 (5) 0.38 (10) 0.28 (7) 225400 7.12 (181) 2.11 (54) 5.25 (133) 3.26 (83) 1.87 (48) 1.62 (41) 0.25 (6) 0.56 (14) 0.4 (10) 450600 8.0 (203) 2.6 (66) 6.0 (152) 3.31 (84) 2.12 (54) 2.0 (51) 0.53 (14) 0.72 (18) 0.53 (14) B C A Up to 100 A D E B C Class RK1 and RK5 — in (mm) FRN-R, KTN-R LPN-RK (250 V) and FRS-R, KTS-R LPS-RK (600 V) A 110 to 400 A A A B D E Fuse amps A B C 1-15 17-1/2* 20 1.88 (48) 0.75 (19) 1.0 (25) D B Up to 60 A 70 to 600 A Basic dimensions are same as Class H, one-time (NON and NOS) fuses. Note: relating to dimensional compatibility these fuses can replace existing Class H, RK1 and RK5 fuses. E 250 V fuses 600 V fuses 0.23 (6) Amp range A B A B 0.27 (7) Up to 30 2 (51) 0.56 (14) 5.0 (127) 0.81 (21) 35-60 3 (76) 0.81 (21) 5.5 (140) 1.06 (27) 7.88 (200) 1.34 (34) 25-30 0.31 (8) 35-40 0.36 (9) 70-100 0.44 (11) 110-200 7.13 (181) 1.56 (40) 9.63 (245) 1.84 (47) 225-400 8.63 (219) 2.38 (61) 11.63 (295) 2.59 (66) 450-600 10.38 (264) 2.88 (73) 13.38 (340) 3.13 (80) 45-50 2.13 (54) 60 1.0 (25) 70 80-90 1.13 (29) 0.67 (17) 3.01 (76) 1.26 (32) 100 0.49 (12) 0.64 (16) 0.57 (14) 110 0.51 (13) 125 0.51 (13) 150 0.51 (13) 175 3.62 (92) 2.9 (74) 1.34 (34) 1.02 (26) 0.57 (14.5) 225 0.63 (16) 250 0.73 (18.5) 350 4.25 (108) 400 3.46 (88) 1.69 (43) 1.47 (36) 5.88 (149) 1.06 (27) RK1 LPN-RK, LPS-RK 70-100 5.88 (149) 1.16 (30) 7.88 (200) 1.16 (30) 110-200 7.13 (181) 1.66 (42) 9.63 (245) 1.66 (42) 225-400 8.63 (219) 2.38 (61) 11.63 (295) 2.38 (61) 450-600 10.38 (264) 2.88 (73) 13.38 (340) 2.88 (73) 0.57 (14.5) 200 300 RK5 FRN-R, FRS-R, — RK1 KTN-R, KTS-R 0.79 (20) 0.86 (21.5) 0.86 (21.5) * Time-delay (TCF) only. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 1-3 1 — Low voltage, branch circuit fuses Class T — in (mm) JJN (300 V) and JJS (600 V) A C D A A B B 1.0 (25) B JJN up to 60 A JJS up to 30 A JJN 70 to 1200 A JJS 70 to 800 A JJS 35 to 60 A 300 V JJN 600 V JJS Amp range A B C D Amp range A B C D Up to 30 0.88 (22) 0.41 (10) — — Up to 30 1.50 (38) 0.56 (14) — — 35-60 0.88 (22) 0.56 (14) — — 35-60 1.56 (40) 0.81 (21) — — 70-100 2.16 (55) 0.75 (19) 1.56 (40) 0.84 (21) 70-100 2.95 (75) 0.75 (19) 2.36 (60) 1.64 (42) 110-200 2.44 (62) 0.88 (22) 1.69 (43) 0.84 (21) 110-200 3.25 (83) 0.88 (22) 2.50 (64) 1.66 (42) 225-400 2.75 (70) 1.00 (25) 1.84 (47) 0.86 (22) 225-400 3.63 (92) 1.00 (25) 2.72 (69) 1.73 (44) 450-600 3.06 (78) 1.25 (32) 2.03 (52) 0.88 (22) 450-600 3.98 (101) 1.25 (32) 2.96 (75) 1.78 (45) 601-800 3.38 (86) 1.75 (45) 2.22 (56) 0.89 (23) 601-800 4.33 (110) 1.75 (45) 3.17 (81) 1.88 (48) 801-1200 4.00 (102) 2.00 (51) 2.53 (64) 1.08 (27) Branch circuit fuse dimensions Class L — in (mm) KLU, KRP-C_SP, KRP-CL, KTU J3 J3 J2 J1 J4 All slots and holes C1 C2 J4 I 801 to 2000 A A 601 to 800 A A J2 J1 2001 to 3000 A 3500 to 4000 A G 4500 to 6000 A D F B Amp range 601-800 801-1200 1350-1600 1800-2000 2001-2500 3000 3500-4000 4500-5000 6000 A B 8.63 (219) 10.75 (273) 10.75 (273) 10.75 (273) 10.75 (273) 10.75 (273) 10.75 (273) 10.75 (273) 10.75 (273) C1 2.4 (61) 6.75 (172) 2.4 (61) 6.75 (172) 3.0 (76) 6.75 (172) 3.5 (89) 6.75 (172) 4.8 (122) 6.75 (172) 5.0 (127) 6.75 (172) 5.75 (146) 6.75 (172) 6.25 (159) 6.75 (172) 7.13 (181) 6.75 (172) C2 5.75 (146) 5.75 (146) 5.75 (146) 5.75 (146) 5.75 (146) 5.75 (146) 5.75 (146) 5.75 (146) 5.75 (146) D 3.75 (95) 3.75 (95) 3.75 (95) 3.75 (95) 3.75 (95) 3.75 (95) 3.75 (95) 3.75 (95) 3.75 (95) F 2.00 (51) 2.00 (51) 2.38 (60) 2.75 (70) 3.50 (89) 4.00 (102) 4.75 (121) 5.25 (133) 5.75 (146) G 0.38 (10) 0.38 (10) 0.44 (11) 0.5 (13) 0.75 (19) 0.75 (19) 0.75 (19) 1.0 (25) 1.0 (25) I 0.63 (16) 0.63 (16) 0.63 (16) 0.63 (16) 0.63 (16) 0.63 (16) 0.63 (16) 0.63 (16) 0.63 (16) J1 — — — — 1.75 (45) 1.75 (45) 1.75 (45) 1.75 (45) 1.75 (45) J2 — — — — 1.38 (35) 1.38 (35) 1.38 (35) 1.38 (35) 1.38 (35) J3 J4 — — — — 0.88 (22) 0.88 (22) 1.63 (41) 1.63 (41) 1.63 (41) — — 0.81 (21) 0.81 (21) 0.88 (22) 0.88 (22) 0.88 (22) Note: KRP-CL (225-600 A) fuses have same dimensions as 601-800 A case size KTU (200-600 A) have same dimensions, except tube 3" length x 2" diameter (76 x 51 mm); terminal 1-5/8" width x 1-1/4" thick (41 x 32 mm). 1-4 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Low voltage, branch circuit fuses — 1 Ratings 100 • 600 Vac (or less) • 300 Vdc (1/2 to 2-8/10 A and 20-30 A) • 150 Vdc (3-15 A) • Amps 1/2-30 A • IR 2011/65/EU 10 • 200 kA RMS Sym. • 20 kA DC Agency information • Amp rating Volts UL Listed Std 248-4, Class CC, Guide JDDZ, File E4273, CSA Certified, Class 1422-02, File 53787, RoHS compliant (20-30 A)*, CE Time in seconds • Low voltage, branch circuit fuses 200 20 25 30 Time-delay, current-limiting, rejection-type fuse — 12 seconds (minimum) at 200% rated amps. For dimensions, see page 1-3. 3 3-1/2 4 4-1/2 6 8 10 12 15 Time-current characteristics — average melt 1/2 6/10 8/10 1 1-1/4 LP-CC Class CC Low-Peak™ time-delay, rejection-type fuses 1 * Contact factory for RoHS compliance on other ratings. Features • Inventory consolidation of 13/32" x 1-1/2" supplemental fuses reduces SKU investment and minimizes potential for misapplying fuse • Selective coordination ratio of 2:1 (within Low-Peak fuse family) prevents electrical shutdowns from extending beyond the failed circuit Typical applications • Branch circuit protection • Specialized circuits • Industrial controls and panels • Isolated, in-line fuse holder Catalog no. (amps) LP-CC-1/2 LP-CC-1-8 /10 LP-CC-4-1/2 LP-CC-10 LP-CC-6/10 LP-CC-2 LP-CC-5 LP-CC-12 LP-CC-8/10 LP-CC-2-1/4 LP-CC-5-6/10 LP-CC-15 LP-CC-1 LP-CC-2-1/2 LP-CC-6 LP-CC-20 LP-CC-1-1/8 LP-CC-2-8/10 LP-CC-6-1/4 LP-CC-25 LP-CC-1-1/4 LP-CC-3 LP-CC-7 LP-CC-30 LP-CC-1-4/10 LP-CC-3-2/10 LP-CC-7-1/2 LP-CC-1-1/2 LP-CC-3-1/2 LP-CC-8 LP-CC-1-6/10 LP-CC-4 LP-CC-9 0.01 1000 200 kA interrupting rating provides high ratings for control circuit locations Current in amps Current limitation curves B 30 25 20 15 2-8/10 1-1/4 Amp Rating • 100 Time-delay coupled with Class CC current-limiting response provides close sizing on small motor and relay circuits, and maximum component short-circuit current rating protection 10 • 1 Class CC rejection feature, with appropriate fuse block, prevents inserting lesser-rated supplementary fuses Instantaneous Peak Let-Through Current In Amps • 0.4 0.1 A Prospective Short-Circuit Current (RMS Sym. Amps) Recommended holders and blocks for Class CC fuses, see page 1-2. Data sheet no. 1023 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 1-5 1 — Low voltage, branch circuit fuses 7-1/2 5 3 1 Time-delay, branch circuit, rejection-type fuse. For superior electrical protection, Eaton recommends upgrading FNQ-R fuse applications to Bussmann series Low-Peak LP-CC fuses, see page 1-5. For dimensions, see page 1-3. Time-current characteristics — average melt 1/2 FNQ-R Class CC Limitron™ time-delay, rejection-type fuse Amp rating 100 Ratings Volts • 600 Vac (or less) • 300 Vdc (15-20 A) • 32 Vdc (self certified) • Amps 1/4-30 A • IR • 200 kA RMS Sym. • 20 kA DC (15 and 20 A only) 2011/65/EU 10 Agency information • UL Listed, Std 248-4, Class CC, Guide JDDZ, File E4273, CSA Certified, Class 1422-01, File 53787, RoHS compliant, CE Time in seconds • 1 Features • Class CC rejection feature, with appropriate fuse block, prevents inserting lesser-rated supplementary fuses • Time-delay compatible with inrush characteristic of small control transformers • Current limitation at Class CC levels provides maximum component short-circuit current rating protection • 200 kA interrupting rating provides high ratings for control circuit locations 0.1 Isolated, in-line fuse holders 0.08 0.01 Current in amps Catalog no. (amps) FNQ-R-1/4 FNQ-R-1-3/10 FNQ-R-3-2/10 FNQ-R-8 FNQ-R-3/10 FNQ-R-1-4/10 FNQ-R-3-1/2 FNQ-R-9 FNQ-R-4/10 FNQ-R-1-1/2 FNQ-R-4 FNQ-R-10 FNQ-R-1/2 FNQ-R-1-6/10 FNQ-R-4-1/2 FNQ-R-12 FNQ-R-6/10 FNQ-R-1-8/10 FNQ-R-5 FNQ-R-15 FNQ-R-3/4 FNQ-R-2 FNQ-R-5-6/10 FNQ-R-17-1/2 FNQ-R-8/10 FNQ-R-2-1/4 FNQ-R-6 FNQ-R-20 FNQ-R-1 FNQ-R-2-1/2 FNQ-R-6-1/4 FNQ-R-25 FNQ-R-1-1/8 FNQ-R-2-8/10 FNQ-R-7 FNQ-R-30 FNQ-R-1-1/4 FNQ-R-3 FNQ-R-7-1/2 Recommended holders and blocks for Class CC fuses, see page 1-2. Data sheet no. 1014 1-6 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 200 Industrial controls and panels • 300 400 500 • 100 Line protection, small control transformers 10 • 1 Typical applications Low voltage, branch circuit fuses — 1 Time-current characteristics — average melt Low voltage, branch circuit fuses KTK-R Class CC Limitron™ fast-acting, rejection-type fuse Fast-acting, branch circuit, rejection-type fuse. For superior electrical protection, Eaton recommends upgrading KTK-R fuse applications to Bussmann series Low-Peak LP-CC fuses, see page 1-5. For dimensions, see page 1-3. Ratings • Volts 600 Vac (or less) • Amps 1/10-30 A • IR 200 kA RMS Sym. 2011/65/EU Agency information • UL Listed, Std 248-4, Class CC, Guide JDDZ, File E4273, CSA Certified, File 53787, Class 1422-02, RoHS compliant, CE Features • Class CC rejection feature, with appropriate fuse block, prevents inserting lesser-rated supplementary fuses • Current limitation at Class CC levels provides maximum component short-circuit current protection • 200 kA interrupting rating provides high ratings for control circuit locations Typical applications • Specialized circuits • Industrial controls and panels • Isolated, in-line fuse holders (street lighting) Catalog no. (amps) KTK-R-1/10 KTK-R-6/10 KTK-R-3-1/2 KTK-R-10 KTK-R-1/8 KTK-R-3/4 KTK-R-4 KTK-R-12 KTK-R-2/10 KTK-R-1 KTK-R-5 KTK-R-15 KTK-R-1/4 KTK-R-1-1/2 KTK-R-6 KTK-R-20 KTK-R-3/10 KTK-R-2 KTK-R-7 KTK-R-25 KTK-R-30 KTK-R-4/10 KTK-R-2-1/2 KTK-R-8 KTK-R-1/2 KTK-R-3 KTK-R-9 Recommended holders and blocks for Class CC fuses, see page 1-2. Data sheet no. 1015 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 1-7 1 — Low voltage, branch circuit fuses TCF Class CF Low-Peak time-delay CUBEFuse™ 2011/65/EU The Bussmann series Low-Peak CUBEFuse is a finger-safe UL Class CF current-limiting, dual-element, time-delay branch circuit fuse and fuse holder system; 10 seconds minimum operating time at 500% rated amps. With Class J electrical performance, teh time-delay CUBEFuse is available in indicating and non-indicating versions, this finger-safe fuse has a very compact, space-saving size and is easily applied using the CUBEFuse holder (TCFH_N), UL 98 Compact Circuit Protector switch (CCP2-_CF) or Compact Circuit Protector Base (CCP2B up to 100 A) used in the Quik-Spec™ Coordination Panelboard). For dimensions, see page 1-3. Features • Smallest installed footprint of any UL Class CC, J, or R fuse solution • Easy application using CUBEFuse holders (TCFH_N), UL 98 Compact Circuit Protector (CCP2) switches and Compact Circuit Protector Base (CCP2B up to 100 A). See data sheet 9007 for details on the CUBEFuse holder, 10801 for details on the CCP2-_ CF switch and 1161 for the CCP2B. • Holders and switches have an amp rating rejection feature to help prevent overfusing; 30, 60 and 100 A switches and holders will hold any CUBEFuse up to its rating, 200 and 400 A switches and 200, 225 and 400 A holders will hold any CUBEFuse 110 A and above up to its rating • The indicating version features local easyID™ open fuse technology for faster troubleshooting and reduced downtime • Faster response to damaging faults helps reduce destructive thermal and magnetic forces • True dual-element fuse construction with a minimum 10 seconds time-delay at 500% of rating • Long time-delay minimizes nuisance openings caused by temporary overloads and transient surges • Up to 300 kA interrupting rating safely interrupts virtually any fault • Robust cycling and inrush current withstand • Low let-through currents under fault conditions • Provides Type 2 “No Damage” protection for IEC motor starters when properly sized • Easy selective coordination with any other Bussmann series Low-Peak Class CC, J, L or RK1 fuse with simple 2:1 amp ratio between upstream and downstream fuses Ratings • Volts • 600 Vac • • * Finger-safe status depends on final, installed application, and will require using accessory shrouds for 110 to 400 A ratings. Amps • 6-400 A (indicating) • • 300 Vdc Typical applications 1-400 A (non-indicating) Interrupting rating • 300 kA RMS Sym. (Up to 100 A UL) • Electrical panelboards • Machinery disconnects Industrial controls and panels Required finger-safe systems • 200 kA RMS Sym. (110 to 400 A UL) • • 200 kA RMS Sym. (Up to 100 A CSA) • • 100 kA DC (Up to 400 A UL and up to 100 A CSA) Watts loss at rated current Fuse amps Catalog numbers (amps) Indicating CUBEFuse Watts TCF6 TCF35 TCF90 TCF225 30 3.99 TCF10 TCF40 TCF100 TCF250 60 6.23 TCF15 TCF45 TCF110 TCF300 100 9.51 TCF17-1/2 TCF50 TCF125 TCF350 200 18.6 TCF20 TCF60 TCF150 TCF400 225 17.6 TCF25 TCF70 TCF175 400 35.2 TCF30 TCF80 TCF200 Agency information Non-Indicating CUBEFuse TCF1RN TCF25RN TCF70RN TCF175RN • UL Listed Class CF fuse: Guide JDDZ, File E4273 (up to 400 A) • CSA® Certified fuse: Class 1422-02, File 053787_C_000 (up to 100 A) TCF3RN TCF30RN TCF80RN TCF200RN • CE (100 A and below) TCF6RN TCF35RN TCF90RN TCF225RN • RoHS compliant TCF10RN TCF40RN TCF100RN TCF250RN Operating and storage temperature range • -40 to 80°C (-40°F to 176°F) TCF15RN TCF45RN TCF110RN TCF300RN TCF17-1/2RN TCF50RN TCF125RN TCF350RN TCF20RN TCF60RN TCF150RN TCF400RN Recommended holders for Class CF fuses, see page 1-12. Data sheet no. 9000 (fuses) and 9007 (holders) 1-8 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Low voltage, branch circuit fuses — 1 Low voltage, branch circuit fuses 400A 1000 200A 225A 250A 110 to 400 A time-current characteristics — average melt 110A Up to 100 A time-current characteristics — average melt TIME IN SECONDS 100 10 1 100 1,000 0.01 10,000 0.1 CURRENT IN AMPS 110 to 400 A current let-through curves B 400A 250A 225A 200A 110A 10,000 1,000 , 10,000 100 1,000 A 100 INSTANTANEOUS PEAK LET-THRU CURRENT IN AMPS 100,000 PROSPECTIVE SHORT CIRCUIT CURRENT SYMMETRICAL RMS AMPS 100,000 Up to 100 A current let-through curves Data sheet no. 9000 (fuses) and 9007 (holders) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 1-9 1 — Low voltage, branch circuit fuses FCF Class CF fast-acting CUBEFuse Amp rating 100 30 40 50 60 20 15 6 10 1000 3 Finger-safe, non-indicating, fast-acting CUBEFuse for UPS and critical applications with a 4 minute maximum clearing time at 200%, rated current for 1 to 30 A fuse, 6 minute maximum clearing time at 200%, rated current for 35 to 60 A fuse. For dimensions, see page 1-3. 1 Time-current characteristics — average melt Ratings Volts 600 Vac/dc (or less) • Amps 1-100 A • IR 100 • 300 kA RMS Sym. (UL up to 60 A) • 200 kA RMS Sym. (CSA all ratings and UL 70 to 100 A) • 2011/65/EU Time in seconds • 50 kA DC Agency information • UL Listed, Guide JDDZ, File E4273, CSA Certified, Class 1422- 02, File 53787, RoHS compliant, CE 10 1 Features Class CF meets Class J fast-acting electrical performance requirements • True fast-acting for faster response to damaging faults to help reduce destructive thermal and magnetic forces • High interrupting rating to safely interrupt faults up to 300 kA • No venting of arc or molten metal and gases during opening • Low let-through currents under fault conditions Current in amps Catalog no. (amps) Current limitation curves FCF45RN FCF90RN FCF100RN FCF3RN FCF25RN FCF50RN FCF6RN FCF30RN FCF60RN FCF10RN FCF35RN FCF70RN FCF15RN FCF40RN FCF80RN Recommended holders for Class CF fuses, see page 1-12. B 100,000 100A 60A 10,000 30A 15A 1000 A Prospective short-circuit current (Symmetrical RMS Amps) Data sheet no. 2147 (fuses) and 9007 (holders) 1-10 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 100,000 10,000 1000 100 100 300,000 FCF20RN Instantaneous peak let-through current in amps FCF1RN 0.01 10,000 • 0.1 1000 Smallest installed footprint of any class fuse including Class CC, J, and RK 100 • 10 The world's first finger-safe power fast-acting fuse system 1 • WCF fast-acting 690 V wind power CUBEFuse Operating and storage temperature range Finger-safe, non-indicating, fast-acting CUBEFuse for wind power generation systems with a maximum clearing time at 200% rated current: 4 minutes for 1 to 30 amp fuses, 6 minutes for 35 to 60 amp fuses, 8 minutes for 70 to 100 amp fuses. For dimensions, see page 1-3. -40°C to 90°C Ratings • 50 kA AC (1-60 A) • 30 kA AC (70-100 A) Agency information • Amp rating 100 30 40 50 60 1000 20 2011/65/EU 15 IR 6 Amps 1-100 A • 10 • Time-current characteristic curves — average melt 3 Volts 690 Vac The wind CUBEFuse must be mounted in the 690 V WCF holders that are rated for 690 volts. Not to be installed in the CCP2-CF or CCP2B disconnect switches. See page 1-12. 1 • Mounting 100 UL Recognized, Guide JFHR2, File E56412, cURus Component Certified C22.2, RoHS compliant, CE Features • Minimize design time, operating outage time and replacement cost with fuses qualified in excessively changing environmental conditions • Simplify compatibility with readily available industry standard holders • Temperature derating — Designed to maximize rated capacity in elevated environmental temperatures • Overload protection — Proven to clear faults faster than the UL requirement • Power loss — Minimal energy consumption leading to increased efficiency 0.1 0.01 Current in amps Typical application Current limitation curves WCF60RN WCF100RN WCF3RN WCF20RN WCF40RN WCF70RN WCF100RN WCF6RN WCF25RN WCF45RN WCF80RN WCF10RN WCF30RN WCF50RN WCF90RN Recommended holders for WCF fuses, see page 1-12. Watts loss at rated current Amps Fuse catalog no. Watts 15 WCF15RN 3.48 30 WCF30RN 5.45 60 WCF60RN 7.27 100 WCF100RN 11.5 100A 60A 40A 50A 30A 15A 10,000 1000 A 100 Prospective short-circuit current (Symmetrical RMS Amps) 300,000 WCF35RN 100,000 WCF15RN 10,000 WCF1RN 1000 Catalog no. (amps) B 100,000 100 Protecting wind system transformers, pitch and speed controls, and turbine HVAC and lighting Instantaneous peak let-through current in amps • 1 10,000 Maximize return on investment with fuses proven to withstand harsh temperatures 1,000 • 100 Minimize chances of equipment failure and personnel injury when using full range fuses having the industry's fastest response time to low-magnitude faults 10 • 10 Time in seconds Maximize uptime and reliability using fuses designed and listed to UL 248-1 1 • Data sheet no. 9009 (fuses) and 9007 (holders) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 1-11 Low voltage, branch circuit fuses Low voltage, branch circuit fuses — 1 1 — Low voltage, branch circuit fuses CUBEFuse™ finger-safe fuse holders Catalog no. Max holder amps Fuse amp range 600 V UL Listed TCFH30N 2011/65/EU 30 1-30 TCFH60N 60 1-60 TCFH100N 100 1-100 TCFH200N 200 110-200 TCFH225N 225 110-225 TCFH400N 400 110-400 30 1-30 690 V UL Recognized TCFH30NW The Bussmann series CUBEFuse holder is a finger-safe modular system of single-pole 30, 60, 100, 200, 225 and 400 amp holders. All holders dovetailed together to create the desired number of poles for the application, including mixed amp ratings between the 30, 60 and 100 amp holders. The 200, 225 and 400 amp holders require installing lugs to make conductor connections. These are listed on page 1-14. The CUBEFuse holder is available as the 600 V UL Listed version utilizing the time-delay Low-Peak™ CUBEFuse (TCF up to 400 A) or fast-acting CUBEFuse (FCF up to 100 A), or the 690 V UL Recognized version utilizing the fast-acting wind CUBEFuse (WCF up to 100 A). Ratings • Volts • 600 Vac / 300 Vdc (UL Listed) • 690 Vac (UL Recognized up to 100 A) • Amps • 30, 60, 100, 200, 225, 400 A • SCCR • 300 kA RMS Sym. (30, 60, 100 A UL Listed) • 200 kA RMS Sym. (200, 225, 400 A UL Listed) • 200 kA RMS Sym. (CSA® Certified 100 A and below) • 100 kA DC (UL Listed and CSA Certified 100 A and below) • 50 kA RMS Sym. (UL Recognized) TCFH60NW 60 1-60 TCFH100NW 100 1-100 Features • Finger-safe construction for enhanced safety* • Amp rating rejection helps prevent overfusing by rejecting higher fuse amp ratings • Smallest installed fuse and holder footprint of any Class J or R installation • All holders dovetail together to create the required number of poles, mixed 30, 60 and 100 A holders dovetail together • 30, 60 and 100 A holders have dual wire rated box lug terminals for wiring ease • 200, 225 and 400 A holders available with a variety of lugs and terminal shrouds for application flexibility • Up to 300 kA SCCR withstands high fault currents * 200, 225 and 400 A holders require installed shrouds. 30, 60 and 100 A CUBEFuse holder fuse applications All 30, 60 and 100 A CUBEFuse holders dovetail together to create the desired number of poles. Each holder accepts CUBEFuse amp ratings up to its rating. E.g., the 60 amp holder will accept a CUBEFuse from 1 to 60 A. Agency information • 600 V UL Listed, Guide IZLT, File E14853 • 690 V UL Recognized, Guide IZLT2, File E14853 • CSA Certified, Class 6225-01, File 47235, cURus component Certified (30, 60 and 100 A holders) • CE (100 A and below) • RoHS compliant Mounting Holder catalog no. Volts TCFH30N • 35 mm DIN-Rail/panel (Up to 100 A) TCFH60N • Panel mount (200 to 400 A) TCFH100N Operating and storage temperature range • CUBEFuse type and amp range -40°C to 80°C (-40°F to 176°F) 600 TCF and TCF_RN FCF_RN 1-30 1-30 1-60 1-60 1-100 1-100 TCFH30NW TCFH60NW 690 — — 1-60 1-100 Data sheet no. 9007 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 — 1-30 TCFH100NW 1-12 WCF_RN Eaton.com/bussmannseries Low voltage, branch circuit fuses — 1 Conductor ratings and torque for 30, 60 and 100 A holders Dimensions — in (mm) Terminal wire rating Low voltage, branch circuit fuses Ratings are for 75°C Cu AWG solid/stranded conductors. Torque is in N•m (lb-in). Holder catalog no. TCFH30N / TCFH30NW TCFH60N / TCFH60NW TCFH100N / TCFH100NW Single 8-10; 2.8 (25), 12-18; 2.6 (20) 10-14; 2.6 (20), 4-8; 3.9 (35) 10-18; 2.6 (20)**, 1-8; 4.5 (40)† Dual 10-18; 2.8 (25)* 10-18; 2.6 (20), 6-8; 3.9 (35) 6; 5.1 (45)† * 10-18 AWG stranded, 14-18 AWG solid ** Solid and stranded † Stranded Recommended Bussmann series fuses Type Amp range Data sheet 600 volt UL Listed Time-delay indicating Low-Peak™ 6-100 A Time-delay non-indicating Low-Peak 1-100 A Fast-acting non-indicating 1-100 A 2147 1-100 A 9009 9000 690 volt UL Recognized Fast-acting wind power Max height with Amps H I J K L M fuse 30 2.3 (58) 0.76 (19) 1.36 (34) 0.15 (4) — — 2.36 (60) 60 2.6 (66) 1.03 (26) 1.60 (41) 0.17 (4) — — 2.73 (69) 100 2.91 (74) 1.05 (27) 2.01 (51) 0.15 (4) 0.80 (20) 2.51 (64) 3.27 (83) Data sheet no. 9007 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 1-13 1 — Low voltage, branch circuit fuses 200, 225 and 400 A CUBEFuse holder fuse applications Terminal shroud Holder catalog no. Volts TCFH200N CUBEFuse amp range 110-200 TCFH225N 600 Vac/300 Vdc TCFH400N 110-225 110-400* * Achieving 400 A continuous current requires three ganged holders and installed lug catalog number CCP2-L4B-3 to permit the necessary copper conductor size. Available lug kits For complete installation, the 200, 225 and 400 A CUBEFuse holders require lugs. The table below contains the information necessary for ordering the desired lug kit for the application. Accessories Catalog no. CCP2-TS2-3 CCP2-PB2 Holder amps 200/225 CCP2-CWK2 CCP2-TS6-3 CCP2-PB6 400 Description 3-pole terminal shroud Phase barriers (pack of 2) 1/4” QC terminals. Use with CCP2-L2-1A, CCP2-MW2-3 and CCP2-MW2-6 lugs (pack of 12) 3-pole terminal shroud Phase barriers (pack of 2) Lug All 200, 225 and 400 amp holders require installing lugs. Only three ganged holders can accept terminal shrouds. See table below. Recommended Bussmann series fuses Type Time-delay indicating Low-Peak Time-delay non-indicating Low-Peak Amp range Data sheet 110-400 A 9000 Available lugs, conductor ratings and terminal torques Catalog no. Description 200/225 A holders CCP2-L2-1 Stainless steel lug CCP2-L2-1A Aluminum lug* CCP2-MW2-3 3-port multi-wire terminal with shroud*† CCP2-MW2-6 6-port multi-wire terminal with shroud*† Lugs per cat. no. Wire range AWG (mm2) Wire type/ temp. Conductor torque N•m (lb-in) Lug mounting screw torque N•m (lb-in) 1 1 3 3 350-4 (185-25) 350-4 (185-25) 2-14 (35-2.5) 6-14 (16-2.5) Cu 75°C Cu/Al 75°C Cu/Al 75°C Cu/Al 75°C 20.3 (180) 28.2 (250) 7.9 (70) 2.8 (25) 0.9 (8) 13.5 (120) 10.8 (95) 10.8 (95) * These lugs also accept 1/4” quick connect control wire terminals. Order catalog number CCP2-CWK2 (package of 12 terminals). 400 A holders CCP2-L4-1 CCP2-L4-1A CCP2-L4B-3 CCP2-L4B-3A CCP2-L6-3 CCP2-L6-3A Stainless steel lug Aluminum lug Stainless steel lug kit with shroud† Aluminum lug kit with shroud† 2-port stainless steel lug kit with shroud 2-port aluminum lug kit with shroud 1 1 3 3 3 3 500-3 (240-35) 500-3 (240-35) 750-500 (400-240) 750-500 (400-240) (2) 500-2 (240-35) (2) 500-2 (240-35) Cu 75°C Cu/Al 75°C Cu 75°C Cu/Al 75°C Cu 75°C Cu/Al 75°C 42.0 (375) 42.0 (375) 57.0 (500) 62.0 (550) 42.0 (375) 42.0 (375) 10-14 = 3.9 (35) CCP2-MW6-6 6-port multi-wire terminal with shroud† 3 1/0-14 (50-2.5) Cu/Al 75°C 8 = 4.5 (40) 4-6 = 5.0 (45 1/0-2 = 5.6 (50) † This is a lug kit with three lugs and a shroud for installation on three ganged CUBEFuse holders. Data sheet no. 9007 1-14 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 22.0 (200) Low voltage, branch circuit fuses — 1 Dimensions — mm (in) Low voltage, branch circuit fuses 200/225 A holder 87.6 (3.4) 40.7 (1.6) 104.8 4.1) 25.3 (1.0) 108.1 (4.2) 34.9 (1.4) 2xØ 4.2 (0.2) 282.6 (11.1) 3-pole ganged 200 A holder with installed shroud 23.9 (0.9) 124.5 (4.9) 400 A holder 99.6 (3.9) 27.5 (1.1) 139.2 (5.5) 43.66 (1.7) 2xØ 4.2 (0.2) 33.4 (1.3) 167.7 (6.6) 276.0 (10.9) 3-pole ganged 400 A holder with installed shroud Data sheet no. 9007 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 1-15 1 — Low voltage, branch circuit fuses Ordering a complete 200/225 A holder installation For a complete installation, select from the following required and optional components, and accessories. Catalog no. Holders Amps TCFH200N Poles 200 1 Order required quantity for installation Required TCFH225N 225 And Lug kits Description CCP2-L2-1 Stainless steel lug, 75° Cu only, 350 kcmil-4, 1 per pack CCP2-L2-1A Aluminum lug, 75°C Cu/Al, 350 kcmil-4, 1 per pack CCP2-MW2-3 3-port multi-wire lug, 75°C Cu/Al, 2-14, 3 per pack, includes terminal shroud CCP2-MW2-6 6-port multi-wire lug, 75°C Cu/Al, 6-14, 3 per pack, includes terminal shroud And Accessories Terminal shrouds Description CCP2-TS2-3 3-pole terminal shroud with phase shields, 1 per pack Phase barriers Description CCP2-PB2 Phase barriers, 2 per pack And Control terminals Description CCP2-CWK2 1/4” quick-connect control wire terminals - mounts on installed lug (cannot be used with lug CCP2-L2-3), 12 per pack Data sheet no. 9007 1-16 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Low voltage, branch circuit fuses — 1 Ordering a complete 400 A holder installation Low voltage, branch circuit fuses For a complete installation, select from the following required and optional components, and accessories. Catalog no. Holder Amps Required TCFH400N Poles 1 400 Order required quantity for installation And Lug kits Description CCP2-L4-1 Stainless steel lug, 75° Cu only, 500 kcmil-3, 1 per pack CCP2-L4-1A Aluminum lug, 75° Cu only, 500 kcmil-3, 1 per pack CCP2-L4B-3 Stainless steel lug, 75° Cu only, 750-500 kcmil, 3 per pack, includes terminal shroud CCP2-L4B-3A Aluminum lug, 75°C Cu/Al, 750-500 kcmil, 3 per pack, includes terminal shroud CCP2-L6-3 2-port stainless steel lug, 75° Cu only, 500 kcmil-2, 3 per pack, includes terminal shroud CCP2-L6-3A 2-port aluminum lug, 75°C Cu/Al, 500 kcmil-2, 3 per pack, includes terminal shroud CCP2-MW6-6 6-port multi-wire lug, 75°C Cu/Al, 1/0-14, 3 per pack, includes terminal shroud Accessories And Terminal shrouds Description CCP2-TS6-3 3-pole terminal shroud with phase shields, 1 per pack Phase barriers Description CCP2-PB6 Phase barriers, 2 per pack Data sheet no. 9007 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 1-17 1 — Low voltage, branch circuit fuses SC Class G general purpose fuses Time-current characteristics — average melt Fast-acting (1/2-6 A) and time-delay (7-60 A) Class G fuses. SC fuses are size rejecting measuring 13/32" in diameter by various lengths associated with their amp rating ranging from 1-5/16" to 2-1/4". This feature helps prevent overfusing. See the catalog numbers table for length by amp rating. Ratings • Volts • 600 Vac (1/2-20 A) • 480 Vac (25-60 A) • 170 Vdc (1/2-20 A) • 300 Vdc (25-60 A) • Amps 1/2-60 A • IR • 100 kA RMS Sym. • 10 kA DC 2011/65/EU Agency information • UL Listed Std 248-5, Class G, Guide JDDZ, File E4273, CSA Certified, Class 1422-01, File 53787, RoHS compliant, CE Features Rejection feature with variations in length helps prevent overfusing Typical applications • Fusible branch circuit panelboards • HVAC branch circuit protection Catalog no. (amps) and length 1-5/16" 1-13/32" 1-5/8" 2-1/4" SC-1/2 SC-20 SC-25 SC-35 SC-30 SC-40 SC-1 SC-1-1/2 SC-45 SC-2 SC-50 SC-2-1/2 SC-60 SC-3 SC-4 SC-5 Current limitation curves B 100,000 60A 30A 20A 15A 1000 A 100 Prospective short-circuit current (Symmetrical RMS Amps) A-B = Asymmetrical available peak (2.3 x Sym. RMS Amps) SC-6 SC-7 SC-8 SC-10 SC-12 SC-15 Recommended holders and blocks for Class G fuses, see page 1-2. Data sheet no. 1024 1-18 100,000 • 10,000 100 kA interrupting rating provides cost-effective branch circuit fusing for systems with high short-circuit current levels 1000 • 100 Class G current limiting for component and branch circuit protection Instantaneous peak let-through current in amps • BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Low voltage, branch circuit fuses — 1 600 400 125 200 250 60 80 100 30 15 10 6 3 300 Amp rating 200 100 Ratings Volts • 600 Vac (or less) • 300 Vdc (or less)* • Amps 1-600 A • IR 10 2011/65/EU • 300 kA RMS Sym. • 100 kA DC Time in seconds • * Does not apply to indicating versions. 1 Agency information • UL Listed, Guide JDDZ, File E4273, CSA Certified Class J per CSA 22.2 No 248.8, Class 1422-02, File 53787, RoHS compliant, CE 0.1 Features • Series combination ratings with branch circuit breakers allows broad range of coverage, independent of breaker manufacturer 10,000 100 Selective coordination ratio of 2:1 (within Low-Peak fuse family) prevents electrical shutdowns from extending beyond the failed circuit 1000 0.01 10 • Separate overload and short-circuit elements provide time delay for sizing of high inrush loads linked with Class J current limitation 1 • Current in amps Current limitation curves B 100,000 Typical applications LPJ-1SP LPJ-4-1/2SP LPJ-25SP* LPJ-125SP* LPJ-1-1/4SP LPJ-5SP LPJ-30SP* LPJ-150SP* LPJ-1-6/10SP LPJ-5-6/10SP LPJ-35SP* LPJ-175SP* LPJ-1-8/10SP LPJ-6SP* LPJ-40SP* LPJ-200SP* LPJ-2SP LPJ-7SP* LPJ-45SP* LPJ-225SP* LPJ-2-1/4SP LPJ-8SP* LPJ-50SP* LPJ-250SP* LPJ-2-1/2SP LPJ-9SP* LPJ-60SP* LPJ-300SP* LPJ-2-8/10SP LPJ-10SP* LPJ-70SP* LPJ-350SP* LPJ-3SP LPJ-12SP* LPJ-80SP* LPJ-400SP* LPJ-3-2/10SP LPJ-15SP* LPJ-90SP* LPJ-450SP* LPJ-3-1/2SP LPJ-17-1/2SP* LPJ-100SP* LPJ-500SP* LPJ-4SP LPJ-20SP* LPJ-110SP* LPJ-600SP* 1000 A 100 300,000 Catalog no. (amps) 30A 15A 200,000 Industrial control 100,000 • 10,000 10,000 Machinery disconnects 1000 Branch circuit breaker panelboard mains • 200A 100A 60A 100 Power panelboards • Instantaneous peak let-through current in amps • 600A 400A Prospective short-circuit current (Symmetrical RMS Amps) *Available with optional permanent replace fuse indication To order, place "I" at end of catalog number Example: LPJ-6SPI. Available with silver plated terminals Add SP/ in front of catalog number. Recommended holders and blocks for Class J fuses, see page 1-2. Data sheet no. 1006 (0-60 A) and 1007 (70-600 A) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 1-19 Low voltage, branch circuit fuses Dual-element, time-delay Class J fuse; 10 seconds (minimum) at 500% rated amps, available with optional indication on select ratings (see catalog numbers table). For dimensions, see page 1-3. Time-current characteristics — average melt 1 LPJ_SP Class J Low-Peak dual-element, timedelay fuses 1 — Low voltage, branch circuit fuses 600 400 200 300 100 Fast-acting, Class J current-limiting fuse. For superior electrical protection, Eaton recommends upgrading JKS fuse applications to Bussmann series Low-Peak LPJ fuses See page 1-19. For dimensions, see page 1-3. 60 Time-current characteristics — average melt 30 JKS Class J Limitron™ fast-acting fuses Amp rating JKS 100 Ratings • Volts 600 Vac (or less) • Amps 1-600 A • IR 200 kA RMS Sym. 10 Agency information 600 Vac, UL Listed, Std. 248-8, Class J, Guide JDDZ, File E4273, CSA Certified, Class 1422-02, File 53787, CE Time in seconds • Features • Current limitation for non-inductive circuits provides Class J current-limiting response to maximum ground fault and shortcircuit conditions • 200 kA interrupting rating provides protection at all circuit locations • Economical circuit protection for high-fault current circuits 1 0.1 40 JKS-70 JKS-225 JKS-2 JKS-20 JKS-80 JKS-250 JKS-3 JKS-25 JKS-90 JKS-300 JKS-4 JKS-30 JKS-100 JKS-350 JKS-5 JKS-35 JKS-110 JKS-400 JKS-6 JKS-40 JKS-125 JKS-450 JKS-8 JKS-45 JKS-150 JKS-500 JKS-10 JKS-50 JKS-175 JKS-600 JKS-12 JKS-60 JKS-200 Recommended holders and blocks for JKS Class J fuses, see page 1-2. Current in amps Current limitation curves B 400,000 100,000 600A 400A 200A 100A 60A 10,000 30A A 1000 1000 200,000 JKS-15 Instantaneous peak let-through current in amps JKS-1 10,000 0.01 Catalog no. (amps) 100,000 Machinery disconnects 1000 Power panelboards • 10,000 • 100 Typical applications Prospective short-circuit current (Symmetrical RMS Amps) A-B = Asymmetrical available peak (2.3 x Sym. RMS Amps) Data sheet no. 1026 (1-60 A) and 1027 (70-600 A) 1-20 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Low voltage, branch circuit fuses — 1 Catalog no. (amps) 250 V NON NON-1/8 NON-5 NON-40 NON-175 General purpose, Class K5 and H non-current-limiting fuse 250 V NON and 600 V NOS fuses. For superior electrical protection, Eaton recommends upgrading NON (250 Vac) and NOS (600 Vac) fuse applications to Bussmann series Low-Peak LPN-RK (250 Vac) and LPS-RK (600 Vac) fuses, see pages 1-24 to 1-26. For dimensions, see page 1-3. NON-1 NON-8 NON-65 NON-300 Ratings NON-1-1/4 NON-9 NON-70 NON-350 • Volts • NON − 250 Vac − 125 Vdc (0-100 A) • NOS − 600 Vac • Amps 1/8-600 A • IR NON-7 NON-60 NON-250 NON-1-1/2 NON-10 NON-75 NON-400 NON-1-6/10 NON-12 NON-80 NON-450 NON-2 NON-15 NON-90 NON-500 NON-2-1/2 NON-20 NON-100 NON-600 NON-3 NON-25 NON-110 NON-3-2/10 NON-30 NON-125 NON-4 NON-35 NON-150 NOS-12 NOS-70 NOS-200 NOS-2 NOS-15 NOS-75 NOS-225 • 10 kA RMS Sym. (NON and NOS 65-600 A) NOS-3 NOS-20 NOS-80 NOS-250 • 50 kA @ 125 Vdc (NON 0-60 A) NOS-4 NOS-25 NOS-90 NOS-300 • 10 kA @ 125 Vdc (NON 65-100 A) NOS-5 NOS-30 NOS-100 NOS-350 UL Listed 250 V Class K5 (0-60 A), Std 248-9, Class H (65-600 A), Std 248-6, (125 Vac, NON 0-100 A) 600 V Class K5 (0-60 A), Std 248-9, Class H (70-600 A), Std 248-6, Guide JDDZ, File E4273 CSA Certified • 250 V (0-12, 65-600 A)† • 600 V (0-600 A), Class 1421-01, File 53787 CE Features Basic overcurrent protection. Typical applications • NON-8/10 NOS-1 † For CSA Certified 15-60 A ratings, see PON in Section 5, page 2. • NON-200 NON-225 50 kA RMS Sym. (NON and NOS 0-60 A) • • NON-45 NON-50 • • • NON-6 NON-6-1/4 600 V NOS Agency information • NON-1/2 NON-3/4 Light duty circuit locations NOS-6 NOS-35 NOS-110 NOS-400 NOS-7 NOS-40 NOS-125 NOS-450 NOS-8 NOS-45 NOS-150 NOS-500 NOS-9 NOS-50 NOS-175 NOS-600 NOS-10 NOS-60 Recommended fuse reducers 250 V Fuse amps 600 V Clip amp size Catalog no. (pair) Fuse amps Clip amp size Catalog no. (pair) 30 60 NO.263 30 60 NO.663 30 100 NO.213 30 100 NO.216 60 100 NO.216 60 100 NO.616 60 200 NO.226 60 200 NO.626 100 200 NO.2621 100 200 NO.2621 100 400 NO.2641 100 400 NO.2641 200 400 NO.2642 200 400 NO.2642 100 600 NO.2661 100 600 NO.2661 200 600 NO.2662 200 600 NO.2662 400 600 NO.2664 400 600 NO.2664 Recommended blocks for Class K5 and H fuses, see page 1-2. Data sheet no. 1030 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 1-21 Low voltage, branch circuit fuses NON and NOS Class K5/H general purpose onetime fuses 1 — Low voltage, branch circuit fuses Ratings Volts • 600 Vac (or less) • 300 Vdc (601-2000 A, 3000 A) • Amps 601-6000 A • IR 2011/65/EU 10 • 300 kA RMS Sym. • 100 kA DC Agency information • Amp rating 100 Time in seconds • 4000 5000 6000 300 1600 2000 2500 3000 Time-delay Class L fuses — 4 seconds (minimum) at 500% rated amps. Use KRP-CL for current ratings under 601 A. For dimensions, see page 1-4. 1200 Time-current characteristics — average melt 800 KRP-C_SP Class L Low-Peak time-delay fuses UL Listed 248-10, Guide JFHR, File E56412, CSA Certified, Class 1422-02, File 53787, Class L per CSA C22.2, No 248.10, RoHS compliant, CE 1 Features • Interrupting rating of 300 kA RMS symmetrical provides adequate ratings without obsolescence for all electrical systems, big or small Quality construction, using high-grade materials, provides lower watts loss and operating temperatures with superior arc quenching during current-limiting action Typical applications • Large machinery disconnects Catalog no. (amps) KRP-C-601SP KRP-C-1000SP KRP-C-1800SP KRP-C-3500SP KRP-C-650SP KRP-C-1100SP KRP-C-1900SP KRP-C-4000SP KRP-C-700SP KRP-C-1200SP KRP-C-2000SP KRP-C-4500SP KRP-C-750SP KRP-C-1350SP KRP-C-2001SP KRP-C-5000SP KRP-C-800SP KRP-C-1400SP KRP-C-2400SP KRP-C-6000SP KRP-C-801SP KRP-C-1500SP KRP-C-2500SP KRP-C-900SP KRP-C-1600SP KRP-C-3000SP Recommended blocks for Class L fuses, see page 1-2. 6000A 5000A 4000A 3000A 2500A 2000A 1600A 1200A 800A 601A 100,000 10,000 A 1000 1000 300,000 Power panelboards B 200,000 • 1,000,000 100,000 Large distribution switchboards Current limitation curves 10,000 • Current in amps Instantaneous peak let-through current in amps • 0.01 200,000 Selective coordination ratio of 2:1 (within Low-Peak fuse family) prevents electrical shutdowns from extending beyond the failed circuit 100,000 • 0.1 10,000 Time-delay of 4 seconds at 5 times rating allows closer sizing on large motor loads combined with Class L current limitation 1000 • Prospective short-circuit current (Symmetrical RMS Amps) Data sheet no. 1008(601-2000 A) and 1009 (2001-6000 A) 1-22 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries KRP-CL current-limiting, time-delay fuses KTU Class L Limitron fast-acting fuses Current-limiting, time-delay fuse with Class L dimensions for the 601-800 A case size. For dimensions, see page 1-4. Fast-acting, Class L fuses. For superior electrical protection, Eaton recommends upgrading KTU fuse applications to Bussmann series Low-Peak KRP-C fuses, see page 1-22. For dimensions, see page 1-4. Ratings • Volts 600 Vac (or less) Ratings • Amps 225-600 A • Volts 600 Vac (or less) • IR 200 kA RMS Sym. • Amps 601-6000 A • IR 200 kA RMS Sym. 2011/65/EU Agency information • Agency information RoHS compliant Features • • 2011/65/EU • Time-delay of 4 seconds at 5 times rating allows closer sizing inductive loads coupled with an equivalent Class L current limitation UL Listed, Std 248-10, Class L, Guide JDDZ, File E4273, CSA Certified, Class 1422-02, File 53787, RoHS compliant, CE Features 601 to 800 A Class L case size permits applying circuit protection from 225 to 600 A for downsize fusing of 800 amp Class L fused switches • 200 kA interrupting rating provides protection at all circuit locations • Economical protection for high-fault current circuits • Quality construction using high-grade materials provides lower watts loss and operating temperatures with superior arc quenching during current-limiting action Typical applications Typical applications • Large distribution switchboards • Power panelboards • Large distribution switchboards • Machinery disconnects • Power panelboards Catalog no. (amps) Catalog no. (amps) KRP-CL-225 KRP-CL-300 KRP-CL-400 KRP-CL-500 KTU-601 KTU-850 KTU-1500 KTU-2500 KRP-CL-250 KRP-CL-350 KRP-CL-450 KRP-CL-600 KTU-650 KTU-900 KTU-1600 KTU-3000 KTU-700 KTU-1000 KTU-1800 KTU-3500 KTU-750 KTU-1100 KTU-2000 KTU-4000 KTU-800 KTU-1200 KTU-2001 KTU-5000 KTU-801 KTU-1400 KTU-2400 KTU-6000 Recommended blocks for Class L fuses, see page 1-2. Recommended blocks for Class L fuses, see page 1-2. Data sheet no. 1016 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Data sheet no. 1010 Eaton.com/bussmannseries 1-23 Low voltage, branch circuit fuses Low voltage, branch circuit fuses — 1 1 — Low voltage, branch circuit fuses KLU Class Limitron time-delay fuses Time-delay, Class L fuses - 5 seconds (minimum) at 500% rated amps. For superior electrical protection, Eaton recommends upgrading KLU fuse applications to Bussmann series Low-Peak KRP-C fuses, see page 1-22. Use KRP-CL for current ratings under 601 A. For dimensions, see page 1-4. Ratings LPN-RK_SP (250 V) and LPS-RK_SP (600 V) Class RK1 Low-Peak dual-element, time-delay fuses Current-limiting, dual-element, time-delay Class RK1 fuses; 10 seconds (minimum) at 500% rated amps (8 seconds for 0-30 A sizes). Available with optional indication on select ratings (see catalog numbers table). For dimensions, see page 1-3. Ratings • Volts 600 Vac (or less) • Amps 601-4000 A • IR 200 kA RMS Sym. 2011/65/EU • Volts • LPN-RK − 250 Vac (or less) − 125 Vdc* (0-60 A) Agency information • − 250 Vdc* (70-600 A) UL Listed, Std 248-10, Class L, Guide JDDZ, File E4273, CSA Certified, CSA Class 1422-02, File 53787, RoHS compliant, CE • − 300 Vdc* Features • 200 kA interrupting rating provides protection at all circuit locations • Economical protection for high-fault current circuits • Amps 1/10-600 A • IR Typical applications • Large distribution switchboards • Power panelboards • Large machinery disconnects LPS-RK − 600 Vac (or less) • 300 kA RMS Sym. • 100 kA DC * Does not apply to indicating versions. Agency information • Catalog no. (amps) KLU-601 KLU-1000 KLU-1800 KLU-650 KLU-1200 KLU-2000 KLU-700 KLU-1500 KLU-2500 KLU-800 KLU-1600 KLU-3000 KLU-4000 Recommended blocks for Class L fuses, see page 1-2. UL Listed, Guide JDDZ, File E4273, CSA Certified, Class RK1 per CSA C22.2, No 248.12, Class 1422-02, File 53787, CE Features • Separate overload and short-circuit elements provide time delay for close sizing of high inrush loads linked with RK1 current-limitation and selective coordination ratio of 2:1 (within Low-Peak fuse family) helps prevent widespread blackouts • Inventory consolidation of Class RK1, RK5 and H fuses for reduced SKU investment and minimizing potential for misapplying fuse • 300 kA RMS symmetrical interrupting rating provides adequate ratings without obsolescence for all electrical systems, big or small • Insulated end caps reduces exposure to live parts and extends air gap to distance between blades of adjacent mounted fuses or to housing Typical applications Data sheet no. 1013 1-24 • Large distribution switchboards • Power panelboards • Motor control centers • Machinery disconnect switches Data sheet no. LPN; 1003 (up to 60 A), 1007 (70-600 A) LPS 1001 (up to 60 A), 1002 (70-600 A) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Low voltage, branch circuit fuses — 1 LPN-RK-4/10SP LPN-RK-3-2/10SP LPN-RK-25SP LPN-RK-200SP** LPN-RK-1/2SP LPN-RK-3-1/2SP LPN-RK-30SP LPN-RK-225SP** LPN-RK-6/10SP LPN-RK-4SP LPN-RK-35SP** LPN-RK-250SP** LPN-RK-8/10SP LPN-RK-4-1/2SP LPN-RK-40SP** LPN-RK-300SP** LPN-RK-1SP LPN-RK-5SP LPN-RK-45SP** LPN-RK-350SP** LPN-RK-1-1/8SP LPN-RK-5-6/10SP LPN-RK-50SP** LPN-RK-400SP** LPN-RK-1-1/4SP LPN-RK-6SP LPN-RK-60SP** LPN-RK-450SP** LPN-RK-1-4/10SP LPN-RK-6-1/4SP LPN-RK-70SP** LPN-RK-500SP** LPN-RK-600SP** LPN-RK-1-6/10SP LPN-RK-8SP LPN-RK-80SP** LPN-RK-1-8/10SP LPN-RK-9SP LPN-RK-90SP** LPN-RK-2SP LPN-RK-10SP LPN-RK-100SP** 600 V LPS-RK LPS-RK-1/10SP LPS-RK-2-1/4SP LPS-RK-10SP** LPS-RK-100SP** LPS-RK-2/10SP LPS-RK-2-1/2SP LPS-RK-12SP** LPS-RK-110SP** LPS-RK-3/10SP LPS-RK-2-8/10SP LPS-RK-15SP** LPS-RK-125SP** LPS-RK-4/10SP LPS-RK-3SP LPS-RK-17-1/2SP** LPS-RK-150SP** LPS-RK-1/2SP LPS-RK-3-2/10SP LPS-RK-20SP** LPS-RK-175SP** LPS-RK-6/10SP LPS-RK-3-1/2SP LPS-RK-25SP** LPS-RK-200SP** LPS-RK-8/10SP LPS-RK-4SP LPS-RK-30SP** LPS-RK-225SP** LPS-RK-1SP LPS-RK-4-1/2SP LPS-RK-35SP** LPS-RK-250SP** LPS-RK-1-1/8SP LPS-RK-5SP LPS-RK-40SP** LPS-RK-300SP** LPS-RK-1-1/4SP LPS-RK-5-6/10SP LPS-RK-45SP** LPS-RK-350SP** LPS-RK-1-4/10SP LPS-RK-6SP** LPS-RK-50SP** LPS-RK-400SP** LPS-RK-1-1/2SP LPS-RK-6-1/4SP** LPS-RK-60SP** LPS-RK-450SP** LPS-RK-1-6/10SP LPS-RK-7SP** LPS-RK-70SP** LPS-RK-500SP** LPS-RK-1-8/10SP LPS-RK-8SP** LPS-RK-80SP** LPS-RK-600SP** LPS-RK-2SP LPS-RK-9SP** LPS-RK-90SP** 300 LPN-RK amp rating 100 10 1 0.1 0.01 Current in amps * 0-60 A fuses available with Nickel plate option. Example: LPS-RK30SPNP). 70-600 A fuses available with tin-plate option. Example: LPS-RK-100SP-TP. ** Available with optional indication; to order, place "I" at end of catalog number Example: LPN-RK-35SPI or LPS-RK-15SPI. Recommended blocks for Class RK1 fuses, see page 1-2. Data sheet no. LPN-RK 1003 (up to 60 A), 1007 (70-600 A) LPS-RK 1001 (up to 60 A), 1002 (70-600 A) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 1-25 Low voltage, branch circuit fuses LPN-RK-150SP** LPN-RK-175SP** 1000 LPN-RK-17-1/2SP LPN-RK-20SP 100 LPN-RK-2-8/10SP LPN-RK-3SP 10 LPN-RK-2/10SP LPN-RK-3/10SP 1 LPN-RK-110SP** LPN-RK-125SP** 1/10 LPN-RK-12SP LPN-RK-15SP Time in seconds LPN-RK-2-1/4SP LPN-RK-2-1/2SP 0.1 LPN-RK-1/10SP LPN-RK-15/100SP 15/100 2/10 3/10 4/10 1/2 6/10 8/10 1 1-1/4 1-6/10 2 2-1/2 3-2/10 4 5 6-1/4 8 10 12 LPN Time-current characteristics — average melt Catalog no. (amps) 250 V LPN-RK* 1 — Low voltage, branch circuit fuses LPN Current limitation curves 0.1 200A 30A A Prospective short-circuit current (Symmetrical RMS Amps) A-B = Asymmetrical available peak (2.3 x Sym. RMS Amps) 1000 100 10 0.1 1 1000 1000 Current in amps 100A 60A 10,000 200,000 1 600A 400A 100,000 Time in seconds 10 100,000 10,000 LPS-RK amp rating 100 0.01 B 400,000 Instantaneous peak let-through current in amps 2/10 3/10 4/10 1/2 6/10 8/10 1-1/4 1 1-6/10 2 2-1/2 3-2/10 4 5 6-1/4 8 10 12 300 1/10 LPS Time-current characteristics — average melt LPS Current limitation curves B Instantaneous peak let-through current in amps 400,000 100,000 600A 400A 200A 100A 60A 10,000 30A 15A 300,000 100,000 1000 1000 10,000 A Prospective short-circuit current (Symmetrical RMS Amps) A-B = Asymmetrical available peak (2.3 x Sym. RMS Amps) Data sheet no. LPN-RK 1003 (up to 60 A), 1007 (70-600 A) LPS-RK 1001 (up to 60 A), 1002 (70-600 A) 1-26 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Low voltage, branch circuit fuses — 1 Catalog no. (amps) 250 V KTN-R KTN-R-1 KTN-R-15 KTN-R-70 KTN-R-200 KTN-R-2 KTN-R-20 KTN-R-75 KTN-R-225 KTN-R-3 KTN-R-25 KTN-R-80 KTN-R-250 KTN-R-4 KTN-R-30 KTN-R-90 KTN-R-300 Ratings KTN-R-5 KTN-R-35 KTN-R-100 KTN-R-350 Volts KTN-R-6 KTN-R-40 KTN-R-110 KTN-R-400 KTN-R-8 KTN-R-45 KTN-R-125 KTN-R-450 KTN-R-10 KTN-R-50 KTN-R-150 KTN-R-500 KTN-R-12 KTN-R-60 KTN-R-175 KTN-R-600 KTS-R-1 KTS-R-12 KTS-R-70 KTS-R-225 KTS-R-2 KTS-R-15 KTS-R-75 KTS-R-250 KTS-R-3 KTS-R-30 KTS-R-80 KTS-R-300 KTS-R-4 KTS-R-35 KTS-R-90 KTS-R-350 KTS-R-5 KTS-R-40 KTS-R-125 KTS-R-400 KTS-R-6 KTS-R-45 KTS-R-150 KTS-R-450 KTS-R-8 KTS-R-50 KTS-R-175 KTS-R-10 KTS-R-60 KTS-R-200 KTS-R-20 KTS-R-100 KTS-R-500 KTS-R-25 KTS-R-110 KTS-R-600 Fast-acting, current-limiting Class RK1 fuses. For superior electrical protection, Eaton recommends upgrading KTN-R fuse applications to Bussmann series Low-Peak LPN-RK 250 V or LPS-RK 600 V fuses, see pages 1-24 to 1-26. For dimensions, see page 1-3. • • KTN-R − 250 Vac (or less) − 250 Vdc (70-350 A) • • • KTS-R 600 Vac (or less) Amps 1-600 A IR • 200 kA RMS Sym. • 100 kA Vdc (KTN-R) Agency information • KTN-R • • • CSA Certified, Class 1422-02, File 53787 KTS-R • • • UL Listed, Std 248-12, Class RK1, Guide JDDZ, File E4273 UL Listed, Std 248-12, Class RK1, Guide JDDZ, File E54273 600 V KTS-R Recommended blocks for Class RK1 fuses, see page 1-2. CSA Certified, C22.2 No 248.12, Class 1422-02, File 53787 CE Features • Current limitation for non-inductive circuits provides Class RK1 current-limiting response to maximum ground fault and shortcircuit conditions • 200 kA interrupting rating provides high ratings at all circuit locations • Economical protection for high-fault current circuits Typical applications • Panelboards Data sheet no. 1043 (KTN-R), 1044 (KTS-R) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 1-27 Low voltage, branch circuit fuses KTN-R (250 V) and KTS-R (600 V) Class RK1 Limitron fast-acting fuses 1 — Low voltage, branch circuit fuses 600 400 200 100 300 60 KTS-R Time-current characteristics — average melt 30 KTN-R Time-current characteristics — average melt Amp rating 100 Time in seconds 10 1 0.1 10,000 1000 100 40 0.01 Current in amps KTS-R Current limitation curves B 100,000 600A 400A 200A 100A 10,000 60A 30A 1000 1000 100,000 A 10,000 Instantaneous peak let-through current in amps 400,000 200,000 KTN-R Current limitation curves Prospective short-circuit current (Symmetrical RMS Amps) A-B = Asymmetrical available peak (2.3 x Sym. RMS Amps) Data sheet no. 1043 (KTN-R), 1044 (KTS-R) 1-28 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Low voltage, branch circuit fuses — 1 Dual-element, time-delay Class RK5 fuses. FRN-R — 10 seconds (minimum) at 500% rated amps (8 seconds for 0-30 A sizes). FRS-R — 10 seconds (minimum) at 500% rated amps. FRN-R and FRS-R available with optional indication on select ratings (see catalog numbers table). For superior electrical protection, Eaton recommends upgrading to Bussmann series Low-Peak LPN-RK (250 V) or LPS-RK (600 V) fuses, see pages 1-24 to 1-26. For dimensions, see page 1-3. Ratings • Volts • • FRN-R − 250 Vac (or less) FRN-R-1/8 FRN-R-2-1/4 FRN-R-12* FRN-R-110 FRN-R-15/100 FRN-R-2-1/2 FRN-R-15* FRN-R-125 FRN-R-2/10 FRN-R-2-8/10 FRN-R-17-1/2* FRN-R-150 FRN-R-1/4 FRN-R-3 FRN-R-20* FRN-R-175 FRN-R-3/10 FRN-R-3-2/10 FRN-R-25* FRN-R-200 FRN-R-4/10 FRN-R-3-1/2 FRN-R-30* FRN-R-225 FRN-R-1/2 FRN-R-4 FRN-R-35* FRN-R-250 FRN-R-6/10 FRN-R-4-1/2 FRN-R-40* FRN-R-300 FRN-R-8/10 FRN-R-5 FRN-R-45* FRN-R-350 FRN-R-50* FRN-R-400 FRN-R-60* FRN-R-450 − 250 Vdc (225-600 A) FRN-R-1-1/4 FRN-R-6-1/4 FRN-R-70 FRN-R-500 FRN-R-600 FRN-R-1-4/10 FRN-R-7 FRN-R-75 FRN-R-1-1/2 FRN-R-7-1/2 FRN-R-80 − 300 Vdc 1/10-30 A, 65-600 A FRN-R-1-6/10 FRN-R-8* FRN-R-85 − 250 Vdc* 35-60 A FRN-R-1-8/10 FRN-R-9* FRN-R-90 FRS-R-2 FRS-R-10* FRS-R − 600 Vac (or less) 600 V FRS-R FRS-R-1/10 200 kA RMS Sym. 20 kA DC Agency information FRN-R • UL Listed, Std 248-12, Class RK5, Guide JDDZ, File E4273 • CSA Certified, Class 1422-01, File 53787 FRS-R • UL Listed, Std 248-12, Class RK5, Guide JDDZ, File E4273 • CSA Certified, Class 1422-02, File 53787 CE Features • FRN-R-100 FRN-R-5-6/10 * Does not apply to indicating versions. • FRN-R-10* FRN-R-6 IR • FRN-R-2 FRN-R-1 • • FRN-R-1/10 FRN-R-1-1/8 Amps 1/10-600 A • 250 V FRN-R − 125 Vdc (1/10-60 A, 110-200 A) • • Catalog no. (amps) Separate overload and short-circuit elements provide time-delay for sizing as close as 125% of motor FLA • 2:1 selective coordination amp ratio (within the Fusetron RK5 fuse family) helps prevent overcurrent events from opening upstream Fusetron fuses • Insulated end caps for 225-600 A (FRN-R) and 65-600 A (FRS-R) fuses reduces exposure to live parts and extends air gap to distance between blades of adjacent mounted fuses or to housing FRS-R-100 FRS-R-1/8 FRS-R-2-1/4 FRS-R-12* FRS-R-110 FRS-R-15/100 FRS-R-2-1/2 FRS-R-15* FRS-R-125 FRS-R-2/10 FRS-R-2-8/10 FRS-R-17-1/2* FRS-R-150 FRS-R-1/4 FRS-R-3 FRS-R-20* FRS-R-175 FRS-R-3/10 FRS-R-3-2/10 FRS-R-25* FRS-R-200 FRS-R-4/10 FRS-R-3-1/2 FRS-R-30* FRS-R-225 FRS-R-1/2 FRS-R-4 FRS-R-35* FRS-R-250 FRS-R-6/10 FRS-R-4-1/2 FRS-R-40* FRS-R-300 FRS-R-8/10 FRS-R-5 FRS-R-45* FRS-R-350 FRS-R-1 FRS-R-5-6/10 FRS-R-50* FRS-R-400 FRS-R-1-1/8 FRS-R-6* FRS-R-60* FRS-R-450 FRS-R-1-1/4 FRS-R-6-1/4* FRS-R-65 FRS-R-500 FRS-R-600 FRS-R-1-4/10 FRS-R-7* FRS-R-70 FRS-R-1-1/2 FRS-R-7-1/2* FRS-R-75 FRS-R-1-6/10 FRS-R-8* FRS-R-80 FRS-R-1-8/10 FRS-R-9* FRS-R-90 * Available with indication To order, place "ID" at the end of the catalog number. Example: FRN-R-30ID or FRS-R-7ID. Recommended blocks for Class RK5 fuses, see page 1-2. Typical applications • Power panelboards • Motor control centers • Combination starters • Machinery disconnects Data sheet no. FRN-R; 1019 (up to 60 A), 1020 (70-600 A) FRS-R 1017 (up to 60 A), 1018 (70-600 A) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 1-29 Low voltage, branch circuit fuses FRN-R (250 V) and FRS-R (600 V) Class RK5 Fusetron™ energy efficient, dual-element, time-delay fuses 1 — Low voltage, branch circuit fuses FRN-R Current limitation curves FRS-R Current limitation curves B 100A 60A 10,000 30A 200A 100A 60A Prospective short-circuit current (Symmetrical RMS Amps) A-B = Asymmetrical available peak (2.3 x Sym. RMS Amps) 30A 10,000 15A A 1000 1000 200,000 1000 100,000 A 600A 400A Prospective short-circuit current (Symmetrical RMS Amps) A-B = Asymmetrical available peak (2.3 x Sym. RMS Amps) Data sheet no. FRN-R; 1019 (up to 60 A), 1020 (70-600 A) FRS-R 1017 (up to 60 A), 1018 (70-600 A) 1-30 100,000 200A 100,000 10,000 600A 400A Instantaneous peak let-through current in amps 100,000 1000 B 400,000 10,000 Instantaneous peak let-through current in amps 400,000 200,000 400 FRS-R Time-current characteristics — average melt 600 200 100 60 30 8 10 15 FRN-R Time-current characteristics — average melt BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Low voltage, branch circuit fuses — 1 Very fast-acting, current-limiting 300 V (JJN) and 600 V (JJS) Class T fuse. For dimensions, see page 1-4. Ratings • • JJS 600 Vac (or less) Amps Multi-family meter stacks • VFD line protection JJN-35 JJN-110 JJN-400 JJN-2 JJN-40 JJN-125 JJN-450 JJN-3 JJN-45 JJN-150 JJN-500 JJN-6 JJN-50 JJN-175 JJN-600 JJN-10 JJN-60 JJN-200 JJN-700 JJN-15 JJN-70 JJN-225 JJN-800 • JJN 1-1200 A JJN-20 JJN-80 JJN-250 JJN-1000 • JJS 1-800 A JJN-25 JJN-90 JJN-300 JJN-1200 JJN-30 JJN-100 JJN-350 IR 600 V JJS • 200 kA RMS Sym. • 20 kA DC @ 160 Vdc (JJN) JJS-1 JJS-30 JJS-90 JJS-250 100 kA DC @ 170 Vdc (JJN) JJS-2 JJS-35 JJS-100 JJS-300 JJS-3 JJS-40 JJS-110 JJS-350 • Agency information • • JJN-1 − 170 Vdc (601-1200 A) • Large apartment complexes 300 V JJN JJN − 300 Vac (or less) − 160 Vdc (15-600 A) • • Catalog no. (amps) 2011/65/EU Volts • Typical applications Low voltage, branch circuit fuses JJN (300 V) and JJS (600 V) Class T Limitron fastacting fuses UL Listed, Std 248-15, Class T, Guide JDDZ, File E4273, CSA Certified, Class 1422-02, File 53787, RoHS compliant, CE Features • Series combination ratings with branch circuit breakers allows broad range of coverage, independent of breaker manufacturer • Current limitation for non-inductive circuits provides Class T current-limiting response to maximum ground fault and shortcircuit conditions • 200 kA interrupting rating provides protection for virtually all circuit locations • Small footprint allows more efficient use of panel space JJS-6 JJS-45 JJS-125 JJS-400 JJS-10 JJS-50 JJS-150 JJS-450 JJS-15 JJS-60 JJS-175 JJS-500 JJS-20 JJS-70 JJS-200 JJS-600 JJS-25 JJS-80 JJS-225 JJS-800 Recommended blocks for Class T fuses, see page 1-2. Current-limiting effects 300 V JJN 600 V JJS Prosp. S.C.C. Let-through current (apparent RMS Sym. vs. fuse rating) — 15 A 30 A 60 A 100 A 200 A 400 A 600 A 800 A 500 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 5000 1000 1000 1000 1000 2000 3000 5000 5000 10,000 1000 1000 1000 2000 2000 4000 6000 7000 15,000 1000 1000 1000 2000 3000 4000 6000 9000 20,000 1000 1000 1000 2000 3000 5000 7000 10,000 25,000 1000 1000 2000 2000 3000 5000 7000 10,000 30,000 1000 1000 2000 2000 3000 5000 8000 11,000 35,000 1000 1000 2000 3000 4000 6000 8000 11,000 40,000 1000 1000 2000 3000 4000 6000 9000 11,000 50,000 1000 1000 2000 3000 4000 7000 9000 12,000 60,000 1000 1000 2000 3000 4000 7000 10,000 13,000 70,000 1000 1000 2000 3000 5000 7000 10,000 14,000 80,000 1000 2000 2000 3000 5000 8000 11,000 15,000 90,000 1000 2000 2000 3000 6000 8000 11,000 15,000 100,000 1000 2000 2000 4000 6000 8000 12,000 16,000 150,000 1000 2000 3000 4000 6000 9000 13,000 17,000 200,000 2000 2000 3000 4000 7000 9000 15,000 19,000 Prosp. S.C.C. Let-through current (apparent RMS Sym. vs. fuse rating) — 15A 30A 60A 100A 200A 400A 600A 800A 500 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 5000 1000 1000 1000 2000 3000 4000 5000 5000 10,000 1000 1000 1000 2000 3000 6000 8000 9000 15,000 1000 1000 2000 3000 4000 7000 10,000 11,000 20,000 1000 1000 2000 3000 4000 7000 10,000 12,000 25,000 1000 1000 2000 3000 5000 7000 11,000 13,000 30,000 1000 1000 2000 3000 5000 8000 12,000 14,000 35,000 1000 1000 2000 3000 5000 9000 13,000 15,000 40,000 1000 2000 2000 4000 5000 9000 13,000 15,000 50,000 1000 2000 2000 4000 6000 10000 14,000 17,000 60,000 1000 2000 3000 4000 6000 10000 16,000 18,000 70,000 1000 2000 3000 4000 7000 11000 17,000 19,000 80,000 1000 2000 3000 4000 7000 11000 17,000 20,000 90,000 1000 2000 3000 4000 7000 12000 18,000 21,000 100,000 2000 2000 3000 5000 7000 12,000 19,000 22,000 150,000 2000 3000 4000 6000 8000 14,000 22,000 25,000 200,000 2000 3000 4000 6000 9000 16,000 24,000 28,000 1200 A 1000 1000 5000 9000 10,000 11,000 12,000 13,000 13,000 13,000 15,000 16,000 17,000 17,000 18,000 19,000 22,000 23,000 Data sheet no. 1025 (JJN) and 1029 (JJS) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 1-31 1 — Low voltage, branch circuit fuses 400 500 600 200 100 60 15 30 10 300 6 3 JJS Time-current characteristics — average melt 1 JJN Time-current characteristics — average melt Amp rating 100 Time in seconds 10 1 Current in seconds JJS Current limitation curves B 100,000 800A 600A 400A 200A 100A 60A 10,000 30A 15A 100,000 100 A 200 10,000 1000 1000 Instantaneous peak let-through current in amps 400,000 200,000 JJN Current limitation curves 1000 100 1 10 0.01 10,000 0.1 Prospective short-circuit current (Symmetrical RMS Amps) A-B = Asymmetrical available peak (2.3 x Sym. RMS Amps) Data sheet no. 1025 (JJN) and 1029 (JJS) 1-32 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries W plug fuses SL rejection base and TL Edison base plug fuses Fast-acting Edison base plug fuse. Time-delay, loaded link Edison (TL) and rejection base (SL) plug fuses. Ratings • Volts 125 Vac • Amps 1/2-12 A • Rating IR 10 kA RMS Sym. Agency information • UL Listed, Std 248-11, Guide JEFV, File E12112, CE • Volts 125 Vac • Amps 15-30 A • IR 10 kA RMS Sym. Agency information • Features • Dependable, fast-acting circuit protection with 10 kA interrupting rating for added safety when applied to existing plug fuse systems and 125 volt single-phase control circuits Typical applications • Replacement fuses for existing systems • For general purpose circuit protection • Lighting and other non-motor circuits UL Listed, Std 248-11, Guide JEFV, File E12112, CE Features • Time-delay loaded link TL Edison base plug fuses pass motor overload starting currents without opening and allow closer sizing to motor load for added protection • Time-delay loaded link SL fuses provide a rejection feature (when used alone or with Fustat adapters to retrofit Edison base holders) to help prevent overfusing Typical applications • Small motor and inductive load circuits with high in-rush current levels Catalog no.* (amps) W-1/2 W-2-1/2 W-6 W-10 • TL for box cover units to provide small motor overload protection W-1 W-3 W-6-1/2 W-12 • SL for applications benefiting from fuse rejection W-1-8/10 W-4 W-7 W-DUMMY** W-2 W-5 W-8 Catalog no. (amps) Rejection base SL * W-15 to W-30 plug fuses obsolete. Replace with either T-(amp) or TL-(amp) Edison base plug fuses. ** Non-conductive dummy base NOT a fuse. SL-15 Recommended box cover units for W plug fuses, see page 1-36. TL-15 SL-20 SL-25 SL-30 TL-20 TL-25 TL-30 Edison base TL Recommended box cover units for SL and TL plug fuses, see page 1-36. For Fustat™ Edison base adapters for use with SL fuses see page 1-35. Data sheet no. 1036 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Data sheet no. 1033 (SL) and 1035 (TL) Eaton.com/bussmannseries 1-33 Low voltage, branch circuit fuses Low voltage, branch circuit fuses — 1 1 — Low voltage, branch circuit fuses S rejection base and T Edison base plug fuses P and TC CSA plug fuses Dual-element, time-delay Edison (T) and rejection base (S) plug fuses. CSA Edison base Type P (P) dual-element fuses and Type D (TC) dual-element, time-delay fuses. Rating Ratings • Volts 125 Vac • Volts 125 Vac or less • Amps • Amps 15-30 A • IR 10 kA • • S 1/4-30 A • T 3/10-30 A Agency information IR 10 kA RMS Sym. Agency information • UL Listed, Std 248-11, Type S and T (0 to 6-1/4) Guide JFHR, File E56412 (7 to 30 A) Guide JEFV, File E12112; CSA Certified, Class 1423-01, File 53787, CE • P - CSA Certified • TC - CSA Certified, Class 1423-01, File 53787 Features • Features • • T Edison base fuses provide small motor overload protection when used with box cover units • S rejection base fuses provide a rejection feature (when used alone or with Fustat adapters to retrofit Edison base holders) to prevent overfusing of branch circuits Typical applications • S for residential load centers • T for box cover units to provide small motor overload protection • Applications benefiting from fuse rejection to help prevent overfusing (S only) P • "P" rating addresses the need of Canadian applications • Non-time delay protects non-inductive loads TC • "D" rating addresses the need of Canadian applications • Heavy duty TC fuses are industrial strength products, featuring dual-element construction • This spring loaded design provides superior short-circuit and overload protection • The TC fuses have more time-delay than the medium duty fuses in order to better protect industrial motors and residential circuits Typical applications Catalog no. (amps) • P for non-inductive loads, residential load centers Rejection base S • TC for box cover units to provide small motor overload protection S-1/4 S-1-4/10 S-3-1/2 S-20 S-3/10 S-1-6/10 S-4 S-25 Catalog no. (amps) S-4/10 S-1-8/10 S-7 S-30 Type P S-1/2 S-2 S-8 P-15 S-6/10 S-2-1/4 S-9 Type D S-8/10 S-2-1/2 S-10 TC-15 S-1 S-2-8/10 S-12 S-1-1/8 S-3 S-14 S-1-1/4 S-3-2/10 S-15 P-20 P-25 P-30 TC-20 TC-25 TC-30 Recommended box cover units for P and TC plug fuses, see page 1-36. Edison base T T-3/10 T-1-6/10 T-4 T-10 T-4/10 T-1-8/10 T-4-1/2 T-12 T-1/2 T-2 T-5 T-14 T-6/10 T-2-1/4 T-5-6/10 T-15 T-8/10 T-2-1/2 T-6 T-20 T-1 T-2-8/10 T-6-1/4 T-25 T-1-1/8 T-3 T-7 T-30 T-1-1/4 T-3-2/10 T-8 T-1-4/10 T-3-1/2 T-9 Recommended box cover units for S and T plug fuses, see page 1-36. For Fustat Edison base adapters for use with SL fuses see page 1-35. Data sheet no. 1032 (S) and 1034 (T) 1-34 Data sheet no. 1039 (TC) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries MB Edison base circuit breakers SA Fustat fuse adapters Edison base manual reset circuit breakers. Adapters for using Type S and SL rejection base fuses in Edison base fuse sockets. Amp rating rejection feature helps prevent overfusing. Ratings • Volts 125 Vac only • Amps 15 and 20 A • Ratings IR 10 kA RMS Sym. Edison base circuit breakers fit standard Edison base fuse sockets to provide resettable overcurrent protection (correct cause of overcurrent event before resetting) Replacing Edison base plug fuses in residential fuse panels • Fustat adapters screw into the "Edison" thread fuse sockets to easy retrofit existing fuse installations to rejection base fuses • Available in various amp ratings to cover a wide range of rating requirements to help prevent overfusing Typical applications • Catalog no.* (amps) MB-15 UL Listed, File E12853, CSA Certified, Class 6225-01, File 47235 Features Typical applications* • Amps 1-30 A • UL Listed, File E14942 Features • Volts 125 Vac • Agency information Agency information • • MB-20 * Not for use in box cover units or for inductive loads. Plug fuse installations where it is desirable to restrict fuse amp ratings and help prevent overfusing Catalog no. Accepts S fuses Accepts SL fuses SA-1* S-1 or smaller — SA-1-1/4* S-1-1/4 or smaller — SA-1-6/10* S-1-6/10 or smaller — SA-2* S-2 or S-1-8/10 — SA-2-1/2* S-2-1/2 to S-1-8/10 — SA-3-2/10* S-3-2/10 to S-1-8/10 — SA-4* S-4 to S-3-1/2 — SA-5* S-5 to S-3-1/2 — SA-6-1/4* S-6-1/4 to S-3-1/2 — SA-8* S-8 to S-7 — SA-10* S-10 to S-7 — SA-15** S-15 to S-7 SL-15 SA-20** S-20 SL-20 SA-30** S-30 to S-25 SL-52, SL-30 * Single motor circuits - both running and short-circuit protection. ** Branch circuits. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 1-35 Low voltage, branch circuit fuses Low voltage, branch circuit fuses — 1 1 — Low voltage, branch circuit fuses Box cover units for Edison base plug fuses SOU, SRU, SSU, SOW, SRW, SSW, SOX, SRX, SOY, SRY, SSY, SSY-RL, STY, SCY, SOY-B and SSN Box cover units for standard electrical boxes provide supplemental fuse protection for small motor circuits and other loads requiring overcurrent protection below that of the branch circuit overcurrent protective device. Versions are available for a fused outlet, switch or plain circuit that fit standard sized electrical boxes. See catalog numbers for available configurations by box type. Use with SA adaptors and S or SL Type fuses may prevent fuse cover from closing. Not recommended for use with MB-15 Edison base circuit breaker. SOU Ratings • Volts 125 V • Amps 15 A SRU 2-1/4” handy box units SSU SSN 4” square box units Agency information • UL Listed, Guide JAMZ, File IE6491 • CSA Class 6225-01, File 47235 SSU SRU SOU SOY SRY SSY SSY-RL SOY-B STY 2-3/4” switch box units Features • • A low-cost method of controlling and protecting small motors when used with Bussmann series Type T dual-element fuses SOW SSW SRW 4” octagon box units Low-cost supplemental protection and disconnection of 125 V or less, single-phase circuits Typical applications • Fractional horsepower, 125 volt single-phase motor circuits • General 125 volt supplemental circuits Catalog no. Box type SOU SRU 2-1/4" Handy Fuse receptacle only (no switch or outlet) Fused outlet SRX X UL, CSA UL 1/2 Fused switch UL, CSA 3/4 Fuse receptacle only (no switch or outlet) UL, CSA 1/2 Fused outlet UL 1/2 Fused switch UL, CSA 1 3/4 Fuse receptacle only (no switch or outlet) UL, CSA 1 1 4" Octagon Agency information Description 1/2 1 SOX Max motor size (Hp) 3/4 1 2-3/4" Switch Pilot light2 1 SOW SSW Switch control1 SCY SRX 1 SSU SRW X 1 1/2 Fused outlet SOY 1 3/4 Fuse receptacle only (no switch or outlet) SRY 1 1/2 Fused outlet UL SSY 1 1/2 Fused switch UL, CSA SSY-RL 4" Square X 1 X STY3 2 X SCY4 2 SOY-B SSN 1 2 3 4 Fuse sockets SOX X 2 Single gang 1 X UL 1/2 Fused switch/outlet with pilot light — 1/2 Fused double pole switch, dual fuse receptacles UL 1/2 Dual fused switches UL 3/4 Dual fuse receptacles only (no switch or outlet) UL 1/2 Weatherproof fused switch UL Switch turns power to fused load OFF or ON. Pilot light indicates power to load (dark when switch OFF or fuse open). Double pole switch opens both sides of circuit. Can be used for two separate motors with common switch or a single motor (3/4 Hp, 250 Vac max). Data sheet no. 1129 1-36 UL, CSA BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Low voltage supplemental fuses — 2 Contents The easiest and fastest way to select and specify the right control circuit fuse Section page 2 3 4 5 6 7 8 9 10 11 12 13 HH2 (ATR) In-line fuse holders ATC-FHID (ATC) HHC (ATC) HHD (ATC) HHF (ATC) HHG (ATC) HHR (ATC) HHS (ATC) ATM-FHID (ATM) HHL (ATM) HHM (ATM) HHU (ATM) 14 HHX (MAX)) MAX-FHID (MAX)) PCB fuseclips ATC 1A5600 1A5780 ATM 1A5778 1A5779 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 2-1 Low voltage, supplemental fuses Bussmann series Fuses Made SimpleTM Control Circuits Description Fuse holder and block selection guide Product Catalog symbol Limiters K (600 V) Cable limiters UH (250 V) 64000 (600 V) Welder limiters 68000 (600 V) ANN (125 V very fast-acting) Bolt-on ANL (80 V non time-delay) 4164 and 4164-FR blocks Supplemental fuses BAF (250 V) KTK (600 V) 13/32" x 1-1/2" fast-acting KLM (600 V) FNM (250 V) 13/32" x 1-1/2" time-delay FNQ (500 V) 13/32" x 1-3/8" fast-acting BBS (600 V) GBA (125 V) GLD (125 V) MIC (250 V fast-acting) Pin indication and actuator FNA 250 V time-delay) MIS (600 V) KAZ (600 V) In-line fuses GLQ size rejecting GMQ size rejecting holder HLQ GLR Non size-rejecting fuses and GMF holders GRF HLR Non size-rejecting fuse holders HLR-2A Blade fuses and holders ATR micro ATM ATM-_ID ATM-LP Fuses ATC ATC-_ID MAX MAX-_ID 2 — Low voltage supplemental fuses Fuse holder and block selection guide Catalog pages for the blocks and holders are denoted parenthetically "()" next to their catalog symbol. Fuse Catalog symbol Blocks DIN-Rail holders Panel mount holders In-line holders PCB fuseclips K_ — — — — — UH_ — — — — — Welder limiters 64000 68000 RM60_ (8-21) — — — — Bolt-on limiters ANN ANL 4164 (2-4) 4164-FR (2-4) — — — — HEB (8-51) HEX (8-53) 1A3400_ (3-16) 5960 (3-16) HEH (8-49) 1A3400_ (3-16) 5960 (3-16) Cable limiters 13/32" x 1-1/2" supplemental fuses BAF FNM FNQ KLM KTK BMM603_ (8-6) 3743 (8-14) 4421 (8-14) 4515 (8-14) CCP2-_ (11-2) OPM-1038_ (8-12) OPM-NG_ (8-13) CHM (8-8) NDNF1-WH (8-11) CCPLP†† (30 A) (11-32) HPC-D (8-43) HPD (8-44) HPF (8-43) HPG (8-44) HPM (8-44) HPM-D (8-44) HPS2 (8-45) HPS (8-45) 13/32" x 1-3/8" supplemental fuses BBS BMM603_ (8-6) — HPS-L (8-45) GBA GLD — — HLD (8-43) — 1A1119 (3-15) 1A1120 (3-15) 1A1907 (3-15) 1A3398 (3-15) 1A4533 (3-15) 1A4534 (3-15) 5681 (3-16) 5682 (3-16) MIC FNA BMM603_ (8-6) 3839† — HPF-C (8-43) — 1A3400_ (3-16) 5960 (3-16) MIS fuse KAZ actuator 2778† 2837† 2838† — — — 1A3400_ (3-16) 5960 (3-16) In-line size rejecting fuses GLQ GMQ — — — HLQ (2-10) — In-line nonrejecting fuses GLR GMF GRF — — — HLR (2-11) HLR-2A (2-11) — 1A5600 (2-14) 1A5780 (2-14) Pin indication fuses and actuator Automotive bladetype fuses ATC ATC-_ID FB_-ATC* 15600* — — ATC-FHID (2-14) HHC (2-14) HHD (2-14) HHF (2-14) HHG (2-14) HHR (2-14) HHS (2-14) ATM ATM-_ID FB_-ATM* RTMF-_* — — ATM-FHID (2-14) HHL (2-14) HHM (2-14) HHU (2-14) 1A5778 (2-14) 1A5779 (2-14) ATM-LP FB_-ATM* RTMF-_* — — HHV (2-14) — ATR micro FB_-ATR* — — HH2 (2-14) — MAX MAX-_ID HHX (2-14) MAX-FHID (2-14) * Not shown in this catalog, for details and available configurations, see Automotive and Home center catalog no. 5084. † Not shown in this catalog, see data sheet for details. †† UL 508 Listed disconnect switch, available in 1-, 2- and 3-pole versions. 2-2 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Low voltage supplemental fuses — 2 K 600 V cable limiters UH 250 V cable limiters Cable limiters for protecting 600 V low voltage distribution and service entrance cables against short-circuit currents. Cable limiters for protecting 250 V low voltage distribution and service entrance cables used in residential applications against shortcircuit currents. Ratings Volts 600 Vac • IR 200 kA RMS Sym. @ 600 Vac Agency information • UL Listed, File E90818, 600 Vac, 200 kA IR on catalog numbers CDA-W, CDB-W, KCD, KCJ, KCM, KCM-B, KCR, KDD, KDF, KDJ, KDM, KDP, KDR, KDU, KEW, KFM, KFT, KHF, KHJ, KHM, KHR Features • • Volts Up to 250 Vac • IR 100 kA RMS Sym. Terminals and conductors • Center bolt-to-offset bolt terminals, Cu or Al conductors • Cu or Al conductors are permitted per the listed cable size. Select the catalog number for the conductor size. See data sheet 1042 for dimensions. Sizes and ratings available to meet many applications Catalog no. *Tubular terminals KCY KCZ KCA KCB Cable size (AWG) 4 3 2 1 Catalog no. KCH KCJ1, 2 KCM1, 2, 3 KCV KCC 1/0 KCR1, 2 2/0 CDA-W1, 4 KCD1, 2 KCE 3/0 KCS KCF 4/0 *Tubular and offset bolt-type terminals KQV 12 KDE KQT 10 KDF1 KFZ 8 KDH KIG 6 KDJ1, 3 KDY 4 KDM1, 3 KDA 2 KDU1 KDB 1 KDR1, 2 KDC 1/0 CDB-W1, 4 1 KDD 2/0 *Compression connector rod and tubular terminals KEX 4/0 KQO KFH-A 250 kcmil KDT **Center bolt-type and off-set bolt-type terminals KPF 4/0 KDP1 250 kcmil KFM1 KFT1 1 KEW 350 kcmil Center bolt-type and tubular terminals 4/0 KHM1 KHF1 1 350 kcmil KHR1 KHJ Cable size (AWG) Catalog no. UHA 3/0 4/0 250 kcmil 350 kcmil 500 kcmil 600 kcmil UHJ-M 3/0 250 kcmil UHJ-T 350 kcmil 500 kcmil UHJ-W 600 kcmil 800 kcmil 750 kcmil 750 kcmil 1000 kcmil 3/0 4/0 250 kcmil 350 kcmil 500 kcmil 600 kcmil 750 kcmil 750 kcmil 350 kcmil 500 kcmil 500 kcmil 750 kcmil 500 kcmil 750 kcmil * Copper conductors only. ** Copper or aluminum conductors. 1 UL Listed (File E90818), 600 Vac, 200 kA I.R. 2 Available with shrink tube "-V" suffix. 3 Available with molded rubber boots. 4 Aluminum conductor only. Cu cable size (AWG) Al cable size (AWG) Data sheet no. 1042 64000 and 68000 600 V welder limiters Limiters for use on welder circuits. Note: welder limiters have special characteristics and are not suitable for use on other circuit types. Ratings • Volts 600 Vac (or less) • IR 200 kA RMS Sym. Features • Current-limiting devices designed specially for use only on welder circuits • Time-current characteristics are designed to hold on the intermittent overloading encountered in welder operation, while providing short-circuit protection to the circuit and equipment Catalog no. Fuse holder type Nominal amp rating 68300 Class H 300 68600 Class H 600 64200 Class J 200 64300 Class J 300 Recommended fuse blocks, see page 2-2. Accessory boots (order separately) Limiter Boot catalog no. Limiter Boot catalog no. KCM BOOT-KCM KDM BOOT-KDM Recommended Thomas and Betts crimp tool TBM-14M with die 15506 KDM/15515 KDR for installation. Data sheet no. 1042 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Data sheet no. 1045 Eaton.com/bussmannseries 2-3 Low voltage, supplemental fuses Ratings • 2 — Low voltage supplemental fuses ANL/ANN limiters 4164 and 4164-FR limiter blocks Circuit limiters typically used in fork lifts, marine, aviation and battery charging systems. ANL limiters are fast-acting and ANN limiters are very fast-acting. Both ANL and ANN limiters measure 7/8" x 3-3/16" (22x81mm) with a depth that varies by amp rating. Limiter fuse blocks for ANL and ANN. 4164 is furnished with nylon inserted locknuts and 4164-FR is furnished with standard hex nuts. 4164 Fast-acting ANL Dimensions Ratings • • • Volts • ANL 80 Vdc • ANN 125 Vac, 80 Vdc Very fast-acting ANN Amps • ANL 35-750 A • ANN 10-800 A • L 3.38" x W 0.95" x H 1.62" • Studs center-to-center 2.43" Ratings 4164-FR • Volts 125 Vac, 80 Vdc, 32 Vdc (self certified) • Amps 10-800 A • Poles single, stud terminal Data sheet no. 2133 IR • ANL 2700 A @ 80 Vdc • ANN 2500 A @ 125 Vac, 2700 A @ 80 Vdc Agency information • ANL: UL Recognized, CSA Certified, 35-750 A @ 80 Vdc, IR 2700 A, Guide JFHR2, File E56412, Class 1422-30, File 53787, SAE J1171 • ANN: UL Recognized, CSA Certified 35-400 A @ 125 Vac, IR 2500 A and 500 A @ 80 Vdc, IR 2700 A, Guide JFHR2, File E56412, Class 1422-30, File 53787, CE for 35-400 A Catalog no. (amps) Fast-acting ANL ANL-35 ANL-125 ANL-250 ANL-500 ANL-40 ANL-130 ANL-275 ANL-600 ANL-50 ANL-150 ANL-300 ANL-675 ANL-750 ANL-60 ANL-175 ANL-325 ANL-80 ANL-200 ANL-350 ANL-100 ANL-225 ANL-400 Very fast-acting ANN ANN-10 ANN-90 ANN-225 ANN-400 ANN-35 ANN-100 ANN-250 ANN-500 ANN-40 ANN-125 ANN-275 ANN-600 ANN-50 ANN-150 ANN-300 ANN-700 ANN-60 ANN-175 ANN-325 ANN-800 ANN-80 ANN-200 ANN-350 Features • Fast-acting sizing for inductive circuits (ANL) • Very fast-acting circuit protection (ANN) • Element viewing window shows limiter status at a glance Data sheet no. 2023 (ANN), 2024 (ANL) 2-4 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Low voltage supplemental fuses — 2 BAF fast-acting 13/32" x 1-1/2" supplemental fuse KTK fast-acting 13/32" x 1-1/2"supplemental fuse Fast-acting, supplemental fuse. Green color code (250 Vac max). For superior protection, Eaton recommends upgrading to Bussmann series Low-Peak Class CC fuses. See data sheet no. 1023. Fast-acting supplemental fuse. Black color code (600 Vac max). For superior protection, Eaton recommends upgrading to Bussmann series Low-Peak Class CC fuses. See data sheet no. 1023. Ratings Ratings Agency information 250 Vac 125 Vac UL CSA 1/4 to 1 35 A 10 kA — X 1/10 to 30 1-1/2 to 2-1/2 100 A 10 kA — X 3 100 A 10 kA X X 4 to 10 200 A 10 kA X X 12 to 15 750 A 10 kA X X 20 to 30 200 A 10 kA — — • 600 Vac UL CSA 100 kA X X UL Listed, Std. 248-14, Guide JDYX, File E19180, CSA Certified, C22.2 No. 248.14, Class 1422-01, File 53787, HRC-MISC, RoHS compliant, CE Catalog no. (amps) UL Listed, Std. 248-14, 250 Vac (3 to 15 A) Guide JDYX, File E19180, CSA Certified, 250 Vac (1/4 to 15 A) Class 1422-01, File 53787 BAF-1-8/10 BAF-6 KTK-1/10 KTK-3/4 KTK-4 KTK-12 KTK-1/8 KTK-1 KTK-5 KTK-15 KTK-2/10 KTK-1-1/4 KTK-6 KTK-20 KTK-1/4 KTK-1-1/2 KTK-7 KTK-25 KTK-30 KTK-3/10 KTK-2 KTK-7-1/2 BAF-12 KTK-4/10 KTK-2-1/2 KTK-8 Catalog no. (amps) BAF-1/4 Agency information Agency information Agency information • IR at rated voltage BAF-1/2 BAF-2 BAF-6-1/4 BAF-15 KTK-1/2 KTK-3 KTK-9 BAF-6/10 BAF-2-1/2 BAF-7 BAF-20 KTK-6/10 KTK-3-1/2 KTK-10 BAF-8/10 BAF-3 BAF-8 BAF-25 BAF-1 BAF-4 BAF-9 BAF-30 BAF-1-1/2 BAF-5 BAF-10 Features • Green color code for maximum 250 Vac rating • Fiber tube construction with nickel-plated brass endcaps Typical applications • General purpose circuits • Lighting circuit protection • Meter circuits Features • Black color code for 600 Vac rating • Fast-acting for resistive loads • Melamine tube construction with nickel-plated bronze endcaps Typical applications • Control circuits • Lighting circuit protection • Meter circuits Recommended blocks and holders for 13/32" x 1-1/2" fuses, see page 2-2. Recommended blocks and holders for 13/32" x 1-1/2" fuses, see page 2-2. Data sheet no. 2011 (0-30) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Data sheet no. 1011 Eaton.com/bussmannseries 2-5 Low voltage, supplemental fuses IR at system voltage Fuse amp range Fuse amp range 2011/65/EU 2 — Low voltage supplemental fuses KLM fast-acting 13/32" x 1-1/2" supplemental fuse FNM time-delay 13/32" x 1-1/2" supplemental fuse Fast-acting supplemental fuse. Color code black (600 Vac/dc max). For superior protection, Eaton recommends upgrading to Bussmann series Low-Peak Class CC fuses. See data sheet no. 1023. For protecting PV systems, use PVM 10x30mm PV fuses. See data sheet no. 10121. Time-delay supplemental fuse. Color code green (250 Vac max). For superior protection, Eaton recommends upgrading to Bussmann series Low-Peak Class CC fuses. See data sheet no. 1023. 2011/65/EU Ratings Ratings IR at system voltage IR at rated voltage Fuse amp range Agency information Fuse amp range 600 Vac 600 Vdc UL CSA 1/10 to 30 100 kA 50 kA X X % of amp rating Opening time 110% 4 hours minimum 135% AC opens within 1 hour • UL CSA 10 kA X X 1-1/8 to 3-1/2 100 A 10 kA X X 4 to 10 200 A 10 kA X X 12 to 30 10 kA — X X UL Listed, Std. 248-14, Guide JDYX; File E19180, CSA Certified, Class 1422-01, File 53787, RoHS compliant, CE Catalog no. (amps) UL Listed, Std. 248-14, Guide JDYX, File E19180, CSA Certified, C22.2 No. 248. 14, Class 1422-01, File 53787, RoHS compliant, CE Catalog no. (amps) KLM-1 125 Vac 35 A Agency information Agency information KLM-1/10 Agency information 250 Vac 1/10 to 1 Electrical characteristics • 2011/65/EU KLM-5 KLM-15 FNM-1/10 FNM-8/10 FNM-2-1/2 FNM-6-1/4 FNM-1/8 FNM-1 FNM-2-8/10 FNM-7 FNM-15/100 FNM-1-1/8 FNM-3 FNM-8 FNM-2/10 FNM-1-1/4 FNM-3-2/10 FNM-9 KLM-1/8 KLM-1-1/4 KLM-6 KLM-20 FNM-1/4 FNM-1-4/10 FNM-3-1/2 FNM-10 KLM-2/10 KLM-1-1/2 KLM-7 KLM-25 FNM-3/10 FNM-1-1/2 FNM-4 FNM-12 KLM-1/4 KLM-2 KLM-8 KLM-30 FNM-4/10 FNM-1-6/10 FNM-4-1/2 FNM-15 KLM-3/10 KLM-2-1/2 KLM-9 FNM-1/2 FNM-1-8/10 FNM-5 FNM-20 FNM-2 FNM-5-6/10 FNM-25 FNM-2-1/4 FNM-6 FNM-30 KLM-1/2 KLM-3 KLM-10 FNM-6/10 KLM-3/4 KLM-4 KLM-12 FNM-3/4 Features Features • Color coded for 600 Vac/dc maximum • Color coded for 250 Vac maximum • A full range DC performance fuse • Melamine tube construction with nickel-plated brass endcaps • Melamine tube construction with nickel-plated brass endcaps Typical applications Recommended fuse blocks and holders for 13/32" x 1-1/2" fuses, see page 2-2. • Circuits with high inrush currents (motor/transformer loads) • Supplemental protection for 125 Vac and 250 Vac inductive circuits Recommended fuse blocks and holders for 13/32" x 1-1/2" fuses, see page 2-2. Data sheet no. 2020 2-6 Data sheet no. 2028 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries FNQ time-delay 13/32" x 1-1/2" supplemental fuse BBS fast-acting 13/32" x 1-3/8" supplemental fuse Time-delay supplemental fuse. Color code orange (500 Vac max). For superior protection, Eaton recommends upgrading to Bussmann series Limitron FNQ-R Class CC fuses. See data sheet no. 1014. Fast-acting supplemental fuse. Color codes black (600 Vac max 1/10 to 6 A), green (250 Vac max 7 to 10 A), purple (48 Vac max 12 to 30 A). (For superior protection, Eaton recommends upgrading to Bussmann series Low-Peak Class CC fuses. See data sheet no. 1023. 2011/65/EU Ratings Fuse amp range Ratings IR at rated voltage Agency information 500 Vac UL CSA 10 kA X X 1/10 to 30 Fuse amp range 1/10 to 6 Agency information • UL Listed, Std. 248-14, Guide JDYX, File E19180, CSA Certified, C22.2 No. 248.14, Class 1422-01, File 53787, HRC-MISC, RoHS compliant, CE Catalog no. (amps) FNQ-1/10 FNQ-3-2/10 250 Vac Agency information 48 Vac UL 10 kA — — X X 7 to 10 — 10 kA — X X 12 to 30* — — — — — Agency information FNQ-9 UL Listed, Std. 248-14 (1/10-6 A@600 Vac, 7-10 A@250 Vac), Guide JDYX, File E19180, CSA Certified, C22.2 No. 248.14 (1/10-6 A@600 Vac, 7-10 A@250 Vac), Class 1422-01, File 53787, CE FNQ-1/8* FNQ-1 FNQ-3-1/2 FNQ-10 FNQ-15/100* FNQ-1-1/8 FNQ-4 FNQ-12 Catalog no. (amps) FNQ-3/16 FNQ-1-1/4 FNQ-4-1/2 FNQ-14 BBS-1/10 BBS-8/10 BBS-4 BBS-15 FNQ-2/10 FNQ-1-1/2 FNQ-5 FNQ-15 BBS-2/10 BBS-1 BBS-5 BBS-20 FNQ-1/4 FNQ-1-6/10 FNQ-5-6/10 FNQ-20 BBS-1/4 BBS-1-1/2 BBS-6 BBS-25 BBS-30 FNQ-3/10 FNQ-2 FNQ-6 FNQ-25 BBS-4/10 BBS-1-6/10 BBS-7 FNQ-4/10 FNQ-2-1/4 FNQ-6-1/4 FNQ-30 BBS-1/2 BBS-1-8/10 BBS-8 FNQ-1/2 FNQ-2-1/2 FNQ-7 BBS-6/10 BBS-2 BBS-10 FNQ-6/10 FNQ-3 FNQ-8 BBS-3/4 BBS-3 BBS-12 * Not RoHS compliant. CSA * For interrupting rating, contact factory. • FNQ-8/10 IR at system voltage 600 Vac Features Features • Color coded for 500 Vac maximum • Fiber tube construction with nickel-plated brass endcaps • Color coded for 600 Vac (black) 250 Vac (green) and 48 Vac (purple) for maximum • Fiber tube construction with nickel-plated brass endcaps Typical applications Typical applications • Motor control transformers • Control circuits • Circuits with in-rush currents • Gaseous vapor fixtures • HID ballasts • Electronic circuits • Hand-held meters Recommended blocks and holders for 13/32" x 1-1/2" fuses, see page 2-2. Recommended blocks and holders for BBS fuses, see page 2-2. Data sheet no. 1012 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Data sheet no. 2010 Eaton.com/bussmannseries 2-7 Low voltage, supplemental fuses Low voltage supplemental fuses — 2 2 — Low voltage supplemental fuses GBA/GLD fast-acting 1/4" x 1-1/4" pin-indicating supplemental fuse MIC fast-acting 13/32" x 1-1/2" pin-indicating supplemental fuse Fast-acting, pin-indicating fuse. Fast-acting, pin-indicating supplemental fuse. Green color code (250 Vac max 1 to 15 A), gray (32 Vac max 20 to 30 A). Ratings • Volts — see agency information • Amps 1/2-15 A • IR — see agency information Agency information • • Ratings UL Listed, Std. 248-14, 0-5 A/125 Vac, 10,000 AIC, Guide JDYX, File E19180 Fuse amp range UL Recognized, 6 A/125 Vac, 1000 AIC 8-15 A/50 Vac/dc, 300 AIC Guide JDYX2, File E19180 IR at voltage rating Agency information 250 Vac 32 Vac UL CSA 1 35 A — X — 100 A — X — • CSA Certified, 0-5 A/125 Vac, 10,000 AIC Class 1422-01, File 53787 2 to 3 • CE 5 to 10 200 A — X — 15 750 A — X — — 10 kA — — Catalog no. (amps) 20 to 30 GBA GBA-1/2 GBA-1-1/2 GBA-4 GBA-10 GBA-3/4 GBA-2 GBA-5 GBA-15 GBA-1 GBA-3 GBA-8 Electrical characteristics GLD GLD-1/2 GLD-1-1/2 GLD-4 GLD-10 GLD-3/4 GLD-2 GLD-5 GLD-12 GLD-1 GLD-3 GLD-6 GLD-15 • Opening time 110% Indefinitely 135% 1 hour max. Agency information • Features • % of fuse rating UL Listed, Std. 248-14, 1-15 A, Guide JDYX, File E19180, CE Catalog no. (amps) Type GBA has a "red" pin indicator providing visual identification of failed circuits, resulting in faster troubleshooting (reduced circuit downtime) Type GLD has a plated pin to activate transmitting a electrical signal to indicate the location of opened circuits, resulting in reduced downtime Typical applications MIC-1 MIC-5 MIC-15 MIC-2 MIC-8 MIC-20 MIC-3 MIC-10 MIC-25 MIC-30 Features • Color coded by maximum voltage rating • Pin indication for visual indication of open fuse condition • Control circuits • Silver-plated pin for positive, electrical signal activation • Electronic circuits • Fiber tube construction with nickel-plated bronze endcaps Recommended fuse blocks/fuse holders for 1/4" x 1-1/4" indicating fuses, see page 2-2. Typical applications • Power electronic circuits in which fuse opening must be quickly apparent • Control circuits • PLC Circuits Recommended signal block for, 13/32" x 1-1/2" indicating fuses, see page 2-2. Data sheet no. 2012 2-8 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Data sheet no. 10246 Eaton.com/bussmannseries Low voltage supplemental fuses — 2 FNA time-delay 13/32" x 1-1/2" pin-indicating supplemental fuse Pin-indicating time-delay supplemental fuse. Color coded green (250 Vac max 1/10 to 6 A), blue (125 Vac max 6-1/4 to 15 A) and gray (32 Vac max 20 to 30 A). MIS non time-delay 13/32" x 2" pin-indicating supplemental fuse and KAZ non-fuse pinindicating actuator MIS is a non time-delay pin-indicating fuse. Dual-tube construction 12A and up Ratings Ratings Fuse amp range IR at system voltage Agency information 250 Vac 125 Vac 32 Vac UL CSA 1/10 to 8/10 35 A 10 kA — X X 1 to 6 200 A 10 kA — X X 6-1/4 to 15 — 10 kA — X X 20 to 30 — — 1 kA — — FNA-3 FNA-9 FNA-1/8 FNA-1-1/8 FNA-3-2/10 FNA-10 FNA-15/100 FNA-1-1/4 FNA-3-1/2 FNA-12 FNA-2/10 FNA-1-4/10 FNA-4 FNA-15 FNA-1/4 FNA-1-1/2 FNA-4-1/2 FNA-20 FNA-3/10 FNA-1-6/10 FNA-5 FNA-25 FNA-4/10 FNA-1-8/10 FNA-5-6/10 FNA-30 FNA-1/2 FNA-2 FNA-6 FNA-6/10 FNA-2-1/4 FNA-6-1/4 FNA-3/4 FNA-2-1/2 FNA-7 FNA-8/10 FNA-2-8/10 FNA-8 Features Volts 600 Vac 600 Vac Amps 1-12 A N/A IR 200 kA 200 kA Load Opening time All 110% 4 hrs. (min.) 1-5 A 150% 6 min. (max.) 6-12 A 150% 12 min. (max.) MIS fuse catalog no. (amps) Catalog no. (amps) FNA-1 KAZ actuator MIS Fuse UL Listed, 1/10 to 8/10 A @ 125/250 Vac, 1-15 A @ 125 Vac, Guide JDYX, File E19180, CSA Certified, 1/10 to 10 A @ 125 Vac, Class 1422-01, File 53787, CE FNA-1/10 MIS fuse MIS fuse electrical characteristics Agency information • Low voltage, supplemental fuses KAZ is a non-fuse actuator mounted in parallel with fuses having a 50 amp or larger rating to provide blown fuse dropout for shunt-trip fused switches. To order, specify catalog number KAZ. MIS-1 MIS-3 MIS-5 MIS-10 MIS-2 MIS-4 MIS-8 MIS-12 KAZ agency information • UL Listed, Guide JDVS, File E58836, CE MIS fuse features • Pin indicator provides visual identification of failed circuits, resulting in faster troubleshooting (reduced circuit downtime) • Fuse can be used in circuits rated 600 V or less • High 200 kA interrupting rating for high fault current circuits MIS fuse typical applications • 480 V control circuits PLC circuits • Color coded by maximum voltage rating • • Pin-indication for visual indication of open fuse condition KAZ actuator features • Dual-element, time-delay performance permits close sizing on control transformers and relays • Convenient means to add open fuse signaling • Silver-plated pin for positive, electrical signal activation • Actuator can be used in circuits rated 600 V or less 12 amp and more versions are dual-tube construction • High 200 kA interrupting rating for high fault current circuits • Recommended signal block for 13/32" x 1-1/2" indicating fuses, see page 2.2. KAZ actuator typical applications • Large, shunt-trip fused switches • Fuse protected circuits rated 50 A or larger with shunt-trip devices Recommended signal blocks for MIS and KAZ, see page 2-2. Data sheet no. 2029 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Data sheet no. 2021 Eaton.com/bussmannseries 2-9 2 — Low voltage supplemental fuses GLQ fast-acting, size-rejecting supplemental fuse GMQ time-delay, size-rejecting supplemental fuse Fast-acting, size-rejecting in-line fuse. Match fuse and holder amp rating per catalog number table below. Time-delay, size-rejecting in-line fuse. Match fuse and holder amp rating per catalog number table below. Ratings Ratings • Volts 300 Vac (or less) • Volts 300 Vac (or less) • Amps 1-10 A • Amps 1/2 to 6-1/4 A • IR 10 kA • IR 10 kA Agency information Agency information • UL Listed, Std. 248-14, (Guide JDYX, File E19180), CSA Certified C22.2 No. 248.14, (Class 1422-01,File 53787), CE • Catalog no. (amps) and holders Catalog no. (amps) and holders Fuse Holder1, 2 Fuse Holder1, 2 Fuse Holders1, 2 Fuse Holders1, 2 GLQ-1 HLQ-1-6/10 GLQ-3 HLQ-3-2/10 GMQ-1/2 HLQ-1/2 GMQ-2-1/2 HLQ-3-2/10 GLQ-1-1/2 HLQ-1-6/10 GLQ-4 HLQ-5 GMQ-6/10 HLQ-1-6/10 GMQ-3 HLQ-3-2/10 GLQ-1-6/10 HLQ-1-6/10 GLQ-5 HLQ-5 GMQ-8/10 HLQ-1-6/10 GMQ-3-2/10 HLQ-3-2/10 GLQ-2 HLQ-3-2/10 GLQ-9 HLQ-10 GMQ-1 HLQ-1-6/10 GMQ-4 HLQ-5 GLQ-2-1/2 HLQ-3-2/10 GLQ-10 HLQ-10 GMQ-1-1/4 HLQ-1-6/10 GMQ-5 HLQ-5 GMQ-1-6/10 HLQ-1-6/10 GMQ-6-1/4 HLQ-8 GMQ-2 HLQ-3-2/10 1 Carrier is UL Recognized, Guide IZLT2, File E14853 and CSA Certified, Class 6225-01, File 47235 10 A, 300 Vac. 2 Units can be panel-mounted either in a knockout hole with a separate steel clip (BK/A-104) or in a keyhole punch using separate mounting clip NO.6374 for panels of thickness 0.043"to 0.062" or NO.4909 for thickness 0.030" to 0.042". Note: Do not put tension on line (rear) terminal of fuse holder. Features • In-line, fast-acting circuit protection • Rejection feature prevents overfusing Typical applications • UL Listed, Std. 248-14, (Guide JDYX, File E19180), CSA Certified, (Class 1422-01, File 53787), CE In-line lighting ballast protection 1 Carrier is UL Recognized, Guide IZLT2, File E14853 and CSA Certified, Class 6225-01, File 47235 10 A, 300 Vac. 2 Units can be panel-mounted either in a knockout hole with a separate steel clip (BK/A-104) or in a keyhole punch using separate mounting clip NO.6374 for panels of thickness 0.043"to 0.062" or NO.4909 for thickness 0.030" to 0.042" Note: Do not put tension on line (rear) terminal of fuse holder. Features • In-line, fast-acting circuit protection • Rejection feature prevents overfusing Typical applications • In-line lighting ballast protection HLQ fuse holders for both GLQ and GMQ fuses Data sheet no. 2033 2-10 Data sheet no. 2030 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries GLR fast-acting, non size-rejecting supplemental fuse GMF/GRF time-delay, non size-rejecting supplemental fuses Fast-acting, non-rejection, in-line fuse. All fuses use the same HLR or HLR-2A holders. Time-delay, non-rejection, in-line fuse. All fuses use the same HLR or HLR-2A holders. Ratings Ratings • Volts 300 Vac (or less) • Volts 300 Vac (or less) • Amps 3/16-15 A • Amps 3/10-10 A • IR 10 kA • IR 10 kA Agency information • Agency information UL Listed, Std. 248-14, 0-15 A/300 Vac Guide JDYX, File E19180, CSA Certified C22.2, No. 248-14, 0-10 A/300 V Class 1422-01, File 53787, CE • Catalog no. (amps) and holders Catalog no. (amps) and holders Fuse Holder1, 2* Fuse Holder1, 2* GLR-1/2 HLR GLR-6 HLR GLR-1 HLR GLR-7 HLR GLR-1-1/2 HLR GLR-8 HLR GLR-1-6/10 HLR GLR-9 HLR GLR-2 HLR GLR-10 HLR GLR-3 HLR GLR-12 HLR GLR-4 HLR GLR-15 HLR-2A GLR-5 HLR 1 Carrier is UL Recognized, Guide IZLT2, File E14853 and CSA Certified, Class 6225-01, File 47235 12 A, 300 Vac. 2 Units can be panel-mounted either in a knockout hole with a separate steel clip (BK/A-104) or in a keyhole punch using separate mounting clip NO.6374 for panels of thickness 0.043"to 0.062" or NO.4909 for thickness 0.030" to 0.042". * For two leads (one each for line and loadside) order HLR-2A, 15 A, 300 V Note: Do not put tension on line (rear) terminal of fuse holder. "A" in-line holder An alternative to the HLR fuse holder is the "A" fuse holder. The A fuse holder comes WITHOUT leads. The customer inserts NO.18 insulated solid copper wire into the lineside receptacle as well as into the load side receptacle. It has the same body dimensions, utilizes the same mounting hole, and takes the same mounting clips as the HLR. The A fuse holder is UL Recognized, 10 A, 300 Vac, Guide IZLT2, File E14853 and CSA Certified, 10 A, 300 Vac, Class 6225-01, File 47235. Order catalog number A. Features • Fuse Holder1, 2* Fuse Holder1, 2* GMF-3/10 HLR GMF-3 HLR GMF-1/2 HLR GMF-3-2/10 HLR GMF-6/10 HLR GMF-4 HLR GMF-8/10 HLR GMF-5 HLR GMF-1 HLR GMF-6-1/4 HLR GMF-1-1/4 HLR GMF-7 HLR GMF-1-6/10 HLR GRF-8 HLR GMF-2 HLR GMF-10 HLR GMF-2-1/2 HLR GRF-10 HLR GMF-2-8/10 HLR 1 Carrier is UL Recognized, Guide IZLT2, File E14853 and CSA Certified, Class 6225-01, File 47235 12 A, 300 Vac. 2 Units can be panel-mounted either in a knockout hole with a separate steel clip (BK/A-104) or in a keyhole punch using separate mounting clip NO.6374 for panels of thickness 0.043"to 0.062" or NO.4909 for thickness 0.030" to 0.042". * For two leads order HLR-2A, 15 A, 300 V Note: Do not put tension on line (rear) terminal of fuse holder. "A" in-line holder An alternative to the HLR fuse holder is the A fuse holder. The A fuse holder comes WITHOUT leads. The customer inserts NO.18 insulated solid copper wire into the line side receptacle as well as into the load side receptacle. It has the same body dimensions, utilizes the same mounting hole, and takes the same mounting clips as the HLR. The A fuse holder is UL Recognized, 10 A, 300 Vac, Guide IZLT2, File E14853 and CSA Certified, 10 A, 300 Vac, Class 6225-01, File 47235. Order catalog number A. Features In-line, fast-acting circuit protection. Typical applications • UL Listed, Std. 248-14 0-10 A, Guide JDYX, File E19180, CSA Certified, Class 1422-01, File 53787, CE • In-line, time-delay circuits protection Typical applications In-line lighting ballast protection • HLR-2A fuse holder In-line lighting ballast protection HLR fuse holder Data sheet no. 2032 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Data sheet no. 2031 Eaton.com/bussmannseries 2-11 Low voltage, supplemental fuses Low voltage supplemental fuses — 2 2 — Low voltage supplemental fuses ATR fast-acting micro blade fuse ATM and ATM-LP fast-acting blade fuses Fast-acting, color-coded 2-leg micro blade fuse. Fast-acting, color-coded blade fuse available in standard and low-profile versions. Standard version available with indication. Ratings • Volts 32 Vdc • Amps 5-30 A • IR 1000 A 2011/65/EU Agency information • • Volts 32 Vdc • Amps 1-30 A • IR 1000 A Indicating Agency information RoHS compliant • Catalog no. (amps) Fuse Color code ATR-5 Tan ATR-20 Yellow Brown ATR-25 Clear ATR-10 Red ATR-30 Green ATR-15 Blue ATR-7-1/2 Fuse Color code • Space-savings size • Industry standard color coding for easy identification of fuse rating Standard UL Listed, Guide FHXT, File AU 169 (2-30 A non-indicating ATM) Catalog no. (amps) Features Typical applications • Low-profile Ratings Automotive Recommended holder for ATR fuses, see page 2-14. Non-indicating *Indicating Low-profile ATM-1 — — Color code Black ATM-2 — ATM-2LP Gray ATM-3 ATM-3ID ATM-3LP Violet ATM-4 — ATM-4LP Pink ATM-5 ATM-5ID ATM-5LP Tan ATM-7-1/2 ATM-7-1/2ID ATM-7-1/2LP ATM-10 ATM-10ID ATM-10LP Brown Red ATM-15 ATM-15ID ATM-15LP Blue ATM-20 ATM-20ID ATM-20LP Yellow ATM-25 ATM-25ID ATM-25LP Clear ATM-30 ATM-30ID ATM-30LP Green * Call customer satisfaction for ordering information. Features • Industry standard color coding for easy identification of fuse rating • Indicating versions show blown fuse at a glance, speeds troubleshooting Typical applications • Automotive Recommended blocks and holders for ATM fuses, see page 2-14. Data sheet no. 2048 (ATM), 2050 (ATM-LP) 2-12 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Low voltage supplemental fuses — 2 ATC fast-acting blade fuse MAX (MAXI) fast-acting blade fuse Fast-acting, color-coded blade fuse for automotive and control circuit applications. Fast-acting, color-coded, high amp blade fuse. Available with and without indication. Ratings Ratings Volts 32 Vdc • Amps 1-40 A • IR 1000 A Standard Indicating • Volts 32 Vdc • Amps Agency information • • UL Recognized, (1-40 A) (Guide JFHR2, File E56412), SAE Standard J1284 *Indicating ATC-1 — Black ATC-2 — Gray ATC-3 ATC-3ID Violet ATC-4 — Pink ATC-5 ATC-5ID Tan ATC-7-1/2 ATC-7-1/2ID ATC-10 ATC-10ID Red ATC-15 ATC-15ID Blue ATC-20 ATC-20ID Yellow ATC-25 ATC-25ID Clear ATC-30 ATC-30ID Green ATC-35 ATC-35ID Blue-green ATC-40 ATC-40ID Orange Color code Brown * Call customer satisfaction for ordering information. Features • 20-80 A (non-indicating) • 20-100 A (indicating) Indicating IR 1000 A Catalog no. (amps) Catalog no. (amps) Non-indicating Standard Low voltage, supplemental fuses • Non-indicating *Indicating MAX-20 MAX-20ID Color code MAX-25 — MAX-30 MAX-30ID MAX-35 — Brown MAX-40 MAX-40ID Orange MAX-50 MAX-50ID Red MAX-60 MAX-60ID Blue MAX-70 MAX-70ID Tan MAX-80 MAX-80ID Clear — MAX-100ID Purple Yellow Gray Green * Call customer satisfaction for ordering information. Features • Color coded housing for easy identification of fuse rating • Indicating versions show blown fuse at a glance, speeds troubleshooting Typical applications • Industry standard color coding for easy identification of fuse rating • • Indicating versions show blown fuse at a glance, speeds troubleshooting Recommended holders for MAX fuses, see page 2-14. Automotive Typical applications • Automotive • Low voltage control circuits Recommended blocks and holders for ATC fuses, see page 2-14. Data sheet no. 2009 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Data sheet no. 2049 Eaton.com/bussmannseries 2-13 2 — Low voltage supplemental fuses In-line fuse holders for ATM, ATC and MAX fuses PCB fuseclips for ATM and ATC fuses ATM fuseclips LED open fuse indicator easyID LED indicating holders available for ATM, ATC and MAX fuses Catalog no. 1A5779 Catalog no. 1A5778 • 15 A • 15 A • Nickel-plated brass • Nickel-plated brass/glass-filled nylon Dimensions — mm (in) Typical in-line blade fuse holders with leadwires Dimensions — mm (in) 14.68 (0.578) 1.9 (0.075) In-line fuse holders for ATM, ATC and MAX blade fuses. Versions available with and without covers and with open fuse indication. 1.24 (0.049) 4.75 (0.187) 3.96 (0.156) Base Ratings Fuseclips 4.98 (0.196) • Volts 32 Vdc • Amps 80% continuous of fuse rating. See catalog numbers table for individual holder fuses amp ranges. Catalog Max no. Description amps Electrical connection ATR holder HH2 Black w/ cover 15 2x4" #16 red leadwire ATM holders - not for low-profile ATM fuses HHL Black w/ cover 20 2x4" #16 black leadwire HHM Black w/ cover 30 2x4" #12 red leadwire HHU Black w/ cover 30 2x4" #12 red leadwire Indicating holder, ATM-FHID black w/ cover 20 2x4" #16 black leadwire Low-profile ATM holder HHV Black w/ cover 20 2x4" #12 red leadwire ATC holders HHC Yellow 20 2x4" #16 black leadwire HHD Black 30 2x4" #12 yellow leadwire HHF Black w/ cover 20 2x4" #16 yellow leadwire HHG Black w/ cover 30 2x4" #12 yellow leadwire HHR Black w/ cover 30 2x5" #12 red leadwire HHS Blue, self-stripping 20 Accepts #14-18 leadwire Indicating holder, ATC-FHID 20 2x6" #16 black leadwire black w/ cover MAX holders HHX Black w/ cover 60 2x5" #6 red leadwire Indicator, black w/ MAX-FHID cover 60 2x5" #6 red leadwire Fuses must be fully inserted into the holder to provide a solid connection. Poor or improper fuse insertion can result in fuse and holder failure and loss of power and/or circuit protection. 8.64 (0.34) 11.18 (0.44) 1.57 (0.062) 3.18 (0.125) 3.66 (0.144) 3.66 (0.144) 3.18 (0.125) 2.54 (0.1) 1.45 (0.057) 1.57 (0.062) 2.18 (0.086) 4.47 (0.176) 1.57 (0.062) 3.66 (0.144) 3.66 (0.144) 4.47 (0.176) 3.66 (0.144) Ø1.65 (0.065) TYP-4 3.66 (0.144) Land pattern Ø1.65 (0.065) TYP-4 Land pattern ATC fuseclips Catalog no. 1A5780 Catalog no. 1A5600 • 20 A • 15 A • Tin-plated cartridge brass • Nickel-plated brass/glass-filled nylon Dimensions — in (mm) Dimensions — mm (in) 0.295 (7.49) 19.30 (0.76) 4.45 (0.175) 0.33 (8.38) 0.15 (3.81) 3.18 (0.125) Base 0.053 (1.35) 0.2 (5.08) 6.88 (0.271) 0.08 (2.03) 0.09 (2.29) Fuseclips 6.35 (0.25) 11.1 (0.437) 1.27 (0.05) 5.08 (0.2) 4.06 (0.16) 5.08 (0.2) Ø2.54 (0.1) TYP-4 ± 0.05 Land pattern Data sheet no. ATM fuses 2128 (HHM, HHL) ATC fuses 2107 (HHC, HHD, HHF, HHG) Max fuses 2129 (HHX) 2-14 Data sheet no. 2131 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Electronic, PCB and small dimension fuses — 3 Contents Section page Description Product C515, C519 time-delay 5x15 mm fuses C518, C520 fast-acting C517 fast acting GDB, S500, S500-V fast-acting IEC 5x20 mm fuses GDA, S501, S501-V fast-acting S505, S506SC time-delay GDC, S505H, S505H-V, S505SCH, S506 S506-V time-delay GMA, GMA-V fast-acting UL 5x20 mm fuses • • • • • • • 5x15 mm 5x20 mm IEC 5x20 mm UL 1/4” x 5/8” 1/4” x 7/8” 1/4” x 1” 1/4” x 1-1/4” PLUS PCB fuse holders and clips GMC, GMC-V time-delay GMD GMD-V time-delay 1/4" x 5/8" fuse AGA fast-acting 1/4" x 7/8" fuse AGW fast-acting 1/4" x 1" fuse AGX fast acting AGC, AGC-V, ABC, ABC-V fast-acting GBB, GBB-V fast-acting 1/4" x 1-1/4" fuses MDL, MDL-V time-delay MDQ, MDQ-V, MDA, MDA-V timedelay 2 3 4 5 6 7 8 9 10 11 PCB holders and fuseclips 5x20 mm holders H15-V, H15-H, HTC-60M 12 1/4" x 1-1/4" holders HBH-I, HBH-M, HBV-I, HBV-M, HBW-I, HBW-M 13 5 mm fuseclips HTC-15M, HTC-140M, HTC-200M, HTC-210M, 1A3399, 1A5018, 1A5601, 1A5602 14 1A1119, 1A1120, 1A1907, 1A3398, 1A4533, 1A4534 15 1/4" fuseclips 5681, 5682 9/32" fuseclips 5674 13/32" fuseclips 5960 1A3400 9/16" fuseclips 5592 16 For blocks and holders, see the following pages in Section 8 Fuse diameter Pages Panel mount blocks 1/4" fuses 4-5 Through panel holders 5 mm fuses 41 1/4" fuses 41-42 In-line holders 5 mm fuses 46 1/4" fuses BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 46-48 Eaton.com/bussmannseries 3-1 Electronic, PCB, small dimension fuses Full range of small dimension fast-acting and time-delay fuses Catalog symbol/type Fuses 3 — Electronic, PCB and small dimension fuses C519 ferrule and C515 axial lead time-delay 5x15 mm glass tube fuses C520 ferrule and C518 axial lead fast-acting 5x15 mm glass tube fuses Ratings Ratings 2011/65/EU • Volts • 125 Vac (3.5-7 A) • 250 Vac (125mA-3 A) • 32 Vdc (self certified) • Amps 125mA-7 A • IR • 250 Vac • 32 Vdc (self certified) • Amps 100mA-5 A • IR • 35 A (100mA-750mA @ 250 Vac) 25 A (350mA @ 600 Vac) • 10 kA (100mA-5 A @ 125 Vac) • 35 A (125mA-1A @ 250 Vac) • 100 A (1.5-3.5 A @ 250 Vac) • 100 A (1.25-3 A @ 250 Vac) • 200 A (4-5 A @ 250 Vac) • 400 A (3.5-7 A @ 125 Vac) • 10 kA (125mA-3 A @ 125 Vac) Agency information • UL Listed, Guide JDYX, File E19180 125mA-250mA and 375mA-3 A, UL Recognized, Guide JDYX2, File E19180, 350mA and 3.5-7 A, CSA Certified, Class 1422-01, File 53787 125mA-250mA and 375mA-3 A, RoHS compliant, CE Features • Volts • Agency information • 2011/65/EU • Time-delay for closer sizing on inductive circuits Electronic circuits • Printed circuit boards Features • Small footprint saves space in equipment • Fast-acting for maximum component protection • Available in ferrule and axial leaded configurations Typical applications Typical application • UL Recognized, Guide JDYX2, File E19180, CSA Certified, Class 1422-01, File 53787, RoHS compliant, CE • Electronic circuits • Printed circuit boards Catalog no. (amps) Catalog no. (amps) Ferrule Ferrule C520-100-R C520-500-R C520-2.5-R C520-125-R C520-750-R C520-3-R C520-250-R C520-1.5-R C520-3.5-R C520-375-R C520-2-R C520-4-R C518-375-R C518-2-R C519-125-R C519-600-R C519-1.6-R C519-3.5-R C519-250-R C519-750-R C519-2-R C519-4-R C519-350-R C519-1-R C519-2.25-R C519-5-R C519-375-R C519-1.25-R C519-2.5-R C519-500-R C519-1.5-R C519-3-R C515-125-R C515-750-R C515-2-R C515-5-R C515-250-R C515-800-R C515-2.25-R C515-6-R C515-350-R C515-1-R C515-2.5-R C515-7-R C515-375-R C515-1.25-R C515-3-R C515-500-R C515-1.5-R C515-3.5-R C515-600-R C515-1.6-R C515-4-R Data sheet no. 2006 (C515) and 2007 (C519) 3-2 Axial lead C518-100-R Axial lead C520-5-R C518-3.5-R C518-125-R C518-500-R C518-2.5-R C518-4-R C518-250-R C518-750-R C518-3-R C518-5-R Data sheet no. 2026 (C518) and 2027 (C520) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Electronic, PCB and small dimension fuses — 3 C517 axial lead fast-acting 5x15 mm glass tube fuse S500 ferrule (GDB†) and S500-V axial lead fast-acting, low breaking capacity 5x20 mm glass tube fuses 2011/65/EU • Volts • 350 Vac • 32 Vdc (self certified) • Amps 3 A • IR • Volts • 250 Vac (or less) • 32 Vdc (self certified) • Amps 32mA-10 A • IR • 100 A @ 350 Vac* • 100 A @ 250 Vac • 35 A (32mA-3.15 A) • 10 kA @ 125 Vac • 40 A (4 A) * 350 Vac/100 A IR is UL Recognized. • 63 A (6.3 A) Agency information • 80 A (8 A) • 100 A (10 A) • 2011/65/EU Ratings UL Listed, Guide JDYX, File E19180, CSA Certified, Class 142201, File 53787, UL Recognized, Guide JDYX2, File E19180, RoHS compliant, CE Features • Small footprint saves space in equipment • Fast-acting for maximum component protection • 350 Vac rating for 277 V ballast circuit protection Electronic, PCB, small dimension fuses Ratings Agency information • cURus, SEMKO, VDE, BSI, IMQ, CCC, RoHS compliant, CE • Agency information not applicable to all ratings; see data sheet for details. Features Typical applications • Fast-acting for maximum protection, conforms to IEC 60127-2 (160mA-10 A) Typical applications • Electronic circuits • Printed circuit boards • Electronic ballast protection • Electronic circuits Catalog no. (amps)* S500-32-R To order, use catalog number C517-3-R S500-160-R S500-800-R S500-4-R S500-40-R S500-200-R S500-1-R S500-5-R S500-50-R S500-250-R S500-1.25-R S500-6.3-R S500-63-R S500-315-R S500-1.6-R S500-8-R S500-10-R S500-80-R S500-400-R S500-2-R S500-100-R S500-500-R S500-2.5-R S500-125-R S500-630-R S500-3.15-R * GDB is not available with axial leads. To order axial leads, place “V” in the S500 catalog number. E.g., S500-V-32-R. † When ordering GDB versions, do not add “-R” suffix to catalog number. Data sheet no. 2025 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Data sheet no. 2052 (S500), 2015 (GDB) Eaton.com/bussmannseries 3-3 3 — Electronic, PCB and small dimension fuses S501 ferrule (GDA†) and S501-V Axial lead fast-acting high breaking capacity 5x20 mm ceramic tube fuses 2011/65/EU Ratings • S505 ferrule, and S505SC axial lead time-delay, high-breaking capacity 5x20 mm ceramic tube fuses Volts 2011/65/EU Ratings • Volts • 250 Vac (or less) • 250 Vac (or less) • 32 Vdc (self certified) • 32 Vdc (self certified) • Amps 50mA-10 A** • Amps 500mA-12 A • IR 1500 A @ 250 Vac • IR 1500 A @ 250 Vac Agency information Agency information • cURus, SEMKO, VDE, IMQ, CCC, CSA, BSI, MITI/JET, RoHS compliant, CE • cURus, CSA, IMQ, VDE, SEMKO, CCC/CQC, PSE/JET, KC, BS, RoHS compliant • Agency information not applicable to all ratings, see data sheet for details. • Agency information not applicable to all ratings, see data sheet for details. Features Features • Fast-acting for maximum protection • Time-delay performance ideal for inductive circuits. • High break capacity for use in higher fault energy electronic circuitry • Conforms to IEC standards. • Conforms to IEC standards • Typical applications • Typical applications Electronic circuits Catalog no. (amps)* Electronic circuits Catalog no. (amps)* S505-500-R** S505-1.6-R S505-4-R S505-10-R S505-800-R** S505-2-R S505-5-R S505-12-R** S501-50-R S501-200-R S501-800-R S501-3.15-R S505-1-R S505-2.5-R S505-6.3-R S501-63-R S501-250-R S501-1-R S501-4-R S505-1.25-R S505-3.15-R S505-8-R S501-80-R S501-315-R S501-1.25-R S501-5-R S501-100-R S501-400-R S501-1.6-R S501-6.3-R S501-125-R S501-500-R S501-2-R S501-8-R S501-160-R S501-630-R S501-2.5-R S501-10-R * To order axial leads, place “SC” in catalog number. E.g., S505SC-2-R. ** Axial leads not available. * GDA is not available with axial leads. To order axial leads, place “V” in the S501 catalog number. E.g., S501-V-125-R. † When ordering GDA version, do not add “-R” suffix to catalog number, GDA is not available above 6.3 A. Data sheet no. 2051 (S501), 2014 (GDA) 3-4 Data sheet no. 2037 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Electronic, PCB and small dimension fuses — 3 S505H ferrule, and S505H-V and S505SCH axial time-delay high breaking capacity 5x20 mm ceramic tube fuses 2011/65/EU Ratings Volts • • • • 600 Vac/400 Vdc (S505H 500mA-5 A • 500 Vac/400 Vdc (S505H 6.3-10 A) • 250 Vac (S505SCH) 2011/65/EU Ratings Volts • 250 Vac (or less) • 32 Vdc (self certified) • Amps 32mA-15 A** • IR 35 A @ 250 Vac Agency information Amps • 500mA-10 A (S505H) • 3.15-6.3 A (S505SCH) IR @ 250 Vac • 35 A (S505H) • 1.5 kA (S505SCH / 50 Hz / 250 Vac / 400 Vdc) • 100 A max AC cURus, CCC, CQC, TUV, PSE/JET (S505H) • cURus, KC, CQC, TUV (S505SCH) • RoHS compliant • Agency information not applicable to all ratings; see data sheets for details. Conforms to IEC standards Typical applications • Power supplies/adapters • Desktops/notebooks Agency information not applicable to all ratings; see data sheet for details. • Time-delay for inductive circuits • Conforms to IEC standards • Features • • Typical applications • Time-delay, high breaking capacity UR, CSA, cURus, SEMKO, VDE, BSI, IMQ, VDE, PSE/JET, CCC, RoHS compliant Features Agency information • • Electronic circuits Catalog no. (amps)* S506-32-R S506-160-R S506-800-R S506-4-R S506-40-R S506-200-R S506-1-R S506-5-R S506-50-R S506-250-R S506-1.25-R S506-6.3-R S506-63-R S506-315-R S506-1.6-R S506-8-R S506-80-R S506-400-R S506-2-R S506-10-R S506-100-R S506-500-R S506-2.5-R S506-12.5-R S506-125-R S506-630-R S506-3.15-R S506-15-R * GDC is not available with axial leads. To order axial leads, place “V” in the S506 catalog number. E.g., S506-V-15-R. † When ordering GDC version, do not add “-R” suffix to catalog number., GDC fuses are not available above 6.3 A. Catalog no. (amps) S505H* S505H-500-R S505H-1.6-R S505H-4-R S505H-800-R S505H-2-R S505H-5-R S505H-1-R S505H-2.5-R S505H-6.3-R S505H-1.25-R S505H-3.15-R S505H-8-R S505H-10-R S505SCH (axial lead only S505SCH-3.15-R S505SCH-5-R S505SCH-6.3-R * To order an axial lead S505H fuse, place “V” in catalog number. E.g., S505H-V-5-R. Data sheet no. 4406 (S505H), 10401 (S505SCH) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Data sheet no. 4332 (S506), 2016 (GDC) Eaton.com/bussmannseries 3-5 Electronic, PCB, small dimension fuses • S506 ferrule (GDC†) and S506-V axial lead time-delay low breaking capacity 5x20 mm glass tube fuses 3 — Electronic, PCB and small dimension fuses GMA ferrule and GMA-V axial leads fast-acting 5x20 mm glass tube fuses GMC ferrule and GMC-V axial lead medium time-delay 5x20 mm glass tube fuses Ratings Ratings • • • 2011/65/EU Volts • 250 Vac (63mA-3 A) • 250 Vac (63mA-3.15 A) • 125 Vac (3.15-15 A) • 125 Vac (3.5-10 A) • 32 Vdc (self certified) • 32 Vdc (self certified) Amps 63mA-15 A • Amps 63mA-10 A IR • IR • 35 A (63mA-1 A @ 250 Vac, p.f. = 0.7-0.8) • 35 A (63mA-1 A @ 250 Vac, p.f. = 0.7-0.8) • 10 kA (63mA-6 A @ 125 Vac, p.f. = 0.7-0.8) • 10 kA (63mA-6 A @ 125 Vac, p.f. = 0.7-0.8) • 100 A (1.25-2.5 A @ 250 Vac, p.f. = 0.7-0.8) • 100 A (1.25-3.15 A @ 250 Vac, p.f. = 0.7-0.8) • 200 A (7-8 A @ 125 Vac, p.f. = 1.0) • 200 A (6.3-10 A @ 125 Vac, p.f. = 1.0) • 150 A (10-15 A @ 125 Vac, p.f. = 1.0) Agency information UL Listed, Std. 248-14 Guide JDYX, File E19180 up to 6 A, UL Recognized, Guide JDYX2, File E19180, 7-15 A, CSA Certified, Class 1422-01,File 53787 up to 6 A, PSE Approval 1-15 A, RoHS compliant, CE Features • • UL Listed, Std. 248-14, Guide JDYX, File E19180 up to 6.3 A, UL Recognized, Guide JDYX2, File E19180 7-10 A, CSA Certified, Class 1422-01, File 53787 up to 6.3 A, MITI Approval, 1-10 A, KC, RoHS compliant, CE • KC not applicable to all ratings; see data sheet for details Features Fast-acting for maximum protection • Typical applications • Volts • Agency information • 2011/65/EU Conforms to UL standards Typical applications Electronic circuits • Catalog no. (amps)* GMA-63-R GMA-600-R GMA-2-R GMA-7-R GMA-100-R GMA-750-R GMA-2.5-R GMA-8-R GMA-125-R GMA-800-R GMA-3.15-R GMA-10-R GMA-200-R GMA-1-R GMA-3.5-R GMA-15-R GMA-250-R GMA-1.25-R GMA-4-R GMA-300-R GMA-1.5-R GMA-5-R GMA-500-R GMA-1.6-R GMA-6-R * To order axial leads, place “V” in catalog number. E.g., GMA-V-8-R. Electronic circuits Catalog no. (amps)* GMC-63-R GMC-315-R GMC-1.25-R GMC-5-R GMC-80-R GMC-400-R GMC-1.5-R GMC-6-R GMC-100-R GMC-500-R GMC-1.6-R GMC-6.3-R GMC-125-R GMC-600-R GMC-2-R GMC-7-R GMC-150-R GMC-630-R GMC-2.5-R GMC-8-R GMC-10-R GMC-200-R GMC-750-R GMC-3.15-R GMC-250-R GMC-800-R GMC-3.5-R GMC-300-R GMC-1-R GMC-4-R * To order axial leads, place “V” in catalog number. E.g., GMC-V-5-R. Data sheet no. 2017 3-6 Data sheet no. 4395 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Electronic, PCB and small dimension fuses — 3 Ratings • • Volts • 250 Vac • 32 Vdc (self certified) Amps 125mA-4 A • IR Volts • 125 Vac (or less) • 32 Vdc (self certified) • Amps 1-30 A • IR • 10 kA (1 to 1-1/2 A @ 125 Vac) • 10 kA (125mA-3 A @ 125 Vac, p.f. = 0.7-0.8) • 200 A (2-5 A @ 125 Vac) • 10 kA (4 A @ 125 Vac, p.f. = 1.0) • 1000 A (6-30 A @ 32 Vac) • 35 A (125mA-1 A @ 250 Vac, p.f. = 0.7-0.8) • 100 A (1.2-3. A @ 250 Vac, p.f. = 0.7-0.8) • 200 A (4 A @ 250 Vac, p.f. = 1.0) Agency information • Agency information • Ratings 2011/65/EU • • AGA fast-acting 1/4˝ x 5/8˝ glass tube fuse UL Listed, Std. 248-14, Guide JDYX, File E19180 up to 3-1/2 A UL Recognized, Guide JDYX2 12-30 A, CE Features UL Listed Guide JDYX, File E19180, UL Recognized Card (4 A), Guide JDYX2, File E19180, 4 A, CSA Certified, Class 1422-01, File 53787, PSE/JET, File 1641-31003-1001, RoHS complaint, CE Agency information not applicable to all ratings; see data sheet for details • Fast-acting for maximum protection • Size rejects insertion of other fuse types Typical applications • Features Electronic circuits • Time-delay for inductive circuits Catalog no. (amps) • Conforms to UL standards AGA-1 Typical applications • Electronic circuits AGA-3 AGA-7-1/2 AGA-25 AGA-30 AGA-1-1/2 AGA-5 AGA-10 AGA-2 AGA-6 AGA-15 AGA-2-1/2 AGA-7 AGA-20 Catalog no. (amps)* GMD-125-R GMD-375-R GMD-800-R GMD-2-R GMD-150-R GMD-400-R GMD-1-R GMD-2.5-R GMD-200-R GMD-500-R GMD-1.2-R GMD-3-R GMD-250-R GMD-600-R GMD-1.25-R GMD-4-R GMD-300-R GMD-630-R GMD-1.5-R GMD-315-R GMD-750-R GMD-1.6-R * To order axial leads, place “V” in catalog number. E.g., GMD-V-2.5-R. Data sheet no. 2019 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Data sheet no. 2039 Eaton.com/bussmannseries 3-7 Electronic, PCB, small dimension fuses GMD ferrule and GMD-V axial leads time-delay 5x20 mm glass tube fuses 3 — Electronic, PCB and small dimension fuses AGW fast-acting 1/4˝ x 7/8˝ glass tube fuse AGX fast-acting 1/4˝ x 1˝ glass tube fuse Ratings Ratings • Volts • Volts • 32 Vac • 250 Vac (1//4-20 A) • 32 Vdc (self certified) • 125 Vac (25-30 A) • 32 Vdc (1/4-30 A) • Amps 1-30 A • IR 1 kA AC Features • Amps 1/4-30 A • IR • 35 A (1/4-1 A @ 250 Vac) • 10 kA (1/4-10 A @ 125 Vac) Typical applications • 200 A (15-20 A @ 125 Vac) Electronic circuits • 100 A (25-30 A @ 125 Vac) • 1000 A (8-30 A @ 32 Vac) • • Fast-acting for maximum protection Catalog no. (amps) AGW-1 AGW-3 AGW-7-1/2 AGW-25 AGW-1-1/2 AGW-4 AGW-10 AGW-30 AGW-2 AGW-5 AGW-15 AGW-2-1/2 AGW-6 AGW-20 Agency information • cULus up to 10 A, Guide JDYX, File E 19180 and Guide JDYX7, File E19180, UL Recognized Card 15-30 A Guide JDYX2, File E19180, CSA Component Acceptance Card 15-30 A Class No. 1422-01, File 53787 Features • Size rejects inserting of other fuse types Typical applications • Electronic circuits Catalog no. (amps) AGX-1/4 Data sheet no. 2040 3-8 AGX-1 AGX-4 AGX-15 AGX-3/10 AGX-1-1/4 AGX-5 AGX-20 AGX-3/8 AGX-1-1/2 AGX-6 AGX-25 AGX-30 AGX-4/10 AGX-2 AGX-7 AGX-1/2 AGX-2-1/2 AGX-8 AGX-3/4 AGX-3 AGX-10 Data sheet no. 2041 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Electronic, PCB and small dimension fuses — 3 AGC ferrule and AGC-V axial lead fast-acing 1/4" x 1-1/4˝ glass tube fuses Ratings • • 2011/65/EU Volts Ratings • 250 Vac (1/20-10 A) • 250 Vac/125 Vdc (1/4-15 A, 20-30 A)* • 32 Vac (12-40 A) • 250 Vac (18 A) • 32 Vdc (self certified) • 32 Vdc (self certified) Amps 1/20-40 A • Amps 1/4-30 A IR • IR** • 35 A (1/20-1 A @ 250 Vac) • 35 A (1/4-1 A @ 250 Vac) • 100 A (11/4-3 A @ 250 Vac) • 100 A (11/2-3 A @ 250 Vac) • 200 A (4-10 A @ 250 Vac) • 200 A (4-10 A @ 250 Vac) • 10 kA (1/20-10 A @ 125 Vac) • 750 A (12-15 A @ 250 Vac) • 1000 A (12-40 A @ 32 Vac) • 400 A (18-20 A @ 250 Vac) • 10 kA (1/4-15 A @ 125 Vac) • 1 kA (18-30 A @ 125 Vac) • 10 kA (1/4-15, 20 A @ 125 Vdc) • 400 A (25-30 A @ 125 Vdc) • 200 A (25-30 A @ 250 Vac) UL Listed, Guide JDYX, File E19180, up to 10 A, UL Recognized, Guide JDYX2, File E19180, 12-30 A, CSA Certified, Class 142201, CSA Component Acceptance Card, Class No. 1422-30, RoHS compliant, CE Features • Original electronic glass tube fuse • Fast-acting for maximum protection • Wide amp/volt ratings allow versatility of protecting electronic circuits Typical applications • Volts • Agency information • 2011/65/EU Electronic, PCB, small dimension fuses • ABC ferrule and ABC-V axial leads fast-acting 1/4" x 1-1/4˝ ceramic tube fuse * CSA approvals for 25 A and 30 A are at 125 Vac – IR 1000 A and Vdc – IR 400 A (IR 1000 A at 75 Vdc) ** Interrupting ratings measured at 70% – 80% power factor on AC. The interrupting ratings for 18 A and 20 A were measured at 85%-95% power factor on AC. The interrupting ratings for 25 A and 30 A were measured at 89% power factor on AC. Agency information • Electronic circuits UL Listed, Std. 248-14, Guide JDYX File E19180 up to 15 A; UL Recognized, Guide JDYX2, File E19180, 18-30 A; CSA Certified, Class 1422-01 and 1422-30, File 53787, RoHS compliant, CE Features Catalog no. (amps)* AGC-1/20-R AGC-3/4-R AGC-5-R AGC-15-R AGC-1/10-R AGC-1-R AGC-6-R AGC-20-R AGC-1/8-R AGC-1-1/4-R AGC-7-R AGC-25-R AGC-3/16-R AGC-1-1/2-R AGC-7-1/2-R AGC-30-R AGC-2/10-R AGC-2-R AGC-8-R AGC-35-R AGC-1/4-R AGC-2-1/4-R AGC-9-R AGC-40-R AGC-3/10-R AGC-2-1/2-R AGC-10-R AGC-3/8-R AGC-3-R AGC-12-R AGC-1/2-R AGC-4-R AGC-14-R * To order axial leads, place “V” in catalog number. E.g., AGC-V-1/10-R. • Ceramic body allows for higher amp/volt rating combinations Typical applications • Electronic circuits Catalog no. (amps) ABC-1/4-R ABC-2-R ABC-6-R ABC-15-R ABC-1/2-R ABC-2-1/2-R ABC-7-R ABC-18-R ABC-3/4-R ABC-3-R ABC-8-R ABC-20-R ABC-1-R ABC-4-R ABC-10-R ABC-25-R ABC-1-1/2-R ABC-5-R ABC-12-R ABC-30-R * To order axial leads, place “V” in catalog number. E.g., ABC-V-7-R. Data sheet no. 2543 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Data sheet no. 2000 Eaton.com/bussmannseries 3-9 3 — Electronic, PCB and small dimension fuses GBB ferrule and GBB-V axial lead very-fast-acting 1/4" x 1-1/4˝ ceramic tube fuses MDL ferrule and MDL-V axial lead time-delay 1/4" x 1-1/4˝ glass tube fuses Ratings Ratings 2011/65/EU 2011/65/EU Volts • Volts 250 Vac/125 Vdc • Amps 1-30 A • 250 Vac (1/16-8 A) • IR • 32 Vac (9-30 A) • 32 Vdc (self certified) • • 200 A @ 250 Vac • 200 A (20-30 A @ 125 Vac/dc) • Amps 1/16-30 A • 10 kA (1-15 A @ 125 Vac/dc) • IR* Agency information • UL Recognized, Std. 248-14, Guide JFHR2, File E56412, CSA Component Acceptance Class 1422-30, File 53787, RoHS complaint, CE Features • Very fast-acting performance allows protection of highly sensitive electronic circuitry Typical applications • • GBB-8-R 100 A (11/4-3 A @ 250 Vac) • 200 A (4-8 A @ 250 Vac) • 10000 A (1/16-8 A @ 125 Vac) • 1000 A (9-30 A @ 32 Vac) Agency information Catalog no. (amps)* GBB-4-R 35 A (1/16-1 A @ 250 Vac) • * Interrupting ratings were measured at 70% – 80% power factor on AC, and at a time constant described in UL 198L. Electronic circuits GBB-1-R • UL Listed, Guide JDYX, File E19180 up to 8 A; CSA Certified Class 1422-01 up to 8 A; UL Recognized, Guide JDYX2, File E19180, 9-30 A; CSA Component Acceptance, Class 1422-30, 9-30 A, RoHS compliant, CE GBB-15-R Features • GBB-1-1/4-R GBB-5-R GBB-9-R GBB-20-R GBB-2-R GBB-6-R GBB-10-R GBB-25-R GBB-3-R GBB-7-R GBB-12-R GBB-30-R * To order axial leads, place “V” in catalog number. E.g., GBB-V-10-R. Time-delay allows close sizing on inductive circuits Typical applications • Electronic circuits Catalog no. (amps)* MDL-1/16-R MDL-1/2-R MDL-3-R MDL-10-R MDL-1/10-R MDL-3/4-R MDL-3-2/10-R MDL-12-R MDL-1/8-R MDL-1-R MDL-4-R MDL-15-R MDL-2/10-R MDL-1-1/4-R MDL-5-R MDL-20-R MDL-3/16-R MDL-1-1/2-R MDL-6-R MDL-25** MDL-1/4-R MDL-2-R MDL-7-R MDL-30** MDL-3/10-R MDL-2-1/4-R MDL-8-R MDL-3/8-R MDL-2-1/2-R MDL-9-R * To order axial leads, place “V” in catalog number. E.g., MDL-V-3-R. ** RoHS compliant construction not available. Data sheet no. 2013 3-10 Data sheet no. 2004 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Electronic, PCB and small dimension fuses — 3 MDQ ferrule and MDQ-V axial lead dual-element, time-delay 1/4" x 1-1/4˝ glass tube fuses MDA ferrule and MDA-V axial lead time-delay 1/4" x 1-1/4˝ ceramic tube fuses Ratings Ratings • • Volts • 250 Vac (1/100-7 A) • 250 Vac (or less) • 32 Vac (7-1/2 to 15 A) • 125 Vdc (20-30 A) • 32 Vdc (self certified) • 32 Vdc (self certified) Amps 1/100-15 A • Amps 1/4-30 A IR • IR** • 35 A (1/100-1 A @ 250 Vac) • 35 A (1/4 to 1 A @ 250 Vac) • 100 A (1-1/4 to 3 A @ 250 Vac) • 100 A (1-1/2 to 2 A @ 250 Vac) • 200 A (4-7 A @ 250 Vac) • 200 A (2-1/2 to 10 A @ 250 Vac) • 1000 A (7-1/2 to 12 A @ 32 Vac) • 750 A (12-15 A @ 250 Vac) • 1500 A (20-30 A @ 250 Vac) • 10 kA (1/4-30 A @ 125 Vac) • 10 kA (20-30 A @ 125 Vdc) UL Listed, Std. 248-14, Guide JDYX, File E19180 1/16-7 A, CSA Component Acceptance, Class 1422-01, File 47233 1/16 -15 A, UL Recognized, Guide JDYX2, File E19180, 7-1/2-15 A. Features • ** Interrupting ratings were measured at 70% – 80% power factor on AC, and at a time constant described in UL 248. Agency information Dual-element design allows closer sizing to inductive circuits than any other fuses • Typical applications • 2011/65/EU • Agency information • Volts Electronic, PCB, small dimension fuses • Electronic relay and control circuits UL Listed, Std. 248-14, Guide JDYX, File E19180 up to 20 A, CSA Certified, Class 1422-01, File 53787 up to 20 A. UL Recognized, Guide JDYX2, File E19180, 25-30 A, CSA Component Acceptance, Class 1422-30, 25-30 A, RoHS compliant, CE Features Catalog no. (amps)* MDQ-1/100 MDQ-3/10 MDQ-1-1/2 MDQ-5 MDQ-1/32 MDQ-3/8 MDQ-1-6/10 MDQ-6 MDQ-1/16 MDQ-4/10 MDQ-1-8/10 MDQ-6-1/4 MDQ-1/10 MDQ-1/2 MDQ-2 MDQ-7 • Ceramic body for higher amp/volt ratings • Inventory consolidation by replacing MDL fuses allows for reduced SKU investment and minimizing potential for misapplying fuse Typical applications MDQ-1/8 MDQ-6/10 MDQ-2-1/4 MDQ-7-1/2 MDQ-15/100 MDQ-3/4 MDQ-2-1/2 MDQ-8 MDQ-175/1000 MDQ-8/10 MDQ-2-8/10 MDQ-9 MDQ-3/16 MDQ-1 MDQ-3 MDQ-10 MDA-1/4-R MDA-2-R MDA-6-R MDA-15-R MDA-1/2-R MDA-2-1/2-R MDA-7-R MDA-20-R MDQ-2/10 MDQ-1-2/10 MDQ-3-2/10 MDQ-12 MDQ-1/4 MDQ-1-1/4 MDQ-4 MDQ-15 * To order axial leads, place “V” in catalog number. E.g., MDQ-V-1-1/4. • Electronic circuits Catalog no. (amps)* MDA-3/4-R MDA-3-R MDA-8-R MDA-25 A-R MDA-1-R MDA-4-R MDA-10-R MDA-30 A-R MDA-1-1 /2-R MDA-5-R MDA-12-R * To order axial leads, place “V” in catalog number. E.g., MDA-V-1-1/2-R. Data sheet no. 2044 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Data sheet no. 2002 Eaton.com/bussmannseries 3-11 3 — Electronic, PCB and small dimension fuses H15-V vertical mount 5 mm fuse holder with threaded cap H15-H horizontal mount 5 mm fuse holder with threaded cap 2011/65/EU Ratings HTC-60M four-leg stand-off mount 5 mm fuse holder 2011/65/EU Ratings 2011/65/EU Ratings • Volts 250 Vac • Volts 250 Vac • Volts 250 Vac • Amps 10 A (cURus and VDE) • Amps 10 A (cURus) 6.3 A (VDE) • Amps 6.3 (cURus and VDE) • Temperature rise 41°C • Temperature rise 41°C Agency information • • Agency information Agency information cURus Recognized, Guide IZLT2/IZLT8, File E14853 • VDE File 40039714 • Materials cURus Recognized, Guide IZLT2/IZLT8, File E14853 VDE File 40039714 Tin-plated clip • Tin-plated clip • Tin-plated copper terminals • Tin-plated copper terminals • Thermoplastic body (UL 94V0, glow wire test: 960°C per IEC 695-2-1) • Thermoplastic body (UL 94V0, glow wire test: 960°C per IEC 695-2-1) Carton qty. Catalog no. Carton qty. BK-H15-V-1 200 BK-H15-H-1 200 BK1-H15-V-1 1000 BK1-H15-H-1 1000 BK-H15-V-1-B 100 holder body only BK-H15-H-1-B 100 holder body only BK-H15-V-1-K 100 holder cap only BK-H15-H-1-K 100 holder cap only Dimensions - in (mm) FU Printed circuit board Mounting holes 0.512 (13) 1.303 (33.1) SE FU SE 0.461 (11.7) VDE File 4004459 Printed circuit board Tin-plated brass terminals Catalog no. Qty. HTC-60M 10 BK-HTC-60M 100 (bulk) Dimensions - in (mm) Catalog no. 0.512 (13) • • • 1.303 (33.1) cURus Recognized, Guide IZLT2/IZLT8, |File E14853 Materials Materials Dimensions - in (mm) • 0.461 (11.7) 0.354 (9) 0.886 (22.5) 0.551 (14) 0.138 (3.5) Mounting holes Ø 0.102 Ø 0.051 (1.3) (2.6) Mounting holes Ø 0.051 ± 0.002 (Typ.) (1.03 ± 0.05) 0.394 (10.0) Ø 0.051 ± 0.002 (Typ.) (1.03 ± 0.05) 0.394 (10.0) Data sheet no. 4426 3-12 Data sheet no. 4426 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 0.591 (15) Data sheet no. 2110 Eaton.com/bussmannseries HBH-I (1/4" x 1-1/4˝) and HBH-M (5x20 mm) horizontal mount fuse holders HBV-I (1/4" x 1-1/4˝) and HBV-M (5x20 mm) vertical mount fuse holders with stability pins HBW-I (1/4" x 1-1/4˝) and HBW-M (5x20 mm) vertical mount fuse holder without stability pins Dimensions - in (mm) Dimensions - in (mm) Dimensions - in (mm) 0.51 0.51 (13.0) (13.0) 0.531 0.531 (13.5) HBW HBV (13.5) 1.855 (47.0) 0.2 1.855 (47.0) (5.0) 0.2 (5.0) 0.04 0.580 (14.9 Ratings UL 16 A/250 V • CSA 12 A/250 V • VDE 6.3 A/250 V • SEMKO 10 A/250 V 0.1 (2.54) Ø, 4 UL Recognized, Guide IZLT2, File EI4853, CSA Certified, Class 6225-01, File 47235, VDE 4009241 (HBV, HBW), SEMKO 800444, CE (10.0) 0.580 0.05 (1.3) Ø, 2 (14.9 Replacement fuse caps • High dielectric molded phenolic with a UL 94V0 flammability rating FBI and FBM fuse caps fit PCB fuse holders HBH-_, HBV-_ and HBW-_. • Fuse carrier and knob: spring-loaded, bayonet-type, tin-plated brass with screwdriver slot To order, specify Catalog numbers: Mounting Agency information • 0.05 (1.3) Ø, 2 0.4 (1.05) (10.0) Material • 0.04 0.4 (1.05) • “Kicked” terminals (all) and stability pins on HBV and HBW • Temperature rating (RTI): body 150ºC, knob 130ºC • FBI for 1/4" diameter fuses • FBM for 5 mm diameter fuses Electrical • Insulation resistance 10 MΩ 500 Vdc • Contact resistance less than 0.005 Ω @ 200mV • Dielectric strength over 200 V/mil FBI FBM Data sheet no. 2118 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 3-13 Electronic, PCB, small dimension fuses Electronic, PCB and small dimension fuses — 3 3 — Electronic, PCB and small dimension fuses HTC-15M, HTC-140M 5 mm fuse holder and snapon cover Ratings • 1A3399 low profile 5 mm fuseclips with end stops and straight leads 0.225" 0.125" 250 V / 6.3 A / 1.6 W 2011/65/EU (5.7mm) (3.2mm) 0.030" (1.6mm) 0.060" 0.125" 0.254" 0.188" (3.2mm) (1.6mm) (2.9mm) Agency information (1.5mm) 0.062" 0.115" 0.237" (6.5mm) (6.0mm) • cURus, Guide 1ZLT2 and IZLT8, File E14853 • VDE 40004458 Catalog no. Material* Finish RoHS compliant 1A3399-01 BeCu Silver 1A3399-04-R BeCu Bright tin 1A3399-10-R Copper alloy Bright tin • 1.047" 0.345" (26.6mm) (9.0mm) 2011/65/EU HTC-140M Cover 0.571" (14.5mm) (4.8mm) * BeCu recommended for more than 15 A. 0.217 " (5.5mm) 0.531" Mounting Holes (13.5mm) 1A5018 high profile 5 mm fuseclips with end stops and straight leads 0.890" (22.60mm) 0.866" (22.0mm) _ 0.002" Dia. (Typ.) 0.059" + 0.177" (1.50 _+ .05mm) (4.5mm) 0.180" (4.57mm) 0.440" Catalog no. Description HTC-15M Holder only HTC-140M Holder with natural color cover HTC-150M* Holder with transparent cover 0.319" 0.50" (8.1mm) (12.7mm) 2011/65/EU BUSS BUSS BUSS 0.61" 0.157" (3.99mm) 0.929" 0.031" 0.217" (5.5mm) Catalog no. Material* Finish 1A5018-07 Copper alloy Silver 1A5018-10-R Copper alloy Bright tin 1A5601 5 mm fuseclip (≤ 7 A) 0.246" 2011/65/EU (8.73mm + 0.38mm) 0.50" 0.50" 0.141" + 0.015" (12.7mm) (3.58mm + 0.38mm) 0.022" + 0.002" 0.060" 0.266" (1.5mm) (6.75mm) 0.032" + 0.002" (0.56mm + 0.05mm) HTC-200M AP/HTC-200M Tin-plated bronze (6.35mm) 0.344" + 0.015" 0.012" (0.3mm) Material 0.250" (6.3mm) (8.73mm + 0.38mm) (12.7mm) Catalog no. (5.84mm) (4.6mm) 0.344" + 0.015" (23.6mm) (15.5mm) (0.79mm) 0.230" 0.180" (3.7mm) * BeCu 1A3399 fuseclips recommended for more than 15 A. HTC-200M 5 mm fuseclip 0.177" 0.140" 0.047" (1.2mm) * Available in bulk only, order BK/HTC-150M. (4.5mm) 2011/65/EU (11.2mm) Description Tape and fan fold pack Ammo pack 1000 pieces per box (0.81mm + 0.05mm) Catalog no. Material Finish 1A5601 Cartridge brass Bright tin 1A5602 fuseclip with end stops (≤ 7 A) HTC-210M 5 mm fuseclip with end stops 0.219" (5.57mm) 4.32mm 2.54mm 6.26mm 8.73mm 2.85mm Catalog no. HTC-210M AP/HTC-210M Material Tin-plated bronze Data sheet no. 2110 3-14 2.29mm 0.500" 0.250" (12.70mm) 2.54mm (6.35mm) 0.140" (3.56mm) 0.093" 3.91mm 6.22mm 2011/65/EU 2011/65/EU 1.46mm 0.216" (5.48mm) 2.54mm Description Tape and fan fold pack Ammo pack 1000 pieces per box (2.36mm) LEGS TO FIT IN 0.052" (1.3mm) DIA. HOLES ON CENTER 0.047" (1.19mm) Catalog no. Material Finish 1A5602 Cartridge brass Bright tin Data sheet no. 2131 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Electronic, PCB and small dimension fuses — 3 1A1119 1/4" fuseclips with end stops and angledin leads 0.285" (7.24mm) 2011/65/EU 0.420" (10.67mm) 1A3398 PCB 1/4" fuseclips without end stops with straight leads (6.5mm) 2011/65/EU 0.245" 0.255" (6.2mm) 0.155" (3.94mm) 0.41" (10.4mm) 0.28" 0.102" Dia. 0.250" (6.5mm) 0.290" (7.4mm) 0.360" (9.14mm) 0.155" (3.9mm) 0.080" (2.03mm) 0.06" (1.5mm) 0.32" 0.14" (7.1mm) (2.6mm) 0.280" (3.6mm) (7.1mm) Material* Finish Catalog no. Material Finish 1A1119-04-R 1A1119-05 High performance copper Bright tin 1A3398-07-R Cartridge brass Bright tin High performance copper Silver 1A1119-10-R Cartridge brass Bright tin * High performance copper recommended for more than 15 A. 1A1120 1/4" fuseclips without end stops or angled-in leads 0.272” [6.91] 0.250” [6.35] 0.245" 2011/65/EU 2011/65/EU (6.2mm) 0.155" C L Ø 0.130”±.003 [3.3mm±0.08] 0.255" (6.5mm) 0.290”±.010 [7.37±0.25] 0.060" 0.228" 0.150" (3.81mm) (1.5mm) 0.363”±.003 [9.22±0.08] Material* (2.6mm) (10.4mm) 0.187” [4.75] 0.312” [7.92] 0.155”±.010 [3.94±0.25] 0.102" (3.94mm) 0.410" 0.400”±.010 [10.16±0.25] 0.080” [2.03] 0.320” [8.13] Catalog no. 1A4533 1/4" fuseclips without end stops or angled out leads (5.79mm) 0.323" 0.280" 0.320" (7.11mm) (8.13mm) (8.20mm) Finish Catalog no. Material* Finish 1A4533-01-R High performance copper Bright tin 1A4533-06-R Cartridge brass Bright tin 1A1120-02 Cartridge brass None/bright dipped 1A1120-05 High performance copper Silver 1A1120-06-R High performance copper Bright tin 1A1120-09-R Cartridge brass Bright tin * High performance copper recommended for more than 15 A. * High performance copper recommended for more than 15 A. 1A1907 1/4" fuseclips with end stops and straight leads 0.245" 0.255" (6.5mm) (6.2mm) 0.410" (10.4mm) 0.060" (1.5mm) 0.320" (2.6mm) 2011/65/EU 0.245" (3.94mm) 0.102" Dia. 0.140" 0.280" 2011/65/EU 0.155" 1A4534 1/4" fuseclips with end stops and angled out leads (6.2mm) 0.155" (3.94mm) 0.410" 0.280" (10.4mm) (7.1mm) 0.255" (3.6mm) (7.1mm) (6.5mm) (8.13mm) 0.06" 0.226" 0.150" (3.81mm) (1.5mm) Catalog no. Material* Finish 1A1907-02 Cartridge brass None/bright dipped 1A1907-03-R High performance copper Bright tin 1A1907-05 High performance copper Silver 1A1907-06-R Cartridge brass Bright tin (5.74mm) 0.321" 0.32" (8.13mm) 0.102" (2.6mm) 0.28" (7.11mm) (8.15mm) Catalog no. Material* Finish 1A4534-01-R High performance copper Bright tin 1A4534-06-R Cartridge brass Bright tin * High performance copper recommended for more than 15 A. * High performance copper recommended for more than 15 A. Data sheet no. 2131 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 3-15 Electronic, PCB, small dimension fuses (8.13mm) Catalog no. 3 — Electronic, PCB and small dimension fuses 5681 and 5682 1/4" fuseclips with mounting holes ØF 0.470" ØF D C B (11.94mm) End stop C 0.080" BeCu 5682-01 Finish B C D E ØF Ref. Silver † 0.265 0.41 0.32 0.132 Fig. 1 0.262 0.41 0.32 0.132 Fig. 2 5682-11-R 0.108 BeCu Silver BeCu Bright tin 0.131 (3.61mm) 1A3400-09 and 1A3400-10 Catalog no. Clip mat. Finish 1A3400-09-R Copper-clad steel Bright tin 20 1A3400-10-R Copper-clad steel Silver 30 Data sheet no. 2131 0.106 † Hole in center of both clip and contact area. Data sheet no. 2132 5674 PCB fuseclips with mounting holes for 9/32˝ dia. fuses ØF B End stop C D 2011/65/EU E Figure 1 Catalog no. Dimensions - in Clip mat. Finish B C D E ØF Ref. 0.38 0.172 Fig. 1 With end stop 5674-01 5674-10 Silver BeCu 0.168 0.356 0.52 Bright tin Data sheet no. 2132 5960 PCB fuseclips with mounting holes for 13/32˝ dia. fuses ØF B C End stop 2011/65/EU D E Figure 1 Catalog no. Clip mat. Dimensions - in Finish B C D E 0.387 0.71 0.47 ØF Ref. With end stop 5960-07 5960-09 BeCu 0.168 Silver 0.2 0.196 0.172 Fig. 1 Data sheet no. 2132 5592 PCB fuseclips with mounting holes for 9/16˝ dia. fuses ØF 2011/65/EU D C E Figure 1 Catalog no. Clip mat. Dimensions - in Finish B C D E ØF Ref. Silver 0.252 0.56 0.875 0.6 0.2 Fig. 1 Without end stop 5592-01 BeCu Data sheet no. 2132 3-16 2011/65/EU 0.142" Dia. (9.65mm) 0.470" (11.94mm) With end stop 5682-02 0.380" (2.03mm) Figure 2 Dimensions - in Clip mat. (1.27mm)(11.1mm) 0.218" (5.54mm) Without end stop 5681-01 (18.03mm) E Figure 1 0.050" 0.437" 0.710" 2011/65/EU D E Catalog no. 1A3400 fuseclips with end stops and straight leads for 13/32˝ dia. fuses BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Max amps High speed fuses — 4 Contents Fuses Accessories British Standard BS88 fuses Volts Amp range Catalog symbol/size 500 Vac/dc 50 to 400 CHSF 3 600 Vac/450 Vdc 1 to 600 DFJ 4 130 Vac/dc 150 Vac/dc 250 Vac/dc 500 Vac/dc 600 Vac 600 Vac 700 Vac/dc 1000 Vac/800 Vdc Modular fuse blocks 1000 to 4000 70 to 1000 35 to 2500 35 to 1600 1 to 1000 35 to 800 5 to 1200 35 to 2000 FWA FWA FWX FWH KAC KBC FWP FWJ 5 6 7 8 9 10 11-12 13 14 LCT, LET LMT, LMMT CT, ET, FE, EET and FEE FM, FMM, MT and MMT 15 16 17-18 19-20 21 240-250-280 Vac/150 Vdc 6 to 180 240-250 Vac/150 Vdc 160 to 900 690-700 Vac/500 Vdc 6 to 200 690-700 Vac/350-450-500 Vdc 160 to 710 Trip indicators, clips and microswitches Fuses Accessories Section page Continued next page Lead the charge with compact designs Bussmann series 50-400 amp compact high speed fuses use up to 48% less enclosure space BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-1 High speed fuses Fuse type Compact high speed fuses Fuses UL Class J full range drive fuse Fuses North American fuses 4 — High speed fuses Contents Fuse type Ferrule Fuses Accessories Volts Amp range Catalog symbol/size 150 Vac/dc 5 to 30 FWA-_A10F (10x38mm) 150 Vac/dc 35 to 60 FWA-_A21F (21x51mm) 250 Vac/dc 1 to 50 FWX (14x51mm) 500 Vac 0.25 to 30 FWH-_A6F (6x32mm) 500 Vac/dc 1 to 30 FWH-_14F (14x51mm) 600-700 Vac/700 Vdc 1 to 32 FWC (10x38mm) 690 Vac 4 to 32 FWP-_G10F (10x38mm) 690-700 Vac/600-700 Vdc 1 to 50 FWP-_A14F (14x51mm) 690 Vac 4 to 50 FWP-_G14F_ (14x51mm) 700 Vac/dc 20 to 100 FWP-_A22F (22x58mm) 690 Vac 20 to 100 FWP-_G22F_ (22x58mm) 750 Vdc 5 to 30 FWK-_A20F (20x127mm) 750 Vdc 35-60 FWK-_A25F (25x146mm) 1000 Vac/800 Vdc 20 to 30 FWJ (14x67mm) 1200 Vac/1000 Vdc 20 to 30 FWL (20x127mm) 1400-2000 Vac/1000 Vdc 2 to 15 FWS (20x127mm) J70032 700 V panel mount block for FWP 14x51mm fuses JM70100 700 V DIN-Rail/panel mount modular blocks for FWP 22x58mm fuses CHM modular holders for FWA and FWC 10x38mm fuses CH14 modular holders for FWX, FWH and FWP 14x51mm fuses CH22 modular holders for FWP 22x58mm fuses Section page 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 Square body DIN 43653 DIN 43620 French style US style Flush-end contact Accessories 690-700 Vac/ 700 Vdc 690-700 Vac 1000 Vac 1000 Vac 1250-1300 Vac 690 Vac 10 to 400 40 to 2000 20 to 315 50 to 1400 50 to 1400 10 to 800 690-700 Vac 10 to 1600 1000 Vac 690-700 Vac 690-700 Vac 1000 Vac 1250-1300 Vac 690 Vac 690-700 Vac 1000 Vac 1250-1300 Vac 690-700 Vac 1000 Vac 1250 Vac 660 Vac 1250 Vac 690 Vac 1000 Vac Fixed center blocks for DIN 43653 fuses Indicators Microswitches 20 to 225 40 to 1600 40 to 2000 50 to 1400 50 to 1400 25 to 400 40 to 2000 50 to 1400 50 to 1400 1000 to 4000 1000 to 3000 800 to 2500 1000 to 4000 630 to 2800 2000 to 7500 2000 to 5000 170M — size 000 and 00 170M — size 1* to 3 170M — size 00 170M — size 1* to 3 170M — size 1* to 3 170M — size 00 to 3 170M — size 000 to 3 dual indicator 170M — size 00 170M — size 1* to 3 170M — size 1* to 3 170M — size 1* to 3 170M — size 1* to 3 170M — size 00 170M — size 1* to 3 170M — size 1* to 3 170M — size 1* to 3 170M — size 4 170M — size 4 170M — size 4 170M — size 23 170M — size 23 170M — size 24 170M — size 24 750-800 Vdc 1000 Vdc 25 to 630 25 to 500 170M — size 000 and 230 170M — size 000 and 230 38-39 40-41 42 43-44 45-46 47-48 49-50 51 52-53 54-55 56-57 58-59 60 61-62 63-64 65-66 67-68 69 70 71-72 73 74 75 76-77 78 78 IGBT fuses Fuses 4-2 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 79-80 81-82 High speed fuses — 4 CHSF — UL compact high speed fuse Features 500 Vac/dc (UL), 50 to 400 A • Requires up to 48% less enclosure space to help reduce the overall assembly size • Innovative design allows for a significantly smaller package without compromising heat rise performance, preventing extensive equipment redesign • Global acceptance with UL, CSA, IEC and RoHS for products sold worldwide Ratings • Bolt-on design provides design flexibility for installation in fuse blocks or direct mounting on busbars Volts • Meets JASO D622 spec for thermal shock, humidity, and vibration • Superior current cycling performance helps withstand demanding applications 2011/65/EU Bussmann™ series compact high speed fuses feature spacesaving case sizes for protecting semiconductor devices up to 500 Vac/dc in ratings from 50 to 400 amps. • 500 Vac/dc (UL) • Amps 50-400 A • Interrupting rating Recommended fuse blocks • Max AC – 200 kA • Min AC 400% • Max DC – 50 kA • Min DC 800% Up to 100 amps Catalog no. AWG wire size Stud size BH-0111 14-2/0 Cu 1/4-20 BH-0112 14-2/0 Cu 5/16-18 BH-0121 (2) 14-1/0 Cu 1/4-20 BH-0122 (2) 14-1/0 Cu 5/16-18 1BS101 14-2/0 Cu 1/4-20 x 1/2 See data sheet no. 1200 (BH-01_) and 1206 (1BS101) for details. Operating class aR Agency information Up to 400 amps • UL Recognized, Guide JFHR2, File E56412 • CSA Component Acceptance, Class 1422-30, File 53787 • IEC aR (self certified) • RoHS compliant • CE Catalog no. AWG wire size Stud size BH-1131 6-250kcmil Cu 1/4-20 BH-1132 6-250kcmil Cu 5/16-18 1BS102 6-250kcmil Cu 1/4-20 x 1/2 See data sheet no. 1201 (BH-11_) and 1207 (1BS102) for details. Watts loss / percent of rated current Catalog no. CHSF-50 CHSF-60 CHSF-70 CHSF-80 CHSF-100 CHSF-125 CHSF-150 Amps 50 60 70 80 100 125 150 CHSF-175 CHSF-200 CHSF-225 CHSF-250 CHSF-300 CHSF-350 CHSF-400 AC/DC I2t (A2s) pre-arcing 304 438 596 778 1216 2042 2941 175 200 225 250 300 350 400 AC* I2t (A2s) total clear 1875 2700 3675 4800 7500 12,721 18,318 DC** I2t (A2s) total clear 935 1346 1833 2394 3740 6465 9309 24,933 32,566 48,028 59,293 85, 382 116,215 151,791 12,671 16,550 21,278 26,270 37,828 51,488 67,250 4003 5228 6835 8438 12,151 16,539 21,603 * @ 200 kA/500 Vac. ** @ 50 kA/500 Vdc. A 81 92 92 @ 50% 3.8 4.5 5.3 6.1 7.6 12.0 14.3 1.3 1.5 1.8 2.0 2.5 3.6 4.3 16.7 19.1 26.1 29.0 34.8 40.6 46.4 5.1 5.8 7.0 7.8 9.4 10.9 12.5 H A G Dimensions — mm Amps 50-100 125-200 225-400 @ 80% B 20 25 30 C 40 53 53 D1 61 77 74 D2 57 68 68 E 8.7 8.7 8.7 F 16 19 25 G 7.7 7.8 9.0 H 3.2 3.2 4.8 C E F B D2 D1 Data sheet no. 10414 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-3 High speed fuses • 4 — High speed fuses DFJ — UL Class J full range high speed fuse 600 Vac/450 Vdc (UL), 1 to 600 A UL Class J high speed, full range current-limiting fuses provide maximum protection for AC and DC drives and controllers. The UL Class J Bussmann series DFJ fuse has the lowest I2t of any branch circuit fuse to protect power semiconductor devices that utilize diodes, GTOs, SCRs and SSRs. The DFJ fuse combines the performance of high speed fuses in a full range Class J branch circuit package, allowing the use of readily available Class J fuse blocks, holders and switches. The DFJ uses standard Class J holders and blocks. See section 8 for available catalog numbers. Ratings • Volts • 600 Vac (UL) • 450 Vdc (UL 15-600 A) Catalog no. I2t (A2Sec) @ 600 Vac/100 kA Amps Pre-arc Clearing Watts loss* • Amps 1-600 A DFJ-1 1 — — — • IR DFJ-2 2 — — — • 200 kA RMS Sym. DFJ-3 3 — — — • 100 kA DC DFJ-4 4 — — — DFJ-5 5 — — — Operating class gR Agency information DFJ-6 6 — — — DFJ-8 8 — — — DFJ-10 10 — — — • UL Listed, Std 248-8, Class J, Guide JDDZ, File E4273 DFJ-12 12 — — — • CSA Certified, C22-2 No 248.8, Class 1422-02, File 53787 DFJ-15 15 4 110 4.1 • CE DFJ-17.5 17.5 — — — DFJ-20 20 8 365 4.0 DFJ-25 25 12 610 4.9 DFJ-30 30 20 1000 5.5 Dimensions — in 2.38 2.25 0.50 0.63 0.81 1 to 30A 1.06 35 to 60A 4.63 3.63 1.13 0.75 2.63 1 0.43 0.28 .13 70 to 100A 5.75 4.38 1.13 0.28 3.0 1.63 1.38 0.43 0.19 110 to 200A 7.13 5.25 3.38 0.41 1.63 0.58 2.11 1.88 0.25 225 to 400A 55 1100 6.8 90 1900 8.6 DFJ-50 50 140 2800 8.7 DFJ-60 60 290 6000 8.5 DFJ-70 70 450 3100 12 DFJ-80 80 650 4600 13 DFJ-90 90 1010 7200 13 DFJ-100 100 1460 10,500 13 DFJ-110 110 1710 9500 17 DFJ-125 125 3580 20,000 15 DFJ-150 150 5080 28,000 19 DFJ-175 175 6310 35,000 23 DFJ-200 200 9850 54,500 24 DFJ-225 225 11,420 51,000 29 DFJ-250 250 17,000 74,500 30 DFJ-300 300 23,500 103,000 36 8.0 DFJ-350 350 38,800 170,000 39 DFJ-400 400 62,200 272,000 40 DFJ-450 450 44,600 270,000 56 DFJ-500 500 79,500 480,000 52 DFJ-600 600 138,000 830,000 57 0.53 2.13 450 to 600A Data sheet no. 1048 4-4 35 40 6.0 3.75 2 0.74 DFJ-35 DFJ-40 2.5 0.38 † Watts loss at rated current. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 FWA — North American 130 Vac/dc (UL), 1000 to 4000 A North American style flush-end high speed fuses for the protection of DC common bus, DC drives, power converters/rectifiers and reduced rated voltage starters. Ratings • Volts 130 Vac/dc • Amps 1000-4000 A • IR • 200 kA RMS Sym at 130 Vac • 50 kA at 130 Vdc • UL Recognized, JFHR2, E91958 on 1000-2000 A fuses • CE I²t (A²s) Rated voltage 130 Vac/dc (UL) Rated current (amps) 1000 1200 1500 2000 2500 3000 4000 Pre-arcing 170,000 270,000 520,000 860,000 1,500,000 2,100,000 3,400,000 Clearing at 130 Vac 460,000 730,000 1,400,000 2,400,000 4,100,000 5,700,000 9,200,000 Watts loss (W)† 60 70 78 108 130 150 257 Catalog no. FWA-1000AH FWA-1200AH FWA-1500AH FWA-2000AH FWA-2500AH FWA-3000AH FWA-4000AH † Watts loss at rated current. Dimensions — in 4000 A 1000-3000 A Amp range 1000 to 2000 2500 to 3000 4000 B 2.0 3.0 3.5 C 1.0 1.5 1.5 D — — 1.5 Thread / depth 3/8-24 x 1/2” UNF 1/2-20 x 1/2” UNF 1/2-20 x 1/2” UNF 1” = 25.4mm For details on electrical characteristics, contact Application Engineering and ask for data sheets: 720001, 5785301 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-5 High speed fuses Agency information 4 — High speed fuses FWA — North American 150 Vac/dc (UL), 70 to 1000 A North American style bolted tag high speed fuses used for the protection of DC common bus, DC drives, power converters / rectifiers and reduced rated voltage starters. Ratings Volts • • 150 Vac/dc (UL) • 80 Vdc 1000 A only • Amps 70-1000 A • IR • 100 kA RMS Sym. (70-400 A) • 200 kA RMS Sym. (450-1000 A) • 20 kA at 150 Vdc (70-800 A) • 100 kA at 80 Vdc (70-1000 A) Agency information • UL Recognized JFHR2, E91958 • CE I²t (A²s) Rated voltage Rated current (amps) 70 80 100 125 150 200 250 300 350 400 500 600 700 800 1000 150 Vac/dc (UL) 80 Vdc Pre-arcing 470 670 1200 1870 2700 4780 7470 10,760 15,700 20,300 39,000 46,000 75,000 92,000 170,000 Clearing at 150 Vac 4000 6000 12,000 18,000 26,000 45,000 70,000 100,000 140,000 180,000 120,000 140,000 220,000 280,000 510,000 Watts loss (W)† 6.9 7.7 9.0 11.2 13.5 17.6 22.5 27.0 30.6 35.2 35.0 47.0 49.0 58.0 60.0 Catalog no. FWA-70B FWA-80B FWA-100B FWA-125B FWA-150B FWA-200B FWA-250B FWA-300B FWA-350B FWA-400B FWA-500A FWA-600A FWA-700A FWA-800A FWA-1000A † Watts loss at rated current. Dimensions — mm 24.21 Ø 11.24 88.3 19.4 31.8 6.35 19.05 8.95 25.4 28.36 3.24 49.06 65.75 11.0 48.7 38.5 Ø 65.5 70-400 A 500-1000 A For details on electrical characteristics, contact Application Engineering and ask for data sheets: 720002, 5785310 4-6 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 FWX — North American 250 Vac/dc (UL), 35 to 2500 A North American style bolted tags and flush-end high speed fuses for the protection of DC common bus, DC drives, power converters/ rectifiers and reduced rated voltage starters. Ratings • Volts 250 Vac/dc (UL) • Amps 35-2500 A • IR 200 kA RMS Sym. • 20 kA at 250 Vdc (35-800 A) Rated voltage Agency information • UL Recognized, JFHR2, E56412 • CSA Class 1422-30, (53787) on 35-800 A fuses (20 kA IR at 250 Vdc) • CE Dimensions — in A D E C H G F B J 250 Vac/dc (UL) 35-800 A A A D C B C B 1000-1200 A 1500-2500 A Amp range 35-60 Thread A B C D E F G H J / depth 3.19 0.81 1.59 2.59 2.25 0.34 0.63 0.13 0.52 — 70-200 3.13 1.22 1.59 2.44 2.19 0.34 1.00 0.19 0.47 225-600 3.84 1.50 1.59 2.94 2.25 0.41 1.00 0.25 0.75 — 700-800 3.84 2.00 1.59 3.03 2.28 0.41 1.50 0.25 0.78 — 1000-1200 2.59 3.00 1.50 — — — — — — 1500-2500 2.59 3.50 1.50 1.50 — — — — — Rated current (amps) 35 40 45 50 60 70 80 90 100 125 150 175 200 225 250 275 300 350 400 450 500 600 700 800 1000 1200 1500 1600 2000 2500 Prearcing 50 60 80 100 140 330 430 570 740 1130 1620 2170 2790 3210 3960 4720 6000 10,600 14,500 22,100 28,000 41,100 48,800 59,000 44,000 92,000 120,000 160,000 320,000 670,000 Clearing at 250 Vac 230 310 390 520 740 1400 1850 2450 3150 4850 6950 9300 12,000 14,700 18,100 21,600 27,300 48,600 66,100 101,000 128,000 188,000 190,000 230,000 360,000 750,000 880,000 1,200,000 2,300,000 4,700,000 Watts loss (W)† 4.2 5.2 5.7 6.0 8.1 7.2 8.1 9.0 10.0 12.5 15.7 18.5 22.0 24.0 27.0 31.0 32.0 39.0 44.0 49.0 54.0 62.0 72.0 84.0 100.0 103.0 140.0 140.0 151.0 163.0 Catalog no. FWX-35A FWX-40A FWX-45A FWX-50A FWX-60A FWX-70A FWX-80A FWX-90A FWX-100A FWX-125A FWX-150A FWX-175A FWX-200A FWX-225A FWX-250A FWX-275A FWX-300A FWX-350A FWX-400A FWX-450A FWX-500A FWX-600A FWX-700A FWX-800A FWX-1000AH FWX-1200AH FWX-1500AH FWX-1600AH FWX-2000AH FWX-2500AH † Watts loss at rated current. — 3/8-24 x 1/2” UNF 1” = 25.4mm For details on electrical characteristics, contact Application Engineering and ask for data sheets:720005, 359 (35-800 A), 5785299 (100-2500 A) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-7 High speed fuses I²t (A²s) • 4 — High speed fuses FWH — North American 500 Vac/dc (UL), 35 to 1600 A North American style bolted tags high speed fuses, for the protection of DC common bus, power converters/rectifiers and reduced rated voltage starters. Ratings • Volts • 500 Vac (UL) • 500 Vdc (35-800 A only) • Amps 35-1600 A • IR • 200 kA RMS Sym. • 50 kA at 500 Vdc I²t (A²s) Agency information • UL Recognized, JFHR2, E91958, FWH-_B (35-200 A) and FWH-_A (1000 and 1200 A), JFHR2, E56412 FWH-_A (225-800 A) • CSA Class 1422-30, File 53787 (35-1600 A) • CE Dimensions — in A D E C H G F B J 35-1200 A 10.22 8.97 8.71 6.22 5.22 4.25 Ø 1.75 3.5 1.625 3.22 Rated current Rated voltage (amps) 35 40 45 50 60 70 80 500 Vac/dc (UL) 90 100 125 150 175 200 225 250 275 300 325 350 500 Vac/dc (UL) 400 450 0.625 0.75 1400-1600 A Amp range 35-60 70-100 125-200 225-400 A 3.19 3.62 3.62 4.34 B 0.81 0.95 1.16 1.50 C 1.59 1.74 1.84 2.09 450-600 4.34 2.00 2.09 700-800 6.34 2.50 2.09 1000-1200 6.97 3.00 3.22 1400-1600 1” = 25.4mm D 2.54 2.85 2.89 3.44 E 2.19 2.81 2.77 2.75 F 0.34 0.35 0.34 0.41 G 0.72 0.75 1.00 1.00 H 0.13 0.13 0.19 0.25 J 0.52 0.38 0.41 0.75 3.53 4.97 5.47 Refer 2.78 0.41 1.50 0.25 0.78 3.44 0.53 2.00 0.38 1.30 4.48 0.62 2.38 0.44 1.12 to drawing 500 Vac (UL) 500 600 700 800 1000 1200 1400 1600 Prearcing 34 76 105 135 210 210 305 360 475 800 1100 1450 1900 4600 6300 7900 9800 13,700 14,500 19,200 24,700 Clearing at 500 Vac 150 320 450 670 900 900 1400 1600 2000 3500 4600 6200 8500 23,300 32,200 40,300 49,800 63,800 72,900 96,700 127,000 29,200 149,000 41,300 206,000 55,000 298,000 76,200 409,000 92,000 450,000 122,000 600,000 200,000 1,000,000 290,000 1,400,000 Watts loss (W)† 8.0 7.5 7.5 7.5 9.9 10.6 12.7 15.0 17.0 25.0 30.0 35.0 40.0 39.0 41.0 46.0 51.0 53.0 58.0 65.0 74.0 Catalog no. FWH-35B FWH-40B FWH-45B FWH-50B FWH-60B FWH-70B FWH-80B FWH-90B FWH-100B FWH-125B FWH-150B FWH-175B FWH-200B FWH-225A FWH-250A FWH-275A FWH-300A FWH-325A FWH-350A FWH-400A FWH-450A 84.0 108.0 120.0 129.0 145.0 180.0 210.0 230.0 FWH-500A FWH-600A FWH-700A FWH-800A FWH-1000A FWH-1200A FWH-1400A FWH-1600A † Watts loss at rated current. For details on electrical characteristics, contact Application Engineering and ask for data sheets: 720007, 360 (225-800 A), 5785304 (35-200 A, 1000-1600 A) 4-8 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 KAC — North American 600 Vac (UL), 1 to 1000 A North American style bolted tags high speed fuses. These fuses are supplied as replacements only. For new installations, Eaton recommends the 700 V FWP. See page 4-11. Ratings • Volts 600 Vac • Amps 1-1000 A • IR 200 kA RMS Sym. Agency information UL Recognized, JFHR2, E56413 (1-600 A only) • CE Rated voltage 600 Vac (UL) Rated current (amps) Catalog no. 1 KAC-1 2 KAC-2 3 KAC-3 4 KAC-4 5 KAC-5 6 KAC-6 7 KAC-7 8 KAC-8 9 KAC-9 10 KAC-10 12 KAC-12 15 KAC-15 17.5 KAC-17.5 20 KAC-20 25 KAC-25 30 KAC-30 35 KAC-35 40 KAC-40 45 KAC-45 50 KAC-50 60 KAC-60 70 KAC-70 80 KAC-80 90 KAC-90 100 KAC-100 110 KAC-110 125 KAC-125 150 KAC-150 175 KAC-175 200 KAC-200 225 KAC-225 250 KAC-250 300 KAC-300 350 KAC-350 400 KAC-400 450 KAC-450 500 KAC-500 600 KAC-600 700 KAC-700 800 KAC-800 1000 KAC-1000 Dimensions — in High speed fuses • 1-30 A and 450-1000 A A B2 B3 C D G E F H 35-400 A Amp range A B1 B2 B3 C D 1-30 2.88 2.50 — — 1.88 0.41 35-60 4.38 — 3.75 3.50 2.75 0.63 70-100 5.00 — 4.06 3.66 2.75 0.75 110-200 5.14 — 4.39 3.77 2.91 1.00 225-400 6.18 — 4.82 4.57 3.00 1.63 450-800 6.25 4.75 — 3.06 2.00 1000 7.25 4.75 — 3.06 2.75 1” = 25.4mm E — 0.34 0.41 0.41 0.56 — — F 0.56 0.81 1.00 1.50 2.00 2.50 3.50 G 0.06 0.09 0.13 0.19 0.25 0.25 0.38 H 0.26 0.47 0.61 0.72 0.69 0.56 0.56 Data sheet no. 720009 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-9 4 — High speed fuses KBC — North American 600 Vac (UL), 35 to 800 A North American style bolted tags and flush-end high speed fuses. These fuses are supplied as replacements only. For new installations, Eaton recommends the 700 V FWP fuses. See page 4-11. Ratings • Volts 600 Vac (UL) • Amps 35-800 A • IR 200 kA RMS Sym. Agency information • UL Recognized, JFHR2, E56412 (35-600 A only) • CE Rated voltage 600 Vac (UL) Rated current (amps) 35 40 45 50 60 70 80 90 100 110 125 150 175 200 225 250 300 350 400 450 500 600 800 Catalog no. KBC-35 KBC-40 KBC-45 KBC-50 KBC-60 KBC-70 KBC-80 KBC-90 KBC-100 KBC-110 KBC-125 KBC-150 KBC-175 KBC-200 KBC-225 KBC-250 KBC-300 KBC-350 KBC-400 KBC-450 KBC-500 KBC-600 KBC-800 Dimensions — in A B C D H F E G J 35-60 and 110-600 A 70-100 A 4 1/2-24 x 1/2” 3.75 0.75 2.5 2.859 0.75 800 A Rated current (amps) 35-60 A B C D E F H J 70-100 Refer to drawing 110-200 4.41 3.72 3.59 2.91 0.31 0.88 1.22 0.19 0.38 225-400 5.13 4.19 3.56 2.91 0.41 1.00 1.50 0.25 0.72 450-600 5.13 4.39 3.69 2.88 0.41 1.50 2.00 0.25 0.76 800 Refer to drawing 1” = 25.4mm Data sheet no. 720010 4-10 G 4.38 3.75 3.50 2.75 0.34 0.63 0.81 0.09 0.47 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 FWP — North American 700 Vac/dc (UL), 5 to 1200 A North American style bolted tags high speed fuses for the protection of DC common bus, DC drives, power converters/rectifiers, reduced rated voltage starters. Ratings • Volts 700 Vac/dc (UL) • Amps 5-1200 A • IR • 200 kA RMS Sym. • 50 kA at 700 Vdc (Type A) • 50 kA at 500 Vdc (Type B) Agency information UL Recognized, JFHR2, E91958 FWP-_B (5-100 A, 700-1200 A), JFHR2, E56412 FWP-_A (125-600 A) • CSA Class 1422-30, (53787) on 5-800 A • CE High speed fuses • I²t (A²s) Rated voltage Rated current (amps) 5 10 15 20 25 30 35 40 50 60 70 80 90 100 125 150 175 200 225 250 300 350 400 450 500 600 700 800 900 1000 1200 700 Vac/dc (UL) Pre-arcing 1.6 3.6 10.0 26.0 44.0 58.0 34.0 76.0 135.0 210.0 305.0 360.0 415.0 540.0 1800.0 2900.0 4200.0 5500.0 7700.0 10,500.0 17,600.0 23,700.0 31,000.0 36,400.0 45,200.0 66,700.0 54,000.0 78,000.0 91,500.0 120,000.0 195,000.0 Clearing at 700 Vac 11 22 70 180 320 450 160 320 600 950 2000 2400 2700 3500 7300 11,700 16,700 22,000 31,300 42,500 71,200 95,600 125,000 137,000 170,000 250,000 300,000 450,000 530,000 600,000 1,100,000 Watts loss (W)† 1.5 4.0 5.5 6.0 7.0 9.0 12.0 12.0 12.0 15.5 18.0 21.0 25.0 27.0 28.0 32.0 35.0 43.0 45.0 48.0 58.0 65.0 78.0 94.0 107.0 122.0 125.0 140.0 150.0 170.0 190.0 Catalog no. FWP-5B FWP-10B FWP-15B FWP-20B FWP-25B FWP-30B FWP-35B FWP-40B FWP-50B FWP-60B FWP-70B FWP-80B FWP-90B FWP-100B FWP-125A FWP-150A FWP-175A FWP-200A FWP-225A FWP-250A FWP-300A FWP-350A FWP-400A FWP-450A FWP-500A FWP-600A FWP-700A FWP-800A FWP-900A FWP-1000A FWP-1200A † Watts loss at rated current. For details on electrical characteristics, contact Application Engineering and ask for data sheets: 720012, 5785316 (5-30 A), 361 (125-600 A), 5785308 (35-100 A, 700-1200 A) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-11 4 — High speed fuses FWP — North American 700 Vac/dc (UL), 5 to 1200 A Dimensions — in A D E C H G F B J 5-800 A Amp range 5-30 35-60 70-100 125-200 225-400 450-600 700-800 900-1000 1200 1” = 25.4mm A 2.87 4.38 4.41 5.09 5.09 7.09 6.63 B 0.56 0.81 0.95 1.50 2.00 2.50 2.00 C 1.86 2.75 2.59 2.84 2.84 2.84 2.76 D 2.48 3.71 3.63 4.19 4.28 5.72 5.56 E 2.48 3.31 3.56 3.5 3.53 4.19 5.06 F 0.25 0.34 0.34 0.41 0.41 0.53 0.63 G 0.41 0.73 0.75 1.00 1.50 2.00 1.50 H 0.06 0.13 0.13 0.25 0.25 0.38 0.25 J 0.25 0.54 0.38 0.75 0.78 1.30 0.88 Refer to drawing 0.49 1.03 0.625 1.38 2.75 3.85 3.5 5.15 5.97 7.59 900-1000 A -mm 10.87 9.59 9.34 6.84 5.84 4.25 Ø 3.84 1.62 1.75 3.5 0.62 0.75 1200 A -mm For details on electrical characteristics, contact Application Engineering and ask for data sheets: 720012, 5785316 (5-30 A), 361 (125-600 A), 5785308 (35-100 A, 700-1200 A) 4-12 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 FWJ — North American 1000 Vac /800 Vdc (UL), 35 to 2000 A North American style bolted tags high speed fuses for the protection of DC common bus, DC drives power converters/rectifiers, reduced rated voltage starters and high voltage traction inverters. Ratings Volts • • 1000 Vac • 800 Vdc • Amps 35-2000 A • IR • 25 kA RMS Sym. (35-200 A) • 100 kA RMS Sym. (250-2000 A) • 50 kA at 800 Vdc (35-200 A and 450-600 A) • UL Recognized, JFHR8, E91958 on 50-600 A only • CE Rated voltage 1000 Vac/ 800 Vdc (UL) I²t (A²s) Rated current (amps) Pre-arcing 35 210 40 300 50 470 60 670 70 1100 80 1550 90 1900 100 2800 125 4800 150 6300 175 7500 200 11,700 250 16,000 300 23,500 350 33,000 400 47,000 500 39,500 600 61,000 800 87,000 1000 190,000 1200 370,000 1400 470,000 1600 700,000 1800 925,000 2000 1,330,000 Clearing at 1000 Vac 2000 2500 3500 5000 6900 9700 12,000 17,500 35,000 45,000 65,000 80,000 112,000 164,000 231,000 330,000 329,000 520,000 500,000 1,100,000 2,100,000 2,700,000 4,000,000 5,300,000 7,600,000 Watts loss (W)† 7 8 10 11 12 13 14 15 16 25 30 32 50 56 62 67 95 105 182 206 240 248 267 239 244 High speed fuses Agency information Dimensions — in Catalog no. FWJ-35A FWJ-40A FWJ-50A FWJ-60A FWJ-70A FWJ-80A FWJ-90A FWJ-100A FWJ-125A FWJ-150A FWJ-175A FWJ-200A FWJ-250A FWJ-300A FWJ-350A FWJ-400A FWJ-500A FWJ-600A FWJ-800A FWJ-1000A FWJ-1200A FWJ-1400A FWJ-1600A FWJ-1800A FWJ-2000A A D E C H G F B J Amp range A B C D E F G H J 35-60 5.00 0.94 3.11 4.24 4.18 0.35 0.75 0.13 0.38 70-100 4.93 1.13 3.09 4.27 4.16 0.35 1.00 0.19 0.41 125-200 5.69 1.53 3.26 4.80 4.06 0.45 1.00 0.25 0.82 250-400 5.77 2.00 3.50 4.81 4.15 0.43 1.50 0.25 0.76 500-600 7.20 2.50 3.47 5.98 4.71 0.56 2.00 0.38 1.20 800-2000 6.81 3.50 3.31 5.47 4.96 0.63 2.75 0.50 0.88 1” = 25.4mm † Watts loss at rated current. For details on electrical characteristics, contact Application Engineering and ask for data sheets: 720027, 5785303 (35-600 A), 5785309 (800-2000 A), BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-13 4 — High speed fuses North American Accessories BH modular type Modular fuse blocks Bussmann series line of fuse blocks provides the user with design and manufacturing flexibility. Two identical half blocks make up a modular assembly that can be panel mounted any distance apart to accommodate any length fuse. C5268 stud type BH modular blocks provide a wide range of mounting configurations for Bussmann series high speed semiconductors fuses. BH fuse blocks have a short-circuit current rating up to 200 kA RMS Sym. The simpler design is the C5268 modular fuse block. With this design, the fuse terminal and cable (with termination) are mounted on the same stud, minimizing installation labor. The stud type block is available in the configurations shown in the table below. Catalog no. C5268-1 Max fuse amp rating 200 Stud 5/16-18 x 1" 200 200 100 100 5/16-18 x 1-3/4" 5/16-18 x 3/4" 1/4-20 x 1" 1/4-20 x 1-3/4" C5268-2 C5268-3 C5268-4 C5268-5 Catalog no. BH-0 BH-1 BH-2 BH-3 Max rated voltage 700 2500 5000 1250 Max fuse amp rating 100 400 600 700 1BS10x connector type Bussmann series 1BS10 blocks utilize a tin-plated connector for wire termination and heat dissipation), and a plated-steel stud for fuse mounting. The connector type block is available in the configurations shown below. Consult your Bussmann series product representative for additional product details. Catalog no. 1BS101 1BS102 1BS103 1BS104 Max rated voltage 600 600 600 600 Max fuse amp rating 100 400 400 600 Data sheets: 1200 (BH-0), 1201 (BH-1), 1202 (BH-2), 1203 (BH-3), 1206 (1BS101), 1207 (1BS102), 1208 (1BS103), 1209 (1BS104) 4-14 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 LCT, LET BS88 240 Vac/150 Vdc (IEC), 250-280 Vac/150 Vdc (UL), 6 to 180 A BS88 style bolted tag high speed fuses for the protection of DC common bus, DC drives, power converters/rectifiers and reduced rated voltage starters. Low watts loss in a compact size. Ratings Volts • LCT 240 Vac/150 Vdc (IEC), 250 Vac/150 Vdc (UL) • LET 280 Vac/150 Vdc (UL, 25-160 A), 250 Vac/150 Vdc (UL 180 A) • Amps 6-180 A • IR • 200 kA RMS Sym. • 50 kA DC at 125 Vdc • 100 kA at 80 Vdc (70-1000 A) Dimensions — mm 47 38 28 Operating class aR. Agency information • Designed and tested to BS88 Part 4 and IEC 60269 Part 4 • UL Recognized* • CCC (LCT only) • CE 8.7 6.4 4 5.5 LCT * All fuses have been tested at 318 Vac. Consult Bussmann series product representative for UL Recognized status. 55 41 26 19.1 12.7 6.95 17.7 9.7 2.34 Indicator (optional) LET — indicator optional I²t (A²s) Fuse symbol LCT LET Rated voltage 240 Vac/150 Vdc (IEC) 250 Vac/150 Vdc (UL) 280 Vac/150 Vdc (UL) 250 Vac/150 Vdc (UL) Rated current(amps) Pre-arcing 6 2.0 10 3.8 12 7.0 16 20.0 20 25.0 25 32 35 50 63 80 100 125 160 180 Clearing at 240 Vac 9 22 32 100 160 18.0 32.0 50.0 100.0 180.0 300.0 600.0 600.0 1100.0 1600.0 250 450 600 1400 2200 3800 7500 7500 16,000 29,000 Watts loss (W)† 1.0 2.5 2.5 2.5 4.0 4.0 5.0 5.0 7.0 9.0 10.0 10.0 16.0 20.0 21.0 Catalog no. 6LCT 10LCT 12LCT 16LCT 20LCT 25LET 32LET 35LET 50LET 63LET 80LET 100LET 125LET 160LET 180LET † Watts loss at rated current. Note: 7LET, 10LET, 12LET and 16LET are available for replacement purposes on existing equipment. For details on electrical characteristics, contact Application Engineering and ask for data sheets: 720004, 5785296 (LCT), 5785293 (LET) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-15 High speed fuses • 4 — High speed fuses LMT, LMMT BS88 240 Vac/150 Vdc (IEC), 250 Vac/150 Vdc (UL), 160 to 900 A BS88 style bolted tags high speed fuses for the protection of DC common bus, DC drives, power converters/rectifiers and reduced rated voltage starters. Low watts loss in a compact size. Ratings Volts • • 240 Vac/150 Vdc (IEC) • 250 Vac/150 Vdc (UL) • Amps 160-900 A • IR • 200 kA RMS Sym., 40 kA at 150 Vdc (IEC) • 200 kA RMS Sym., 50 kA at 150 Vdc (UL) Operating class aR Agency information • Designed and tested to BS88 Part 4 and IEC 60269 Part 4 • UL Recognized* • CCC • CE * All fuses have been tested at 318 Vac. Consult Bussmann series product representative for UL Recognized status. I²t (A²s) Fuse symbol Rated current (amps) 160 Rated voltage 240 Vac /150 Vdc (IEC) LMT 250 Vac /150 Vdc (UL) 240 Vac /150 Vdc (IEC) LMMT 250 Vac /150 Vdc (UL) Clearing at Pre-arcing 1100 120 Vac 240 Vac 7000 16,000 Watts loss (W)† 17 Catalog no. 160LMT 200 250 315 355 1500 3200 6000 8000 10,000 20,000 35,000 50,000 20,000 40,000 75,000 100,000 28 28 35 35 200LMT 250LMT 315LMT 355LMT 400 450 400 500 630 710 800 14,000 18,000 6000 14,000 24,000 32,000 52,000 70,000 100,000 35,000 80,000 150,000 200,000 300,000 160,000 220,000 80,000 170,000 300,000 460,000 600,000 40 42 60 64 75 77 82 400LMT 450LMT 400LMMT 500LMMT 630LMMT 710LMMT 800LMMT 900 75,000 400,000 800,000 97 900LMMT † Watts loss at rated current. Dimensions — mm 41.3 83.5 58.0 30.5 83.5 58.0 30.5 3.15 83.5 25.4 38.1 6.5 25.4 13.5 LMT — indicator optional 82.5 10.3 38.1 13.5 LMMT — indicator optional For details on electrical characteristics, contact Application Engineering and ask for data sheets: 720004, 5785294 (LMT), 5785295 (LMMT) 4-16 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 CT, ET, FE, EET, FEE BS88 690 Vac/500 Vdc (IEC), 700 Vac/500 Vdc (UL), 6 to 200 A BS88 style bolted tags high speed fuses for the protection of DC common bus, DC drives, power converters /rectifiers and reduced rated voltage starters. Ratings • Volts • 690 Vac/500 Vdc (IEC) • 700 Vac/500 Vdc (UL) • Amps 6-200 A • IR • CT: IEC — 90 kA RMS Sym., 40 kA at 500 Vdc, UL — 200 kA RMS Sym., 50 kA at 500 Vdc • ET, EET, FE and FEE: 200 kA RMS Sym.,50 kA at 500 Vdc Operating class aR • Designed and tested to BS88 part 4 and IEC 60269 Part 4 • UL Recognized* • CCC for ET, FE, EET, FEE • CE High speed fuses Agency information * Consult your Bussmann series product representative for UL Recognized status. Dimensions — mm 9.7 74.6 64.3 7.1 55 48.0 6.4 4 63.5 17.7 5.5 19.1 8.7 77.0 CT 2.34 12.7 ET, FE — indicator optional 94.0 71.0 46.0 19.5 8.7 31.8 36.0 11.9 1.6 EET, FEE — indicator optional For details on electrical characteristics, contact Application Engineering and ask for data sheets: 5785312 (CT, ET), 5785314 (FE), 5785313 (EET), 5785292 (FEE) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-17 4 — High speed fuses CT, ET, FE, EET, FEE BS88 690 Vac/500 Vdc (IEC), 700 Vac/500 Vdc (UL), 6 to 200 A Fuse symbol Rated voltage CT ET FE EET FEE 690 Vac/500 Vdc (IEC) 700 Vac/500 Vdc (UL) 690 Vac/500 Vdc (IEC) 700 Vac/500 Vdc (UL) 690 Vac/500 Vdc (IEC) 700 Vac/500 Vdc (UL) 690 Vac/500 Vdc (IEC) 700 Vac/500 Vdc (UL) 690 Vac/500 Vdc (IEC) 700 Vac/500 Vdc (UL) Rated current (amps) 6 10 12 16 20 25 32 35 40 45 56 63 80 35 40 45 50 63 71 80 90 100 90 110 140 160 100 120 140 160 180 200 I²t (A²s) Pre-arcing 1.8 7.0 10.0 16.0 32.0 25.0 32.0 52.0 103.0 103.0 135.0 171.0 360.0 33.0 52.0 76.0 103.0 135.0 210.0 250.0 360.0 470.0 490.0 600.0 1050.0 1500.0 400.0 540.0 850.0 1000.0 1400.0 1900.0 Clearing at 415 Vac 8.5 30.0 40.0 66.0 150.0 150.0 190.0 310.0 600.0 680.0 950.0 1200.0 2500.0 130.0 180.0 270.0 380.0 480.0 600.0 900.0 1300.0 1800.0 300.0 4000.0 7000.0 10,000.0 1600.0 1900.0 2500.0 3700.0 5300.0 7100.0 Clearing at 660 Vac 12 48 65 110 220 250 350 500 900 1100 1500 2000 4000 200 300 450 600 750 950 1500 2100 2800 4500 6500 12,000 17,000 2400 3100 3800 5700 8400 11,400 Watts loss (W)† 2 3 3 7 7 7 11 11 9 11 14 16 18 9 9 11 11 12 17 20 20 23 19 27 35 39 24 32 36 46 46 52 Catalog no. 6CT 10CT 12CT 16CT 20CT 25ET 32ET 35ET 40ET 45ET 56ET 63ET 80ET 35FE 40FE 45FE 50FE 63FE 71FE 80FE 90FE 100FE 90EET 110EET 140EET 160EET 100FEE 120FEE 140FEE 160FEE 180FEE 200FEE † Watts loss at rated current. Note: FC, 8ET, 12ET, 15ET, 20ET, 65EET and 75EET are available for replacement purposes on existing equipment. For details on electrical characteristics, contact Application Engineering and ask for data sheets: 5785312 (CT, ET), 5785314 (FE), 5785313 (EET), 5785292 (FEE) 4-18 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 FM, FMM, MT, MMT BS88 690 Vac/350-450 Vdc (IEC),700 Vac/500 Vdc (UL), 160 to 710 A BS88 style bolted tags high speed fuses for the protection of DC common bus, DC drives, power converters /rectifiers and reduced rated voltage starters. Ratings Volts • FM: 690 Vac/450 Vdc (IEC); 700 Vac/500 Vdc (UL) • FMM: 690 Vac/450 Vdc (IEC); 700 Vac (UL) • MT and MMT: 690 Vac/350 Vdc (IEC); 700 Vac (UL) • Amps 160-710 A • IR • FM: 200 kA RMS Sym. (IEC/UL), 40 kA at 450 Vdc (IEC), 50 kA at 500 Vdc (UL) • FMM: 200 kA RMS Sym. (IEC/UL), 40 kA at 450 Vdc (IEC). • MT and MMT: 200 kA RMS Sym. (IEC/UL), 40 kA at 350 Vdc (IEC). High speed fuses • Operating class aR Agency information • Designed and tested to BS88 Part 4 and IEC 60269 Part 4 • UL Recognized MT and MMT 350 Vdc (IEC) rating* • CCC for FM and FMM • CE Consult your Bussmann series product representative for UL Recognized status. Dimensions — mm 112.0 41.3 84.0 49.5 3.15 38.1 10.3 25.4 13.5 FM, MT — indicator optional 112.0 82.5 6.5 84.0 49.5 10.3 25.4 38.1 13.5 FMM, MMT — indicator optional For details on electrical characteristics, contact Application Engineering and ask for data sheets: 5785314 (FM), 5785313 (MT), 5785292 (FMM), 5785311 (MMT) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-19 4 — High speed fuses FM, FMM, MT, MMT BS88 690 Vac/350-450 Vdc (IEC), 700 Vac/500 Vdc (UL), 160 to 710 A Fuse symbol FM FMM MT MMT Rated voltage 690 Vac/450 Vdc (IEC) 700 Vac/500 Vdc (UL) 690 Vac/450 Vdc (IEC) 700 Vac (UL) 690 Vac/350 Vdc (IEC) 700 Vac (UL) 690 Vac/350 Vdc (IEC) 700 Vac (UL) Rated current (amps) 180 200 225 250 280 315 350 400 450 500 550 630 700 160 180 200 250 280 315 355 180 200 225 280 315 355 400 450 500 560 630 710 I²t (A²s) Pre-arcing 1400 2600 3700 5200 7000 10,000 15,000 10,000 15,000 20,000 30,000 45,000 60,000 2400 3800 6000 11,500 16,500 19,000 22,000 1650 2200 3700 6600 8600 13,500 21,000 30,000 42,000 60,000 68,500 78,000 Clearing at 415 Vac 7500 10,500 14,500 20,500 30,500 40,000 60,000 40,000 60,000 82,000 120,000 180,000 245,000 15,000 25,000 40,000 80,000 100,000 125,000 160,000 12,000 16,000 26,000 47,000 62,000 97,000 150,000 220,000 300,000 430,000 500,000 600,000 Clearing at 660 Vac 13,500 18,500 26,500 37,500 55,000 77,000 105,000 72,500 105,000 150,000 215,000 310,000 420,000 25,000 38,000 58,000 110,000 150,000 180,000 200,000 18,000 23,000 40,000 70,000 91,000 140,000 220,000 320,000 450,000 640,000 720,000 850,000 Watts loss (W)† 40 40 44 48 48 55 55 85 90 100 100 100 120 26 26 27 32 35 42 51 42 42 42 47 51 54 60 57 64 64 86 105 Catalog no. 180FM 200FM 225FM 250FM 280FM 315FM 350FM 400FMM 450FMM 500FMM 550FMM 630FMM 700FMM 160MT 180MT 200MT 250MT 280MT 315MT 355MT 180MMT 200MMT 225MMT 280MMT 315MMT 355MMT 400MMT 450MMT 500MMT 560MMT 630MMT 710MMT † Watts loss at rated current. For details on electrical characteristics, contact Application Engineering and ask for data sheets: 5785314 (FM), 5785313 (MT), 5785292 (FMM), 5785311 (MMT) 4-20 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 BS 88 Accessories Trip indicator Microswitches Trip-indicator fuses are available for use in parallel with the main BS88-4 fuses. They can either be attached to the associated fuse or mounted separately in panel mounted fuse clips. Push-on adapters with microswitch (catalog numbers MAI and MBI) are available for use with the trip indicator to provide a means for remote indication. Microswitch/adapter: MAI and MBI Fuse ratings of 20 A and below cannot usually accommodate a trip fuse in parallel. When a trip-indicator is to be attached to the main fuse, an accessory pack comprising a pair of mounting clips and an appropriate trip indicator is required. The clips are snapped onto the fuse and the indicator is pressed into clips as shown below. Trip indicator kit catalog numbers (indicator + clips) Catalog no. EC-600 EC-600 EC-600 EC-600 EC-250 MC-600 MC-600 MC-250 MC-250 Rated current 250 500 600 700 1100 1500 2000 2500 Description MAI Trip indicator adapter and microswitch Terminal orientation Back MBI Trip indicator adapter and microswitch Side Microswitch ratings (MAI and MBI) Terminals Quick connect Current rating 4 A @ 250 V RMS AC 50/60 Hz resistive load 6 A @ 127 V RMS 0.7 A @ 110 Vdc DC, resistive load 2 A @ 30 Vdc Maximum working voltage Indicator only Catalog no. TI250 TI500 TI600 TI700 TI1100 TI1500 TI2000 TI2500 Catalog no. High speed fuses For fuse symbol ET EET FE FEE LET FM FMM LMT LMMT To provide a means of remote indication with the trip indicators, we offer two microswitch/adapters. The microswitches are provided with double pole, single throw contacts, having both a normally open (NO) and a normally closed (NC) position. A special material is used in the construction of the adapter to provide reliable operation in the temperatures ranges associated with standard operating conditions and during fuse operation. Dim. ‘A’ (mm) 37.6 47.5 55.7 61.8 98.4 120.8 147.5 198.3 1000 V Contact-to-contact (RMS) 1500 V Maximum DC volts 110 Vdc Indicator dimensions — mm 6 21 6.35 0.8 Microswitch/adapter dimensions — mm A 6.0 2.8 2.4 3.6 5.2 5.2 Indicator panel mount clips CL1 panel mount fuse clips are available for mounting a trip-indicator directly to a PCB or insulated panel, or when mounting directly on the fuse is impractical. Order catalog number CL1. CL1 dimensions — mm 44 36 3.6 44 36 6.0 14 8.7 9.5 NO NC NC 21 NO MAI 21 or MBI 50.8 B BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-21 4 — High speed fuses FWA Ferrule 150 Vac/dc (UL), 10x38mm and 21x51mm, 5 to 60 A Ferrule style high speed fuses for the protection of DC common bus, DC drives, power converters /rectifiers and reduced rated voltage starters. Ratings • Volts 150 Vac/dc (UL) • Amps 5-60 A • IR • 200 kA RMS Sym. • 50 kA DC at 150 Vdc Operating class aR Agency information • UL Recognized, JFHR2, E91958 • CE Fuse size Rated voltage 10x38mm (13/32”x1-1/2”) 150 Vac/dc (UL) 21x51mm (13/16”x2”) Rated current (amps) 5 10 15 20 25 30 35 40 45 50 60 I²t (A²s) Pre-arcing 1.6 3.6 14.0 33.0 58.0 100.0 75.0 100.0 130.0 170.0 250.0 Clearing at 150 Vac 8 16 50 130 220 400 800 1000 1300 1600 2400 Watts loss (W)† 2.0 2.7 3.3 3.8 4.9 4.9 4.5 5.1 6.0 7.3 8.0 Catalog no. FWA-5A10F FWA-10A10F FWA-15A10F FWA-20A10F FWA-25A10F FWA-30A10F FWA-35A21F FWA-40A21F FWA-45A21F FWA-50A21F FWA-60A21F † Watts loss at rated current. Dimensions — in (mm) C A B Amp range 5-30 35-60 A 1.5 (38.1) 2.0 (50.8) B C 0.38 (9.5) 0.41 (10.3) 0.63 (15.9) 0.81 (20.6) For details on electrical characteristics, contact Application Engineering and ask for data sheets: 720003,5785317 (5-30 A), 5785305 (35-60 A) 4-22 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 FWX Ferrule 250 Vac/dc (UL), 14x51mm, 1 to 50 A Ferrule style high speed fuses for the protection of DC common bus, DC drives, power converters/rectifiers rated voltage starters. Ratings • Volts • 250 Vac (UL, all ratings) • 250 Vdc (UL, 5-50 A only) • Amps 1-50 A • IR • 200 kA RMS Sym. (UL, all ratings) • 50 kA at 250 Vdc (UL, 5-50 A only) Operating class aR • UL Recognized, JFHR2, E91958 1-50 A • CSA Class 1422-30, 1422-90 (53787) 5-30 A • CE High speed fuses Agency information I²t (A²s) Fuse size Rated voltage 250 Vac (UL) 14x51mm (9/16”x2”) 250 Vac/dc (UL) Rated current(amps) 1 2 3 4 5 10 15 20 25 30 50 Pre-arcing Clearing at 250 Vac 0.03 0.40 0.08 0.10 0.11 0.26 0.1 0.23 1.6 13.00 3.6 24.00 14.0 83.00 33.0 200.00 58.0 300.00 100.0 500.00 200.0 1800.00 Watts loss (W)† 5.7 8.6 2.8 3.0 1.3 3.4 3.8 4.6 5.3 5.9 5.7 Catalog no. FWX-1A14F FWX-2A14F FWX-3A14F FWX-4A14F FWX-5A14F FWX-10A14F FWX-15A14F FWX-20A14F FWX-25A14F FWX-30A14F FWX-50A14F † Watts loss at rated current. Dimensions — mm (in) 50.8 (2.0) 14.3 (0.56) 15.5 (0.61) For details on electrical characteristics, contact Application Engineering and ask for data sheets: 720006, 5785302 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-23 4 — High speed fuses FWH Ferrule 2011/65/EU 500 Vac (UL), 6x32mm, 0.25 to 30 A Ferrule style high speed fuses for the protection of DC common bus, DC drives, power converters/rectifiers and reduced rated voltage starters. Ratings Volts • • 500 Vac (UL — 0.25-1 A and 3.15-30 A) • 1000 Vac (UL — 2 A) • 600 Vdc (UL — 1-5 A) • Amps 0.25-30 A • IR Dimensions — mm (in) • 50 kA AC (0.25-1 A and 3.15-20 A) • 30 kA AC (2 A) • 20 kA AC (25-30 A)1 • 50 kA DC (1-5 A)) 31.8 (1.25) 3.2 (0.125) Tested at PF = 76%. 1 6.4 (0.25) Operating class aR Agency information Opening times • UL Recognized, JFHR2, E91958 (0.25-7 A) and JDYX2, E19180 (10-30 A) Amp range • CSA Component Acceptance Class 1422-30, 1422-90 (53787) 0.25-7 A 10-30 • RoHS compliant • CE Amps 0.25 0.5 1 2 3.15 4 5 6.3 7 10 12.5 15 16 20 25 30 Rated voltage Vac Vdc — 500 1000 600 500 — 0.25-7 150% 200% 300% >30 min >30 min ≤ 10 sec 300 % 200 % I2t (A2s) Catalog no. Pre-arcing Clearing @ 500Vac Watts loss (W)† Standard RoHS compliant 0.01 0.05 2.7 FWH-.250A6F 0.05 0.25 1.2 FWH-.500A6F 0.4 2 1.7 FWH-001A6F 1.3 3.5 3.2 FWH-002A6F 3.1 7.7 2.9 — FWH-3.15A6F — — — FWH-004A6F 15 40 2.1 FWH-005A6F 36 90 2.3 FWH-6.30A6F 50 125 2.5 FWH-007A6F 9.9 139 2.86 FWH5-010A6F FWH5-010A6FR 20 60 3.53 FWH5-12-5A6F FWH5-12-5A6FR 44 146 3.08 FWH5-015A6F FWH5-015A6FR 48 177 4.48 FWH5-016A6F FWH5-016A6FR 75 259 4.26 FWH5-020A6F FWH5-020A6FR 126 345 — FWH-025A6F FWH-025A6FR 145 430 — FWH-030A6F FWH-030A6FR † Watts loss at rated current. Data sheet no.720038 4-24 Min IR BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 FWH Ferrule 500 Vac/ Vdc (UL), 14x51mm, 1 to 30 A Ferrule style high speed fuses for the protection of DC common bus, DC drives, power converters/rectifiers and reduced rated voltage starters. Ratings Volts • • 500 Vac (UL, all ratings) • 500 Vdc (UL, 5-30 A only) • Amps 1-30 A • IR • 200 kA RMS Sym. all ratings • 50 kA at 500 Vdc 5-30 A only Operating class aR • UL Recognized 1-30 A • CSA Class 1422-30, (53787) 5-30 A • CE High speed fuses Agency information I²t (A²s) Fuse size Rated voltage 500 Vac (UL) 14x51mm (9/16"x2") 500 Vac/dc (UL) Rated current (amps) 1 2 3 4 5 6 10 12 15 20 25 30 Pre-arcing 0.04 0.08 0.11 0.10 2.00 2.00 4.00 7.00 10.00 26.00 49.00 58.00 Clearing at 500 Vac 0.2 0.1 0.2 0.2 7.0 7.0 15.0 25.0 40.0 100.0 200.0 240.0 Watts loss (W)† 5.7 8.7 2.8 3.0 1.5 1.5 4.0 4.3 5.5 6.5 7.0 9.0 Catalog no. FWH-1A14F FWH-2A14F FWH-3A14F FWH-4A14F FWH-5A14F FWH-6A14F FWH-10A14F FWH-12A14F FWH-15A14F FWH-20A14F FWH-25A14F FWH-30A14F † Watts loss at rated current. Dimensions — mm (in) 50.8 (2.0) 14.3 (0.56) 15.5 (0.61) For details on electrical characteristics, contact Application Engineering and ask for data sheets:720008, 5785298 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-25 4 — High speed fuses FWC Ferrule 600-700 Vac/700 Vdc (UL), 10x38mm, 1 to 32 A Ferrule style high speed fuses for the protection of DC common bus, DC drives, power converters/rectifiers and reduced rated voltage starters. Ratings Volts • • 700 Vac/dc (UL, 1-4 A) • 600 Vac (UL, 6-32 A), 700 Vdc (UL, 6-25 A) • Amps 1-32 A • IR • 200 kA RMS Sym. at 600 Vac (6-32 A) • 200 kA RMS Sym. at 700 Vac (1-4 A) • 10 kA DC at 700 Vdc (1-25 A) Operating class aR Agency information • UL Recognized, JFHR8, E91958 6-32 A • CSA Class 1422-30, (53787) 6-32 A • CE Fuse size Rated voltage 700 Vac/dc (UL) 10x38mm (13/32"x1-1/2") 600 Vac/700 Vdc (UL) 600 Vac (UL) Rated current (amps) 1 2 3 4 6 8 10 12 16 20 25 32 I²t (A²s) Pre-arcing Clearing at 600 Vac 0.2 1.2 0.5 3.0 1.6 11.0 5.2 32.0 4.0 30.0 6.0 9.0 15.0 25.0 34.0 60.0 95.0 50.0 70.0 120.0 150.0 260.0 390.0 600.0 Watts loss (W)† 0.5 1.2 1.5 1.5 1.5 Catalog no. FWC-1A10F FWC-2A10F FWC-3A10F FWC-4A10F FWC-6A10F 2.0 2.5 3.0 3.5 4.8 6.0 7.5 FWC-8A10F FWC-10A10F FWC-12A10F FWC-16A10F FWC-20A10F FWC-25A10F FWC-32A10F † Watts loss at rated current. Dimensions — mm 38 10 9.5 For details on electrical characteristics, contact Application Engineering and ask for data sheets:720011, 5785306 4-26 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 FWP Ferrule 690 Vac (IEC) 10x38mm, 4 to 32 A Ferrule style Class gR high speed fuses for the protection of AC/DC drives and semiconductors. Ratings • Volts 690 Vac • Amps 4-32 A • IR • 200 kA RMS Sym. Operating class gR Agency information UL 248-13 • Designed and tested to IEC 60269, Part 4 • CE High speed fuses • I²t (A²s) Fuse type Without striker Fuse size 10x38 mm Rated voltage 690 Vac (IEC) Rated current (amps) Pre-arcing 4 5.6 Watts loss (W)† Clearing at 690 Vac 17 0.8In 1.13 In 2.05 Catalog no. FWP-4G10F 6 16.0 48 1.56 3.0 FWP-6G10F 8 4.3 38 0.97 1.68 FWP-8G10F 10 6.6 59 1.20 2.09 FWP-10G10F 12 9.6 84 1.69 2.99 FWP-12G10F 16 17.0 150 2.31 4.27 FWP-16G10F 20 23.5 200 2.86 5.35 FWP-20G10F 25 60.2 512 2.94 5.52 FWP-25G10F 32** 94.0 800 3.82 7.43 FWP-32G10F † Watts loss at rated current. ** 32 A rated current with 25mm2 conductors, derate to 27 A with 6mm2 conductors. Data sheet no. 10467 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-27 4 — High speed fuses FWP Ferrule 690 Vac (IEC), 700 Vac (UL), 600 - 700 Vdc (UL), 14x51mm, 1 to 50 A Ferrule style Class aR high speed fuses for the protection of DC common bus, DC drives, power converters/rectifiers and reduced rated voltage starters. Available with or without striker. Ratings • Volts 690 Vac (IEC), 700 Vac/600 Vdc (UL) with striker (see table for striker version) • Amps 1-50 A • IR • 200 kA RMS Sym. • 50 kA at 800 Vdc (5-50 A non striker version) • 600 Vdc for striker version Operating class aR Agency information • UL Recognized, (without striker only) JFHR2, E91958 • CSA (without striker only) Class 1422-30, 1422-90 (53787) • Designed and tested to IEC 60269, Part 4 • CE Fuse type Fuse size Rated voltage 700 Vac (UL) Without striker 690 Vac (IEC) 700 Vac/dc (UL) 14x51mm (9/16”x2”) With striker 700 Vac/600 Vdc (UL) Rated current (amps) 1 I²t (A²s) Pre-arcing 0.04 Clearing at 700 Vac 0.41 Watts loss (W)† 5.7 Catalog no. FWP-1A14F 2 0.08 0.11 8.7 FWP-2A14F 3 0.11 0.26 2.8 FWP-3A14F 4 0.10 0.23 3.0 FWP-4A14F 5 2.00 11.00 1.5 FWP-5A14F 10 4.00 22.00 4.0 FWP-10A14F 15 10.00 70.00 5.5 FWP-15A14F 20 26.00 180.00 6.5 FWP-20A14F 25 49.00 320.00 7.0 FWP-25A14F 30 58.00 400.00 9.0 FWP-30A14F 32 68.00 600.00 8.0 FWP-32A14F 40 84.00 750.00 8.0 FWP-40A14F 50 200.00 1800.00 9.0 FWP-50A14F 10 4.00 32.00 2.0 FWP-10A14FI 15 7.00 63.00 4.0 FWP-15A14FI 20 26.00 234.00 4.0 FWP-20A14FI 25 42.00 378.00 4.0 FWP-25A14FI 30 52.00 468.00 6.0 FWP-30A14FI 32 68.00 600.00 8.0 FWP-32A14FI 40 84.00 750.00 8.0 FWP-40A14FI 50 200.00 1800.00 9.0 FWP-50A14FI † Watts loss at rated current. Dimensions — mm (in) 50.8 (2.0) 59 (2.32) 14.3 (0.56) 51 (2.0) 14.3 (0.56) Without striker 15.5 (0.61) With striker 13.0 (0.5) 5.0 (0.2) For details on electrical characteristics, contact Application Engineering and ask for data sheets: 720025, 5781724 fuses without striker; 5785566 fuses with striker 4-28 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 FWP Ferrule 690 Vac 14x51mm, 1 to 50 A Ferrule style Class gR high speed fuses for the protection of AC/DC drives, semiconductors and high voltage auxiliary circuits in electric vehicles. Available with or without striker. Ratings • Volts 690 Vac • Amps 4-50 A • IR 200 kA RMS Sym. Operating class gR Agency information UL 248-13 • Designed and tested to IEC 60269, Part 4 • CE High speed fuses • Fuse type Fuse size Rated voltage Without striker 14x51mm (9/16”x2”) With striker 690 Vac (UL/IEC) Rated current (amps) 4 I²t (A²s) Watts loss (W)† Pre-arcing Clearing at 690 Vac 5.6 17 0.8In 1.56 In 2.94 Catalog no. FWP-4G14F 6 16 48 2.25 4.2 FWP-6G14F 8 3.8 30 1.18 2.0 FWP-8G14F 10 5.9 47 1.41 2.52 FWP-10G14F 12 8.4 68 1.95 3.54 FWP-12G14F 16 15 120 5.67 4.83 FWP-16G14F 20 27 170 2.91 5.4 FWP-20G14F 25 53 333 3.38 6.0 FWP-25G14F 32 108 679 3.72 6.93 FWP-32G14F 40 211 1331 4.13 7.52 FWP-40G14F 50 350 2200 5.36 9.8 FWP-50G14F 8 3.8 30 1.18 2.0 FWP-8G14FI 10 5.9 47 1.41 2.52 FWP-10G14FI 12 8.4 68 1.95 3.54 FWP-12G14FI 16 15 120 5.67 4.83 FWP-16G14FI 20 27 170 2.91 5.4 FWP-20G14FI 25 53 333 3.38 6.0 FWP-25G14FI 32 108 679 3.72 6.93 FWP-32G14FI 40 211 1331 4.13 7.52 FWP-40G14FI 50 350 2200 5.36 9.8 FWP-50G14FI † Watts loss at rated current. Dimensions — mm (in) 50.8 (2.0) 59 (2.32) 14.3 (0.56) 51 (2.0) 14.3 (0.56) Without striker 15.5 (0.61) With striker 13.0 (0.5) 5.0 (0.2) Data sheet no. 10468 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-29 4 — High speed fuses FWP Ferrule 700 Vac/dc (UL), 22x58mm, 20 to 100 A Ferrule style high speed fuses for the protection of DC common bus, DC drives, power converters/rectifiers and reduced rated voltage starters. Available with or without striker. Ratings • Volts 700 Vac/dc (UL) • Amps 20-100 A • IR • 200 kA RMS Sym. • 50 kA at 700 Vdc, L/R 5 ms Operating class aR Agency information • UL Recognized, (without striker only) JFHR2, E91958 • CSA (without striker only) Class 1422-30, 1422-90 (53787) • CE Fuse type Fuse size Rated voltage Without striker 22x58mm (7/8"x2-9/32") 700 Vac/dc (UL With striker Rated current (amps) 20 Pre-arcing 23.0 I²t (A²s) Clearing at 700 Vac Watts loss (W)† 330 5.0 25 37.0 530 6.0 FWP-25A22F 32 55.0 780 8.0 FWP-32A22F 40 68.0 960 12.0 FWP-40A22F 50 155.0 2200 12.5 FWP-50A22F 63 280.0 4000 15.0 FWP-63A22F 80 550.0 7800 15.0 FWP-80A22F 100 1100.0 15,600 16.5 FWP-100A22F 20 19.0 260 5.0 FWP-20A22FI 25 34.0 410 6.0 FWP-25A22FI 32 53.5 605 8.0 FWP-32A22FI 40 68.0 750 9.0 FWP-40A22FI 50 135.0 1600 9.5 FWP-50A22FI 63 280.0 3080 11.0 FWP-63A22FI 80 600.0 6600 13.5 FWP-80A22FI 100 1100.0 12,500 16.0 FWP-100A22FI † Watts loss at rated current. Dimensions — mm (in) 58.0 (2.28) Without striker 22.2 (0.87) 15.0 (0.6) For details on electrical characteristics, contact Application Engineering and ask for data sheets:720026, 5781723 4-30 Catalog no. FWP-20A22F BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 FWP Ferrule 690 Vac, 500 Vdc 22x58mm, 20 to 100 A Ferrule style Class gR high speed fuses for the protection of AC/DC drives, semiconductors and high voltage auxiliary circuits in electric vehicles. Available with or without striker. Ratings • Volts • 690 Vac • 500 Vdc • Amps 20-100 A • IR • 200 kA RMS Sym. • 50 kA DC Operating class gR • UL 248-13 • Designed and tested to IEC 60269, Part 4 • CE Fuse type Fuse size Rated voltage Without striker 22x58 mm 690 Vac, 500Vdc (7/8"x2-9/32") With striker Rated current (amps) 20 Pre-arcing 24 I²t (A²s) Clearing at 690 Vac 154 Watts loss (W)† 0.8In In 3.23 6.00 High speed fuses Agency information Catalog no. FWP-20G22F 25 43 274 3.66 6.65 FWP-25G22F 32 97 616 4.86 9.21 FWP-32G22F 40 180 899 4.50 8.24 FWP-40G22F 50 273 1362 6.26 11.85 FWP-50G22F 63 516 2575 7.35 13.80 FWP-63G22F 80 1092 5448 8.40 14.00 FWP-80G22F 100 2065 10,300 9.40 17.70 FWP-100G22F 20 24 154 3.23 6.00 FWP-20G22FI 25 43 274 3.66 6.65 FWP-25G22FI 32 97 616 4.86 9.21 FWP-32G22FI 40 180 899 4.50 8.24 FWP-40G22FI 50 273 1362 6.26 11.85 FWP-50G22FI 63 516 2575 7.35 13.80 FWP-63G22FI 80 1092 5448 8.40 14.00 FWP-80G22FI 100 2065 10,300 9.40 17.70 FWP-100G22FI † Watts loss at rated current. Dimensions — mm (in) 58.0 (2.28) Without striker 22.2 (0.87) 15.0 (0.6) Data sheet no. 10469 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-31 4 — High speed fuses FWK Ferrule 750 Vdc (IEC), 20x127mm and 25x146mm, 5 to 60 A Ferrule style high speed fuses for the protection of DC common bus, DC drives, power converters/rectifiers and reduced rated voltage starters. Ratings • Volts 750 Vdc (IEC) • Amps • 5-30 A (20x127mm) • 35-60 A (25x146mm) IR 50 kA at 750 Vdc, L/R 10-15 ms • Operating class gG Agency information CE • Fuse size Rated voltage 20x127mm (13/32"x5") 750 Vdc (IEC) 25x146mm (1”x5-3/4") Rated current (amps) 5 8 10 15 20 25 30 35 40 50 60 I²t (A²s) Pre-arcing 8.5 50 95 100 125 400 800 1300 1600 3100 5900 Clearing at 750 Vac 16 100 200 240 315 1100 2600 4600 5300 12,000 24,000 Watts loss (W)† 6.7 8.8 8.5 5.0 7.8 6.5 6.5 6.0 6.8 7.3 7.7 Catalog no. FWK-5A20F FWK-8A20F FWK-10A20F FWK-15A20F FWK-20A20F FWK-25A20F FWK-30A20F FWK-35A25F FWK-40A25F FWK-50A25F FWK-60A25F † Watts loss at rated current. Dimensions — mm (in) 127.0 (5.0) 5-30 A — 20x127mm 20.5 (0.81) 16.0 (0.63) 146.0 (5.75) 24.5 (1.0) 20.64 (0.8) 35-60 A — 25x146mm For details on electrical characteristics, contact Application Engineering and ask for data sheets:720039, 5785031 4-32 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 FWJ Ferrule 1000 Vac/800 Vdc (UL), 14x67mm, 20 to 30 A Ferrule style high speed fuses for the protection of DC common bus, DC drives, power converters/rectifiers, reduced rated voltage starters and high voltage auxiliary circuits in electric vehicles.. Available with or without striker for remote indication. Ratings • Volts 1000 Vac/800 Vdc • Amps 20-30 A • IR • 25 kA RMS Sym. • 50 kA at 800 Vdc Operating class aR Agency information UL Recognized, JFHR2, E91958 • CE High speed fuses • Fuse size Rated voltage 14x67mm (9/16"x2-5/8") 1000 Vac/ 800 Vdc (UL) I²t (A²s) Rated current (amps) 20 25 Pre-arcing 25 33 Clearing at 1000 Vac 220 350 Watts loss (W)† 9 11 30 52 450 14 Catalog no. FWJ-20A14F FWJ-25A14F FWJ-30A14F † Watts loss at rated current. Dimensions — mm 67 14 10 For details on electrical characteristics, contact Application Engineering and ask for data sheets:720028, 5785315 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-33 4 — High speed fuses FWL Ferrule 1200 Vac/1000 Vdc (IEC), 20x127mm, 20 to 30 A Ferrule style high speed fuses for the protection of DC common bus, DC drives, power converters/rectifiers and reduced rated voltage starters. Available with indicator. Ratings • Volts • 1200 Vac (IEC) • 1000 Vdc (IEC) • Amps 20-30 A • IR • 50 kA RMS Sym. • 50 kA at 1000 Vdc Operating class gR Agency information • IEC 60077 • CE Fuse type Fuse size Rated voltage Without indicator 20x127mm (13/16"x5") With indicator 1200 Vac/1000 Vdc (IEC) Rated current (amps) Pre-arcing 20 675 I²t (A²s) Clearing at 1000 Vac 1550 Watts loss (W)† 5.9 Catalog no. FWL-20A20F FWL-25A20F 25 1200 2760 6.5 30 1850 4300 7.5 FWL-30A20F 20 675 1550 5.9 FWL-20A20FI 25 1200 2760 6.5 FWL-25A20FI 30 1850 4300 7.5 FWL-30A20FI † Watts loss at rated current. Dimensions — mm For details on electrical characteristics, contact Application Engineering and ask for data sheets:720040, 5785455 4-34 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 FWS Ferrule 1400 - 2000 Vac/1000 Vdc (IEC), 20x127mm, 2 to 15 A Ferrule style high speed fuses for the protection of DC common bus, DC drives, power converters/rectifiers and reduced rated voltage starters. Available with indicator. Ratings • Volts • 2000 Vac/1000 Vdc (IEC, 2-8 A) • 1400 Vac/1000 Vdc (IEC, 10-15 A) • Amps 2-15 A • IR • 50 kA RMS Sym. • 50 kA at 1000 Vdc (2-10 A only) Operating class gG • IEC 60077 • CE Fuse type High speed fuses Agency information Fuse size Rated voltage 2000 Vac/1000 Vdc (IEC) Without indicator 1400 Vac/1000 Vdc (IEC) 20x127mm (13/16"x5") 2000 Vac/1000 Vdc (IEC) With indicator 1400 Vac/1000 Vdc (IEC) Rated current (amps) 2 I²t (A²s) Pre-arcing 0.8 Clearing at 1000 Vac 2.4 Watts loss (W)† 4.4 Catalog no. FWS-2A20F 6 27.0 81.0 6.7 FWS-6A20F 8 64.0 192.0 7.6 FWS-8A20F 10 118.0 277.0 3.0 FWS-10A20F 12 170.0 380.0 3.4 FWS-12A20F 15 209.0 500.0 5.0 FWS-15A20F 2 0.8 2.4 4.4 FWS-2A20FI 6 27.0 81.0 6.7 FWS-6A20FI 8 64.0 192.0 7.6 FWS-8A20FI 10 118.0 277.0 3.0 FWS-10A20FI 12 170.0 380.0 3.4 FWS-12A20FI 15 209.0 500.0 5.0 FWS-15A20FI † Watts loss at rated current. Dimensions — mm For details on electrical characteristics, contact Application Engineering and ask for data sheets:720040, 5785109 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-35 4 — High speed fuses Ferrule fuse accessories JM70100 DIN-Rail/panel mount block for 22x58mm fuses Modular, open-style fuse blocks for 22x58mm cylindrical fuses feature versatile 35mm DIN-Rail or screw-to-panel mounting. Available optional IP20 finger-safe covers with lockout/tagout capability come in indicating and non-indicating versions. For use with FWP fuses. Ratings • Volts 700 Vac • Amps 100 A • Withstand rating 200 kA Agency information • UL Recognized, Guide IZTL2, File 14853 Catalog no. JM70100-1CR JM70100-2CR JM70100-3CR Poles 1 2 3 Terminal type Box lug Optional IP20 cover catalog no.* Indicating** Non-indicating CVRI-J-60060 CVR-J-60060 * Order separately, one cover per pole. ** Indication requires 90 V minimum and energized, closed circuit. Data sheet no. 10496 CHM modular DIN-Rail mount holders for 10x38mm fuses Bussmann series compact IP20 finger-safe modular DIN-Rail mount fuse holders for 10x38mm cylindrical fuses. Catalog no. With indicator Without indicator Rated voltage and current CHM1DIU CHM1DU CHM2DIU CHM2DU CHM3DIU CHM3DU IEC 690 Vac/32 A CHM4DIU CHM4DU UL 600 Vac/30 A CHM1DNIU CHM1DNU CHM3DNIU CHM3DNU — CHM1DNXU Agency information Number of poles Rated withstand capacity Terminal rating 1 IEC 60269-2 UR; CSA; CCC 3 4 IEC 60269-2 IEC 690 Vac/32 A 2 IEC 60269-2 1-pole + 1 neutral 3-pole + 1 neutral 1 neutral IEC: 1 to 25mm² 70°C PVC/copper cable, solid, stranded, fine stranded, fork lug, comb busbar; single and dual IEC 120 kA RMS Sym. UL 200 kA RMS Sym. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 FWA, FWC. CCC 100 kA RMS Sym. N/A Data sheet no. 10430 4-36 Compatible Bussmann series fuses Eaton.com/bussmannseries N/A High speed fuses — 4 Ferrule fuse accessories CH14 and CH22 modular DIN-Rail holders Bussmann series compact DIN-Rail mount fuse holders for 14x51mm and 22x58mm cylindrical fuses. Available in different versions with neutral and microswitch. Mounting • 35mm DIN-Rail • Panel mount (2xM4 screws) CH14 CH22 Catalog no. Without indicator With indicator Description — Neutral only Rated withstand capacity Rated voltage and current Agency markings Terminal rating 690 Vac/50 A IEC 60269-1 Size: 2.5-50mm2 750 Vdc/50 A IEC 60269-2 Torque: 3 N•m max 690 Vac/125 A IEC 60269-1 Size: 4 - 50 mm2 120 kA AC 1000 Vdc/125 A IEC 60269-2 Torque: 4 N•m max 50 kA DC Compatible Bussmann series fuses CH141DNXU CH141DU CH141DIU 1 pole CH142DU CH142DIU 2 pole CH143DU CH143DIU 3 pole CH144DU CH144DIU 4 pole CH141DNU CH141DNIU 1 pole + neutral CH143DNU CH143DNIU 3 pole + neutral CH141DMSU-F — CH143DMSU-F — 3 pole with microswitch — 3 pole +neutral with microswitch — Neutral holder CH143DNMSU-F FWX-A14F1, 120 kA AC FWH-A14F1, FWP-A14F1, 2 1 pole with microswitch 22x58mm CH221DNXU 1 2 CH221DU CH221DIU 1 pole fuse holder CH222DU CH222DIU 2 pole fuse holder CH223DU CH223DIU 3 pole fuse holder CH224DU CH224DIU 4 pole fuse holder CH221DNU CH221DNIU 1 pole + neutral CH223DNU CH223DNIU 3 pole + neutral — CH221DMSU-F 1 pole with microswitch — CH223DMSU-F 3 pole with microswitch — CH223DNMSU-F 3 pole with microswitch + neutral FWP ferrule1, 2 Maximum allowed continuous current applies. Please refer to data sheet for details. Please consult our application engineers if you wish to use a FWP fuse with a striker option. CH14 and CH22 accessories Catalog no. AL-D CH14-P CH14-L CH22-L CH14-IP20 CH22-IP20 CH14-MS1 CH22-MS1 CH14-MS3 CH22-MS3 Description Multi-pole ganging clips, one kit will gang up to 4-poles together Multi-pole handle pins, one kit will gang up to 12 handles together Lockout padlock support, it will accept up to 5mm diameter padlock shank Lockout padlock support, it will accept up to 5mm diameter padlock shank For holder CH14 and CH22 CH14 and CH22 CH14 CH22 IP20 protection accessory, provides IP20 protection to terminals with 10mm2 or less cable CH14 CH22 CH14 1-pole microswitch for blown fuse monitoring CH22 CH14 CH22 3-pole microswitch for blown fuse monitoring Data sheet no. 10080 (CH14), 10115 (CH22) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-37 High speed fuses 14x51mm 4 — High speed fuses 170M — Square Body size 000 and 00, DIN 43653 690 Vac (IEC), 700 Vac/dc (UL), 10 to 400 A Square body DIN 43653 bolted tags high speed fuses, for the protection of DC common bus, DC drives, power converters/ rectifiers and reduced rated voltage starters. Available with and without visual indicator, and Type T indicator for a microswitch. Ratings • Volts • 690 Vac (IEC, size 000 and 00) • 700 Vac (UL, size 000; size 00 100-400 A only) • 700 Vdc (UL, size 000) • Amps 10-400 A • IR • 200 kA RMS Sym. • 50 kA at 700 Vdc (size 000 only) Operating class • gR - size 000 (10-63 A), size 00 (25-80 A) • aR - size 000 (>63 A), size 00 (>80 A) Agency Information • Designed and tested to IEC 60269 Part 4 • UL Recognized, JFHR2, E125085 • CSA Class 53787, File 1422-30 on size 000 • CCC • CE Dimensions — mm The dotted line represents the Type T indicator fuse. 54 Indicator* G D K E 100 78 H F Type -U/80, -/80, -TN/80 Size D E F G H K 000 40 21 20 51 8 2 00 51 30 28 67 10 2 * Indicatior for size 00 fuses is a red pin. For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6310 (Size 000), 170K6312 (Size 00) 4-38 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M — Square Body size 000 and 00, DIN 43653 690 Vac (IEC), 700 Vac/dc (UL), 10 to 400 A Fuse size Rated voltage 000 00 00 690 Vac (IEC) 700 Vac/dc (UL) 690 Vac (IEC) 690 Vac (IEC) 700 Vac (UL) 100 125 160 200 250 315 25 32 40 50 63 80 100 125 160 200 250 315 350 400 Catalog no. Pre-Arcing 3.8 7.2 11.5 19.0 40.0 69.0 115.0 215.0 380.0 Clearing at 660 Vac 25.5 48.0 78.0 130.0 270.0 460.0 770.0 1450.0 2550.0 Watts loss (W)† 3.0 5.5 7.0 9.0 10.0 12.0 15.0 16.0 19.0 695.0 1250.0 2350.0 4200.0 7750.0 12,000.0 19.0 28.5 50.0 95.0 170.0 310.0 620.0 1000.0 1900.0 3400.0 6250.0 10,000.0 13,500.0 18,000.0 4650.0 8500.0 16,000.0 28,000.0 51,500.0 80,500.0 130.0 195.0 360.0 640.0 1200.0 2100.0 4150.0 6950.0 13,000.0 23,000.0 42,000.0 68,500.0 91,500.0 125,000.0 24.0 28.0 32.0 37.0 42.0 53.0 6.0 7.0 9.0 10.0 12.0 15.0 20.0 25.0 30.0 35.0 45.0 55.0 60.0 70.0 -U/80 without indicator 170M1308 170M1309 170M1310 170M1311 170M1312 170M1313 170M1314 170M1315 170M1316 170M1317 170M1318 170M1319 170M1320 170M1321 170M1322 — -/80 with indicator 170M1358 170M1359 170M1360 170M1361 170M1362 170M1363 170M1364 170M1365 170M1366 -TN/80 Type T indicator for microswitch 170M1408 170M1409 170M1410 170M1411 170M1412 170M1413 170M1414 170M1415 170M1416 170M1367 170M1368 170M1369 170M1370 170M1371 170M1372 170M2608 170M2609 170M2610 170M2611 170M2612 170M2613 170M2614 170M2615 170M2616 170M2617 170M2618 170M2619 170M2620 170M2621 170M1417 170M1418 170M1419 170M1420 170M1421 170M1422 170M2658 170M2659 170M2660 170M2661 170M2662 170M2663 170M2664 170M2665 170M2666 170M2667 170M2668 170M2669 170M2670 170M2671 High speed fuses I²t (A²s) Rated current (amps) 10 16 20 25 32 40 50 63 80 † Watts loss at rated current. For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6310 (Size 000), 170K6312 (Size 00) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-39 4 — High speed fuses 170M — Square Body size 1* to 3, DIN 43653 690 Vac (IEC), 700 Vac (UL), 40 to 2000 A Square body DIN 43653 bolted tags high speed fuses, for the protection of DC common bus, DC drives, power converters/ rectifiers and reduced rated voltage starters. Available with visual indicator, and Type K and T indicator for a microswitch. Ratings • Volts • 690 Vac (IEC)/700 Vac (UL) • 750 Vdc (UL, see catalog number table for specific fuses) • Amps 40-2000 A • IR 200 kA RMS Sym. Operating class aR Agency information • Designed and tested to IEC 60269 Part 4 • UL Recognized, JFHR2*, E125085 • CSA Class 53787, File 1422-30* • CCC except where noted • CE * Consult your Bussmann series product representative for status. Dimensions — mm 1mm = 0.0394” Type -/80, -TN/80, -/110, -TN/110 Type -KN/80, -KN/110 Size A B B1 C C1 D2 E H Size A B B3 C C3 D E H 1* 50 104 134 78 108 58 45 22 1* 50 104 134 78 108 59 45 22 1 50 108 138 78 108 66 53 25 1 50 108 138 78 108 69 53 25 2 50 108 138 78 108 75 61 25 2 50 108 138 78 108 77 61 25 3 51 109 139 78 108 90 76 30 3 51 109 139 78 108 92 76 30 1 Valid for fuse Types -/110 and -TN/110. 2 Valid for fuse Types -TN/80 and -TN/110. 3 Valid for fuse Type -KN/110. For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6314 (Size 1*), 170K6316 (Size 1), 170K6318 (Size 2), 170K6320 (Size 3) 4-40 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M — Square Body size 1* to 3, DIN 43653 690 Vac (IEC), 700 Vac (UL), 40 to 2000 A Fuse Rated size voltage 1* 1 2 3 690 Vac (IEC) 700 Vac (UL) 690 Vac (IEC) 700 Vac (UL) 690 Vac (IEC) 700 Vac (UL) 690 Vac (IEC) 700 Vac (UL) Rated Watts current Clearing at loss -/80 with (amps) Pre-arcing 660 Vac (W)† indicator 40 40 270 9 170M3008 50 77 515 11 170M3009 63 115 770 14 170M3010 80 185 1250 18 170M3011 100 360 2450 21 170M3012 125 550 3700 26 170M3013 160 1100 7500 30 170M3014 200 2200 15,000 35 170M3015 250 4200 28,500 40 170M3016 315 7000 46,500 50 170M3017 350 10,000 68,500 55 170M3018 400 15,000 105,000 60 170M3019 450 21,000 140,000 65 170M3020 500 27,000 180,000 70 170M3021 550 34,000 230,000 75 170M3022 630 48,500 325,000 80 170M3023 200 1650 11,500 45 170M4008 250 3100 21,000 55 170M4009 315 6200 42,000 58 170M4010 350 8500 59,000 60 170M4011 400 13,500 91,500 65 170M4012 450 17,000 120,000 70 170M4013 500 25,000 170,000 72 170M4014 550 34,000 230,000 75 170M4015 630 52,000 350,000 80 170M4016 700 69,500 465,000 85 170M4017 800 105,000 725,000 95 170M4018 155,000 850,0002 100 170M40191 9002 400 11,000 74,000 65 170M5008 450 15,500 105,000 70 170M5009 500 21,500 145,000 75 170M5010 550 28,000 190,000 80 170M5011 630 41,000 275,000 90 170M5012 700 60,500 405,000 95 170M5013 800 86,000 575,000 105 170M5014 900 125,000 840,000 110 170M5015 1000 180,000 1,250,000 115 170M5016 11003 245,000 1,600,000 120 170M5017 12503 365,000 2,400,000 130 170M5018 500 14,000 95,000 95 170M6008 550 19,500 135,000 100 170M6009 630 31,000 210,000 105 170M6010 700 44,500 300,000 110 170M6011 800 69,500 465,000 115 170M6012 900 100,000 670,000 120 170M6013 1000 140,000 945,000 125 170M6014 1100 190,000 1,300,000 130 170M6015 1250 290,000 1,950,000 140 170M6016 1400 370,000 2,450,000 155 170M6017 1500 460,000 3,100,000 160 170M6018 1600 580,000 3,900,000 160 170M6019 18004 880,000 5,250,0004 165 170M6020†† 20005 1,150,000 6,350,0005 175 170M6021 Catalog no. -TN/80 Type T indicator for micro 170M3058 170M3059 170M3060 170M3061 170M3062 170M3063 170M3064 170M3065 170M3066 170M3067 170M3068 170M3069 170M3070 170M3071 170M3072 170M3073 170M4058 170M4059 170M4060 170M4061 170M4062 170M4063 170M4064 170M4065 170M4066 170M4067 170M4068 170M40691 170M5058 170M5059 170M5060 170M5061 170M5062 170M5063 170M5064 170M5065 170M5066 170M5067 170M5068 170M6058 170M6059 170M6060 170M6061 170M6062 170M6063 170M6064 170M6065 170M6066 170M6067 170M6068 170M6069 170M6070†† 170M6071 -KN/80 Type K indicator for micro 170M3108 170M3109 170M3110 170M3111 170M3112 170M3113 170M3114 170M3115 170M3116 170M3117 170M3118 170M3119 170M3120 170M3121 170M3122 170M3123 170M4108 170M4109 170M4110 170M4111 170M4112 170M4113 170M4114 170M4115 170M4116 170M4117 170M4118 170M41191 170M5108 170M5109 170M5110 170M5111 170M5112 170M5113 170M5114 170M5115 170M5116 170M5117 170M5118 170M6108 170M6109 170M6110 170M6111 170M6112 170M6113 170M6114 170M6115 170M6116 170M6117 170M6118 170M6119 170M6120 170M6121 -/110 with indicator 170M3158 170M3159 170M3160 170M3161 170M3162 170M3163 170M3164 170M3165 170M3166 170M3167 170M3168 170M3169 170M3170 170M3171 170M3172 170M3173 170M4158 170M4159 170M4160 170M4161 170M4162 170M4163 170M4164 170M4165 170M4166 170M4167 170M4168 170M41691 170M5158 170M5159 170M5160 170M5161 170M5162 170M5163 170M5164 170M5165 170M5166 170M5167 170M5168 170M6158 170M6159 170M6160 170M6161 170M6162 170M6163 170M6164 170M6165 170M6166 170M6167 170M6168 170M6169 170M6170†† 170M6171 -TN/110 Type T indicator for micro 170M3208 170M3209 170M3210 170M3211 170M3212 170M3213 170M3214 170M3215 170M3216 170M3217 170M3218 170M3219 170M3220 170M3221 170M3222 170M3223 170M4208 170M4209 170M4210 170M4211 170M4212 170M4213 170M4214 170M4215 170M4216 170M4217 170M4218 170M42191 170M5208 170M5209 170M5210 170M5211 170M5212 170M5213 170M5214 170M5215 170M5216 170M5217 170M5218 170M6208 170M6209 170M6210 170M6211 170M6212 170M6213 170M6214 170M6215 170M6216 170M6217 170M6218 170M6219 170M6220†† 170M6221 -KN/110 Type K indicator for micro 170M3258 170M3259 170M3260 170M3261 170M3262 170M3263 170M3264 170M3265 170M3266 170M3267 170M3268 170M3269 170M3270 170M3271 170M3272 170M3273 170M4258 170M4259 170M4260 170M4261 170M4262 170M4263 170M4264 170M4265 170M4266 170M4267 170M4268 170M42691 170M5258 170M5259 170M5260 170M5261 170M5262 170M5263 170M5264 170M5265 170M5266 170M5267 170M5268 170M6258 170M6259 170M6260 170M6261 170M6262 170M6263 170M6264 170M6265 170M6266 170M6267 170M6268 170M6269 170M6270 170M6271 † Watts loss at rated current. †† DC voltage rated at 750 Vdc, IR 130 kA DC, UL Recognized, File E12085. 1 Not UL Recognized, 2 Rated voltage: 550 Vac IEC, 3 Rated voltage: 600 Vac IEC, 700 Vac UL, 4 Rated voltage: 600 Vac IEC, 500 Vac UL, 5 Rated voltage: 550 Vac IEC, 500 Vac UL. For details on electrical characteristics, contact Application Engineering and ask for data sheets: 170K6314 (Size 1*), 170K6316 (Size 1), 170K6318 (Size 2), 170K6320 (Size 3) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-41 High speed fuses I²t (A²s) 4 — High speed fuses 170M — Square Body size 00, DIN 43653 1000 Vac (IEC and UL), 20 to 315 A Square body DIN 43653 bolted tags high speed fuses, for the protection of DC common bus, DC drives, power converters/ rectifiers and reduced rated voltage starters. Available with indicator or Type T indicator for a microswitch. Ratings • Volts • 1000 Vac (IEC and UL 20-250 A) • 900 Vac (IEC, 315 A) • Amps 20-315 A • IR 125 kA RMS Sym. Operating class aR Agency information • Designed and tested to IEC 60269 Part 4 • UL Recognized, E125085, JFHR2 (20-250 A) • CSA Class 53787, File 1422-30 (20-250 A) • CE Fuse size Rated voltage 00 1000 Vac (IEC/UL) 900 Vac (IEC) Rated current (amps) 20 25 32 35 40 50 63 80 100 125 160 200 250 315 I²t (A²s) Pre-arcing 20 30 55 69 100 170 280 500 950 1500 3000 5600 10,000 18,000 Clearing at rated voltage 140 210 390 500 690 1200 2000 3500 6850 11,500 22,000 40,500 74,000 115,000 Watts loss (W)† 5 7 9 10 11 13 18 22 25 33 37 40 48 58 Catalog no. 00/80 with indicator 170M4802 170M4803 170M4804 170M4805 170M4806 170M4807 170M4808 170M4809 170M4810 170M4811 170M4812 170M4813 170M4814 170M4815 00TN/80 Type T indicator for micro 170M4822 170M4823 170M4824 170M4825 170M4826 170M4827 170M4828 170M4829 170M4830 170M4831 170M4832 170M4833 170M4834 170M4835 † Watts loss at rated current. Dimensions — mm 2.0 28.0 Indicator 10.0 78.0 Tag for microswitch 27.0 54.0 98.0 27.0 45.0 47.7 10.0 30.0 65.5 For details on electrical characteristics, contact Application Engineering and ask for Data sheet no. 170K8504 4-42 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M — Square Body size 1* to 3, DIN 43653 1000 Vac (IEC and UL), 50 to 1400 A Square body DIN 43653 bolted tags high speed fuses, for the protection of DC common bus, DC drives, power converters/ rectifiers and reduced rated voltage starters. Available with a Type T or K indicator for a microswitch. Ratings • Volts • 1000 Vac (IEC, 50-1250 A), 900 Vac (IEC, 1400 A) • 1000 Vac (UL size 2, size 3, 315-1100 A only) • 900 Vdc (UL, see catalog number table for specific fuses) • Amps 50-1400 A • IR 125 kA RMS Sym. Operating class aR • Designed and tested to IEC 60269 Part 4 • UL Recognized, JFHR2, E125085 (only sizes 2 and 3) • CCC (only size 3, 315-1100 A) • CE High speed fuses Agency Information Dimensions — mm C A C E A Indicator E D1 H D1 G G H E J Type -KN/110 T B E J Type -TN/110 B Type -KN/110 Size 1*KN/110 1KN/110 2KN/110 3KN/110 Type -TN/110 A 80 80 80 81 B 138 138 138 139 C 108 108 108 108 D1 (max) 61 69 77 92 E 43 51 59 74 G 6 6 6 6 H 22 25 25 30 J 11 11 11 11 Size 1*TN/110 1TN/110 2TN/110 3TN/110 A 80 80 80 81 B 138 138 138 139 C 108 108 108 108 D1 (max) 61 69 75 90 E 43 51 59 74 G 6 6 6 6 H 22 25 25 30 For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K8564 (Size 1*), 170K8566 (Size 1), 170K8568 (Size 2), 170K8570 (Size 3) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-43 J 11 11 11 11 4 — High speed fuses 170M — Square Body size 1* to 3, DIN 43653 1000 Vac (IEC and UL), 50 to 1400 A Fuse size Rated voltage 1* 1000 Vac (IEC) 1 1000 Vac (IEC) 2 1000 Vac (IEC and UL) 1000 Vac (IEC and UL) 3 1000 Vac (IEC) 900 Vac (IEC) Rated current (amps) 50 63 80 100 125 160 200 250 315 350 400 160 200 250 315 350 400 450 500 550 630 250 315 350 400 450 500 550 630 700 800 315 350 400 450 500 550 630 700 800 900 1000 1100 1250 1400 I²t (A²s) Clearing at Pre-arcing rated voltage 135 815 215 1300 460 2750 860 5100 1450 8600 2850 17,500 4950 29,500 9550 57,000 21,500 130,000 29,000 175,000 42,000 250,000 2200 13,500 4150 24,500 7750 46,000 16,500 98,500 21,500 130,000 31,000 185,000 44,500 265,000 63,000 375,000 84,500 500,000 125,000 755,000 6750 13,500 16,500 26,000 35,500 49,500 66,000 93,500 130,000 195,000 9200 13,000 19,000 27,000 37,500 52,000 82,500 115,000 170,000 250,000 340,000 460,000 575,000 795,000 40,000 81,500 99,000 155,000 210,000 295,000 390,000 555,000 770,000 1,200,000 54,500 77,500 115,000 160,000 225,000 310,000 490,000 700,000 1,050,000 1,500,000 2,050,000 2,750,000 3,400,000 4,200,000 Watts loss (W)† 20 25 30 35 40 45 50 55 65 70 75 40 45 52 60 65 70 80 85 90 98 65 75 80 85 90 95 100 110 115 125 90 95 105 107 110 115 120 125 135 145 150 155 175 185 Catalog no. -KN/110 Type K indicator -TN/110 Type T indicator for microswitch for microswitch 170M3965 170M3981 170M3966 170M3982 170M3967 170M3983 170M3968 170M3984 170M3969 170M3985 170M3970 170M3986 170M3971 170M3987 170M3972 170M3988 170M3973 170M3989 170M3974 170M3990 170M3975 170M3991 170M4965 170M4980 170M4966 170M4981 170M4967 170M4982 170M4968 170M4983 170M4969 170M4984 170M4970 170M4985 170M4971 170M4986 170M4972 170M4987 170M4973 170M4988 170M4974 170M4989 170M5966 170M5967 170M5968 170M5969 170M5970 170M5971 170M5972 170M5973 170M5974 170M5975 170M8614 170M8615 170M8616 170M8617 170M8618 170M8619 170M8620 170M8621 170M8622 170M8623 170M8624 170M8625 170M8626 170M8627 170M5981 170M5982 170M5983 170M5984 170M5985 170M5986 170M5987 170M5988 170M5989 170M5990 170M8629†† 170M8630†† 170M8631†† 170M8632†† 170M8633†† 170M8634†† 170M8635†† 170M8636†† 170M8637†† 170M8638†† 170M8639†† 170M8640†† 170M8641 170M8642 † Watts loss at rated current. †† DC voltage rated at 900 Vdc, UL Recognized, File E125085. For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K8564 (Size 1*), 170K8566 (Size 1), 170K8568 (Size 2), 170K8570 (Size 3) 4-44 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M — Square Body size 1* to 3, DIN 43653 1250 Vac (IEC), 1300 Vac (UL), 50 to 1400 A Square body DIN 43653 bolted tags high speed fuses, for the protection of DC common bus, DC drives, power converters/ rectifiers and reduced rated voltage starters. Ratings Volts • • 1100 to 1300 Vac (see catalog number table) • 900 and 1000 Vdc (UL, see catalog number table for specific fuses) • Amps 50-1400 A • IR 100 kA RMS Sym. Operating class aR • Designed and tested to IEC 60269 Part 4 • UL Recognized, JFHR2*, E125085 • CSA Class 53787, File 1422-30* • CE High speed fuses Agency information * Consult your Bussmann series product representative for status. Dimensions — mm 1mm = 0.0394” Type-/110-TN/110 Size 1* 1 2 3 A 80 80 80 81 Type-KN/110 B 138 138 138 139 C 108 108 108 108 D1 58 66 75 90 E 45 53 61 76 H 20 25 25 30 K 11 11 11 11 Size 1* 1 2 3 A 80 80 80 81 B 138 138 138 139 C 108 108 108 108 D 60 69 77 92 E 45 53 61 76 H 20 25 25 30 K 11 11 11 11 1 Clip on microswitch valid for -TN/110 fuses. For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6630 (Size 1*), 170K6632 (Size 1), 170K6634 (Size 2), 170K6636 (Size 3) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-45 4 — High speed fuses 170M — Square Body size 1* to 3, DIN 43653, 170M 1250 Vac (IEC), 1300 Vac (UL), 50 to 1400 A I²t (A²s) Fuse size Rated voltage 1* 1250 Vac (IEC) 1300 Vac (UL) 1 1250 Vac (IEC) 1300 Vac (UL) 1100 Vac (IEC) 2 1250 Vac (IEC) 1300 Vac (UL) 1100 Vac (IEC/UL) 1300 Vac (UL) 3 1100 Vac (IEC) Rated current (amps) 50 63 80 100 125 160 200 250 315 350 400 160 200 -/110 with indicator 170M3138 170M3139 170M3140 170M3141 170M3142 170M3143 170M3144 170M3145 170M3146 170M3147 170M3148 170M4138†† 170M4139†† Catalog no. -TN/110 Type T indicator for microswitch 170M3188 170M3189 170M3190 170M3191 170M3192 170M3193 170M3194 170M3195 170M3196 170M3197 170M3198 170M4188†† 170M4189†† -KN/110 Type K indicator for microswitch 170M3238 170M3239 170M3240 170M3241 170M3242 170M3243 170M3244 170M3245 170M3246 170M3247 170M3248 170M4238†† 170M4239†† Pre-arcing 135 215 420 750 1450 2600 5150 9200 18,500 27,000 53,000 1900 3800 Clearing at 1000 Vac 815 1300 2500 4450 9000 16,000 31,000 54,500 115,000 165,000 265,000 11,500 22,500 Clearing at 1250 Vac 1100 1750 3350 5950 11,500 21,000 41,000 73,000 150,000 220,000 335,000 15,500 30,000 Watts loss (W)† 15 20 25 30 35 40 45 55 60 65 70 45 50 250 315 350 400 450 500 550 630 250 280 315 350 400 450 500 550 630 700 800 7750 15,000 20,000 29,500 42,000 69,500 95,000 130,000 6500 9350 13,000 16,500 23,000 34,000 48,000 62,000 115,000 160,000 245,000 46,000 90,000 125,000 175,000 250,000 340,000 465,000 660,000 38,500 55,500 77,500 97,500 140,000 205,000 285,000 370,000 575,000 795,000 1,200,000 61,500 120,000 165,000 235,000 335,000 435,000 590,000 N/A 51,500 74,500 105,000 135,000 180,000 270,000 380,000 495,000 730,000 1,050,000 1,550,000 60 65 70 75 80 85 95 100 65 70 75 80 85 90 95 100 120 125 130 170M4140†† 170M4141†† 170M4142†† 170M4143†† 170M4144†† 170M4145 170M4146 170M41471 170M5138 170M5139 170M5140 170M5141 170M5142 170M5143 170M5144 170M5145 170M5146†† 170M5147†† 170M5148†† 170M4190†† 170M4191†† 170M4192†† 170M4193†† 170M4194†† 170M4195 170M4196 170M41971 170M5188 170M5189 170M5190 170M5191 170M5192 170M5193 170M5194 170M5195 170M5196†† 170M5197†† 170M5198†† 170M4240†† 170M4241†† 170M4242†† 170M4243†† 170M4244†† 170M4245 170M4246 170M42471 170M5238 170M5239 170M5240 170M5241 170M5242 170M5243 170M5244 170M5245 170M5246 170M5247 170M5248 900 1000 315 350 400 450 500 550 630 700 360,000 480,000 9500 13,500 19,500 31,000 39,000 55,000 83,500 115,000 1,750,000 2,350,000 58,000 81,500 120,000 185,000 235,000 325,000 495,000 705,000 N/A N/A 77,500 110,000 160,000 245,000 310,000 435,000 665,000 940,000 135 145 85 90 95 100 105 110 115 120 170M5149†† 170M5150†† 170M6138†† 170M6139†† 170M6140†† 170M6141†† 170M6142†† 170M6143†† 170M6144†† 170M6145†† 170M5199†† 170M5200†† 170M6188†† 170M6189†† 170M6190†† 170M6191†† 170M6192†† 170M6193†† 170M6194†† 170M6195†† 170M5249†† 170M5250†† 170M6238†† 170M6239†† 170M6240†† 170M6241†† 170M6242†† 170M6243†† 170M6244†† 170M6245†† 800 900 1000 1100 1250 205,000 305,000 450,000 575,000 810,000 995,000 1,500,000 2,150,000 2,800,000 3,950,000 1,300,000 1,900,000 2,750,000 3,600,000 N/A 125 130 135 160 170 1400 1,250,000 6,000,000 N/A 175 170M6146††† 170M6147††† 170M6148††† 170M6149††† 170M61501,†† 170M61511,†† 170M6196††† 170M6197††† 170M6198††† 170M6199††† 170M62001 170M62011 170M62461 170M62471 170M62481 170M62491 170M62501 170M62511 † Watts loss at rated current. †† DC voltage rated at 900 Vdc, UL Recognized, File E125085. ††† DC voltage rated at 1000 Vdc, UL Recognized, File E125085. 1 Not UL Recognized. For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6630 (Size 1*), 170K6632 (Size 1), 170K6634 (Size 2), 170K6636 (Size 3) 4-46 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M — Square Body size 00 to 3, DIN 43620, full range (gR) 690 Vac (IEC), 10 to 800 A Square body DIN 43653 blade high speed fuses. Full range protection fuses provide both overload and short-circuit protection. Fuses come with Type T indicator for a microswitch. Ratings • Volts 690 Vac (IEC) • Amps 10-800 A • IR 200 kA RMS Sym. Operating class gR Agency information • Designed and tested to IEC 60269 Part 4 • CE High speed fuses Dimensions — mm Size 00 A 49 B 78.5 D (max) 60 E (max) 30 F 35 G 6 H (min) 15 1 2 3 68 68 68 135 150 150 66 74 89 52 60 75 40 48 60 6 6 6 20 25 32 For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6412 (Size 00), 170K6416 (Size 1), 170K6418 (Size 2), 170K6420 (Size 3) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-47 4 — High speed fuses 170M — Square Body size 00 to 3, DIN 43620, full range (gR) 690 Vac (IEC), 10 to 800 A Fuse size I²t (A²s) Rated voltage 00 690 Vac (IEC) 1 690 Vac (IEC) 2 690 Vac (IEC) 3 690 Vac (IEC) Rated current (amps)1 10 16 20 25 32 40 50 63 80 100 125 160 50 63 80 100 125 160 200 250 315 350 400 200 250 315 350 400 450 500 550 630 350 400 450 500 550 630 700 800 Pre-arcing 3.8 7.2 13.0 24.0 53.0 95.0 185.0 345.0 695.0 1250.0 2300.0 4350.0 135.0 245.0 500.0 950.0 1850.0 3450.0 6750.0 13,500.0 26,000.0 34,000.0 48,500.0 5650.0 10,000.0 19,500.0 26,000.0 39,500.0 55,500.0 73,000.0 100,000.0 150,000.0 23,000.0 34,000.0 48,500.0 64,000.0 84,500.0 125,000.0 160,000.0 245,000.0 Clearing at 690 Vac 20 38 70 125 275 490 1000 1800 3600 6650 12,000 22,500 705 1300 2600 4850 9500 18,000 34,500 70,500 135,000 175,000 250,000 29,000 52,500 105,000 135,000 205,000 290,000 375,000 515,000 770,000 120,000 175,000 250,000 330,000 435,000 645,000 840,000 1,300,000 Watts loss (W)† 3.5 5.5 6.0 8.0 9.0 10.0 11.0 14.0 16.0 19.0 23.0 29.0 12.0 15.0 17.0 20.0 23.0 28.0 31.0 35.0 41.0 45.0 48.0 33.0 40.0 46.0 50.0 53.0 59.0 66.0 70.0 79.0 55.0 59.0 62.0 67.0 70.0 85.0 93.0 99.0 Catalog no. - Type T indicator for microswitch 170M2691 170M2692 170M2693 170M2694 170M2695 170M2696 170M2697 170M2698 170M2699 170M2700 170M2701 170M2702 170M4176 170M4177 170M4178 170M4179 170M4180 170M4181 170M4182 170M4183 170M4184 170M4185 170M4186 170M5881 170M5882 170M5883 170M5884 170M5885 170M5886 170M5887 170M5888 170M5889 170M6080 170M6081 170M6082 170M6083 170M6084 170M6085 170M6086 170M6087 † Watts loss at rated current. 1 The RMS Amp rating of this fuses range is given with open fuse blocks connected to copper conductors according to IEC 60269, Part 1, table 10. When used in enclosed fuse blocks/disconnects, derating factors have to be observed. Please contact Eaton's Bussmann Division for application assistance bulehighspeedtechnical@ eaton.com. For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6412 (Size 00), 170K6416 (Size 1), 170K6418 (Size 2), 170K6420 (Size 3) 4-48 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M — Square Body size 000 to 3, DIN 43620, dual indicator fuses 690 Vac (IEC), 700 Vac (UL), 10 to 1600 A Square body DIN 43620 blade high speed fuses with dual indicator system: one indicator in the fuse body and another one in the metallic end plate. Interchangeable with existing high speed DIN 43620 fuses for the protection of UPS, soft starters, solid state relays, variable speed drives, rectifiers and inverters. Ratings Volts • • 690 Vac (IEC) • 700 Vac (UL) • Amps 10-1600 A • IR 200 kA RMS Sym. • gR (size 000, 10-63 A) • aR (others) High speed fuses Operating class Agency information • Designed and tested to IEC 60269 Part 4 • UL Recognized, JFHR2, E125085 • CSA Class 1422-30, (53787) with the exception of catalog number 170M4867D • CE Dimensions — mm Size A B 000 78.5 53.0 00 78.5 53.0 1 135.0 71.4 2 150.0 71.4 3 150.0 72.4 C 15.0 15.0 20.0 25.1 32.0 D 52 59 64 72 87 E 35 35 40 48 60 F 10 10 10 10 10 G 49.7 49.7 67.5 67.5 68.5 H 1.5 2.0 2.0 2.0 2.5 J 6 6 6 6 6 K 20.5 30.0 40.0 54.0 71.0 For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6386 (Size 000 and 00), 170K6388 (Size 1), 170K6390 (Size 2), 170K6392 (Size 3) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-49 4 — High speed fuses 170M — Square Body size 000 to 3, DIN 43620, dual indicator fuses 690 Vac (IEC), 700 Vac (UL), 10 to 1600 A Fuse size Rated voltage 000 690 Vac (IEC) 700 Vac (UL) 00 690 Vac (IEC) /700 Vac (UL) 1 690 Vac (IEC) 700 Vac (UL) 2 690 Vac (IEC) 700 Vac (UL) 3 690 Vac (IEC) 700 Vac (UL) Rated current (amps) 10 16 20 25 32 40 50 63 80 100 125 160 200 250 315 40 50 63 80 100 125 160 200 250 315 350 400 450 500 550 630 700 400 450 500 550 630 700 800 900 1000 1100 500 550 630 700 800 900 1000 1100 1250 1400 1500 1600 Max permissible load current 10 16 20 25 32 40 50 63 80 100 125 160 200 250 315 25 30 38 50 60 75 95 120 150 I2t (A2s) Pre-arcing 190 210 240 270 300 330 380 420 240 270 300 330 380 420 480 540 600 660 300 330 380 420 480 540 600 660 750 840 900 960 4 7 11.5 19 40 65 115 215 380 695 1180 2300 4350 7900 12,000 40 78 120 185 360 550 1150 2300 4350 7300 10,000 16,000 21,500 27,000 33,500 48,500 69,500 11,000 16,000 21,500 29,000 41,000 60,500 86,000 125,000 180,000 245,000 14,000 19,500 31,000 45,000 69,500 100,000 140,000 190,000 300,000 380,000 470,000 585,000 Watts Clearing at 690 Vac loss (W)3 27 2.5 51 4 82.5 5 140 6 285 7 490 8.5 815 9.5 1550 11.5 2700 15 4950 16.5 8250 21.5 16,500 25 31,000 29.5 56,000 35.5 84,500 45 285 4 550 4.5 850 6.5 1350 8.5 2600 10 3900 11 8250 12 16,500 12.5 31,000 16 Catalog no. 170M1558D 170M1559D 170M1560D 170M1561D 170M1562D 170M1563D 170M1564D 170M1565D 170M1566D 170M1567D 170M1568D 170M1569D 170M1570D 170M1571D 170M1572D 170M3808D 170M3809D 170M3810D 170M3811D 170M3812D 170M3813D 170M3814D 170M3815D 170M3816D 52,000 73,000 115,000 155,000 190,000 240,000 345,000 495,000 79,000 115,000 155,000 215,000 295,000 430,000 610,000 895,000 1,300,000 1,750,000 99,500 140,000 220,000 320,000 490,000 720,000 985,000 1,400,000 2,150,000 2,700,000 3,350,000 4,150,000 170M3817D 170M3818D 170M3819D 170M4863D 170M4864D 170M4865D 170M4866D 170M4867D1 170M5808D 170M5809D 170M5810D 170M5811D 170M5812D 170M5813D 170M5814D 170M5820D 170M5816D 170M5817D 170M6808D 170M6809D 170M6810D 170M6811D 170M6812D 170M6813D 170M6814D 170M6892D 170M8554D 170M8555D 170M8556D 170M8557D 20 21.5 23 26.5 28.5 33 37.5 39 29 32 34 36 42 43 48 52 53 56 43 44 45 46 48 50 56 57 61 70 72 74 1 170M4867D is not UL Recognized. 3 Given at maximum load rated current, please refer to data sheets for further details. For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6386 (Size 000 and 00), 170K6388 (Size 1), 170K6390 (Size 2), 170K6392 (Size 3) 4-50 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M — Square Body size 00, DIN 43620 1000 Vac (IEC and UL), 20 to 225 A Square body DIN 43620 blade style high speed fuses for the protection of DC common bus, DC drives, power converters/rectifiers and reduced rated voltage starters. Fuses come with Type T indicator for microswitches. Ratings Volts • • 1000 Vac (IEC and UL) • 900 Vac (200 and 225 A) • Amps 20-225 A • IR 125 kA RMS Sym. Operating class aR • Designed and tested to IEC 60269 Part 4 • UL Recognized (20-160 A) • CSA (20-160 A) • CE I²t (A²s) Fuse size Rated voltage 00 1000 Vac (IEC/UL) 00 900 Vac (IEC) Rated current (amps) 20 25 32 35 40 50 63 80 100 125 160 200 225 Pre-arcing 15 28.5 53 69 105 215 380 815 1550 3000 6250 12,000 18,000 Clearing at 1000 Vac 110 210 390 500 760 1550 2750 5900 11,500 22,000 45,000 86,500 115,000 Watts loss (W)† 8.5 9.5 11 12 13 14 16 18 21 23 26 31 33 Catalog no. with Type T indicator for microswitch 170M2673 170M2674 170M2675 170M2676 170M2677 170M2678 170M2679 170M2680 170M2681 170M2682 170M2683 170M2684 170M2685 † Watts loss at rated current. Dimensions — mm 20.0 10.0 47.5 2.5 Indicator 60 35.0 48 15.0 52.0 78.5 6.0 30.0 For details on electrical characteristics, contact Application Engineering and ask for Data sheet no. 170K8506 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-51 High speed fuses Agency information 4 — High speed fuses 170M — Square Body size 1* to 3, French style 690 Vac (IEC), 700 Vac (UL), 40 to 1600 A Square body French style high speed fuses for the protection of DC common bus, DC drives, power converters/rectifiers and reduced rated voltage starters. Available with Type T or K indicators for microswitches. Ratings Volts • • 690 Vac (IEC) • 700 Vac (UL) • Amps 40-1600 A • IR 200 kA RMS Sym. Operating class aR Agency information • Designed and tested to IEC 60269 Part 4 • UL Recognized, JFHR2, E125085 • CSA Class 1422-30, (53787) on sizes (1, 2, 3) only • CCC (please consult bulehighspeedtechnical@eaton.com for status) • CE Dimensions — mm Type -E/-, -EKN/Size 1* 1 2 3 A 50 50 50 51 B 102 111 126 126 C 76 86 91 91 D 59 69 77 92 E 45 53 61 76 H 18 25 30 36 J 9 11 13 13 K 13 11 12 13 For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6314 (Size 1*), 170K6316 (Size 1), 170K6318 (Size 2), 170K6320 (Size 3) 4-52 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M —Square Body size 1* to 3, French style 690 Vac (IEC), 700 Vac (UL), 40 to 1600 A Fuse size 1* 1 2 3 690 Vac (IEC) 700 Vac (UL) 690 Vac (IEC) 700 Vac (UL) 690 Vac (IEC) 700 Vac (UL) 690 Vac (IEC) 700 Vac (UL) Rated current (amps) 40 50 63 80 100 125 160 200 250 315 350 400 450 500 200 250 315 350 400 450 500 550 630 700 800 400 450 500 550 630 700 800 900 1000 500 550 630 700 800 900 1000 1100 1250 1400 1500 1600 Pre-arcing 40 77 115 185 360 550 1100 2200 4200 7000 10,000 15,000 21,000 Clearing at 660 Vac 270 515 770 1250 2450 3700 7500 15,000 28,500 46,500 68,500 105,000 140,000 Watts loss (W)† 9 11 14 18 21 26 30 35 40 50 55 60 65 27,000 1650 3100 6200 8500 13,500 17,000 25,000 34,000 52,000 69,500 105,000 11,000 15,500 21,500 28,000 41,000 60,500 86,000 125,000 180,000 14,000 19,500 31,000 44,500 69,500 100,000 140,000 190,000 290,000 370,000 460,000 580,000 180,000 11,500 21,000 42,000 59,000 91,500 120,000 170,000 230,000 350,000 465,000 725,000 74,000 105,000 145,000 190,000 275,000 405,000 575,000 840,000 1,250,000 95,000 135,000 210,000 300,000 465,000 670,000 945,000 1,300,000 1,950,000 2,450,000 3,100,000 3,900,000 70 45 55 58 60 65 70 72 75 80 85 95 65 70 75 80 90 95 105 110 115 95 100 105 110 115 120 125 130 140 155 160 160 Catalog no. -E/- Type T indicator for microswitch 170M3308 170M3309 170M3310 170M3311 170M3312 170M3313 170M3314 170M3315 170M3316 170M3317 170M3318 170M3319 170M3320 170M3321 170M4308 170M4309 170M4310 170M4311 170M4312 170M4313 170M4314 170M4315 170M4316 170M4317 170M4318 170M5308 170M5309 170M5310 170M5311 170M5312 170M5313 170M5314 170M5315 170M5316 170M6308 170M6309 170M6310 170M6311 170M6312 170M6313 170M6314 170M6315 170M6316 170M6317 170M6318 170M6319 -EKN/- Type K indicator for microswitch 170M3358 170M3359 170M3360 170M3361 170M3362 170M3363 170M3364 170M3365 170M3366 170M3367 170M3368 170M3369 170M3370 170M3371 170M4358 170M4359 170M4360 170M4361 170M4362 170M4363 170M4364 170M4365 170M4366 170M4367 170M4368 170M5358 170M5359 170M5360 170M5361 170M5362 170M5363 170M5364 170M5365 170M5366 170M6358 170M6359 170M6360 170M6361 170M6362 170M6363 170M6364 170M6365 170M6366 170M6367 170M6368 170M6369 High speed fuses I²t (A²s) Rated voltage † Watts loss at rated current. For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6314 (Size 1*), 170K6316 (Size 1), 170K6318 (Size 2), 170K6320 (Size 3) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-53 4 — High speed fuses 170M — Square Body size 1* to 3, US style 690 Vac (IEC), 700 Vac (UL), 40 to 2000 A Square body US style bolted tags high speed fuses for the protection of DC common bus, DC drives, power converters/ rectifiers and reduced rated voltage starters. Available with Type K indicator for a microswitch. Ratings • Volts • 500 to 700 Vac (see catalog number table) • 750 Vdc (UL, see catalog number table for specific fuses) • Amps 40-2000 A • IR 200 kA RMS Sym. Operating class aR Agency information • Designed and tested to IEC 60269 Part 4 • UL Recognized, JFHR2*, E125085 • CSA Class 53787, File 1422-30* • CCC* • CE * Consult your Bussmann series product representative for status. Dimensions — mm 1mm = 0.0394” B E G D A C1 C2 J H Type -FU/-, -FKE/-, FU/115-, -FKE/115 Size 1* 1 2 3 A 50 50 50 51 B 110 136 135 135 B1 C1 148 85 157 104 159 105 155 106 C1† 123 126 125 125 C2 72 78 78 77 C2† 110 100 99 97 D 59 69 77 92 E 45 53 61 76 G 6 6 6 6 H 20 25 25 36 J 10 14 14 16 † Valid for fuss types -FU/115 and -FKE/115. For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6314 (Size 1*), 170K6316 (Size 1), 170K6318 (Size 2), 170K6320 (Size 3) 4-54 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M — Square Body size 1* to 3, US style Fuse size 1* Rated voltage 690 Vac (IEC) 700 Vac (UL) 690 Vac (IEC) 1 700 Vac (UL) 550 Vac (IEC) 690 Vac (IEC) 2 700 Vac (UL) 600 Vac (IEC) 700 Vac (UL) 690 Vac (IEC) 700 Vac (UL) 3 600 Vac (IEC) 500 Vac (UL) 550 Vac (IEC) 500 Vac (UL) I²t (A²s) Rated current Clearing at Watts -FU/- without (amps) Pre-arcing 660 Vac loss (W)† indicator 40 40 270 9 170M3608 50 70 515 11 170M3609 63 115 770 14 170M3610 80 185 1250 18 170M3611 100 360 2450 21 170M3612 125 550 3700 26 170M3613 160 1100 7500 30 170M3614 200 2200 15,000 35 170M3615 250 4200 28,500 40 170M3616 315 7000 46,500 50 170M3617 350 10,000 68,500 55 170M3618 400 15,000 105,000 60 170M3619 450 21,000 140,000 65 170M3620 500 27,000 180,000 70 170M3621 550 34,000 230,000 75 170M3622 630 48,500 325,000 80 170M3623 200 1650 11,500 45 170M4608 250 3100 21,000 55 170M4609 315 6200 42,000 58 170M4610 350 8500 59,000 60 170M4611 400 13,500 91,500 65 170M4612 450 17,000 120,000 70 170M4613 500 25,000 170,000 72 170M4614 550 34,000 230,000 75 170M4615 630 52,000 350,000 80 170M4616 700 69,500 465,000 85 170M4617 800 105,000 725,000 95 170M4618 900 155,000 850,000 100 170M4619 400 11,000 74,000 65 170M5608 450 15,500 105,000 70 170M5609 500 21,500 145,000 75 170M5610 550 28,000 190,000 80 170M5611 630 41,000 275,000 90 170M5612 700 60,500 405,000 95 170M5613 800 86,000 575,000 105 170M5614 900 125,000 840,000 110 170M5615 1000 180,000 1,250,000 115 170M5616 1100 245,000 1,600,000 120 170M5617 1250 365,000 2,400,000 130 170M5618 Catalog no. -FKE/- Type K indicator for -FU/115 without microswitch indicator 170M3658 170M3708 170M3659 170M3709 170M3660 170M3710 170M3661 170M3711 170M3662 170M3712 170M3663 170M3713 170M3664 170M3714 170M3665 170M3715 170M3666 170M3716 170M3667 170M3717 170M3668 170M3718 170M3669 170M3719 170M3670 170M3720 170M3671 170M3721 170M3672 170M3722 170M3673 170M3723 170M4658 170M4708 170M4659 170M4709 170M4660 170M4710 170M4661 170M4711 170M4662 170M4712 170M4663 170M4713 170M4664 170M4714 170M4665 170M4715 170M4666 170M4716 170M4667 170M4717 170M4668 170M4718 170M4669 170M4719 170M5658 170M5708 170M5659 170M5709 170M5660 170M5710 170M5661 170M5711 170M5662 170M5712 170M5663 170M5713 170M5664 170M5714 170M5665 170M5715 170M5666 170M5716 170M5667 170M5717 170M5668 170M5718 -FKE/115 Type K indicator for microswitch 170M3758 170M3759 170M3760 170M3761 170M3762 170M3763 170M3764 170M3765 170M3766 170M3767 170M3768 170M3769 170M3770 170M3771 170M3772 170M3773 170M4758 170M4759 170M4760 170M4761 170M4762 170M4763 170M4764 170M4765 170M4766 170M4767 170M4768 170M4769 170M5758 170M5759 170M5760 170M5761 170M5762 170M5763 170M5764 170M5765 170M5766 170M5767 170M5768 500 550 630 700 800 900 1000 1100 1250 1400 1500 1600 14,000 19,500 31,000 44,500 69,500 100,000 140,000 190,000 290,000 370,000 460,000 580,000 95,000 135,000 210,000 300,000 465,000 670,000 945,000 1,300,000 1,950,000 2,450,000 3,100,000 3,900,000 95 100 105 110 115 120 125 130 140 155 160 160 170M6608 170M6609 170M6610 170M6611 170M6612 170M6613 170M6614 170M6615 170M6616 170M6617 170M6618 170M6619 170M6658 170M6659 170M6660 170M6661 170M6662 170M6663 170M6664 170M6665 170M6666 170M6667 170M6668 170M6669 170M6708 170M6709 170M6710 170M6711 170M6712 170M6713 170M6714 170M6715 170M6716 170M6717 170M6718 170M6719 170M6758 170M6759 170M6760 170M6761 170M6762 170M6763 170M6764 170M6765 170M6766 170M6767 170M6768 170M6769 1800 880,000 5,250,000 165 170M6620†† 170M66701 170M6720†† 170M6770 2000 1,150,000 6,350,000 175 170M6621 170M66712 170M6721 170M6771 † Watts loss at rated current. †† DC voltage rated at 750 Vdc, UL Recognized, File E125085. 1 170M6670 600 Vac (IEC)/550 Vac. 2 170M6671 550 Vac (IEC and UL). For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6314 (Size 1*), 170K6316 (Size 1), 170K6318 (Size 2), 170K6320 (Size 3) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-55 High speed fuses 690 Vac (IEC), 700 Vac (UL), 40 to 2000 A 4 — High speed fuses 170M — Square Body size 1* to 3, US style 1000 Vac (IEC), 50 to 1400 A Square body US style bolted tags high speed fuses for the protection of DC common bus, DC drives, power converters/ rectifiers and reduced rated voltage starters. Fuses come with Type K indicator for microswitches. Ratings • Volts 1000 Vac (IEC) (1400 A 900 Vac) • Amps 50-1400 A • IR 125 kA RMS Sym. Operating class aR Agency information • Designed and tested to IEC 60269 Part 4 • UL Recognized, JFHR2, E125085 for size 2 and 3 (315-1100 A) • CSA Class 53787, File 1422-30 for size 2 and 3 (315-1100 A) • CCC approval for size 2 only • CE Dimensions — mm 1mm = 0.0394” Size 1*FKE/115 1FKE/115 2FKE/115 3FKE/115 A 74 76 76 76 B C 101.0 130.0 102.0 128.0 101.1 127.5 101.1 127.5 D 156 160 160 158 F 43 51 59 74 G 60 68 76 91 H 10.4 14.3 14.4 16.0 I 20 25 25 36 K 6 6 6 6 For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K8564 (Size 1*), 170K8566 (Size 1), 170K8568 (Size 2), 170K8570 (Size 3) 4-56 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M — Square Body size 1* to 3, US style, 170M 1000 Vac (IEC), 50 to 1400 A Fuse size Rated voltage 1* 1000 Vac (IEC) 1 2 1000 Vac (IEC) 1000 Vac (IEC/UL) 1000 Vac (IEC/UL) 3 1000 Vac (IEC) 900 Vac (IEC) Rated current (amps) 50 63 80 100 125 160 200 250 315 350 400 Pre-arcing 135 215 460 860 1450 2850 4950 9550 21,500 29,000 42,000 Watts Clearing at 1000 Vac loss (W)† 815 20 1300 25 2750 30 5100 35 8600 40 17,500 45 29,500 50 57,000 55 130,000 65 175,000 70 250,000 75 Catalog no. -FKE/115 Type K indicator for microswitch 170M3531 170M3532 170M3533 170M3534 170M3535 170M3536 170M3537 170M3538 170M3539 170M3540 170M3541 160 200 250 315 350 400 450 500 550 630 2200 4150 7750 16,500 21,500 31,000 44,500 63,000 84,500 125,000 13,500 24,500 46,000 98,500 130,000 185,000 265,000 375,000 500,000 755,000 40 50 55 65 70 75 80 85 90 98 170M4531 170M4532 170M4533 170M4534 170M4535 170M4536 170M4537 170M4538 170M4539 170M4540 250 315 350 400 450 500 550 630 700 800 315 350 400 450 500 550 630 700 800 900 1000 1100 1250 1400 6750 13,500 16,500 26,000 35,500 49,500 66,000 93,500 130,000 195,000 9200 13,000 19,000 27,000 37,500 52,000 82,500 115,000 170,000 250,000 340,000 460,000 575,000 795,000 40,000 81,500 99,000 155,000 210,000 295,000 390,000 555,000 770,000 1,200,000 54,500 77,500 115,000 160,000 225,000 310,000 490,000 700,000 1,050,000 1,500,000 2,050,000 2,750,000 3,400,000 4,200,000 65 75 80 85 90 95 100 110 115 125 90 95 105 107 110 115 120 125 135 145 150 155 175 185 170M5531 170M5532 170M5533 170M5534 170M5535 170M5536 170M5337 170M5538 170M5539 170M5540 170M8531 170M8532 170M8533 170M8534 170M8535 170M8536 170M8537 170M8538 170M8539 170M8540 170M8541 170M8542 170M8543 170M8544 High speed fuses I²t (A²s) † Watts loss at rated current. For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K8564 (Size 1*), 170K8566 (Size 1), 170K8568 (Size 2), 170K8570 (Size 3) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-57 4 — High speed fuses 170M — Square Body size 1* to 3, US style 1250 Vac (IEC), 1300 Vac (UL), 50 to 1400 A Square body US style bolted tags high speed fuses for the protection of DC common bus, DC drives, power converters/ rectifiers and reduced rated voltage starters. Available with Type K indicator for microswitches. Ratings Volts • • 1250 Vac (IEC) • 1300 Vac (UL) • 900 Vdc (UL, see catalog number table for specific fuses) • Amps 50-1400 A • IR 100 kA RMS Sym. Operating class aR Agency information • Designed and tested to IEC 60269 Part 4 • UL Recognized† • CSA† • CCC† • CE † Consult your Bussmann series product representative for status. Dimensions — mm B E G D A C1 C2 J H Type-FU/115,-FKE/115 Size 1* 1 2 3 A 74 76 76 76 B 156 160 160 159 C1 130 127 127 128 C2 101 102 102 101 D 59 69 77 92 E 45 53 61 76 G 6 6 6 6 H 20 25 25 36 J 10 14 14 16 For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6630 (Size 1*), 170K6632 (Size 1), 170K6634 (Size 2), 170K6636 (Size 3) 4-58 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M — Square Body size 1* to 3, US style 1250 Vac (IEC), 1300 Vac (UL), 50 to 1400 A 1* I²t (A²s) Catalog no. Rated current (amps) 50 63 80 100 125 160 200 250 315 350 Pre-arcing 135 215 420 750 1450 2600 5150 9200 18,500 27,000 160 200 250 315 350 400 450 1900 3800 7750 15,000 20,000 29,500 42,000 11,500 22,500 46,000 90,000 125,000 175,000 250,000 15,500 30,000 61,500 120,000 165,000 235,000 335,000 500 550 630 69,500 95,000 130,000 340,000 465,000 660,000 250 280 315 350 400 450 500 550 630 6500 9350 13,000 16,500 23,000 34,000 48,000 62,000 115,000 700 800 -FU/115 without indicator 170M3688†† 170M3689†† 170M3690†† 170M3691†† 170M3692†† 170M3693†† 170M3694†† 170M3695†† 170M3696†† 170M3697†† -FKE/115 Type K indicator for microswitch 170M3738†† 170M3739†† 170M3740†† 170M3741†† 170M3742†† 170M3743†† 170M3744†† 170M3745†† 170M3746†† 170M3747†† 45 50 60 65 70 75 80 170M4688 170M4689 170M4690 170M4691 170M4692 170M4693 170M4694 170M4738 170M4739 170M4740 170M4741 170M4742 170M4743 170M4744 N/A N/A N/A 85 95 100 170M4695 170M4696 170M4697 170M4745 170M4746 170M4747 38,500 55,500 77,500 97,500 140,000 205,000 285,000 370,000 575,000 51,500 74,500 105,000 135,000 180,000 270,000 380,000 495,000 730,000 65 70 75 80 85 90 95 100 120 170M5688 170M5689 170M5690 170M5691 170M5692 170M5693 170M5694 170M5695 170M5696 170M5738 170M5739 170M5740 170M5741 170M5742 170M5743 170M5744 170M5745 170M5746 160,000 245,000 795,000 1,200,000 N/A N/A 125 130 170M5697 170M5698 170M5747 170M5748 900 1000 315 350 400 450 500 550 630 700 360,000 480,000 9500 13,500 19,000 31,000 39,000 55,000 83,500 115,000 1,750,000 2,350,000 58,000 81,500 120,000 185,000 235,000 325,000 495,000 705,000 N/A N/A 77,500 110,000 160,000 245,000 310,000 435,000 665,000 940,000 135 145 85 90 95 100 105 110 115 120 170M5699 170M5700 170M6688 170M6689 170M6690 170M6691 170M6692 170M6693 170M6694 170M6695 170M5749 170M5750 170M6738 170M6739 170M6740 170M6741 170M6742 170M6743 170M6744 170M6745 1100 Vac (IEC) 800 900 1000 205,000 305,000 450,000 995,000 1,500,000 2,150,000 1,300,000 1,900,000 N/A 125 130 135 170M6696 170M6697 170M6698 170M6746 170M6747 170M6748 1000 Vac (UL) 1100 575,000 2,800,000 N/A 160 170M6699 170M6749 1000 Vac (IEC/UL) 1250 1400 810,000 1,250,000 3,950,000 6,000,000 N/A N/A 170 175 170M6700 170M6701 170M6750 170M6751 1250 Vac (IEC) 1300 Vac (UL) 1250 Vac (IEC) 1300 Vac (UL) 1 1100 Vac IEC 1000 Vac IEC 1250 Vac (IEC) 1300 Vac (UL) 2 1100 Vac IEC 1000 Vac IEC 1250 Vac (IEC) 1300 Vac (UL) 3 1250 Vac (IEC) Clearing at Clearing at 1000 Vac 1250 Vac 815 1100 1300 1750 2500 3350 4450 5950 9000 11,500 16,000 21,000 31,000 41,000 54,500 73,000 115,000 150,000 165,000 220,000 Watts loss (W)† 15 20 25 30 35 40 45 55 60 65 High speed fuses Fuse size Rated voltage † Watts loss at rated current. †† DC voltage rated at 900 Vdc, UL Recognized, File E125085. For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6630 (Size 1*), 170K6632 (Size 1), 170K6634 (Size 2), 170K6636 (Size 3) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-59 4 — High speed fuses 170M — Square Body size 00, flush-end contact 690 Vac, 25 to 400 A Square body flush-end contact high speed fuses, for the protection of DC common bus, DC drives, power converters/rectifiers and reduced rated voltage starters. Catalog numbers available with visual indicator and Type T indicator for a microswitch. Ratings • Volts 690 Vac (IEC) • Amps 25-400 A • IR 200 kA RMS Sym. Operating class • gR (25-80 A) • aR (100-400 A) Agency information • Designed and tested to IEC 60269 Part 4 • UL Recognized, JFHR2, E125085 • CSA Class 53787, File 1422-30 on size 000 • CE Fuse size 00 Rated voltage 690 Vac (IEC) Rated current (amps) 25 32 40 50 63 80 100 125 160 200 250 315 350 400 I²t (A²s) Pre-arcing 19.0 28.5 50.0 95.0 170.0 310.0 620.0 1000.0 1900.0 3400.0 6250.0 10,000.0 13,500.0 18,000.0 Clearing at 660 Vac 130 195 360 640 1200 2100 4150 6950 13,000 23,000 42,000 68,500 91,500 125,000 Watts loss (W)† 6 7 9 10 12 15 20 25 30 35 45 55 60 70 Catalog no. 00B/60 visual indicator 170M2708 170M2709 170M2710 170M2711 170M2712 170M2713 170M2714 170M2715 170M2716 170M2717 170M2718 170M2719 170M2720 170M2721 00BTN/60 Type T indicator for microswitch 170M2758 170M2759 170M2760 170M2761 170M2762 170M2763 170M2764 170M2765 170M2766 170M2767 170M2768 170M2769 170M2770 170M2771 † Watts loss at rated current. Dimensions — mm Indicator Ø16 30 48 64 54 62 6 M8 For details on electrical characteristics, contact Application Engineering and ask for Data sheet no. 170K6312 4-60 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M — Square Body size 1* to 3, flush-end contact 690 Vac (IEC), 700 Vac (UL), 40 to 2000 A Square body flush-end contact high speed fuses, for the protection of DC common bus, DC drives, power converters/rectifiers and reduced rated voltage starters. Catalog numbers available with visual indicator and Type K indicator for a microswitch. Ratings • Volts • 500 to 700 Vac (see catalog number table) • 750 Vdc (UL, see catalog number table for specific fuses) • Amps 40-2000 A • IR 200 kA RMS Sym. Operating class aR • Designed and tested to IEC 60269 Part 4 • UL Recognized, JFHR2, E125085† • CSA Class 53787, File 1422-30† • CCC† • CE High speed fuses Agency information † Consult your Bussmann series product representative for status. Dimensions — mm Type -B/- , -BKN/- , -G/- , -GKN/Size 1* 1 A 50 50 B 51 51 D1 59 69 E 45 53 F M8 M8 F2 (in) 5/16-18 UNC-2B 5/16-18 UNC-2B G 5 8 H N17 N20 2 50 51 (400-1000 A) 65 (1100-1250 A) 77 61 M10 3/8-16 UNC-2B 10 N24 3 51 53 (500-1500 A) 65 (1600-2000 A) 92 76 M12 1/2-13 UNC-2B 10 N30 1 Valid for fuse Types -BKN/ and -GKN/. 2 Valid for fuse Types -G- and -GKN/. For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6314 (Size 1*), 170K6316 (Size 1), 170K6318 (Size 2), 170K6320 (Size 3) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-61 4 — High speed fuses 170M — Square Body size 1* to 3, flush-end contact 690 Vac (IEC), 700 Vac (UL), 40 to 2000 A I²t (A²s) Fuse size 1* 1 Rated voltage 690 Vac (IEC) 700 Vac (UL) 690 Vac (IEC) 700 Vac (UL) 550 Vac (IEC) 2 690 Vac (IEC) 700 Vac (UL) 600 Vac (IEC) 700 Vac (UL) 690 Vac (IEC) 700 Vac (UL) 3 600 Vac (IEC) 500 Vac (UL) 550 Vac (IEC) 500 Vac (UL) Rated current (amps) 40 50 63 80 100 125 160 200 250 315 350 400 450 500 550 630 200 250 315 350 400 450 500 550 630 700 800 900 400 450 500 550 630 700 800 900 1000 1100 1250 500 550 630 700 800 900 1000 1100 1250 1400 1500 1600 Watts loss -B/- visual (W)† indicator 9 170M3408 11 170M3409 14 170M3410 18 170M3411 21 170M3412 26 170M3413 30 170M3414 35 170M3415 40 170M3416 50 170M3417 55 170M3418 60 170M3419 65 170M3420 70 170M3421 75 170M3422 80 170M3423 45 170M4408 55 170M4409 58 170M4410 60 170M4411 65 170M4412 70 170M4413 72 170M4414 75 170M4415 80 170M4416 85 170M4417 95 170M4418 100 170M4419 65 170M5408 70 170M5409 75 170M5410 80 170M5411 90 170M5412 95 170M5413 105 170M5414 110 170M5415 115 170M5416 120 170M5417 130 170M5418 95 170M6408 100 170M6409 105 170M6410 110 170M6411 115 170M6412 120 170M6413 125 170M6414 130 170M6415 140 170M6416 155 170M6417 160 170M6418 160 170M6419 Catalog no. -BKN/- Type K indicator for -G/- visual microswitch indicator 170M3458 170M3508 170M3459 170M3509 170M3460 170M3510 170M3461 170M3511 170M3462 170M3512 170M3463 170M3513 170M3464 170M3514 170M3465 170M3515 170M3466 170M3516 170M3467 170M3517 170M3468 170M3518 170M3469 170M3519 170M3470 170M3520 170M3471 170M3521 170M3472 170M3522 170M3473 170M3523 170M4458 170M4508 170M4459 170M4509 170M4460 170M4510 170M4461 170M4511 170M4462 170M4512 170M4463 170M4513 170M4464 170M4514 170M4465 170M4515 170M4466 170M4516 170M4467 170M4517 170M4468 170M4518 170M4469 170M4519 170M5458 170M5508 170M5459 170M5509 170M5460 170M5510 170M5461 170M5511 170M5462 170M5512 170M5463 170M5513 170M5464 170M5514 170M5465 170M5515 170M5466 170M5516 170M5467 170M5517 170M5468 170M5518 170M6458 170M6508 170M6459 170M6509 170M6460 170M6510 170M6461 170M6511 170M6462 170M6512 170M6463 170M6513 170M6464 170M6514 170M6465 170M6515 170M6466 170M6516 170M6467 170M6517 170M6468 170M6518 170M6469 170M6519 -GKN/- Type K indicator for microswitch 170M3558 170M3559 170M3560 170M3561 170M3562 170M3563 170M3564 170M3565 170M3566 170M3567 170M3568 170M3569 170M3570 170M3571 170M3572 170M3573 170M4558 170M4559 170M4560 170M4561 170M4562 170M4563 170M4564 170M4565 170M4566 170M4567 170M4568 170M4569 170M5558 170M5559 170M5560 170M5561 170M5562 170M5563 170M5564 170M5565 170M5566 170M5567 170M5568 170M6558 170M6559 170M6560 170M6561 170M6562 170M6563 170M6564 170M6565 170M6566 170M6567 170M6568 170M6569 Pre-arcing 40 77 115 185 360 550 1100 2200 4200 7000 10,000 15,000 21,000 27,000 34,000 48,500 1650 3100 6200 8500 13,500 17,000 25,000 34,000 52,000 69,500 105,000 155,000 11,000 15,500 21,500 28,000 41,000 60,500 86,000 125,000 180,000 245,000 365,000 14,000 19,500 31,000 44,500 69,500 100,000 140,000 190,000 290,000 370,000 460,000 580,000 Clearing at 660 Vac 270 515 770 1250 2450 3700 7500 15,000 28,500 46,500 68,500 105,000 140,000 180,000 230,000 325,000 11,500 21,000 42,000 59,000 91,500 120,000 170,000 230,000 350,000 465,000 725,000 850,000 74,000 105,000 145,000 190,000 275,000 405,000 575,000 840,000 1,250,000 1,600,000 2,400,000 95,000 135,000 210,000 300,000 465,000 670,000 945,000 1,300,000 1,950,000 2,450,000 3,100,000 3,900,000 1800 880,000 5,250,000 165 170M6420†† 170M6470 170M6520†† 170M6570 2000 1,150,000 6,350,000 175 170M6421 170M6471 170M6521 170M6571 † Watts loss at rated current. †† DC voltage rated at 750 Vdc, UL Recognized, File E125085. For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6314 (Size 1*), 170K6316 (Size 1), 170K6318 (Size 2), 170K6320 (Size 3) 4-62 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M — Square Body size 1* to 3, flush-end contact 1000 Vac (IEC and UL), 50 to 1400 A Square body flush-end contact high speed fuses, for the protection of DC common bus, DC drives, power converters/rectifiers and reduced rated voltage starters. Catalog numbers come with Type K indicator for use with microswitches. Ratings Volts • • 1000 Vac (IEC, 50-1250 A) • 1000 Vac (UL, 250-1100 A) • 900 Vac (IEC, 1400 A • Amps 50-1400 A • IR 125 kA RMS Sym. Operating class aR • Designed and tested to IEC 60269 Part 4 • UL Recognized, JFHR2, E125085 (only sizes 2 and 3 up to 1100 A) • CE High speed fuses Agency information Dimensions — mm Type -BKN/- and -GKN/Size 1* 1 2 3 Type BKN/75 BKN/75 BKN/75 BKN/75 BKN/90 + + + + + GKN/75 GKN/75 GKN/75 GKN/75 GKN/90 A 72.5 73.2 73.2 73.3 80.3 B 74.0 74.0 74.4 75.4 91.4 D (max) 61 69 77 92 92 E 43 52 59 74 74 F M8 M8 M10 M12 M12 F1 (in) 5/16-18 UNC-2B 5/16-18 UNC-2B 3/8-16 UNC-2B 1/2-13 UNC-2B 1/2-13 UNC-2B G (min) 5 8 10 10 10 H 17.5 20.0 24.5 30.0 30.0 1 Valid for fuse Types -GKN/-. For details on electrical characteristics, contact Application Engineering and ask for data sheets: 170K8564 (Size 1*), 170K8566 (Size 1), 170K8568 (Size 2), 170K8570 (Size 3) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-63 4 — High speed fuses 170M — Square Body size 1* to 3, flush-end contact 1000 Vac (IEC and UL), 50 to 1400 A Fuse size Rated voltage 1* 1000 Vac (IEC) 1 1000 Vac IEC) 2 1000 Vac (IEC/UL) 1000 Vac (IEC/UL) 3 1000 Vac (IEC) 900 Vac (IEC) Rated current (amps) 50 63 80 100 125 160 200 250 315 350 400 160 200 250 315 350 400 450 500 550 630 250 315 350 400 450 500 550 630 700 800 315 350 400 450 500 550 630 700 800 900 1000 1100 1250 1400 I²t (A²s) Pre-arcing 135 215 460 860 1450 2850 4950 Clearing at rated voltage 815 1300 2750 5100 8600 17,500 29,500 9550 21,500 29,000 42,000 2200 4150 7750 16,500 21,500 31,000 44,500 63,000 84,500 125,000 6750 13,500 16,500 26,000 35,500 49,500 66,000 93,500 130,000 195,000 9200 13,000 19,000 27,000 37,500 52,000 82,500 115,000 170,000 250,000 340,000 460,000 575,000 795,000 57,000 130,000 175,000 250,000 13,500 24,500 46,000 98,500 130,000 185,000 265,000 375,000 500,000 755,000 40,000 81,500 99,000 155,000 210,000 295,000 390,000 555,000 770,000 1,200,000 54,500 77,500 115,000 160,000 225,000 310,000 490,000 700,000 1,050,000 1,500,000 2,050,000 2,750,000 3,400,000 4,200,000 Watts loss (W)† 20 25 30 35 40 45 50 Catalog no. -BKN/- Type K indicator for microswitch 170M3951 170M3952 170M3953 170M3954 170M3955 170M3956 170M3957 55 65 70 75 40 45 52 60 65 70 80 85 90 98 65 75 80 85 90 95 100 110 115 125 90 95 105 107 110 115 120 125 135 145 150 155 175 185 170M3958 170M3959 170M3960 170M3961 170M4951 170M4952 170M4953 170M4954 170M4955 170M4956 170M4957 170M4958 170M4959 170M4960 170M5952 170M5953 170M5954 170M5955 170M5956 170M5957 170M5958 170M5959 170M5960 170M5961 170M8600 170M8601 170M8602 170M8603 170M8604 170M8605 170M8606 170M8607 170M8608 170M8609 170M8610 170M8611 170M86121 170M86131 -GKN/- Type K indicator for microswitch 170M3921 170M3922 170M3923 170M3924 170M3925 170M3926 170M3927 170M3928 170M3929 170M3930 170M3931 170M4921 170M4922 170M4923 170M4924 170M4925 170M4926 170M4927 170M4928 170M4929 170M4930 170M5922 170M5923 170M5924 170M5925 170M5926 170M5927 170M5928 170M5929 170M5930 170M5931 170M8500 170M8501 170M8502 170M8503 170M8504 170M8505 170M8506 170M8507 170M8508 170M8509 170M8510 170M8511 170M85121 170M85131 † Watts loss at rated current. 1 Overall length is 90mm, for all other fuses the overall length is 75mm. For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K8564 (Size 1*), 170K8566 (Size 1), 170K8568 (Size 2), 170K8570 (Size 3) 4-64 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M — Square Body size 1* to 3, flush-end contact 1250 Vac (IEC), 1300 Vac (UL), 50 to 1400 A Square body flush-end contact high speed fuses, for the protection of DC common bus, DC drives, power converters/rectifiers and reduced rated voltage starters. Catalog numbers come with Type K indicator for use with microswitches. Ratings Volts • • 1250 Vac (IEC) • 1300 Vac (UL) • 900 and 1000 Vdc (UL, see catalog number table for specific fuses) • Amps 50-1400 A • IR 100 kA RMS Sym. Operating class aR • Designed and tested to IEC 60269 Part 4 • UL Recognized, JFHR2, E125085† • CSA Class 53787, File 1422-30† • CE High speed fuses Agency information † Consult your Bussmann series product representative status. Dimensions — mm Type -BKN/- and -GKN/Size 1* 1 2 3 Type BKN + GKN/75 BKN/80 BKN + GKN/75 BKN/80 BKN + GKN/75 BKN/80 BKN + GKN/90 BKN + GKN/75 BKN/80 BKN + GKN/90 A 74 80 74 80 74 80 80 74 81 81 B 75 81 75 81 75 81 91 76 83 91 D 59 59 69 69 77 77 77 92 92 92 E 45 45 53 53 61 61 61 76 76 76 F M8 M8 M8 M8 M10 M10 M10 M12 M12 M12 F1 (in) 5/16-18 UNC-2B 3/8-16 UNC-2B 1/2-13 UNC-2B Min G 5 5 8 8 10 10 10 10 10 10 HØ 17 17 20 20 24 24 24 30 30 30 1 Valid for fuse Types -GKN/-. For details on electrical characteristics, contact Application Engineering and ask for data sheets: 170K6630 (Size 1*), 170K6632 (Size 1), 170K6634 (Size 2), 170K6636 (Size 3) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-65 4 — High speed fuses 170M — Square Body size 1* to 3, flush-end contact 1250 Vac (IEC), 1300 Vac (UL), 50 to 1400 A Fuse size 1* 1 2 3 Rated voltage 1250 Vac (IEC) 1300 Vac (UL) 1250 Vac (IEC) 1300 Vac (UL) 1250 Vac (IEC) 1300 Vac (UL) 1250 Vac (IEC) 1300 Vac (UL) Rated current (amps) 50 63 80 100 125 160 200 250 315 350 400 160 200 250 315 350 400 450 500 550 630 250 280 315 350 400 450 500 550 630 700 800 900 1000 315 350 400 450 500 550 630 700 800 900 1000 1100 1250 Prearcing 135 215 420 750 1450 2600 5150 9200 18,500 27,000 53,000 1900 3800 7750 15,000 20,000 29,500 42,000 69,500 95,000 130,000 6500 9350 13,000 16,500 23,000 34,000 48,000 62,000 115,000 160,000 245,000 360,000 480,000 9500 13,500 19,500 31,000 39,000 55,000 83,500 115,000 205,000 305,000 450,000 575,000 810,000 I²t (A²s) Clearing at 1000 Vac 815 1300 2500 4450 9000 16,000 31,000 54,500 115,000 165,000 265,000 11,500 22,500 46,000 90,000 125,000 175,000 250,000 340,000 465,000 660,000 38,500 55,500 77,500 97,500 140,000 205,000 285,000 370,000 575,000 795,000 1,200,000 1,750,000 2,350,000 58,000 81,500 120,000 185,000 235,000 325,000 495,000 705,000 995,000 1,500,000 2,150,000 2,800,000 3,950,000 Clearing Watts -BKN/75 Type at 1250 loss K indicator for Vac (W)† micro 1100 15 170M3388†† 1750 20 170M3389†† 3350 25 170M3390†† 5950 30 170M3391†† 11,500 35 170M3392†† 21,000 40 170M3393†† 41,000 45 170M3394†† 73,000 55 170M3395†† 150,000 60 170M3396†† 220,000 65 170M3397†† 335,000 70 — 15,500 45 170M4388†† 30,000 50 170M4389†† 61,500 60 170M4390†† 120,000 65 170M4391†† 165,000 70 170M4392†† 235,000 75 170M4393†† 335,000 80 170M4394†† 435,000 85 170M43954 590,000 95 170M43965 N/A 110 170M43975 51,500 65 170M5388 74,500 70 170M5389 105,000 75 170M5390 135,000 80 170M5391 180,000 85 170M5392 270,000 90 170M5393 380,000 95 170M5394 495,000 100 170M5395 730,000 120 170M53964 1,050,000 125 170M53975 1,550,000 130 170M53985 N/A 135 — N/A 145 — 77,500 85 170M6338†† 110,000 90 170M6339†† 160,000 95 170M6340†† 245,000 100 170M6341†† 310,000 105 170M6342†† 435,000 110 170M6343†† 665,000 115 170M6344†† 940,000 120 170M6345 1,300,000 125 170M63464 1,900,000 130 170M63475 2,750,000 135 170M63485 3,600,000 160 170M63495 N/A 170 — 1400 1,250,000 6,000,000 N/A 175 — -BKN/80 Type K indicator for micro 170M3438 170M3439 170M3440 170M3441 170M3442 170M3443 170M3444 170M3445 170M3446 170M3447 170M3448 170M4438†† 170M4439†† 170M4440†† 170M4441†† 170M4442†† 170M4443†† 170M4444†† 170M4445 170M4446 170M44474 170M5438 170M5439 170M5440 170M5441 170M5442 170M5443 170M5444 170M5445 170M5446 170M54471††† 170M54482††† — — 170M6538†† 170M6539†† 170M6540†† 170M6541†† 170M6542†† 170M6543†† 170M6544†† 170M6545†† 170M6546†† 170M65471†† 170M65481†† 170M65492†† — — Catalog no. -BKN/90 Type K indicator for micro — — — — — — — — — — — — — — — — — — — — — — — — — — — 170M5494 170M5495 170M5496 170M5497 170M5498 170M54993†† 170M55003†† — — — — — — 170M6494†† 170M6495†† 170M6496††† 170M6497††† 170M6498††† 170M6499††† 170M65003†† 170M65013†† -GKN/75 Type K indicator for micro 170M3488†† 170M3489†† 170M3490†† 170M3491†† 170M3492†† 170M3493†† 170M3494†† 170M3495†† 170M3496†† 170M3497†† — 170M4488 170M4489 170M4490 170M4491 170M4492 170M4493 170M4494 170M44954 170M44965 170M44975 170M5588 170M5589 170M5590 170M5591 170M5592 170M5593 170M5594 170M5595 170M55964 170M55975 170M55985 — — 170M6588 170M6589 170M6590 170M6591 170M6592 170M6593 170M6594 170M6595 170M65964 170M65975 170M65985 170M65995 — — -GKN/90 Type K indicator for micro — — — — — — — — — — — — — — — — — — — — — — — — — — — 170M5644 170M5645 170M5646 170M5647 170M5648 170M56493†† 170M56503†† — — — — — — 170M6644 170M6645†† 170M6646††† 170M6647††† 170M6648††† 170M6649††† 170M66504 170M66514 † Watts loss at rated current. †† DC voltage rated at 900 Vdc, UL Recognized, File E125085. ††† DC voltage rated at 1000 Vdc, UL Recognized, File E125085. 1 Rated voltage 1100 Vac (IEC), 1000 Vac (UL). 2 Rated voltage 1000 Vac (IEC and UL). 3 Rated voltage 1100 Vac (IEC and UL). 4 Rated voltage (IEC) 1100 Vac. 5 Rated voltage (IEC) 1000 Vac. For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6630 (Size 1*), 170K6632 (Size 1), 170K6634 (Size 2), 170K6636 (Size 3) 4-66 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M — Square Body size 4, flush-end contact 690 Vac (IEC), 700 Vac (UL), 1000 to 4000 A Square body, flush-end contact, high speed fuses, for the protection of power rectifiers. Catalog numbers come with visual indicator or Type K indicator for use with microswitches. Ratings Volts • • 690 Vac (IEC)/700 Vac (UL) 1000-3500 A • 600 Vac (IEC and UL, 4000 A) • Amps 1000-4000 A • IR 200 kA RMS Sym. Operating class aR Agency information Designed and tested to IEC 60269 Part 4 • UL Recognized, JFHR2, E125085 • CE Fuse size High speed fuses • Rated voltage 690 Vac (IEC) 4 700 Vac (UL) 600 Vac (IEC/UL) Rated current (amps) 1000 1250 1400 1600 2000 2500 3000 3500 4000 I²t (A²s) Pre-arcing 76,000 145,000 205,000 305,000 600,000 1,200,000 2,000,000 3,250,000 4,700,000 Clearing at Watts loss -B/65 visual 660 Vac (W)† indicator 505,000 175 170M7058 965,000 195 170M7059 1,400,000 205 170M7060 2,050,000 220 170M7061 3,950,000 245 170M7062 7,800,000 275 170M7063 13,500,000 305 170M7064 22,000,000 325 170M7065 28,000,0001 355 170M7066 Catalog no. -BKN/65 Type K indicator 170M7078 170M7079 170M7080 170M7081 170M7082 170M7083 170M7084 170M7085 170M7086 -G/65 visual indicator 170M7098 170M7099 170M7100 170M7101 170M7102 170M7103 170M7104 170M7105 170M7106 -GKN/65 Type K indicator 170M7118 170M7119 170M7120 170M7121 170M7122 170M7123 170M7124 170M7125 170M7126 † Watts loss at rated current. 1 Clearing at 600 Vac. For details on electrical characteristics, contact Application Engineering and ask for Data sheet no. 170K6328 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-67 4 — High speed fuses 170M — Square Body size 4, flush-end contact 690 Vac (IEC), 700 Vac (UL), 1000 to 4000 A Dimensions — mm Type -BKN/65, -GKN/65 Type -GKN/65 PCD Ø 38.1 Thread 1/2-13 UNC -BKN/65 Ø 33.0 M-10 PCDØ 38.1 33.0 Thread 1/2-13 UNC M-10 Type -B/65, -G/65 Type -G/65 -B/65 For details on electrical characteristics, contact Application Engineering and ask for Data sheet no.170K6328 4-68 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M — Square Body size 4, flush-end contact 1000 Vac (IEC), 1000 to 3000 A Square body, flush-end contact, high speed fuses, for the protection of power rectifiers. Catalog numbers come with visual indicator or Type K indicator for use with microswitches. Ratings • Volts 1000 Vac (IEC) • Amps 1000-3000 A • IR 200 kA RMS Sym. Operating class aR • Designed and tested to IEC 60269 Part 4 • UL Recognized, JFHR2, E125085 • CE Fuse size 4 Rated voltage 1000 Vac Rated current (amps) 1000 1100 1500 1700 1800 2000 I²t (A²s) Pre-arcing 180,000 250,000 600,000 850,000 1,000,000 1,450,000 Clearing at 1000 Vac 1,100,000 1,500,000 3,600,000 5,000,000 5,950,000 8,600,000 Watts loss (W)† 195 200 250 260 265 270 2200 2500 2700 3000 2,000,000 3,000,000 3,700,000 4,700,000 12,000,000 18,000,000 22,000,000 28,000,000 280 295 310 380 Catalog no. -BKN/95 Type K indicator — — 170M7636 170M7639 170M7661 170M7963 -SBKN/90 Type K indicator 170M7542 170M7031 170M7548 170M7034 170M7053 170M7544 170M7090 170M7640 170M7658 170M7962 170M7035 170M7036 170M7037 170M7156 † Watts loss at rated current. Dimensions — mm Type 4BKN/95 Type 4SBKN/90 For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K8520, 170K8520-R BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-69 High speed fuses Agency information 4 — High speed fuses 170M — Square Body size 4, flush-end contact 1250 Vac (IEC), 800 to 2500 A Square body, flush-end contact, high speed fuses, for the protection of power rectifiers. Catalog numbers come with visual indicator or Type K indicator for use with microswitches. Ratings • Volts • 1250 Vac (IEC) • 1200 Vdc (UL) • Amps 800-2500 A • IR • 200 kA RMS Sym. • 85 kA DC (L/R 2 ms) Agency information Operating class aR Fuse size Rated voltage 4 1250 Vac (IEC) 1200 Vdc (UL) Rated current (amps) 800 1000 1200 1400 1500 1700 1800 2000 2200 2400 2500 I²t (A²s) Pre-arcing Clearing at 1250 Vac 145,000 905,000 275,000 1,750,000 495,000 3,100,000 800,000 5,000,000 1,000,000 6,200,000 1,400,000 8,700,000 1,700,000 11,000,000 2,300,000 14,500,000 3,100,000 19,500,000 4,000,000 25,000,000 4,500,000 28,000,000 • Designed and tested to IEC 60269 Part 4 • UL Recognized, JFHR2, E125085 • cURus JFHR2, E125085 • CE Watts loss (W)† 195 220 240 250 260 275 280 305 315 330 340 Catalog no. -BKN/105 Type K indicator 170M7802 170M7803 170M7804 170M7217 170M7597 170M7676 170M7532 170M7633 170M7592 170M7107 170M7595 -SBKN/105 Type K indicator — — — 170M7512 170M7510 170M7511 170M7976 170M7513 170M7546 170M7516 170M7978 † Watts loss at rated current. Dimensions — mm Type 4BKN/105 Type 4SBKN/105 For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6640 (1400-2400 A), 170K6642 (800-1200, 2500 A) 4-70 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M — Square Body size 23, flush-end contact 660 Vac (IEC), 1000 to 4000 A Square body, flush-end contact, high speed fuses, for the protection of power rectifiers. Catalog numbers available with Type K indicator for use with microswitches. Ratings • Volts • 660 Vac (IEC, 1000-3000 A) • 600 Vac (IEC, 3500 A) • 550 Vac (IEC, 4000 A) • Amps 1000-4000 A • IR 100 kA RMS Sym. Operating class aR Agency information Designed and tested to IEC 60269 Part 4 • UL Recognized, JFHR2, E125085 • CE High speed fuses • I²t (A²s) Fuse size Rated voltage 660 Vac (IEC) 23 Rated current (amps) Pre-arcing Catalog no. Watts Clearing at loss 660 Vac (W)† -BU/55 -BKE/55 Type K indicator -BKN/55 Type K indicator -GU/55 -GKE/55 Type K indicator -GKN/55 Type K indicator 1000 79,000 530,000 170 170M6858 170M6898 170M6878 170M6918 170M6958 1100 95,000 635,000 185 170M6859 170M6899 170M6879 170M6919 170M6959 170M6938 170M6939 1250 155,000 1,050,000 190 170M6860 170M6900 170M6880 170M6920 170M6960 170M6940 1400 200,000 1,350,000 210 170M6861 170M6901 170M6881 170M6921 170M6961 170M6941 1500 240,000 1,650,000 215 170M6862 170M6902 170M6882 170M6922 170M6962 170M6942 1600 315,000 2,150,000 220 170M6863 170M6903 170M6883 170M6923 170M6963 170M6943 1800 450,000 3,050,000 230 170M6864 170M6904 170M6884 170M6924 170M6964 170M6944 2000 625,000 4,200,000 240 170M6865 170M6905 170M6885 170M6925 170M6965 170M6945 2200 805,000 5,400,000 255 170M6866 170M6906 170M6886 170M6926 170M6966 170M6946 2500 1,250,000 8,350,000 265 170M6867 170M6907 170M6887 170M6927 170M6967 170M6947 3000 2,250,000 15,500,000 285 170M6868 170M6908 170M6888 170M6928 170M6968 170M6948 600 Vac (IEC) 3500 3,450,000 21,000,0001 315 170M6869 170M6909 170M6889 170M6929 170M6969 170M6949 550 Vac (IEC) 4000 5,000,000 340 170M6870 170M6910 170M6890 170M6930 170M6970 170M6950 27,500,0002 † Watts loss at rated current. 1 Clearing at 600 Vac. 2 Clearing at 550 Vac. When using these fuses, please consult our application engineers. For details on electrical characteristics, contact Application Engineering and ask for Data sheet no. 170K6326 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-71 4 — High speed fuses 170M — Square Body size 23, flush-end contact 660 Vac (IEC), 1000 to 4000 A Dimensions — mm Type -BU/55, -BKE/55, -BKN/55 Type -GU/55, -GKE/55, -GKN/55 When using these fuses, please consult our application engineers. For details on electrical characteristics, contact Application Engineering and ask for Data sheet no.170K6326 4-72 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M — Square Body size 23, flush-end contact 1250 Vac (IEC), 630 to 2800 A Square body, flush-end contact, high speed fuses, for the protection of power rectifiers. Catalog numbers available with visual indicator or Type K indicator for use with microswitches. Ratings • Volts • 1250 Vac (IEC 630 to 2200 A) • 1100 Vac (IEC 2500 and 2800 A) • 900 Vdc (UL, see catalog number table for specific fuses) • Amps 630-2800 A • IR 125 kA RMS Sym. Operating class aR Agency information Designed and tested to IEC 60269 Part 4 • UL Recognized • CE High speed fuses • I²t (A²s) Fuse size Rated voltage 1250 Vac (IEC) 23 1100 Vac (IEC) Rated current (amps) 630 Watts Clearing at loss Pre-arcing 1250 Vac (W)† 38,000 310,000 170 -BU/75 visual indicator 170M6775 -BKE/75 Type K indicator 170M6795 Catalog no. -BU/80 -BKN/75 visual Type K indicator indicator 170M6785 — -BKE/80 Type K indicator — -BKN/80 Type K indicator — 700 54,000 440,000 180 170M6776 170M6796 170M6786 — — — 800 78,000 640,000 190 170M6777 170M6797 170M6787 — — — 900 120,000 980,000 200 170M6805 170M6807 170M6806 — — — 1000 155,000 1,250,000 210 170M6778 170M6798 170M6788 — — — 1100 220,000 1,750,000 220 170M6779 170M6799 170M6789 — — — 1250 330,000 2,700,000 230 170M6780 170M6800 170M6790 — — — 1400 460,000 3,800,000 240 170M6781 170M6801 170M6791 — — — 1600 820,000 5,200,000 250 170M6782 170M6802 170M6792 — — — — — — 1800 1,200,000 7,600,000 260 170M6783†† 170M6803†† 170M6793†† 2000 1,800,000 11,000,000 270 — — — 170M6784 170M6804 170M6794 170M6815 170M6833 170M6827 2200 2,300,000 14,500,000 280 — — — 2500 3,200,000 16,000,0001 290 — — — 170M6816 170M6834 170M6828 2800 5,000,000 24,000,0001 300 — — — 170M6817 170M6835 170M6829 † Watts loss at rated current. †† DC voltage rated at 900 Vdc, UL Recognized, File E125085. 1 Clearing at 1000 V. When using these fuses, please consult our application engineers. Dimensions — mm For details on electrical characteristics, contact Application Engineering and ask for Data sheet no.170K6638 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-73 4 — High speed fuses 170M — Square Body size 24, flush-end contact 690 Vac (IEC), 2000 to 7500 A Square body, flush-end contact, high speed fuses, for the protection of power rectifiers. Catalog numbers available with Type K indicator for use with microswitches. Ratings Volts • • 690 Vac (IEC 2000 to 7000 A) • 500 Vac (IEC 7500 A) • Amps 2000-7500 A • IR 200 kA RMS Sym. Operating class aR Agency information • Designed and tested to IEC 60269 Part 4 • UL Recognized, JFHR2, E125085 • CE Fuse size Rated voltage 24 690 Vac (IEC) 500 Vac (IEC) Rated current (amps) 2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 7000 7500 I²t (A²s) Clearing at Watts loss -BU/60 without Pre-arcing 660 Vac (W)† indicator 340,000 2,300,000 340 170M7138 650,000 4,350,000 390 170M7139 1,100,000 7,300,000 430 170M7140 1,800,000 12,000,000 460 170M7141 2,700,000 18,000,000 490 170M7142 3,800,000 25,500,000 520 170M7143 5,450,000 36,500,000 540 170M7144 7,400,000 49,500,000 560 170M7145 9,600,000 64,000,000 580 170M7146 12,500,000 83,000,000 600 170M7147 15,000,000 100,000,000 630 170M7148 18,500,000 93,000,0001 660 170M7149 Catalog no. -BKN/60 Type -GU/60 without K indicator indicator 170M7158 170M7198 170M7159 170M7199 170M7160 170M7200 170M7161 170M7201 170M7162 170M7202 170M7163 170M7203 170M7164 170M7204 170M7165 170M7205 170M7166 170M7206 170M7167 170M7207 170M7168 170M7208 170M7169 170M7209 † Watts loss at rated current. 1 Clearing at 500 Vac. When using these fuses, please consult our application engineers. Dimensions — mm Size 24 Type BKN GKN A 2x3 M12 2x3 1/2-13 UNC-2B For details on electrical characteristics, contact Application Engineering and ask for Data sheet no.170K6332 4-74 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries -GKN/60 Type K indicator 170M7218 170M7219 170M7220 170M7221 170M7222 170M7223 170M7224 170M7225 170M7226 170M7227 170M7228 170M7229 High speed fuses — 4 170M — Square Body size 24, flush-end contact 1000 Vac (IEC), 2000 to 5000 A Square body, flush-end contact, high speed fuses, for the protection of power rectifiers. Catalog numbers come with Type K indicator for use with microswitches. Ratings • Volts 1000 Vac (IEC) • Amps 2000-5000 A • IR 166 kA RMS Sym. Operating class aR • Designed and tested to IEC 60269 Part 4 • UL Recognized, JFHR2, E125085 • CE I²t (A²s) Fuse size Rated voltage 24 1000 Vac (IEC) Rated current (amps) 2000 3000 3200 3500 4000 4200 4500 5000 Pre-arcing 900,000 2,950,000 3,300,000 4,500,000 6,800,000 8,000,000 10,000,000 14,000,000 Clearing at 1000 Vac 5,350,000 17,500,000 20,000,000 27,000,000 40,000,000 47,500,000 59,000,000 82,500,000 Watts loss (W)† 345 430 440 450 475 485 495 540 Catalog no. -BKN/85 Type K indicator 170M7608 170M7680 170M7567 170M7568 170M7569 170M7498 170M7488 170M7622 † Watts loss at rated current. When using these fuses, please consult our application engineers. Dimensions — mm The normal position of the indicator is as shown position "N", position "E" on request only. For details on electrical characteristics, contact Application Engineering and ask for Data sheet no.170K8514 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-75 High speed fuses Agency information 4 — High speed fuses Square Body fuse accessories Fixed center fuse blocks for DIN 43653 fuses Fuse blocks for use with DIN 43653 square body fuses with center distances of 80 and 110mm. Available for sizes 000, 00, 1*, 1, 2 and 3. Sizes 000 to 00 Catalog no. 170H1007 170H1013 Max rated voltage 1000 690 Max fuse amp rating 400 200 Center distance (mm) 80 80 Fuse sizes 00, 000 0000, 000 Dimensions — mm 170H1007 170H1013 4-76 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 Square Body fuse accessories Fixed center fuse blocks for DIN 43653 fuses Sizes 1* to 3 Catalog no. 170H3003 170H3004† Max rated voltage 1000 1000 170H3005 170H3006† Max fuse amp rating 630 1250 Center distance (mm) 80 80 1400 630 110 1400 1250 110 † Fuses with ratings higher than 1250 A can be used with 170H3004 or 170H3006 if the maximum load current is derated according to this table. Fuse amp rating 1400 1500 1600 1800 2000 Max. amp load in fuse block 1325 1400 1500 1650 1800 High speed fuses Dimensions — mm 170H3003 170H3005 170H3004 170H3006 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-77 4 — High speed fuses Square Body fuse accessories Indicators High speed square body fuses are available with the following indicators. Visual indicator The indicator situated in one end plate is clearly visible as soon as the fuse has operated. The minimum rated voltage for operating the indicator is 20 V. Type T indicator The indicator is situated on one cover plate with a cover plate tag to accommodate an auxiliary switch. The minimum rated voltage for operating the indicator is 20 V. A special low rated voltage indicator (1.5 V) is available on request. Type K indicator The indicator is situated on the fuse body. It is covered by an adapter for snap-on mounting of a microswitch. The rated operating voltage of the indicator is 1.5 V. As a matter of safety, the factory mounted adapter must not be removed from the fuse. Microswitches High speed square body fuses with either Type T or K indicators can be equipped with a microswitch for remote signaling of fuse operation. All microswitches have one normally open (NO) and one normally closed (NC) contact. Ratings • Volts 250 Vac • Amps 5 A Catalog numbers DIN 43653 Fuse size 000 00 1* 1 2 3 DIN 43620 French style Flush-end US style Type T Type K aR gR and dual indication Type T Type K Type T Type K Type K 170H0236 — 170H0236 170H0236 — — — — — 170H0238 — 170H0238 170H0238 — — — — — Quick connect terminal size (mm) 170H0235 170H0069 170H0235 — 170H0236 170H0069 — 170H0069 170H0069 170H0237 — 170H0237 — 170H0238 — — — — 6.3x0.8 2.8x0.5 6.3x0.8 2.8x0.5 6.3x0.8 2.8x0.5 1 170H0235 — 170H0236 170H0236 — — 170H0235 — — 170H0237 — 170H0238 170H0238 — — 170H0237 — — 170H0235 170H0069 170H0235 170H0236 170H0236 170H0069 — 170H0069 170H0069 6.3x0.8 170H0237 — 170H02371 170H0238 170H0238 — — — — 170H0235 170H0069 170H0235 170H0236 170H0236 170H0069 — 170H0069 170H0069 170H0237 — 170H0237 170H0238 170H0238 — — — — 170H0235 170H0069 170H0236 170H0236 170H0236 170H0069 — 170H0069 170H0069 2.8x0.5 6.3x0.8 2.8x0.5 6.3x0.8 2.8x0.5 170H0237 — 170H0238 170H0238 170H0238 — — — — 4 — — — — — — — 170H0069 — 23 — — — — — — — 170H0069 — 24 — — — — — — — 170H0069 — 6.3x0.8 1 DIN2* (55x55), if DIN2 then use microswitch 170H0236, 170H0238. For special microswitches, double microswitches, microswitches with DC ratings, lower/higher signal levels and for insulation voltages please contact Eaton's Bussmann Division: bulehighspeedtechnical@eaton.com. 4-78 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M — IGBT size 000 and 230 750 Vdc (IEC), 800 Vdc (UL), 25 to 630 A Bolted tag high speed fuses for the protection of IGBT modules, optimized for use in IGBT inverter circuits with DC fuse voltage ratings up to 750 Vdc. Low inductance ≤ 15nH. Ratings Volts • • 750 Vdc tested at 863 Vdc according to IEC 60269-4 • 800 Vdc tested at 800 Vdc according to UL 248-1 • Amps 25-630 A • IR 50 kA DC (1ms tc) at 800 Vdc Operating class aR Agency information I²t (A²s) Fuse size Rated voltage 000 750 Vdc (IEC) 800 Vdc (UL) 230 Rated current (amps) 25 32 40 50 63 80 100 125 160 200 250 315 350 100 125 160 200 250 315 350 400 450 500 550 630 Catalog no. Pre-arcing Clearing at 690 Vac Watts loss (W)† 25 135 12 45 240 13 75 395 14 135 695 16 260 1350 17 460 2350 20 795 4000 25 1300 6800 29 2550 13500 34 4350 22000 40 7400 37500 48 12,500 65000 60 17,000 88000 65 380 1950 35 645 3300 42 1350 7000 47 2550 13500 54 4950 25000 62 9350 47500 72 12,000 61000 78 18,500 94500 80 27,000 140000 85 37,500 190000 90 48,500 245000 95 69,500 355000 105 -FU/70 170M1750 170M1751 170M1752 170M1753 170M1754 170M1755 170M1756 170M1757 170M1758 170M1759 170M1760 170M1761 170M1762 170M1770 170M1771 170M1772 170M1773 170M1774 170M1775 170M1776 170M1777 170M1778 170M1779 170M1780 170M1781 -FN/70 170M1730 170M1731 170M1732 170M1733 170M1734 170M1735 170M1736 170M1737 170M1738 170M1739 170M1740 170M1741 170M1742 170M1785 170M1786 170M1787 170M1788 170M1789 170M1790 170M1791 170M1792 170M1793 170M1794 170M1795 170M1796 † Watts loss at rated current. For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6422 (Size 000), 170K6426 (Size 230) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-79 High speed fuses UL DC Recognized, 800 Vdc L/R 1 ms max • 4 — High speed fuses 170M — IGBT size 000 and 230 750 Vdc (IEC), 800 Vdc (UL), 25 to 630 A Dimensions — mm Size 000 Size 230 For details on electrical characteristics, contact Application Engineering and ask for data sheets: 170K6422 (Size 000), 170K6426 (Size 230) 4-80 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries High speed fuses — 4 170M — IGBT size 000 and 230 1000 Vdc (IEC and UL), 25 to 500 A Bolted tag high speed fuses for the protection of IGBT modules, optimized for use in IGBT inverter circuits with DC fuse voltage ratings up to 1000 Vdc. Low inductance ≤ 20nH. Ratings Volts • • 1000 Vdc tested at 1150 Vdc according to IEC 60269-4 • 1000 Vdc tested at 1000 Vdc according to UL 248-1 • Amps 25-500 A • IR 50 kA DC (1ms tc) Operating class aR Agency information Fuse size I²t (A²s) Rated voltage 000 1000 Vdc (IEC/UL) 230 Rated current (amps) 25 32 40 50 63 80 100 125 160 200 225 250 Pre-arcing 19 34 61 135 245 505 1050 1900 4050 8500 12,000 16,000 100 125 160 200 250 315 350 400 450 500 600 1200 2550 4650 9300 18,500 24,500 37,500 52,000 69,500 Catalog no. Clearing at 1000 Vac Watts loss (W)† 95 14 170 17 300 20 675 21 1200 22 2500 27 5150 32 9500 34 20,000 37 42,000 43 59,000 45 79,500 48 3050 6050 13,000 23,000 45,500 91,500 125,000 185,000 260,000 340,000 38 42 48 55 62 68 75 80 85 90 -FU/90 170M1802 170M1803 170M1804 170M1805 170M1806 170M1807 170M1808 170M1809 170M1810 170M1811 170M1812 170M1813 -FN/90 170M1842 170M1843 170M1844 170M1845 170M1846 170M1847 170M1848 170M1849 170M1850 170M1851 170M1852 170M1853 170M1824 170M1825 170M1826 170M1827 170M1828 170M1829 170M1830 170M1831 170M1832 170M1833 170M1860 170M1861 170M1862 170M1863 170M1864 170M1865 170M1866 170M1867 170M1868 170M1869 † Watts loss at rated current. For details on electrical characteristics, contact Application Engineering and ask for data sheets: 170K6680 (Size 000), 170K6682 (Size 230) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 4-81 High speed fuses UL DC Recognized, 1000 Vdc L/R 1ms max • 4 — High speed fuses 170M — size 000 and 230 1000 Vdc (IEC and UL), 25 to 500 A Dimensions — mm Size 000 Size 230 For details on electrical characteristics, contact Application Engineering and ask for data sheets:170K6680 (Size 000), 170K6682 (Size 230) 4-82 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries IEC and British Standard fuses — 5 Contents Section page Description Fuses Bussmann series IEC cylindrical fuses CSA Type P and D fuses (CDN, CDS and PON) 2 HRC Form II Class C fuses (CGL) 3 HRCI industrial ceramic body fuses HRCI-CA (CIF21) 4 HRCI-CB (CIF06) HRCI-Misc. Type K (CIH, CIK and CIL) 5 HRC Form II current-limiting fuses (H07C, K07C, L14C, M14C, L09C, M09C, P09C, P11C, R11C) 6 BS88 Part 1 fuses SSD, NSD, ESD 7 STD, NITD, AAO, BAO, OSD, CEO, DEO BS88 AC, AD, BC, BD, CD, DD, ED, EFS 8 EF, FF, FG, GF, GG, GH DIN Type D Diazed (D16, D27, D33, D125) 9 DIN Type N Neozed (NZ01, NZ02) 10-11 JKS-700 fast-acting, current limiting UL Recognized and CSA Component Acceptance 700 Vac fuses up to 60 amps 11 NH fuse blocks and accessories (SD, TD) 12 Fuses continued IEC 60269 industrial fuses with and without indicator/striker Class gG ferrule (C10G, C14G, C22G) 13 Class aM ferrule (C10M, C14M, C22M) 14 HRC fuse holders CAMaster Complete portfolio of 8-22 mm diameter Class aM and Class gG cylindrical fuses for industrial applications SAFEloc 15 Red Spot BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 5-1 IEC and British Standard fuses NH HRC fuses (NHG) 5 — IEC and British Standard fuses CDN, CDS and PON CSA Type P and D fuses Dimensions — in (mm) A CSA time-delay Type D and P fuses. B Ratings • Volts • 250 Vac (CDN and PON) • 600 Vac (CDS) Up to 60 A Amps 10-600 A • IR 10 kA minimum CSA Certified, Class 1421-01, File 53787, CE Features Economical fuse in a variety of ratings for applications not requiring time-delay Typical applications • Lighting, heating and other circuits not subject to temporary surges and where available short-circuit current are relatively low Catalog no.* Catalog symbol Volts Available amp ratings Time-Delay CSA Type "D" fuses CDN** CDS† 250 Vac 10, 12, 15, 20, 25, 30, 35, 40, 45, 50, 60, 70, 80, 90, 100, 110, 125, 150, 175, 200, 225, 250, 300, 350, 400, 450, 500, 600 600 Vac 10, 12, 15, 20, 25, 30, 35, 40, 45, 50, 60, 70, 80, 90, 100, 110, 125, 150,175, 200, 225, 250, 300, 350, 400, 450, 500, 600 One-time CSA Type "P" fuses PON 250 Vac E 70 to 600 A Agency information • B F • • A D C 15, 20, 25, 30, 35, 40, 45, 50, 60 * To order, specify catalog symbol and amp rating, e.g., CDN30, CDS110 or PON40. ** Below 10 amps, use FRN-R. † Below 10 amps, use FRS-R. Amps A CDN/PON 250 Vac Up to 30 2.0 (51) 35-60 3.0 (76) 70-100 5.9 (149) 110-200 7.3 (185) 225-400 8.6 (219) 450-600 10.4 (264) CDS 600 Vac Up to 30 5.0 (127) 35-60 5.5 (140) 70-100 7.9 (200) 110-200 9.6 (245) 225-400 11.6 (295) 450-600 13.4 (340) B C D E F 0.6 (14) — — 0.8 (21) — — — 1.0 (25) — — 1.4 (35) 4.1 (105) — 1.9 (48) 4.6 (118) — 2.3 (57) 5.2 (132) — — 0.1 (3) 0.2 (5) 0.3 (6) 0.3 (6) — — 0.8 (19) 1.1 (29) 1.6 (41) 2 (51) 0.8 (21) — — 1.1 (27) — — — 1.0 (25) — — 1.4 (35) 6.1 (116) — 1.9 (48) 7.1 (118) — 2.3 (57) 8.2 (208) — — 0.1 (3) 0.2 (5) 0.3 (6) 0.3 (6) — — 0.8 (19) 1.1 (29) 1.6 (41) 2 (51) Recommended fuse blocks Catalog no.* Volts Fuse amps 250 600 Up to 30 HM25030-(poles) HM60030-(poles) 35-60 HM25060-(poles) HM60060-(poles) 70-100 HM25100-(poles) HM60100-(poles) 110-200 HM25200-(poles) HM60200-(poles) 225-400 HM25400-(poles) HM60400-(poles) 450-600 HM25600-(poles) HM60600-(poles) * To order, specify 1, 2 or 3 poles, e.g., HM25030-2_. See data sheets 10289 (30-60 A) and 3192 (70-600 A) for available terminals. Data sheet no. 4126 5-2 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries IEC and British Standard fuses — 5 CGL HRC Form II Class C fuses Dimensions — in (mm) Current-limiting HRCII-C fuses designed to withstand inrush currents on typical motor start-ups while offering high current limitation in the short-circuit region. See drawings for dimensions. 0.22 0.81 0.22 (5.56) (20.64) (5.56) 0.06 2.0 2.80 • 0.94 (8.73) (71.04) Ratings (1.59) 0.34 (50.8) (23.81) 3.31 (84.14) CGL 1-30 Volts 0.22 • 600 Vac • 250 Vdc (1-30 A) • Amps 1-600 A • IR 0.81 0.22 (5.56) (20.64) (5.56) 0.06 2.0 (1.59) 0.50 (50.8) 2.80 1.06 (12.7) (71.04) (26.92) 3.5 (88.9) • 200 kA • 40 kA DC CGL 35-60 0.343 1.34 0.343 (8.71) (34.04) (8.71) Agency information 2.39 CSA Certified, Class 1422,File 53787, CE (60.72) 3.64 0.09 (2.29) 0.75 1.375 (19.05) (34.93) (92.47) 4.31 Catalog no. (amps) (109.54) CGL-1 CGL-25 CGL-80 CGL-225 CGL-2 CGL-30 CGL-90 CGL-250 CGL-3 CGL-35 CGL-100 CGL-300 CGL-4 CGL-40 CGL-110 CGL-350 CGL-6 CGL-45 CGL-125 CGL-400 CGL-10 CGL-50 CGL-150 CGL-450 CGL-15 CGL-60 CGL-175 CGL-500 CGL-20 CGL-70 CGL-200 CGL-600 0.343 0.343 (8.71) (8.71) 3.00 0.125 0.75 (76.2) (19.05) 4.30 (109.22) Close sizing to loads allows using smaller and less costly switches • Provides a higher degree of short-circuit protection • Helps protect motors against burnout from overloads (38.1) 5.31 (134.87) 0.19 (4.76) 1.0 (25.4) (9.53) • (3.18) 1.50 CGL 110-200 0.38 Features 1.0 3.0 (25.4) 2.38 (76.2) (60.33) 5.25 (133.35) 8.19 (207.96) Typical applications • CGL 70-100 IEC and British Standard fuses • CGL 225-400 For use in circuits subject to surge currents such as those caused by motors, transformers and other inductive loads 1.0 0.41 (25.4) (10.32) Available Red Spot fuse holders Fuse amps Catalog symbol* Up to 32 RS32_ 35-60 RS63_ 70-100 RS100_ 110-200 RS200_ 225-400 RS400_ 1.0 (25.4) 0.60 3.0 (76.2) 5.25 (133.35) 8.19 (15.24) 0.375 (9.53) 3.00 (76.2) (207.96) CGL 450-600 * See Red Spot data sheet no. 10083 for terminal options. Data sheet no. 4125 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 5-3 5 — IEC and British Standard fuses CIF21 HRCI-CA industrial ceramic body fuses CIF06 HRCI-CB industrial ceramic body fuses The HRCI-CA bolt-on, ceramic body fuse provides both overload and short-circuit protection to HRCI requirements. Offset blades for bolt-on mounting CIF21 fuse fits the Bussmann series Red Spot fuse holder (data sheet 10083) and CAMaster fuse holder (data sheet number 4132). A miniature offset clip-in blade, ceramic body industrial fuse that provides both short-circuit and overload protection and the CIF06 fits the 30 A SAFEloc fuse holder (data sheet number 4133). Ratings • • Ratings Volts • 600 Vac Volts • 600 Vac • 250 Vdc 250 Vdc • Amps 1-30 A • Amps 1-30 A • IR 200 kA RMS Sym. • IR 200 kA RMS Sym. Agency information • Agency information • • CSA, Class 1422-02, File 53787, CE Catalog no. Amps CSA, Class 1422-02, File 53787 (3-30 A only), CE Catalog no. Catalog no. Amps 1CIF21 1 15CIF21 15 3CIF21 3 20CIF21 20 6CIF21 6 25CIF21 25 10CIF21 10 30CIF21 30 Features Amps 1CIF06 1 15CIF06 15 3 20CIF06 20 6CIF06 6 25CIF06 25 10CIF06 10 30CIF06 30 Features • Close sizing to loads allows using smaller and less costly switches Provides a higher degree of short-circuit protection Helps protect motors against burnout from overloads • Close sizing to loads allows using smaller and less costly switches • Provides a higher degree of short-circuit protection • • Helps protect motors against burnout from overloads Typical applications • • For use in circuits subject to surge currents such as those caused by motors, transformers and other inductive loads Recommended fuse holders Amps Description Catalog no.* Up to 20 Red Spot RS20_(terminal option) Up to 30 CAMaster CM20CF Amps 3CIF06 • Typical applications Catalog no. For use in circuits subject to surge currents such as those caused by motors, transformers and other inductive loads Recommended fuse holders Amps Description Catalog no.* Up to 30 SAFEloc C30(terminal option) * See data sheet no. 4133 for SAFEloc details. Dimensions — in (mm) * See data sheet no. 10083 (Red Spot) and 4132 (CAMaster) for details. 2.38 (60) 1.44 (36) Dimensions — in (mm) 0.54 (14) 0.03 (4) 0.44 (11) 0.19 (5) 1.75 (45) Data sheet no. 4127 5-4 0.5 (13) 0.54 (14) 2.15 (55) 1.44 (36) 0.14 (4) 0.03 (1) Data sheet no. 4128 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries IEC and British Standard fuses — 5 CIH, CIK and CIL HRCI — Misc. Type K fuses Misc. Type K HRCI bolt-on, ceramic body fuses provide both overload and short-circuit protection, featuring offset blades for bolt down mounting. Ratings • Volts 600 V • Amps 1-100 A • IR 200 kA@600 V Agency information • CSA, Class 1422-02, File 53787, CE Catalog no. (amp)CIH, CIK, CIL 1CIH07 15CIH07 35CIK07 80CIL14 3CIH07 20CIH07 40CIK07 90CIL14 6CIH07 25CIH07 50CIK07 100CIL14 10CIH07 30CIH07 60CIK07 Dimensions — in (mm) K F A D G J E B H IEC and British Standard fuses L C G The CIL14 has a rejection hole, not a slot as shown above. Amps Up to 30 A 2.25 (57) 2.28 35-60 (58) 2.75 80-100 (70) B 0.94 (24) 1.06 (27) 1.44 (37) C 3.38 (86) 3.56 (91) 4.38 (111) D E F G H J K L 0.38 0.04 2.88 0.21 0.31 1 0.10 2.38 (10) (1) (73) (5) (8) (25) (3) (60) 0.5 0.05 2.88 0.21 0.41 1.09 0.13 2.38 (13) (1) (73) (5) (11) (28) (3) (61) 0.75 0.09 3.69 0.34 0.41 1.5 2.91 — (19) (3) (94) (9) (11) (39) (74) Recommended fuse holders Amps Red Spot* CAMaster* Up to 30 RS32_ CM30CF 35-60 RS63_ CM60CF 80-100 RS100_ — * See data sheet no. 10083 (Red Spot) and 4132 (CAMaster) for details. Data sheet no. 4130 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 5-5 5 — IEC and British Standard fuses HRC Form II current-limiting fuses Dimensions — in (mm) H C H07C offset blades Volts • 600 Vac (or less) • 250 Vdc F A G J E D B • Amps 2-600 A • IR 200 kA RMS Sym. H C K07C, K07CR, L14C, M14C offset blades Agency information • J E D B Ratings • F A G HRC Form II bolt-on, ceramic body current-limiting fuses. C A H G B D CSA, Class 1422-02, File 53787, BS88:2, IEC 60269:2, CE (amps) catalog no. E F L09C, M09C, P09C center blades H07C offset blades 2H07C 6H07C 15H07C 25H07C 4H07C 10H07C 20H07C 30H07C K K F A G B D K07C offset blades 40K07C 60K07C 50K07C 80K07CR 100K07CR L14C offset blades 80L14C 100L14C M14C offset blades 125M14C* 150M14C* 200M14C* L09C center blades 80L09C* 100L09C* M09C center blades 125M09C 150M09C 200M09C P09C center blades 250P09C* 300P09C* 350P09C* 400P09C* 350P11C 400P11C P11C center blades 250P11C 300P11C R11C center blades 450R11C 500R11C 600R11C * Not suitable for installation in Red Spot fuse holders. Typical applications • H C P11C, R11C center blades Used to protect motor control circuits, together with contactors and overload protection relays to provide Type 2 coordination per IEC 60947-4. Catalog symbol/ style A B H07C offset blades 1.38 0.56 2-30 (35) (14) K07C offset blades 2.19 0.88 40-60 (56) (22) 2.19 0.88 80-100 (56) (22) L14C offset blades 2.38 0.88 80-100 (60) (21) M14C offset blades 2.56 1.5 125-200 (65) (38) L09C center blades 2.38 0.88 80-100 (60) (21) M09C center blades 2.56 1.5 125-200 (65) (38) P09C center blades 3.06 2.31 250-400 (178) (59) P11C center blades 3.06 2.31 250-400 (178) (59) R11C center blades 3.19 2.88 450-600 (81) (73) E K CSA category — HRCII-C — HRCII-C — HRCIIMISC 4.38 0.56 0.13 3.69 0.34 0.44 1 (111) (14) (3) (94) (9) (11) (25) — HRCII-C 4.38 0.75 0.09 3.69 0.34 0.44 (111) (19) (2) (94) (9) (11) — — HRCIIMISC 5 0.56 0.13 4.38 0.34 0.44 (127) (14) (3) (111) (9) (11) — — HRCIIMISC 5.38 0.75 0.13 4.38 0.34 0.56 (136) (19) (3) (111) (9) (14) — — HRCII-C 5.38 1 0.19 4.38 0.34 (136) (25) (5) (111) (9) 0.5 (13) — — HRCIIMISC 8.25 1 0.19 5.25 0.41 0.63 (210) (25) (5) (133) (10) (16) — 1 (25) HRCII-C 8.25 1 0.25 5.25 0.41 0.63 (210) (25) (6) (133) (10) (16) — 1 (25) HRCII-C C D E F G H J 3.38 0.38 0.06 2.88 0.22 0.31 0.56 (85) (9) (1) (73) (6) (8) (14) 3.44 0.5 0.06 2.88 0.22 0.31 0.88 (87) (13) (1) (73) (6) (8) (22) 3.75 0.5 0.06 2.88 0.22 0.31 0.88 (95) (13) (1) (73) (6) (8) (22) Recommended fuse holders: Red Spot up to 400 amps (data sheet no.10083) and CAMaster up to 100 amps (data sheet no. 4132). Data sheet no. 4131 5-6 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries IEC and British Standard fuses — 5 SSD, NSD, ESD BS88 Part 1 fuses The NSD and ESD are low voltage offset blade, ceramic body fuses complying with general purpose gG characteristics. Ratings Volts 240-550 Vac • Amps • The STD to DEO type ceramic body, offset bolt-on blade low voltage fuses complying with general purpose gG characteristics. Ratings • 2-63 A • 20M25 to 63M100 motor starter ratings • Volts 240-550 Vac • Amps IR • 33 kA (SSD) • 80 kA (NSD, ESD) • Agency information • • Catalog no.* SSD NSD† ESD† Amps (class) Max Vac BS88 ref. 2, 4, 6, 10, 16, 20, 25, 32 (gG) 240 E1 2, 4, 6, 10, 16, 20, 25, 32 (gG) 550 20M25, 20M32, 20M36, 32M36, 32M40, 32M50, 32M63 (gM) 415 2, 4, 6, 10, 16, 20, 25, 32 (gG) 550 40, 50, 63 (gG) 415 63M80, 63M100 (gM) 2-200 A • 20M25 to 200M315 motor starter ratings IR • 33 kA (STD) • 80 kA (NITD, AAO, BAO, CEO, DEO, OSD) Agency information Meets the requirements of BS88 Part 1 and IEC 60269-1, CE Catalog symbol • Meets the requirements of BS88 Part 1 and IEC 60269-1, CE Catalog no.* Catalog symbol STD F1 NITD† F2 AAO† NSD 32NNSF ESD 63ENSF BS88 ref. 2, 4, 6, 10, 16, 20, 25, 32 (gG) 240 — 20M25, 20M32 (gM) 415 2, 4, 6, 10, 16, 20, 25, 32, (gG) 550 32M40, 32M50, 32M63 (gM) 500 500 63M80, 63M100 (gM) CEO† 32, 40, 50, 63, 80, 100 (gG) 550 100M125, 100M160, 100M200 (gM) 415 125, 160, 200 (gG) DEO† 415 200M315 (gM) OSD† 550 32M40, 32M50, 32M63 (gM) 40, 50, 63 (gG) BAO† Recommended fuse holders Catalog no. Max Vac 2, 4, 6, 10, 16, 20, 25, 32 (gG) * To order, specify catalog symbol and amp rating, e.g., SSD20. † "M" indicates motor starter ratings. Fuse symbol Amps (class) 80, 100 (gG) 500 100M125, 100M160 (gM) 415 — A2 A3 A4 — — * To order, specify basic catalog symbol and amp rating. E.g., BAO16. † "M" indicates motor starter ratings. Typical applications • The STD type are used in 240 V street lighting cut-outs • NITD to DEO types used for industrial and general purpose applications Recommended fuse blocks and holders Fuse catalog symbol Block/holder catalog no.* NITD CM32FC, RS20_ AAO CM32F, RS32_ BAO CM63F, RS63_ OSD CM100F, RS100_ CEO BH-0111 * See data sheet no. 4132 (CM_), 10083 (RS_) and 1200 (BH-_). Data sheet no. 4105 (SSD), 4100 (NSD) and 4101 (ESD) Data sheet no. 4123 (STD), 4106 (NITD), 4109 (AAO), 4112 (BAO), 4107 (OSD), 4115 (CEO) and 4117 (DEO) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 5-7 IEC and British Standard fuses • STD, NITD, AAO, BAO, OSD, CEO, DEO BS88 Part 1 fuses 5 — IEC and British Standard fuses AC, AD, BC, BD, CD, DD, ED, EFS BS88 fuses EF, FF, FG, GF, GG, GH BS88 fuses Ceramic body, center blade two-hole bolt-on low voltage fuses that comply with general purpose gG characteristics and available up to 400 amps with two hole mount and up to 1250 amps with four hole mount. Ceramic body, center blade four-hole bolt-on low voltage fuses complying with general purpose gG characteristics and available up to 400 amps with two hole mount and up to 1250 amps with four hole mount. Ratings Ratings (see catalog numbers table) • • • Volts • 415/550 Vac • 415/690 Vac • 250 Vdc • 250/400 Vdc Amps • 2-400 A • 63M80 to 400M500 motor starter ratings Catalog no.* AC AD BC† BD IR ( kA) Amps (class) AC 2, 4, 6, 10, 16, 20 (gG) 25, 32 (gG) 2, 4, 6, 10, 16, 20 (gG) 25, 32 (gG) 40, 50, 63 (gG) 63M80, 63M100 (gM) 40, 50, 63 (gG) DC DD† 100M125, 100M160, 100M200 (gM) 125, 160, 200 (gG) 200M250, 200M315 (gM) ED 315M400 (gM) IR see catalog numbers table 125, 160, 200, 250, 315 (gG) 550 AC DC 80 40 AC DC BS88 ref. — C1 C2 — FF 450, 500, 560, 630 (gG) 80 40 550 400 FG 450, 500, 560, 630 (gG) 80 40 550 400 — 250 — GF 710, 800 (gG) 80 40 550 250 C3 500 250 — 80 40 500 250 — 500 — 80 — 415 — 80 — 415 — B2 80 — — B3 B4 — — 415 Amps (class) Max volts 250 40 500 Catalog symbol IR ( kA) EF† 80 550 Catalog no.* BS88 ref. 40 500 Meets the requirements of BS88 Parts 1 and 2 and IEC 60269-1, CE DC 80 400M500 (gM) EFS AC 40 250, 315, 355, 400 (gG) † Max volts 80 CD80, CD100 (gG) CD† Amps 355-1250 A • • Meets the requirements of BS88 Parts 1 and 2 and IEC 60269-1, CE Catalog symbol • Agency information IR see catalog numbers table Agency information • Volts • B1 GG GH 355, 400 (gG) 400M500 (gM) 710, 800 (gG) 80 1000, 1250 (gG) 710, 800, 1000, 1250 80 40 — — 415 550 550 550 250 — — * To order, specify catalog symbol and amp rating, e.g., FG450. † "M" indicates motor starter ratings. 550 80 — 415 * To order, specify catalog symbol and amp rating. E.g., BC40. † "M" indicates motor starter ratings. Recommended fuse blocks Fuse catalog symbol Modular block catalog no.* AC BH-0111 AD BH-____ BC BH-0111 BD BH-____ CD BH-____ DD BH-____ ED BH-1131 * See data sheet no. 1200 (BH-0_) and 1201 (BH-1_) for details. Data sheets no. 4110 (AC), 4111 (AD), 4113 (BC), 4114 (BD), 4116 (CD), 4118 (DD), 4119 (ED) and 4121 (EFS) 5-8 Data sheet no. 4120 (EF), 4102 (FF), 4122 (FG), 4103 (GF), 4104 (GG) and 4108 (GH) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries — D1 IEC and British Standard fuses — 5 D16, D27, D33, D125 DIN Type D Diazed fuses NZ01, NZ02 DIN Type N Neozed fuses DIN style Type D ceramic body low voltage fuses. DIN style Type N ceramic body low voltage. Ratings Ratings • Volts 500 Vac • Volts 400 Vac • Amps 2-100 A • Amps 2-63 A • IR 50 kA • IR 50 kA Agency information IEC 60269 and DIN 49515, CE Catalog no. • Amps "D" dimension Color code 2D16 2 6 Pink 4D16 4 6 Brown 6D16 6 6 Green 10D16 10 8 Red Fig. 1 IEC 60269 and DIN 49515, CE Catalog no. Amps "D" dimension Color code 2NZ01 2 11 Pink 4NZ01 4 11 Brown 6NZ01 6 11 Green 10NZ01 10 11 Red 16D16 16 10 Grey 16NZ01 16 11 Grey 20D16 20 12 Blue 20NZ02 20 15 Blue 25D16 25 14 Yellow 25NZ02 25 15 Yellow 2D27 2 6 Pink 35NZ02 35 15 Black 4D27 4 6 Brown 50NZ02 50 15 White 63NZ02 63 15 Copper 6D27 6 6 Green 10D27 10 8 Red 16D27 16 10 Grey 20D27 20 12 Blue 25D27 25 14 Yellow 35D33 35 16 Black 50D33 50 18 White 63D33 63 20 Copper 80D125 80 5 Silver 100D125 100 7 Red 2 Dimensions — mm IEC and British Standard fuses • Agency information D 3 36 4 Additional 500 V quick acting fuses in body sizes D16, D27, D33 and D125 rated 2-100 A. Reference number suffixed "Q." E.g., 10D27Q. Gauge rings and keys can also be supplied. Dimensions — mm 21.5 13.2 50 D Fig. 1 Fig. 2 Data sheet no. 4124 57 50 50 D 33.5 27.5 D Fig. 3 D Fig. 4 Data sheet no. 4124 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 5-9 5 — IEC and British Standard fuses ___NHG___B NH HRC fuses ___NHG___B NH HRC fuses DIN 000 to 4 Class: gG/gL DIN square bodied, dual indication industrial fuses with voltage conducting metal gripping lugs. They are made of a steatite insulator, corrosion-proof (aluminum) metal parts with full-contact and silver-plated copper blades. All NHG fuses feature a selectivity ratio: 1:1.6 up to 500 Vac. Ratings • Volts • 500 Vac • 690 Vac • Amps 2-1250 A • IR 120 kA • Frequency • 45-62 Hz operating Agency information • IEC 60269, VDE 0636, DIN 43620 • CE (500 Vac only) Dimensions — mm a4 a3 e3 d 2 min. c2 c1 e1 b e4 f e2 a2 a1 Fuse size 000 00 0 01 1 02 2 03 3 4 a1 79 79 125 135 135 150 150 150 150 200 a2 54 54 68 75 75 75 75 75 75 84 a3 45 45 62 62 62 62 62 62 62 80 a4 49 49 68 68 68 68 68 68 68 90 b 15 15 15 15 20 20 25 25 32 50 c1 35 35 35 40 40 48 48 60 60 85 c2 10 11 11 11 11 11 11 11 11 11 D e1 2 41 7.0 48 2.5 48 2.5 48 2.5 53 2.5 53 2.5 61 2.5 61 3.0 75 3 120 Recommended fuse blocks Block catalog no. SD00-D Fuse size 000-00 SD1-D 1*, 1 SD2-D 02, 2, 03, 3 e2 21 30 30 30 52 52 60 60 70 87 e3 16 25 25 25 25 25 25 25 25 — e4 6 6 6 6 6 6 6 6 6 8 f 8 15 15 15 15 15 15 15 18 30 500 Vac gG/gL dual indicator voltage conducting metal gripping lugs Amps 000 size 2 4 6 10 16 20 25 32 35 40 50 63 80 100 00 size 50 63 80 100 125 160 0 size 6 10 16 20 25 32 35 40 50 63 80 100 125 160 01 size 6 10 16 20 25 32 35 40 50 63 80 100 125 160 Data sheet no. 10164 (500 V), 720109 (690 V) 5-10 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Catalog no. 2NHG000B 4NHG000B 6NHG000B 10NHG000B 16NHG000B 20NHG000B 25NHG000B 32NHG000B 35NHG000B 40NHG000B 50NHG000B 63NHG000B 80NHG000B 100NHG000B 50NHG00B 63NHG00B 80NHG00B 100NHG00B 125NHG00B 160NHG00B 6NHG0B 10NHG0B 16NHG0B 20NHG0B 25NHG0B 32NHG0B 35NHG0B 40NHG0B 50NHG0B 63NHG0B 80NHG0B 100NHG0B 125NHG0B 160NHG0B 6NHG01B 10NHG01B 16NHG01B 20NHG01B 25NHG01B 32NHG01B 35NHG01B 40NHG01B 50NHG01B 63NHG01B 80NHG01B 100NHG01B 125NHG01B 160NHG01B Amps 1 size 50 63 80 100 125 160 200 224 250 315 355 02 size 35 40 50 63 80 100 125 160 200 224 250 2 size 250 300 315 355 400 425 450 500 03 size 250 315 355 400 3 size 315 355 400 425 450 500 630 800 4 size* 500 630 800 1000 1250 Catalog no. 50NHG1B 63NHG1B 80NHG1B 100NHG1B 125NHG1B 160NHG1B 200NHG1B 224NHG1B 250NHG1B 315NHG1B 355NHG1B 35NHG02B 40NHG02B 50NHG02B 63NHG02B 80NHG02B 100NHG02B 125NHG02B 160NHG02B 200NHG02B 224NHG02B 250NHG02B 250NHG2B 300NHG2B 315NHG2B 355NHG2B 400NHG2B 425NHG2B 450NHG2B 500NHG2B 250NHG03B 315NHG03B 355NHG03B 400NHG03B 315NHG3B 355NHG3B 400NHG3B 425NHG3B 450NHG3B 500NHG3B 630NHG3B 800NHG3B 500NHG4G 630NHG4G 800NHG4G 1000NHG4G 1250NHG4G * Size 4 is a a single indicator fuse with slotted end blades. Eaton.com/bussmannseries IEC and British Standard fuses — 5 ___NHG___B NH HRC fuses JKS-700 fast-acting fuses Amps Catalog no. Amps 000 size Catalog no. 2 size The JKS-700 is a fast-acting, current-limiting fuse that is UL Recognized and has CSA Component Acceptance for applications up to 700 Vac. The JKS-700 is available in ratings up to 60 amps with the same dimensions as a standard Class J fuses; but its voltage rating places it outside the standard Class J fuse class. 2 2NHG000B-690 200 200NHG2B-690 4 4NHG000B-690 224 224NHG2B-690 6 6NHG000B-690 250 250NHG2B-690 10 10NHG000B-690 315 315NHG2B-690 16 16NHG000B-690 3 size 20 20NHG000B-690 250 250NHG3B-690 25 25NHG000B-690 315 315NHG3B-690 32 32NHG000B-690 355 355NHG3B-690 35 35NHG000B-690 400 400NHG3B-690 40 40NHG000B-690 425 425NHG3B-690 • Volts 700 Vac (or less) 50 50NHG000B-690 500 500NHG3B-690 • Amps 25-60 A 63 63NHG000B-690 4 size** • IR 00 size 50 50NHG00B-690 63 63NHG00B-690 80 80NHG00B-690 100 100NHG00B-690 125 125NHG00B-690 160* 160NHG00B-690 Bussmann recommends the JM70100 modular fuse block and the JM70100-MW power distribution fuse block for the 30 amp case size JKS-700 fuses. See page 8-18 for details. Ratings 630 630NHG4B-690 • Minimum 6In 800 800NHG4B-690 • 200 kA RMS Sym. * 160 amps rated at 660 Vac. ** Size 4 is a single indicator fuse with slotted end blades. 1 size Operating class aR Agency information • UL Recognized, 248-13 Semiconductor Fuses, File E56412 • CSA Component Acceptance, C22.2 No 248.13 Semiconductor Fuses, Class 1422-30 50 50NHG1B-690 63 63NHG1B-690 Features 80 80NHG1B-690 • 100 100NHG1B-690 125 125NHG1B-690 Current limitation for non-inductive circuits provides currentlimiting response to maximum ground fault and short-circuit conditions 160 160NHG1B-690 • 200 kA interrupting rating provides protection at all circuit locations 200 200NHG1B-690 • Economical circuit protection for high-fault current circuits 224 224NHG1B-690 Typical applications 250 250NHG1B-690 • Power panelboards up to 700 Vac • Machinery disconnects up to 700 Vac Catalog no. (amps) JKS-25-700 Data sheet no. 10164 (500 V), 720109 (690 V) JKS-30-700 JKS-35-700 JKS-60-700 Data sheet no. 1026 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 5-11 IEC and British Standard fuses 690 Vac gG/gL dual indicator voltage conducting metal gripping lugs 5 — IEC and British Standard fuses SD_ and TD_ NH fuse blocks Shroud kits NH fuse bases feature thermoplastic bodies, and DIN-Rail and screw mounting (size 4 is screw fix). They are available with a range of protection accessories for live parts for IP20 protection. Ratings • Volts • 690 Vac • 1000 Vac (SD1-D only) • Amps up to 1250 A • NH fuse sizes 000 to 4 Agency information • IEC 60269-1 and 2 • VDE 0636-1 and 2 Typical applications • Protecting industrial circuits and electrical apparatus Catalog no. Fuse size Poles Amps Catalog no. Carton qty. Accepts fuse sizes DIN-Rail or screw mount 00 1 2 3 1 160 3 1 250 3 1 400 3 1 630 3 Catalog no. SD00-D 3 TD00-D 1 SD1-D 3 TD1-D 1 SD2-D 3 TD2-D 1 SD3-D 3 TD3-D 1 SD4-S 3 000 and 00 01 and 1 02 and 2 03 and 3 1 1250 Neutrals NH size Amps Catalog no. Carton qty. 1 250 SDL-1 3 2 400 SDL-2 3 3 630 SDL-3 3 TD00-D TD1-IP20 TD1-D TD2-IP20 TD2-D TD3-IP20 TD3-D SD00-SK SD00-D SD12-SK SD1 and SD2 SD3-SK SD3 Phase barrier kits Screw mount only 4 Fits fuse block TD00-IP20 4 Catalog no. Fits fuse block SD00-PB SD00-D SD12-PB* SD1 and SD2 SD3-PB* SD3 * Kits include 2 phase barriers and 2 ganging links. Fuse extraction handle Size Catalog no. Carton qty. C00-3 FEH 1 Data sheet 10163 5-12 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries IEC and British Standard fuses — 5 Class gG IEC 60269 industrial ferrule fuses 10 to 22mm diameter IEC Class gG fuses with optional indicators (10x38mm only) and strikers. See catalog numbers for availability and ratings. Class gG, 400, 500 and 690 Vac, 2 to 125 A Catalog no. Standard W/ striker C22G2 — C22G4 C22G6 C22G8 C22G10 C22G12 C22G16 C22G20 C22G25 C22G32 C22G40 C22G50 C22G63 C22G80 C22G100 C22G125 C22G4S C22G6S C22G8S C22G10S C22G12S C22G16S C22G20S C22G25S C22G32S C22G40S C22G50S C22G63S C22G80S C22G100S C22G125S Vac Amps IR (kA) Holder/block 2 690 500 400 4 6 8 10 12 16 20 25 32 40 50 63 80 100 125 80 CH22 DIN-Rail*, JM70100 block 120 * Use striker version to actuate optional, external microswitch. 10x38mm, Class gG, 500 and 400 Vac, 0.5 to 50 A Dimensions — mm W/ indicator — — — — — — — — — — — — — C10G321 C10G40I C10G50I Vac 500 400 400 500 500 400 Amps 0.5 1 2 4 6 8 10 12 16 20 25 32 32 32 40 50 IR (kA) Holder/block C D ØA ØE B 120 CHM DIN-Rail*, BMM block Catalog symbol Indicator/striker ØA B C D ØE C10G 10 38 10 — — C14G 14.3 51 13 8 4 C22G 22 58 16 8 4 * Not recommended for use with indicator version. 14x51mm, Class gG, 400, 500 and 690 Vac, 1 to 50 A Catalog no. Standard C14G1 C14G2 — C14G4 — C14G6 — C14G8 — C14G10 — C14G12 — C14G16 — C14G20 — C14G25 — C14G32 C14G40 C14G50 W/ striker — — C14G2S — C14G4S — C14G6S — C14G8S — C14G10S — C14G12S — C14G16S — C14G20S — C14G25S C14G32S C14G40S C14G50S Vac 690 500 690 500 690 500 690 500 690 500 690 500 690 500 690 500 690 500 400 Amps 1 2 4 6 8 10 12 16 20 25 32 40 50 IR ( kA) Holder 80 120 80 120 80 120 80 120 80 120 80 120 80 120 80 120 80 CH14 DIN-Rail** 120 ** Not recommended for use with indicator version, use striker version to actuate optional, external microswitch Data sheet no. 720115 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 5-13 IEC and British Standard fuses Catalog no. Standard C10G0.5 C10G1 C10G2 C10G4 C10G6 C10G8 C10G10 C10G12 C10G16 C10G20 C10G25 C10G32 C10G32 — — — .22x58mm, 5 — IEC and British Standard fuses Class aM IEC 60269 industrial ferrule fuses 10 to 22mm diameter IEC Class aM fuses with optional indicators (22x58mm only) and strikers. See catalog numbers for availability and ratings. 10x38mm, Class aM, 500 and 400 Vac, 0.25 to 25 A Catalog no. Standard C10M0.5 C10M1 C10M2 C10M4 C10M6 C10M8 C10M10 C10M12 C10M16 C10M20 C10M25 Vac Amps 0.5 1 2 4 6 8 10 12 16 20 25 500 400 IR (kA) W/ striker — — — — C14M2S — C14M4S — C14M6S — C14M8S — C14M10S — C14M12S — C14M16S — C14M20S — C14M25S C14M32S C14M40S C14M50S Vac 690 500 690 500 690 500 690 500 690 500 690 500 690 500 690 500 690 500 400 Catalog no. W/ Standard indicator C22M2 — C22M4 — C22M6 — C22M8 — C22M10 — C22M12 — C22M16 — C22M20 — C22M25 — C22M32 — C22M40 — C22M50 — C22M63 — C22M80 — C22M100 — C22M125 C22M125I W/ striker — — — — — C22M12S C22M16S C22M20S C22M25S C22M32S C22M40S C22M50S C22M63S C22M80S C22M100S C22M125S Vac Amps IR (kA) Holder/block 2 4 6 8 10 12 690 16 80 20 CH22 DIN-Rail*, JM70100 block 25 32 40 50 63 80 500 100 120 400 125 * Not recommended for use with indicator version, use striker version to actuate optional, external microswitch. Holder/block Dimensions — mm C D ØA B Catalog symbol Amps 0.25 0.5 1 2 4 6 8 10 12 16 20 25 32 40 50 ØE CHM Din-Rail, BMM block 120 14x51mm, Class aM, 400, 500 and 690 Vac, 0.25 to 50 A Catalog no. Standard C14M0.25 C14M0.5 C14M1 C14M2 — C14M4 — C14M6 — C14M8 — C14M10 — C14M12 — C14M16 — C14M20 — C14M25 — C14M32 C14M40 C14M50 22x58mm, Class aM, 400, 500 and 690 Vac, 2 to 125 A IR (kA) 80 80 120 80 120 80 120 80 120 80 120 80 120 80 120 80 120 80 Indicator/striker ØA B C D ØE C10M 10 38 10 — — C14M 14.3 51 13 8 4 C22M 22 58 16 8 4 Holder CH14 DIN-Rail** 120 ** Use striker version to actuate optional, external microswitch. Data sheet no. 720115 5-14 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries IEC and British Standard fuses — 5 HRC fuse holders CAMaster SAFEloc The Bussmann series CAMaster HRC fuse holder features a unique cam-action for easy fuse removal while allowing significantly improved contact pressure between fuse carrier and base contact that enhances electrical performance. A range of lockable safety carriers for the fuse holder (catalog reference LSC), are available. • Volts 690 V The Bussmann series SAFEloc HRC fuse holders (for use with HRCI-CB fuses) provides a positive, stress-free fuse fitting and locks it in position to ensure safe insertion and withdrawal from the base. Base contacts are fully shrouded to help protect against electric shock. Shrouds utilize simple slide/snap action allowing access to the contact terminal screws. It can be mounted on a 35mm DIN-Rail or panel-mounted with a single screw. • Amps up to 100 A Ratings Agency information • CSA C22.2 No. 39; IEC 269 and BS88, CE Catalog no. Amps CM20CF 30 CM30CF 30 CM60CF 60 CM100CF 100 Details for Fuses accepted HRCI-CA applications HRCII applications _CIF21 _H07C _K07C _K07CR Accessories Catalog no. Amps 30 32BS 30 Description All 20LSC 30 32LSCC 30 CAMaster accepted CM20CF Back stud 60/100 GLP 63/100LSC Volts 600 V • Amps 30-60 A Agency information • Designed to accommodate the compact range of offset blade fuse to CSA C22.2 No. 106, HRCI-CB, CE Catalog no.* CM30CF CM60/100CF Ganging link kit 3-Pole CM20CF Security carrier with clip 60/100 Amps C30F C30BS 20BS 60/100BS • Fuses accepted Front 30 C30FBS Back _CIF06 Front-back C60F C60BS Connection Front 60 C60FBS Back EK-(amp) Front-back * For use with HRCI-CB fuses. Bussmann series Red Spot fuse holders CM30CF CM60/100CF These versatile CSA Certified and IP20 finger-safe fuse holders for BS88 HRC industrial fuses are available in ratings from 20 to 400 amps. Padlock inserts, warning carriers and fuse adapter accessories enhance safety and application flexibility. See data sheet no. 10083 for details. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 5-15 IEC and British Standard fuses Ratings BUSSMANN SERIES Enhanced safety. Improved system reliability. Simplified inventory. It’s easier than ever to improve your circuit protection while efficiently reducing your fuse inventory. Leveraging Bussmann™ series ultimate protection fuses, our Low-Peak™ Upgrade program couples the industry’s most advanced circuit protection with our extensive knowledge to deliver enganced safety, improved system reliability and simplified inventory. In just three simple steps, you’ll save time and increase productivity. All by using Bussmann series Low-Peak fuses. Three steps to ultimate protection: 1 Audit 2 Analyze 3 Implement Visit Eaton.com/bussmannseries to learn more. Follow us on social media to get the latest product and support information. Photovoltaic fuses, holders, and blocks — 6 Contents Section page Description Fuse size PVM 13/32" x 1-1/2" Volts 600 Amps 4-30 PVS-R RK5 600 20-400 PV-_A10_ 10x38mm 1000 1-20 HPV In-line assembly 1000/1500 1-20 PV-_A14F 14x51mm 1000/1100 15-32 PV-_ANH_ NH1, 2, 3 1000 32-400 PV-_A10F85L 10x85mm 1500 2.25-25 PV15M-4A-CT Crimp terminal 1500 4 PV-_A-_XL XL 01, 1, 2, 3 Holder Fuse size CHPV_ 10x38mm 1000 30 Blocks Fuse size Volts Amps BPVM-_ 10x38mm 1000 30 CHPV15L85 10x85 and 14x85mm 1500 32 SD_-S-PV 01XL to 3L 1500 Up to 630 SD_-D-PV and TD_D-PV NH1, 2, 3 1500 Up to 630 1000/1500 50-600 Volts Amps 2 3 4 5 6 7 8 9 10 11 PV fuses, holders, blocks and SPDs Complete and reliable solar circuit protection Fuses BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 6-1 6 — Photovoltaic fuses, holders and blocks PVM 600 Vdc 13/32" x 1-1/2" midget PV fuses PVS-R 600 Vac/dc Class RK5 PV fuse A range of UL 248-19 fastacting 600 Vdc 13/32" x 1-1/2" (10x38mm) midget fuses specifically designed to protect solar power systems in extreme ambient temperature, high cycling and low level fault current conditions (reverse current, multiarray fault). A range of UL 248-19 fastacting 600 Vdc Class RK5 fuses specifically designed to protect photovoltaic power systems in extreme ambient temperature, high cycling and low level fault current conditions (reverse current, multi-array fault). 2011/65/EU Ratings Ratings • Volts Volts 600 Vdc • 600 Vac to UL 248-12 • Amps 4-30 A • 600 Vdc to UL 248-19 • IR 50 kA DC (4-30 A) • Agency information • • Amps 20-400 A • IR UL Listed 248-19, Guide JFGA, File E335324, CSA Component Certified C22.2, RoHS compliant, CE Watts loss • 200 kA RMS Sym. AC • 20 kA DC (20-60 A) • 10 kA DC (70-400 A) Agency information Power loss (watts) Catalog no. Amps 0.8 In In PVM-10 10 1.0 1.9 PVM-15 15 1.0 1.7 PVM-30 30 1.6 2.9 • UL Listed, Std. 248-12, Class RK5, Guide JFGA, File E335324. Photovoltaic to UL 248-19, CSA Component Certified C22.2, CE Catalog no. (amps) PVS-R-20 PVS-R-60 PVS-R-125 PVS-R-300 PVS-R-25 PVS-R-70 PVS-R-150 PVS-R-350 PVS-R-400 Catalog no. (amps) PVS-R-30 PVS-R-80 PVS-R-175 PVM-4 PVM-7 PVM-10 PVM-20 PVS-R-35 PVS-R-90 PVS-R-200 PVM-5 PVM-8 PVM-12 PVM-25 PVS-R-40 PVS-R-100 PVS-R-225 PVM-30 PVS-R-50 PVS-R-110 PVS-R-250 PVM-6 PVM-9 PVM-15 Features Features • Specifically designed to protect photovoltaic systems in extreme ambient temperature per UL 248-19 listed • Capable of withstanding high cycling and low level fault current conditions Typical applications • Current limitation for non-inductive circuits provides Class RK5 current-limiting response to ground fault and short-circuit conditions • Designed for the protection and isolation of photovoltaic systems Typical applications • Combiner boxes • Photovoltaic systems • String protectors • Inverters • Photovoltaic system DC safety switches • Recombiner boxes Recommended fuse holders and blocks, see pages 6-8 and 6-9. Recommended fuse blocks, see page 8-19. Data sheet no. 2153 6-2 Data sheet no. 4203 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Photovoltaic fuses, holders, and blocks — 6 Features PV 1000 Vdc 10x38mm PV fuses A range 10x38mm, 1000 Vdc PV fuses for the protection and isolation of photovoltaic strings that are specifically designed for use in PV systems with extreme ambient temperature, high cycling and low fault current conditions (reverse current, multi-array fault) string arrays. For application flexibility, the PV 10x38mm fuse is available as a cylindrical fuse as well as bolt-on, single and dual PCB tab and in-line crimp terminal versions. 2011/65/EU • Meets UL and IEC photovoltaic standards for global acceptance • Low watts loss performance for energy efficiency • Low temperature rise performance for more precise sizing • In-line crimp terminal version is easy to apply in wire harness construction Typical applications Ratings • Combiner boxes • Inverters • PV wire harnesses Recommended fuse blocks, holders and fuseclips • Volts 1000 Vdc • Amps 1-20 A • BPVM modular fuse block with optional cover, see page 6-9 • IR 50 kA • CHPV 1- and 2-pole modular fuse holders with optional open fuse indication, see page 6-8 • 1A3400-09 PCB fuseclip, see page 3-16 • HPV in-line fuse holder assembly, see page 6-4 Terminals and conductors • Crimp connection for single, 75°C/90°C Cu Stranded 12-8 AWG PV wire Agency information • UL Listed to 248-19†, Guide JFGA, File E335324, IEC 60269-6 (gPV), CSA File 53787, Class 1422-30 (1-15A), 20 A Pending, CCC (1-20 A), RoHS Compliant Catalog no. (amp) I2t (A2s) Watts loss Amps Pre-arcing Total @rated volts 0.8 In In PV-1A10F-CT 1 0.15 0.4 0.8 1.5 PV-2A10F-CT 2 1.2 3.4 0.6 1.0 4 11 0.8 1.3 6.6 18 0.9 1.4 9.5 26 1.0 1.5 19 50 1.0 1.6 6 30 90 1.1 1.8 PV-8A10F-CT 8 3 32 1.2 2.1 PV-10A10F-CT 10 7 70 1.2 2.3 PV-12A10-2P PV-12A10F-CT 12 12 120 1.5 2.7 PV-15A10-2P PV-15A10F-CT 15 22 220 1.7 2.9 PV-20A10-2P PV-20A10F-CT 20 34 350 2.1 3.6 Cylindrical Bolt-on PCB single pin PCB double pin Crimp terminal PV-1A10F PV-1A10-T PV-1A10-1P PV-1A10-2P PV-2A10F PV-2A10-T PV-2A10-1P PV-2A10-2P PV-3A10F PV-3A10-T PV-3A10-1P PV-3A10-2P PV31A10F-CT 3 PV-3-5A10F PV-3-5A10-T PV-3-5A10-1P PV-3-5A10-2 PV-3.5A10F-CT 3.5 PV-4A10F PV-4A10-T PV-4A10-1P PV-4A10-2P PV-4A10F-CT 4 PV-5A10F PV-5A10-T PV-5A10-1P PV-5A10-2P PV-5A10F-CT 5 PV-6A10F PV-6A10-T PV-6A10-1P PV-6A10-2P PV-6A10F-CT PV-8A10F PV-8A10-T PV-8A10-1P PV-8A10-2P PV-10A10F PV-10A10-T PV-10A10-1P PV-10A10-2P PV-12A10F PV-12A10-T PV-12A10-1P PV-15A10F PV-15A10-T PV-15A10-1P PV-20A10F PV-20A10-T PV-20A10-1P Data sheet no. 10121 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 6-3 PV fuses, holders, blocks and SPDs † Except crimp terminal version that is UL Recognized to UL 248-19, Guide JFGA2, File E335324. 6 — Photovoltaic fuses, holders and blocks HPV 1000 Vdc in-line PV fuse assembly PV 1000/1100 Vdc 14x51mm PV fuses A single-pole, non-serviceable photovoltaic in-line fuse holder and fuse assembly in an IP67 dust tight, submersible insulating boot for use in photovoltaic wire harnesses. A range of 14x51mm PV fuses specifically designed for protecting and isolating photovoltaic strings. These fuses are capable of interrupting low overcurrents associated with faulted PV systems (reverse current, multi-array fault). 2011/65/EU Ratings • Volts • 1000 Vdc • 1500 Vdc (HPV-D15V-4A only) • Amps 1-20 A • IR 33 kA Ratings • Agency information • UL Listed to 4248-1 and 4248-19, File E 348242, CSA Component Acceptance, Class 6225 30, File # 47235, IP67 submersible, RoHS compliant, CE Terminals and conductors • • 1000 Vdc (25 and 32 A) • 1100 Vdc (15 and 20 A) Amps 15-32 A • IR 10 kA Agency information • Crimp connection for single, 75°C/90°C Cu Stranded 12-8 AWG PV wire UL Listed, Guide JFGA, File E335324. Photovoltaic to, UL 248-19, IEC 60269-6 gPV, CSA Pending, CCC Pending, RoHS compliant I2t (A2s) Catalog no. PV-15A14F UL 5VA flammability resistant rated elastomer, UV resistant to UL F1 suitable for outdoor use. Operating and storage temperature range • Volts • Boot material • 2011/65/EU -40°C to +90°C Watts loss Amps Pre-arcing Total @ rated volts 0.8 In In 15 14 265 2.1 4 PV-20A14F 20 27 568 2.7 5 PV-25A14F 25 65 943 2.7 5.1 PV-32A14F 32 120 1740 3.3 6.2 Features Packaging • Bulk packed in cartons, 180 fuse assemblies per carton. Carton weight 19.3 lbs (8.7543 kg). • Fuse assemblies poly bagged with PV fuse element, two insulating boots (for lineside and loadside), and one pressure sensitive label to be applied on outside after complete assembly to the wire harness. • Specifically designed to provide fast-acting protection under low fault current conditions associated with PV systems • High DC voltage rating • Demonstrated performance in extreme temperature cycling conditions Typical applications Catalog no. (amps)* • Combiner boxes 1000 Vdc • Inverters HPV-DV-1A HPV-DV-3.5A HPV-DV-8A HPV-DV-2A HPV-DV-4A HPV-DV-10A HPV-DV-2.5A HPV-DV-5A HPV-DV-12A HPV-DV-3A HPV-DV-6A HPV-DV-15A HPV-DV-20A Recommended fuse holder • CH141B-PV DIN-Rail modular fuse holder, see data sheet no. 720148 for more information. 1500 Vdc HPV-D15V-4A * For PV-(amp)A10F-CT fuse specifications and derating curves see data sheet no. 10121 at Eaton.com/bussmannseries. Recommended tools • Sta-Kon™ terminal crimping tool, catalog no. ERG4002 • Multi-Contact assembly tool, catalog no, PV-RWZ with PV-KOI+II and PV-KOIII tapered spindles Data sheet no.: 2157 6-4 Data sheet no. 720132 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Photovoltaic fuses, holders, and blocks — 6 NH 1000 Vdc blade and bolt-on PV fuses A range of 1000 Vdc NH size Photovoltaic (PV) fuses specifically designed for protecting and isolating array combiners/ re-combiners, disconnects and inverters. 2011/65/EU Ratings • Volts 1000 Vdc • Amps 32-400 A • IR 50 kA Agency information • UL Listed, Guide JFGA, File E335324, Photovoltaic to UL 248-19, IEC 60269-6 gPV, CSA Class 1422-30, File 53787 (32-160 A), UL Listed, IEC gPV, CSA, CCC Pending, RoHS compliant Features • Compact size saves panel space and extends design flexibility • Bolt-on versions have common hole centers for standardizing busbar designs across 63-400 amp range • Low power loss for greater efficiency and lower operating temperature • Global agency standards simplifies design considerations for worldwide markets • Dual indication feature and optional microswitches make system monitoring easier Catalog no. Blade versions PV-32ANH1 PV-40ANH1 PV-50ANH1 PV-63ANH1 PV-80ANH1 PV-100ANH1 PV-125ANH1 PV-160ANH1 PV-200ANH1 PV-250ANH2 PV-300ANH3 PV-315ANH3 PV-350ANH3 PV-355ANH3 PV-400ANH3 Bolt-on versions PV-63ANH1-B PV-80ANH1-B PV-100ANH1-B PV-125ANH1-B PV-160ANH1-B PV-200ANH1-B PV-250ANH2-B PV-315ANH3-B PV-355ANH3-B PV-400ANH3-B NH size 1 2 3 1 2 3 Amps I2t (A2S) PreTotal @ arcing 1000V Watts loss 0.8 In In 32 40 50 63 80 100 125 160 200 250 300 315 350 355 400 80 185 400 470 640 1300 2600 5200 10,200 17,000 32,000 32,000 44,500 44,500 67,500 720 1670 3600 4300 5760 11,700 23,400 46,800 82,000 136,000 260,000 260,000 370,000 370,000 550,000 4 5 6 6 8 8 9 14 13 19 24 26 27 28 30 8 9 11 12 15 16 17 27 25 38 40 44 45 46 50 63 80 100 125 160 200 250 315 355 400 470 640 1300 2600 5200 10,200 17,000 32,000 38,000 61,000 4300 5760 11,700 23,400 46,800 82,000 136,000 260,000 310,000 490,000 6 8 8 9 14 13 19 26 29 32 12 15 16 17 27 25 38 44 48 50 • Recombiner boxes • Inverters PV fuses, holders, blocks and SPDs Typical applications Recommended fuse blocks • SD_ and TD_, see page 6-11 Optional microswitches† Catalog no. Tab size - mm (inch) 170H0236 250/6.3 (1/4) 170H0238 110/2.8 (0.11) BVL50 187/4.8 (3/16) Connection Volts Quick connect 250 Amps 2 2 6 Blade versions mount in fuse blocks † For use with bladed version. Bolt-on versions mount directly to busbas and conductor terminals Data sheet no. 720133 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 6-5 6 — Photovoltaic fuses, holders and blocks Agency information PV 1500 Vdc 10x85mm PV fuses A range of 10x85mm PV fuses specifically designed for protecting and isolating photovoltaic strings. These fuse links are capable of interrupting low overcurrents associated with faulted PV systems (reverse current, multi-array fault). 2011/65/EU • UL 248-19 • IEC 60269 • RoHS compliant Features Mounts in Bussmann series CHPV15L85 DIN-Rail holder. See page 6-10. • Designed for fast-acting protection under low fault current conditions associated with PV systems Ratings • UL and IEC photovoltaic standards for global product acceptance • Low watts loss for greater PV system efficiency • Volts 1500 Vdc • Amps 2.25-30 A • IR 30 kA, 1 ms Typical applications • Combiner boxes, wire harnesses Operating class • gPV I2t (A2s) Catalog no. Watts loss (W) Amps Pre-arcing Total at 1500 Vdc 0.8 In In PV-2.25A10F85L 2.25 3 10 1.4 2.4 PV-2.5A10F85L 2.5 4 10 1.3 2.1 3 7 20 1.3 2.2 3.5 10 20 1.6 2.6 PV-3A10F85L PV-3-5A10F85L PV-4A10F85L 4 15 30 1.7 2.8 PV-5A10F85L 5 33 60 1.7 2.8 PV-12A10F85L 12 19 240 2.1 3.5 PV-15A10F85L 15 42 300 2.2 3.6 PV-16A10F85L 16 48 350 2.1 3.5 PV-20A10F85L 20 108 800 2.7 4.5 PV-25A10F85L 25 190 1400 3.4 5.6 PV-30A10F85L 30 268 1090 4.0 6.6 Data sheet no. 10658 PV15M-4A-CT 1500 Vdc in-line PV fuse with crimp terminals Catalog number Bussmann series PV15M-4A-CT is a 1500 Vdc in-line photovoltaic fuse with crimp terminals for use in wire harnesses and other applications where an in-line PV fuse is desirable. Conductor • • PV15M-4A-CT Single PV stranded 75/90°C Cu This in-line fuse can be electrically insulated with customer-supplied overmolding or approved heat-shrink. Operating temperature range Ratings -40°C to 90°C 2011/65/EU • Volts 1500 Vdc • Amps 4 A • IR 15 kA DC • Time constant 3 ms max. • Agency information • UL Recognized, 248-19, File E484317 Vol. 1 Sec. 1, CSA pending, RoHS compliant Data sheet no. 10639 6-6 Materials Copper terminals with ceramic fuse body Features • Crimp terminals eliminate the need for a fuse holder or block • 1500 Vdc rating is ideally suited for today's efficient, higher-voltage PV systems Recommended tools Sta-Kon® terminal crimping tool, catalog no. ERG4002 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Photovoltaic fuses, holders, and blocks — 6 XL 1000 Vdc and 1500 Vdc PV fuses Features A range of XL size PV fuses specifically designed for protecting and isolating photovoltaic array combiners and disconnects. These fuses are capable of interrupting low overcurrents associated with faulted PV systems (reverse current, multi-array fault). Optional microswitches available for use in monitoring systems. • High DC voltage rating with fast-acting protection under low fault current conditions for PV systems • Blade or bolt-on mounting for application flexibility • Demonstrated performance in extreme temperature cycling conditions Ratings Typical applications 2011/65/EU Volts • 1000 Vdc (63-600 A) • 1500 Vdc (50-500 A) • Amps (see table) • IR (see table) • Recommended fuse blocks • UL 248-19, Guide JFGA, File E335324, IEC 60269-6 gPV, CSA Class 1422-30, File 53787, RoHS Compliant XL size 1000 Vdc 01 1 2 3 SD_-S-PV blocks, see page 6-10 Optional microswitches Agency information • Recombiner boxes, Inverters • Blade: 170H0235 or 170H0237 for size 01XL, 70H0236 or 170H0238 for sizes 1XL, 2XL and 3L • Bolt-on: 170H0069 for all sizes Catalog no. Bladed version Bolt-on version Amps IR (kA) Pre-arcing PV-63A-01XL PV-80A-01XL PV-100A-01XL PV-125A-01XL PV-160A-01XL PV-200A-1XL PV-160A-2XL PV-200A-2XL PV-250A-2XL PV-315A-2XL PV-355A-2XL — — — — — PV-350A-3L PV-400A-3L PV-500A-3L PV-600A-3L PV-63A-01XL-B PV-80A-01XL-B PV-100A-01XL-B PV-125A-01XL-B PV-160A-01XL-B PV-200A-1XL-B PV-160A-2XL-B PV-200A-2XL-B PV-250A-2XL-B PV-315A-2XL-B PV-355A-2XL-B PV-160A-2XL-3B* PV-200A-2XL-3B* PV-250A-2XL-3B* PV-315A-2XL-3B* PV-355A-2XL-3B* PV-350A-3L-B PV-400A-3L-B PV-500A-3L-B PV-600A-3L-B 63 80 100 125 160 200 160 200 250 315 355 160 200 250 315 355 350 400 500 600 50 50 50 50 50 33 33 33 33 33 33 33 33 33 33 33 50 50 50 50 260 490 870 1930 3900 9400 2780 4950 9450 16,600 26,000 2780 4950 9450 16,600 26,000 31,000 44,500 85,000 137,000 PV-50A-01XL-15 PV-63A-01XL-15 PV-80A-01XL-15 PV-100A-01XL-15 PV-125A-01XL-15 PV-160A-01XL-12 PV-100A-1XL-15 PV-125A-1XL-15 PV-160A-1XL-15 PV-200A-1XL-15 PV-125A-2XL-15 PV-160A-2XL-15 PV-200A-2XL-15 PV-250A-2XL-15 — — — — PV-250A-3L-15 PV-315A-3L-15 PV-350A-3L-15 PV-355A-3L-15 PV-400A-3L-15 PV-450A-3L-15 PV-50A-01XL-B-15 PV-63A-01XL-B-15 PV-80A-01XL-B-15 PV-100A-01XL-B-15 PV-125A-01XL-B-15 PV-160A-01XL-B-12 PV-100A-1XL-B-15 PV-125A-1XL-B-15 PV-160A-1XL-B-15 PV-200A-1XL-B-15 PV-125A-2XL-B-15 PV-160A-2XL-B-15 PV-200A-2XL-B-15 PV-250A-2XL-B-15 PV-125A-2XL-3B-15* PV-160A-2XL-3B-15* PV-200A-2XL-3B-15* PV-250A-2XL-3B-15* PV-250A-3L-B-15 PV-315A-3L-B-15 PV-350A-3L-B-15 PV-355A-3L-B-15 PV-400A-3L-B-15 PV-450A-3L-B-15 50 63 80 100 125 160 100 125 160 200 125 160 200 250 125 160 200 250 250 315 350 355 400 450 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 100 100 100 100 100 100 PV-500A-3L-15 PV-500A-3L-B-15 500 100 I2t (A2s) Total @ rated volts Watts loss 0.8In In 1900 3600 6300 13,900 28,100 27,260 21,000 37,000 70,000 123,000 192,000 21,000 37,000 70,000 123,000 192,000 161,200 231,400 442,000 712,400 13 17 18 20 22 31 25 28 34 40 42 25 28 34 40 42 40 48 50 80 24 29 32 40 44 60 44 50 60 66 68 44 50 60 66 68 65 82 85 108 175 362 565 1100 2200 5000 1250 1950 4200 9400 2200 5000 8800 16,600 2200 5000 8800 16,600 74,000 150,000 195,000 195,000 296,000 412,000 1000 2250 3300 6600 10500 24000 6000 9360 20,160 45,120 15,000 32,000 51,000 85,000 15,000 32,000 51,000 85,000 263,000 533,000 693,000 693,000 1,060,000 1,470,000 14 15 19 22 23 26 24 25 30 31 25 29 32 40 25 29 32 40 28 30 34 34 35 39 25 26 35 40 42 52 43 52 58 61 44 48 57 70 44 48 57 70 49 52 59 59 61 67 532,000 1,890,000 42 73 1500 Vdc 01 1 2 3 * These fuses have revised bolting patterns that are identical to size 3L bolting pattern to allow using both size 2XL and size 3L fuses without changing the dimensional layout of the inverter, combiners and disconnects. Data sheet no. 10201 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 6-7 PV fuses, holders, blocks and SPDs • 6 — Photovoltaic fuses, holders and blocks CHPV Modular, IP20 finger-safe DIN-Rail holders for 10x38mm fuses Features • Enhanced safety with IP20 finger-safe construction Bussmann series CHPV DIN-Rail fuse holders are for 10x38mm IEC and UL photovoltaic fuses rated up to 1000 Vdc. They are available with and without indication in 1- and 2-pole IP20 finger-safe versions. A variety of accessories extends their application flexibility and they may be ganged together to meet specific application requirements. • Wiring flexibility with terminals rated for use with 75°C or 90°C solid, stranded and fine stranded wire, and spade terminals and comb busbars. (Use any higher temperature insulations at the 90°C ampacity with appropriate derating.) • Complete range of UL Listed and high SCCR rated one- and threephase finger-safe comb busbars and power feed lugs Ratings • Volts 1000 Vdc (or less) • Amps 30 A • SCCR 33 kA DC Optional open fuse indicator Fuse access door accommodates 4mm lockout/ tagout device 2011/65/EU IP20 finger-safe construction Captive phil-slot terminal screw Toolless ganging for multiple poles Agency information • UL Listed to 4248-19, Guide IZMR, File E348242 • CSA, Class 6225-30, File 47235 • IEC 60269-2 • CCC • RoHS compliant • CE Toolless 35mm DIN-Rail mounting Fork lug connection Dual conductor rated box lug clamp Wire strip gauge Mounting 35mm DIN-Rail Wire range - AWG (mm2) • 75°C and 90°C* Cu • 18-4 (0.8-21.1) • Solid, stranded, fine stranded * May be used with higher temperature rated conductors with appropriate derating. Gang multiple poles to meet application requirements using kit catalog number JV-L (gangs up to four poles). Terminals • Single or dual conductors • Comb busbar Torque 30 lb-in (3.4 N•m) maximum Flammability UL 94V0, self-extinguishing Storage and operating temperature • -4°F (-20°C) to 194°F (90°C) indicating • -4°F (-20°C) to 248°F (120°C) non-indicating Catalog no. With indication* Without indication CHPV1IU CHPV1U CHPV2IU CHPV2U Volts / amps Agency marks 1000 Vdc/30 A UL, CSA, , UL 4248-18, IEC 60269-1, CCC Poles 1 2 SCCR 33 kA DC Recommended Bussmann series fuses PV-(amp)A10F, PV10M-(amp) * All models require 90 V minimum for illumination. Data sheet no. 10430 6-8 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Photovoltaic fuses, holders, and blocks — 6 Features BPVM modular blocks for 10x38mm fuses The Bussmann series BPVM modular style 1000 Vdc fuse blocks for use with 10x38mm (13/32” x 1-1/2”) photovoltaic fuses up to 30 amps contain multiple features to add versatility, reduce labor and enhance safety of any panel design. Optional IP20 fingersafe covers enhance safety with a lockout/tagout feature along with optional open fuse indication to speed troubleshooting. Ratings • Volts 1000 Vdc • Amps 30 A • SCCR 33 kA • Blocks are fully modular with a snap-together design that provides tool-less assembly of multiple pole blocks at point-of-use to reduce inventory and save assembly time and labor • DIN-Rail and panel mount versatility allows one product to be used for multiple applications, lowering inventory cost • Compact footprint consumes minimal panel space • Optional see-through cover enhances safety with IP20 finger-safe protection, lockout/tagout capability and open circuit indication • Easy circuit identification with available universal marker labels for fuse block covers • Tin-plated bimetallic copper fuse clips deliver superior fatigue resistance compared to traditional spring brass • Listed to UL 4248-18 for photovoltaic application BPVM-2C with CVRI-CCM covers Blocks • UL Listed, Guide IZMR, File E348242 • CSA Component Acceptance, Class 6225-01, File 47235 • RoHS compliant • CE Terminal type AWG range Box lug (“CR” Option) Cu 2-14, Al 2-8 Screw (S) Cu 10-18 Torque lb-in (N•m) Cu 2-3 — 50 (5.6) Cu 4-6 — 45 (5.1) Cu 8-14 — 35 (4.0) Al 2-6 — 50 (5.6) Al 8 — 40 (4.5) 10-18 — 20 (2.3) Covers • Covers are included in the overall UL Listing and CSA Acceptance • IP20 finger-safe • RoHS Compliant Catalog no. Terminal type #10-32 Philslot screw Box lug BPVM-1S BPVM-1C BPVM-2S BPVM-2C Poles • 1-, 2-pole units factory assembled • Single-pole units snap together to create desired number of poles Flammability ratings • Blocks — UL 94V0, self-extinguishing • Covers — UL 94HB, self-extinguishing Poles 1 2 Fuse size/class 10x38mm (13/32" x 1-1/2”) gPV and PV Recommended covers* Cover part numbers Indicating CVRI-CCM Non indicating CVR-CCM * For use with 4 AWG max conductors. Operating and storage temperature range • Blocks -40°C to +120°C • Non-Indicating covers -40°C to +120°C • Indicating covers -20°C to +90°C* * Indication requires minimum 90 Vac/dc and closed circuit to illuminate. Recommended Bussmann series fuses • 10x38mm PV fuses • Fast-acting 600 Vdc PVM fuses • Class gPV 1000 Vdc PV fuses Recommended DIN-Rail end stops • Catalog no. BRKT-ND or BRKT-NDSCRW2 Data sheet no. 10265 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 6-9 PV fuses, holders, blocks and SPDs • Available in 1- and 2-pole configurations to meet stocking requirements Terminal specifications for 75/90°C Cu and Al wire Agency information • • 2011/65/EU 6 — Photovoltaic fuses, holders and blocks CHPV15L85 holder for 10x85mm and 14x85mm fuses CHPV15L85 fuse holder can be used with 10x85mm and 14x85mm cylindrical gPV fuses. The unique design offers a high degree of safety with no possibility of any accidental contact with live parts during fuse replacement. When the fuse carrier is extracted, it continues to cover the live parts. SD blocks for XL size PV fuses SD XL PV fuse blocks are available with integral shields specifically designed to be fitted with Bussmann series XL photovoltaic fuses (see data sheet 10201). Ratings • Volts 1500 Vdc • Amps Ratings 2011/65/EU • Volts 1500 Vdc • Amps 32 A (UL and IEC) • SCCR 50 kA • Impulse withstand Uimp 12 kV (tested at 18.5 kV) Agency information • 250 A • 400 A • 630 A 2011/65/EU Agency information • IEC 60269-1 • UL Listed, File E348242 • RoHS complaint • cULus 4248-1 Edition 1, File E384242 • cULus 4248-19 Edition 1, File E14853 Poles • IEC 60269-1 • 1 • RoHS compliant • Power acceptance • Sizes 01XL and 1XL: 56 W • Size 2XL: 70 W • Size 3L: 96 W Poles 1 Fuse rated power dissipation • Up to 8.5 W max Protection level Protection level • • IP20 Storage and operating temperature range • Minimum permitted ambient temperature: -40°C (installation only at temperatures > -5°C). Service conditions as per IEC 61439-1, maximum pollution degree 3. • Box terminal, Cu 4-10mm2 flexible, directly clamped or with wireend ferrules (flexible + wire-end ferrule may not be possible with maximum cross-section) To order • • -45°C to 80°C (with fuse derating above 40°C) Mounting Panel UL94 Flammability rating 35mm DIN-Rail Terminals • Operating temperature range • Mounting IP20 with terminal covers and gripping lug cover in place and shielding of any exposed part of the terminal lugs • Block V-2 • Terminal cover V-0 Catalog no. SD1XL-S-PV SD2XL-S-PV Specify catalog number CHPV15L85 Description 1-pole PV fuse block SD3L-S-PV XL fuse size 01XL and 1XL 250 2XL 400 3L 630 Accessory Features • Global accreditation • 32 amp current rating for UL and IEC Catalog no. Description FEH1500 Fuse extraction handle available for sizes 01XL to 3L Compatible Bussmann series fuses • PV-xA10F85 10x85mm fuses • PV-xxA14LF10F 14x85mm fuses Data sheet no. 10628 6-10 Amps Data sheet no. 10066 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Photovoltaic fuses, holders, and blocks — 6 SD and TD blocks for NH size PV fuses Flammability rating SD PV fuse blocks for NH fuse sizes 1 to 3 NH are available in 1- and 3-pole versions and are specifically designed for use with Bussmann series bladed NH photovoltaic fuses (see data sheet 720133). • UL 94V0 Catalog no. Poles Ratings SD1--D-PV 1 TD1--D-PV 3 Volts SD2-D-PV 1 TD2-D-PV 3 SD3-D-PV 1 TD3-D-PV 3 • • • 1500 Vdc (IEC) Amps • 250 A (SD1) • 400 A (SD2) • 630 A (SD3) 2011/65/EU NH PV fuse block NH fuse size Amps 1 250 2 400 3 630 Accessories SCCR 50 kA Fuse extraction handle Agency information Catalog no. FEH Size Amps NH1 to 3 250 to 630 • IEC 60269-1 • UL Listed, File E348242 • CSA File 47235 Catalog no.* Fuse block • RoHS compliant SD12-SK SD1 and TD1 NH1 250 SD12-SK SD2 and TD2 NH2 400 SD3-SK SD3 and TD3 NH3 630 Fuse size Amps Shroud kits Poles • 1 and 3 SD1 - 32 W • SD2 - 45 W • SD3 - 60 W Amps Description Includes 2 shrouds and 1 fuse cover * Order one kit per pole. Shown with optional shroud kit Power acceptance • Fuse size Protection level • IEC - IP20 with shroud kit installed and shielding of any exposed terminal lugs • UL - Installation of shroud kit decreases the likelihood of incidental terminal contact. To ensure compliance to IP20 specifications per UL the installer must make additional provisions. Operating temperature range • IEC Standards -20°C to 70°C • UL -20°C to 90°C Max* Phase barrier kits Catalog no.† Fuse block SD12-PB SD1 and TD1 NH1 250 SD12-PB SD2 and TD2 NH2 400 SD3-PB SD3 and TD3 NH3 630 Description 2 phase barriers and 2 ganging links PV fuses, holders, blocks and SPDs • Description † Order one kit per pole. Microswitches Catalog no. Ratings BVL50 6 A 250 Vac 170H0236 2 A 250 Vac 170H0238 2 A 250 Vac Neutral links * Dependant upon rating of customer supplied lugs. Catalog no. Fuse block Storage temperature range SDL-1 SD1 and TD1 NH1 250 IEC and UL -40°C to 90°C SDL-2 SD2 and TD2 NH2 400 SDL-3 SD3 and TD3 NH3 630 • Fuse size Amps Mounting • 35mm DIN-Rail • Panel Data sheet no. 720149 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 6-11 BUSSMANN SERIES Bussmann series products at your fingertips We make searching for and selecting Bussmann™ series products easy with four unique product selector tools: Surge Protective Device Selector Low Voltage Fuses Selector Medium Voltage Fuse Selector Connector Selector Each tool allows you to select from available attributes to find the product that best meets your needs. Results are then displayed with links to product detail webpages for more information. Quick access to our team of experts for additional assistance is also made available. And with a responsive design, the tools can be used anytime, anywhere. Find these selector tools and more at toolbox.bussmann.com. Follow us on social media to get the latest product and support information. Medium voltage fuses — 7 Contents Section page Description Introduction 2 E-Rated current-limiting A fusible solution for virtually every medium voltage application 2.75 kV 3-4 5.5 kV 5-7 5.5 kV specialty mount 8-10 8.3 kV 11-12 8.3 kV specialty mount 13-14 15.5 kV 15-17 15.5 kV specialty mount 18-19 DIN E-Rated current-limiting — 5.5-38 kV 20-21 R-Rated current-limiting 2.4 kV 22 4.8 kV 23-24 7.2 kV 25 PT E-Rated current-limiting — 2.475-38 kV 26-29 30 British IEC 31 DIN IEC 32 Expulsion fuse links 33 EEI-NEMA Type K and T – Type H and N 34 PT fuse mountings 35 Recommended fuseclips 36 Medium voltage fuses PT fast-acting current-limiting Bussmann series E-Rated, R-Rated and PT medium voltage fuses BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 7-1 7 — Medium voltage fuses E- and R-Rated fuses Introduction Worldwide circuit protection solutions Eaton is the world-leading supplier of Bussmann series medium voltage fuses. Each product is backed by an efficient worldwide distribution network with unrivaled service and technical support. Eaton circuit protection solutions comply with major international standards: ANSI, BS, DIN, IEC and UL. Fuse types Medium voltage fuses generally fit into two categories – expulsion fuses and current limiting. The definitions per ANSI C37.40 are: Expulsion fuse: A vented fuse in which the expulsion effect of the gases produced by internal arcing, either alone or aided by other mechanisms results in current interruption. Expulsion fuses will limit the duration of an overcurrent event, but they will not limit the magnitude of fault current. Current-limiting fuse: A fuse unit that, when in its currentresponsive element is melted by a current within the fuse’s specified current-limiting range, abruptly introduces a high resistance to reduce current magnitude and duration, resulting in subsequent current interruption. A current limiting fuse will reduce the magnitude a fault current as well as limit the duration of the overcurrent event when operating in its current limiting range. Eaton offers a broad range of current limiting fuses for protection of feeders, transformers and motor circuits designed to ANSI, BS, DIN and IEC standards. In North America, current limiting fuses typically fall into the category of E-Rated fuses and R-Rated fuses. Eaton also offers a wide range of Bussmann series current limiting fuses designed to BS, DIN and IEC standards. E-Rated fuses are used to protect feeder circuits, power transformers and potential transformers. E-Rated fuses have defined current response times specified by ANSI C37.46. E-Rated fuses 100 amps and below must melt in 300 seconds at an RMS current within the range of 200 to 240 percent of the continuous current rating. E-Rated fuses above 100 amps must melt in 600 seconds at an RMS current within the range of 220 to 264 percent of the continuous current rating of the fuse. Eaton offers a wide variety of full range and general purpose E-Rated fuses from 2.4 to 38 kV. R-Rated fuses are back-up fuses that provide short-circuit protection for motor circuits. They are applied with medium voltage motor starters which provide the overload protection for the circuit. R-Rated fuses also have defined current response times specified by ANSI C37.46. R-Rated fuses will melt in a range of 15 to 35 seconds at a current equal to 100 times the “R” rating. Bussmann series R-Rated fuses for motor circuit protection are available in voltage ratings from 2.4 to 8.3 kV Medium voltage current-limiting fuses Current-limiting fuses are classified into three categories: 1. Full range – defined by ANSI C37.40 as “a fuse capable of interrupting all currents from the maximum rated interrupting current down to the minimum continuous current that causes the melting of the fusible element(s), when the fuse is applied at the maximum ambient temperature specified by the manufacturer.” It is able to interrupt any current that will melt its element. 2. General purpose – defined by ANSI C37.40 as “a fuse capable of interrupting all currents from the maximum rated interrupting current down to the current that causes melting of the fusible element(s) in one hour.” Not all currents fall within this range. It is possible for the fuse to be exposed to an overcurrent lower than the value given by the one hour criteria. In that case, a different overcurrent protection device would be required to interrupt the overcurrent. 3. Back-up – defined by ANSI C37.40 as “a fuse capable of interrupting all currents from the maximum interrupting rating current down to the minimum interrupting current.” The minimum interrupting current is the lowest current that the fuse will be able to clear properly. This creates a need to place a low current interrupting device, such as motor overloads, in series with the back-up rated fuse. 7-2 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Medium voltage fuses — 7 2.75 kV E-Rated medium voltage ferrule fuses Dimensions — in (mm) Catalog symbols • 2CLE-_E • JCX-_E C B Ratings • Volts 2.75 kV • Amps 10 to 450 A • Interrupting ratings • 50 kA RMS Sym. (2CLE-_E) • 40 kA RMS Sym. (JCX-_E) 3.31 (84.1) B A Agency information E-Rated fuses meet the performance characteristics of ANSI C37.46 • Recommended CLE fuse holders Approx. dimensions — in (mm) Amps CLE 15E–25E Single barrel 10E–225E Single barrel 250E–300E 350X-450X Double barrel Fuse mounting type Non-disconnect Disconnect† Non-disconnect Disconnect† Non-disconnect BIL (kV) Diameter A Clip center B Length C 2 (51) 8.1 (206) 9.5 (241) 3 (76) 7 (178) 10.9 (277) 60 Disconnect † Catalog no. Mounting* Porcelain insulator Glass-polyester insulator Live parts (with end fittings) End fittings (disconnect only) 2CLE-PNM-C 2CLE-PDM-C 2CLE-PNM-D 2CLE-PDM-D 2CLE-PNM-E 2CLE-GNM-C 2CLE-GDM-C 2CLE-GNM-D 2CLE-GDM-D 2CLE-GNM-E CLE-NL-C CLE-DL-C CLE-NL-D CLE-DL-D CLE-NL-E — CLE-DF-C — CLE-DF-D — 2CLE-PDM-E 2CLE-GDM-E CLE-DL-E CLE-DF-E * Includes live parts and end fittings, end fittings supplied only when required. † Disconnect mountings provide a means for fuse extraction only. Do not use a disconnect mounting for load switching or fuse removal while energized. Recommended fuseclips Fuse dia. — in (mm) 2 (51) Enclosed fuseclip Open fuseclip Spring loaded open fuseclip 3 (76) Catalog no. A3354710* A3354730* 1A0065 9078A67G04 Medium voltage fuses Description * For single barrel applications only. Not sold in pairs. Data sheet no. 10350 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 7-3 7 — Medium voltage fuses CLE and JCX Amps Dimensions — in (mm) Length A Diameter B Clip centers C IR RMS Sym. (kA) No. of barrels Installation location Catalog no. 1 JCX-1E 2 3 5 7 10 10 15 20 25 30 40 50 65 80 100 125 150 200 225 250* 300* 350** 400** 450** JCX-2E JCX-3E JCX-5E JCX-7E JCX-10E 2CLE-10E 2CLE-15E 2CLE-20E 2CLE-25E 2CLE-30E 2CLE-40E 2CLE-50E 2CLE-65E 2CLE-80E 2CLE-100E 2CLE-125E 2CLE-150E 2CLE-200E 2CLE-225E 2CLE-250E 2CLE-300E 2CLE-350X 2CLE-400X 2CLE-450X 9.2 (234) 2 (51) 10.9 (277) 3 (76) 9.5 (241) 2 (51) 7 (178) 40 Indoor/outdoor 8.1 (206) 1 50 10.9 (277) 3 (76) Indoor 7 (178) 2 * 250 and 300 amp ratings may also be applied at 280 and 325 amps respectively, but fuses will no longer be complaint with ANSI E rating criteria. ** Does not comply with ANSI C37.46 for “E” rating. Data sheet no. 10350 7-4 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Medium voltage fuses — 7 5.5 kV E-Rated medium voltage ferrule fuses Dimensions — in (mm) C Catalog symbols General purpose • • 5CLE-_E-D (10-25 A) • 5CLE-_E (10-1350 A) • 5HLE-_E (10-450 A) • JCY-_E (1-25 A) B 3.31 (84.1) Full range (per ANSI C37.40) • • MV055F_ (10-450 A) B Ratings* A • Volts 5.5 kV • Amps 1 to 1350 A • Interrupting ratings 40 to 63 kA RMS Sym. * See catalog number tables for voltages, ampacities and interrupting ratings by catalog number. Agency information • E-Rated fuses meet the performance characteristics of ANSI C37.46 • UL Listed, Guide JEEG, File E240398. See catalog numbers. Recommended fuseclips Description Fuse dia. — in (mm) 2 (51) Enclosed fuseclip Open fuseclip Spring loaded open fuseclip 3 (76) Catalog no. A3354710* A3354730* 1A0065 9078A67G04 * For single barrel applications only. Not sold in pairs. Amps CLE 10E-D–25E-D 30E–250E Single barrel 15E–25E Single barrel 300E–450E Double barrel Fuse mounting type Approx. Dimensions — in (mm) BIL Diameter Clip center (kV) A B Length C Non-disconnect 3.0 (76.2) 14.0 (355.6) 17.9 (454.7) Disconnect † Non-disconnect Disconnect† Non-disconnect Disconnect† 600E and 750E Consult factory Double barrel 1100E and 1350E Consult factory Four barrel HLE Non-disconnect 10E-D–250E Single barrel Disconnect Non-disconnect 300E–450E Double barrel Disconnect 60 Catalog no. Mounting* Porcelain insulator Glass-polyester insulator Live parts (with end fittings) End fittings (disconnect only) 5CLE-PNM-D 5CLE-GNM-D CLE-NL-D — 5CLE-PDM-D 5CLE-GDM-D CLE-DL-D CLE-DF-D 5CLE-PNM-C 2.0 (50.8) 11.5 (292.1) 12.9 (327.7) 5CLE-PDM-C 5CLE-PNM-E 3.0 (76.2) 14.0 (355.6) 17.9 (454.7) 5CLE-PDM-E 5CLE-GNM-C 5CLE-GDM-C 5CLE-GNM-E 5CLE-GDM-E CLE-NL-C CLE-DL-C CLE-NL-E CLE-DL-E — CLE-DF-C — CLE-DF-E 4.0 (101.6) — — — 5HLE-GNM-D 5HLE-GDM-D 5HLE-GNM-E 5HLE-GDM-E CLE-NL-D CLE-DL-D CLE-NL-E CLE-DL-E — CLE-DF-D — CLE-DF-E N/A N/A — — 60 5HLE-PNM-D 5HLE-PDM-D 3.0 (76.2) 12.0 (304.8) 15.9 (403.9) 5HLE-PNM-E 5HLE-PDM-E * Including live parts and end fittings, end fittings supplied only when required. † Disconnect mountings provide a means for fuse extraction only. Do not use a disconnect mounting for load switching or fuse removal while energized. Data sheet no. 10351 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 7-5 Medium voltage fuses Recommended CLE and HLE holders 7 — Medium voltage fuses CLE, HLE and JCY general purpose Amps 1 2 3 5 7 10 10 10 15 15 15 15 20 20 20 20 25 25 25 25 30 30 40 40 50 50 65 65 80 80 100 100 125 125 150 150 175 175 200 200 250 250 300 300 350 350 400 400 450 450 Dimensions — in (mm) Length A Diameter B 11.2 (284) 2 (51) Clip centers C IR RMS Sym. (kA) 9 (229) 40 No. of barrels Installation location Indoor/outdoor 17.9 (455) 15.9 (404) 11.2 (284) 12.9 (328) 17.9 (455) 15.9 (404) 11.2 (284) 12.9 (328) 17.9 (455) 15.9 (404) 11.2 (284) 12.9 (328) 17.9 (455) 15.9 (404) 17.9 (455) 15.9 (404) 17.9 (455) 15.9 (404) 17.9 (455) 15.9 (404) 17.9 (455) 15.9 (404) 17.9 (455) 15.9 (404) 17.9 (455) 15.9 (404) 17.9 (455) 15.9 (404) 17.9 (455) 15.9 (404) 17.9 (455) 15.9 (404) 17.9 (455) 15.9 (404) 17.9 (455) 15.9 (404) 17.9 (455) 15.9 (404) 17.9 (455) 15.9 (404) 17.9 (455) 15.9 (404) 17.9 (455) 15.9 (404) 3 (76) 2 (51) 3 (76) 2 (51) 3 (76) 2 (51) 2 (51) 3 (76) 14 (356) 12 (305) 9 (229) 11.5 (292) 14 (356) 12 (305) 9 (229) 11.5 (292) 14 (356) 12 (305) 9 (229) 11.5 (292) 14 (356) 12 (305) 14 (356) 12 (305) 14 (356) 12 (305) 14 (356) 12 (305) 14 (356) 12 (305) 14 (356) 12 (305) 14 (356) 12 (305) 14 (356) 12 (305) 14 (356) 12 (305) 14 (356) 12 (305) 14 (356) 12 (305) 14 (356) 12 (305) 14 (356) 12 (305) 14 (356) 12 (305) 14 (356) 12 (305) 14 (356) 12 (305) 63 40 50 Indoor 63 Indoor/outdoor 40 50 Indoor 63 Indoor/outdoor 40 50 Indoor 63 1 Indoor/outdoor 65 2 Catalog no. JCY-1E JCY-2E JCY-3E JCY-5E JCY-7E JCY-10E 5CLE-10E-D 5HLE-10E JCY-15E 5CLE-15E* 5CLE-15E-D 5HLE-15E JCY-20E 5CLE-20E* 5CLE-20E-D 5HLE-20E JCY-25E 5CLE-25E* 5CLE-25E-D 5HLE-25E 5CLE-30E 5HLE-30E 5CLE-40E† 5HLE-40E† 5CLE-50E† 5HLE-50E† 5CLE-65E† 5HLE-65E† 5CLE-80E† 5HLE-80E† 5CLE-100E† 5HLE-100E† 5CLE-125E† 5HLE-125E† 5CLE-150E† 5HLE-150E† 5CLE-175E† 5HLE-175E† 5CLE-200E† 5HLE-200E† 5CLE-250E† 5HLE-250E† 5CLE-300E† 5HLE-300E† 5CLE-350E† 5HLE-350E† 5CLE-400E† 5HLE-400E† 5CLE-450E† 5HLE-450E† * Fuses conform to dimensional standards established by Westinghouse. † UL Listed, Guide JEEG, File E240398. Data sheet no. 10351 7-6 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Medium voltage fuses — 7 MV055 full range Amps 5 7 10 10 15 15 20 20 25 25 30 30 40 40 50 50 65 65 80 100 125 150 175 200 250 300 350 400 450 Dimensions — in (mm) Length A Diameter B Clip centers C IR RMS Sym. (kA) No. of Barrels Installation location 2 (51) 15.7 (399) 3 (76) 2 (51) 3 (76) 2 (51) 3 (76) 2 (51) 3 (76) 2 (51) 3 (76) 2 (51) 3 (76) 2 (51) 3 (76) 2 (51) 1 12 (305) 50 Indoor 3 (76) 2 Catalog no. MV055F1CAX5E MV055F1CAX7E MV055F1CAX10E MV055F1DAX10E MV055F1CAX15E MV055F1DAX15E MV055F1CAX20E MV055F1DAX20E MV055F1CAX25E MV055F1DAX25E MV055F1CAX30E MV055F1DAX30E MV055F1CAX40E MV055F1DAX40E MV055F1CAX50E MV055F1DAX50E MV055F1CAX65E MV055F1DAX65E MV055F1DAX80E MV055F1DAX100E MV055F1DAX125E MV055F1DAX150E MV055F1DAX175E MV055F1DAX200E MV055F2DAX250E MV055F2DAX300E MV055F2DAX350E MV055F2DAX400E MV055F2DAX450E Recommended MV055 fuseclips Fuse dia. — in (mm) 2 (51) Enclosed fuseclip Open fuseclip Spring loaded open fuseclip 3 (76) Catalog no. A3354710* A3354730* 1A0065 9078A67G04 Medium voltage fuses Description * For single barrel applications only. Not sold in pairs. Data sheet no. 10351 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 7-7 7 — Medium voltage fuses A X.XX (XX.X) HCL clip-lock 5.5B kV E-Rated medium voltage specialty mount fuses 0.44 x 0.91 (11.2 x 23.1) Catalog symbols Slots A 0.44 (11.2) Dia. Hole • 5AHLE-_E (for EatonCAMPGARD motor starting assemblies) • • 5BHLE-_E / 5BHCL-_E (bolt-on version) 4.31 (109.5) 5CLE-_E • 5HCL-_E (clip-lock version) 0.5 (12.7) Volts 5.5 kV • Amps 10 to 900 A • Interrupting ratings 31 to 63 kA RMS Sym. 0.25 (6.4) 4.31 (109.5) Ratings* • Indicator 1.25 1.25 (31.8) (31.8) B 7.94 (201.7) 7.94 (201.7) * See catalog number tables for voltages, ampacities and interrupting ratings by catalog number. Agency information • 0.5 (12.7) E-Rated fuses meet the performance characteristics of ANSI C37.46 Recommended live parts for clip-lock fuses 11.62 (295.1) • Catalog number HCL-NL-1 11.62 (295.1) 0.38 (9.7) Dimensions — in (mm) BHLE bolt-on Indicator 2.12 (53.8) * Flush with surface in untripped position, trip force is 2 lb (0.9kg) 3.00 (76.2) CLE four-barrel bolt-on 16.0 C B A 10.18 Indicator to be located here 1.19 3.31 (84.1) 20.0 B 2.12 (53.8) C A Indicator to be located here 3.31 (84.1) Note: 1100E and 1350E fuses require two double barrel fuses (4 total barrels) customer to parallel. 3.31 (84.1) B 2.12 (53.8) C A Data sheet no. 10351 7-8 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Medium voltage fuses — 7 AHLE for Eaton AMPGARD motor starting assemblies Amps 10 15 20 25 30 40 50 65 80 100 125 150 175 200 250 300 350 400 450 IR RMS Sym. (kA) No. of barrels Catalog no. 5AHLE-10E 5AHLE-15E 5AHLE-20E 5AHLE-25E 5AHLE-30E 5AHLE-40E† 5AHLE-50E† 5AHLE-65E† 5AHLE-80E† 5AHLE-100E† 5AHLE-125E† 5AHLE-150E† 5AHLE-175E† 5AHLE-200E† 5AHLE-250E† 5AHLE-300E† 5AHLE-350E† 5AHLE-400E† 5AHLE-450E† 1 65 2 † UL Listed, Guide JEEG, File E240398. Amps 10 15 20 25 30 40 50 65 80 100 125 150 200 250 300 400 450 500 600 Dimensions — in (mm) Length A Diameter B Hole centers C IR RMS Sym. (kA) No. of barrels Installation location 16.8 (427) 1 3 (76) N/A 65 Indoor 22.8 (579) 2 Catalog no. 5HCL-10E 5HCL-15E 5HCL-20E 5HCL-25E 5HCL-30E 5HCL-40E† 5HCL-50E† 5HCL-65E† 5HCL-80E† 5HCL-100E† 5HCL-125E† 5HCL-150E† 5HCL-200E† 5HCL-250E† 5HCL-300E† 5HCL-400E† 5HCL-450E† 5HCL-500E 5HCL-600E † UL Listed, Guide JEEG, File E240398. Data sheet no. 10351 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 7-9 Medium voltage fuses HCL clip-lock versions 7 — Medium voltage fuses CLE, BHLE and BHCL bolt-on versions Amps 10 15 20 25 30 40 50 65 80 100 125 150 175 200 200 250 250 300 300 350 400 400 450 450 500 600 600 750 750 900 1100 1350 Dimensions — in (mm) Length A Diameter B 19.2 (488) Hole centers C IR RMS Sym. (kA) No. of barrels Installation location 17.9 (455) 1 3 (76) 65 25.1 (637) 19.2 (488) 25.1 (637) 19.2 (488) 25.1 (637) 23.7 (602) 17.9 (455) 23.7 (602) 17.9 (455) 23.7 (602) 19.2 (488) 17.9 (455) 25.1 (637) 19.2 (488) 23.7 (602) 17.9 (455) 25.1 (637) 23.7 (602) 28.9 25.1 28.9 25.1 Indoor 2 (734) (637) (734) (637) 4 (102) 3 (76) 4 (102) 3 (76) 18.4 (467) 23.7 (602) 18.4 (467) 23.7 (602) 40 63 40 63 3 2 3 19.8 (503) 4 (102) 18.4 (467) 31 4 Catalog no. 5BHLE-10E 5BHLE-15E 5BHLE-20E 5BHLE-25E 5BHLE-30E 5BHLE-40E† 5BHLE-50E† 5BHLE-65E† 5BHLE-80E† 5BHLE-100E† 5BHLE-125E† 5BHLE-150E† 5BHLE-175E† 5BHLE-200E† 5BHCL-200E 5BHLE-250E† 5BHCL-250E 5BHLE-300E† 5BHCL-300E 5BHLE-350E† 5BHLE-400E† 5BHCL-400E 5BHLE-450E† 5BHCL-450E 5BHCL-500E 5BHCL-600E 5CLE-600E 5BHCL-750E 5CLE-750E 5BHCL-900E 5CLE-1100E 5CLE-1350E † UL Listed, Guide JEEG, File E240398. Data sheet no. 10351 7-10 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Medium voltage fuses — 7 8.3 kV E-Rated medium voltage ferrule fuses Dimensions — in (mm) Catalog symbols • 8CLE-_E-D (10-25 A) • 8CLE-_E (10-350 A) • 8HLE-_E (10-350 A) C B Ratings* • Volts 8.3 kV • Amps 10 to 350 A • IR 50 kA RMS Sym. 3.31 (84.1) B * See catalog number tables for voltages, ampacities and interrupting ratings by catalog number. A Agency information E-Rated fuses meet the performance characteristics of ANSI C37.46 • Recommended fuseclips Description Fuse dia. — in (mm) 2 (51) Enclosed fuseclip Open fuseclip Spring loaded open fuseclip 3 (76) Catalog no. A3354710* A3354730* 1A0065 9078A67G04 * For single barrel applications only. Not sold in pairs. Catalog no. Mounting* Porcelain insulator Live parts Glass-polyester (with end insulator fittings) End fittings (disconnect only) 8CLE-PNM-D 8CLE-GNM-D CLE-NL-D — 8CLE-PDM-D 8CLE-GDM-D CLE-DL-D CLE-DF-D 8CLE-PNM-C 15.5 (394) 8CLE-PDM-C 8CLE-PNM-E 17.9 (455) 8CLE-PDM-E 8CLE-GNM-C 8CLE-GDM-C 8CLE-GNM-E 8CLE-GDM-E CLE-NL-C CLE-DL-C CLE-NL-E CLE-DL-E — CLE-DF-C — CLE-DF-E 8HLE-PNM-D 8HLE-PDM-D 15.9 (404) 8HLE-PNM-E 8HLE-PDM-E 8HLE-GNM-D 8HLE-GDM-D 8HLE-GNM-E 8HLE-GDM-E CLE-NL-D CLE-DL-D CLE-NL-E CLE-DL-E — CLE-DF-D — CLE-DF-E Approx. dimensions — in (mm) Amps CLE 10E-D–25E-D 30E–175E Single barrel Fuse mounting type Non-disconnect Disconnect 3.0 (76) † Non-disconnect Disconnect† Non-disconnect 200E–350E Double barrel Disconnect HLE Non-disconnect 10E-175E Single barrel Disconnect† Non-disconnect 200E–350E Double barrel Disconnect† 15E–25E Single Barrel BIL (kV) Diameter A Clip center B 75 2.0 (51) 17.9 (455) 14 (356) 3.0 (76) 75 3.0 (76) Length C 12 (305) * Including live parts and end fittings, end fittings supplied only when required. † Disconnect mountings provide a means for fuse extraction only. Do not use a disconnect mounting for load switching or fuse removal while energized. Data sheet no. 10352 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 7-11 Medium voltage fuses Recommended fuse holders 7 — Medium voltage fuses CLE and HLE Type fuses Dimensions — in (mm) Amps Length A Diameter B Clip centers C IR RMS Sym. (kA) No. of barrels Installation location Catalog no. CLE Long construction (Westinghouse) 10 17.9 (455) 15 15.5 (394) 15 17.9 (455) 20 15.5 (394) 20 17.9 (455) 25 15.5 (394) 25 30 40 50 65 80 100 17.9 (455) 125 150 175 200 250 300 350 HLE Short construction 10 15 20 25 30 40 50 65 80 15.9 (404) 100 125 150 175 200 250 300 350 3 (76) 2 (51) 3 (76) 2 (51) 3 (76) 2 (51) Indoor/outdoor Indoor Indoor/outdoor Indoor Indoor/outdoor Indoor 1 14 (356) 50 3 (76) Indoor/outdoor 2 1 3 (76) 12 (305) 50 Indoor/outdoor 2 8CLE-10E-D 8CLE-15E* 8CLE-15E-D 8CLE-20E* 8CLE-20E-D 8CLE-25E* 8CLE-25E-D 8CLE-30E 8CLE-40E 8CLE-50E 8CLE-65E 8CLE-80E 8CLE-100E 8CLE-125E 8CLE-150E 8CLE-175E 8CLE-200E 8CLE-250E 8CLE-300E 8CLE-350E 8HLE-10E 8HLE-15E 8HLE-20E 8HLE-25E 8HLE-30E 8HLE-40E 8HLE-50E 8HLE-65E 8HLE-80E 8HLE-100E 8HLE-125E 8HLE-150E 8HLE-175E 8HLE-200E 8HLE-250E 8HLE-300E 8HLE-350E * Fuses conform to dimensional standards established by Westinghouse. Data sheet no. 10352 7-12 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Medium voltage fuses — 7 8.3 kV E-Rated medium voltage specialty mount fuses Catalog symbols • 8AHLE-_E (special dimension fuses for use with 7.2 kV rated, 800 amp AMPGARD motor starting assemblies) • 8BHLE-_E (bolt-on version) • 8HCL-_E (clip-lock version) Ratings* • Volts 8.3 kV • Amps 10 to 350 A • Interrupting rating 50 kA RMS Sym. * See catalog number tables for voltages, ampacities and interrupting ratings by catalog number. Agency information • E-Rated fuses meet the performance characteristics of ANSI C37.46 Recommended live parts for clip-lock fuses Catalog number HCL-NL-1 Dimensions for BHLE — in (mm) A Dimensions for HCL — in (mm) X.XX (XX.X) 2.12 (53.8) B 0.44 x 0.91 (11.2 x 23.1) Slots C B A 0.44 (11.2) Dia. Hole Indicator 0.5 (12.7) C A 0.25 (6.4) 4.31 (109.5) 4.31 (109.5) Indicator to be located here 1.25 1.25 (31.8) (31.8) B Medium voltage fuses • 3.31 (84.1) 7.94 (201.7) 7.94 (201.7) B C 2.12 (53.8) A 0.5 (12.7) 11.62 (295.1) Indicator to be located here 0.38 11.62 (295.1) (9.7) 3.31 (84.1) 3.00 Indicator 3.31 (84.1) (76.2) * Flush with surface in untripped position, trip force is 2 lb (0.9kg) B 2.12 (53.8) C A BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Data sheet no. 10352 Eaton.com/bussmannseries 7-13 7 — Medium voltage fuses AHLE Type fuses Special dimension fuses for use with 7.2 kV rated, 800 amp AMPGARD motor starting assemblies. Amps 10 15 20 25 30 40 50 65 80 100 125 150 175 200 250 300 350 IR RMS Sym. (kA) No. of barrels Catalog no. 8AHLE-10E 8AHLE-15E 8AHLE-20E 8AHLE-25E 8AHLE-30E 8AHLE-40E 8AHLE-50E 8AHLE-65E 8AHLE-80E 8AHLE-100E 8AHLE-125E 8AHLE-150E 8AHLE-175E 8AHLE-200E 8AHLE-250E 8AHLE-300E 8AHLE-350E 1 50 2 BHLE bolt-on versions Amps 10 15 20 25 30 40 50 65 80 100 125 150 175 200 250 300 350 Dimensions — in (mm) Overall length Diameter Hole centers IR RMS Sym. (kA) No. of barrels Installation location 1 19.25 (488.9) 3 (76.2) 17.88 (454.2) 50 Indoor 2 Catalog no. 8BHLE-10E 8BHLE-15E 8BHLE-20E 8BHLE-25E 8BHLE-30E 8BHLE-40E 8BHLE-50E 8BHLE-65E 8BHLE-80E 8BHLE-100E 8BHLE-125E 8BHLE-150E 8BHLE-175E 8BHLE-200E 8BHLE-250E 8BHLE-300E 8BHLE-350E HCL Clip lock versions Amps 65 80 100 125 150 Dimensions — in (mm) Overall length Diameter IR RMS Sym. (kA) No. of barrels Installation location 1 22.5 (571.5) 175 200 250 300 350 Hole centers 3 (76.2) N/A 50 Indoor/outdoor 2 Data sheet no. 10352 7-14 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Catalog no. 8HCL-65E 8HCL-80E 8HCL-100E 8HCL-125E 8HCL-150E 8HCL-175E 8HCL-200E 8HCL-250E 8HCL-300E 8HCL-350E Medium voltage fuses — 7 15.5 kV E-Rated medium voltage ferrule fuses Catalog symbols • General purpose B • 15CLE-_E-D (long construction, 10-25 A) • 15CLE-_E (long construction, 15-300 A) • 15HLE-_E (short construction, 10-250 A) • 15LHLE-_E (intermediate construction, 65-300 A) Full range (per ANSI C37.40) • 3.31 (84.1) MV155F_ B Ratings* A • Volts 15.5 kV • Amps 10 to 300 A • Interrupting ratings 31.5 to 63 kA RMS Sym. Dimensions — in (mm) * See catalog number tables for voltages, ampacities and interrupting ratings by catalog number. Recommended fuseclips Description Agency information • E-Rated fuses meet the performance characteristics of ANSI C37.46 • UL Listed, Guide JEEG, File E240398. See catalog numbers. Enclosed fuseclip Open fuseclip Spring loaded open fuseclip Recommended fuse holders Amps CLE 15E–25E Single barrel Non-disconnect Disconnect† 10E-D–25E-D Non-disconnect 30E–150E Single barrel Disconnect† Non-disconnect 175E–300E Double barrel Disconnect† HLE Non-disconnect 10E-125E Single barrel Disconnect† Non-disconnect 150E–250E Double barrel Disconnect† LHLE Non-disconnect 65E–150E Single barrel Disconnect† 175E–300E Double barrel Non-disconnect Disconnect† 3 (76) Catalog no. A3354710* A3354730* 1A0065 9078A67G04 * For single barrel applications only. Not sold in pairs. Approx. dimensions — in (mm) Fuse mounting type Fuse dia. — in (mm) 2 (51) BIL (kV) Diameter 95 110 95 110 95 110 95 110 110 110 95 95 95 95 — — — — Clip center 2 (51) Length 21.5 (546) 20 (508) 3 (76) 3 (76) 3 (76) 23.9 (607) 15 (381) 18 (457) 18.9 (480) Catalog no. Mounting* Live parts Glass-polyester (with end Porcelain insulator insulator fittings) End fittings (disconnect only) 15CLE-PNM-C 15CLE-HPNM-C 15CLE-PDM-C 15CLE-HPDM-C 15CLE-PNM-D 15CLE-HPM-D 15CLE-PDM-D 15CLE-HPDM-D 15CLE-PNM-E 15CLE-PDM-E 15CLE-GNM-C — 15CLE-GDM-C — 15CLE-GNM-D — 15CLE-GDM-D — — — CLE-NL-C CLE-NL-C CLE-DL-C CLE-DL-C CLE-NL-D CLE-NL-D CLE-DL-D CLE-DL-D CLE-NL-E CLE-DL-E — — CLE-DF-C CLE-DF-C — — CLE-DF-D CLE-DF-D — CLE-DF-E 15HLE-PNM-D 15HLE-PDM-D 15HLE-PNM-E 15HLE-PDM-E 15HLE-GNM-D 15HLE-GDM-D — — CLE-NL-D CLE-DL-D CLE-NL-E CLE-DL-E — CLE-DF-D — CLE-DF-E CLE-NL-D — CLE-DL-D CLE-DF-D — CLE-DF-E 20.53 (521) Not available Not available CLE-NL-E CLE-DL-E * Including live parts and end fittings, end fittings supplied only when required. † Disconnect mountings provide a means for fuse extraction only. Do not use a disconnect mounting for load switching or fuse removal while energized. Data sheet no. 10353 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 7-15 Medium voltage fuses • C 7 — Medium voltage fuses CLE, HLE and LHLE Type general purpose fuses Dimensions — in (mm) Amps Length A Diameter B CLE Long construction 10 23.9 (607) 3 (76) 15 21.5 (546) 2 (51) 15 23.9 (607) 3 (76) 20 21.5 (546) 2 (51) 20 23.9 (607) 3 (76) 25 21.5 (546) 2 (51) 25 30 40 50 65 80 100 23.9 (607) 3 (76) 125 150 175 200 250 300 HLE Short construction 10 15 20 25 30 40 50 65 18.9 (480) 3 (76) 80 100 125 150 175 200 250 LHLE 65 80 100 125 150 20.5 (521) 3 (76) 175 200 250 300 Clip centers C IR RMS Sym. (kA) No. of barrels 63 31.5 63 31.5 63 31.5 Installation location Indoor/outdoor Indoor Indoor/outdoor Indoor Indoor/outdoor Indoor 1 20 (508) 63 Indoor/outdoor 2 63 Indoor/outdoor Indoor/outdoor 15LHLE-65E 15LHLE-80E 15LHLE-100E 15LHLE-125E 15LHLE-150E 15LHLE-175E 15LHLE-200E 15LHLE-250E 15LHLE-300E 2 1 18 (457) 50 2 15CLE-10E-D 15CLE-15E* 15CLE-15E-D 15CLE-20E* 15CLE-20E-D 15CLE-25E* 15CLE-25E-D 15CLE-30E 15CLE-40E† 15CLE-50E† 15CLE-65E† 15CLE-80E† 15CLE-100E† 15CLE-125E† 15CLE-150E† 15CLE-175E† 15CLE-200E† 15CLE-250E† 15CLE-300E† 15HLE-10E 15HLE-15E 15HLE-20E 15HLE-25E 15HLE-30E 15HLE-40E† 15HLE-50E† 15HLE-65E† 15HLE-80E† 15HLE-100E† 15HLE-125E† 15HLE-150E† 15HLE-175E† 15HLE-200E† 15HLE-250E† 1 15 (381) Catalog no. * Fuses conform to dimensional standards established by Westinghouse. † UL Listed, Guide JEEG, File E240398. Data sheet no. 10353 7-16 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Medium voltage fuses — 7 MV155F_ Full range Dimensions — in (mm) Length A Diameter B Clip centers C IR RMS Sym. (kA) No. of barrels Installation location 21.7 (551) 18.7 (475) 18 (457) 15 (381) Catalog no. MV155F1CBX5E MV155F1CBX7E MV155F1CBX10E MV155F1DBX10E MV155F1CBX15E MV155F1DBX15E MV155F1CBX20E MV155F1DBX20E MV155F1CBX25E MV155F1DBX25E MV155F1CBX30E MV155F1DBX30E MV155F1DBX40E MV155F1DBX50E MV155F1DBX65E MV155F1DCX65E MV155F1DBX80E 80 21.7 (551) 18 (457) MV155F1DCX80E 100 100 125 125 150 150 175 175 200 200 18.7 (475) 21.7 (551) 18.7 (475) 21.7 (551) 18.7 (475) 21.7 (551) 18.7 (475) 21.7 (551) 18.7 (475) 21.7 (551) 15 (381) 18 (457) 15 (381) 18 (457) 15 (381) 18 (457) 15 (381) 18 (457) 15 (381) 18 (457) MV155F1DBX100E MV155F1DCX100E MV155F2DBX125E MV155F2DCX125E MV155F2DBX150E MV155F2DCX150E MV155F2DBX175E MV155F2DCX175E MV155F2DBX200E MV155F2DCX200E 2 (51) 18.7 (475) 3 (76) 2 (51) 3 (76) 2 (51) 3 (76) 2 (51) 3 (76) 2 (51) 15 (381) 1 50 3 (76) Indoor 2 Medium voltage fuses Amps 5 7 10 10 15 15 20 20 25 25 30 30 40 50 65 65 80 Data sheet no. 10353 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 7-17 7 — Medium voltage fuses 15.5 kV E-Rated medium voltage specialty mount fuses Catalog symbols • 15BHLE-_E (bolt-on version) • 15HCL-_E (clip-lock version) Ratings* • Volts 15.5 kV • Amps 10 to 300 A • Interrupting ratings 50 to 63 kA RMS Sym. * See catalog number tables for voltages, ampacities and interrupting ratings by catalog number. Agency information • E-Rated fuses meet the performance characteristics of ANSI C37.46 Recommended live parts for clip-lock fuses • Catalog number HCL-NL-1 Dimensions — in (mm) X.XX (XX.X) A BHLE B HCL 2.12 (53.8) 0.44 x 0.91 (11.2 x 23.1) Slots Indicator 0.5 (12.7) C B A 0.44 (11.2) Dia. Hole 0.25 C A 4.31 (109.5) 4.31 (109.5) Indicator to be located here 1.25 1.25 (31.8) (31.8) B 3.31 (84.1) 7.94 (201.7) 7.94 (201.7) B C 2.12 (53.8) A 0.5 (12.7) 11.62 (295.1) Indicator to be located here 0.38 11.62 (295.1) (9.7) 3.31 (84.1) 3.00 Indicator 3.31 (84.1) (76.2) * Flush with surface in untripped position, trip force is 2 lb (0.9kg) B 2.12 (53.8) C A Data sheet no. 10353 7-18 (6.4) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Medium voltage fuses — 7 BHCL, BHLE and HCL Type fuses Dimensions — in (mm) Amps Length A BHCL and BHLE bolt-on 10 15 20 25 30 40 50 65 22.2 (563) 80 100 125 150 175 200 250 300 25.1 (637) 400 HCL clip-lock Diameter B Hole centers C IR RMS Sym. (kA) No. of barrels Installation location Catalog no. 1 20.9 (531) 63 Indoor/outdoor 3 (76) 2 23.7 (602) 50 3 Indoor Indoor 15BHLE-10E 15BHLE-15E 15BHLE-20E 15BHLE-25E 15BHLE-30E 15BHLE-40E† 15BHLE-50E† 15BHLE-65E† 15BHLE-80E† 15BHLE-100E† 15BHLE-125E† 15BHLE-150E† 15BHLE-175E† 15BHLE-200E† 15BHLE-250E† 15BHCL-300E 15BHCL-400E 10 15HCL-10E 15 20 25 30 40 50 15HCL-15E 15HCL-20E 15HCL-25E 15HCL-30E 15HCL-40E† 15HCL-50E† 65 80 1 22.8 (579) 3 (76) N/A 63 Indoor 15HCL-65E† 15HCL-80E† 100 15HCL-100E† 125 15HCL-125E† 150 15HCL-150E† 175 15HCL-175E† 200 2 15HCL-200E† 15HCL-250E† 300 15HCL-300E† Medium voltage fuses 250 † UL Listed, Guide JEEG, File E240398. Data sheet no. 10353 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 7-19 7 — Medium voltage fuses 5.5 to 38 kV E-Rated DIN medium voltage fuses Bussmann series DIN dimensioned E-Rated medium voltage power fuses with striker for indoor use. Available in general purpose (5.5 to 17.5 kV) and full range (25.8 to 38 kV) versions. Ratings • Volts 5.5 - 38 kV • Amps 10 - 450 A • Interrupting ratings 25 to 65 kA Agency information • General purpose E-Rated per ANSI C37.46 (5.5 to 17.5 kV) • Full range E-Rated per ANSI C37.40 (25.8 to 38 kV) Striker force • 50 N (11 lbs) Recommended fuseclips See page 7-36 for dimensions. Amp range Description Catalog no. Up to 200 A Enclosed fuseclip with wingnut tensioner A3354745* Open fuseclip with spring tensioner 270303 * Not sold in pairs. Features • Cool running for lower watts loss • 100% X-ray inspected to help assure fuse integrity • Striker provides visual indication of fuse operation or a means to activate a remote monitoring system Typical applications • Primary protection for medium voltage transformers and switch gear • Protection of medium voltage feeder circuits • Direct OEM replacement fuses for 600 A Square D HVLCC and HVL switches Dimensions — in (mm) Striker in operated position (striker force 50 N/11 Lbs) 0.59 (15) 1.77 (45) Diameter Length See catalog numbers tables for diameter and length values. 1.34 (34) 1.02 (26) Data sheet no. 10638 7-20 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Medium voltage fuses — 7 Amps Interrupting rating (Sym. kA) 10 15 20 25 30 40 50 65 80 100 125 150 175 200 250 300 350 400 450 65 175 200 65 10 15 20 25 30 40 50 65 80 100 125 150 10 15 20 25 30 40 50 65 258GXZSJ80E 80 258GXZSJ100E 38 kV 38GFZSJ10E 38GFZSJ15E 38GFZSJ20E 38GFZSJ25E 38GFZSJ30E 100 10 15 20 25 30 Dimensions — in (mm) Length 65 Diameter 17.4 (442) 2 (51) 17.4 (442) 3 (76) 21.1 (537) 3.5 (89) 17.4 (442) 2 (51) 17.4 (442) 3 (76) 17.4 (442) 3.5 (89) 21.1 (537) 3.5 (89) 21.1 (537) 2 (51) 21.1 (537) 3.5 (89) 28.3 (718) 3.5 (89) 28.3 (718) 3 (76) Medium voltage fuses Catalog no. General purpose versions 5.5 kV 55GDMSJ10E 55GDMSJ15E 55GDMSJ20E 55GDMSJ25E 55GDMSJ30E 55GDMSJ40E 55GDMSJ50E 55GDMSJ65E 55GDMSJ80E 55GDMSJ100E 55GDMSJ125E 55GFMSJ150E 55GFMSJ175E 55GFMSJ200E 55GFMSJ250E 55GFMSJ300E 55GFMSJ350E 55GFMSJ400E 55GFMSJ450E 15.5 kV 155GXQSJ175E 155GXQSJ200E 17.5 kV 175GDMSJ10E 175GDMSJ15E 175GDMSJ20E 175GDMSJ25E 175GDMSJ30E 175GFMSJ40E 175GFMSJ50E 175GFMSJ65E 175GXMSJ80E 175GXMSJ100E 175GXQSJ125E 175GXQSJ150E Full range versions 25.8 kV 258GDQSJ10E 258GDQSJ15E 258GDQSJ20E 258GDQSJ25E 258GDQSJ30E 258GXQSJ40E 258GXQSJ50E 258GXQSJ65E 25 25 Data sheet no. 10638 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 7-21 7 — Medium voltage fuses Dimensions — in (mm) 2.4 kV R-Rated fuses Catalog symbols/construction Construction • JCK-_R/Standard • 2CLS-_R/Standard • JCK-A-_R*/AMPGARD Hookeye • 2ACLS-_R/AMPGARD Hookeye • JCH-_R/Hermetically sealed AMPGARD • 2HCLS-_R/Hermetically sealed AMPGARD • JCK-B-_R/Bolt-on • 2BCLS-_R/Bolt-on Standard short AMPGARD Hookeye* Bolt-on Amps 25-230A 390-450A 70-230A 390-450A 25-230A 390-450A Dimension A B 10.8 (274) 3 (76) C 3 (76) 19.2 (488) 17.9 (455) D — 3.3 (84) — 3.3 (84) — 3.3 (84) * Includes hermetically sealed versions. * For use in 400 amp AMPGARD motor starters. Standard and AMPGARD Hookeye Ratings Volts • 2.4 kV (nominal) • • D 2.54 kV (max design) • Amps 25-450 A • Interrupting ratings • 50 kA Sym. • Gripping tab for Hookeye constructions only C B A 80 kA Asym. Bolt-on Agency information UL Recognized: Guide MSSS2, File E96676 (JCK-_R [2R-12R] and JCK-A-_R [2R-12R]) • Indicator Recommended fuseclips and holders for standard constructions Amps Fuseclips 25-230A Description D A3354730 1A0065 9078A67G04 R 0.23 [5.81] Typ. EFGHI Indicator C 2.12 [53.8] Catalog no. 3” Enclosed fuseclip* 3” Open fuseclip 3” Spring loaded open fuseclip 25-450A E = 3 [76.2] F = 2.5 [63.5] G = 2.04 [51.81 H = 0.96 [24.4] I = 0.5 [12.7] 3.0 [76.2] B A 3.0 [76.2] Fuse holders Non-disconnect holder, porcelain Non-disconnect holder, glass polyester 25-230A Single barrel Disconnect holder, porcelain Disconnect holder, glass polyester Non-disconnect holder, porcelain 390-450A Non-disconnect holder, glass polyester Double Disconnect holder, porcelain barrel Disconnect holder, glass polyester 2CLE-PNM-D 2CLE-GNM-D 2CLE-PDM-D 2CLE-GDM-E 2CLE-PNM-E 2CLE-GNM-E 2CLE-PDM-E 2CLE-GDM-E * Single barrel only, not sold in pairs. 2.4 kV R-Rated fuse catalog numbers Amps 25 70 100 130 150 170 200 230 390 450 "R" Des. — 2R 3R 4R 5R 6R 9R 12R 18R 24R Standard — 2CLS-25* (100) JCK-2R (165) 2CLS-2R (180) JCK-3R (220) 2CLS-3R (270) JCK-4R (320) 2CLS-4R (360) JCK-5R (410) 2CLS-5R (450) JCK-6R (480) 2CLS-6R (540) JCK-9R (720) 2CLS-200* (740) JCK-12R (970) 2CLS-230* (1080) JCK-18R (1430)† 2CLS-390* (1500) JCK-24R (1880)† 2CLS-450* (2200) Mounting style (minimum Standard AMPGARD — 2ACLS-25* (90) JCK-A-2R (165) 2ACLS-2R (180) JCK-A-3R (220) 2ACLS-3R (270) JCK-A-4R (320) 2ACLS-4R (360) JCK-A-5R (410) 2ACLS-5R (450) JCK-A-6R (480) 2ACLS-6R (540) JCK-A-9R (720) 2ACLS-200* (740) JCK-A-12R (970) 2ACLS-230* (1080) JCK-A-18R (1430)† 2ACLS-390* (1500) JCK-A-24R (1880)† 2ACLS-450* (2200) interrupting rating in amps) Hermetically sealed AMPGARD JCH-30* (90) 2HCLS-25* (90) JCH-2R (180) 2HCLS-2R (180) JCH-3R (270) 2HCLS-3R (270) JCH-4R (360) 2HCLS-4R (360) JCH-5R (450) 2HCLS-5R (450) JCH-6R (540) 2HCLS-6R (540) JCH-200* (740) 2HCLS-200* (740) JCH-230* (1080) 2HCLS-230* (1080) JCH-390* (1500) 2HCLS-390* (1500) JCH-450* (2200) 2HCLS-450* (2200) No. of Bolt-on barrels JCK-B-25* (90) 2BCLS-25* (90) JCK-B-2R (180) 2BCLS-2R (180) JCK-B-3R (270) 2BCLS-3R (270) JCK-B-4R (360) 2BCLS-4R (360) 1 JCK-B-5R (450) 2BCLS-5R (450) JCK-B-6R (540) 2BCLS-6R (540) JCK-B-200* (740) 2BCLS-200* (740) JCK-B-230* (1080) 2BCLS-230* (1080) JCK-B-390* (1500) 2BCLS-390* (1500) 2 JCK-B-450* (2200) 2BCLS-450* (2200) * Does not comply with ANSI C37.46 for “R” rating. † Not UL Recognized. Data sheet no. 6001 7-22 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Medium voltage fuses — 7 Dimensions — in (mm) 4.8 kV R-Rated fuses Catalog symbols/construction • 5CLS-30 and 5CLS-_R/Standard - short (30 A, 2R-24R) • JCL-_R/Standard - short (2R - 24R) • 5LCLS-_R/Standard - long (2R - 24R) • 5ACLS-30 and 5ACLS-_R/AMPGARD Hookeye* (30 A, 2R-24R) • JCL-A-_R/AMPGARD Hookeye* (2R - 24R) • 5HCLS-30 and 5HCLS-_R/Hermetically sealed AMPGARD Hookeye* (30 A, 2R-24R) • 5BCLS-30 and 5BCLS-_R/Bolt-on (30 A, 2R-44R) • JCL-B-_R/Bolt-on (2R-24R) • 5MCLS-_R-_A and 5MCLS-_R-_B/Bolt-on GE Limitamp (2R- 24R) Construction Amp 30-230 390-450 70-230 390-450 30-230 390-450 30-230 390-450 600-800 70-230 390-450 70-230 390-450 Standard - short Standard - long AMPGARD Hookeye* Bolt-on Limitamp (-A) * For use in 400 amp AMPGARD motor starters Limitamp (-B) Ratings 4.8 kV (nominal) • 5.0 kV (max design) Amps 30-800 A • Interrupting ratings • 50 kA Sym. • 80 kA Asym. 18.3 (465) Indicator C B File E96676: JCL-_R [2R-12R], JCL-A-_R [2R-12R], 5MCLS-_R-A [2R-24R], and 5MCLS-_R-B [2R-24R] E = 3 [76.2] F = 2.5 [63.5] G = 2.04 [51.81 H = 0.96 [24.4] I = 0.5 [12.7] D Recommended fuseclips and holders for standard constructions 3” Enclosed fuseclip* 3” Open fuseclip 3” Spring loaded open fuseclip Fuse holders for CLS / JCL / 5HCLS Non-disconnect holder, porcelain 30-230A Non-disconnect holder, glass polyester Single Disconnect holder, porcelain barrel Disconnect holder, glass polyester Non-disconnect holder, porcelain 390-450A Non-disconnect holder, glass polyester Double Disconnect holder, porcelain barrel Disconnect holder, glass polyester Fuse holders for 5LCLS† Non-disconnect holder, porcelain Non-disconnect holder, glass polyester 70-230A Disconnect holder, porcelain Single Disconnect holder, glass polyester barrel Disconnect holder, porcelain Disconnect holder, glass polyester 390-450A Disconnect holder, porcelain Double Disconnect holder, glass polyester Barrel 30-450A BIL (kV) Catalog no. — A3354730 1A0065 9078A67G04 60 5HLE-PNM-D 5HLE-GNM-D 5HLE-PDM-D 5HLE-GDM-D 5HLE-PNM-E 5HLE-GNM-E 5HLE-PDM-E 5HLE-GDM-E EFGHI R 0.23 [5.81] Typ. Indicator C File E60757: 5CLS-30, 5CLS-_R [2R-18R], 5ACLS-30, and 5ACLS-_R [2R-24R] Description A Bolt-on — 5BCLS-_ UL Recognized, Guide MSSS2 Amps Fuseclips 30-230A 19.2 (488) Gripping tab for Hookeye constructions only D Agency information • 15.6 (396) D — 3.3 (84) — 3 (76) 3.3 (84) 3 (76) — 3.3 (84) — 17.9 (455) 3.3 (84) 4 (101) 9 (229) 4.8 (122) 7.4 (188) 18.8 (478) 1.4 (36) 3.0 (76) 2.4 (61) Ferrule JCL, 5LCLS, 5CLS and AMPGARD Hookeye • • 17.8 (452) C * Includes hermetically sealed versions. Volts • • 15.6 (396) B 2.12 [53.8] 3.0 [76.2] B A 3.0 [76.2] Bolt-on — 5MCLS-_R-A 2 SLOTS (0.38X0.5) 0.25 C 17.7 (striker not extended) 16.5 0.25 0.25 D 7.75 3.1 2.25 Ø3.0 (REF) 60 75 60 5CLE-PNM-D 5CLE-GNM-D 5CLE-PDM-D 5CLE-GDM-D 8CLE-PDM-D 8CLE-GDM-D 5CLE-PDM-E 2.250 A B 2 SLOTS (.343 X .875) C Bolt-on — 5MCLS-_R-B 17.7 (striker not extended) 0.25 Ø3.00 REF 16.5 0.25 0.25 3.1 7.01 2.25 D 0.38 A B 2.25 2 SLOTS (0.38X0.5) 5CLE-GDM-E * Single barrel only, not sold in pairs. ** Not available for standard - long constructions † Not available for 390 to 450 amp ratings. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 2 SLOTS (0.343X0.875) C C Data sheet no. 6001 Eaton.com/bussmannseries 7-23 Medium voltage fuses • Dimension A 7 — Medium voltage fuses 4.8 kV R-Rated fuse catalog numbers Ferrule constructions (min. interrupting rating in amps) Amps Short Short No. of barrels Long 30 5CLS-30* (100) 70 5CLS-2R (180) JCL-2R (165) — 5LCLS-2R (180)† — Bolt-on (min. interrupting rating in amps) Amps Regular No. of barrels Regular 30 5BCLS-30* (100)† 70 5BCLS-2R (180)† — JCL-B-2R (165)† 100 5CLS-3R (270) JCL-3R (220) 5LCLS-3R (270)† 100 5BCLS-3R (270)† JCL-B-3R (220)† 130 5CLS-4R (360) JCL-4R (320) 5LCLS-4R (360)† 130 5BCLS-4R (360)† JCL-B-4R (320)† 150 5CLS-5R (450) JCL-5R (410) 5LCLS-5R (450)† 150 5BCLS-5R (450)† JCL-B-5R (410)† 1 170 5CLS-6R (540) JCL-6R (480) 5LCLS-6R (540)† 170 5BCLS-6R (540)† JCL-B-6R (480)† 200 5CLS-9R (740) JCL-9R (720) 5LCLS-9R (740)† 200 5BCLS-9R (740)† JCL-B-9R (720)† 230 5CLS-12R (1080) JCL-12R (970) 5LCLS-12R (1080)† 230 5BCLS-12R (1080)† JCL-B-12R (970)† 390 5CLS-18R (1500) JCL-18R (1430)† 5LCLS-18R (1500)† 390 5BCLS-18R (1500)† JCL-B-18R (1430)† 450 5CLS-24R (2200)† JCL-24R (1880)† 5LCLS-24R (2200)† JCL-B-24R (1880)† 2 * Does not comply with ANSI C37.46 for "R" rating. † Not UL Recognized. AMPGARD Hookeye (min. interrupting rating in amps) Amps Hookeye Hookeye Hermetic seal — No. of barrels 5HCLS-30* (100)† 450 5BCLS-24R (2200)† 600 5BCLS-32R (3000)† — 650 5BCLS-36R (3200)† — 800 5BCLS-44R (3600)† — 2 * Does not comply with ANSI C37.46 for "R" rating. † Not UL Recognized. 30 5ACLS-30* (100) 70 5ACLS-2R (180) JCL-A-2R (165) 5HCLS-2R (180)† GE Limitamp (min. interrupting rating in amps) 100 5ACLS-3R (270) JCL-A-3R (220) 5HCLS-3R (270)† Amps 130 5ACLS-4R (360) JCL-A-4R (320) 5HCLS-4R (360)† 150 5ACLS-5R (450) JCL-A-5R (410) 5HCLS-5R (450)† 1 30 70 Bolt-on No. of barrels Bolt-on — — 5MCLS-2R-A (180) 5MCLS-2R-B (180) 170 5ACLS-6R (540) JCL-A-6R (480) 5HCLS-6R (540)† 100 5MCLS-3R-A (270) 5MCLS-3R-B (270) 200 5ACLS-9R (740) JCL-A-9R (720) 5HCLS-9R (740)† 130 5MCLS-4R-A (360) 5MCLS-4R-B (360) 230 5ACLS-12R (1080) JCL-A-12R (970) 5HCLS-12R (1080)† 150 5MCLS-5R-A (450) 5MCLS-5R-B (450) 390 5ACLS-18R (1500) JCL-A-18R (1430)† 5HCLS-18R (1500)† 450 5ACLS-24R (2200) JCL-A-24R (1880)† 5HCLS-24R (2200)† 2 * Does not comply with ANSI C37.46 for "R" rating. † Not UL Recognized. 1 170 5MCLS-6R-A (540) 5MCLS-6R-B (540) 200 5MCLS-9R-A (850) 5MCLS-9R-B (850) 230 5MCLS-12R-A (1150) 5MCLS-12R-B (1150) 390 5MCLS-18R-A (1725) 5MCLS-18R-B (1725) 450 5MCLS-24R-A (2350) 5MCLS-24R-B (2350) 1 2 * Does not comply with ANSI C37.46 for "R" rating. † Not UL Recognized. 5CLS, JCL, JCL-A, 5ACLS and 5HCLS Type mountings — in (mm) Hole centers Catalog no. A Disconnect single barrel† 5CLE-GDM-D 15.24 (387.1) 5CLE-PDM-D 5HLE-PDM-D 16.25 (412.8) 5HLE-GDM-D Disconnect double barrel† 5CLE-GDM-E 15.24 (387.1) 5CLE-PDM-E 5HLE-GDM-E 16.25 (412.8) 5HLE-PDM-E Non-disconnect single barrel 5CLE-GNM-D 15.24 (387.1) 5CLE-PNM-D 5HLE-GNM-D 16.25 (412.7) 5HLE-PNM-D Non-disconnect double barrel 5HLE-PNM-E 16.25 (412.7) 5HLE-GNM-E B Overall length C Hole inset D Hole ctr. E Contact hgt. F Overall hgt. G BIL (kV) 0.62 (15.7) 1.75 (44.4) 4.5 (114.3) 11.72 (297.7) 60 0.62 (15.7) 1.75 (44.4) 4.5 (114.3) 15.28 (388.1) 60 0.62 (15.7) 1.75 (44.4) 4.5 (114.3) 8.79 (223.3) 60 0.62 (15.7)\ 1.75 (44.4) 4.5 (114.3) 12.48 (317.0) 60 25 (647.7) 6 (152.4) 23 (584.2) 25 (647.7) 6 (152.4) 23 (584.2) 25 (635.0) 6 (152.4) 23 (584.2) 6 (152.4) 25 (635.0) Data sheet no. 6001 7-24 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Medium voltage fuses — 7 Dimensions — in (mm) 7.2 kV R-Rated fuses Catalog symbols/construction • 8CLS-_R/Standard (2R - 6R) • 8ACLS-_R/AMPGARD Hookeye* (2R - 6R) • 7BCLS-_R/Bolt-on (2R - 6R) Construction Standard AMPGARD Hookeye Bolt-on 70-170 Dimension A B 15.8 (401) 3 (76) 19.2 (488) 17.9 (455) C 3 (76) Standard and AMPGARD Hookeye * For use in 400 amp AMPGARD motor starters. Gripping tab for Hookeye constructions Ratings • Amps Indicator Volts C • 7.2 kV (nominal) • 8.3 kV (max design 70-170 A standard and AMPGARD Hookeye) • 7.2 kV (max design 70-170 A bolt-on) • Amps 70-170 A • Interrupting ratings • 50 kA Sym. • 80 kA Asym. B A Bolt-on Recommended fuseclips and holders for standard constructions Amps Description Fuseclips 3” Enclosed fuseclip* 70-170 3” Open fuseclip 3” Spring loaded open fuseclip Fuse holders for 7CLS and 8CLS Non-disconnect holder, porcelain Non-disconnect holder, glass polyester 70-170 Disconnect holder, porcelain Disconnect holder, glass polyester BIL (kV) Cat. No. — 75 A3354730 1A0065 9078A67G04 8HLE-PNM-D 8HLE-GNM-D 8HLE-PDM-D 8HLE-GDM-D E = 3 [76.2] F = 2.5 [63.5] G = 2.04 [51.81 H = 0.96 [24.4] I = 0.5 [12.7] R 0.23 [5.81] Typ. EFGHI Indicator C 2.12 [53.8] B A 3.0 [76.2] * Single barrel only, not sold in pairs. 7.2 kV R-Rated fuse catalog numbers “R” Designation 2R 3R 4R 5R 6R Mounting style (minimum interrupting rating in amps) Standard AMPGARD Hookeye 8CLS-2R (160) 8ACLS-2R (160) 8CLS-3R (250) 8ACLS-3R (250) 8CLS-4R (325) 8ACLS-4R (325) 8CLS-5R (390) 8ACLS-5R (390) 8CLS-6R (500) 8ACLS-6R (500) Bolt-on 7BCLS-2R 7BCLS-3R 7BCLS-4R 7BCLS-5R 7BCLS-6R No. of barrels (160) (250) (325) (390) (500) Medium voltage fuses Amps 70 100 130 150 170 1 Data sheet no. 6001 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 7-25 7 — Medium voltage fuses E-Rated PT medium voltage fuses Dimensions — in (mm) C B A Catalog symbols (by maximum voltage rating) • 2.475 kV • • • • • • 2NCLPT-_ 3.6 kV 12 kV • 12ABCNA_ • 12CAV_ • 3.6ABCNA_ • 3.6ABWNA_ • 15CLPT-_E • 3.6CAV_ • 15NCLPT-_E-A • 15NCLPT-_E-B • 5.5 kV 15.5 kV • JCW-_ • 15.5CAV_E • 5CLPT-_E • 15.5CAVH_E • 5NCLPT-_E • 5NCLPT-_E-A • 17.5ABGNA_ • 5.5ABWNA_E • 17.5CAV_ • 5.5AMWNA_E • 5.5CAV_E • 24ABGNA_ • 5.5CAVH_E • 24CAV_ • • 7.2 kV • PTFB-2500-JCD 25.5 kV • 7.2ABCNA_ • 7.2AMWNA_E • 36ABGNA_ • 7.2CAV_ • 36CAV_ • • Catalog no. 1A1837 24 kV 7.2ABWNA_ 8.3 kV Description Open fuseclip for 0.8 (20 mm) dia. fuses Single-pole open fuse block with #10-32 phil-slot screw terminals rated 2500 V, 5 A maximum and 63 kA withstand rating 17.5 kV • • Recommended fuseclip and block 25CLPT-_E 36 kV 38 kV • 8CLPT-_E-A • 38CAV_E • 8NCLPT-_E • 38CAVH_E • 8NCLPT-_E-A • 38CLPT-_E • 8NCLPT-_E-B Ratings* • Volts 2.4 kV to 38 kV • Amps 0.25 to 15 A • Interrupting ratings 25 to 80 kA RMS Sym. * See catalog number tables for voltages, ampacities and interrupting ratings by catalog number. Agency information • PT fuses conforming to the requirements for E-Rating meet the performance characteristics of IEEE/ANSI C37.46 Data sheet no. 6002 7-26 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Medium voltage fuses — 7 2.475 to 38 kV PT E-Rated fuses Dimensions — in (mm) Amps Length A Catalog no. (IR - kA) Diameter B Clip centers C Indicating Non-indicating — 2NCLPT-.25E (63) Recommended fuseclip 2.475 kV maximum system voltage 0.25 0.5 1 4.5 (114) 0.8 (20) 3.9 (99) — 2NCLPT-.5E (63) — 2NCLPT-1E (40) 2 — 2NCLPT-2E (40) 5 — 2NCLPT-5E (25) 7.6 (193) — 3.6CAV2 (50) 3.6ABWNA3.15 (50) 1A1837 3.6 kV maximum system voltage 2 8.7 (221) 1.6 (41) 3.15 5.6 (142) 4.4 (112) — 3.15 7.7 (195) 6.5 (165) — 3.6ABCNA3.15 (50) 6.3 5.6 (142) 4.4 (112) — 3.6ABWNA6.3 (50) 6.3 10 1 (25) 7.7 (195) 6.5 (165) 1A1837 A3354705 — 3.6ABCNA6.3 (50) — 3.6ABCNA10 (50) — 5.5AMWNA0.5E (50) 1A1837 5.5 kV maximum system voltage 0.5 5.6 (142) 0.8 (20) 4.8 (122) 1 (25) 4.4 (112) — 5.5ABWNA0.5E (50) A3354705 0.5 7.4 (188) 1.6 (41) 6.2 (157) 5.5CAVH0.5E (50) JCW-1/2E (40) 1A0835 0.5 9.5 (241) 1.6 (41) 8.1 (206) 5CLPT-.5 (50) 5NCLPT-.5E-A (50) 1A0835 1 (25) 4.4 (112) — 5.5ABWNA1E (50) A3354705 0.8 (20) 4.8 (122) — 5.5AMWNA1.0E (50) 1A1837 6.2 (157) 5.5CAVH1E (50) JCW-1E (40) 5CLPT-1 (50)† 5NCLPT-1E-A (50) 1 1 1 1 1.5 5.6 (142) 7.4 (188) 9.5 (241) 2 2 1 (25) 5.6 (142) 2 2 3 3 1.6 (41) 7.4 (188) 5.6 (142) 3 9.5 (241) 3 7.4 (188) 0.8 (20) 8.1 (206) † 5CLPT-1.5 (50) † 1A0835 — 4.4 (112) — 5.5ABWNA2E (50) 8.1 (206) — 5NCLPT-2E (50) 4.8 (122) — 5.5AMWNA2.0E (50) A3354705 1A1837 1.6 (41) 6.2 (157) 5.5CAVH2E (50) JCW-2E (40) 1A0835 1 (25) 4.4 (112) — 5.5ABWNA3E (50) A3354705 0.8 (20) 4.8 (122) — 5.5AMWNA3.0E (50) 1A1837 8.1 (206) 5CLPT-3E (50) 5NCLPT-3E (50) 6.2 (157) — JCW-3E (40) 1.6 (41) 1A0835 4 5.6 (142) 0.8 (20) 4.8 (122) — 5.5AMWNA4.0E (50) 1A1837 5 9.5 (241) 1.6 (41) 8.1 (206) 5CLPT-5E (50) 5NCLPT-5E-A (50) 1A0835 5 5 5.6 (142) 5 7.3 (185) 10 9.5 (241) 15 7.4 (188) 1 (25) 4.4 (112) — 5.5ABWNA5E (50) A3354705 0.8 (20) 4.8 (122) — 5.5AMWNA5.0E (50) 1A1837 5.9 (150) — JCW-5E (40) 1.6 (41) 8.1 (206) 5CLPT-10E (50) 5NCLPT-10E (50) 6.2 (157) — 5.5CAV15E (50) 1A0835 † Due to manufacturing variations, this fuse does not comply with ANSI C37.46 for "E" rating. Data sheet no. 6002 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 7-27 Medium voltage fuses 0.5 7 — Medium voltage fuses 2.475 to 38 kV PT E-Rated fuses Dimensions — in (mm) Amps Length A Catalog no. (IR - kA) Diameter B Clip centers C Indicating Non-indicating Recommended fuseclip 7.2 kV maximum system voltage 0.5 7.2AMWNA0.5E (50) 1 5.6 (142) 0.8 (20) 4.8 (122) 7.2AMWNA1.0E (50) 2 1A1837 7.2AMWNA2.0E (50) 2 8.7 (221) 1.6 (41) 7.5 (190) 0.8 (20) 3 5.6 (142) 3.15 5.6 (142) 3.15 7.7 (195) 1 (25.4) 7.2CAV2 (40) 1A0835 4.8 (122) 7.2AMWNA3.0E (50) 1A1837 4.4 (112) 7.2ABWNA3.15 (45) 6.5 (165) 4 5.6 (142) 0.8 (20) 4.8 (122) 4 8.7 (221) 1.6 (41) 7.5 (190) — 7.2ABCNA3.15 (45) A3354705 7.2AMWNA4.0E (50) 1A1837 7.2CAV4 (40) 1A0835 5 5.6 (142) 0.8 (20) 4.8 (122) 7.2AMWNA5E (50) 1A1837 6 8.7 (221) 1.6 (41) 7.5 (190) 7.2CAV6 (40) 1A0835 6.3 5.6 (142) 6.3 7.7 (195) 4.4 (112) 7.2ABWNA6.3 (45) 6.5 (165) 7.2ABCNA6.3 (45) 10 8.7 (221) 1.6 (41) 7.5 (190) 7.2CAV10 (40) 9.5 (241) 1.6 (41) 8.1 (206) 1 5 (127) 1.1 (28) 4 (102) 1 9.5 (241) 1.6 (41) 8.1 (206) 2 8 (203) 0.8 (20) 7.2 (183) 1 (25.4) A3354705 1A0835 8.3 kV maximum system voltage 0.5 2 9.5 (241) 3 12.9 (328) 4 8 (203) 1.6 (41) 0.8 (20) 8CLPT-.5 (50)† — 8.1 (206) 11.5 (292) 5 5 (127) 1.1 (28) 4 (102) 12.9 (328) 1.6 (41) 11.5 (292) 8 5 (127) 1.1 (28) 4 (102) 10 12.9 (328) 1.6 (41) 11.5 (292) 1A0835 A3354705 8NCLPT-1E-A (50) 1A0835 8NCLPT-2E (25) 1A1837 8NCLPT-2E-A (50) 8CLPT-3E (50) 7.2 (183) 5 8NCLPT-.5E-A (50) 8NCLPT-1E (50) — 8CLPT-5E (50) 8NCLPT-3E-B (50) 8NCLPT-4E (25) 1A0835 1A1837 8NCLPT-5E (50) A3354705 8NCLPT-5E-B (50) 1A0835 — 8NCLPT-8E A3354705 8CLPT-10E (50) 8NCLPT-10E-B (50) 1A0835 12 kV maximum system voltage 2 8.7 (221) 1.6 (41) 7.5 (190) 3.15 7.7 (195) 1 (25) 6.5 (165) — 12CAV2 (40) 1A0835 12ABCNA3.15 (45) A3354705 15.5 kV maximum system voltage 0.5 12.9 (328) 11.5 (292) 15.5CAVH0.5E (80) 15NCLPT-.5E-A (50) 1 12.9 (328) 11.5 (292) 15.5CAVH1E (80) 15NCLPT-1E-A (50) 15.5CAVH2E (80) 2 12.9 (328) 11.5 (292) 3 12.9 (328) 11.5 (292) — 15.5CAV3E (80) 3 17.6 (447) 16.1 (409) — 15NCLPT-3E (50) 3 17.6 (447) 5 12.9 (328) 11.5 (292) 5 17.6 (447) 16.1 (409) 7 12.9 (328) 11.5 (292) 10 17.6 (447) 16.1 (409) 1.6 (41) 16.1 (409) 15CLPT-3E (50) — 15CLPT-5E (50) — 15CLPT-10E (50) 15NCLPT-2E (50) — 1A0835 15.5CAV5E (80) 15NCLPT-5E (50) 15.5CAV7E (80) 15NCLPT-10E (50) 17.5 kV maximum system voltage 2 17.5CAV2 (40) 4 8.7 (221) 6 1.6 (41) 7.5 (190) 10 — 17.5CAV4 (40) 17.5CAV6 (40) 1A0835 17.5CAV10 (40) † Does not comply with ANSI C37.46 for "E" rating. Data sheet no. 6002 7-28 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Medium voltage fuses — 7 2.475 to 38 kV PT E-Rated fuses Dimensions — in (mm) Amps Length A Catalog no. (IR - kA) Diameter B Clip centers C Indicating Non-indicating — 24CAV2 (40) Recommended fuseclip 24 kV maximum system voltage 2 3 13.49 (340) 1.6 (41) 12.2 (310) 4 — 24CAV3 (40) — 24CAV4 (40) 1A0835 25.5 kV maximum system voltage 0.5 17.6 (447) 1 1.6 (41) 16.1 (410) 1.6 (41) 16.1 (410) 25CLPT-.5 (43.5)† — 25CLPT-1 (43.5) — † 1A0835 36 kV maximum system voltage 2 17.3 (439) 4 — 36CAV2 (40) — 36CAV4 (40) 1A0835 38 kV maximum system voltage 0.5 17.3 (439) 16.1 (409) 38CAVH0.5E (40) — 0.5 18.6 (472) 17.1 (434) 38CLPT-0.5 (43.5)† — 38CAVH1E (40) — 16.1 (409) 38CAVH2E (40) — — 38CAV4E (40) 1 1.6 (41) 2 17.3 (439) 4 1A0835 † Does not comply with ANSI C37.46 for “E” rating. CLPT Type mountings and hardware Catalog no. Amps Fuse mounting type* BIL (kV) Mounting (including live parts, end fittings)** Porcelain insulator Glass-polyester insulator Live parts (including end fittings)*** End fittings (disconnect only) 5CLPT-PNM-A 5CLPT-GNM-A CLPT-NL — 5CLPT-PDM-A 5CLPT-GDM-A CLPT-DL CLPT-DF 5.5 kV maximum (4.8 kV nominal)† 0.5–10 Non-disconnect Disconnect †† 60 8.3 kV maximum (7.2 kV nominal)† 0.5–2 3–10 Non-disconnect 8CLPT-PNM-A 8CLPT-GNM-A CLPT-NL — Disconnect†† 8CLPT-PDM-A 8CLPT-GDM-A CLPT-DL CLPT-DF 8CLPT-PNM-B 8CLPT-GNM-B CLPT-NL — 8CLPT-PDM-B 8CLPT-GDM-B CLPT-DL CLPT-DF Non-disconnect 15CLPT-PNM-A 15CLPT-GNM-A CLPT-NL — Disconnect†† 15CLPT-PDM-A 15CLPT-GDM-A CLPT-DL CLPT-DF 15CLPT-PNM-B 15CLPT-GNM-B CLPT-NL CLPT-DF 15CLPT-PDM-B 15CLPT-GDM-B CLPT-DL — 25CLPT-NL — 25CLPT-DL CLPT-DF CLPT-NL CLPT-DF CLPT-DL — Non-disconnect 75 Disconnect†† 0.5–2 3–10 Non-disconnect 95 Disconnect†† Medium voltage fuses 15.5 kV maximum (14.4 kV nominal) 25.5 kV Maximum (23 kV Nominal) 0.5–1 Non-disconnect Disconnect †† 150 25CLPT-PNM-A 25CLPT-PDM-A — 38 kV Maximum (34.5 kV Nominal) 0.5 Disconnect†† Non-disconnect N/A Not applicable 38CLPT-PNM-A Not applicable * See page 7-35 for dimensions and diagrams of typical mountings. ** End fittings supplied only when required. † Refers to 5CLPT, 5NCLPT, 8CLPT and 8NCLPT-A or -B fuses only. †† Disconnect mountings provide a means for fuse extraction only. Do not use a disconnect mounting for load switching or fuse removal while energized. Data sheet no. 6002 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 7-29 7 — Medium voltage fuses HVA, HVB, HVJ, HVL, HVR, HVT, HVU, HVW and HVX fast-acting PT fuses Medium voltage, non-time delay, fast-acting fuses. Ratings* • Volts 1-10 kV • Amps 1/16-10 A * See catalog number table for possible volt/amp combinations. Features • Physical size varies with electrical rating of fuse to prevent overfusing • Space-saving size Typical applications • Medium voltage instrument and circuit protection Test specifications Catalog symbol Percent load HVA, HVB, HVJ, HVL HVR, HVT, HVU, HVW, HVX Opening time 110 4 hours (min) 135 1 hour (max) 100 4 hours (min) 150 1 hour (max) Recommended fuseclips and blocks Fuse catalog symbol Block catalog no. HVA, HVR 4528* HVB, HVT 4529* HVJ, HVU Fuseclip catalog no. — HVL, HVX 5960 4180 * Use #8 screws. Dimensions — in (mm) Catalog symbol kV Amps Max. IR (amps) HVA 1 1/16, 1/10, 1/8, 2/10, 1/4, 3/8, 1/2, 3/4, 1, 1-1/2, 2, 3, 4, 6, 10 20 DC / 30 AC HVB 2.5 1/2, 3/4, 1, 1-1/2, 2, 3 8 DC / 12 AC HVJ 5 1/16, 1/8, 1/4, 1/2, 3/4, 1, 1-1/2, 2, 4, 6* 4 DC / 6 AC HVL 10 1/16, 1/8, 1/4, 1/2, 1, 1-1/2, 2, 3* 2 DC / 3 AC HVR 1 1/2, 1, 2, 3, 4, 5 500 AC HVW 1.2 1, 2, 3, 4, 5, 8 4 DC / 167 AC HVT 2.5 1/2, 1, 2, 3, 5 500 AC HVU 5 1/2, 1, 2, 3, 4, 5 500 AC HVX 10 1/2, 1, 3, 5 1200 AC Diameter 0.4 (10) 0.8 (21) 0.4 (10) _____ ___ - 0.8 (20) E.g., HVB-3/4 (2.5 kV 3/4 amp fuse) Data sheet no. 6003 7-30 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 5 (126.9) 10 (254) 2.3 (57) 4.5 (114) Catalog number build-a-code Amps 3 (76) 4.5 (114) 3 (76) * AC only. Fuse catalog symbol Length Eaton.com/bussmannseries 5 (127) 10 (254) Medium voltage fuses — 7 British standard dimensioned IEC fuses for motor circuit protection The Bussmann series IEC motor fuses are designed to meet the specific requirements necessary for motor protection. During the starting cycle of direct on-line motors, the fuse elements will reach a considerably higher temperature than during normal operation; (this is due to the high amount of current the motor will draw as it starts, typically, six times its normal load current value). This results in expansion and contraction of the fuse elements and could cause premature operation of the fuse. Bussmann series motor fuses encompass an advanced design to minimize this effect. This, therefore, negates the need to over specify the fuse rating due to high values of motor starting current. These motor fuses operate extremely quickly under heavy fault currents, resulting from the time / current characteristic. Low power dissipation ensures low temperature rise, important in multitier starters for example. Switching (arc), voltages are lower than permitted values, therefore, 5.5 kV fuses are also suitable for 4.8 kV and 2.4 kV circuits. Catalog symbol 3.6WJON6 3.6WDOH6 3.6WFOH6 3.6WDLSJ 3.6WFLSJ 3.6WDFHO 3.6WFFHO 3.6WKFHO 5.5VFNHA 5.5VKNHA 7.2WFNHO 7.2WKNHO 7.2WFMSJ 7.2WKMSJ kV 3.6 5.5 7.2 IR (kA) Amps/rating 5, 6.3, 10, 16, 20, 25, 31.5, 40, 50 50, 63, 80, 100, 125 160, 200 50, 63, 80, 100, 125 50 160, 200 50, 63, 80, 100, 125 160, 200 250, 315, 355, 400 2R, 3R, 4R, 6R 60 9R, 12R, 18R, 24R 25, 31.5, 40, 50, 63, 80, 100, 125, 160 40 200, 224, 250, 315 25, 31.5, 40, 50, 63, 80, 125, 160 63 200, 224, 250, 315, 355 Dimensions — in (mm) Length Diameter 1.4 (36) 7.6 (192) 2 (51) 3 (76) 2 (51) 11.5 (292) 3 (76) 2 (51) 10 (254) Dimension standard BS 2692 (TA1) Interchangeable with GEC Type K2 PA BS 2692 (TA1) or DIN 43625 DIN 43625 BS 2692 (TA2) ANSI R-Rated 15.9 (403) 3 (76) BS 2692 (TA4) 17.4 (442) DIN 43625 Catalog number build-a-code Fuse catalog symbol Amps _____ ___ - BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Medium voltage fuses E.g., 3.6WKFHO-315 (315 amp 3.6 kV fuse) Eaton.com/bussmannseries 7-31 7 — Medium voltage fuses DIN dimensioned IEC fuses for transformer protection DIN dimension fuses to Specification DIN 43625 covering currentlimiting fuses with performance in compliance with IEC 60282-1. These are in accordance with the R10 and, in some cases, the R20 series of preferred numbers. Typical applications • Ratings* Medium voltage IEC designed equipment Recommended fuseclips • Volts 3.6-36 kV • Amps 6.3-100 A • Interrupting ratings 20-50 kA • * See catalog number table for possible volt/amp combinations. Catalog numbers 270303, A3354745, see page 7-36. Dimensions — in (mm) Striker -in operated position • Compliant with DIN dimensional standard DIN 43625, VDE 0670 part 4, VDE 0670 part 40Z and with IEC 60282-1 (2005) Diameter Agency information 0.59 (15) 1.77 (45) Features Length • DIN dimensioned for retrofitting in existing hardware • Open fuse indicator for ease in troubleshooting • Designed for use in IEC equipment kV 3.6 7.2 12 17.5 24 36 * 1 2 3 Catalog symbol 3.6ADOSJ 3.6WDOSJ 3.6WFOSJ 3.6ADLSJ 3.6WKLSJ 7.2TDLSJ 7.2TFLSJ 12TDLEJ 12THLEJ 12TKLEJ 12TXLEJ* 17.5TDLSJ* 17.5TFLSJ* 17.5TDMEJ 17.5THMEJ 17.5TKMEJ 24TDMEJ 24THMEJ 24TFMEJ 24TXMEJ* 36TDQSJ 36TFQSJ 36TXQEJ* Amps 6.3, 10, 16, 20, 25, 31.5, 40 50, 63, 80, 100, 125 160, 200 25, 40 250, 315, 400 6.3, 10, 16, 20, 25, 31.5, 40, 80, 100, 125, 160 6.3, 10, 16, 20, 25, 31.5, 40, 80, 100 125 160, 200 6.3, 10, 16, 20, 25, 31.5, 40 50 6.3, 10, 16, 20, 25, 31.5, 40, 80, 100 125 6.3, 10, 16, 20, 25, 31.5, 40, 63 80, 100*1 1252, 160 3.153, 6.3, 10, 16, 20, 25 31.5, 40, 50 63 For diameter and length values, see catalog number table. Dimensions — in (mm) Diameter Length 2.0 (51) 50, 63 50, 63 50, 63 50 3.0 (76) 2.0 (51) 3.0 (76) 2.0 (51) 3.0 (76) 2.0 (51) 2.5 (64) 3.0 (76) 3.5 (88) 2.0 (51) 3.0 (76) 2.0 (51) 2.5 (64) 3.0 (76) 2.0 (51) 2.5 (64) 3.0 (76) 3.5 (88) 2.0 (51) 3.0 (76) 3.5 (88) IR RMS Sym. (kA) 40 7.6 (192) 50 11.5 (292) 40 63 11.5 (292) 35.5 50 17.4 (442) 50 31.5 21.2 (537) 35.5 20 Not compliant with VDE 0670, part 402. IR RMS Sym. is 63 kA IR RMS Sym. is 40 kA IR RMS Sym. is 20 kA Catalog number build-a-code Fuse catalog symbol Amps _____ ___ - E.g., 17.5THMEJ-80 (17.5 kV 80 amp fuse) 7-32 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 1.34 (34) 1.02 (26) Medium voltage fuses — 7 Expulsion fuse links for use in high voltage distribution cut-outs Typical applications • Primary side transformer protection Expulsion fuse links available in a wide range of options from 15 to 72 kV in ANSI Type T and K characteristics. Expulsion fuse link current ratings should be selected on the basis of maximum expected transient no-damage currents rather than on full load current. In addition, the selection of higher current ratings will reduce the possibility of supply interruption due to transient surges such as those due to lightning strikes. • Feeder protection • Capacitor bank protection Fuse label color coding Type Color Type Color XA Pink T Green K Yellow S — Dimensions — mm (in) A 125 (4.92) Links should be handled with a reasonable degree of care when installing. Excessively rough handling may damage the element. Universal It is normal, under certain fault conditions, for arc extinguishing material and/or metal particles to be expelled from the fuse assembly. It is therefore recommended that reasonable precautions be taken to prevent the installation being approached by unauthorized persons. When ordering, select from the table below the characteristics in each column you need your fuse link to have. Double tail Ø10 (0.39) Button head Ø7.5 (0.29) Ø19 (0.75) Removeable button head Up to 50 A A A 125 (4.92) Example: 15TB30 is a 15 kV, ANSI C 37-42 compliant fuse with a fixed button head terminal that is rated for 30 amps. Double tail 11 (0.43) The fuse link assembly for a given range is standard to all rated voltages. The exception is the tail length that’s varied to suit the expulsion carrier dimensions of different ratings. Universal Adjustable button for 65 to 100 a assembly only Ø19 (0.75) Button head Ratings* 10.5 (0.41) Ø19 (0.75) • Volts 15-72 kV • Amps 1-100 A • Interrupting rating 8 kA approximate Removeable button head 60-100 A Agency information • Type T, complies with ANSI C37-42 • Type K, complies with ANSI C37-42 Link kV A Link kV A 15 533 (21) 46 787 (31) 25 660 (26) 72 1016 (40 Notes: Type BR is similar to button head shown, except that the button head is attached via a 1/4" UNF thread. Tails can be cut to desired length. Medium voltage fuses * See catalog number configuring table for possible volt/amp combinations. A Features • Wide range of options available from 15 kV to 72 kV in ANSI T and K characteristics. • Extra rapid option also available. Catalog number configuration table Available voltage ratings (kV) 15, 25, 46, 72 1st letter = current characteristics type 2nd letter = termination type T = complies with ANSI C 37-42 requirements for slow acting T characteristics B = a fixed NEMA button head link K = complies with ANSI C 37-42 requirements for fast acting K characteristics U = a universal link, with double tail and slip off NEMA button head XA = this type of expulsion fuse link has an extra rapid characteristic. It is suitable for applications where a high degree of system protection is required at the expense of discrimination. D = double tailed link without NEMA button head S = Solid links rated at 100 amps are also available in both button head and universal versions for fitting into expulsion fuse carriers where required. These can be ordered in a similar way using the abbreviation S, e.g. 15SB, etc. BR = as pattern B but the button head is attached via a 1/4" UNF thread to allow use of an extension rod BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Available amps ratings 1, 2, 3, 4, 5, 6, 7.5, 8, 10, 12, 15, 20, 25, 30, 40, 50, 60, 65, 75, 80, 100 7-33 7 — Medium voltage fuses FL — Type H, and EEI-NEMA Type K and T fuses Medium voltage fuses: Type H (high surge), EEI-NEMA Type K (fastacting), EEI-NEMA Type T (time-delay). Type H (high-surge), K and T universal tin element cutout fuses rated to 27 kV Catalog no. EEI-NEMA High-surge, Type H fuses are manufactured in ratings of 1, 2, 3, 5, and 8 amps and were developed for primary fusing of small-sized transformers. Type H links are manufactured in the universal button head design. Type H high surge Type K fast-acting Type T time-delay Amps Non-removable button-head for standard open or enclosed cutouts Type N fuses conform to previous NEMA standards and are superseded by Type K and T links. Type N fuses are manufactured in the universal button design in ratings of 5 through 200 amps for use in standard NEMA dimensioned cutouts rated through 27 kV. FL11H1 FL11K1 FL11T1 1 FL11H2 FL11K2 FL11T2 2 FL11H3 FL11K3 FL11T3 3 FL11K5 FL11T5 5 FL11K6 FL11T6 6 FL11H5 — FL11H8 Ratings* FL11K8 FL11T8 8 — FL11K10 FL11T10 10 — FL11K12 FL11T12 12 — FL11K15 FL11T15 15 — FL11K20 FL11T20 20 — FL11K25 FL11T25 25 • Volts rated to 27 kV — FL11K30 FL11T30 30 • Amps 1-200 A — FL11K40 FL11T40 40 * See catalog number table for type and amp combinations. — FL11K50 FL11T50 50 Features — FL11K65 FL11T65 65 — FL11K80 FL11T80 80 — FL11K100 FL11T100 100 — FL11K140 FL11T140 140 — FL11K200 FL11T200 200 • Wide range of EEI-NEMA type fuse links for use in open fuse cutouts • Voltage rating up to 27 kV for flexible application • Can be coordinated with other overcurrent protective devices for sectionalizing to isolate feeder branches Typical applications • Medium voltage fused cutouts Type K universal silver-element cutout fuses rated to 27 kV Catalog no. Fast-acting EEI-NEMA Type K Amps Non-removable button-head for standard open or enclosed cutouts FL12K8 8 FL12K10 10 FL12K12 12 FL12K15 15 FL12K25 25 FL12K50 50 7-34 Removable button-head for cutouts requiring removable-button links* — FL3K1 FL3T1 1 — FL3K2 FL3T2 2 — FL3K3 FL3T3 3 — FL3K5 FL3T5 5 — FL3K6 FL3T6 6 — FL3K8 FL3T8 8 — FL3K10 FL3T10 10 — FL3K12 FL3T12 12 — FL3K15 FL3T15 15 — FL3K20 FL3T20 20 — FL3K25 FL3T25 25 — FL3K30 FL3T30 30 — FL3K40 FL3T40 40 — FL3K50 FL3T50 50 — FL3K65 FL3T65 65 — FL3K80 FL3T80 80 — FL3K100 FL3T100 100 — FL3K140 FL3T140 140 — FL3K200 FL3T200 200 * Adapter-type removable-button links with ferrule adapter to convert to doubleleader links are available in K and T types. Order by description. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Medium voltage fuses — 7 PT fuse mountings — in (mm) Catalog no. Hole ctrs. A 5.5 kV Disconnect† 5CLPT-GDM-A 9.37 (238) 5CLPT-PDM-A 5.5 kV Non-disconnect 5CLPT-GNM-A 9.37 (238) 5CLPT-PNM-A 8.3 kV Disconnect† 8CLPT-GDM-A 8CLPT-GDM-B 9.37 (238) 8CLPT-PDM-A 8CLPT-PDM-B 12.74 (323.6) 8.3 kV Non-disconnect 8CLPT-GNM-A 9.37 (238) 8CLPT-PNM-A 8CLPT-GNM-B 12.75 (323.8) 8CLPT-PNM-B 15.5 kV Disconnect† 15CLPT-GDM-A 12.74 (323.6) 15CLPT-PDM-A 15CLPT-GDM-B 17.46 (443.5) 15CLPT-PDM-B 15.5 kV Non-disconnect 15CLPT-GNM-A 12.74 (323.6) 15CLPT-PNM-A 15CLPT-GNM-B 17.46 (443.5) 15CLPT-PNM-B 25.5 kV Disconnect† 25CLPT-PDM-A 19.12 (485.6) 25.5 kV Non-disconnect 25CLPT-PNM-A 26.63 (676.4) Hole ctrs. B Overall length C Hole Inset D Hole ctrs. E Contact hgt. F Overall hgt. G BIL (kV) 6 (152.4) 18.63 (473.2) 0.75 (19) 1.75 (44.4) 4.5 (114.3) 9.56 (242.8) 60 6 (152.4) 18.63 (473.2) 0.75 (19) 1.75 (44.4) 4.5 (114.3) 6.94 (176.2) 60 0.75 (19) 1.75 (44.4) 7 (177.8) 12.06 (306.3) 75 0.75 (19) 1.75 (44.4) 7 (177.8) 9.44 (239.8) 75 0.75 (19) 1.75 (44.4) 7 (177.8) 12.06 (306.3) 95 0.75 (19) 1.75 (44.4) 7 (177.8) 9.44 (239.8) 95 6 (152.4) 18.63 (473.2) 22 (558.8) 18.63 (473.2) 6 (152.4) 22 (558.8) 22 (558.8) 6 (152.4) 26.63 (676.4) 22 (558.8) 6 (152.4) 26.63 (676.4) 7 (177.8) 26.63 (676.4) 0.75 (19) 1.75 (44.4) 12 (304.8) 17.06 (433.3) 150 7 (177.8) 26.63 (676.4) 0.75 (19) 1.75 (44.4) 12 (304.8) 14.75 (374.6) 150 † Disconnect mountings provide a means for fuse extraction only. Do not use a disconnect mounting for load switching or fuse removal while energized. Disconnect mountings†† Non-disconnect mountings G G F D F D C A E Medium voltage fuses E E A C E D B D BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 B Eaton.com/bussmannseries 7-35 7 — Medium voltage fuses Recommended fuseclips Description DIN clip and stirrup Enclosed fuseclip Enclosed fuseclip Enclosed fuseclip Open fuseclip Spring loaded open fuseclip Clip Dimensions — in (mm) Fuse dia. — in (mm) Fig. A B ØC D E 1 — — — — — 1.8 (45) 2 3.5 (89) 2.5 (63) 1.8 (45) 4.4 (112) 2 (51) 2 3.75 (95) 1.98 (50) 2.01 (51) 1.19 (30) 4.54 (115) 2 4.14 (105) 2.45 (62) 3.01 (76) 5.64 (143) 3 3 (76) See dimensions drawing 4 F — G — 1.5 (38) Catalog no. 270303 A3354745* 0.4 (10) A3354710* A3354730* 1A0065 9078A67G04 * For single barrel applications only. Not sold in pairs. Figure 1 Figure 2 ØC A D B 26.5 6.5 G F E Figure 3 Figure 4 7-36 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 Save up to 65% panel space with Bussmann series power distribution fuse blocks Fuse size/ Section class Description page Quick guide 2-3 Control panel applications 1/4" dia. Panel mount blocks 8000, 3828, 4520, 4393 4-5 Class CC and midget Modular blocks BCM, BMM 6-7 DIN-Rail holders CHCC, CHM, NDNF1, OPM 8-13 Panel mount blocks 3743, 4421, 4515 14 Class G Panel mount blocks BG, G 15 14mm dia. DIN-Rail holder CH14 16 22mm dia. DIN-Rail holder CH22 17 Modular block JM70100 18 Modular power distribution blocks JM70100_ MW_ Class H(K)/R Modular blocks HM, RM 19-23 Modular power distribution blocks HM___MW_, 24-27 RM___MW_ Class J DIN-Rail holders CH30J, CH60J 28 Safety J™ JT(N)600 29 Panel mount pyramid block JP 30 Modular blocks JM60_ 31-32 Modular power distribution blocks JM60___MW_ 33-34 Class T 300 V panel mount blocks T300 35-36 600 V panel mount blocks T600 37-38 High speed fuses Open center panel mount blocks BH, C5268, 39 1BS NH fuses DIN-Rail/panel mount blocks SD00, SD1, SD2, 40 SD3, SD4, TD00, TD1, TD2, TD3 Through-panel applications 41 5mm dia. HTB HJL, HK, HKP, HLD 42-43 1/4" dia. 43-45 13/32" dia. HPC, HPC-D, HPD, HPF, HPG, HPM, HPS, HPS2 In-line applications 46 5mm dia. HHT HFA, HFB, HEB-10, HHB, HR/HM, HRK 46-48 1/4" dia. Single-pole HEC, HEG, HEH, HEJ non-breakaway 49 Class G 51-52 13/32" dia. HEB single-pole breakaway and non-breakaway HEZ waterproof single-pole breakaway and 52 Class CC non-breakaway HEX, Class CC HEY dual-pole breakaway and 53-54 13/32" dia. non-breakaway BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-1 Fuse blocks and holders Contents 8 — Fuse blocks and holders Quick guide These tables list various fuse classes, sizes and voltages along with their available blocks and holders. Catalog pages are denoted parenthetically "()" next to their catalog symbol. E.g.: BCM603 (8-6) is in Section 8, page 6. Fuse class/ size Catalog symbol* Amp range Fuse blocks** Class CC FNQ-R KTK-R LP-CC Up to 30 BCM603 (8-6) 1/2-15 BG301 (8-15) 20 BG302 (8-15) 25-30 Class G Class J SC DFJ JKS LPJ 250 V Class H/K5 NON 600 V Class H/K5 NOS Class L KLU KRP-C KRP-CL KTU 250 V Class RK1/RK5 FRN-R KTN-R KWN-R LPN-RK 600 V Class RK1/RK5 FRS-R KTS-R KWS-R LPS-RK 300 V Class T JJN 600 V Class T JJS DIN—Rail holders** In-line holders** Panel mount holders** Open center blocks** CHCC (8-8) OPM-NG (8-13) OPM-1038 (8-12) HEY (8-53) HEZ (8-52) HPF-RR (8-43) HPS-RR (8-45) — HEG (8-49) HPG-EE (8-44) HPS-EE (8-45) HEH (8-49) HPS-JJ (8-45) BG303 (8-15) HEC (8-49) HPS-FF (8-45) 35-60 G30060 (8-15) HEJ (8-49) — Up to 60 JM60030 (8-31) JM60030-_MW_, *** (8-33) JP60030-3 (8-30) 70-400 JM60100 (8-31) JM60100-_MW_*** (8-33) 110-200 JM60200 (8-31 JM60200-_MW_*** (8-33) 250-400 JM60400 (8-31) JM60400-_MW_*** (8-33) BH-3145 (8-39) 450-600 JM60600 (8-31) BH-3144 (8-39) Up to 60 HM250__ (8-19) HM250__-_MW_*** (8-24) 70-600 HM25___ (8-19) Up to 60 HM600__ (8-19) HM600__0-_-MW_*** (8-24) 70-600 HM60___ (8-19) 601-1200 — CH_J (8-28) JT(N)600_ (8-29) — 1BS101 (8-39) BH-0111 (8-39) — — — CH14 (8-16) — -— — — — — — — 51215 (1-pole)† 51235 (3-pole)† — — — — Up to 60 RM250__ (8-21) RM250__0-_MW_*** (8-26) — — — — 70-600 RM25___ (8-21) Up to 60 RM600__ (8-21) RM600__-_MW_*** (8-26) — — — — 70-600 RM60___0 (8-21) — — Up to 600 T30___ (8-35) 250-400 T30400 (8-35) — BH-1133 (8-39) — 450-600 T30600 (8-35) BH-3144 (8-39) Up to 60 T600__ (8-37) — 70-100 T60100 (8-37) 110-200 T60200 (8-37) 250-400 T60400 (8-37) BH-1133 (8-39) 450-600 T60600 (8-37) BH-3144 (8-39) — — BH-0111 (8-39) — — BH-1132 (8-39) Supplemental 13/32" x 1-1/2" BAF FNM FNQ KLM KTK Up to 30 BMM603 (8-6) 3743 (8-14) 4421 (8-14) 4515 (8-14) CHM (8-8) NDNF1-WH (8-11) OPM-1038 (8-12) OPM-NG (8-13) HEB (8-51) HEX (8-53) HPC-D (8-43) HPD (8-44) HPF (8-43) HPG (8-44) HPM (8-44) HPM-D (8-44) HPS2 (8-45) HPS (8-45) Supplemental 13/32" x 1-3/8" BBS Up to 30 BMM603 (8-6) 3743 (8-14) 4421 (8-14) 4515 (8-14) — HEH (8-49) HPS-L (8-45) 8-2 — BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries — Fuse blocks and holders — 8 Fuse class/ size Catalog symbol* Amp range Fuse blocks** DIN—Rail holders** In-line holders** Panel mount holders** Open center blocks** 1/4 x 7/8 AGW Up to 30 — — HHB (8-47) HM (8-48) HR (8-48) HRK (8-48) HJL (8-42) — 1/4 x 1 AGX Up to 30 3828 (8-5) 4520 (8-5) 4393 (8-5) — HHB (8-47) HM (8-48) HR (8-48) HRK (8-48) HJL (8-42) — 1/4 x 1-1/4 ABC AGC GBB MDA MDL MDQ Up to 30 S-8000 family (8-4) — HFA (8-46) HFB (8-47) HHB (8-47) HM (8-48) HR (8-48) HRK (8-48) HKP (8-42) HTB (8-41) HK (8-42) HLD (8-43) — 5x15mm C515 C517 C518 C519 C520 Up to 7 — — HHT (8-46) — — 5x20mm GDA GDB GDC GMA GMC GMD S500 S501 S505 S505H S506 Up to 15 — — HHT (8-46) HTB (8-41) — Fuse blocks and holders * Refer to data sheets for applicable fuse voltage and interrupting ratings and agency information. ** Fuse blocks and fused switches are available in a variety of pole and terminal configurations, and voltage and withstand ratings (SCCRs).Refer to data sheets for complete catalog numbers. *** This is a UL Listed power distribution fuse block, combining a fuse block and power distribution block into one unit. † Not shown in this catalog. Contact customer service for details. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-3 8 — Fuse blocks and holders S-8000 bolt-in and snap-in mount open blocks for 1/4" x 1-1/4" fuses 2011/65/EU Ratings Volts 300 V Amps 30 A max* * See catalog number tables for agency limitations. Agency information • UL Recognized, Guide IZLT2, File E14853, CSA Certified Class 6225-01, File 47235, RoHS compliant, CE Single pole anti-rotation pin • Single-pole blocks may be ordered without the anti-rotational pin. Add an “X” to the number of poles, e.g., BK/S-8000-1X. Catalog no.† Bolt-in mount S-8001-(poles)-R S-8002-(poles)-R S-8101-(poles)-R S-8102-(poles)-R S-8201-(poles)-R S-8202-(poles)-R S-8203-1-R Poles Terminal S-8301-(poles)-R Terminal angle UL 30 CSA 21 1 0° 40° 0° 3/16" quick-connect 40° 0° 1/4" quick-connect 40° Side 1/4" quick-connect 1-12 Screw — UL 30 A CSA 25A 0° 40° 0° 40° 0° Side UL 25 CSA 21 Solder 1-12 Snap-in mount S-8001-1-SNP-R S-8002-1-SNP-R S-8101-1-SNP-R S-8102-1-SNP-R S-8201-1-SNP-R S-8203-1-SNP-R Max amps Solder 3/16" quick-connect 1 1/4" quick-connect UL 20 CSA 13 UL 30 CSA 16 UL 20 CSA 13 UL 20 CSA 16 † Quantities for regular and bulk (BK/ prefix) catalog numbers varies with the number of poles. Contact customer satisfaction team for details. Mounting dimensions — in* No. of Poles A B 1 — — 2 1-1/8 5/8 3 1-3/4 1-1/4 4 2-3/8 1-7/8 5 3 2-1/2 6 3-5/8 3-1/8 7 4-1/4 3-3/4 8 4-7/8 4-3/8 9 5-1/2 5 10 6-1/8 5-5/8 11 6-3/4 6-1/4 12 7-3/8 6-7/8 A B * Block length varies by specific termination and mounting. See data sheet 2101 for details. Data sheet no. 2101 8-4 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 3828 open blocks with solder terminals for 1/4" x 1" fuses 4520 and 4393 open blocks with solder terminals for 1/4" x 1" fuses Ratings 3828 Ratings • Volts 250 V • Amps 30 A • Volts 250 V • Amps 30 A 2011/65/EU 2011/65/EU Catalog no. Poles Base width — in (mm) 3828-1 1 1/2 (12.7) 3828-2 2 1-1/8 (28.6) 3828-3 3 1-3/4 (44.5) 3828-4 4 2-3/8 (60.3) 3828-5 5 3 (76.2) 3828-6 6 3 5/8 (92.1) 3828-7 7 4-1/4 (108.0) 3828-8 8 4-7/8 (123.8) 3828-10 10 6-1/8 (155.6) 3828-12 12 7-3/8 (187.3) Catalog no. Description 4520 Integral clip and straight solder terminals 4393 Spare fuse block - no terminals Dimensions — in* 1.94 0.598 0.188 1.38 4520 integral clip and straight solder terminals 1.38 Dimensions — in** 0.598 1.88 0.63 0.188 4393 spare fuse block, no terminals 0.19 1.38 * Mounting screw hole diameter is 0.147". Counterbore 0.636" diameter. Max #6 mounting screw. Fuse blocks and holders ** Mounting screw hole diameter is 0.147." Max #6 mounting screw. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-5 8 — Fuse blocks and holders BCM (Class CC) and BMM (supplemental 13/32 x 1-1/2” /10x38mm) modular style fuse blocks with optional covers. 2011/65/EU The BCM and BMM modular fuse blocks contain features that add versatility, reduce labor and enhance safety of any panel design. Optional IP20 finger-safe covers enhance safety with a lockout/tagout feature along with optional open fuse indication to speed troubleshooting. Volts 600 Vac/dc • Amps 30 A • SCCR up to 200 kA* • • UL Listed E14853 - IZLT • CSA Certified 47235-6225-01 • RoHS Compliant 13/32” x 1-1/2” BMM blocks • UL Recognized, E14853 - IZLT2 • CSA Certified 47235-6225-01 • CE • RoHS compliant UL 13/32" x 1-1/2": KTK, FNQ, KLM, FNM, BAF • IEC 10x38mm: C10G, C10M, FWA, FWC • Catalog no. BRKT-ND • Catalog no. BRKT-NDSCRW2 • Available in 1-, 2- and 3-pole configurations to meet stocking requirements • Blocks are fully modular with a snap-together design that provides toolless assembly of multiple pole blocks at point-of-use to reduce inventory and save assembly time and labor • DIN-Rail and panel mount versatility allows one product to be used for multiple applications, lowering inventory cost • Compact footprint consumes minimal panel space • Optional see-through cover enhances safety with IP20 finger-safe protection, lockout/tagout capability and open circuit indication • Easy circuit identification with available universal marker labels for fuse block covers • Tin-plated bimetallic copper fuse clips deliver superior fatigue resistance compared to traditional spring brass • Terminal options to meet application needs including 1/4” spade quick-connect terminals for faster panel assembly Terminals for 75/90°C Cu and AL wire BCM603-3PQ with pressure plate and 1/4" quick-connect terminals Covers* • • BMM603-3C with CVRI-CCM covers Class CC BCM blocks • Class CC: LP-CC, FNQ-R, KTK-R Features * Limited by fuse interrupting rating Agency information • Recommended DIN-Rail end stops Ratings • Recommended Bussmann series fuses Covers are included in the overall UL Listing/Recognition and CSA Certification * Covers sold separately in multiples of three units. Order one unit per pole. Poles • 1-, 2-, 3-pole units factory assembled • Single-pole units snap together to create desired number of poles Flammability ratings Terminal type AWG range Box lug (C) Cu 2-14 Al 2-8 Screw (S) Screw/quick-connect* (SQ) Pressure plate (P) Pressure plate/quick-connect* (PQ) Cu 10-18 AWG Cu 2-3 Cu 4-6 Cu 8-14 Al 2-6 Al 8 Torque lb-in (N•m) 50 (5.6) 45 (5.1) 35 (4.0) 50 (5.6) 40 (4.5) 10-18 20 (2.3) • Blocks UL 94V0, self-extinguishing * ¼“ quick-connect terminal maximum amps dependent on female spade connector and wire ratings. • Covers UL 94HB, self-extinguishing Recommended covers† Operating and storage temperature range • Blocks -40°C to +120°C • Non indicating covers -40°C to +120°C • Indicating covers -20°C to +90°C** ** Indication requires minimum 90 V and closed circuit to illuminate. Cover catalog numbers • For blocks with quick-connect terminals — CVR(I)-CCM-QC • All other terminal options — CVR(I)-CCM Terminal type Box lug (C) Cover catalog no. Indicating Non indicating CVRI-CCM CVR-CCM Screw (S) Screw/quick-connect (SQ) Pressure plate (P) Pressure plate/quick-connect (PQ) CVRI-CCM CVRI-CCM-QC CVRI-CCM CVRI-CCM-QC CVR-CCM CVR-CCM-QC CVR-CCM CVR-CCM-QC † For use with 4 AWG max conductors. Data sheet no. 10241 8-6 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 Catalog no. Terminal type 10-32 Phil-slot screw BCM603-1S BCM603-2S BCM603-3S — — — Screw with quick-connect* BCM603-1SQ BCM603-2SQ BCM603-3SQ BMM603-1SQ BMM603-2SQ BMM603-3SQ Pressure plate BCM603-1P BCM603-2P BCM603-3P — — — Pressure plate with quick-connect* BCM603-1PQ BCM603-2PQ BCM603-3PQ BMM603-1PQ BMM603-2PQ BMM603-3PQ Box lug BCM603-1C BCM603-2C BCM603-3C BMM603-1C BMM603-2C BMM603-3C Poles 1 2 3 1 2 3 — BCCMM603-3SQ — BCCMM603-3PQ — 3 Fuse/class CC CC CC 10x38 (13/32”x1-1/2”) 10x38 (13/32”x1-1/2”) 10x38 (13/32”x1-1/2”) 3-Pole control circuit transformer block 2-pole CC with 1-pole 10x38mm (13/32” x 1-1/2”) * 1/4“ quick-connect terminal maximum amps dependent on female spade connector and wire ratings. Dimensions — mm (in) 33 1.3 95 3.7 40 1.6 21 .8 77 10 3.0 .4 4 .2 20 .8 16 .6 20 .8 39 1.6 59 2.3 33 1.3 Fuse blocks and holders 41 1.6 60 2.4 Data sheet no. 10241 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-7 8 — Fuse blocks and holders CH modular, IP20 finger-safe DIN-Rail holders for Class CC, midget and PV fuses Bussmann series CH DIN-Rail fuse holders are for UL Class CC and midget fuses, and IEC 10x38mm fuses. They are available with and without indication in 1-, 2- and 3-pole IP20 finger-safe versions. A variety of accessories extends their application flexibility and they may be ganged together to meet specific application requirements. 2011/65/EU Ratings • • Volts • 600 V (or less) UL • UL 94V0, self-extinguishing Storage and operating temperature • -4°F (-20°C) to +194°F (90°C) indicating • -4°F (-20°C) to +248°F (120°C) non-indicating Features • High SCCR rated, UL Listed Class CC holder with optional open fuse indication for 600 V and 48 Vdc (see catalog number table for details) • Enhanced safety with IP20 finger-safe construction • UL Recognized midget and IEC 10x38mm holders with factory assembled neutral pole option • 690 V (or less) IEC • Agency ratings up to 1000 Vdc for use with PV fuses. • 1000 Vdc (or less) photovoltaic (PV) • Available remote PLC fuse indication module • Wiring flexibility with terminals rated for use with 75°C or 90°C solid, stranded and fine stranded wire, and fork terminals and comb busbars. (Use any higher temperature insulations at the 90°C ampacity with appropriate derating.) • Complete range of UL Listed and high SCCR rated one- and threephase finger-safe comb busbars and power feed lugs • Optional hex head terminal screw makes it easier to achieve necessary torque values Amps • 30 A UL • • Flammability 32 A IEC SCCR • 33 kA photovoltaic • 200 kA RMS Sym. (CHCC, CHM*) * CHM SCCR is fuse interrupting rating dependent. Agency information • CHCC, CHM; UL Listed Guide IZLT, Recognized Guide IZLT2, File E14853 • CHPV, UL Listed to 4248-19, Guide IZMR, File E348242 • CSA File 47235, CHPV and CHM - Class 6225-30, CHCC - Class 6225-01 • IEC 60269-2 (CHM, CHPV) • CCC • RoHS compliant • CE Fuse access door accommodates 4mm lockout/tagout device IP20 finger-safe construction Optional open fuse indicator Captive phil-slot or optional hex head terminal screw Fork lug terminal Mounting: 35mm DIN-Rail Wire range Toolless ganging for multiple poles • 75°C and 90°C Cu • 18-4 AWG (0.8-21.1mm2) • Solid, stranded and fine stranded* Toolless 35mm DIN-Rail mounting * See data sheet 10430 for application details. Wire strip gauge Dual conductor rated box lug terminal Terminals • Single or dual conductors • Comb busbar • Terminal screws • Standard phil-slot • Optional hex head (order by adding “-H” suffix to the catalog number, e.g., CHM1DU-H) Torque • 30 lb-in (3.4 N•m) maximum Data sheet no. 10430 8-8 Gang multiple poles to meet application requirements using kit catalog number JV-L (gangs up to four poles). BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 UL midget and IEC 10x38 Catalog no.† Volts and amps With indication* CHM1DIU Without indication CHM1DU CHM2DIU CHM2DU CHM3DIU CHM3DU CHM4DIU CHM4DU CHM1DNIU CHM1DNU CHM3DNIU CHM3DNU UL IEC 600 V/ 30 A 690 V/ 32 A Agency marks Poles 1 UR, CSA, IEC 60269-2, CCC 2 3 4 IEC 60269-2 UR, CSA, 48 Vdc/ IEC 60269-2, 32 A CCC 690 V/ IEC 60269-2 32 A 1 + neutral 3 + neutral CHM1DI-48U — 48 Vdc/ 30 A — CHM1DNXU — CHM1DCIU CHM1DCU 1 CHM2DCIU CHM2DCU 2 CHM3DCIU CHM3DCU CHM4DCIU CHM4DCU 600 Vac, 1000 Vdc, 30 A 690 V, 32 A UR, CSA, IEC 60269-2 SCCR Recommended Bussmann series fuses BAF, BAN, FNM, FNQ, 200 kA FWA, FWC, RMS Sym.†† KLM, KTK, AGU, C10G_, C10M_ 1 N/A N/A 600/690 V BAF, BAN, FNM, FNQ, 200 kA FWA, FWC, RMS Sym.†† KLM, KTK, 33 kA DC AGU, C10G_, C10M_, 1000 Vdc PV-(amp)A10F, PV10M-(amp) 3 4 UL Class CC Catalog no. † With indication* CHCC1DIU CHCC2DIU CHCC3DIU CHCC1DI-48U Without indication CHCC1DU CHCC2DU CHCC3DU — Volts / amps 600 V/30 A Agency marks UL, CSA, CCC 48 Vdc/30 A Poles 1 2 3 1 SCCR Poles SCCR 200 kA RMS Sym. 33 kA DC Recommended Bussmann series fuses LP-CC, FNQ-R, KTK-R UL and IEC photovoltaic Catalog no. † With indication* Without indication CHPV1IU CHPV1U CHPV2IU CHPV2U Volts / amps 1000 Vdc/30 A Agency marks UL, CSA, , UL 4248-18, IEC 60269-1, CCC 1 33 kA DC 2 Recommended Bussmann series fuses PV-(amp)A10F, PV10M-(amp) † Available with optional hex head terminal screws. To order, add “-H” suffix to the desired catalog number. †† SCCR is limited to the interrupting rating of the installed fuse or 200 kA, which ever is less. * All models require 90 V minimum for illumination, except CHM1DI-48U that requires 15 V minimum. Dimensions — mm (in) 70 (2.756) 52.5 (2.067) 35 (1.378) 61.83 (2.434) 18.59 (0.732) Fuse blocks and holders 17.5 (0689) 73.88 (2.909) 9 (0.354) 42.58 (1.676) 7 (0.276) 52.83 (2.08) 83.19 (3.275) Data sheet no. 10430 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-9 8 — Fuse blocks and holders Power feed terminals Accessories PWR1PLP — Single-phase, low profile power feed terminal Ratings Power feed terminals 1- and 3-phase comb busbars Contact safety covers • Volts 1000 V • Amps 115 A • Wire range 1/0-10 AWG Cu, max torque 50 lb-in (5.6 N•m) • Wire rating 60°C† PWR35MM — 35mm2 three-phase power feed terminal for three- phase busbars Ratings Comb busbars • Volts 1000 V • Amps 115 A • Wire range 1/0-10 AWG Cu, max torque 50 lb-in (5.6 N•m) • Wire rating 60°C† PWR50MM — 50mm2 direct feed power terminal • Easily distribute power in single-or three-phase systems • Flexible cut-to-length busbars do not compromise the finger-safe protection (requires using endcaps) • Volts 1000 V • 100 kA SCCR when protected by a max 200 A Class J fuse • Amps 115 A • Single-phase busbars rated to 1000 Vdc and 100 A • • Three-phase busbars rated to 600 V and 100 A Wire range 1-14 AWG Cu, max torque 35 lb-in (3.9 N•m) • Power feed terminals for single-and three-phase systems • Wire rating 75°C† Ratings † Higher temperature rated wire may be used with appropriate derating. Agency information Comb busbar safety covers and end caps FSCVR UL 508, File E195399 • Spare comb busbar pin safety protection covers (used to cover exposed pins on comb busbars). Sold in quantity of ten strips of five covers each. (FSCVR comes with five covers on a strip. Minimum order is 10 strips or 50 safety covers total.) Pitch 17.8mm Ratings Volts • • 600 V max. (three-phase) • 1000 Vdc/600 Vac max. (single-phase) ECAP1P • Amps 100 A max. End cap for single-phase comb busbars. Sold in quantity of fifty. • SCCR ECAPMP • 10 kA (default) • 100 kA (with upstream Class J max 200 A fuses) Catalog no. BB1P100M3 BB1P100M6 BB1P100M9 BB1P100M12 BB1P100M15 BB1P100M57 BB3P100M6 BB3P100M9 BB3P100M12 BB3P100M15 BB3P100M57 Phase Single Three No. of pins 3 6 9 12 15 57 pin cuttable 6 9 12 15 57 pin cuttable Endcaps* End cap for three-phase comb busbars. Sold in quantity of fifty. Accessory catalog numbers Catalog no. No** PWR50MM Yes* ECAP1P ECAPMP Description Single-phase low-profile power feed terminal (115 A, 1000 V) 35mm2 power feed terminal for three-phase busbar (115 A, 1000 V) 50mm2 direct power feed terminal (1000 V) Single-phase busbar endcap Three-phase comb busbar end cap FSCVR Spare comb busbar pin safety protection covers Yes* PWR1PLP PWR35MM No** Carton quantity 10 10 10 50 50 10 strips of five covers each, total 50 individual covers * With endcaps assembled. If cut to length, order additional endcaps separately. ** Order end caps separately, ECAP1P for single-phase busbars and ECAPMP for three-phase busbars. Data sheet no. 10430 8-10 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 PLC fuse monitor Local indication Catalog no. CH-PLC2 The Bussmann series resettable PLC fuse monitor permits easy integration with a Programmable Logic Controller (PLC) or other monitoring and control equipment. Signals up to three-phases. Includes 0.11" (2.8mm) quick-connects for power, signal and ground connections. Ratings • Signal output to PLC* • • Flammability rating UL 94V0 +24 Vdc, 10 mA max Output signals • Wiring • Digital 0 Vdc (low), 24 Vdc max (high) • 0 Vdc Low – fuse is good • 24 Vdc High – fuse has opened • Mounts on the left side of the fuse holder and mechanically interlocks with the fuse holder switch handle with hardware provided Degree of protection IP20 finger-safe • UL 508 Listed, Guide NKCR, File E170168 • cULus, Guide NKCR7, File E170168 to Canadian Standard 22.2, No. 14-13 Emissions and immunity testing • IEC 60947-1: Voltage Switchgear and Control Gear • IEC 61000-6-2: Electromagnetic Compatibility (EMC) • IEC 61000-4-2: Electrostatic Discharge Immunity - Test at level 3 (6 kV-Contact Discharge) and level 2 (4 kV-Air Discharge) • Minimum circuit voltage required across the CH holder is 100 Vac for the remote indication device to operate Installation * When the fuse opens, the output signal is sent high and will remain high until the unit is reset. Agency information For power, signal and ground connections use shielded twisted pair 22-24 AWG (0.34-0.25mm2) 300 V rated wire. Minimum circuit voltage • • Two distinct LEDs indicate unit power (green) and open fuse (red). Open fuse LED is resettable upon fuse replacement and the actuating the reset switch IEC 61000-4-3: Electromagnetic Compatibility - Radiated, Radiofrequency, Electromagnetic Field Immunity test at level x (20 V/m) Storage and operating temperature • -4°F (-20°C) to +167°F (+75°C) PLC programming • The CH-PLC2 signal line is designed to provide a digital input to a PLC I/O card • Programmable Logic Control program must be written to properly interpret the input signal to the PLC • The PLC program should check for consecutive high signals before taking action on a critical process • IEC 61000-4-4: Electromagnetic Compatibility - Testing and Measurement Techniques at level 3 (± 2kV - Power Port and ±1 kV - I/O Ports) To order • IEC 61000-4-5: Electromagnetic Compatibility - Surge Immunity test at level 4 (±4 kV) Data sheet no. 10430 • IEC 61000-4-6: Immunity to Conducted Disturbances at level 3 (10 V) • Specify catalog number CH-PLC2 (one unit) NDNF1-WH single-pole DIN-Rail mount fuse holding terminal block for 13/32" x 1-1/2" (10x38mm) fuses Ratings: 600 volts / 30 amps Fuse blocks and holders Wire range 8-22 AWG Cu Torque rating 2.03 N•m (18 lb-in) Mounting 35mm DIN-Rail or C-rail Fuse pullers • PF1-WH (white) • PF1-BK (black) Max operating temperature 105°C Circuit jumper catalog no. JF1 for 2 circuits BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-11 8 — Fuse blocks and holders Optima™ fuse holder module and module with disconnect switch Features • Padlockable with finger-safe terminals for safety. Qualified as IP20 per IEC 60529 • Cam-action handle for easy fuse module removal, offered with Class CC rejection clips or 13/32 x 1-1/2 (10x38mm) clips to meet global needs • Wire ready with 35mm DIN-Rail or screw panel mounting (#8 screw, 1-1/4” long) saves installation time • Fuse indication lights with optional communications for remote fuse status available. See data sheet for additional wiring details. OPM-1038(R)(C) without switch OPM-1038(R)SW(C) with switch OPM-1038(R)(C) is a 3-pole modular fuse holder 13/32" x 1-1/2" (10x38mm) and Class CC fuses. OPM-1038(R)SW(C)* is a 3-pole load break modular fuse holder and disconnect switch for 13/32" x 1-1/2" (10x38mm) and Class CC fuses. Typical applications • Industrial control • Process control systems • Automated warehouse systems * Recommend using the UL 98 Listed CCP2 disconnect switch. See page 11-2. • Individual control circuits Ratings Dimensions — in (mm) Both the OPM-1038(R)SW(C) and OPM-1038(R) (C) are available with optional communications for interfacing with programmable logic controllers. 0.57 (15) • See catalog numbers table 3.22 (82) 2T1 Agency information 3.74 (95) See catalog numbers table 1.65 (42) Flammability rating UL 94V0 0.23 (6) 0.27 (7) 5L3 0.74 (19) 0.31 (8) 3.6 (91) 0.50 (13) Counication port 3L2 0.41 (11) 0.224 (6) OPM-1038(R)SW(C) switch horsepower ratings 3-phase volts 240 480 600 HP 5 10 15 3.60 (91) 1.312 (33) Panel mount hole pattern 1.86 (47) Panel mount hole pattern Counication port OPM-1038 0.57 (15) Recommended Bussmann series fuses 3.74 (95) Counication port 3.17 (81) • Class CC; LP-CC, FNQ-R, KTK-R • UL 13/32" x 1-1/2"; KTK, FNQ, KLM, FNM, BAF • IEC 10x38mm; C10G, C10M, FWA, FWC 0.23 (6) 0.224 (6) 1.86 (47) Panel mounting hole pattern 3.60 (91) 1.312 (33) Panel mounting hole pattern Physical characteristics • 4T2 1.76 (45) 6T3 BUSS • IL1 3.17 (81) 5.72 (145) 4.25 (108) Small size matches 45mm IEC starter width Accepts Cu AWG stranded 8-18 and solid 10-18 wire • OPM-1038(R)SW(C ) switch version requires a handle and shaft for through the door operation 1.38 (35) 2T1 4T 2 6T3 1L1 BUSS • 0.43 (11) 0.50 (13) 0.44 (11) Counication port 3L2 0.27 (7) 5L3 0.74 (19) 1.76 (45) 0.31 (8) OPM-1038SW Catalog no. Without communication With communication Fuse type/size Volts Amps SCCR Agency information OPM with disconnect switch OPM-1038SW OPM-1038SWC* Non-rejection, 13/32” x 1-1/2 or 10x38mm 600 Vac UL/CSA, 660 V IEC 30 A UL, 32 A IEC ** UL 508 Recognized, Guide NLRV2, File E161278, CSA Certified, C22.2 No. 39, Class 6225-01, File 47235, IEC 60947-3, CE OPM-1038RSW OPM-1038RSWC* Class CC 600 Vac UL/CSA 30 A 100 kA UL 508 Listed, Guide NLRV, File E161278, CSA Certified, C22.2 No. 39, Class 6225-01, File 47235,IEC 60947-3, CE OPM without switch OPM-1038 OPM-1038C* Non-rejection, 13/32” x 1-1/2 or 10x38mm 600 Vac UL/CSA, 660 V IEC 30 A UL, 32 A IEC ** UL Recognized, Guide IZLT2, File E114853, CSA Certified, C22.2 No. 39, Class 6225-01, File 47235, IEC 60269-2-1, CE OPM-1038R OPM-1038RC* Class CC 600 Vac UL/CSA 30 A 200 kA UL Listed, Guide IZLT2, File E114853, CSA Certified, C22.2 No. 39, Class 6225-01, File 47235, IEC 602692-1, CE * With communication not CE. ** Rating varies depending on fuse used in module; 10 kA default, higher SCCR requires testing and certification. Data sheets no. 1002 (OPM-1038) and 1103 (OPM-1038SW) 8-12 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 OPM-NG Optima three-pole overcurrent protection module Fuse holder AWG wire range (75°C Cu only)* • 18-12, single/dual, torque 15 lb-in (1.7 N•m) The OPM-NG is a 3-pole protection module that's available in versions for Class CC, and UL 13/32" x 1-1/2" supplemental and 10x38mm IEC fuses. • 10-8, single/dual, torque 20 lb-in (2.2 N•m) * Dual wire with same gauge and type Input power terminal wire range (AWG) Torque lb-in (N•m) Wire Catalog numbers • OPM-NG-SC3 (Class CC) • OPM-NG-SM3 (UL/IEC) Solid 2011/65/EU Stranded Ratings • • • • 600 Vac (or less) UL and CSA • 690 Vac (or less) IEC Amps 30 A UL and CSA • 32 A IEC Connector Screw clamp 20 (2.2) 15 (1.7) Single 14-2 (1.5-25) Dual 14-6 (1.5-10) Single 14-2 (1.5-25) Dual 12-6 (2.5-10) Flammability rating Volts • AWG (mm2) range • UL V2 Dimensions — mm (in) SCCR • 200 kA Class CC • UL supplemental and IEC same as fuse IR up to 200 kA max Agency information • UL; OPM-NG-SC3 UL Listed, UL 4248, File E14853, Guide IZLT. OPM-NG-SM3, UL Recognized, UL 4248, File E14853, Guide IZLT2. CSA Certified, C22.2 No. 4248, Class 6225-01, File 47235. IEC 60947-3 Utilization Category AC20B, CE Recommended Bussmann series fuses • Class CC: LP-CC, FNQ-R, KTK-R • UL 13/32" x 1-1/2": KTK, FNQ, KLM, FNM, BAF • IEC 10x38mm: C10G, C10M, FWA, FWC • 45mm width matches IEC starters • 35mm DIN-Rail or panel mount. Max. screw size #8 (M4). • Pressure plate terminations with dual-wire rated terminals (see wire table) and optional auxiliary contacts • Integrated collapsible handle and fuse carrier cannot be removed from holder base • Padlockable and IP20 finger-safe to IEC 60529 Fuse blocks and holders Features Typical applications • Mass produced control systems • Process control systems • Automated warehouse systems • Individual control circuits Data sheet no. 1109 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-13 8 — Fuse blocks and holders 3743 open, add-on block for 13/32" x 1-1/2" (10x38mm) fuses 4421 and 4515 open single pole blocks for 13/32" x 1-1/2" (10x38mm) fuses. Single pole blocks lock into each other and can be added at any time. Each has a single end barrier. Ratings Ratings 3743 open, add-on block 2011/65/EU • Volts 250 V • Amps 30 A 2011/65/EU Agency information Volts 600 V • Amps 30 A 4421 solder terminal CE Agency information • UL Recognized, Guide IZLT2, File E14853, CE 4515 screw terminal 3742 end barrier only Catalog no. Catalog no. Description 3743 Add-on fuse block 3742 End barrier 3723 Block and end barrier marking strip (length 9-3/8") Terminals Base width 4421 Solder 5/8" (16mm) 4515 Screw 3/4" (19mm) Dimensions — in* 2.5 Dimensions — in* 2.56 0.323 0.897 0.19 0.25 1.125 0.78 4421 solder terminals 0.144 2.56 1.34 1.29 3742 2.56 1.125 0.25 1.63 0.897 0.84 0.19 0.50 * Mounting screw hole diameter 0.147" (3.7mm). Counterbore diameter 0.636" (8mm). Max. #6 mounting screw. 4515 with screw terminals * Mounting screw hole diameter 0.147". Counterbore diameter 0.312". Max. #6 mounting screw. Data sheet no. 2104 8-14 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 BG and G Class G fuse blocks Dimensions — in 1-30 A Bussmann series open style BG and G fuse blocks are available in 1-, 2- and 3-pole configurations and offer a variety of terminal options. 1.53 1.22 0.36 Ratings • 0.425 0.425 0.36 Volts 0.2 3 • 600 V (0-20 A) • 480 V (25-60 A) 1.5 2011/65/EU • Amps up to 60 A • SCCR 100 kA RMS Sym. 0.86 0.169 x 0.210 1.63 Agency information 2.38 0.765 35-60 A 1.38 • UL Listed, 4248-5, Guide IZLT, File E14853 • 1-60 A CSA Certified, C22.2 No. 39, Class 6225-01, File 47235 • RoHS compliant 0.22 0.5 0.47 0.84 Mounting 0.29 Dia. hole 0.38 C'bore • Panel • DIN-Rail with DRA-1 adapter 4.25 2.125 Catalog no./terminal Amps Up to 15 20 25-30 35-60 AWG wire range/ type Screw w/ quickconnect* Pressure plate w/ quickconnect* BG3011SQ Box lug Box lug w/ retaining clip Poles BG3011PQ BG3011B — 1 BG3012SQ BG3012PQ BG3012B — 2 BG3013SQ BG3013PQ BG3013B — 3 BG3021SQ BG3021PQ BG3021B — 1 BG3022SQ BG3022PQ BG3022B — 2 BG3023SQ BG3023PQ BG3023B — 3 BG3031S BG3031P BG3031B — 1 BG3032S BG3032P BG3032B — 2 BG3033S BG3033P BG3033B — 3 — — — G30060-1CR 1 — — — G30060-2CR 2 — — G30060-3C** G30060-3CR 3 10-14 Cu 10-18 Cu 6-14 Cu (1-30 A) 2-14 Cu (35-60 A) 2-8 Al (35-60 A) 2-14 Cu 2-8 Al 0.94 1.78 35-60 A 3-Pole G30060-3C and G30060-3CR 1.41 0.53 1.69 0.22 Dia. hole 3.56 1.78 2.75 Fuse blocks and holders * Quick-connect rated 20 A max. ** Not RoHS compliant. Accessories Catalog no.† Description PF1-WH Fuse cover/puller PF1-BK Color White Black † Order one cover per pole. Data sheet no. 1106 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-15 8 — Fuse blocks and holders CH14 modular fuse holders for 14x51mm fuses Bussmann series 14x51mm modular fuse holders are suitable for use with standard cylindrical fuses and high speed FW type ferrule fuses. With DIN-Rail or panel mount flexibility, their compact dimensions helps reduce space, allows for higher cable bending radius. Low watts loss and wide range of accessories make them ideally suited for most industrial applications. Ratings • Volts • 690 Vac/750 Vdc (IEC) • • • 700 Vac (UL) Amps • 50 A SCCR • 120 kA AC • • 2011/65/EU 10 kA DC (PV only) Power acceptance • 5 W to IEC 60269-2 (rated) Shown with optional microswitch 6.2 W (max) Catalog no. Poles Description CH141DNXU 1 Neutral holder CH141DU 1 CH142DU 2 CH143DU 3 CH144DU 4 CH141DNU 2 1-pole holder+ neutral CH143DNU 4 3-pole holder+ neutral CH141DIU 1 CH142DIU 2 CH143DIU 3 CH144DIU 4 CH141DNIU 2 1-pole holder + neutral + neon indicator CH143DNIU 4 3-pole holder + neutral + neon indicator CH141DMSU-F 1 CH143DMSU-F 3 UL/IEC holders Fuse holder Fuse holder with neon indicator Holder + microswitch CH143DNMSU-F 4 3-pole holder+ neutral + microswitch • Rated impulse withstand voltage (Uimp) • 6 kV CHPV141DI-48U 1 Holder with LED indicator • Microswitch (IEC) • 250 Vac / 5 A CHPV141U 1 CHPV141IU 1 Holder with neon indicator Agency information CHPV142U 2 Holder CHPV142IU 2 Holder with neon indicator • • IEC 60269-1 and 2, UL Listed File E14853, CCC (UL/IEC) • IEC 60269-1 and 2, UL Listed File E348242, CCC (PV) • RoHS compliant 1 to 4 CH14-CTP Protection index Holder Accessories Catalog no. JV-L CH14-SPS CH14-TPS Poles • 1500 Vdc photovoltaic holders Description Multi-pole connector kit; one kit gangs up to 4 poles Microswitch for CH141D(I)U; 1 NO + 1 NC changeover type Microswitch for CH143D(I)U; 1 NO + 1 NC changeover type IP20 protection accessory for terminals with 10mm2 or less cable IP20 Temperature range • • Storage • -40°C to +80°C (CH14D) • -20°C to +90°C (CHPV14 indicating) • -20°C to +120°C (CHPV14 non-indicating) Operating • -20°C to +70°C (CH14D) • -20°C to +90°C (CHPV14 indicating) • -20°C to +120°C (CHPV14 non-indicating) Features • Ventilation zones optimized for better heat dissipation • Built-in padlocking facility and IP20 degree of protection • Photovoltaic version rated at 1500 Vdc (IEC only) for use with gPV fuses Data sheet no. 10080 8-16 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 CH22 modular fuse holders for 22x58mm fuses Bussmann series 22x58mm modular fuse holders are suitable for use with standard cylindrical fuses and high speed FW type ferrule fuses. Their compact dimensions help reduce space and allow for higher cable bending radius. Low watts loss and wide range of accessories make them ideally suited for most industrial applications. Ratings • • • • Volts • 690 Vac/1000 Vdc (IEC) • 700 Vac (UL) Amps CH221DNXU 1 Neutral holder CH221DU 1 CH222DU 2 CH223DU 3 CH224DU 4 CH221DIU 1 CH222DIU 2 CH223DIU 3 CH224DIU 4 CH221DNU 2 1-pole holder + neutral CH223DNU 4 3-pole holder + neutral Fuse holder Holder with neon indicator CH221DNIU 2 1-pole holder+ neutral + neon indicator • 100 A (UL) CH223DNIU 4 3-pole holder+ neutral + neon indicator CH221DMSU-F 1 Holder with microswitch (pre-breaking/fuse operation) CH223DMSU-F 3 3-pole holder + microswitch (pre-breaking/ fuse operation) CH223DNMSU-F 3 3-pole holder + neutral + microswitch (prebreaking/fuse operation) CH221DI-48U 1 1-pole holder with LED Indicator SCCR • 120 kA AC • 50 kA DC Power acceptance 9.5 W to IEC 60269-2 Rated impulse withstand voltage (Uimp) 6 kV Microswitch (IEC) • Accessories Catalog no. JV-L CH22-SPS CH22-TPS 250 Vac / 5 A Agency information • Description 125 A (IEC) • • Poles • • • 2011/65/EU Catalog no. IEC 60269-1 and 2, UL Listed File E14853, CCC, RoHS compliant CH22-CTP Description Multi-pole connector kit; one kit gangs up to 4 poles Microswitch for CH221D(I)U; 1 NO + 1 NC changeover type Microswitch for CH223D(I)U; 1 NO + 1 NC changeover type IP20 protection accessory for terminals with 10mm2 or less cable Poles 1 to 4 Protection index • IP20 Finger-safe* * Available protection accessory CH22-CTP for use with conductors of 10mm2 or less Wire size (Cu only) • 2.5-70mm2 • Storage -40°C to +80°C • Operating -20°C to +70°C Fuse blocks and holders Temperature range Features • Compact dimensions • Ventilation zones optimized for a better heat dissipation • Built-in padlocking facility • IP20 degree of protection • Flexibility to mount on DIN Rail and screw mounting • Toolless DIN-Rail mounting, improves ease of use and reduces installation time and costs Data sheet no. 10115 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-17 8 — Fuse blocks and holders JM70100 700 V modular fuse blocks and modular power distribution fuse blocks for 22x58mm IEC fuses Ratings The patented JM70100 fuse block products are available for 22x58mm gG, aM and select high speed fuses as either a fuse block or power distribution fuse block. The power distribution fuse blocks eliminate the need for a separate power distribution block, and require up to 78 percent less panel space while reducing installation time and labor by an average of 36 percent. 2011/65/EU • Volts 700 V • Amps 100 A • SCCR 200 kA RMS Sym. Agency information Fuses not included. • Blocks; UL Recognized, Guide IZLT2, File E14853, CSA Component acceptance 47235 — 6225-01 • Covers UL Listed, Guide JDVS, File E58836 • RoHS compliant Poles All blocks are equipped with a fuse clip reinforcing spring to minimize temperature rise while maintaining reliable surface contact between the fuse and clip over the block's service life. Rated for applications up to 700 V and 100 amps, their modular design allows for assembly of multiple pole configurations at the point of use. These blocks can also be ordered as factory configured 2- and 3-pole versions. The versatile 35mm DIN-rail or panel mount capability allows using the same block for multiple applications and reducing inventory cost. Optional IP20 finger-safe covers enhance electrical safety with a lockout/tagout feature and can be ordered with or without open fuse indication to speed troubleshooting. • 1-, 2-, 3-pole • Single-pole units snap together to create desired number of poles Flammability ratings • Blocks: UL 94V0, self-extinguishing • Covers: UL 94HB, self-extinguishing Operating and storage temperature range • Blocks -40°C to +120°C • Covers; Non-indicating -40°C to +120°C, Indicating -20°C to +90°C The high 200 kA SCCR rating helps achieve a higher assembly shortcircuit current rating (SCCR) for compliance with NEC® sections 110.10, 409.110(4), 409.22, 440.4(B), 670.3(A)(4) and 670.5. Conductors Easy circuit identification with available universal labels for blocks and covers. * Conductors with higher temperature rating may be used, but at their 75°C ampacity. Fuse class Accessories • IEC 22x58mm gG, gL, aM and aR and gR high speed fuses Catalog no. Optional covers* Fuse amp range • • 75°C Cu/Al* Optional IP20 finger-safe covers in indicating and non-indicating versions. Order one for each pole Lineside conductors and torque Poles Conductors Loadside conductors and torque Size (AWG) N•m (lb-in) 2-3 5.6 (50) Conductors Size (AWG) N•m (lb-in) 2-3 5.6 (50) Fuse blocks JM70100-1CR JM70100-2CR 1 CVR-J-60060 CVRI-J-60060** Up to 100 JM70100-3CR 2 Cu 2-14 Al 2-8 3 4-6 5.1 (45) 8 4.5 (40) 10-14 4.0 (35) 2-3 5.6 (50) Cu 2-14 Al 2-8 4-6 5.1 (45) 8 4.5 (40) 10-14 4.0 (35) Cu (1) 8 3.4 (30) Power distribution fuse blocks JM70100-1MW14 JM70100-2MW14 1 CVR-J-60060 CVRI-J-60060** JM70100-3MW14 Up to 100 2 Cu 2-14 Al 2-8 3 4-6 5.1 (45) 8 4.5 (40) 10-14 4.0 (35) Cu (1) 8-18 Cu (2) 12-18 Al (1) 8 Str Al (1) 10 Sol Cu (1) 10-18 2.8 (25) Cu (2) 12-18 3.4 (30) Al (1) 8-10 3.4 (30) * Covers sold separately, one cover per pole. ** Open fuse indication requires 90 volts minimum and closed circuit to operate. Data sheet no. 10496 8-18 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 HM modular 250 V and 600 V Class H(K) fuse blocks Class H(K) modular fuse blocks enhance safety for any panel or electrical system design and are available for the full Class H(K) fuse amp range. 2011/65/EU All blocks are available as snaptogether single-pole versions for toolless assembly of multiple poles at point of use, or as factory configured 2-, and 3-pole versions to meet stocking requirements. Ratings • Volts • 250 V • 600 V • Amps up to 600 • SCCR 10 kA RMS Sym. Agency information All blocks are equipped with a fuse clip reinforcing spring to minimize temperature rise while maintaining reliable surface contact between the fuse and clip over the block's service life. • Blocks;UL Listed, Guide IZLT and IZLT7, File E14853, CSA Certified 47235-6225-01, CE • RoHS Compliant • Covers; UL Listed, Guide JDVS, File E58836, CSA Certified 472356225-01 (30 and 60 A) • RoHS Compliant Poles 30 and 60 amp ferrule fuse blocks save panel space with the smallest width dimension on the market and feature DIN-Rail and panel mount versatility. 100 to 600 amp knifeblade fuse blocks feature phase barriers between poles for additional safety with up to four mounting holes per pole to increase installation flexibility. All knifeblade blocks meet UL creep and clearance requirements for Industrial Power Circuits (UL 508 and UL 845), with the 200 to 600 amp blocks meeting the higher UL creep and clearance requirements for Power Distribution Standards (UL 98, UL 67, UL 489, UL 891 and UL 869A) All blocks are available with optional IP20 finger-safe high clarity, see-through covers for inspecting wire terminations or thermography measurements without removal. All covers enhance safety by featuring probe holes for easier, safer testing and a lockout/tagout capability. These covers also have optional open fuse indication to speed troubleshooting. Easy circuit identification is available for 30 and 60 amp blocks and covers with universal marker labels. • 1-, 2-, 3-pole units factory assembled • Single-pole units snap together to create desired number of poles Flammability ratings • Blocks: UL 94V0, self-extinguishing • Covers: UL 94HB, self-extinguishing Operating and storage temperature range • Blocks -40°C to +120°C • Covers; Non-Indicating -40°C to +120°C, Indicating -20°C to +90°C* * Indication requires minimum 90 V and closed circuit to illuminate. Conductors • See catalog numbers for details and torque specifications Class K 30 and 60 amp blocks and covers Fuse amp range Catalog no./terminal type Poles Box lug/slot screw Box lug/hex screw Optional covers* 10-32 Phil-slot screw Screw with quick-connect Pressure plate Indicating** Nonindicating CVRI-RH-25030 CVR-RH-25030 CVRI-RH-25060 CVR-RH-25060 CVRI-RH-60030 CVR-RH-60030 CVRI-RH-60060 CVR-RH-60060 up to 30 35 to 60 1 HM25030-1CR HM25030-1CHR HM25030-1SR HM25030-1QR HM25030-1PR 2 HM25030-2CR HM25030-2CHR HM25030-2SR HM25030-2QR HM25030-2PR 3 HM25030-3CR HM25030-3CHR HM25030-3SR HM25030-3QR HM25030-3PR 1 HM25060-1CR HM25060-1CHR 2 HM25060-2CR HM25060-2CHR — — — 3 HM25060-3CR HM25060-3CHR HM60030-1CR HM60030-1CHR 600 volt blocks 1 up to 30 35 to 60 HM60030-1SR HM60030-1PR 2 HM60030-2CR HM60030-2CHR HM60030-2SR HM60030-2PR 3 HM60030-3CR HM60030-3CHR HM60030-3SR HM60030-3PR 1 HM60060-1CR HM60060-1CHR 2 HM60060-2CR HM60060-2CHR 3 HM60060-3CR HM60060-3CHR — — — * Covers sold separately, one cover per pole. ** Open fuse indication requires 90 volts minimum and closed circuit to operate. Data sheet no. 10487 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-19 Fuse blocks and holders 250 volt blocks 8 — Fuse blocks and holders Class H 100 to 600 amp knifeblade blocks and covers Fuse amp range Optional covers* Poles Catalog no. Non-indicating Conductors*** Indicating** Solid and stranded Fine stranded Torque N•m (lb-in) — Cu 1-3 AWG 6.2 (55) 1/0-3 AWG; (2) Cu 4-6 AWG Cu 4-6 AWG 5.6 (50) 2 4-6 AWG; (2) Cu 8 AWG Cu 8 AWG 5.1 (45) 8 AWG; (2) Cu 10-14 AWG — 4.5 (40) Cu 10-14 AWG; Al 10-12 AWG — 4.0 (35) 250kcmil-1 AWG Cu 3/0-1 AWG 42 (375) 2-6 AWG; (2) Cu 2-6 AWG Cu 2-6 AWG 31 (275) 250 volt blocks 1 70-100 110-200 225-400 HM25100-1CR 2 HM25100-2CR 3 HM25100-3CR 1 HM25200-1CR 2 HM25200-2CR 3 HM25200-3CR 1 HM25400-1CR 2 HM25400-2CR 3 HM25400-3CR CVR-RH-25100 CVR-RH-25200 CVRI-RH-25100 CVRI-RH-25200 600kcmil CVR-RH-25400 CVRI-RH-25400 500kcmil-4 AWG (2) Cu 3/0 - 4 AWG 57 (500) 51 (450) N/A 57 (500) (2) Al 3/0 - 4 AWG 450-600 1 HM25600-1CR 2 HM25600-2CR 3 HM25600-3CR CVR-RH-25600 CVRI-RH-25600 2 (2) 500kcmil-4 AWG 34 (300) N/A 51 (450) 600 volt blocks 70-100 110-200 225-400 450-600 1 HM60100-1CR 2 HM60100-2CR CVR-RH-60100 CVRI-RH-60100 — Cu 1-3 AWG 6.2 (55) 1/0-3 AWG; (2) Cu 4-6 AWG Cu 4-6 AWG 5.6 (50) 2 4-6 AWG; (2) Cu 8 AWG Cu 8 AWG 5.1 (45) 8 AWG; (2) Cu 10-14 AWG — 4.5 (40) 3 HM60100-3CR Cu 10-14 AWG; Al 10-12 AWG — 4.0 (35) 1 HM60200-1CR 250kcmil-1 AWG Cu 3/0-1 AWG 42 (375) 2 HM60200-2CR 2-6 AWG; (2) Cu 2-6 AWG Cu 2-6 AWG 31 (275) 3 HM60200-3CR 1 HM60400-1CR 600kcmil 2 HM60400-2CR 500kcmil-4 AWG 3 HM60400-3CR 1 HM60600-1CR 2 HM60600-2CR 3 HM60600-3CR CVR-RH-60200 CVR-RH-60400 CVRI-RH-60200 CVRI-RH-60400 (2) Cu 3/0 - 4 AWG 57 (500) 51 (450) N/A 57 (500) (2) Al 3/0 - 4 AWG CVR-RH-60600 CVRI-RH-60600 2 (2) 500kcmil-4 AWG 34 (300) N/A 51 (450) * Covers sold separately. ** Open fuse indication requires 90 volts minimum and closed circuit to operate. *** Ratings for copper and aluminum conductors except where otherwise noted. Class K 30 and 60 amp block terminals and conductors Terminal type AWG type/range AWG 2-3 75°C 4-6 Cu 2-14, 8 AL 2-8 10-14 Box lug 10-32 Phil-slot screw Screw with quick-connect* 75/90°C Cu 10-18 Pressure plate 10-18 Torque N•m (lb-in) 5.6 (50) 5.1 (45) 4.5 (40) 4.0 (35) Recommended DIN-Rail stops for 30 and 60 amp blocks Catalog no. BRKT-ND BRKT-NDSCREW2 Description DIN-Rail end stops 2.3 (20) * 3/16” quick-connect terminal maximum amps dependent on female spade connector and wire ratings. Data sheet no. 10487 8-20 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 RM modular 250 V and 600 V Class R fuse blocks Ratings Class R modular fuse blocks enhance safety for any panel or electrical system design and are available for the full Class R fuse amp range. • 2011/65/EU All blocks are available as snaptogether single-pole versions for toolless assembly of multiple poles at point of use, or as factory configured 2-, and 3-pole versions to meet stocking requirements. All blocks are equipped with a fuse clip reinforcing spring to minimize temperature rise while maintaining reliable surface contact between the fuse and clip over the block's service life. 30 and 60 amp ferrule fuse blocks save panel space with the smallest width dimension on the market and feature DIN-Rail and panel mount versatility. 100 to 600 amp knifeblade fuse blocks feature phase barriers between poles for additional safety with up to four mounting holes per pole to increase installation flexibility. All knifeblade blocks meet UL creep and clearance requirements for Industrial Power Circuits (UL 508 and UL 845), with the 200 to 600 amp blocks meeting the higher UL creep and clearance requirements for Power Distribution Standards (UL 98, UL 67, UL 489, UL 891 and UL 869A). All blocks are available with optional IP20 finger-safe high clarity, see-through covers for inspecting wire terminations or thermography measurements without removal. All covers enhance safety by featuring probe holes for easier, safer testing and a lockout/tagout capability. These covers also have optional open fuse indication to speed troubleshooting. Easy circuit identification is available for 30 and 60 amp blocks and covers with universal marker labels. Volts • 250 V • 600 V • Amps up to 600 • SCCR 200 kA RMS Sym. Agency information • Blocks; UL Listed Guide IZLT and IZLT7, File E14853, CSA Certified 47235-6225-01, CE • Covers; UL Listed Guide JDVS, File E58836, CSA Certified 472356225-01 (30 and 60 A) • RoHS Compliant Poles • 1-, 2-, 3-pole units factory assembled • Single-pole units snap together to create desired number of poles Flammability ratings • Blocks: UL 94V0, self-extinguishing • Covers: UL 94HB, self-extinguishing Operating and storage temperature range • Blocks -40°C to +120°C • Covers; Non-Indicating -40°C to +120°C, Indicating -20°C to +90°C* * Indication requires minimum 90 V and closed circuit to illuminate. Conductors • See catalog numbers for details and torque specifications Finger grips on cover for easy removal Optional see-through, snap-on cover for easy visual inspection Optional open fuse indication speeds troubleshooting Vent slots improve cooling* Standard fuse clip reinforcing spring reduces temperature rise Toolless interlocking modular design for easy point-of-use assembly Lockout/tagout feature improves safety Probe holes for easy testing without removing cover *No fuse derating necessary. DIN-rail or panel mounting on each pole provides installation flexibility for units rated up to 60 amps Data sheet no. 10489 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-21 Fuse blocks and holders Standard phase barriers for additional safety 8 — Fuse blocks and holders Class R 30 and 60 amp blocks and covers Catalog no./terminal type Fuse amp range Optional covers* Box lug/ slot screw Box lug/ hex screw 10-32 Phil-slot screw screw with quick-connect Pressure plate 1 RM25030-1CR RM25030-1CHR RM25030-1SR RM25030-1QR RM25030-1PR 2 RM25030-2CR RM25030-2CHR RM25030-2SR RM25030-2QR RM25030-2PR 3 RM25030-3CR RM25030-3CHR RM25030-3SR RM25030-3QR RM25030-3PR 1 RM25060-1CR RM25060-1CHR 2 RM25060-2CR RM25060-2CHR — — — 3 RM25060-3CR RM25060-3CHR 1 RM60030-1CR RM60030-1CHR RM60030-1SR RM60030-1PR 2 RM60030-2CR RM60030-2CHR RM60030-2SR RM60030-2PR 3 RM60030-3CR RM60030-3CHR RM60030-3SR 1 RM60060-1CR RM60060-1CHR 2 RM60060-2CR RM60060-2CHR 3 RM60060-3CR RM60060-3CHR Poles Indicating** Nonindicating CVRI-RH-25030 CVR-RH-25030 CVRI-RH-25060 CVR-RH-25060 CVRI-RH-60030 CVR-RH-60030 CVRI-RH-60060 CVR-RH-60060 250 volt blocks up to 30 35 to 60 600 volt blocks up to 30 35 to 60 — — RM60030-3PR — * Covers sold separately, order one cover per pole. ** Open fuse indication requires 90 volts minimum and closed circuit to operate. Class R 30 and 60 amp block terminals and conductors Terminal type AWG type/range Box lug 75°C Cu 2-14, AL 2-8 10-32 Phil-slot screw Pressure plate Screw with quick-connect* 75/90°C Cu 10-18 AWG 2-3 4-6 8 10-14 Torque N•m (lb-in) 5.6 (50) 5.1 (45) 4.5 (40) 4.0 (35) 10-18 2.3 (20) * 3/16" quick-connect terminal maximum amps dependent on female spade connector and wire ratings. Recommended DIN-Rail stops for 30 and 60 amp blocks Catalog no. BRKT-ND BRKT-NDSCREW2 Description DIN-Rail end stops Data sheet no. 10489 8-22 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 Class R 100 to 600 amp knifeblade blocks and covers Fuse amp range Optional covers* Poles Catalog no. Non-indicating Conductors*** Indicating** Solid and stranded Fine stranded Torque N•m (lb-in) — Cu 1-3 AWG 6.2 (55) 1/0-3 AWG; (2) Cu 4-6 AWG Cu 4-6 AWG 5.6 (50) 2 4-6 AWG; (2) Cu 8 AWG Cu 8 AWG 5.1 (45) 8 AWG; (2) Cu 10-14 AWG — 4.5 (40) Cu 10-14 AWG; Al 10-12 AWG — 4.0 (35) 250kcmil-1 AWG Cu 3/0-1 AWG 42 (375) 2-6 AWG; (2) Cu 2-6 AWG Cu 2-6 AWG 31 (275) 250 volt blocks 1 70-100 110-200 225-400 450-600 RM25100-1CR CVR-RH-25100 CVRI-RH-25100 2 RM25100-2CR 3 RM25100-3CR 1 RM25200-1CR 2 RM25200-2CR 3 RM25200-3CR 1 RM25400-1CR 600kcmil 2 RM25400-2CR 500kcmil-4 AWG 3 RM25400-3CR 1 RM25600-1CR 2 RM25600-2CR 3 RM25600-3CR CVR-RH-25200 CVR-RH-25400 CVRI-RH-25200 CVRI-RH-25400 57 (500) 51 (450) N/A (2) Cu 3/0 - 4 AWG 57 (500) (2) Al 3/0 - 4 AWG CVR-RH-25600 CVRI-RH-25600 34 (300) 2 (2) 500kcmil-4 AWG N/A 51 (450) — Cu 1-3 AWG 6.2 (55) 1/0-3 AWG; (2) Cu 4-6 AWG Cu 4-6 AWG 5.6 (50) 2 4-6 AWG; (2) Cu 8 AWG Cu 8 AWG 5.1 (45) 8 AWG; (2) Cu 10-14 AWG — 4.5 (40) Cu 10-14 AWG; Al 10-12 AWG — 4.0 (35) 250kcmil-1 AWG Cu 3/0-1 AWG 42 (375) 2-6 AWG; (2) Cu 2-6 AWG Cu 2-6 AWG 31 (275) 600 volt blocks 1 70-100 110-200 225-400 450-600 RM60100-1CR CVR-RH-60100 CVRI-RH-60100 2 RM60100-2CR 3 RM60100-3CR 1 RM60200-1CR 2 RM60200-2CR 3 RM60200-3CR 1 RM60400-1CR 600kcmil 2 RM60400-2CR 500kcmil-4 AWG 3 RM60400-3CR 1 RM60600-1CR 2 RM60600-2CR 3 RM60600-3CR CVR-RH-60200 CVR-RH-60400 CVRI-RH-60200 CVRI-RH-60400 57 (500) 51 (450) N/A (2) Cu 3/0 - 4 AWG 57 (500) (2) Al 3/0 - 4 AWG CVR-RH-60600 CVRI-RH-60600 34 (300) 2 (2) 500kcmil-4 AWG N/A 51 (450) Fuse blocks and holders * Covers sold separately, order one cover per pole. ** Open fuse indication requires 90 volts minimum and closed circuit to operate. *** Ratings for copper and aluminum conductors except where otherwise noted. Data sheet no. 10489 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-23 8 — Fuse blocks and holders HM modular 250 V and 600 V Class H(K) power distribution fuse blocks 2011/65/EU The patented 30 and 60 amp 250 V and 600 V Class H(K) power distribution fuse blocks use fewer wire connections to reduce watts loss and overall operating temperature of the panel, while simplifying panel layout. Available in ratings up to 400 amps, they use up to 57 percent less panel space while lowering inventory costs, and reducing installation time and labor by an average of 33 percent. 250 volt 60 amp modular blocks. Agency information • Blocks: UL Listed, Guide IZLT, File E14853, CSA Certified 47235 6225-01 • Covers: UL Listed, Guide JDVS, File E58836 • RoHS compliant Poles 600 volt 30 and 60 amp modular blocks. • 1-, 2-, 3-pole • Single-pole units snap together to create desired number of poles Flammability ratings All blocks are equipped with a fuse clip reinforcing spring to minimize temperature rise while maintaining reliable surface contact between the fuse and clip over the block's service life. Available as snap-together one-pole units for toolless assembly of multiple poles at point of use or factory configured 2- and 3-pole units to meet popular stocking requirements. Optional see-through cover enhances safety with IP20 finger-safe protection, lockout/tagout capability and open circuit indication. • Blocks: UL 94V0, self-extinguishing • Covers: UL 94HB, self-extinguishing Operating and storage temperature range • Blocks: -40°C to +120°C • Covers: Non-indicating -40°C to +120°C, Indicating -20°C to +90°C Conductors • 75°C Cu/Al (unless otherwise noted) DIN-Rail and panel mount versatility allows one product to be used for multiple applications without incurring additional inventory cost. Accessories Ratings • Optional IP20 finger-safe covers in indicating and non-indicating versions. Order one for each pole • DIN-Rail end stops, catalog numbers BRKT-ND or BRKT-NDSCRW2 • Volts • 250 V • 600 V • Amps up to 60 A • SCCR 10 kA RMS Sym. Available two-port lineside lug for easy daisy-chain wiring configuration Optional see-through, snap-on cover for easy visual inspection Finger grips on cover for easy removal Lockout/tagout feature improves safety Probe holes for easy testing without removing cover Standard phase barriers for additional safety Vent slots improve cooling (no fuse derating necessary) Optional open fuse indication speeds troubleshooting Toolless interlocking modular design for easy point-of-use assembly DIN-Rail or panel mounting on each pole provides installation flexibility Standard fuse clip reinforcing spring reduces temperature rise Multi-port loadside lug for power distribution to multiple branch circuit connections Ports on power distribution lugs rated for dual-wire application, increasing the number of branch circuit connections (see catalog number table for details) Marker label provision for easy circuit identification Data sheet no. 10490 8-24 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 Optional covers* Catalog no. Fuse amp range Lineside (conductors per port) Poles Conductors Ports/ pole Loadside (conductors per port) Torque AWG N•m (lb-in) 2-4 5.6 (50) 6-10 4.5 (40) Conductors Ports/ pole Torque AWG N•m (lb-in) 2-3 5.6 (50) 4-6 5.1 (45) 8 4.5 (40) 10-14 4.0 (35) Cu (1) 8 3.4 (30) Cu (1) 10-14 2.8 (25) 250 volt blocks 1 HM25060-1MW12 HM25060-2MW12 2 N/A Cu 2-14 Al 2-8 2 HM25060-3MW12 3 12-14 1.7 (15) HM25060-1MW14 1 2-3 5.6 (50) HM25060-2MW14 CVR-RH-25060 35-60 CVRI-RH-25060** HM25060-3MW14 2 Cu 2-14 Al 2-8 1 3 4-6 5.1 (45) 8 4.5 (40) 10-14 4.0 (35) HM25060-1MW24† 1 2-4 5.6 (50) HM25060-2MW24† 2 6-10 4.5 (40) 12-14 1.7 (15) N/A HM25060-3MW24 Cu 2-14 Al 2-8 2 3 † Cu 2-14 Al 2-8 1 Cu (1) 8-14 Cu (2) 12-14*** 4 Al (1) 8 Str Al (1) 10 Sol Cu (1) 8-14 Cu (2) 12-14*** 4 Al (1) 8 Str Al (1) 10 Sol Cu (2) 12-14 3.4 (30) Al (1) 8-10 3.4 (30) Cu (1) 8 3.4 (30) Cu (1) 10-14 2.8 (25) Cu (2) 12-14 3.4 (30) Al (1) 8-10 3.4 (30) 600 volt blocks HM60030-1MW14† 1 2-3 5.6 (50) HM60030-2MW14† 2 4-6 5.1 (45) 8 4.5 (40) 10-14 4.0 (35) Al (1) 8-10 3.4 (30) 2-4 5.6 (50) 2-3 5.6 (50) 6-10 4.5 (40) 4-6 5.1 (45) 8 4.5 (40) 10-14 4.0 (35) Cu (1) 8 3.4 (30) Cu (1) 10-14 2.8 (25) Cu (2) 12-14 3.4 (30) N/A up to 30 Cu 2-14 Al 2-8 1 Cu (1) 8-14 Cu (2) 12-14*** 4 Al (1) 8 Str Al (1) 10 Sol Cu (1) 8 3.4 (30) Cu (1) 10-14 2.8 (25) Cu (2) 12-14 3.4 (30) HM60030-3MW14 3 HM60060-1MW12 1 HM60060-2MW12 2 HM60060-3MW12 3 12-14 1.7 (15) HM60060-1MW14 1 2-3 5.6 (50) HM60060-2MW14 2 4-6 5.1 (45) 8 4.5 (40) 10-14 4.0 (35) Al (1) 8-10 3.4 (30) 2-4 5.6 (50) Cu (1) 8 3.4 (30) Cu (1) 10-14 2.8 (25) Cu (2) 12-14 3.4 (30) Al (1) 8-10 3.4 (30) † CVR-RH-60060 35-60 CVRI-RH-60060** HM60060-3MW14 3 HM60060-1MW24† 1 HM60060-2MW24 † HM60060-3MW24† 2 Cu 2-14 Al 2-8 Cu 2-14 Al 2-8 Cu 2-14 Al 2-8 2 1 2 3 6-10 12-14 4.5 (40) 1.7 (15) Cu 2-14 Al 2-8 1 Cu (1) 8-14 Cu (2) 12-14*** 4 Al (1) 8 Str Al (1) 10 Sol Cu (1) 8-14 Cu (2) 12-14*** 4 Al (1) 8 Str Al (1) 10 Sol Fuse blocks and holders * Order one cover per pole. ** With open fuse indication. 90 V minimum and closed circuit required for illumination. *** Dual wire rated lugs with same wire size and stranding. † Rated for use with 75°C/90°C Cu/Al conductors. Data sheet no. 10490 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-25 8 — Fuse blocks and holders RM modular 250 V and 600 V Class R power distribution fuse blocks 2011/65/EU The patented 30 and 60 amp 250 V and 600 V Class R power distribution fuse blocks use fewer wire connections to reduce watts loss and overall operating temperature of the panel, while simplifying panel layout. Available in ratings up to 400 amps, they use up to 57 percent less panel space while lowering inventory costs, and reducing installation time and labor by an average of 33 percent. High 200 kA SCCR helps achieve a higher assembly short-circuit current rating (SCCR) for compliance with NEC sections 110.10, 409.110(4), 409.22, 440.4(B), 670.3(A)(4) and 670.5. All blocks are equipped with a fuse clip reinforcing spring to minimize temperature rise while maintaining reliable surface contact between the fuse and clip over the block's service life. Available as snap-together one-pole units for toolless assembly of multiple poles at point of use or factory configured 2- and 3-pole units to meet popular stocking requirements. Agency information • Blocks; UL Listed Guide IZLT, File E14853, CSA Certified 47235 — 6225-01 • Covers; UL Listed Guide JDVS, File E58836 • RoHS compliant Poles • 1-, 2-, 3-pole • Single-pole units snap together to create desired number of poles Flammability ratings • Blocks: UL 94V0, self-extinguishing • Covers: UL 94HB, self-extinguishing Operating and storage temperature range • Blocks: -40°C to +120°C • Covers; Non-indicating -40°C to +120°C, Indicating -20°C to +90°C Conductors • 75°C Cu/Al (unless otherwise noted) Optional see-through cover enhances safety with IP20 finger-safe protection, lockout/tagout capability and open circuit indication. Accessories DIN-Rail and panel mount versatility allows one product to be used for multiple applications without incurring additional inventory cost. • Optional IP20 finger-safe covers in indicating and non-indicating versions. Order one for each pole. • DIN-Rail end stops, catalog numbers BRKT-ND or BRKT-NDSCRW2. Ratings • Volts • 250 V • 600 V • Amps up to 60 A • SCCR 200 kA RMS Sym. Available two-port lineside lug for easy daisy-chain wiring configuration Optional see-through, snap-on cover for easy visual inspection Standard phase barriers for additional safety Toolless interlocking modular design for easy point-of-use assembly Standard fuse clip reinforcing spring reduces temperature rise Multi-port loadside lug for power distribution to multiple branch circuit connections Ports on power distribution lugs rated for dual-wire application, increasing the number of branch circuit connections (see catalog number table for details) Finger grips on cover for easy removal Lockout/tagout feature improves safety Probe holes for easy testing without removing cover Vent slots improve cooling (no fuse derating necessary) Optional open fuse indication speeds troubleshooting DIN-Rail or panel mounting on each pole provides installation flexibility Marker label provision for easy circuit identification Data sheet no. 10491 8-26 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 Optional covers* Catalog no. Fuse amp range Lineside (conductors per port) Poles Conductors Ports/ pole Loadside (conductors per port) Torque AWG N•m (lb-in) Conductors Ports/ pole Torque AWG N•m (lb-in) 250 Volts RM25060-1MW12 1 2-4 5.6 (50) 2-3 5.6 (50) RM25060-2MW12 2 6-10 4.5 (40) 4-6 5.1 (45) 8 4.5 (40) 10-14 4.0 (35) Cu (1) 8 3.4 (30) Cu (1) 10-14 2.8 (25) Cu (2) 12-14 3.4 (30) Al (1) 8-10 3.4 (30) N/A Cu 2-14 Al 2-8 2 RM25060-3MW12 3 12-14 1.7 (15) RM25060-1MW14 1 2-3 5.6 (50) RM25060-2MW14 CVR-RH-25060 35 - 60 CVRI-RH-25060** RM25060-3MW14 2 Cu 2-14 Al 2-8 1 3 4-6 5.1 (45) 8 4.5 (40) 10-14 4.0 (35) † RM25060-1MW24 1 2-4 5.6 (50) RM25060-2MW24† 2 6-10 4.5 (40) 12-14 1.7 (15) N/A RM25060-3MW24 Cu 2-14 Al 2-8 2 3 † Cu 2-14 Al 2-8 1 Cu (1) 8-14 Cu (2) 12-14*** 4 Al (1) 8 Str Al (1) 10 Sol Cu (1) 8-14 Cu (2) 12-14*** 4 Al (1) 8 Str Al (1) 10 Sol Cu (1) 8 3.4 (30) Cu (1) 10-14 2.8 (25) Cu (2) 12-14 3.4 (30) Al (1) 8-10 3.4 (30) 600 Volts RM60030-1MW14† 1 2-3 5.6 (50) RM60030-2MW14† 2 4-6 5.1 (45) 8 4.5 (40) 10-14 2-4 6-10 4.5 (40) N/A up to 30 RM60030-3MW14 3 RM60060-1MW12 1 RM60060-2MW12 2 † Cu 2-14 Al 2-8 Cu 2-14 Al 2-8 1 2 3.4 (30) 2.8 (25) Cu (2) 12-14 3.4 (30) 4.0 (35) Al (1) 8-10 3.4 (30) 5.6 (50) 2-3 5.6 (50) 4-6 5.1 (45) 8 4.5 (40) 10-14 4.0 (35) Cu (1) 8 3.4 (30) Cu (1) 10-14 2.8 (25) RM60060-3MW12 3 RM60060-1MW14 1 2-3 5.6 (50) RM60060-2MW14 2 4-6 5.1 (45) 8 4.5 (40) 10-14 4.0 (35) 2-4 5.6 (50) CVR-RH-60060 35-60 CVRI-RH-60060** RM60060-3MW14 Cu 2-14 Al 2-8 1 3 RM60060-1MW24† RM60060-2MW24 † RM60060-3MW24† 1 2 Cu 2-14 Al 2-8 2 3 6-10 12-14 Cu 2-14 Al 2-8 1 1.7 (15) 4.5 (40) 1.7 (15) Cu (1) 8-14 Cu (2) 12-14*** 4 Al (1) 8 Str Al (1) 10 Sol Cu (1) 8-14 Cu (2) 12-14*** 4 Al (1) 8 Str Al (1) 10 Sol Cu (2) 12-14 3.4 (30) Al (1) 8-10 3.4 (30) Cu (1) 8 3.4 (30) Cu (1) 10-14 2.8 (25) Cu (2) 12-14 3.4 (30) Al (1) 8-10 3.4 (30) Order one cover per pole. With open fuse indication. 90 V minimum and closed circuit required for illumination. Dual wire rated lugs with same wire size and stranding. Rated for use with 75°C/90°C Cu/Al conductors. Fuse blocks and holders * ** *** † 12-14 Cu (1) 8 Cu (1) 10-14 Cu (1) 8-14 Cu (2) 12-14*** 4 Al (1) 8 Str Al (1) 10 Sol Data sheet no. 10491 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-27 8 — Fuse blocks and holders CH _ _ J _ Class J fuse holder Features The CH_J_ Class J fuse holders are available in 30 and 60 amp ratings featuring IP20 finger-safe construction that can be either DIN-Rail or panel mounted. Available as factory configured 1-, 2- or 3-pole holders they are available with optional open fuse indication to speed troubleshooting. • Choice of local fuse indication; easyID™ viewing window (for seeing indicator on LPJ-SPI indicating fuse) or neon lamp • Versatile 1-, 2- and 3-pole versions for 0-30 A and 35-60 A fuses with dual wire rated connections simplify wiring • Improved electrical safety with IP20 finger-safe construction with lock-out/tag-out feature. 3-phase fuse extraction assures all phases are opened for service work • Flexible panel/35mm DIN-Rail mounting Dimensions — mm Ratings • Volts 600 V (or less) • Amps • • 30 A • 60 A Fuse amps Up to 30 A 30 A 60 A SCCR 200 kA 35-60 A Agency information • Poles W 1 32 2 64 3 96 1 40 2 80 3 120 D H 70 115 83 125 UL Listed, Guide IZLT, File E14853, UL 4248/CSA 22.2 No. 4248.P, CE Conductors • Single 1-18 AWG and dual 3-18 AWG Cu solid and stranded conductors Terminal torque ratings • 10-18 AWG 24 lb-in • 1-8 AWG 35 lb-in Storage and operating temperature range* • -20°C to +75°C * For fuse selection on applications above or below 25ºC, consult derating charts in the Bussmann Division publication no. 3002 “Selecting Protective Devices” (SPD). Flammability rating UL 94V0 Catalog no. Without indication* With indication** Poles CH30J1 CH30J1I 1 CH30J2 CH30J2I 2 CH30J3 CH30J3I 3 CH60J1 CH60J1I 1 CH60J2 CH60J2I 2 CH60J3 CH60J3I 3 Amps Volts (AC/DC) IP20 fingersafe AWG Cu wire range Padlockable Mounting 30 600 Yes Single 1-18, dual 3-18 Yes 35mm DIN/ panel 60 600 Yes Single 1-18, dual 3-18 Yes 35mm DIN/ panel * Local fuse indication 6 amps and above possible using Bussmann series LPJ_SPI permanent indication fuses. ** Neon indication non-fuse dependent, minimum voltage 90 V. Data sheet no. 2144 8-28 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 JT(N)60030 and JT(N)60060 Safety J™ modular finger-safe Class J fuse holders Typical applications • Industrial controls The Bussmann series Safety J™ modular fuse holders are available in indicating and non-indicating versions. Finger-safe construction improves electrical safety, while modular construction permits dovetailing the required number of poles* at point of use. DIN-Rail mount provides for easy installation. 30 A version Optional open fuse indication speeds troubleshooting. • Process controls • Small horsepower VFDs Dimensions — in (mm) 60 A version 1.14 (29.0) 1.05 (26.7) Slot * JT(N)60030 cannot be dovetailed to JT(N)60060. Din-rail Ratings • Volts 600 Vac • Amps • 0.07 (1.8) MOUNTING Shown without fuse pullout cover • Up to 30 A (JT(N)60030) • 35--60 A (JT(N)60060) 1.23 (31.2) 2.42 (61.3) 2.75 (69.9) 3.60 (91.4) SCCR • 200 kA RMS Sym. • 300 kA self certified using Bussmann series LPJ_SP fuses 2.52 (64.1) Agency information • Listed to UL 4248: Guide IZLT, File 14853, CSA Certified: Class 6225-01, File 47235. IP20 per IEC 60529, CE JT(N)60030 Catalog numbers and conductor information Catalog no. Holder Non75°C Cu conductor amps indicating Indicating* size (AWG) and type 8-18 stranded, single or dual** 30 JT60030 JTN60030 10-18 solid, single or dual** 4-14 stranded or solid, 60 JT60060 JTN60060 single 8-10 stranded, dual** Terminal torque N•m (lb-in) 2.26 (20) 1.31 (33.3) 1.25 (31.8) Slot Din-rail 5.1 (45) * Indication non-fuse dependent, minimum 90 V. ** Dual wire applications must use conductors of the same size and type. 0.10 (2.6) MOUNTING Shown without fuse pullout cover 3.10 (78.7) Dimensions — in (mm) 1.52 (38.1) 2.96 (75.2) 4.40 (111.7) JT60030, JTN60030 Flammability rating: UL 94V0 Fuse blocks and holders 3.06 (77.7) Open fuse indication Min. voltage: 90 V; neon lamp “ON” when fuse opens, voltage source and current path are present. JT(N)60060 Features • 300 kA SCCR with Bussmann series LPJ_SP fuses • Rapid, flexible 35mm DIN-Rail mounting • One piece interlocking design for assembling multiple pole blocks reduces inventory costs • Removable fuse carrier allows fuse replacement away from base while maintaining finger-safe rating Data sheet no. 1152 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-29 8 — Fuse blocks and holders JP pyramid style 3-pole Class J fuse block The Bussmann series JP (pyramid) open fuse block provides a means of mounting a three-pole 30 amp Class J fuse block with a footprint that is narrower than traditional solutions. See catalog numbers for terminals and conductor information. Ratings Volts 600 V Amps 30 A SCCR 200 kA RMS Sym. Agency information • UL Listed, UL 4248, Guide IZLT, File E14853, CSA Certified, C22.2 No. 39, Class 4225-04, File 47235, CE Flammability rating UL 94V0 Mounting • Panel • 35mm DIN-Rail* * To order DIN-Rail, specify catalog number DRL35MMLO (1 meter). Catalog no. JP60030-3PR JP60030-3CR JP60030-3COR JP60030-3PRA JP60030-3CRA JP60030-3CORA Mounting Panel DIN-Rail* Yes No Yes No Yes No No Yes No Yes No Yes Terminals/AWG wire range/ type Pressure plate Box lug 10-14 Cu — — 2-14 Cu/Al — 2-14 Cu 10-14 Cu — — 2-14 Cu/Al — 2-14 Cu * Requires adapter, order catalog number JPA-3. Dimensions — in DIN-Rail mounting screw 8 inches (203mm) apart End stops prevent block movement when changing fuses 4.0 max. (101) 3.75 (95) 1.88 (48) 1.19 (30) 2.38 (60) 3.29 (84) 2.78 3.06 (71) (78) 3.13 (80) JPA-3 adaptor for symmetrical mounting on a 35mm DIN-Rail Data sheet no. 1108 8-30 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 JM modular Class J fuse blocks Ratings 2011/65/EU Class J modular fuse blocks enhance safety for any panel or electrical system design and are available for the full Class J fuse amp range. All blocks are available as single-pole versions that snap together at point of use, or as factory configured 2-, and 3-pole versions. All blocks are equipped with a fuse clip reinforcing spring to minimize temperature rise while maintaining reliable surface contact between the fuse and clip over the block's service life. • Volts 600 V • Amps up to 600 A • SCCR 200 kA RMS Sym. Agency information 30 and 60 amp blocks are DIN-Rail and panel mount. Optional covers increase safety. • Blocks; UL Listed E14853 — IZLT and IZLT7, CSA Certified 472356225-01, CE, RoHS Compliant • Covers; UL Listed E58836 - JDVS, CSA Certified 47235-6225-01 (30 and 60 A), RoHS Compliant Poles 100 to 600 amp blocks are panel mount. Optional covers increase safety. Ferrule fuse blocks up to 60 amps have the smallest width dimension on the market and feature DIN-Rail or panel mount versatility. Easy circuit identification is available for 30 and 60 amp blocks and covers with universal marker labels. Knifeblade fuse blocks from 100 to 600 amps feature phase barriers for additional safety with up to four mounting holes per pole for increased installation flexibility. All knifeblade blocks meet UL creep and clearance requirements for Industrial Power Circuits (UL 508 and UL 845). The 200 to 600 amp blocks also meet the higher UL creep and clearance requirements for Power Distribution Standards (UL 98, UL 67, UL 489, UL 891 and UL 869A) All blocks have optional IP20 finger-safe high clarity, seethrough covers for inspecting wire terminations or thermography measurements without removal. All covers enhance safety by featuring probe holes for easier, safer testing and a lockout/tagout capability. These covers also have optional open fuse indication to speed troubleshooting. Optional see-through, snap-on cover for easy visual inspection • 1-, 2-, 3-pole units factory assembled • Single-pole units snap together to create desired number of poles Flammability ratings • Blocks: UL 94V0, self-extinguishing • Covers: UL 94HB, self-extinguishing Operating and storage temperature range • Blocks -40°C to +120°C • Covers; non-indicating -40°C to +120°C, indicating -20°C to +90°C* * Indication requires minimum 90 V and closed circuit to illuminate. Conductors • See catalog numbers for details and torque specifications. Finger grips on cover for easy removal Standard phase barriers for additional safety Marker label provision for easy circuit identification (applies to 30 and 60 A blocks only) Vent slots improve cooling (no fuse derating necessary) Optional open fuse indication speeds troubleshooting Lockout/tagout feature improves safety DIN-Rail or panel mounting on each pole provides installation flexibility (DIN-Rail mounting applies to 30 and 60 A blocks only) Probe holes for easy testing without removing cover Standard fuse clip reinforcing spring reduces temperature rise Data sheet no. 10488 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-31 Fuse blocks and holders Toolless interlocking modular design for easy point-of-use assembly 8 — Fuse blocks and holders 30 and 60 amp blocks and covers Fuse amp range Catalog no./terminal type Poles Box lug/slot screw Box lug/hex screw 1 JM60030-1CR JM60030-1CHR 10-32 Phil-slot screw JM60030-1SR Pressure plate JM60030-1PR up to 30 2 JM60030-2CR JM60030-2CHR JM60030-2SR JM60030-2PR 3 JM60030-3CR JM60030-3CHR JM60030-3SR JM60030-3PR 1 JM60060-1CR JM60060-1CHR 2 3 JM60060-2CR JM60060-3CR JM60060-2CHR JM60060-3CHR — — 35 to 60 Optional covers* Indicating** Non-indicating CVRI-J-60030 CVR-J-60030 CVRI-J-60060 CVR-J-60060 * Covers sold separately, one cover per pole. ** Open fuse indication requires 90 volts minimum and closed circuit to operate. 30 and 60 amp block terminals and conductors Terminal type AWG type/range Box lug 75°C Cu 2-14, Al 2-8 10-32 Phil-slot screw 75/90°C Cu 10-18 AWG 2-3 4-6 8 10-14 Torque N•m (lb-in) 5.6 (50) 5.1 (45) 4.5 (40) 4.0 (35) 10-18 2.3 (20) Pressure plate 100 to 600 amp knifeblade blocks and covers Optional covers* Fuse amp range 70-100 110-200 225-400 450-600 Poles Catalog no. 1 JM60100-1CR 2 JM60100-2CR Non-indicating CVR-J-60100-M Conductors*** Indicating** CVRI-J-60100-M Solid and stranded Fine stranded — Cu 1-3 AWG 6.2 (55) 1/0-3 AWG; (2) Cu 4-6 AWG Cu 4-6 AWG 5.6 (50) 2 4-6 AWG; (2) Cu 8 AWG Cu 8 AWG 5.1 (45) 8 AWG; (2) Cu 10-14 AWG — 4.5 (40) 3 JM60100-3CR Cu 10-14 AWG; Al 10-12 AWG — 4.0 (35) 1 JM60200-1CR 250kcmil-1 AWG Cu 3/0-1 AWG 42 (375) 2 JM60200-2CR 3 JM60200-3CR 2-6 AWG; (2) Cu 2-6 AWG Cu 2-6 AWG 31 (275) CVR-J-60200-M CVRI-J-60200-M 1 JM60400-1CR 600kcmil 57 (500) 2 JM60400-2CR 500kcmil-4 AWG 51 (450) 3 JM60400-3CR 1 JM60400-1MW22 2 JM60400-2MW22 3 JM60400-3MW22 1 JM60600-1CR 2 JM60600-2CR 3 JM60600-3CR CVR-J-60400-M CVRI-J-60400-M (2) Cu 3/0 - 4 AWG N/A (2) Al 3/0 - 4 AWG CVR-J-60600 CVRI-J-60600 2 (2) 500kcmil-4 AWG N/A Data sheet no. 10488 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 57 (500) 34 (300) * Covers sold separately. ** Open fuse indication requires 90 volts minimum and closed circuit to operate. *** Ratings for copper and aluminum conductors except where otherwise noted. 8-32 Torque N•m (lb-in) Eaton.com/bussmannseries 51 (450) Fuse blocks and holders — 8 JM modular Class J power distribution fuse blocks The patented Class J power distribution fuse blocks use fewer wire connections to reduce watts loss and overall operating temperature of the panel, while simplifying panel layout. Available in ratings up to 400 amps, they use up to 65 percent less panel space while lowering inventory costs, and reducing installation time and labor by an average of 33 percent. All blocks are equipped with a fuse clip reinforcing spring to minimize temperature rise while maintaining reliable surface contact between the fuse and clip over the block's service life. 30 and 60 amp blocks. 100, 200 and 400 amp blocks. Ratings Amps up to 400 A SCCR 200 kA Sym. RMS Optional see-through, snap-on cover for easy visual inspection Available two-port lineside lug for easy daisy-chain wiring configuration. See catalog number table for applicable catalog numbers. Covers; UL Listed, Guide JDVS, File E58836 • RoHS compliant • 1-, 2-, 3-pole • Single-pole units snap together to create desired number of poles • 30 and 60 amp blocks DIN-Rail and panel mount • 100, 200 and 400 amp blocks panel mount only Flammability ratings All blocks are available with optional see-through cover to enhance safety with IP20 finger-safe protection, lockout/tagout capability and open circuit indication. See catalog number tables for details. • • Mounting 30 and 60 amp blocks feature DIN-Rail and panel mount versatility, while 100 to 400 amp blocks are panel mount. • Blocks; UL Listed, Guide IZLT, File E14853, CSA Certified 47235 — 6225-01 Poles The high 200 kA SCCR helps achieve a higher assembly short-circuit current rating (SCCR) for compliance with NEC sections 110.10, 409.110(4), 409.22, 440.4(B), 670.3(A)(4) and 670.5. Volts 600 V • 2011/65/EU Available as snap-together one-pole units for toolless assembly of multiple poles at point of use or factory configured 2- and 3-pole units to meet popular stocking requirements. • Agency information • Blocks, UL 94V0, self-extinguishing • Covers; UL 94HB, self-extinguishing Operating and storage temperature range • Blocks, -40°C to +120°C • Covers; non-indicating -40°C to +120°C, indicating -20°C to +90°C Conductors • 75/90°C Cu/Al (unless otherwise noted) Accessories • IP20 finger-safe covers in indicating and non-indicating versions. Order one for each pole. • DIN-Rail end stops for blocks rated up to 60 amps, catalog numbers BRKT-ND or BRKT-NDSCRW2 Finger grips on cover for easy removal Lockout/tagout feature improves safety Probe holes for easy testing without removing cover Vent slots improve cooling (no fuse derating necessary) Standard phase barriers for additional safety Toolless interlocking modular design for easy point-of-use assembly DIN-Rail or panel mounting on each pole provides installation flexibility (DIN-Rail mounting applies to 30 and 60 A blocks only) Standard fuse clip reinforcing spring reduces temperature rise Multi-port loadside lug for power distribution to multiple branch circuit connections Ports on power distribution lugs rated for dual-wire application, increasing the number of branch circuit connections (see catalog number table for details) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Marker label provision for easy circuit identification (applies to 30 and 60 A blocks only) Data sheet no. 10192 Eaton.com/bussmannseries 8-33 Fuse blocks and holders Optional open fuse indication speeds troubleshooting 8 — Fuse blocks and holders Optional covers* Catalog no. Fuse amp range Lineside (conductors per port) Poles Conductors Ports/ pole 1 JM60030-1MW14 JM60030-2MW14 N/A Up to 30 JM60030-3MW14 2 Cu 2-14 Al 2-8 1 3 Loadside (conductors per port) Torque AWG N•m (lb-in) 2-3 5.6 (50) 4-6 5.1 (45) 8 4.5 (40) 10-14 4.0 (35) Conductors Ports/ pole Cu (1) 8-14 Cu (2) 12-14*** 4 Al (1) 8 Str Al (1) 10 Sol Torque AWG N•m (lb-in) Cu (1) 8 3.4 (30) Cu (1) 10-14 2.8 (25) Cu (2) 12-14 3.4 (30) Al (1) 8-10 3.4 (30) † 1 2-4 5.6 (50) 2-3 5.6 (50) JM60060-2MW12† 2 6-10 4.5 (40) 4-6 5.1 (45) JM60060-3MW12 † 3 12-14 1.7 (15) 8 4.5 (40) 10-14 4.0 (35) JM60060-1MW14 † 1 2-3 5.6 (50) Cu (1) 8 3.4 (30) JM60060-1MW12 JM60060-2MW14 † CVR-J-60060 CVRI-J-60060** 35 - 60 2 JM60060-3MW14† 3 JM60060-1MW24 1 JM60060-2MW24 2 JM60060-3MW24 JM60100-1MW14 JM60100-2MW14 CVR-J-60100-M 70 - 100 CVRI-J-60100-M** 1 1 2 Cu 1/0-14 Al 1/0-12 Cu/Al (1) 250kcmil-6 Cu (2) 2-6 1 Al (1) 8-10 3.4 (30) 5.6 (50) Cu (1) 8 3.4 (30) JM60400-1MW16 1 JM60400-2MW16 2 4-6; Cu (2) 8 5.0 (45) 8; Cu (2) 10-14 4.5 (40) 10-14 4.0 (35) 250kcmil-1 42 (375) 2-6 31 (275) 600kcmil Cu/Al (1) 600kcmil-4 Cu/Al (2) 3/0-4 500kcmil-4 Cu (2) 3/0-4 Al (2) (3/0-4 CVR-J-60400-M 225-400 CVRI-J-60400-M** 1 2 350kcmil-1 Cu/Al 350kcmil-6 Cu (1) 10-14 2.8 (25) Cu (2) 12-14 3.4 (30) Al (1) 8-10 3.4 (30) 4-6 4.0 (35) 2.8 (25) 2.3 (20) (2) 10-14 3.4 (30) 4-6 4.0 (35) 8 2.8 (25) 10-14 2.3 (20) (2) 10-14 3.4 (30) 2-3 5.6 (50) 4-6 8 (2) 8 5.0 (45) 4.5 (40) 4.5 (40) 57 (500) 10-14 4.0 (35) 34 (300) (2) 10-14 4.5 (40) 42 (375) 2-3 4-6 8 5.6 (50) 5.0 (45) 4.5 (40) (2) 8 4.5 (40) 10-14 4.0 (35) (2) 10-14 4.5 (40) Cu (1) 4-14 Al (1) 4-8 6 Cu (2) 10-14*** 57 (500) 51 (450) 2 3 2-6 Cu (1) 4-14 Al (1) 4-8 4 Cu (2) 10-14*** Cu (2) 12-14 3.4 (30) 8 1 3 Cu (1) 8-14 Cu (2) 12-14*** 4 Al (1) 8 Str Al (1) 10 Sol Cu (1) 10-14 2.8 (25) Cu 10-14 1 3 JM60400-3MW26 4.0 (35) 2-4 1/0-3; Cu (2) 4-6 5.6 (50) JM60200-2MW16 JM60400-1MW26 JM60400-2MW26 10-14 1 JM60200-1MW16 JM60400-3MW16 4.5 (40) 1.7 (15) 2 Cu (1) 8-14 Cu (2) 12-14*** 4 Al (1) 8 Str Al (1) 10 Sol 5.1 (45) 12-14 2 1 8 3 Cu 2-14 Al 2-8 Cu 2-14 Al 2-8 4-6 4.5 (40) 3 JM60200-3MW16 Cu 2-14 Al 2-8 2 6-10 JM60100-3MW14 CVR-J-60200-M 110-200 CVRI-J-60200-M** Cu 2-14 Al 2-8 31 (275) Cu (1) 2-14 Al (1) 2-8 Cu (2) 8-14*** Cu (1) 2-14 Al (1) 2-8 Cu (2) 8-14*** 6 6 * Order one cover per pole. ** With open fuse indication. 90 V minimum and closed circuit required for illumination. *** Dual wire rated lugs with same wire size and stranding. † Rated for 75°C Cu/Al conductors. Conductors with higher ratings may be used with appropriate derating. Data sheet no. 10192 8-34 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 T300 300 volt Class T fuse blocks Dimensions — in 1.63 0.72 0.16 Bussmann series T300 fuse blocks are open fuse blocks for use with Class T fuses up to 600 amps in various pole configurations from 1- to 4-poles. T300 blocks use Bussmann series JJN fuses. 0.69 0.91 A B 1.20 X 1.63 0.72 0.16 Z 0.91 2.75 2.5 Ratings T30030-S SECTION X-X • Volts 300 V • Amps up to 600 A • SCCR 200 kA RMS Sym. T30060-C SECTION Z-Z Z 0.44 Full 0.20 Radius C Figure 1. Up to 60 A Dimensions — in Agency information Catalog no. UL Listed UL 4248, Guide IZLT, File E14853, CSA Certified, Class 6225-01, File 47235, CE Flammability rating UL 94V0 Features • Provide 1-, 2-, 3- and 4-pole housing for 300 Vac Class T fuses • High 200 kA RMS Sym. Short-Circuit Current Rating • Class T fuse blocks have a small foot print, providing substantial space savings in equipment A B T30030-2 2.41 — 1.03 T30060-2 2.41 — 1.03 T30030-3 3.44 1.03 2.06 T30060-3 3.44 1.03 2.06 T30030-4 4.47 2.06 3.09 T30060-4 4.47 2.06 3.09 1.69 (1 POLE) 3.09 (2 POLE) 4.5 (3 POLE) 2.06 1.41 (2 POLE) 2.81 (3 POLE) 0.84 Typical applications • 300 V or less control systems • 300 V or less individual control circuits C X Z 0.22 DIA Catalog numbers Catalog no./terminals Screw T30030-2SR T30030-3SR T30030-4SR T30060-2SR T30060-3SR T30060-4SR — — — — — — — Box lug T30030-2CR T30030-3CR T30030-4CR T30060-2CR T30060-3CR T30060-4CR T30100-1CR T30100-2CR T30100-3CR T30200-1C T30200-3C T30400-1C T30600-1C Amps Poles 2 Up to 30 3 4 2 31-60 3 4 1 61-100 2 3 1 101-200 3 201-400 1 401-600 1 Fig. Terminal AWG wire range/type 0.52 C'BORE 0.55 DEEP 2.25 REF 4.78 SR 10-18 Cu CR 6-14 Cu/Al 2.39 1 CR 2-14 Cu/Al SR 10-18 Cu 2 3 4 5 6 1/0-8 Cu/Al X 0.38 600kcmil-2/0 Cu/Al (2) 600kcmil-4/0 Cu/Al 0.75 Figure 2. 61 to 100 A 250kcmil-6 Cu/Al Z 6 3 0.05 1.125 1.25 1.69 Fuse blocks and holders • X 2.25 0.28 DIAMETER 0.63 C'BORE 0.5 DEEP 3.06 2.56 1.94 0.81 Figure 3. 101 to 200 A Data sheet no. 1115 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-35 8 — Fuse blocks and holders 4.87 1.695 0.996 A 2.75 A 0.282 DIAMETER THRU HOLE, 0.625 C'BORE 0.438 DEEP 2.375 0.625 4.46 Figure 4. 200 A 6 3 2.25 1.25 1.125 0.63 0.28 DIAMETER, 0.63 C'BORE 0.5" DEEP 1.84 3.06 2.38 0.81 Figure 5. 201 to 400 A 5.75 2.88 1.5 2 2.03 3 0.33 DIAMETER 0.75 C'BORE 0.5 DEEP 3.44 3 0.75 Figure 6. 401 to 600 A Data sheet no. 1115 8-36 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 T600 600 volt Class T fuse blocks Typical applications Bussmann series T600 fuse blocks are open fuse blocks for use with Class T fuses up to 600 amps in various pole configurations from 1- to 3-poles. T600 blocks use Bussmann series JJS fuses. • 600 V or less control systems • 600 V or less individual control circuits Catalog no./terminals Ratings • Volts 600 V • Amps up to 600 A • SCCR 200 kA RMS Sym. Agency information • UL Listed, UL 4248, Guide IZLT, File E14853, CSA Certified, Class 6225-01, File 47235, CE Flammability rating UL 94V0 Screw T60030-1SR T60030-2SR T60030-3SR T60060-1SR T60060-2SR T60060-3SR — — — — — — — Box lug T60030-1CR T60030-2CR T60030-3CR T60060-1CR T60060-2CR T60060-3CR T60100-1C T60100-2C T60100-3C T60200-1C 1B0089* T60400-1C T60600-1C Amps Poles 1 Up to 2 30 3 1 31-60 2 3 1 61-100 2 3 1 101-200 3 201-400 1 401-600 1 Terminal AWG Fig. range/type 1 SR 10-18 Cu CR 2-14 Cu/Al 2 SR 10-18 Cu CR 2-14 Cu/Al 3 2/0-14 Cu/Al 4 5 6 7 250kcmil-6 Cu/Al 600kcmil-2/0 Cu/Al (2) 600kcmil-4/0 Cu/Al * UL Listed, Guide IZLT, File E14853, CSA Certified Class 6225-01, File 21455M18. Features • Provide 1-, 2- and 3-pole housing for 600 Vac Class T fuses. • High 200 kA RMS Sym. Short-Circuit Current Ratings • Class T fuse blocks have a small foot print, providing substantial space savings in equipment Dimensions — in 1.44 1.44 0.55 0.5 0.33 0.55 2.59 1.16 0.33 0.55 3.75 2.31 0.33 0.22 DIAMETER, 0.5 C'BORE 0.33 3.19 1.563 1.42 1.81 1.75 0.59 0.5 0.63 0.59 3.34 1.53 0.63 0.59 4.86 3.06 Fuse blocks and holders Figure 1. Up to 30 A 0.63 0.22 DIAMETER, 0.5 C'BORE 2.94 1.63 1.47 Figure 2. 31 to 60 A Data sheet no. 1116 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-37 8 — Fuse blocks and holders Dimensions — in 1.69 (1 POLE) 3.09 (2 POLE) 4.5 (3 POLE) 1.41 (2 POLE) 2.81 (3 POLE) X Z 0.84 6 3 0.78 0.22 DIA. 0.52 C'BORE 0.55 DEEP 2.25 1.25 1.125 0.63 0.28 DIAMETER, 0.63 C'BORE 0.5 DEEP 2.34 REF 2.72 2.39 3.06 2.38 X 0.38 0.75 Z SECTION Z-Z Figure 3. 61 to 100 A 0.81 Figure 6. 201 to 400 A 3.38 3 0.05 6 6.75 1.5 23 1.125 1.25 2.25 0.3 DIAMETER, 0.75 C'BORE 0.5 DEEP 0.28 DIAMETER 0.63 C'BORE 0.5 DEEP 2.5 2.95 3.44 3.06 2.56 1.94 3 0.75 0.81 Figure 4. 101 to 200 A (T60200-1C) Figure 7. 401 to 600 A Ø0.2812 C-Bore 0.5 4.5 3.0 7.0 2.25 0.1875 7.75 Figure 5. 101 to 200 A (1B0089) Data sheet no. 1116 8-38 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 Modular open-center fuse blocks 2011/65/EU BH modular type C5268 stud type BH modular fuse blocks are for use with various blade and ferrule (cylindrical) Bussmann series high speed, and Class J and T fuses. See the data sheets referenced in the catalog number table for block/fuse compatibility. Ratings • Volts 700 V • Amps • • BH-0xxx 100 A • BH-1xxx and BH-2xxx 400 A • BH-3xxx 700 A The simpler design is the C5268 modular fuse block. With this design, the fuse terminal and cable (with termination) are mounted on the same stud, minimizing labor needed for installation. The stud type block is available in the configurations shown in the table below. Catalog no. C5268-1 C5268-2 C5268-3 C5268-4 C5268-5 Max fuse amp rating 200 100 Stud 5/16-18 x 1" 5/16-18 x 1-3/4" 5/16-18 x 3/4" 1/4-20 x 1" 1/4-20 x 1-3/4" SCCR 200 kA RMS Sym. or fuse IR, whichever is lower Agency information • UL Recognized, Guide EZLT2, File No. E14853 up to 700 V, CSA Certified, Class 6225-01, File No. 47235 up to 700 V, RoHS compliant, CE 2011/65/EU Features • A wide range of mounting configurations • High Short-Circuit Current Rating (SCCR) based upon installed fuse up to 200 kA RMS Sym. Typical applications Solid state control circuits • VFDs • UPS systems 1BS10x connector type Refer to the data sheet numbers below for the catalog code description information. Cat no. BH-0001 BH-0002 BH-0003 BH-0111 BH-0112 BH-0113 BH-0121 BH-0122 Data sheet 1200 Cat no. BH-1001 BH-1002 BH-1003 BH-1131 BH-1132 BH-1133 Data sheet 1201 Cat no. BH-2001 BH-2002 BH-2003 BH-2031 BH-2032 BH-2033 Data sheet 1202 Cat no. BH-3003 BH-3004 BH-3033 BH-3144 BH-3145 Data sheet no. 1200 (BH-0), 1201 (BH-1), 1202 (BH-2), 1203 (BH-3) Data sheet 1203 Eaton's Bussmann series also offers a modular style fuse block that utilizes a tin-plated connector for wire termination and heat dissipation) with a plated-steel stud for fuse mounting. The connector type fuse block is available in the RoHS compliant configurations shown below. Consult your Bussmann series product representative for additional product details. Catalog no. 1BS101 1BS102 1BS103 1BS104 Max rated voltage Max fuse amp rating 100 600 400 600 Data sheet no. 1206 (1BS101), 1207 (1BS102), 1208 (1BS103), 1209 (1BS104) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-39 Fuse blocks and holders • 8 — Fuse blocks and holders SD and TD blocks for NH size fuses Flammability rating 1-pole SD and 3-pole TD fuse blocks for NH fuse sizes 00 to 4 are specifically designed for use with Bussmann series bladed NH fuses. See data sheet 720109 (690 V gG/gL) and 10164 (500 V gG/gL). • 2011/65/EU UL 94V0 Catalog no. Poles SD00-D 1 TD00-D 3 TD00-DI* For NH 1 to 3 photovoltaic fuse applications, see the single-pole SD-PV blocks in the PV fuse section. SD1-D 1 TD1-D 3 SD2-D 1 Ratings TD2-D 3 SD3-D 1 TD3-D 3 • Volts • 690 Vac • 1000 Vac (Sd1-D only) • Amps 160 to 1600 A • SCCR up to 120 kA SD4-D Shown with optional shroud kit Agency information • IEC 60269-1 and 2 • VDE 0636-1 and 2 • RoHS compliant Poles • • NH fuse block 1 SD4-S1600** NH fuse size Amps 000 and 00 160 1 250 2 400 3 630 1 and 3 IEC - IP20 with shroud kit installed and shielding of any exposed terminal lugs UL - Installation of shroud kit decreases the likelihood of incidental terminal contact. To ensure compliance to IP20 specifications per UL the installer must make additional provisions. Temperature range Accessories Fuse extraction handle Catalog no. Size Amps FEH NH00 to 3 160 to 630 Catalog no.† Fuse block Fuse size Amps SD12-SK SD1/TD1 NH1 250 SD12-SK SD2/TD2 NH2 400 SD3-SK SD3/TD3 NH3 630 Catalog no.†† Fuse block Fuse size Amps SD00-PB SD00/TD00 NH00 160 SD12-PB SD1/TD1 NH1 250 Storage -40°C to +80°C SD12-PB SD2/TD2 NH2 400 SD3-PB SD3/TD3 NH3 630 35mm DIN-Rail Panel Includes 2 shrouds and 1 fuse cover Phase barrier kits Operating -20°C to +70°C Mounting Description † Order one kit per pole. • • 1600 * 3-pole integral base molding. ** Panel mount only. • • 1250 4 Shroud kits Protection level • Description Description 2 phase barriers and 2 ganging links †† Order one kit per 3-pole assembly. Microswitches Catalog no. Ratings BVL50 6 A 250 Vac 170H0236 2 A 250 Vac 170H0238 2 A 250 Vac Neutral links Catalog no. Fuse size Amps SDL-00 NH00 160 SDL-1 NH1 250 SDL-2 NH2 400 SDL-3 NH3 630 Data sheet no. 10163 8-40 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 HTB panel mount fuse holders for 5x20mm and 1/4" x 1-1/4" fuses Panel mount holders with knobtype and screwdriver-type carriers made from high temperature, flame retardant thermoplastic (UL 94V0) and tin-plated brass quick-connect terminals. Knob-type fuse carrier Volts 250 V 2011/65/EU Amps 20 A max* • Insulation resistance (per IEC #257) 10,000 ohms @ 500 Vdc • Contact resistance (per IEC #257) 0.005 ohms max @ 1 A • Standoff voltage (per IEC #257) 480 V/Mil @ 0.125” thickness Catalog numbers and dimensions — in (mm) Solder / 3/16" QC terminal Holder dimensions 0.34 (8.7) In-line • UL Recognized, Guide IZLT2, File E14853, 1/4" dia. fuse @ 20 A, 5mm dia. fuse @16 A @ 250 V, CSA Class 6225-01 File 47235 @ 16 A @ 250 V, VDE Certified, 136128, HTB-XXM, SEMKO Certification, Ref. 0146149/01, HTB-XXM, RoHS compliant, CE 0.33 (8.3) -55°C to +85°C Mounting • Rear hex nut; HTB-2_, HTB3_, HTB-4_, HTB-5_ • Front hex nut; HTB-6_ • Snap-in; HTB-8_, HTB-9_ Splash-proof versions • * See data sheet 2119 for ratings by holder configuration. Max panel thickness — in (mm) • Operating temperature range Screwdriver-type fuse carrier Ratings* Agency information Splash-proof versions available by adding "-SP" suffix to the catalog number. 1/4" QC terminal 0.47 (11.9) Fuse carrier* 0.45 (11.5) Rt. angle In-line Rt. angle HTB-22I-R HTB-24I-R HTB-26I-R HTB-28I-R HTB-22M-R HTB-24M-R HTB-26M-R HTB-28M-R HTB-42I-R HTB-44I-R HTB-46I-R HTB-48I-R HTB-42M-R HTB-44M-R HTB-46M-R HTB-48M-R HTB-62I-R HTB-64I-R HTB-66I-R HTB-68I-R HTB-62M-R HTB-64M-R HTB-66M-R HTB-68M-R HTB-82I-R HTB-84I-R HTB-86I-R HTB-88I-R HTB-82M-R HTB-84M-R HTB-86M-R HTB-88M-R 1/4" I = inches 5mm M = metric Knob-type carrier — common length 1.69 (43) 0.47 (11.9) 1.125 (28.6) X 0.3 (8) 0.09 NOM. X (2.4) 0.69 0.91 (17.5) (23.0) X 0.125 (3) 0.67 (17.1) 0.92 (23.4) X X 0.3 (8) 0.47 (11.9) 1.125 (28.6) X X 0.125 (3) X 0.17 (4.37) 1.58 (40.03) HTB-32I-R HTB-34I-R HTB-36I-R HTB-38I-R HTB-32M-R HTB-34M-R HTB-36M-R HTB-38M-R HTB-52I-R HTB-54I-R HTB-56I-R HTB-58I-R HTB-52M-R HTB-54M-R HTB-56M-R HTB-58M-R HTB-92I-R HTB-94I-R HTB-96I-R HTB-98I-R HTB-92M-R HTB-94M-R HTB-96M-R HTB-98M-R X 0.3 (8) 0.41 (10.31) 1.34 (34.13) X X 0.125 (3) 0.17 (4.37) 1.59 (40.08) X X 0.125 (3) X * Fuse carriers may be ordered separately. Specify "FT" for knob-type or "ST" for screwdriver type, followed by "-I" for 1/4" fuses and "-M" for 5mm fuses. Data sheet no. 2119 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-41 Fuse blocks and holders Screwdriver-type carrier — common length 1.75 (45) 8 — Fuse blocks and holders HJL panel mount neon lamp indicating holder for 1/4" x 1" fuses Ratings • Volts 250 V • Amps 15 A Vibration resistant bayonet-type knob holders for panels up to 5/16" thick. HKP, HKP-L, HKP-W Ratings 2011/65/EU • Volts 250 V Amps up to 30 A* Catalog no.* Volts Lamp color Knob type • HJL 90 to 250 Clear Octagonal * See data sheet 2106 for ratings by specific holder. * Use with AGX, MKB, TCP70 and TDC fuses, for panels up to 1/8" thick. Agency information Dimensions — in (mm) 1.19 2.81 (71) (30) • Punched mounting hole 0.63 0.81 (16) (21) Octagonal sides 0.590 (15) Data sheet no. 2121 HK panel mount neon and incandescent lamp indicating holders for 1/4" x 1" fuses Ratings • Volts 250 V • Amps HKP-BBHH, HKP-HH, HKP-LW-HH HKP-OO UL Recognized Guide IZLT2, File E14853, CSA Certified, Class 6225-01, File 47235, CE (HKP, HKP-L, HKP-W, HKP-OO), RoHS compliant Catalog no. Description HKP-R Standard fuse holder HKP-L-R HKP with 2250 V stand-off barrier HKP-W-R HKP with drip-proof knob HKP-BBHH-R HKP with 1/4" quick-connects, nut and washer assembled. HKP-HH-R HKP with 1/4" quick-connect. HKP-LW-HH-R HKP with drip-proof knob, 2250 V stand-off barrier and 1/4" quick-connects. HKP-OO-R HKP with snap-lock Replacement parts • 15 A (HKL, HKL-X) • 20 A (HKR, HKT, HKU, HKX) Agency information • HKP panel mount holders for 1/4" x 1-1/4" fuses UL Recognized, Guide IZLT2, File E14853), CSA Certified Class 6225-01, File 47235, CE Catalog no. Lamp volts Knob color/type HKL* 90-250 Clear/octagonal HKL-X* 90-250 Clear/flat side HKR** 22-30 Amber/octagonal HKT** 13-22 Amber/octagonal HKU** 4-6 Red/octagonal HKX** 22-33 Amber/flat side Catalog no. Description 9435-1/2 Cap BK/1A4287 Plastic nut (100 pieces minimum) BK/1A4806-2 Metal nut (100 pieces minimum) 9732 Washer Dimensions — in (mm) HKP-R, HKP-L-R, HKP-W-R * Neon lamp UL Recognized and CSA Certified. ** Incandescent lamp. Dimensions — in (mm) 2.81 1.19 (30) (71) Punched mounting hole HKP-BBHH-R, HKP-HH-R, HKP-LW-HH-R 0.75 Flat sides 0.81 (19) 0.630 (21) FU F USE (15) Octagonal sides HKP-OO-R Data sheet no. 2105 SE F E US 0.573 8-42 1.56 (40) Punched mounting hole (16) 0.855 1.17 0.89 (23) (22) 0.8 (20) 0.81 (21) Data sheet no. 2106 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 HLD panel mount holders for 1/4" x 1-1/4" pin indicating fuses HPF panel mount holders with screw-type knobs for 13/32" x 1-5/16" to 1-1/2" fuses Ratings Ratings* • Volts 250 V • Volts up to 600 V • Amps 15 A • Amps up to 30 A * See catalog numbers for ratings by specific holder. Agency information • UL Recognized, Guide IZLT2, File E14853, CE Agency information • Catalog no.* Terminals HLD Solder terminals HLD-HH 1/4" quick-connect terminals * Use with GBA or GLD fuses. Dimensions — in (mm) • Punched mounting hole Washer (22) 0.69 0.505 (18) (16) 0.473 2.75 Max. (HLD-HH) (12) (70 Max.) Data sheet no. 2120 HPC-D flange panel mount, solder terminal 10 AWG max holder with screw-type knob for 13/32" x 1-1/2" fuses. Supplied with O-ring and panel gasket Ratings • Flammability rating: UL 94HB Terminals 2.5 Max. (HLD) (64 Max.) 0.86 Octagonal sides UL Recognized, Guide IZLT2, File E14853; CSA Certified, Class 6225-01, File 47235, CE Combination 1/4" quick-connect/solder** terminals ** Solder terminal 10 AWG wire max. Catalog no. HPF HPF-C HPF-L HPF-EE HPF-JJ HPF-FF1 HPF-RR HPF-WT Amps 302 303 5 15 20 302 302 302 Volts (AC) Fuse/description/length 600 1-1/2" (38mm) 6003 Clear knob 1-1/2" (38mm) 600 BBS, 1-3/8" fuses. 600 SC Class G up to 15 A, 1-5/16" 600 SC Class G 20 A, 1-13/32" 480 SC Class G 25 and 30 A, 1-5/8" 600 FNQ-R, KTK-R, LP-CC, Class CC 600 Splash-proof knob. 1-1/2" (38mm) 1 Not CSA Certified. 2 20 A max when used with quick-connect terminals. 3 HPF-C ratings for CSA: 15 A, 250 V. Dimensions — in (mm) 600 V, 30 A* With fuse 2.81 Max. * 20 A max when used with quickconnect terminals. (71) Agency information FU E FUS • USE SE F UL Recognized, Guide IZLT2, File E14853, CE Flammability rating: UL 94HB 1.0 1.31 1.78 (25) (33) (45) Ø 0.180 1.125 (29) Catalog no. Description HPC-D Flange mount in panels up to 1/4" thick. BK/9987SA Replacement knob, bulk only, 50 pieces (5) 0.88 (22) 2.69 Max. (68) Without fuse 0.250 (6) (Typ.2) 1.120 Fuse blocks and holders Dimensions — in (mm) 0.88 (30.5) (22.2) 1.775 (45.1) With fuse 0.180 2.48 (63.1) (4.6) 0.187 (4.75) 1.031 0.89 (26.2) Mounting hole 1.312 (33.3) rear of panel (22.6) 1.312 (33.3) front of panel Data sheet no. 2109 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Data sheet no. 2114 Eaton.com/bussmannseries 8-43 8 — Fuse blocks and holders HPD and HPG panel mount bayonet-type knob holders for 13/32" x 1-1/2" fuses Ratings Ratings • Volts 600 V • Amps Volts 600 V Amps 30 A* • 30 A • 15 A (Class G only) * 20 A max when used with quickconnect terminals. HPD Agency information Agency information • • UL Recognized, Guide IZLT2, File E14853, CE Flammability ratings • • HPM panel mount holders with screw-type knob for 13/32" x 1-1/2" fuses. Flammability rating: UL 94HB HPG, HPG-EE Body UL 94V0 Knob UL 94HB Catalog no. HPD* HPG** HPG-EE** Amps Volts (AC) 301 600 15 UL Recognized, Guide IZLT2, File E14853; CSA Certified, Class 6225-01, File 47235, CE Fuse/description/length Catalog no. Description HPM 1/4" quick-connect/solder HPM-D Splash-resistant knob** BK/9789-Y2 Replacement knob, bulk only, 50 pieces ** HPM-D has 1/4" quick-connect/solder terminal on rear (load) terminal only. The side (line) terminal is 1/4" quick-connect only. 1-1/2" (38mm) SC Class G up to 15 A, 1-5/16" * HPD has combination 1/4" quick-connect/solder terminal on loadside (side) terminal only. Lineside (rear) terminal is 3/16" shorter than and is solder only. ** HPG and HPG-EE has combination 1/4" quick-connect/solder terminals on both side (load) and rear (line) terminals. 1 20 A max when used with quick-connect terminals. Nut torque: • 30 lb-in. Dimensions — in (mm) With fuse 2.73 (69.5) Dimensions — in (mm) 0.94 (23.8) 1.41 (30.6) 2.594 (65.89) HPD Without fuse 0.250 2.81 0.88 (22) 1.125 (28.6) (6.35) (71) Punched mounting hole 0.88 (22) 0.815 (21) HPG, HPG-EE Data sheet no. 2108 8-44 Data sheet no. 2112 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 HPS panel mount bayonet-type knob holders for 13/32" x 1-5/16" to 1-1/2" fuses Ratings* • Volts up to 600 V • Amps up to 30 A For fuse size 13/32" x 1-1/2", meeting UL 1598 requirement that both poles be removed simultaneously. * See catalog numbers for ratings by specific holder. Agency information • Ratings UL Recognized, Guide IZLT2, File E14853; CSA Certified, Class 6225-01, File 47235, CE Flammability rating: UL 94HB Volts 600 V Amps 30 A* * 20 A max when used with quick-connect terminals. Agency information Terminals • HPS2 panel mount, 1/4" quick-connect/solder terminal (10 AWG max) holder with screw-type knob for 13/32" x 1-1/2" fuses. Supplied with O-ring and panel gasket • Combination 1/4" quick-connect/solder terminals. Catalog no. HPS HPS-L HPS-EE* HPS-JJ* Amps 301 2 5 15 20 Volts (AC) 600 600 600 600 HPS-F-EE† 15 600 HPS-FF*† HPS-RR*† 301 301 480 600 Fuse/description/length 1-1/2" (38mm) BBS, 1-3/8" SC Class G up to 15 A , 1-5/16" SC Class G 20 A, 1-13/32" Sleeve on body, leaded for 1-5/16" fuses SC Class G 25 and 30 A, 1-5/8" FNQ-R KTK-R, LP-CC Class CC UL 4248 Recognized, Guide IZLT2, File E14853, CSA certified Class 6225-01, File 47235 Flammability rating: UL 94V0 Terminals: 1/4” quick-connect/solder. Catalog no. Description HPS2 Standard 10-in carton BK/HPS2 Bulk 100-in carton Dimensions — in (mm) * -EE, -JJ, -FF and -RR suffix versions are UL Recognized for applications requiring branch circuit protection. † Not CSA Certified. 1 20 A max when used with quick-connect terminals. 2 HPS rated at 250 V for CSA. Dimensions — in (mm) With fuse 2.81 0.88 (71) (22) 0.250 (6) (Typ.2) 1.78 (45) 0.180 (5) (29) 0.80 (20) 2.41 (64) Without fuse Fuse blocks and holders 1.125 Data sheet no. 2113 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Data sheet no. 2140 Eaton.com/bussmannseries 8-45 8 — Fuse blocks and holders HHT in-line fuse holder for 5x15mm to 20mm fuses HFA in-line water-resistant holders for 1/4" x 1-1/4" fuses The HHT features a black thermoplastic body with brass contacts and 13 inch red AWG 16 leads. The HFA is a waterproof, crimp or quick-connect terminal holder for exposed locations made of high temperature, flame retardant phenolic material meeting UL 94 HB. Recommended crimp tools include Thomas & Betts WT-112M or ERG-2002 and Channelock No. 909. Ratings • • Volts • 250 Vac • 32 Vdc Ratings Amps • 5 A (5x15mm fuses) • 10 A (5x20mm fuses) • Volts 250 V • Amps 20 A max. Agency information Catalog no. • Fuse size (mm) HHT (100-in) 5x15 and 5x20 BK/HHT (1000-in) UL Recognized, Guide IZLT2, File E14853 using AWG 12 copper conductors Catalog no. Terminals/AWG HFA (10-in) Dimensions — in HFA-R (10-in, RoHS compliant) 0.25 Crimp/12-16 BK/HFA-R (20-in, RoHS compliant) 6.181 0.99 0.88 6.063 HFA-HH* (10-in) HFA-HH-R* (10-in, RoHS compliant WIRE LENGTH: 13 1/4" quick-connect BK/HFA-HH-R* (20-in, RoHS compliant 0.42 DIA. 1.87 Data sheet no. 2138 8-46 * Not UL Recognized. Dimensions — in Data sheet no. 2115 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 HFB and HFB-10 in-line holders for 1/4" x 7/8" to 1-1/4" fuses HHB universal in-line holders for 1/4" x 7/8", 1" and 1-1/4" fuses Water-resistant in-line fuse holder for 1/4" x 1-1/4" fuses made of a thermoplastic rubber body with tin-plated, copper contacts. Universal in-line fuse holder for 1/4" diameter fuses in lengths from 7/8" to 1-1/4" made of a nylon body with tin-plated, copper contacts. Ratings Ratings • Volts 32 V • Volts 32 V • Amps 30 A max. • Amps 30 A max. Catalog no. Description Catalog no. HFB-R* Standard pack (10-in) Holder without leads* Description BK/HFB-R* Bulk pack (100-in) HHB-R** Standard pack (10-in) HFB-10-R** Standard pack (10-in) BK/HHB-R** Bulk pack (1000-in) BK/1A2294 HFB replacement contact clip Holder with pre-attached 14 AWG insulated lead wires 1A2294-01 HFB-10** replacement contact clip BK/HHB-Y408 8" yellow leads (1000-in) * HFB-R accepts #12 to #18 wire leads (not provided). See data sheet 2102 for recommended crimp tools. ** HFB-10-R accepts #10 wire leads (not provided). See data sheet 2102 for recommended crimp tools. BK/HHB-R408** 8" red leads (1000-in) BK/HHB-B408 8" black leads (1000-in) BK/HHB-Y419 19" yellow leads (1000-in) Features BK/HHB-R419 19" red leads (1000-in) BK/HHB-B419 19" black leads (1000-in) • Simple assembly with one-piece thermoplastic (important information molded into body) • High visibility yellow color for easy identification in dark or hard-toaccess locations • Ideal for shock and vibration environments; withstands many organic solvents; temperature range -40°C to +150°C Typical applications * Accepts #12 to #16 wire leads (not provided with basic fuse holder). See data sheet 2103 for recommended crimp tools. ** RoHS compliant. Flammability rating: UL 94V2 Pull force • • Supplemental, low voltage, low amperage control circuits Dimensions — in (mm) Features • 3 (76.2) 5 lbs minimum to separate fuse holder housing with fuse installed Universal application for 1/4" x 7/8", 1" and 1-1/4" fuses Typical applications • 0.75 (19.1) Supplemental, low voltage, low amperage control circuits Dimensions — in (mm) L 0.53 Data sheet no. 2102 Fuse length Fuse Max. holder length “L” 7/8" AWG 2.10 1" AGX 2.25 1-1/4" ABC, AGC, GBB, MDA, MDL, MDQ 2.42 Data sheet no. 2103 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-47 Fuse blocks and holders (13.5) 8 — Fuse blocks and holders HRK Universal in-line holder for 1/4" x 7/8" to 1-1/4" fuses HM, HR and HH in-line holders HM and HR in-line fuse holders feature 8 and 19 inch 14 AWG length leads with a size-rejecting SFE fuse. Also accommodates various length 1/4" diameter fuses from 5/8" to 1-1/4". Universal in-line fuse holder with 8" (203mm) 14 AWG lead wires for 1/4" diameter fuses in lengths from 7/8" to 1-1/4". Ratings 2011/65/EU Ratings • Volts 32 V • Amps 20 A max. Lead length (in) • Volts 32 V • Amps 15 A max. Fuse length (in) Catalog no. Included SFE fuse HMJ* SFE-20 1-1/4 HMI SFE-14 1-1/16 HMH SFE-9 7/8 HME SFE-7-1/2 HMG SFE-6 3/4 HMF SFE-4 5/8 * Three springs furnished with fuse holder to accommodate different length 1/4" fuses. Features 8 Catalog no. HRK-R* 7/8 HRJ** SFE-20 1-1/4 HRI SFE-14 1-1/16 HRH SFE-9 HRE SFE-7-1/2 7/8 19 7/8 Accepts fuse length Fuse 7/8" AWG 1" AGX 1-1/4" ABC, AGC, GBB, MDA, MDL, MDQ • Universal application for 1/4" x 7/8", 1" and 1-1/4" fuses • 14 AWG lead wires simplify electrical connection. RoHS compliant HRG SFE-6 3/4 • HRF SFE-4 5/8 Typical applications * Also available as in-line fuse holder only with lead wire contacts, HMJ-LESS-fuse. ** Also available as in-line fuse holder only with lead wire contacts, HRJ-LESS-fuse. Catalog no. HHJ-A HHJ-B HHI-A HHI-B Fuse length (in) 1-1/4 1-1/16 Holder description No wire or fuse included AWG wire range Max amps 18-22 10 12-16 30 18-22 10 12-16 30 • Supplemental, low voltage, low amperage control circuits Dimensions — in (mm) 2.19 (55.6) 0.75 (19.1) 0.69 (17.5) Replacement contacts 1.56 (39.7) Contact catalog no. For holder catalog no. 9838 HHJ-A and HHI-A 9841 HHJ-B and HHI-B Features • Universal application for SFE and various length 1/4" diameter fuses. • 14 AWG lead wires simplify electrical connection. Typical applications • Supplemental, low voltage, low amperage control circuits Dimensions — in (mm) 2.19 (55.6) 0.75 (19.1) 0.69 (17.5) 1.56 (39.7) Data sheet no. 2122 8-48 0.38 (9.5) Data sheet no. 2111 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 0.38 (9.5) Fuse blocks and holders — 8 HEC, HEG, HEH and HEJ† single-pole Class G fuse non-breakaway in-line holders Class G size-rejecting non-breakaway submersible, single-pole in-line fuse holders available with many terminal options to meet application needs. Optional insulating boots provide additional protection from dust and moisture ingress (order separately). The HEC is also available in a breakaway version. † HEJ holders are not RoHS compliant. 2011/65/EU Ratings* Recommended crimping tools This list is not intended to exclude the use of other crimping tools that can provide similar crimps or indents. Terminal code T & B P/N (Die) Terminal code T & B P/N (Die) WT-111M (C) A TBM5 (Brown) Sta-Kon ERG4002 (C) B D WT-115A (D) TBM5 (Grey) C WT-115A (E) N, P, Q, R, T TBM8 (Brown) WT-115A (F) Z WT-111M (A) Sta-Kon ERG4002 (A) TBM8 (Orange) Volts up to 600 V Amps up to 60 A HET neutral SCCR 200 kA RMS Sym. The HET holder is a single-pole in-line holder with a permanent, solid neutral for use along with the Class G in-line holders to provide a means of conductor continuity. The HET holder is identified by a white, plastic coupling nut. Available HET holder counterparts to their Class G holder equivalents are listed in the following catalog number tables. See data sheet no. 2125 for details on the HET holder. * Dependant upon fuse and conductor rating. Insulating boots Insulating boots are not included. Two insulating boots must be ordered separately, if required, for each holder ordered. When insulating boots are utilized, extra heat retention requires that fuses are sized at a minimum of 200 percent of the RMS load current. To order insulating boots for Class G holders, use these catalog numbers. Catalog no. Description 2A0660 Single conductor 2A0661 Dual conductor HEG HEH • 600 V • 600 V • 15 A • 20 A HEC breakaway Class G fuse in-line holder The HEC breakaway holder includes insulating boots. HEJ • 480 V • 480 V • 25-30 A • 35-60 A Amps Catalog no. Line and load terminal AWG 25-30 HEC-RW-RLB-R Al crimp 1-2 str. Fuse blocks and holders HEC Data sheet no. 2123 (HEJ), 2124 (HEC, HEG, HEH) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-49 8 — Fuse blocks and holders Non-breakaway catalog number system Loadside terminal Lineside terminal 15 Catalog symbol Amps HE_ - A A HEG A A 20 HEH A 25-30 HEC A A 35-60 HEJ Loadside terminal Lineside terminal Terminal type AWG Wire range* Terminal type AWG wire range* HET neutral equivalent Cu crimp 8-16; (2) 12-16 Cu crimp 8-16; (2) 12-16 HET-AA A Cu crimp 8-16; (2) 12-16 Cu crimp 8-16; (2) 12-16 HET-AA D Cu crimp 8-16; (2) 12-16 Cu crimp 2 str; (2) 6 — A Cu crimp 8-16; (2) 12-16 Cu crimp 8-16; (2) 12-16 HET-AA A Cu crimp 8-16; (2) 12-16 Cu crimp 8-16; (2) 12-16 HET-AA B Cu crimp 8-16; (2) 12-16 Cu crimp 6; (2) 10 HET-AB B B Cu crimp 6; (2) 10 Cu crimp 6; (2) 10 HET-BB C C Cu crimp 4 str; (2) 8 Cu crimp 4 str; (2) 8 — D D Cu crimp 2 str; (2) 6 Cu crimp 2 str; (2) 6 — J Cu setscrew 3-12 Cu setscrew 3-12 HET-JJ K Cu setscrew 3-12 Cu dual setscrew 2-12† HET-JK Al setscrew 2-12 Al setscrew 2-12 — J L L LB†† P P Al crimp 4 sol; 6 str Al crimp 4 sol; 6 str — Q Q Al crimp 2 sol; 3-4 str Al crimp 2 sol; 3-4 str — W W Cu solid - Cu solid - — * Solid/stranded conductors unless otherwise noted. † Not dual wire rated. One wire per opening. †† Same as catalog number as HEJ-LL, but packaged with two 2A0660 single conductor insulating boots. To order: specify catalog symbol and the loadside terminal code. Then select a lineside terminal code that is available with the loadside terminal. Example: HEJ-BB defines a non-breakaway holder with a loadside copper crimp terminal for a single #6 or two #10 wires with a lineside copper crimp terminal for a single #6 or two #10 wires. Data sheet no. 2123 (HEJ), 2124 (HEC, HEG, HEH) 8-50 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 Insulating boots HEB single-pole breakaway and non-breakaway in-line holders for 13/32" x 1-1/2" supplemental fuses Two insulating boots come standard with the breakaway holder configurations. Insulating boots are not included as standard with non-breakaway holders. Two insulating boots must be ordered separately, if required, for each non-breakaway holder ordered. When insulating boots are utilized, extra heat retention requires that fuses are sized at a minimum of 200 percent of the RMS load current. 2011/65/EU Breakaway and non-breakaway submersible, single-pole in-line fuse holders available with many terminal options to meet application needs. Breakaway versions come with insulating boots to provide submersibility per UL IP67. Nonbreakaway versions require ordering optional insulating boots for submersibility. To order insulating boots for a non-breakaway HEB holder, use these catalog numbers. Ratings Catalog no. Description 2A0660 Single conductor 2A0661 Dual conductor Recommended crimping tools Volts 600 V This list is not intended to exclude the use of other crimping tools that can provide similar crimps or indents. Amps up to 30 A limited by conductor size SCCR 200 kA RMS Sym.* Terminal code T & B P/N (Die) * Dependant upon fuse interrupting rating. A Agency information Terminal code WT-111M (C) TBM5 (Brown) Sta-Kon ERG4002 (C) B D TBM8 (Brown) WT-115A (D) UL Recognized, Guide IZLT2, File E14853, CSA Certified, Class 622501, File 47235, CE, RoHS compliant** C ** See data sheet 2127 for exceptions. N, P, Q, R, T TBM5 (Grey) WT-115A (E) T & B P/N (Die) WT-115A (F) WT-111M (A) Z Sta-Kon ERG4002 (A) TBM8 (Orange) HET neutral The HET holder is a single-pole in-line holder with a permanent, solid neutral for use along with the HEB holder to provide a means of conductor continuity. The HET holder is identified by a white, plastic coupling nut. Available HET holder counterparts to their HEB equivalents are listed in the following catalog number tables. See data sheet no. 2125 for details on the HET holder. A HEB B J K L Lineside terminal Loadside terminal Catalog symbol HEB - A W - RYC Agency Information Loadside terminal Lineside terminal AWG wire range* HET neutral equivalent Cu crimp 8-16; (2) 12-16 Str/Sol HET-AW-RLC-A Cu crimp 6; (2) 10 HET-AW-RLC-B 8-16; (2) 12-16 Str/Sol Cu crimp 4; (2) 8 HET-AW-RLC-C Cu crimp 8-16; (2) 12-16 Str/Sol Cu setscrew 3-12 Str; 10-12 Sol HET-AW-RLC-J X Cu crimp 8-16; (2) 12-16 Str/Sol Cu dual setscrew 2-12† Str; 10-12 Sol† HET-AW-RYC — — Cu crimp 8-16; (2) 12-16 Str/Sol Al setscrew 2-12 — RYA — — Cu crimp 8-16; (2) 12-16 Str/Sol Al dual setscrew 2-12† — RLC-A X X Cu crimp 6; (2) 10 Cu crimp 8-16; (2) 12-16 — RLC-B X X Cu crimp 6; (2) 10 Cu crimp 6; (2) 10 HET-BW-RLC-B RYC X X Cu crimp Cu dual setscrew 2-12† Str; 10-12 Sol† — RLC-J X X Cu setscrew 3-12 Str; 10-12 Sol Cu setscrew 3-12 Str; 10-12 Sol HET-JW-RLC-J RYC X X Cu setscrew 3-12 Str; 10-12 Sol Cu dual setscrew 2-12† Str; 10-12 Sol† HET-JW-RYC RLC-J X — Cu dual setscrew 2-12 Str ; 10-12 Sol Cu setscrew 3-12 Str; 10-12 Sol — RYC X — Cu dual setscrew 2-12 Str†; 10-12 Sol† Cu dual setscrew 2-12† Str; 10-12 Sol† — UL CSA Terminal type AWG wire range* RLC-A X X Cu crimp 8-16; (2) 12-16 Str/Sol RLC-B X X Cu crimp 8-16; (2) 12-16 Str/Sol RLC-C X X Cu crimp RLC-J X X RYC X RLA 6; (2) 10 † † Terminal type RLA — — Al setscrew 2-12 Al setscrew 2-12 — RLC-J — — Al setscrew 2-12 Cu setscrew 3-12 — RYA — — Al setscrew 2-12 Al dual setscrew 2-12† — * Stranded conductors unless otherwise noted. † Not dual wire rated. One wire per opening. To order: specify catalog symbol HEB and the loadside terminal code plus the letter “W.” Then select a lineside terminal code that is available with the loadside terminal. Example: HEB-BW-RCL-B defines a breakaway holder with a loadside copper crimp terminal for a single #6 or two #10 wires with a lineside copper crimp terminal for a single #6 or two #10 wires. Data sheet no. 2127 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-51 Fuse blocks and holders Breakaway catalog number system 8 — Fuse blocks and holders Non-breakaway catalog number system A B HEB Lineside terminal Loadside terminal Catalog symbol HEB - A A Agency information Loadside terminal Lineside terminal AWG wire range* HET neutral equivalent Cu crimp 8-16; (2) 12-16 Str/Sol HET-AA Cu crimp 6; (2) 10 HET-AB 8-16; (2) 12-16 Str/Sol Cu crimp 4; (2) 8 — Cu crimp 8-16; (2) 12-16 Str/Sol Cu crimp 2; (2) 6 — UL CSA Terminal type AWG Wire range* A X X Cu crimp 8-16; (2) 12-16 Str/Sol B X X Cu crimp 8-16; (2) 12-16 Str/Sol C†† X X Cu crimp D†† X X Terminal type J X X Cu crimp 8-16; (2) 12-16 Str/Sol Cu setscrew K X X Cu crimp 8-16; (2) 12-16 Str/Sol Cu dual setscrew 3-12 Str; 10-12 Sol — 2-12† Str; 10-12 Sol† — R — — Cu crimp 8-16; (2) 12-16 Str/Sol L — — Cu crimp 8-16; (2) 12-16 Str/Sol Al crimp 1-2 — Al setscrew 2-12 W — — Cu crimp 8-16; (2) 12-16 Str/Sol Cu solid — — HET-AW Al dual setscrew 2-12† — Y — — Cu crimp 8-16; (2) 12-16 Str/Sol A X X Cu crimp 6; (2) 10 Cu crimp 8-16; (2) 12-16 Str/Sol — B X X Cu crimp 6; (2) 10 Cu crimp 6; (2) 10 HET-BB C X X Cu crimp 6; (2) 10 Cu crimp 4; (2) 8 — D†† X X Cu crimp 6; (2) 10 Cu crimp 2; (2) 6 — W — — Cu crimp 6; (2) 10 Cu solid — — C C†† X X Cu crimp 4; (2) 8 Cu crimp 4; (2) 8 — D D X X Cu crimp 2; (2) 6 Cu crimp 2; (2) 6 — Z A — — Cu crimp 18-20 Cu crimp 8-16; (2) 12-16 Str/Sol — J X — Cu setscrew 3-12 Str; 10-12 Sol Cu setscrew K X — Cu setscrew 3-12 Str; 10-12 Sol Cu dual setscrew J L — — Cu setscrew 3-12 Str; 10-12 Sol Al setscrew W — — Cu setscrew 3-12 Str; 10-12 Sol Cu solid 3-12 Str; 10-12 Sol HET-JJ 2-12 Str†; 10-12 Sol† HET-JK 2-12 — — — Al dual setscrew 2-12† — Al setscrew 2-12 — Y — — Cu setscrew 3-12 Str; 10-12 Sol L L — — Al setscrew 2-12 N N — — Al crimp 8 Str ;6 Sol Al crimp 8 Str; 6 Sol — P P — X Al crimp 6 Str; 4 Sol Al crimp 6 Str; 4 Sol — Q Q — X Al crimp 3-4 Str; 2 Sol Al crimp 3-4 Str; 2 Sol — R R — X Al crimp 1-2 Str Al crimp 1-2 — T T — X Al crimp 1/0 Str Al crimp 1/0 — W W — — Cu solid — Cu solid — — * Stranded conductors unless otherwise noted. † Not dual wire rated. One wire per opening. To order: specify catalog symbol HEB and the loadside terminal code. Then select a lineside terminal code that is available with the loadside terminal. Example: HEB-BB defines a non-breakaway holder with a loadside copper crimp terminal for a single #6 or two #10 wires with a lineside copper crimp terminal for a single #6 or two #10 wires. Data sheet no. 2127 HEZ waterproof single-pole breakaway and nonbreakaway Class CC in-line holder HEZ submersible, single-pole in-line rejection fuse holders are for UL Class CC fuses. They are available in non-breakaway and breakaway versions with terminal options to meet application needs. Breakaway versions come with insulating boots (for details, see HEB insulating boot information) to provide submersibility per UL IP67. The non-breakaway version requires ordering optional insulating boots for submersibility. Ratings • 2011/65/EU Agency information • UL Listed, Guide IZLT, File E14853 • CSA Certified, Class 6225-01, File 47235 • RoHS compliant • CE Catalog no. Type Terminal AWG range HEZ-AA Nonbreakaway Line/load Cu crimp 8-16 (2) 12-16 Line/load Cu crimp 8-16 (2) 12-16 Line Cu crimp 8-16 (2) 12-16 Load Cu dual setscrew† 2-12 HEZ-AW-RLC-A Volts 600 V • Amps up to 30 A limited by conductor size • Withstand 200 kA RMS Sym. Data sheet no. 2130 8-52 HEZ-AW-RYC Breakaway † Not dual wire rated, one wire per opening. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse blocks and holders — 8 Insulating boots HEX (13/32" x 1-1/2" supplemental) and HEY (Class CC) dual-pole breakaway and nonbreakaway in-line holders Two insulating boots come standard with the breakaway holder configurations. Insulating boots are not included as standard with non-breakaway holders. Two insulating boots must be ordered separately, if required, for each non-breakaway holder ordered. When insulating boots are utilized, extra heat retention requires that fuses are sized at a minimum of 200 percent of the RMS load current. Breakaway and non-breakaway submersible, dual-pole in-line fuse holders available with terminal options to meet application needs. Breakaway versions come with insulating boots to provide submersibility per UL IP67. Nonbreakaway versions require ordering optional insulating boots for submersibility. To order insulating boots for a non-breakaway HEB holder, use these catalog numbers. Ratings Description 2A0660 Single conductor 2A0661 Dual conductor Recommended crimping tools Volts 600 V This list is not intended to exclude the use of other crimping tools that can provide similar crimps or indents. Amps • Up to 30 A limited by conductor size (UL) • Up to 15 A limited by conductor size (CSA) HEB terminal T & B P/N (Die) * Dependant upon fuse interrupting rating. C Agency information N, P, Q, R, T TBM5 (Brown) Sta-Kon ERG4002 (C) B 200 kA RMS Sym.* HEB terminal T & B P/N (Die) WT-111M (C) A SCCR • Catalog no. D TBM8 (Brown) WT-115A (D) WT-115A (F) TBM5 (Grey) WT-111M (A) Z WT-115A (E) Sta-Kon ERG4002 (A) TBM8 (Orange) • HEX; UL Recognized, Guide IZLT2, File E14853, CSA Certified, Class 6225-01, File 47235, CE HET neutral • HEY; UL Listed, Guide IZLT, File E14853, CSA Certified, Class 6225-01, File 47235, CE The HET holder is a single-pole in-line holder with a permanent, solid neutral for use along with the HEB holder to provide a means of conductor continuity. The HET holder is identified by a white, plastic coupling nut. Available HET holder counterparts to their HEB equivalents are listed in the following catalog number tables. See data sheet no. 2125 for details on the HET holder. Breakaway catalog number system Agency Information Lineside terminal Loadside terminal Catalog symbol HE_ - A W - RYC UL CSA Loadside terminal Lineside terminal Terminal type AWG wire range* Terminal type AWG wire range* HET neutral equivalent Cu crimp 8-16; (2) 12-16 Cu crimp 8-16; (2) 12-16 HET-AW_RLC-A DRLC-A A X X DRLC-B X — Cu crimp 8-16; (2) 12-16 Cu crimp 6; (2) 10 HET-AW_RLC-B DRYC X — Cu crimp 8-16; (2) 12-16 Cu dual setscrew 2-12† HET-AW_RYC J DRYC X — Cu setscrew 3-12 Cu dual setscrew 2-12† HET-JW-RYC K DRYC X — Cu dual setscrew 2-12† Cu dual setscrew 2-12† — HEX Class CC rejection fuse HEY A DRLC-A X X Cu crimp 8-16; (2) 12-16 Cu crimp 8-16; (2) 12-16 HET-AW_RLC-A DRLC-B X — Cu crimp 8-16; (2) 12-16 Cu crimp 6; (2) 10 HET-AW_RLC-B DRLC-J X — Cu crimp 8-12; (2) 12-16 Cu setscrew 3-12 HET-AW_RLC-J DRYC X — Cu crimp 8-16; (2) 12-16 Cu dual setscrew 2-12† HET-AW_RYC * Solid/stranded conductors unless otherwise noted. † Not dual wire rated. One wire per opening. To order: specify catalog symbol HEX and the loadside terminal code plus the letter “W.” Then select a lineside terminal code that is available with the loadside terminal. Example: HEX-AW-DRCL-B defines a breakaway holder with a loadside copper crimp terminal for a single #8-16 or two #12-16 wires with a lineside copper crimp terminal for a single #6 or two #10 wires. Data sheet no. 2126 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 8-53 Fuse blocks and holders 13/32" x 1-1/2" supplemental fuse 8 — Fuse blocks and holders Non-breakaway catalog number system Lineside terminal Loadside terminal Catalog symbol HE_ - A A Agency information UL CSA Loadside terminal Lineside terminal Terminal type AWG Wire range* Terminal type AWG wire range* HET neutral equivalent 13/32" x 1-1/2" supplemental fuse A A X X Cu crimp 8-16; (2) 12-16 Cu crimp 8-16; (2) 12-16 HET-AA B X X Cu crimp 8-16; (2) 12-16 Cu crimp 6; (2) 10 HET-AB C X X Cu crimp 8-16; (2) 12-16 Cu crimp 4 str; (2) 8 — D X X Cu crimp 8-16; (2) 12-16 Cu crimp 2 str; (2) 6 — E X X Cu crimp 8-16; (2) 12-16 Cu crimp (2) 4 — B B X X Cu crimp 6; (2) 10 Cu crimp 6; (2) 10 HET-BB C C X X Cu crimp 4 str; (2) 8 Cu crimp 4 str; (2) 8 — J X — Cu setscrew 3-12 Cu setscrew 3-12 HET-JJ K X — Cu setscrew 3-12 Cu dual setscrew 2-12† HET-JK HEX J Class CC rejection fuse A A X X Cu crimp 8-16; (2) 12-16 Cu crimp 8-16; (2) 12-16 HET-AA B X X Cu crimp 8-16; (2) 12-16 Cu crimp 6; (2) 10 HET-AB C X X Cu crimp 8-16; (2) 12-16 Cu crimp 4 str; (2) 8 — D X X Cu crimp 8-16; (2) 12-16 Cu crimp 2 str; (2) 6 — E X X Cu crimp 8-16; (2) 12-16 Cu crimp (2) 4 — B B X X Cu crimp 6; (2) 10 Cu crimp 6; (2) 10 HET-BB J J X — Cu setscrew 3-12 Cu setscrew 3-12 HET-JJ HEY * Solid/stranded conductors unless otherwise noted. † Not dual wire rated. One wire per opening. To order: specify catalog symbol HE_ and the loadside terminal code. Then select a lineside terminal code that is available with the loadside terminal. Example: HEX-BB defines a non-breakaway holder with a loadside copper crimp terminal for a single #6 or two #10 wires with a lineside copper crimp terminal for a single #6 or two #10 wires. Data sheet no. 2126 8-54 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Power distribution and terminal blocks — 9 Contents Section page Description Selecting power distribution blocks 2 Power distribution blocks Maximize short-circuit current rating up to 200 kA PDBFS UL Listed finger-safe, high SCCR blocks 3-5 PDB UL Listed high SCCR open blocks 160, 162, 163, 164 and 165 UL Recognized open blocks 6-8 9-12 Power stud terminal blocks 162, 163 and 165 UL Recognized blocks 13-14 Power splicer blocks 160, 162, 163 and 165 UL Recognized blocks 15-16 Power terminal blocks 11675 250 V screw/quick-connect block 17 11725 600 V screw/quick-connect block Barrier and deadfront terminal blocks 14002 600 V barrier block 17 14004 600 V dead front block Simplify your panel design To save panel space and reduce component count, Bussmann series power distribution fuse blocks combine circuit protection and power distribution into one unit. Available in Class H(K), and R up to 60 amps and Class J up to 400 amps, with up to a high 200 kA withstand rating. See these cost and space saving products in Section 8, Fuse blocks and holders. Power distribution and terminal blocks with Bussmann series finger-safe power distribution fuse blocks BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 9-1 9 — Power distribution and terminal blocks Selecting SCCR power distribution blocks and terminal blocks Short-circuit current rated power distribution blocks Bussmann series power distribution blocks have three distinct styles to match different application needs. There are the PDBFS_ and PDB_ high short-circuit current rated power distribution blocks and the 16_ power terminal blocks. The differences are whether the power distribution blocks are enclosed or not, and whether they are UL 1953 Listed power distribution blocks or UL 1059 Recognized power terminal blocks, which have different minimum spacing requirements. The table on this page will assist you in selecting which block is right for your application. Why these are important Per the NEC and OSHA, equipment cannot be installed in an electrical system at a location where the available fault (short-circuit) current is greater than the equipment's SCCR. Further, equipment SCCRs are required in the 2014 NEC and for UL 508A Listed control panels. Marking the equipment SCCR on control panels (NEC 409.110), industrial machinery electrical panels (NEC 670.3(A)), and HVAC equipment (NEC 440.4(B)) is required by the NEC. Catalog symbol Power distribution and terminal blocks not marked with a component SCCR are typically one of the weakest links in a control panel's equipment SCCR and may limit the equipment SCCR to no more than 10 kA. The PDBFS_ and PDB_ products have the increased spacing required for use in feeder circuits of equipment listed to UL 508A (UL 1059 terminal blocks must be evaluated for proper spacings). Also, for building wiring systems, the PDBFS_ and PDB_ power distribution blocks can be used to meet the 2014 NEC requirements in section 376.56(B) for power distribution blocks in wireways. Selection table The table below provides an overview of the three Bussmann series power distribution and terminal blocks mentioned above. For details on the PDB_ blocks, see data sheet number 10537. For the 16_ blocks, see data sheet numbers 10533 (UL Recognized power distribution blocks), 10534 (splicer blocks) and 10535 (stud blocks). Spacing ** 1” air, 2” surface UL 508A panel branch circuit UL 508A panel feeder circuit HVAC UL 1995 Wireways NEC 376.56(B) (requires UL 1953) Enclosed High SCCR* PDBFS_ UL 1953 Listed power distribution blocks Yes*** Yes Yes Yes Yes Yes Yes PDB_ UL 1953 Listed power distribution blocks No† Yes Yes Yes Yes Yes Yes, with optional cover UL 1059 Recognized terminal blocks No† Yes No†† Yes No†† Yes No 16_ UL status * When protected by proper fuse class with maximum ampere rating specified or smaller. ** For details, see PDB and TB minimum spacing requirements for equipment table below. *** IP20 finger-safe under specific conditions, see data sheet 10536. † Optional covers are available. Not IP20, but provide a safety benefit. †† No, except if single pole units installed with proper spacings. Power distribution and terminal block minimum spacing requirements for equipment Spacing between live parts of opposite polarity UL standard Through air @ 600 V Over surface @ 600 V Spacing between live parts and grounded parts or enclosure @ 600 V 508A feeder circuits 1" 2" 1" 508A branch circuits 3/8" 1/2" 1/2" 1995 HVAC 3/8" 1/2" 1/2" Note: Refer to specific UL standards for complete spacing details. 9-2 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Power distribution and terminal blocks — 9 PDBFS UL Listed finger-safe, high SCCR power distribution blocks These single pole, small footprint, high Short-Circuit Current Rating (SCCR) power distribution blocks provide IP20* fingersafe protection in a modular design that permits dovetailing together the required number of poles and still meet the UL 1953 minimum 1" and 2" spacing required per UL 508A for feeder circuit applications and per NEC for field installations. Where: • The catalog symbol "PDBFS" defines the block as a finger-safe design • The catalog number ending "204" in this example defines this block's lineside and loadside characteristics covering the amp rating, number of ports and wire sizes, etc. • See the catalog number table for details on the available lineside/loadside characteristics. Features With SCCRs up to 200 kA, these blocks help achieve compliance with NEC and OSHA requirements by resolving a common SCCR "weak link" in industrial control panels. To increase application flexibility, these blocks feature dual-wire rated ports that accept copper or aluminum conductors while retaining a UL Listed status. Catalog number example — PDBFS204 is a 1-pole block 2011/65/EU With panel or 35mm DIN-Rail** mounting these blocks are suitable for installation in wireways and industrial control panel feeder and branch circuits. • IP20 finger-safe under specified conditions increases safety by isolating energized connections • Wire-ready captive termination screws cannot be misplaced and are shipped "backed out" to save time on conductor installation • Sliding DIN-Rail latch provides easy block mounting • For multiple pole applications, all single-pole units can be gang mounted by using the interlocking dovetail pins that are preinstalled on the side of the blocks • Elongated panel-mounting holes provide greater flexibility and installation ease when matching up with drilled panel holes * See table on page 9-5. ** PDFFS504 panel mount only. Dual wire port application Ratings • Rated for dual wire port application to increase the possible number of lineside and loadside connections. E.g., PDBFS220 can accept two wires into the lineside port (4 - 14 Cu, 4 - 8 Al) and two wires per port (eight connections total) on the loadside lug (8 - 14 Cu, 8 Al). • Dual wire applications are only viable when using two wires of the same size, stranding, and insulating and conductor material. Volts • 600 V (UL) • 690 V (IEC) • 1000 V (self-certified) • Amps 175 to 760 A • Ferrule terminal application • SCCR Up to 200 kA (see table for circuit protection details) • Bussmann series PDBFS power distribution blocks are rated for use with UL Listed ferrules (see catalog number table for details). • Ferrule applications allow for the use of a broader range of conductor stranding and simulate a more efficient, solid wire connection with the PDBFS terminal port. • Always use UL Listed ferrules in accordance with the manufacturer's specifications and instructions. Conductors† • Stranded 75°C copper and aluminum • Higher temperature rated conductors permitted with appropriate derating † As specified in the catalog number table. Multi-pole block ganging Agency information • UL 1953 Listed, Guide QPQS, File E256146 • CSA Certified, Class 6228-01, File 47235 • RoHS compliant • CE Flammability rating • Dovetail feature permits easy ganging for multi-pole applications UL 94 V0 PDBFS blocks can be ganged for the required number of poles. How to order • From the catalog number table, select the catalog number that defines the desired lineside/loadside port and conductor characteristics • Order one block per pole for the application • Multiple single-pole blocks can be ganged together via the dovetailing feature to form multi-pole configurations To gang two or more blocks for DIN-Rail or panel mounting, place them side-by-side and slide the dovetail pin of one block into the reciprocal slot on the other until fully seated and both blocks are coplanar. Note: Dissimilar PDBFS blocks can be ganged. E.g., a PDBFS204 can be ganged with a PDBFS220. Ganging with a PDBFS504 (nonDIN Rail mount version) will prevent DIN-Rail mounting. Data sheet no. 10536 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 9-3 Power distribution and terminal blocks • 9 — Power distribution and terminal blocks Current rating (A) Line/load port configuration Wire size (Str/ferrule unless noted)* 2/0 - 1 Cu/Al (Str) 2 - 3 Cu/Al 4 - 8 Cu/Al 10 - 12 Al (Str) 10 - 14 Cu 4 - 8 Cu/Al 10 - 14 Cu 2/0 - 1 Cu/Al (Str) 2 - 3 Cu/Al 4 - 8 Cu/Al 10 - 14 Cu 175 175 350kcmil - 2/0 Cu/Al (Str) 1 1/0 Cu/Al (Str) 1-2 1 - 6 Cu/Al 1-2 500kcmil - 4/0 Cu/Al (Str) 1 3/0 - 1/0 Cu/Al (Str) 1-2 310 380 570 620 Lineside Wires per Torque Ports/ port N•m (lb-in) pole 1 1 12.4 (110)†† 1 1 1 4.0 (35) 1 2 13.6 (120) 2 1 1 13.6 (120) 1 1-2 1-2 1 - 6 Cu/Al 1-2 300kcmil - 2/0 Cu/Al (Str) 1/0 Cu/Al (Str) 1 - 2 Cu/Al 1 1-2 1-2 4 Cu/Al (Str) 1-2 350kcmil - 2/0 Cu/Al (Str) 1/0 Cu/Al (Str) 1 - 4 Cu/Al 6 Cu/Al 1 1-2 1-2 2 500kcmil - 4/0 Cu/Al (Str) 1 3/0 - 1/0 Cu/Al (Str) 1-2 1 - 6 Cu/Al 1-2 760 31.1 (275) † 56.5 (500) 31.1 (275)† Wire size (Str/ferrule unless noted)* 2/0 - 1 Cu/Al (Str) 2 - 3 Cu/Al 4 - 8 Cu/Al 10 - 12 Al (Str) 10 - 14 Cu 4 - 8 Cu/Al 10 - 14 Cu 4 - 6 Cu/Al (Str) 8 Cu 8 Al (Str) 10 - 14 Cu 350kcmil - 2/0 Cu/Al (Str) 1 1/0 Cu/Al (Str) 1-2 1 - 6 Cu/Al 1-2 2 - 3 Cu/Al (Str) 4 Cu/Al 6 Cu/Al 8 Cu/Al 10 - 14 Cu 4 - 6 Cu/Al (Str) 8 Cu 8 Al (Str) 10 - 12 Al (Str) 10 - 14 Cu 350kcmil - 2/0 Cu/Al (Str) 1/0 Cu/Al (Str) 1 - 4 Cu/Al 6 Cu/Al 1 1 1-2 1-2 1-2 1 1 1-2 1 1-2 1 1-2 1-2 2 1 1 2 31.1 (275)† 2 56.5 (500) 2 Loadside Max Wires per Torque Ports/ SCCR port N•m (lb-in) pole (kA)** 1 1 12.4 (110)†† 1 1 1 200 4.0 (35) 1 2 13.6 (120) 2 1 4.0 (35) 1 2.8 (25) 4 200 1-2 1-2 2.3 (20) 500kcmil - 4/0 Cu/Al (Str) 1 3/0 - 1/0 Cu/Al (Str) 1-2 1 - 6 Cu/Al 1-2 31.1 (275)† Catalog no. PDBFS204 PDBFS220 1 200 PDBFS303 6 200 PDBFS330 12 200 PDBFS377 31.1 (275)† 2 200 PDBFS500 56.5 (500) 2 200 PDBFS504 5.6 (50) 5.1 (45) 4.5 (40) 4.0 (35) 4.0 (35) 2.8 (25) 2.3 (20) * 75°C wire (higher temperature rated wire acceptable with appropriate derating). Using a ferrule on a stranded conductor requires a correctly sized UL Listed ferrule (customer supplied) applied according to the manufacturer’s specifications. Ferrule ratings apply to copper wire only. ** See pages 9-4 and 9-5 for the tested upstream overcurrent protective devices necessary for achieving these SCCRs. † Torque rating for dual wire and ferrule application is 30.5 N•m (270 lb-in). †† Torque rating for ferrule application is 13.6 N•m (120 lb-in). Upstream fusing for SCCR and minimum enclosure data This table contains the tested SCCR levels for each PDBFS power distribution block using the specified lineside and loadside conductors and Bussmann series Class J, RK1, RK5 and T fuses. Using these tested SCCR levels also requires the power distribution block be installed in an enclosure with the minimum size indicated for each catalog number. Conductors (AWG/kcmil) Catalog no. Lineside PDBFS204 2/0 - 8 PDBFS220 2/0 - 8 PDBFS303 350 - 6 PDBFS330 500 - 6 PDBFS377 PDBFS500 PDBFS504 Loadside 2/0 - 8 4 - 12 4 - 14 350 - 6 2-6 6 - 14 4 300 - 4 4 - 14 4 350 350 - 4 500 500 - 6 4 350 350 - 4 500 500 - 6 J — LPJ 200 200 175 200 400 400 200 175 600 400 200 600 600 600 600 600 Fuse class and maximum amps* RK1 — LPN-RK (250 V) RK5 — FRN-R (250 V), LPS-RK (600 V) FRS-R (600 V) 100 60 100 60 100 30 100 60 200 100 200 100 100 60 100 30 400 200 200 100 100 60 400 200 400 200 400 200 600 200 400 200 T — JJN (300 V), JJS (600 V) 200 200 175 200 400 400 200 175 600 400 200 600 600 600 800** 600 SCCR (kA) 200 200 100 50 200 200 50 100 200 100 50 50 200 100 200 100 Ampacities 75°C per NEC® Table 310.16 and UL 508A Table 28.1. * Class G 60 A (SC-60) or less or Class CC 30 A (LP-CC-30, FNQ-R-30, KTK-R-30) or less are suitable for all SCCRs in this table. ** Class L 800 A (KRP-C 800_SP) or less fuses suitable for this particular SCCR case. Data sheet no. 10536 9-4 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Min. enclosure size (in) 16 x 16 x 6.75 16 x 16 x 6.75 36 x 30 x 12.625 24 x 20 x 6.75 24 x 20 x 6.75 36 x 30 x 12.625 36 x 30 x 12.625 Power distribution and terminal blocks — 9 Upstream circuit breakers for SCCR and minimum enclosure data This table contains the tested SCCR levels for each PDBFS power distribution block using the specified lineside and loadside conductors and Eaton and General Electric circuit breakers. Using these tested SCCR levels also requires the power distribution block be installed in an enclosure with the minimum size indicated for each catalog number. PDBFS SCCR as rated with Eaton circuit breakers Catalog no. PDBFS204 Suitable Cu conductors kcmil/AWG Lineside Loadside 2/0 - 8 2/0 - 8 SCCR, RMS Sym. (kA) 65 Volts max 480 14 PDBFS330 500 - 3 2-8 480 25 PDBFS377 (2) 300 - 2 4 6 8 4 6 8 30 18 14 42 35 14 Overcurrent protection circuit breaker required Type Max amp EGC125, E125C, EGH125, E125H 125 LGH400, L400H, LGE400, L400E, LGS400, L400S 400 LGC400, L400C, LGU400, L400U, LGX400, L400X Min. enclosure size (in.) 16 x 16 x 6.75 24 x 20 x 6.75 LGH600, L600H, LGE600, L600E, LGS600, L600S 480 600 24 x 20 x 6.75 LGC600, L600C, LGU600, L600U, LGX600, L600X PDBFS SCCR as rated with General Electric circuit breakers Catalog no. Suitable Cu conductors kcmil/AWG Lineside Loadside PDBFS204 2/0 - 8 PDBFS220 2/0 - 8 4 - 12 250 - 6 350 - 6 250 - 6 3/0 - 6 350 - 6 PDBFS303 2/0 - 8 SCCR, RMS Sym. (kA) 65 25 65 25 65 35 65 250 - 6 PDBFS330 Volts max 480 SEHA 150 65 SFLA 250 SFHA 250 SELA 150 SEHA 150 480 65 3/0 - 6 480 25 35 2 - 12 480 Overcurrent protection circuit breaker required Type Max amp SELA 150 SEHA 150 SELA 150 SEHA 150 SFLA 250 SFHA 250 SELA 150 25 Min. enclosure size (in.) 16 x 16 x 6.75 16 x 16 x 6.75 24 x 20 x 6.75 24 x 20 x 6.75 Specified installation conditions for IP20 finger-safe ratings This table contains the installed wire and trim lengths, and other conditions the PDBFS power distribution blocks need in order to be compliant with IP20 specifications. IP20 compliance status is indicated in the lineside and loadside wire port and terminal screw opening columns. Catalog no. PDBFS204 PDBFS220 PDBFS303 PDBFS330 PDBFS377 PDBFS500 PDBFS504 Installed wire/state 2/0 - 8 Wire trim length in (mm) 0.85 (22) 2/0 - 8 0.75 (19) 350kcmil - 2/0 1/0 - 6 500 - 250kcmil 4/0 - 6 300kcmil - 4/0 3/0 - 4 Screws fully open No wire in port 350kcmil - 2/0 1/0 - 4 Screws fully opened No wire in port 500 - 350kcmil 300 - 6 Screws fully open No wire in port 1.35 (34) 1.25 (32) Top row 1.15 (29) bottom row 1.4 (36) 1.25 (32) 1.25 (32) Loadside IP20 status Terminal Wire port screw opening opening Yes Yes Yes Yes Yes No Yes No Yes Yes Yes Yes Yes No N/A No No No N/A No Yes No N/A No Yes Yes No N/A Yes Yes No N/A Yes Yes No N/A Installed wire/state 2/0 - 8 4 - 14 Screws fully opened No wire in hole 350kcmil - 2/0 1/0 - 6 2 - 14 Screws fully opened No wire in hole 4 - 14 Screws fully open No wire in port 350kcmil - 2/0 1/0 - 4 Screws fully open No wire in port 500 - 350kcmil 300 - 6 Screws fully opened No wire in port Wire trim length in (mm) 0.97 (25) Top row 0.55 (14), Bottom row 0.85 (22) 1.25 (32) Top row 0.59 (15), Bottom row 1.2 (30) Top row 0.55 (14), Middle row 1.00 (35), Bottom row 1.22 (31) IP20 status Terminal Wire port screw opening opening Yes Yes Yes Yes N/A Yes No N/A Yes Yes No Yes Yes Yes N/A Yes Yes N/A Yes Yes N/A Yes 1.25 (32) 1.25 (32) Yes N/A Yes No N/A No Yes No N/A No Yes Yes No N/A Yes Yes No N/A Data sheet no. 10536 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 9-5 Power distribution and terminal blocks Lineside 9 — Power distribution and terminal blocks PDB UL Listed high SCCR open power distribution blocks High Short-Circuit Current Rating (SCCR) power distribution blocks provide up to 200 kA SCCR and help achieve compliance with NEC and OSHA requirements by resolving a common SCCR “weak link” in industrial control panels. Available in 1-, 2- and 3-pole panel mount versions with popular lineside and loadside port configurations, these blocks are UL Listed with the requisite spacing between uninsulated opposite polarities or ground by meeting the UL 1953 1” through air and 2” over surface spacings required per UL 508A for feeder circuit applications and per NEC for field installations. Features • High SCCRs up to 200 kA, assist in achieving high SCCR for a control panel per NEC and UL 508A requirements • In compliance with UL 1953 minimum spacing requirements for industrial control panel feeder and branch circuits • Optional covers available to reduce the risk of accidental contact with energized components Dual wire port application • Rated for dual wire port application to increase the possible number of lineside and loadside connections. E.g., PDB220 can accept two wires into the lineside port (4-14 Cu, 4-8 Al) and two wires per port (eight connections per pole total) on the loadside lug (8-14 Cu, 8 Al). To increase application flexibility, these blocks feature dual-wire rated ports that accept copper or aluminum conductors while retaining a UL Listed status. • Dual wire applications are only viable when using two wires of the same size, stranding, and insulating and conductor material in the same port Optional covers are available to enhance electrical safety. Ferrule terminal application Ratings • Volts 600 V • Amps 175 to 310 A • SCCR 200 kA (see table for circuit protection details) Conductors† • Bussmann series PDB power distribution blocks are rated for use with UL Listed ferrules (see catalog number table for details) • Ferrule applications allow for the use of a broader range of conductor stranding and simulate a more efficient, solid wire connection with the PDB terminal port • Always use UL Listed ferrules in accordance with the manufacturer’s specifications and instructions • Stranded 75°C copper and aluminum Optional covers • Higher temperature rated conductors permitted with appropriate derating Electrical safety can be enhanced by installing optional covers. † As specified in the catalog number table. Agency information • UL 1953 Listed, Guide QPQS, File E256146 • CSA Certified, Class 6228-01, File 47235 • CE Flammability rating • UL 94 V0 How to order From the catalog number table, select the catalog number that defines the desired lineside/loadside port and conductor characteristics. Add to the catalog number the suffix that defines the desired pole configuration. Note, you must select from the available number of poles for each catalog number. These appear in the second column of the catalog number tables. Catalog number example — PDB323-3 is a 3-pole PDB323 Where: From the table below, order the cover catalog number that matches the block catalog number. Order the quantity indicated in the “order quantity” column. E.g., the 3-pole block PDB204-3 requires ordering three CPB162-1 covers (one cover for each pole). Block catalog no. PDB204-1 PDB204-3 PDB220-1 PDB220-3 PDB280-1 PDB280-3 PDB323-1 PDB323-3 PDB370-1 PDB370-3 PDB371-1 PDB371-3 PDB321-1 PDB321-2 PDB321-3 Poles 1 3 1 3 1 3 1 3 1 3 1 3 1 2 3 Cover catalog no. CPB162-1 CPB162-1 CPB162-1 CPB162-1 CPB162-1 CPB162-1 CPDB-1 CPDB-1 CPDB-1 CPDB-1 CPDB-1 CPDB-1 CPDB-1* CPDB-2* CPDB-3* Order quantity 1 3 1 3 1 3 1 3 1 3 1 3 1 1 1 * For the PDB321-_ blocks, order one cover for each block (not per pole). • The prefix “PDB323” defines the block’s lineside characteristics (i.e., one conductor port per pole that accepts 350kcmil-6 Cu/Al conductors) and the loadside characteristics (i.e., six (6) conductor ports per pole that each accepts 4-14 Cu or 4-12 Al conductors) • The suffix “3” in this example defines this as a three-pole block • See the catalog number table for details on the available lineside/ loadside characteristics Data sheet no. 10537 9-6 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Power distribution and terminal blocks — 9 Line/load port configuration Current No. of rating poles (A) 1, 3 175 1, 3 175 1, 3 175 1, 2, 3 1, 3 1, 3 1, 3 175 310 310 310 Wire size (Str/ferrule unless noted)* 2/0 - 1 Cu/Al (Str) 2 - 3 Cu/Al 4 - 8 Cu/Al 10 - 12 Al (Str) 10 - 14 Cu 4 - 8 Cu/Al 10 - 14 Cu 2/0 - 1 Cu/Al (Str) 2 - 3 Cu/Al 4 - 8 Cu/Al 10 - 14 Cu 2/0 - 1 Cu/Al (Str) 2 - 3 Cu/Al 4 - 8 Cu/Al 10 - 14 Cu 2/0 - 1 Cu/Al (Str) 2 - 3 Cu/Al 4 - 8 Cu/Al 10 - 12 Al (Str) 10 - 14 Cu Lineside Wires per port 1 1 1 1 1 2 2 1 1 1-2 1-2 1 1 1-2 1-2 1 1 1-2 1 1-2 350kcmil - 2/0 Cu/Al (Str) 1 1/0 Cu/Al (Str) 1-2 1 - 6 Cu/Al 1-2 350kcmil - 2/0 Cu/Al (Str) 1 1/0 Cu/Al (Str) 1-2 1 - 6 Cu/Al 1-2 350kcmil - 2/0 Cu/Al (Str) 1 1/0 Cu/Al (Str) 1 - 6 Cu/Al 1-2 Loadside Max Wire size Wires Torque Ports/ (Str/ferrule unless per Torque Ports/ SCCR Catalog no. N•m (lb-in) pole noted)* port N•m (lb-in) pole (kA)** 2/0 - 1 Cu/Al (Str) 1 2 - 3 Cu/Al 1 12.4 (110)†† 12.4 (110)†† 4 - 8 Cu/Al 1 1 10 - 12 Al (Str) 1 1 200 PDB204-_ 4.0 (35) 4.0 (35) 10 - 14 Cu 1 4 - 8 Cu/Al 2 13.6 (120) 13.6 (120) 10 - 14 Cu 2 4 - 6 Cu/Al (Str) 1 4.0 (35) 8 Cu 1 13.6 (120) 1 2.8 (25) 4 200 PDB220-_ 8 Al (Str) 1-2 10 - 14 Cu 1-2 2.3 (20) 13.6 (120) 13.6 (120) 31.1 (275)† 31.1 (275)† 31.1 (275)† 1 1 1 1 1 1-2 1/4-20 x 3/4” Stud — 4 - 6 Cu/Al (Str) 8 Al (Str) 8 Cu 10 - 12 Al (Str) 10 - 14 Cu 4 - 6 Cu/Al (Str) 8 Al (Str) 8 Cu 10 - 12 Al (Str) 10 - 12 Cu 10 - 14 Cu 4 - 6 Cu/Al (Str) 8 Al (Str) 8 Cu 10 - 12 Al (Str) 10 - 14 Cu 2 - 3 Cu/Al (Str) 4 - 8 Al (Str) 6 - 8 Al (Str) 4 Cu 6 Cu 8 Cu 10 - 12 Cu 14 Cu 1/0 - 3 Cu/Al (Str) 4 - 6 Cu/Al 8 Cu/Al 10 - 12 Cu 6 - 14 Cu 4 - 6 Al (Str) 1 1-2 1 1 1-2 1 1-2 1 1 1 2 1 1-2 1 1 1-2 1 1 2 1 1-2 1-2 1-2 2 1 1 1 1 2 2 — 1 200 PDB280-_ 6 200 PDB321-_ 6 200 PDB323-_ 12 200 PDB370-_ 200 PDB371-_ 4.0 (35) 2.8 (25) 4.0 (35) 2.3 (20) 4.0 (35) 2.8 (25) 4.0 (35) 2.3 (20) 4.0 (35) 2.8 (25) 4.0 (35) 2.3 (20) 5.6 (50) 5.1 (45) 6 4.5 (40) 4.0 (35) 5.6 (50) 5.1 (45)†† 4.5 (40)†† 4.0 (35)†† 3 13.6 (120) Power distribution and terminal blocks * 75°C wire (higher temperature rated wire acceptable with appropriate derating). Using a ferrule on a stranded conductor requires a correctly sized UL Listed ferrule (customer supplied) applied according to the manufacturer’s specifications. Ferrule ratings apply to copper wire only. ** See page 9-8 for the tested upstream overcurrent protective devices necessary for achieving these SCCRs. † Torque rating for dual wire and ferrule application is 30.5 N•m (270 lb-in). †† Torque rating for ferrule application is 13.6 N•m (120 lb-in). Data sheet no. 10537 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 9-7 9 — Power distribution and terminal blocks Upstream fusing for SCCR and minimum enclosure data This table contains the tested SCCR levels for each PDBFS power distribution block using the specified lineside and loadside conductors and Bussmann series Class J, RK1, RK5 and T fuses. Using these tested SCCR levels also requires the power distribution block be installed in an enclosure with the minimum size indicated for each catalog number. Conductors (AWG/kcmil) Fuse class and maximum amps* RK1 — LPN-RK (250 RK5 — FRN-R (250 V), T — JJN (300 SCCR V), LPS-RK (600 V) FRS-R (600 V) V), JJS (600 V) (kA) Catalog no. Lineside Loadside PDB204-1, -3 2/0 - 8 2/0 - 8 — 200 100 60 200 200 4 - 12 — 200 100 60 200 200 4 - 14 60 175 100 30 175 100 PDB220-1, -3 2/0 - 8 PDB280-1, -3 2/0 - 8 PDB321-1, -2, -3 2/0 - 8 PDB323-1, -3 350 - 4 PDB370-1, -3 350 - 4 PDB371-1, -3 350 - 4 G — SC (480 V) J — LPJ Stud — 200 100 60 200 200 4 - 12 — 400 200 100 400 200 4 - 14 60 175 100 30 175 100 4-8 — 400 200 100 400 200 4 - 12 60 175 100 30 175 100 4-8 — 400 200 100 400 200 4 - 14 60 175 100 30 175 100 1/0 - 6 — 400 200 100 400 200 1/0 - 12 60 175 100 30 175 100 Min. enclosure size (in) 16 x 16 x 6.75 16 x 16 x 6.75 16 x 16 x 6.75 24 x 20 x 6.75 24 x 20 x 6.75 24 x 20 x 6.75 24 x 20 x 6.75 Ampacities 75°C per NEC Table 310.16 and UL 508A Table 28.1. * Class CC 30 A (LP-CC-30, FNQ-R-30, KTK-R-30) or less are suitable for all SCCRs in this table. Upstream circuit breakers for SCCR and minimum enclosure data This table contains the tested SCCR levels for each PDB power distribution block using the specified lineside and loadside conductors and Eaton circuit breakers. Using these tested SCCR levels also requires the power distribution block be installed in an enclosure with the minimum size indicated for each catalog number. PDB_ SCCR as rated with Eaton circuit breakers Suitable Cu conductors kcmil/AWG Catalog no. PDB220 PDB321 Lineside Loadside 2/0 - 8 4 - 10 65 2/0 - 8 22 Type Max amp 480 EGC125, E125C, EGH125, E125H 125 480 EGC125, E125C, EGE125, E125E, EGS125, E125S, EGH125, E125H 125 125 2/0 - 8 14 14 480 2/0 - 8 4 - 10 65 480 EGC125, E125C, EGH125, E125H 125 2/0 - 8 12 22 480 EGC125, E125C, EGE125, E125E, EGS125, E125S, EGH125, E125H 125 480 EGC125, E125C, EGB125, E125B, EGE125, E125E, EGS125, E125S, EGH125, E125H 125 2/0 - 8 14 350 - 4 4-6 65 480 JGH250, J250H 250 350 - 4 8 42 480 JGH250, J250H 250 480 JGH250, J250H, JGE250, J250E, JGS250, J250S, 250 PDB323 350 - 4 14 10 14 4-6 65 8 42 10 25 8 50 10 25 480 JGC250, J250C, JGU250, J250U, JGX250, J250X 65 480 JGH250, J250H 250 350 - 4 8 42 480 JGH250, J250H 250 480 JGH250, J250H, JGE250, J250E, JGS250, J250S, 250 480 JGC250, J250C, JGU250, J250U, JGX250, J250X 250 10 14 4-6 65 8 42 10 25 350 - 4 4-6 50 480 JGH250, J250H 250 350 - 4 8 42 480 JGH250, J250H 250 480 JGH250, J250H, JGE250, J250E, JGS250, J250S, 250 480 JGC250, J250C, JGU250, J250U, JGX250, J250X 250 350 - 4 350 - 4 10 14 4-6 65 8 50 10 25 Data sheet no. 10537 9-8 16 x 16 x 6.75 24 x 20 x 6.75 250 4-6 350 - 4 Min. enclosure size (in.) 24 x 20 x 6.75 350 - 4 350 - 4 PDB371 12 Volts max EGC125, E125C, EGB125, E125B, EGE125, E125E, EGS125, E125S, EGH125, E125H 350 - 4 PDB370 Overcurrent protection circuit breaker required SCCR, RMS Sym. (kA) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 24 x 20 x 6.75 24 x 20 x 6.75 Power distribution and terminal blocks — 9 160, 162, 163, 164 and 165 UL Recognized open power distribution blocks UL Recognized power distribution blocks offer a variety of lineside and loadside port configurations for greater flexibility in panel wiring and wire management. These blocks are UL Recognized to UL 1059 and rated for use in UL 508A industrial control panels. Blocks are factory configured in 1-, 2 and 3-pole versions, and have optional covers to enhance safety (order covers separately). Dual wire port application • Rated for dual wire port application to increase the possible number of lineside and loadside connections. E.g., 16220-1 can accept two wires into the lineside port (4 - 14 Cu, 4 - 8 Al) and two wires per port (eight connections total) on the loadside lug (8 - 14 Cu, 8 Al). • Dual wire applications are only viable when using two wires of the same size, stranding, and insulating and conductor material. Ferrule terminal application • Bussmann series UL Recognized power distribution blocks are rated for use with UL Listed ferrules (see catalog number table for details). • Ferrule applications allow for the use of a broader range of conductor stranding and simulate a more efficient, solid wire connection with the terminal port. • Always use UL Listed ferrules in accordance with the manufacturer’s specifications and instructions. Ratings • Volts 600 V • Amps 175 to 1520 A • SCCR up to 200 kA* (see table for SCCR by catalog number) * Maximum SCCR contingent upon the application of an upstream current-limiting overcurrent protective device. See table for fusing requirements. Conductors† • Stranded 75°C copper and aluminum • Higher temperature rated conductors permitted with appropriate derating † As specified in the catalog number table. Agency information • UL 1059 Recognized, Guide XCFR2, File E62622 • CSA Certified, Class 6228-01, File 15364 Optional covers For block catalog number starting 160__ 162__ 163__ 165__ Order cover catalog number CPB160-(poles)* CPB162-(poles)* CPDB-(poles)* CPDB165** * Order one cover for each block by specifying the number of poles in the catalog number suffix. E.g., For the block catalog number 16021-4, order the cover catalog number CPD160-4. ** Order one cover for each of the block’s poles. E.g., For block catalog number 16530-3, order three of cover catalog number CPDB165. Flammability rating • UL 94 V0 Optional covers • See table for catalog numbers and ordering details How to order From the catalog number tables, select the catalog number that defines the desired lineside/loadside port and conductor characteristics. Add to the catalog number the suffix that defines the desired pole configuration. Note, you must select from the available number of poles for each catalog number. These appear in the second column of the catalog number tables. Catalog number example — 16220-3 is a 3-pole 16220 • The prefix “16220” defines the block’s lineside characteristics (i.e., one conductor port per pole that accepts 2/0 - 14 Cu, or 2/0 - 8 Al conductors) and the loadside characteristics (i.e., four conductor ports per pole that each accepts 4 - 14 Cu or 4 - 8 Al conductors) • The suffix “3” in this example defines this as a three-pole block • See the catalog number tables for details on the available lineside/ loadside characteristics Power distribution and terminal blocks Where: Data sheet no. 10533 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 9-9 9 — Power distribution and terminal blocks Line/load port configuration Current No. of rating poles (A) 2, 3, 4 1, 2, 3 1, 2, 3 1, 2, 3 2,3,4 1, 2, 3 175 175 175 175 310 310 Lineside Wires Wire size (Sol/ferrule per unless noted)* port 2/0 - 1 Cu/Al (Str) 1 2 - 3 Cu/Al 1 4 - 8 Cu/Al 10 - 14 Cu 2/0 - 1 Cu/Al (Str) 2 - 3 Cu/Al 4 - 8 Cu/Al 10 - 14 Cu 2/0 - 1 Cu/Al (Str) 2 - 3 Cu/Al 4 - 8 Cu/Al 10 - 14 Cu 2/0 - 1 Cu/Al (Str) 2 - 3 Cu/Al 4 - 8 Cu/Al 10 - 14 Cu 350kcmil - 2/0 Cu/Al (Str) 1-2 1-2 1 1 1-2 1-2 1 1 1-2 1-2 1 1 1-2 1-2 1 1/0 Cu/Al (Str) 1-2 1 - 6 Cu/Al 1-2 350kcmil - 2/0 Cu/Al (Str) 1 1/0 Cu/Al (Str) 1-2 1 - 6 Cu/Al 1-2 350kcmil - 2/0 Cu/Al (Str) 1, 2, 3 1, 2, 3 1, 2, 3 1-2 1 - 6 Cu/Al 1-2 350kcmil - 2/0 Cu/Al (Str) 1 1/0 Cu/Al (Str) 1-2 1 - 6 Cu/Al 1-2 350kcmil - 2/0 Cu/Al (Str) 1 1/0 Cu/Al (Str) 1-2 310 310 13.6 (120) 13.6 (120) 13.6 (120) 31.1 (275)†† 31.1 (275)†† 31.1 (275)†† 1/0 Cu/Al (Str) 31.1 (275)†† 31.1 (275)†† 1 - 6 Cu/Al 1, 2, 3 13.6 (120) Loadside Wires Ports/ Wire size (Sol/ferrule per pole unless noted)* port 4 - 6 Cu/Al (Str) 1 1 1 1 1 1 1 1 310 310 Torque N•m (lb-in) 1 1 1 1-2 350kcmil - 2/0 Cu/Al (Str) 1 1/0 Cu/Al (Str) 1-2 1 - 6 Cu/Al 1-2 31.1 (275)†† 1 8 Cu 1 8 Al (Str) 10 - 14 Cu 4 - 6 Cu/Al (Str) 8 Cu 8 Al (Str) 10 - 14 Cu 4 - 6 Cu/Al (Str) 8 Cu 8 Al (Str) 10 - 14 Cu 4 - 6 Cu/Al (Str) 8 Cu 8 Al (Str) 10 - 14 Cu 4 - 6 Cu/Al (Str) 8 Cu 8 Al (Str) 10 - 12 Al (Str) 10 - 14 Cu 4 - 6 Cu/Al (Str) 8 Cu 8 Al (Str) 10 - 12 Al (Str) 10 - 14 Cu 2 - 3 Cu/Al (Str) 4 Cu/Al 6 Cu/Al 8 Cu/Al 10 - 14 Cu 1/0 - 3 Cu/Al (Str) 4 Cu 4 - 8 Al (Str) 6 - 14 Cu 4 - 6 Cu/Al (Str) 8 Cu 8 Al (Str) 10 - 12 Al (Str) 10 - 14 Cu 2 - 3 Cu/Al (Str) 4 - 6 Cu/Al (Str) 8 Cu/Al (Str) 10 - 14 Cu (Str) 1/0 - 3 Cu/Al (Str) 4 - 8 Cu/Al 10 - 14 Cu 6 - 14 Cu 4 - 8 Al (Str) 1-2 1-2 1 1 1-2 1-2 1 1 1-2 1-2 1 1 1-2 1-2 1 1 1-2 1 1-2 1 1 1-2 1 1-2 1 1 1-2 1-2 1-2 1 1 1-2 1-2 1 1 1-2 1 1-2 1 1 1 1 1 1 1 2 2 10 Cu/Al 1 12 - 14 Cu 1 Torque N•m (lb-in) 4.0 (35) 2.8 (25) Max Ports/ SCCR (kA)† Catalog no. pole 6 10 16021-_ 4 200 16220-_ 4 200 16220_H††† 6 200 16321-_ 6 10 16023-_ 6 200 16323-_ 10 16332-_ 200 16370-_ 200 16371-_ 10 16372-_ 2.3 (20) 4.0 (35) 2.8 (25) 2.3 (20) 4.0 (35) 2.8 (25) 2.3 (20) 4.0 (35) 2.8 (25) 2.3 (20) 4.0 (35) 2.8 (25) 2.3 (20) 4.0 (35) 2.8 (25) 2.3 (20) 5.6 (50) 5.1 (45) 3 4.5 (40) 4.0 (35) 13.6 (120) 2 4.0 (35) 2.8 (25) 12 2.3 (20) 5.6 5.1 4.5 4.0 (50) (45) (40) (35) 6 13.6 (120) 3 0.8 (7) 21 * 75°C wire (higher temperature rated wire acceptable with appropriate derating). Using a ferrule on a stranded conductor requires a correctly sized UL Listed ferrule (customer supplied) applied according to the manufacturer’s specifications. Ferrule ratings apply to copper wire only. ** Not covered by CSA certification. † See Short-Circuit Current Ratings table for the tested upstream overcurrent protective devices necessary for achieving these SCCRs. †† Torque rating for dual wire and ferrule application is 30.5 N•m (270 lb-in). ††† Configuration includes hex screws. Data sheet no. 10533 9-10 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Power distribution and terminal blocks — 9 Lineside Line/load port configuration No. of poles 1, 2, 3 1, 2, 3 1, 2, 3 1, 2, 3 1, 2, 3 1, 2, 3 Current rating (A) Loadside Wire size (Sol/ferrule unless noted)* Wires Torque per N•m port (lb-in) 350kcmil - 2/0 Cu/Al (Str) 1 1/0 Cu/Al (Str) 1-2 1 - 6 Cu/Al 2/0 - 1 Cu/Al (Str) 2 - 3 Cu/Al 4 - 8 Cu/Al 10 - 14 Cu 1-2 1 1 1-2 1-2 500kcmil - 4/0 Cu/Al (Str) 1 3/0 - 1/0 Cu/Al (Str) 1-2 1 - 6 Cu/Al 1-2 500kcmil - 4/0 Cu/Al (Str) 1 310 350 380 380 380 420 31.1 (275)†† 3/0 - 1/0 Cu/Al (Str) 1-2 1 - 6 Cu/Al 1-2 500kcmil - 4/0 Cu/Al (Str) 1 3/0 - 1/0 Cu/Al (Str) 1-2 1 - 6 Cu/Al 1-2 600kcmil - 2 Cu/Al (Str) 1 13.6 (120) 56.5 (500) 56.5 (500) 56.5 (500) 56.5 (500) Ports/ Wire size (Sol/ferrule pole unless noted)* 10 Cu/Al 12 - 14 Cu 1/0 - 3 Cu/Al (Str) 1 4 Cu 6 - 14 Cu 4 - 8 Al (Str) 10 - 14 Al (Str) 4 - 6 Cu/Al (Str) 8 Cu 2 8 Al (Str) 10 - 14 Cu 2 - 3 Cu/Al (Str) 4 Cu/Al 6 Cu/Al 1 8 Cu/Al 10 - 12 Al (Str) 10 - 14 Cu 2 - 3 Cu/Al (Str) 4 Cu/Al 6 Cu/Al 8 Cu/Al 1 10 - 14 Cu 1/0 - 3 Cu/Al (Str) 4 Cu 4 - 8 Al (Str) 6 - 14 Cu 6 Cu/Al (Str) 8 Cu 1 8 Al (Str) 10 - 14 Al (Str) 10 - 14 Cu 4 - 6 Cu/Al (Str) 8 Cu 1 8 Al (Str) 10 - 12 Al (Str) 10 - 14 Cu Wires per port 1 1 1 1 1-2 1-2 1 1 1 1-2 1-2 1 1 1-2 1-2 1 1-2 1 1 1-2 1-2 1-2 1 1 1-2 1-2 1 1 1-2 1 1-2 1 1 1-2 1 1-2 Torque N•m (lb-in) Max Ports/ SCCR (kA)† pole 0.8 (7) 14 Catalog no. 10 16373_ 6 10 16325_ 6 10 16330_ 10 16335_ 21 10 16541_ 12 10 16375_ 13.6 (120) 3 4.0 (35) 2.8 (25) 2.3 (20) 5.6 (50) 5.1 (45) 4.5 (40) 4.0 (35) 5.6 (50) 5.1 (45) 3 4.5 (40) 4.0 (35) 13.6 (120) 2 4.0 (35) 2.8 (25) 2.3 (20) 4.0 (35) 2.8 (25) 2.3 (20) * 75°C wire (higher temperature rated wire acceptable with appropriate derating). Using a ferrule on a stranded conductor requires a correctly sized UL Listed ferrule (customer supplied) applied according to the manufacturer’s specifications. Ferrule ratings apply to copper wire only. † See Short-Circuit Current Ratings table for the tested upstream overcurrent protective devices necessary for achieving these SCCRs. †† Dual wire and ferrule application torque rating = 30.5 N•m (270 lb-in). Short-Circuit Current Rating (SCCR) data Conductors (AWG/kcmil) 16220-_ 16321-_ 16323-_ 16370-_ 16371-_ 1, 2, 3 1, 2, 3 1, 2, 3 1, 2, 3 1, 2, 3 Lineside 2/0 - 8 2/0 - 8 350 - 4 350 - 4 350 - 4 Loadside J — LPJ RK1 — LPN-RK (250 V), LPS-RK (600 V) 4 - 12 200 200 60 200 4 - 14 175 100 60 175 100 400 200 100 400 200 4 - 12 4-8 RK5 — FRN-R (250 V), FRS-R (600 V) T — JJN (300 V), JJS (600 V) SCCR (kA) 200 175 100 60 175 100 400 200 100 400 200 4 - 12 175 100 60 175 100 4-8 400 200 100 400 200 4 - 14 175 100 60 175 100 1/0 - 6 400 200 100 400 200 1/0 - 12 175 100 60 175 100 Power distribution and terminal blocks Catalog no. No. of poles Fuse Class/Bussmann series symbol/amp rating Data sheet no. 10533 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 9-11 9 — Power distribution and terminal blocks Line/load port configuration Current No. of rating poles (A) 1, 2, 3 1, 2, 3 1, 2, 3 1, 2, 3 1 Wire size (Str/ferrule unless noted)* Lineside Wires per Torque Ports/ port N•m (lb-in) pole 420 600kcmil - 2 Cu/Al (Str) 1 56.5 (500) 1 570 300kcmil - 2/0 Cu/Al (Str) 1/0 Cu/Al (Str) 1 - 2 Cu/Al 1 1-2 1-2 31.1 (275)†† 2 4 Cu/Al (Str) 1-2 500kcmil - 4/0 Cu/Al (Str) 3/0 - 1/0 Cu/Al (Str) 1 1-2 56.5 (500) 2 56.5 (500) 2 56.5 (500) 4 760 840 1520 1 - 6 Cu/Al 1-2 600kcmil - 2 Cu/Al 1 500kcmil - 4/0 Cu/Al (Str) 1 3/0 - 1/0 Cu/Al (Str) 1-2 1 - 6 Cu/Al 1-2 Wire size (Str/ferrule unless noted)* 2 - 3 Cu/Al (Str) 4 Cu/Al 6 Cu/Al 8 Cu/Al 10 - 14 Cu 1/0 - 3 Cu/Al (Str) 4 Cu 6 - 14 Cu 4 - 8 Al (Str) 4 - 6 Cu/Al (Str) 8 Cu 8 Al (Str) 10 - 12 Al (Str) 10 - 14 Cu 4 - 6 Cu/Al (Str) 8 Cu 8 Al (Str) 10 - 14 Al (Str) 10 - 14 Cu 3/0 - 6 Cu/Al (Str) 4 - 6 Cu/Al (Str) 8 Cu 8 Al (Str) 10 - 14 Al (Str) 10 - 14 Cu 2 - 3 Cu/Al (Str) 4 Cu/Al 6 Cu/Al 8 Cu/Al 10 - 14 Cu 1/0 - 3 Cu/Al (Str) 4 Cu 4 - 8 Al (Str) 6 - 14 Cu Loadside Max Wires per Torque Ports/ SCCR Catalog no. port N•m (lb-in) pole (kA)† 1 5.6 (50) 1 5.1 (45) 1-2 6 1-2 4.5 (40) 1-2 4.0 (35) 10 16376-_ 1 1 13.6 (120) 3 1-2 1-2 1 4.0 (35) 1 2.8 (25) 1-2 12 10 16377-_ 1 2.3 (20) 1-2 1 4.0 (35) 1 2.8 (25) 1-2 12 10 16530-_ 1 2.3 (20) 1-2 1 13.6 (120) 4 1 4.0 (35) 1 2.8 (25) 10 16528-_ 1-2 4 1 2.3 (20) 1-2 1 5.6 (50) 1 5.1 (45) 1-2 22 1-2 4.5 (40) 1-2 4.0 (35) 10 16400 1 1 13.6 (120) 6 1-2 1-2 * 75°C wire (higher temperature rated wire acceptable with appropriate derating). Using a ferrule on a stranded conductor requires a correctly sized UL Listed ferrule (customer supplied) applied according to the manufacturer’s specifications. Ferrule ratings apply to copper wire only. † See Short-Circuit Current Ratings table for the tested upstream overcurrent protective devices necessary for achieving these SCCRs. †† Dual wire and ferrule application torque rating = 30.5 N•m (270 lb-in). Data sheet no. 10533 9-12 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Power distribution and terminal blocks — 9 Port-to-stud and stud-to-stud power terminal blocks are available with current ratings up to 760 A. These blocks provide a convenient stud connection means for lug/ring wire terminals. Factory configured from 1- to 3-poles (catalog number dependent) with optional covers to enhance safety (order covers separately), these blocks are UL Recognized to UL 1059 and rated for use in UL 508A industrial control panels. Dual wire port application • Rated for dual wire port application to increase the possible number of lineside and loadside connections. E.g., 16280-1 can accept two wires into the lineside port (#4 - #8 Cu/Al, #10 - #14 Cu). • Dual wire applications are only viable when using two wires of the same size, stranding, and insulating and conductor material in the same port Ferrule terminal application • Bussmann series stud blocks are rated for use with UL Listed ferrules (see catalog number table for details). Ferrule ratings apply to copper wire only. • Ferrule applications allow for the use of a broader range of conductor stranding and simulate a more efficient, solid wire connection with the terminal port • Always use UL Listed ferrules in accordance with the manufacturer’s specifications and instructions Ratings • Volts 600 V • Amps 150 up to 760 A • SCCR up to 200 kA* (see table for SCCR by catalog number) * Maximum SCCR contingent upon the application of an upstream current-limiting overcurrent protective device. See table for fusing requirements. Conductors† • Stranded 75°C copper and aluminum • Higher temperature rated conductors permitted with appropriate derating † As specified in the catalog number table. Agency information • UL 1059 Recognized, Guide XCFR2, File E62622 • CSA Certified, Class 6228-01, File 15364 Flammability rating • UL 94 V0 Optional covers • See table for catalog numbers specific to each block How to order From the catalog number tables, select the catalog number that defines the desired lineside/loadside port and conductor characteristics. Add to the catalog number the suffix that defines the desired pole configuration. Note, you must select from the available number of poles for each catalog number. These appear in the second column of the catalog number tables. Catalog number example — 16280-3 is a 3-pole 16280 Where: • The prefix “16280” defines the block’s lineside characteristics (i.e., one conductor port per pole that accepts 2/0 - 14 Cu/Al conductors) and the loadside characteristics (i.e., 1/4-20 x 3/4” stud) • The suffix “3” in this example defines this as a three-pole block • See the catalog number tables for details on the available lineside/ loadside characteristics Optional covers Electrical safety can be enhanced by installing optional covers. From the table below, order the cover catalog number that matches the block catalog number. Block catalog no. 16280-1 16280-2 16280-3 16280-2-M 16280-3-M 16281-1 16281-2 16281-3 16290-1 16290-2 16290-3 16378-1 16378-2 16378-3 16383-1 16383-2 16383-3 16390-1 16390-2 16390-3 16392-1-H 16392-2-H 16392-3-H 16394-1 16394-2 16394-3 16395-1 16395-2 16395-3 16582-1 16582-2 16582-3 16591-1 16591-2 16591-3 16593-1 16593-2 16593-3 Poles 1 2 3 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 Cover catalog no. CPB162-1* CPB162-2* CPB162-3* CPB162-2* CPB162-3* CPB162-1* CPB162-2* CPB162-3* CPB162-1* CPB162-2* CPD162-3* CPDB-1* CPDB-2* CPDB-3* CPDB-1* CPDB-2* CPDB-3* CPDB-1* CPDB-2* CPDB-3* CPDB-1* CPDB-2* CPDB-3* CPDB-1* CPDB-2* CPDB-3* CPDB-1* CPDB-2* CPDB-3* CPDB165** CPDB165** CPDB165** CPDB165** CPDB165** CPDB165** CPDB165** CPDB165** CPDB165** Power distribution and terminal blocks 162, 163 and 165 UL Recognized stud power terminal blocks * Cover catalog number provides one individual cover for each block. ** Order one cover for each pole. Data sheet no. 10535 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 9-13 9 — Power distribution and terminal blocks Lineside Line/load configuration No. of poles Current rating (A) Wire/stud size (Str/ferrule unless noted)* Loadside Wires per port Torque N•m (lb-in) Ports/ pole Stud/ connector size Studs/ pole SCCR (kA) 13.6 (120) 1 1/4-20 x 3/4” stud 1 200† 16280-_** 13.6 (120) 1 M6 x 1” stud 1 200† 16280-_-M 13.6 (120) 1 1/4-20 tapped hole 1 10 16281-_** 56.5 (500) 1 1/4-20 x 1” stud 2 10 16378-_ 56.5 (500) 1 3/8-16 x 1” stud 1 10 16383-_ 56.5 (500) 2 3/8-16 x 1-5/8” stud 2 10 16582-_ Catalog no. Connector - to - stud 2/0 - 1 Cu/Al (Str) 1, 2, 3 2 - 3 Cu/Al 175 4 - 8 Cu/Al 1-2 10 - 14 Cu 2/0 - 1 Cu/Al (Str) 2, 3 2 - 3 Cu/Al 175 4 - 8 Cu/Al 10 - 14 Cu 2 - 3 Cu/Al 175 4 - 8 Cu/Al 10 - 14 Cu 380 3/0 - 1/0 Cu/Al (Str) 1 - 6 Cu/Al 500kcmil - 4/0 Cu/Al (Str) 1, 2, 3 380 3/0 - 1/0 Cu/Al (Str) 1 - 6 Cu/Al 500kcmil - 4/0 Cu/Al (Str) 1, 2, 3 760 1 1-2 500kcmil - 4/0 Cu/Al (Str) 1, 2, 3 1 1-2 2/0 - 1 Cu/Al (Str) 1, 2, 3 1 3/0 - 1/0 Cu/Al (Str) 1 - 6 Cu/Al 1 1-2 1 1-2 1 1-2 Stud - to - stud 1, 2, 3 175 1/4-20 x 3/4” stud 1 1/4-20 x 3/4” stud 1 10 16290-_** 1, 2, 3 250 3/8-16 x 1-1/8” stud 1 3/8-16 x 1-1/8” stud 1 10 16390-_ 1, 2, 3 310 3/8-16 x 1-7/16” stud 1 1/4-20 x 9/16” stud 2 10 16395-_ 1, 2, 3 400 3/8-16 x 1-1/8” stud 1 3/8-16 x 1-1/8” stud 1 10 16392-_-H†† 1, 2, 3 400 1/2-13 x 1-1/16” stud 1 1/2-13 x 1-1/16” stud 1 10 16394-_ 1, 2, 3 400 3/8-16 x 1-7/16” stud 1 3/8-16 x 1-7/16” stud 2 10 16591-_** 1, 2, 3 600 1/2-13 x 1” stud 1 1/2-13 x 1” stud 1 10 16593-_ * 75°C wire (higher temperature rated wire acceptable with appropriate derating). Using a ferrule on a stranded conductor requires a correctly sized UL Listed ferrule (customer supplied) applied according to the manufacturer’s specifications. Ferrule ratings apply to copper wire only. ** Not covered by CSA certification. † See table below for the tested upstream overcurrent protective devices necessary for achieving this SCCR. †† Configuration includes washers and hex nuts for each stud. Short-Circuit Current Rating (SCCR) data for block 16280-_ Conductors (AWG) Catalog no. No. of poles Lineside 16280-_ 1, 2, 3 2/0 - 8 Fuse class/Bussmann series symbol/amp rating Loadside Class J LPJ Class RK1 LPN-RK (250 V) LPS-RK (600 V) Class RK5 FRN-R (250 V) FRS-R (600 V) Class T JJN (300 V) JJS (600 V) SCCR (kA) 1/4-20x3/4 stud 200 200 60 200 200 Data sheet no. 10535 9-14 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Power distribution and terminal blocks — 9 160, 162, 163 and 165 UL Recognized power splicer blocks Splicer blocks allow for increasing or decreasing wire size within a circuit to accommodate different connections from the power source to the branch load. These blocks are factory configured from 1- to 4-poles (catalog number dependent) for wire sizes up to 500kcmil and amp ratings up to 760 A. Optional covers are available to enhance safety (order covers separately). These blocks are UL Recognized to UL 1059 and rated for use in UL 508A industrial control panels. Ratings • Volts 600 V • Amps 115 to 760 A • SCCR up to 200 kA* (see table for SCCR by catalog number) Dual wire port application • Rated for dual wire port application to increase the possible number of lineside and loadside connections. E.g., 16303-1 can accept two wires into the lineside port (1/0 - #6 Cu/Al) and two wires per port (2 connections per pole total) on the loadside lug (1/0 - #6 Cu/Al). • Dual wire applications are only viable when using two wires of the same size, stranding, and insulating and conductor material in the same port. Ferrule terminal application • Bussmann series splicer blocks are rated for use with UL Listed ferrules (see catalog number table for details). Ferrule ratings apply to copper wire only. • Ferrule applications allow for the use of a broader range of conductor stranding and simulate a more efficient, solid wire connection with the PDB terminal port • Always use UL Listed ferrules in accordance with the manufacturer’s specifications and instructions Optional covers Conductors† Electrical safety can be enhanced by installing optional covers. From the table below, order the cover catalog number that matches the block catalog number. Block catalog no. Poles Cover catalog no. • Stranded 75°C copper and aluminum 16000-2 2 CPB160-2* • Higher temperature rated conductors permitted with appropriate derating 16000-3 3 CPB160-3* 16000-4 4 CPB160-4* 16003-2 2 CPB160-2* 16003-3 3 CPB160-3* 16003-4 4 CPB160-4* 16005-2 2 CPB160-2* † As specified in the catalog number table. Agency information • UL 1059 Recognized, Guide XCFR2, File E62622 16005-3 3 CPB160-3* • CSA® Certified, Class 6228-01, File 15364 16005-4 4 CPB160-4* 16200-1 1 CPB162-1* 16200-2 2 CPB162-2* 16200-3 3 CPB162-3* 16201-1 1 CPB162-1* 16201-2 2 CPB162-2* 16201-3 3 CPB162-3* 16204-1 1 CPB162-1* 16204-2 2 CPB162-2* 16204-3 3 CPD162-3* 16301-1 1 CPDB-1* 16301-2 2 CPDB-2* 16301-3 3 CPDB-3* 16303-1 1 CPDB-1* 16303-2 2 CPDB-2* 16303-3 3 CPDB-3* 16306-1 1 CPDB-1* 16306-2 2 CPDB-2* 16306-3 3 CPDB-3* 16500-1 1 CPDB165** 16500-2 2 CPDB165** The prefix “16204” defines the block’s lineside and loadside characteristics (i.e., conductor port per pole that accepts 2/0 - #14 Cu, or 2/0 - #12 Al conductors) 16500-3 3 CPDB165** 16504-1 1 CPDB165** 16504-2 2 CPDB165** • The suffix “3” in this example defines this as a three-pole block 16504-3 3 CPDB165** • See the catalog number tables for details on the available lineside/ loadside characteristics Flammability rating • UL 94 V0 Optional covers • See table for catalog numbers specific to each block How to order From the catalog number tables, select the catalog number that defines the desired lineside/loadside port and conductor characteristics. Add to the catalog number the suffix that defines the desired pole configuration. Note, you must select from the available number of poles for each catalog number. These appear in the second column of the catalog number tables. Catalog number example — 16204-3 is a 3-pole 16204 Where: • Power distribution and terminal blocks * Maximum SCCR contingent upon the application of an upstream current-limiting overcurrent protective device. See table for fusing requirements. * Cover catalog number provides one individual cover for each block. ** Order one cover for each pole. Data sheet no. 10534 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 9-15 9 — Power distribution and terminal blocks Lineside No. Current of rating poles (A) Line/load port configuration 1, 2, 3 115 1, 2, 3 150 2, 3, 4 1, 2, 3 175 175 Loadside Wire size (Str/ferrule unless noted)* 2 - 3 Cu/Al (Str) 4 - 6 Cu/Al (Str) 8 Cu/Al (Str) 10 - 14 Cu (Str) 1/0 - 3 Cu (Str) 4 - 6 Cu (Str) 8 Cu (Str) 10 - 14 Cu (Str) 2/0 - 1 Cu/Al (Str) 2 - 8 Cu/Al 10 - 12 Al (Str) 10 - 14 Cu 4 - 8 Cu/Al 10 - 14 Cu 2/0 - 1 Cu/Al (Str) 2 - 8 Cu/Al 10 - 12 Al (Str) 10 - 14 Cu 4 - 8 Cu/Al 10 - 14 Cu Wires per port 1 1 1 1 1 1 1 1 1 1 1 1 2 2 1 1 1 1 2 2 Torque N•m (lb-in) 5.6 (50) 5.1 (45) 4.5 (40) 4.0 (35) 5.6 (50) 5.1 (45) 4.5 (40) 4.0 (35) Ports/ Pole 1 1 12.4 (110) 4.0 (35) 1 13.6 (120) 12.4 (110) 4.0 (35) 1 13.6 (120) Wire size (Str/ferrule unless noted)* 2 - 3 Cu/Al (Str) 4 - 6 Cu/Al (Str) 8 Cu/Al (Str) 10 - 14 Cu (Str) 1/0 - 3 Cu (Str) 4 - 6 Cu (Str) 8 Cu (Str) 10 - 14 Cu (Str) 2/0 - 1 Cu/Al (Str) 2 - 8 Cu/Al 10 - 12 Al (Str) 10 - 14 Cu 4 - 8 Cu/Al 10 - 14 Cu 2/0 - 1 Cu/Al (Str) 2 - 8 Cu/Al 10 - 12 Al (Str) 10 - 14 Cu 4 - 8 Cu/Al 10 - 14 Cu Wires per port 1 1 1 1 1 1 1 1 1 1 1 1 2 2 1 1 1 1 2 2 Torque N•m (lb-in) 5.6 (50) 5.1 (45) 4.5 (40) 4.0 (35) 5.6 (50) 5.1 (45) 4.5 (40) 4.0 (35) Ports/ SCCR (kA) pole Catalog no. 1 10 16200-_** 1 10 16201-_ 1 10 16000-_** 1 200† 12.4 (110) 4.0 (35) 13.6 (120) 12.4 (110) 4.0 (35) 16204-_ 13.6 (120) 2, 3, 4 255 250kcmil - 6 Cu 1 42.4 (375) 1 250kcmil - 6 Cu 1 42.4 (375) 1 10 16003-_** 1, 2, 3 255 250kcmil - 6 Cu 1 42.4 (375) 1 250kcmil - 6 Cu 1 42.4 (375) 1 10 16301-_ 350kcmil - 2/0 Cu/Al (Str) 1/0 Cu/Al (Str) 1 1-2 350kcmil - 2/0 Cu/Al (Str) 1/0 Cu/Al (Str) 1 1-2 10 16005-_** 1-2 1 - 6 Cu/Al 1-2 31.1 (275)†† 1 1 - 6 Cu/Al 350kcmil - 2/0 Cu/Al (Str) 1/0 Cu/Al (Str) 1 1-2 350kcmil - 2/0 Cu/Al (Str) 1/0 Cu/Al (Str) 1 1-2 10 16303-_ 1-2 1 - 6 Cu/Al 1-2 31.1 (275)†† 1 1 - 6 Cu/Al 500kcmil - 4/0 Cu/Al (Str) 3/0 - 1/0 Cu/Al (Str) 1 1-2 500kcmil - 4/0 Cu/Al (Str) 3/0 - 1/0 Cu/Al (Str) 1 1-2 56.5 (500) 1 10 16306-_ 1 - 6 Cu/Al 1-2 1 - 6 Cu/Al 1-2 350kcmil - 2/0 Cu/Al (Str) 1/0 Cu/Al (Str) 1 - 4 Cu/Al 6 Cu/Al 500kcmil - 4/0 Cu/Al (Str) 3/0 - 1/0 Cu/Al (Str) 1 1-2 1-2 2 1 1-2 350kcmil - 2/0 Cu/Al (Str) 1/0 Cu/Al (Str) 1 - 4 Cu/Al 6 Cu/Al 500kcmil - 4/0 Cu/Al (Str) 3/0 - 1/0 Cu/Al (Str) 1 1-2 1-2 2 1 1-2 31.1 (275)†† 2 10 16500-_ 56.5 (500) 2 10 16504-_ 1 - 6 Cu/Al 1-2 1 - 6 Cu/Al 1-2 2, 3, 4 1, 2, 3 1, 2, 3 310 310 380 1, 2, 3 620 1, 2, 3 760 31.1 (275)†† 1 31.1 (275)†† 1 56.5 (500) 1 31.1 (275)†† 2 56.5 (500) 2 * 75°C wire (higher temperature rated wire acceptable with appropriate derating). Using a ferrule on a stranded conductor requires a correctly sized UL Listed ferrule (customer supplied) applied according to the manufacturer’s specifications. Ferrule ratings apply to copper wire only. ** Not covered by CSA certification. † See table below for the tested upstream overcurrent protective devices necessary for achieving this SCCR. †† Torque rating for dual wire and ferrule application is 30.5 N•m (270 lb-in). Short-Circuit Current Rating (SCCR) data for block 16204-_ Conductors (AWG) Catalog no. No. of poles Lineside 16204-_ 1, 2, 3 2/0 - 8 Fuse class/Bussmann series symbol/amp rating Loadside Class J LPJ Class RK1 LPN-RK (250 V) LPS-RK (600 V) Class RK5 FRN-R (250 V) FRS-R (600 V) Class T JJN (300 V) JJS (600 V) SCCR (kA) Min. enclosure size 2/0 - 8 200 200 60 200 200 16 x 16 x 6.75 Data sheet no. 10534 9-16 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Power distribution and terminal blocks — 9 11675 250 V screw/quick connect power terminal block 11725 600 V screw/quick connect power terminal block Lineside screw connection, loadside 0.250" quick-connect (3 per pole) power terminal block available from 2 to 6 poles (see catalog number table). Lineside screw connection, loadside 0.250" quick-connect (4 per pole) power terminal block available in 2, 3 or 4 poles (see catalog number table). Ratings Ratings Volts 250 Vac/dc • • Amps Up to 40 A • • SCCR 10 kA per UL 508A, Table SB4.1 • • Agency Information Agency information • UL Recognized, Guide XCFR2, File E62622, CSA 47235, CE • • 8-14 AWG Cu. • 9 lb-in (1.0 N•m) max. • • Catalog no. (poles) 11675-2 UL Recognized, Guide XCFR2, File E62622, CSA 47235, CE Conductors/torque ratings Conductors/torque ratings • Volts 600 Vac/dc Amps up to 70 A SCCR 10 kA per UL 508A Table SB4.1 2 – 14 AWG Cu 8 AWG Al. 45 lb-in (5.1 N•m) max. Catalog no. (poles) 11675-3 11675-4 11675-6 11725-2 11725-3 11725-4 14002 600 V barrier terminal block 14004 600 V dead front terminal block Barrier terminal block available from 2 to 6 poles with box lug terminals. 2- and 3-pole versions available with loadside 0.25" quickconnect terminals (4 per pole). See catalog numbers table. Dead front terminal block available from 2 to 12 poles (see catalog number table). Ratings • Ratings • • • • • Volts 600 Vac/dc Amps 115 A SCCR 10 kA per UL 508A Table SB4.1 Agency information • Agency information • UL Recognized, Guide XCFR2, File E62622, CSA 47235, CE Conductors/torque ratings* • • Volts 600 Vac/dc Amps 90 A SCCR 10 kA per UL 508A Table SB4.1 Conductors • • Wire; 2 – 14 AWG Cu, 8 AWG Al. Torque; 2-3 AWG 50 (5.6 N•m), 4-6 AWG 45 (5.1 N•m), 8 AWG 40 (4.5 N•m), 10-14 AWG 35 (3.9 N•m) UL Recognized, Guide XCFR2, File E62600, CSA 47235, CE 4 – 14 AWG Cu 8 AWG Al Marking • Numeral marking molded into the top of the block is standard * Consult factory for torque ratings on "Q" quick-connect terminal option. Catalog no. (poles) • Marking strip optional on 2- and 3-pole configurations. See catalog numbers table. 14004-2 14004-5 14004-8 14004-3 14004-6 14004-9 14004-4 14004-7 14004-10 14004-12 Power distribution and terminal blocks Marking Catalog no. (poles) Standard Loadside quickconnect terminals Standard with marking strip 14002-2 14002-5 Q14002-2 14002-2A 14002-3 14002-6 Q14002-3 14002-3A 14002-4 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 9-17 BUSSMANN SERIES Calculate available fault current anytime, anywhere Eaton’s Bussmann™ series FC2 Available Fault Current Calculator is a simple-to-use mobile and web-based application that calculates single- and three-phase system fault current levels. The free tool is available for all Apple® iPhones, iPads, and Android™ mobile devices and allows you to quickly and easily determine available fault current levels anywhere in an electrical distribution system. What’s more, FC2 has English, Spanish and French modes to address local language and equipment marking requirements. Download today from the Android or Apple store or visit Eaton.com/bussmannseries to learn more. Follow us on social media to get the latest product and support information. Connector products — 10 Section page Description Compact rail and panel mount blocks Connector products to simplify wiring NDN DIN-Rail and C-Rail feed through blocks 2-3 N512, NFT2, NFT3, NC3, NSE3, NSS3 C-Rail feed through blocks 4-5 15188, PLU3, PLU1, PSU1 depluggable DIN-Rail and C-Rail blocks 6-7 KT3, KT4 multi-pole panel mount blocks 7 BNQ21, BQQ41 quick-connect panel mount blocks 8 Power feed through terminal blocks C7021 1- to 6-pole block 9 Double row terminal blocks TB100 2- to 36-pole blocks 10-11 TB200 and TB200HB 2- to 30-pole blocks 12-13 TB300 and TB345 2- to 24-pole blocks 14-15 Accessories for double row terninal blocks Marking options and covers 16 Top and bottom marking strips for terminal blocks 17 Double row terminal blocks continued TB400 2- to 12-pole blocks 18 KU 2- to 12-pole blocks 19 Mounting accessories End brackets DIN-Rail and C-Rail mounting rails and brackets BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 20 10-1 Connector products Contents 10 — Connector products NDN DIN-Rail feed through blocks The NDN feed through blocks feature a compact line of terminal blocks suitable for both 35mm DIN-Rail or C-Rail applications. Products easily snap onto the mounting rail for a quick, simple, low-cost solution. Available accessories include jumpers and marking tape. UL E62622 CSA File 15364 CSA File 47235 (NDN1, NDN111) NDN3 NDNV4 Approval Approval Approval Technical data Technical data Technical data Rated voltage 600V Rated voltage 600V Rated voltage Rated Current 30A Rated Current 30A Rated Current Center spacing, in (mm) Conductor cross-section, flexible (AWG/mm2) 0.25 / 6.35 22~10 / 0.3~5.3 0.3 / 7.62 22~10 / 0.3~5.3 Conductor cross-section, flexible (AWG/mm2) 18~6 / 0.8~13.3 4 Number of Poles 3 Number of Poles 3 Circuits per foot 38 Circuits per foot 30 Torque(N•m) 2 Torque(N•m) 2 Torque(N•m) 4 18 Torque(lb-in) 18 Torque(lb-in) #6-32 25.4 x 34 x 42.4 Colors Block Cat. no. White (standard) NDNV4-WH Black NDNV4-BK Accessories Cat. no. 4 circuits JN4 Marking tape 35mm DIN-Rail C-Rail #6-32 WxHxD(mm) 23.9 x 33.3 x 42.4 Colors Cat. no. White (standard) NDN3-WH Blue NDN3-BL Accessories Cat. no. 2 circuits JNDN3 35 Screw #10-32 WxHxD(mm) 29.7 x 36.8 x 42.4 Colors Cat. no. White (standard) NDN63-WH Black NDN63-BK Accessories Cat. no. 2 circuits JN1 MTC6 MT12-1-2 MT12-1-2 DRL35MML DRL35MMHI NFTA NRA DRL35MML DRL35MMHI NFTA NRA — — Screw DRL35MML DRL35MMHI NFTA NRA 35mm DIN-Rail C-Rail — — Dimensions — in (mm) 35mm DIN-Rail C-Rail — — Dimensions — in (mm) 1.0 (25.4) Dimensions — in (mm) Marking tape 1.67 1.47 1.23 (42.41) (37.33) (31.24) 1.50 (38.10) 1.47 (37.33) 1.67 (42.41) 1.67 (42.41) 1.34 (34.04) 10-2 0.375 / 9.52 48 WxHxD(mm) Modular option Conductor cross-section, flexible (AWG/mm2) 65A Center spacing, in (mm) Circuits per foot Screw Mounting Center spacing, in (mm) 600V Number of Poles Torque(lb-in) Jumper NDN63 0.94 (23.87) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 1.31 (33.27) 1.17 (29.71) Eaton.com/bussmannseries 1.45 (36.83) Connector products Connector products — 10 NDN1 NDN111 Approval Approval Technical data Technical data Rated voltage 600V Rated voltage 600V Rated Current 90A Rated Current 90A Center spacing in (mm) Conductor cross-section, flexible (AWG/mm2) 0.635 / 16.31 18~2 / 0.8~33.6 Center spacing in (mm) Conductor cross-section, flexible (AWG/mm2) 0.635 / 16.31 18~2 / 0.8~33.6 Number of Poles 1 Number of Poles 3 Circuits per foot 18 Circuits per foot 18 Torque(N•m) 3.6 Torque(N•m) 3.6 32 Torque(lb-in) Torque(lb-in) Screw 1/4-28 WxHxD(mm) 15 x 30.3 x 43.5 Colors Cat. no. NDN1-WH White (standard) Accessories Cat. no. — — 35mm DIN-Rail C-Rail 32 Screw 1/4-28 WxHxD(mm) 47.5 x 36.6 x 43.5 Colors Cat. no. White (standard) NDN111-WH Black NDN111-BK Accessories Cat. no. 2 circuits JN1 MT12-1-2 MT12-1-2 DRL35MML DRL35MMHI NFTA NRA DRL35MML DRL35MMHI NFTA NRA 35mm DIN-Rail C-Rail NDN111A-WH, NDN111A-BK Dimensions — in (mm) Dimensions — in (mm) Mtg. holes 0.18 (4.57) dia. 0.28 (7.11) c'bores 1.46 (37.13) 1.71 (43.48) 1.32 (33.68) 1.71 (43.48) Dovetail option 0.62 (15.75) 1.87 (47.50) Dovetail Option 0.59 (14.99) 1.43 (36.31) 1.44 (36.57) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 10-3 10 — Connector products C-Rail feed through terminal blocks 12-pole C-Rail terminal blocks provide a low-profile, compact footprint solution for various wire connection applications. Products feature an easy, snap-on installation method and an array of accessories including jumpers and marking strips. UL E62622 (excluding N512) CSA File 15364 CSA File 47235 (NFT3) N512 Approval Approval Approval Technical data Technical data Technical data Rated voltage 300V 600V Rated voltage 600V Rated voltage 600V Rated current 20A 5A Rated Current 40A Rated Current 40A Center spacing in (mm) Conductor cross-section, flexible (AWG/mm2) 0.197 / 5.0 22~12 / 0.3~3.3 0.28 / 7.13 Conductor cross-section, flexible (AWG/mm2) 22~8 / 0.3~8.4 Center spacing in (mm) Conductor cross-section, flexible (AWG/mm2) 0.39 / 9.91 22~8 / 0.3~8.4 12 Number of Poles 2 Number of Poles 3 Circuits per foot 60 Circuits per foot 38 Circuits per foot 28 Torque(N•m) 1.4 Torque(N•m) 2 Torque(N•m) 2 12 Torque(lb-in) 18 Torque(lb-in) Screw #4-48 WxHxD(mm) 61.0 x 27.7 x 22.4 Colors Cat. no. Black (standard) Block Screw — Accessories 12 circuits 16.5 x 34.7 x 42.8 Colors Cat. no. JN512 NFT2-WH White (standard) — Cat. no. Marking tape #8-32 WxHxD(mm) N512-BK — Mounting Center spacing in (mm) Number of Poles Torque(lb-in) Jumper NFT3 NFT2 Cat. no. 2 circuits JN2 AT512 NFTA NRA C-Rail Dimensions — in (mm) WxHxD(mm) Colors NFTA NRA 30.0 x 32.9 x 31.4 Cat. no. White (standard) NFT3-WH NFT3-BK Accessories 2 circuits Cat. no. JN3 MT12-1-2 MT12-1-2 C-Rail 18 #8-32 Black — Accessories Screw NFTA NRA C-Rail Dimensions — in (mm) Dimensions — in (mm) 2.40 (60.96) 0.60 (15.44) 0.07 (1.78) 1.68 (42.82) 1.09 (27.68) 10-4 1.29 (32.94) 0.93 (23.80) 0.88 (22.35) 1.18 (29.97) 0.36 (9.14) 1.23 (31.34) 1.23 (31.37) 0.65 (16.51) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 1.29 (32.94) Connector products — 10 Connector products 3-pole NC3 NSE3 NSS3 Approval Approval Approval Technical data Technical data Technical data Rated voltage 600V Rated voltage 600V Rated voltage 600V Rated Current 175A Rated Current 115A Rated Current 30A Center spacing in (mm) 1.06 / 26.92 Conductor cross-section, flexible (AWG/mm2) 14~2/0 /2.1~67.4 Cu/AL Center spacing in (mm) Conductor cross-section, flexible (AWG/mm2) 1.06 / 26.92 Ring terminals only Center spacing in (mm) Conductor cross-section, flexible (AWG/mm2) 0.385 / 9.77 Ring terminals only Number of Poles 3 Number of Poles 3 Number of Poles 3 Circuits per foot 11 Circuits per foot 11 Circuits per foot 28 Torque(N•m) 5.1 Torque(N•m) 3.6 Torque(N•m) 1.4 Torque(lb-in) 45 Torque(lb-in) 32 Torque(lb-in) 12 Screw 5/16 - 24 WxHxD(mm) 79.4 x 44.5 x 44.5 Colors Cat. no. Screw — — Accessories Cat. no. — — Accessories 2 circuits — NFTA NRA Dimensions — in (mm) #6-32 WxHxD(mm) 31.5 x 33.7 x 31.8 Colors Cat. no. JNSE3 — Accessories Cat. no. 2 circuits JNSS3 MT12-1-2 — NFTA Series NRA Series Panel mount C-Rail Dimensions — in (mm) NSS3-WH White (standard) — Cat. no. MT12-1-2 Panel mount C-Rail Screw NSE3-WH White (standard) — Cat. no. — 79.2 x 38.9 x 445 Colors NC3-WH White (standard) 1/4 - 28 WxHxD(mm) MT12-1-2 — NFTA NRA Panel mount C-Rail Dimensions — in (mm) 1.25 (31.75) 3.12 (79.38) 1.75 (44.45) 0.250 x 0.190 mtg. slots 1.24 (31.50) 1.75 (44.45) 1.75 (44.45) 1.25 (31.75) 1.25 (31.75) 1.32 (33.73) 1.53 (38.86) 0.250 x 0.190" mtg. slots 3.12 (79.24) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 10-5 10 — Connector products DIN-Rail depluggable blocks Depluggable terminal blocks are available for both 35mm DIN-Rail and C-Rail applications. These blocks provide a simple depluggable* option for panel wiring applications with the convenience of quick, easy, snap-on installation. Product accessories such as jumpers and marking tape are available for most products. UL E62622 PLU3 15188 CSA File 15364 PLU1 CSA File 47235 (15188 Series) Approval Approval Approval * Not for use as a load break disconnect. Technical data Technical data Technical data Rated voltage Rated Current Center spacing in (mm) 600V 30A Rated Current 70A Center spacing in (mm) Conductor cross-section, flexible (AWG/mm2) 0.39 / 9.91 22~8 / 0.3~8.4 Center spacing in (mm) Conductor cross-section, flexible (AWG/mm2) 0.3 / 7.62 18~4 / 0.8~21.2 Number of Poles 3 Number of Poles 1-3 Circuits per foot 32 Circuits per foot 28 Circuits per foot 19 Torque(N•m) 1.4 Torque(N•m) 2 Torque(N•m) 3.6 Torque(lb-in) 12 Torque(lb-in) 18 Torque(lb-in) Screw #6-32 Screw #8-32 3-Pole 4-Pole WxHxD(mm) 30.2 x 49.3 x 47.8 39.2 x 49.3 x 47.8 3-Pole WxHxD(mm) 31.8 x 47.0 x 45.6 Colors Cat. no. Colors Cat. no. 32 Screw 1/4 - 28 1-Pole 2-Pole 3-Pole WxHxD(mm) 18.5 x 47.0 x 45.6 34.0 x 47.0 x 45.6 49.5 x 47.0 x 45.6 Colors Cat. no. White (standard) 15188-3 White (standard) PLU3-WH White (1-Pole) White (standard) 15188-4 Black PLU3-BK White (2-Pole) PLU11-WH White (3-Pole) PLU111-WH Accessories Configurable Option Rated voltage 40A 3 or 4 Block Mounting 600V Rated Current 16~12 / 1.3~3.3 Number of Poles Marking tape Rated voltage 0.375 / 9.52 Conductor cross-section, flexible (AWG/mm2) Jumper 600V Accessories Cat. no. 2 circuits 15188J-2-J, J15188 — Cat. no. 2 circuits JN3 DRL35MMLO DRL35MMHI Reverse Wiring Locking Reverse; Locking Accessories Cat. no. 2 circuits JN1 MT12-1-2 — 35mm DIN-Rail PLU1-WH 15188-_R 15188-_S 15188-_RS NFTA NRA C-Rail (AL) — MT12-1-2 NFTA NRA C-Rail (AL) — — — Options offered for both pole lengths Dimensions — in (mm) Dimensions — in (mm) Dimensions — in (mm) 3 Pole = 1.19 (30.22) 4 Pole = 1.56 (39.62) 1.87 (47.49) 1.25 (31.75) 1.94 (49.27) 0.59 (14.98) 1.85 (46.99) 1.48 (37.59) 1.79 (45.64) IN-LINE WIRING DIRECTION 1.25 (31.75) 3 Pole = 1.19 (30.22) 4 Pole = 1.56 (39.62) 0.375 (9.52) 1.25 (31.75) 1.85 (46.99) 0.22 (5.58) 1.25 (31.75) 1.94 (49.27) REVERSE WIRING DIRECTION 10-6 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Connector products — 10 Panel mount multi-pole blocks Connector products Multi-pole panel mount terminal blocks provide a compact, high density circuit connection solution without the necessity of a mounting rail. These products are designed to be nested together to form one string of circuit connections. UL E62622 CSA 15364 PSU1 KT4 KT3 Approval Approval Approval Technical data Technical data Technical data Rated voltage 600V Rated voltage 600V Rated voltage 600V Rated Current 45A Rated Current 40A Rated Current 30A Center spacing in (mm) Center spacing in (mm) 0.625 / 15.88 0.39 / 9.91 Center spacing in (mm) only 1-3 Number of Poles 3 Number of Poles 4 Circuits per foot 19 Circuits per foot 28 Circuits per foot 48 Torque(N•m) 2.7 Torque(N•m) 2 Torque(N•m) 2 Torque(lb-in) 24 Torque(lb-in) 18 Torque(lb-in) Ring terminals Number of Poles Screw #10-32 3-Pole WxHxD(mm) 50.3 x 49.1 x 62.1 Colors Cat. no. Screw #8-32 WxHxD(mm) Cat. no. White (standard) Accessories PSU111-WH White (3-Pole) Jumper Cat. no. 2 circuits Accessories Cat. no. — Mounting — MT12-1-2 — Cat. no. White KT4-WH-A* White KT4-WH-B* Cat. no. 4 circuits JN4 MTC6 — KAD Panel mount Dimensions — in (mm) 1.87 (47.63) — Dimensions — in (mm) 1.25 (31.75) 0.98 (24.99) 0.25 (6.35) 1.22 (31.04) — 43.8 x 34.0 x 32.2 MT12-1-2 Panel mount • Mounting foot NFTA NRA C-Rail (AL) WxHxD(mm) Accessories JN3 Marking tape #6-32 Colors KT3-WH 22~10 / 0.3~5.3 18 Screw 59.5 x 31.8 x 31.0 Colors Block 22~8 / 0.3~8.4 Conductor cross-section, flexible (AWG/mm2) 0.25 / 6.35 Conductor cross-section, flexible (AWG/mm2) Conductor cross-section, flexible (AWG/mm2) 0.62 (15.88) 0.37 (9.40) 1.26 (32.23) #8 screw clearance KAD end mtg. adapter Dimensions — in (mm) 1.93 (49.12) 1.48 (37.64) 0.625 (15.88) 2.34 (59.51) 1.34 (34.04) 1.25 (31.75) * The KT4 products are designed to be nested together to form one string of circuit connectors. When used in series, order catalog numbers KT4WH-A and KT4-WH-B. 2.44 (62.10) 0.43 (11.10) 1.25 (31.75) 1.30 (33.00) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 10-7 10 — Connector products Panel mount quick-connect blocks A time saving alternative for electrical connections, the Bussmann series quickconnect terminal blocks offer a convenient solution. With male spade terminals, wire connections are made quickly and simply with these terminal blocks. UL E62622 CSA 15364 BNQ21 BQQ41 Approval Approval Technical data Technical data Rated voltage 600V Rated voltage 600V Rated Current 40A Rated Current 30A Center spacing in (mm) 0.437 / 11.1 Conductor cross-section, flexible (AWG/mm2) 22~8 / 0.3~8.4 0.437 / 11.1 Conductor cross-section, flexible (AWG/mm2) 0.25" Quick-connect terminals only Number of Poles 1 Number of Poles 1 Circuits per foot 24 Circuits per foot 24 Torque(N•m) 2 Torque(N•m) NA Torque(lb-in) 18 Torque(lb-in) NA Screw #8-32 WxHxD(mm) Screw 33.3 x 35.8 x 37.3 Colors Block Cat. no. Cat. no. — — BQE — Panel mount • Mounting foot Dimensions — in (mm) #BQE (end mtg. adaptor) Cat. no. BQQ41-WH White (standard) Accessories — Panel mount • Mounting foot 33.3 x 35.8 x 37.3 Colors Cat. no. — NA WxHxD(mm) BNQ21-WH White (standard) Accessories Mounting Center spacing in (mm) — BQE Dimensions — in (mm) #8 mtg. screw #BQE (end mtg. adaptor) #8 mtg. screw 0.56 (14.28) 0.56 (14.28) 1.47 (37.33) B A 10-8 1.47 (37.33) 1.41 (35.81) B A BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 1.41 (35.81) Eaton.com/bussmannseries Connector products — 10 C7021 power feed through terminal blocks Dimensions — mm (in) C 9.6 28.0 (0.38) (1.10) 15.8 (0.62) With mounting ends 5.4 (0.21) 15.8 (0.62) 55.7 (2.19) 12.5 (0.49) Ø 9.0 TYP (0.35) 7.9 (0.31) 1/4-20 UNC-2A Thread TYP A Ratings Ø12.2 TYP (0.48) B 17.5 TYP (0.69) • Volts 300 V • Amps 115/175 A* per pole * 175 achieved using both studs in parallel, 115 A using a single stud per line. Without mounting ends 15.0 TYP (0.59) 24.0 (0.94) 12.7 (0.50) Agency information 33.0 (1.30) • cURus, Guides XCFR2, XCFR8, File E62622 • CE A Panel cutouts Poles: 1- to 6 • Wire range: AWG #3/0-8 • Center spacing: 0.69" (18mm) • Bolt hole spacing: 0.625" or 5/8" (16mm) • Stud: Standard 1/4-20 stud (tin-plated brass) or optional M6 stud. • Mounting: #6 thread cutting screws (not included) or optional mounting ends. • Torque: 36 lb-in. • Operating temperature: 130°C (266°F) max. Typical applications • Applications requiring up to 175 A utilizing a 2-hole compression lug on 5/8" centers • Input/output block for telecommunications power panels • To eliminate busbars 14.5 TYP (0.57) E 14.2 ( ø.56) 1.6 (R.06) 30.0 (1.18) Specifications • Blind Hole for #6 Thread Cutting Screw 14.5 TYP (0.57) Catalog no. A B C D E C7021-01-X with mounting ends C7021-02-X 17.5 (0.69) — 54.4 (2.14) 67.3 (2.65) 31.8 (1.25) C7021-03-X 34.9 (1.37) — 70.9 (2.83) 84.8 (3.34) 49.2 (1.94) C7021-04-X 52.3 (2.06) — 89.3 (3.52) 102.2 (4.02) 66.7 (2.63) C7021-05-X 69.8 (2.75) — 106.8 (4.20) 119.7 (4.71) 84.2 (3.31) C7021-06-X 87.2 (3.44) — 124.2 (4.89) 134.1 (5.40) 101.7 (4.00) C7021-01N-X without mounting ends C7021-02N-X 17.5 (0.69) 36.1 (1.42) — — 31.8 (1.25) C7021-03N-X 34.9 (0.69) 53.5 (2.11) — — 49.2 (1.94) C7021-04N-X 52.3 (2.06) 71.0 (2.80) — — 66.7 (2.63) C7021-05N-X 69.8 (2.75) 88.4 (3.48) — — 84.2 (3.31) C7021-06N-X 87.2 (3.44) 105.9 (4.17) — — 101.7 (4.00) Catalog number build-a-code Symbol Poles Mount ends Studs 01 = 1-pole (2 studs) Blank = Mount ends Blank = Standard Blank = No hardware 02 = 2-pole (4 studs) N = No mount ends M6 = M6 studs 0 = Bulk pack, one set C7021 Hardware — 03 = 3-pole (6 studs) 1 = Bulk pack, two sets 04 = 4-pole (8 studs) 2 = Assembled, bottom 05 = 5-pole (10 studs) 3 = Assembled, top 06 = 6-pole (12 studs) 4 = Assembled, both sets BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 10-9 Connector products D Power feed through terminal block with two rows 1/4-20 studs capable of accommodating the industry standard two-hole compression lugs on both studs in parallel. 10 — Connector products TB100 double row terminal blocks Dimensions — in A Ratings* 0.14 (3.5) • 300 V • 30 A • Breakdown voltage: 3600 V TB100-08 UL File E62622/CSA File 47235; IEC Compliance 0.375 (9.5) 0.17 dia. (4.3) TB100-04SP Agency information 0.88 (22.3) 0.31 (7.9) * Maximum rating shown; some options may be rated lower. • 0.14 (3.5) B 0.30 (7.6) 0.41 (10.4) 0.25 (6.3) Specifications Poles: 2 to 36 Poles A B A B A B • Center spacing: 0.375" or 3/8" (10mm) 02 1.40 1.12 14 5.90 5.62 26 10.40 10.12 • Wire range: 14-22 AWG Cu 03 1.78 1.50 15 6.28 6.00 27 10.78 10.50 • Screw size: #6-32 phil-slot screws 04 2.16 1.88 16 6.66 6.38 28 11.16 10.88 05 2.53 2.25 17 7.03 6.75 29 11.53 11.25 06 2.90 2.62 18 7.40 7.12 30 11.90 11.62 07 3.28 3.00 19 7.78 7.50 31 12.28 12.00 08 3.66 3.38 20 8.16 7.88 32 12.66 12.38 09 4.03 3.75 21 8.53 8.25 33 13.03 12.75 10 4.40 4.12 22 8.90 8.62 34 13.40 13.12 11 4.78 4.50 23 9.28 9.00 35 13.78 13.50 12 5.16 4.88 24 9.66 9.38 36 14.16 13.88 13 5.53 5.25 25 10.03 9.75 • • Torque rating: 9 lb-in • Distance between barriers: 0.30" (8mm) • Mounting: #6 screws • Operating temperature: -40°C to 130°C (-40°F to 266°F) Materials • Molded black thermoplastic base, UL rated 94V0 • Tin-plated brass terminals • Zinc-plated steel screws Poles Poles 1" = 25.4mm. Catalog number build-a-code Symbol TB100 Poles Screw options Marking/cover Hardware options — 02 to 36 Blank = steel phil-slot, zinc-plated L1 to L6 QC1 to QC20 = Quick-connects 00 = screws shipped bulk Marking options, see page 10-16 Custom options† B = brass phil-slot, nickel-plated Special markings†, see page 10-16 J101 = flat slip-on jumper (2 position only) SP = steel SEMS phil-slot, zinc-plated 0J2 = over barrier jumpers 0J4 = over barrier jumpers † Contact factory for configuration. Accessories • Marker strips, see page 10-17 • Covers, see page 10-16 10-10 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Connector products — 10 B SP Brass phil-slot, nickel-plated F502-J (bulk) Steel SEMS phil-slot, zinc-plated B001-7021-J (bulk) Connector products Screw options Hardware options Quick-connects — assembled: 0.187" x 0.020" terminals, 13 amps maximum. For other orientations, contact factory. QC1 QC2 QC3 QC4 QC5 QC6 QC7 QC8 QC9 QC10 QC11 QC12 QC13 QC14 QC15 QC16 QC17 QC18 QC19 QC20 Quick-connects — bulk: minimum order 100 pieces per catalog number. QC101-J QC102-J QC103-J QC104-J QC105-J Flat — none QC 45° — none QC 90° — none Flat — Flat Flat — QC 45° QC106-J QC107-J QC108-J QC109-J Flat — QC 90° QC 45° — QC 45° QC 45° — QC 90° QC 90° — QC90° Jumpers — bulk: minimum order 100 pieces per catalog number. Contact factory for jumper assembly. J101 Flat slip-on (bulk: J101-J) OJ2 OJ4 Slip-on over barrier (bulk: OJ2-J) Closed over barrier (bulk: OJ4-J) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 10-11 10 — Connector products TB200 and TB200HB double row terminal blocks Dimensions — in A Ratings* • 0.16 (4.0) Volts TB200-10SP • 300 V (TB200) • 600 V (TB200HB) • Amps 30 A • Breakdown voltage 4800 V TB200 0.437 (11.1) 0.353 (8.9) 0.56 (14.2) 0.31 (7.8) TB200HB-06 A Agency information • 1.12 (28.4) 0.44 (11.2) 0.17 dia. (4.3) * Maximum rating shown; some options may be rated lower. 0.16 (4.0) B 0.16 (4.0) UL File E62622, CSA File 47235 and 15364; IEC Compliance 0.16 (4.0) B 0.90 1.37 (22.8) (34.8) 0.44 (11.2) Specifications TB200HB • Poles: 2 to 30 • Wire range: 12 - 22 AWG Cu • Center spacing: 0.437" or 7/16" (11mm) • Distance between barriers: 0.353" (9mm) • Screw size: #6-32 phil-slot screws • Torque rating: 9 lb-in • Mounting: #6 screws • Operating temperature: -40°C to 130°C (-40°F to 266°F) 0.437 (11.1) 0.17 dia. (4.3) • Molded black thermoplastic base UL rated 94V0 • Terminal plating: Tin-plated brass terminals • Zinc-plated steel screws 0.17 x 0.22 slots (4.3 x 5.6) 0.75 (19.0) 0.33 (8.4) Poles Materials 0.353 (8.9) A B A B A B 02 1.63 1.31 Poles 12 6.00 5.68 22 Poles 10.37 10.06 03 2.07 1.75 13 6.44 6.12 23 10.81 10.50 04 2.51 2.18 14 6.87 6.56 24 11.25 10.93 05 2.94 2.62 15 7.31 7.00 25 11.68 11.37 06 3.38 3.06 16 7.75 7.43 26 12.12 11.81 07 3.82 3.50 17 8.19 7.87 27 12.56 12.25 08 4.25 3.93 18 8.62 8.31 28 13.00 12.68 09 4.69 4.37 19 9.06 8.75 29 13.44 13.12 10 5.13 4.81 20 9.50 9.18 30 13.87 13.56 11 5.57 5.25 21 9.94 9.62 1" = 25.4mm. Catalog number build-a-code Symbol Barrier style TB Poles Screw options Marking/cover Hardware options 02 to 30 Blank = Steel phil-slot, zinc-plated L1 to L6 = Marking options, see page 10-16 QC1 to QC20 = Quick-connects 00 = Screws shipped bulk Special markings†, see page 10-16 Custom options† — 200 = Standard 200HB = High barrier B = Brass phil-slot, nickel-plated J201 = Flat slip-on jumper, 2 position only BS = Brass SEMS phil-slot, nickelplated 0J3 = Over barrier jumpers P = Steel SEMS (P-style) 0J5 = Over barrier jumpers SP = Steel SEMS phil-slot, zinc-plated 0J7 = Over barrier jumpers SS = Stainless steel SEMS, phil-slot ST = Stainless steel, phil-slot † Contact factory for configuration. Accessories • Marker strips, see page 10-17 • Covers, see page 10-16 10-12 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Connector products — 10 B BS SP P ST SS Brass phil-slot nickel-plated B001-7016-J (bulk) Brass SEMS phil-slot nickel-plated B001-7019-J (bulk) Steel SEMS phil-slot zinc-plated B001-7007-J (bulk) Steel SEMS (P-style) B001-7000-J (bulk) Stainless steel philslot F507-J (bulk) Stainless steel SEMS phil-slot B001-7085-J (bulk) Hardware options Quick-connects — assembled: 0.25" x 0.031" terminals, 20 amps maximum. For other orientations, contact factory. QC1 QC2 QC3 QC4 QC5 QC6 QC7 QC8 QC9 QC11 QC10 QC12 QC13 QC14 QC15 QC16 QC17 QC18 QC19 QC20 Quick-connects — bulk: minimum order 100 pieces per catalog number. QC201-J QC202-J QC203-J QC204-J QC205-J QC 45° — blank Flat — blank QC 90° — blank Flat — Flat Flat — QC 45° QC206-J QC207-J QC208-J QC209-J Flat — QC 90° QC 45° — QC 45° QC 45° — QC 90° QC 90° — QC 90° Jumpers — bulk: minimum. order 100 pieces per catalog number. Contact factory for jumper assembly. J201 OJ3 OJ5 OJ7 Flat slip-on (not available on TB200HB) J201-J (bulk) Slip-on over barrier for TB200HB OJ3-J (bulk) Closed over barrier for TB200HB OJ5-J (bulk) Closed over barrier for TB200 OJ7-J (bulk) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 10-13 Connector products Screw options 10 — Connector products TB300 and TB345 double row terminal blocks Dimensions — in Ratings* • • • 8-32 binding head screw - TB 300 10-32 binding head screw - TB 345 Volts 600 V A 0.22 (5.6) TB300-08 Amps • 30 A (TB300) • 45 A (TB345) TB300 and TB345 Breakdown voltage 7500 V TB345-06SP * Maximum rating shown; some options may be rated lower. B 0.90 1.33 (22.8) (33.8) 0.50 (12.7) 0.56 (14.2) Agency information 0.21 x 0.25 slots (5.3 x 6.3) 0.412 (10.4) 0.56 (14.2) 0.21dia. (5.3) 0.81 (20.5) 0.33 (8.4) UL File E62622, CSA File 47235; IEC Compliance Specifications Poles • Poles: 2 to 24 • Wire range: 8 - 22 AWG Cu • Center spacing: 0.562" or 9/16" (14mm) • Screw size • • TB300 — #8-32 phil-slot screws • TB345 — #10-32 phil-slot screws Torque rating • #8 screws - 16 lb-in • #10 screws - 20 lb-in Distance between barriers: 0.41" (10mm) • Mounting • TB300 — #8 screws • TB345 — #10 screws B A B A B 2.13 1.69 Poles 10 6.62 6.19 Poles 18 11.12 10.68 03 2.69 2.25 11 7.18 6.75 19 11.68 11.25 04 3.25 2.81 12 7.75 7.31 20 12.24 11.81 05 3.81 3.37 13 8.31 7.87 21 12.80 12.37 06 4.37 3.94 14 8.87 8.44 22 13.37 12.93 07 4.94 4.50 15 9.43 9.00 23 13.93 13.50 08 5.50 5.06 16 9.99 9.56 24 14.49 14.06 09 6.06 5.62 17 10.56 10.12 1" = 25.4mm. • • A 02 Operating temperature: -40°C to 130°C (-40°F to 266°F) Materials • Molded black thermoplastic base, UL rated 94V0 • Tin-plated brass terminals • Zinc-plated steel screws Catalog number build-a-code Symbol Screw size TB Poles Screw options Marking/cover Hardware options 02 to 24 Blank = Steel phil-slot, zinc-plated L1 to L6 marking options, see page 10-16 QC1 to QC20 = Quick-connects (TB300 only) 00 = Screws shipped bulk Special markings†, see page 10-16 Custom options (TB300 only)† — 300 = 8-32 screw 345 = 10-32 screw B = Brass phil-slot, nickel-plated J301 = Flat slip-on jumper BS = Brass SEMS phil-slot, nickelplated (TB300 only) OJ6 = Over barrier jumper SP = Steel SEMS phil-slot, zincplated OJ11 = Over barrier jumper ST = Stainless steel, phil-slot † Contact factory for configuration. Accessories • Marker strips, see page 10-17 • Covers, see page 10-16 10-14 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Connector products — 10 B BS Brass phil-slot nickel-plated - B001-7018-J (TB300 bulk) - B500-023-028-J (TB345 bulk) SP Brass SEMS phil-slot nickel-plated - B001-7015-J (TB300 bulk) ST Steel SEMS phil-slot zinc-plated - B001-7017-J (TB300 bulk) - B001-5774-J (TB346 bulk) Stainless steel phil-slot - B001-7063-J (TB300 bulk) - B001-7064-J (TB345 bulk) Hardware options Quick-connects — assembled: TB300 only; 0.25" x 0.031" terminals, 20 amps maximum. For other orientations, contact factory. QC1 QC2 QC3 QC4 QC5 QC6 QC7 QC8 QC9 QC10 QC11 QC12 QC13 QC14 QC15 QC16 QC17 QC18 QC19 QC20 Quick-connects — bulk: *TB300 only; minimum order 100 pieces per catalog number. QC201-J QC202-J QC203-J QC204-J QC205-J Flat — blank QC 45° — blank QC 90° — blank Flat — Flat Flat — QC 45° QC206-J QC207-J QC208-J QC209-J Flat — QC 90° QC 45° — QC 45° QC 45° — QC 90° QC 90° — QC 90° Jumpers — bulk: TB300 only; minimum order 100 pieces per catalog number. Contact factory for jumper assembly. J301 OJ6 OJ11 Flat slip-on J301-J (bulk) Closed over barrier OJ6-J (bulk) Slip-on over barrier OJ11-J (bulk) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 10-15 Connector products Screw options 10 — Connector products Marking options and covers for double row terminal blocks Special marking* 1 2 3 3 2 1 1 2 3 Standard marking L1 L2 L3 1 2 3 1 2 3 3 2 1 L4 L5 L6 Standard markings are applied directly to the side(s) of a block. The standard marking color is white. The standard numeral height is 0.125 inches (3mm). Special markings are available at an additional charge. Drawing(s) must be submitted to ensure accuracy of part required. Consult factory for price and delivery. * Not available on TB400 products Note: Blocks marked on both sides require a different code for each side. Example: Style L1 on one side of the block requires Style L2 on the other side to ensure common terminal marking. To order, add appropriate suffix (L1, L2, L3, L4, L5 and/or L6) to block catalog number in the proper sequence. Covers Catalog no. For block family (must be ordered separately) DD1-J TB100 DD2-J TB200 DD2HB-J TB200HB DD3-J TB300 Covers prevent personnel, screws and foreign items from contacting live terminals, and are available in white (opaque) or clear plastic. Two cover clips are supplied with each cover. The cover width is 1.31 inches (33mm). Example: 10 position cover, white, TB100 = catalog number X12010. Cover catalog number build-a-code† Symbol Cover strip† Poles 119 = TB100 - clear 02 to 36 (TB100) 120 = TB100 - white 02 to 30 (TB200/ TB200HB) 219 = TB200/TB200HB - clear 02 to 24 (TB300/ TB345) High barrier option only X HB = High barrier†† 220 = TB200/TB200HB - white 319 = TB300/TB345 - clear 320 = TB300/TB345 - white † Cover strip not available for TB400 products. †† Applicable to X219 and X220 only. Cover clips — bulk 10-16 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Connector products — 10 Bottom marker strips (order separately from blocks) (order separately from blocks) Connector products Top marker strips des o si g Top mounting marker strips must be ordered separately and are only available in white (opaque) plastic. Two cover clips are supplied with each marker strip. Example: 12 position cover, TB200, 0.032" x 0.312" = catalog number X20312. Example: 12 position cover, TB200HB, 0.06" x 0.50" = catalog number X23312HB. Top marker strip catalog number build-a-code Series Top marker strip† Poles High barrier option only 103 = TB100 (0.032 thk x 0.312 w) 02 to 36 (TB100) HB = High barrier†† 133 = TB100 (0.060 thk x 0.500 w) 02 to 30 (TB200/TB200HB) 203 = TB200/TB200HB (0.032 thk x 0.312 w) 02 to 24 (TB300/TB345) X 233 = TB200/TB200HB (0.060 thk x 0.500 w) 303 = TB300/TB345 (0.032 thk x 0.380 w) 333 = TB300/TB345 (0.060 thk x 0.500 w) † Marking strips not available for TB400 products †† Applicable to X203 and X233 only. in ark one w ng t arki M e sid M o g tw es sid rkin Ma Bottom mounting marker strips are made of 0.03" thick black PVC. Space is available along the edge to handle most marking needs. All marker strips must be ordered separately. To order, specify catalog number and required marking orientation. Example: 13 position strip, TB100 with no markings, space for marking one side = catalog number X10513. Consult factory for specials. Standard numeral height is 0.125". Standard markings are 0-99. Special markings are available on special order. Drawing(s) must be submitted to ensure accuracy of part required. Dimensions — in For TB block Dim. TB100 TB200 TB200HB TB300 TB345 TB400 A 1.13 1.37 1.62 1.58 1.58 N/A B 1.38 1.62 1.81 1.81 1.81 N/A Bottom marker strip catalog number build-a-code Symbol X Bottom Marker Strip† Poles 101 = TB100 marking both sides 105 = TB100 marking one side 201 = TB200 marking both sides 205 = TB200 marking one side 291 = TB200HB marking both sides 295 = TB200HB marking one side 301 = TB300 and TB345 marking both sides 305 = TB300 and TB345 marking one side 02 to 36 (TB100) 02 to 30 (TB200/TB200HB) 02 to 24 (TB300/TB345) Marking orientation BF = Bottom forward BR = Bottom reverse TF = Top forward TR = Top reverse † Not available for TB400 products. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 10-17 10 — Connector products TB400 double row terminal blocks Dimensions — in A Ratings B • Volts 600 V • Amps 75 A • Breakdown voltage 7500 V 0.22 (5.6) 0.15 dia. (3.8) TB400-05 0.625 (15.9) 1.12 (28.4) Agency information • 0.22 dia. (5.6) UL File E62622, CSA File 47235; IEC Compliance 0.687 (17.4) Specifications 0.687 (17.4) 0.562 (14.3) 1.81 (46.0) • Poles: 2 to 12 • Wire range: 6-14 AWG Cu • Center spacing: 0.687" or 11/16" (17mm) • Distance between barriers: 0.56" (14mm) • Screw size: #10-32 phil-slot screws • Torque rating: 20 lb-in • Mounting: #10 screws • Operating temperature: -40°C to 130°C (-40°F to 266°F) Materials 0.76 (19.3) 0.46 (11.7) 1.34 (34.0) A B A B A B 02 Poles 2.51 2.06 06 5.26 4.81 10 8.01 7.56 03 3.20 2.75 07 5.95 5.50 11 8.70 8.25 04 3.89 3.44 08 6.64 6.19 12 9.39 8.94 05 4.58 4.13 09 7.33 6.88 • Molded black thermoplastic base, UL rated 94V0 1" = 25.4mm. • Tin-plated brass terminals Screw options • Zinc-plated steel screws Poles Brass nickel-plated phil-slot B500-023-028-J (bulk) Poles Stainless steel phil-slot B001-7064-J (bulk) Hardware options OJ14: Closed over barrier OJ14-J (bulk) Catalog number build-a-code Symbol TB400 Poles Screw options — 02 to 12 Blank = Zinc-plated steel phil-slot 00 = Screws shipped bulk B = Nickel-plated brass phil-slot ST = Stainless steel, phil-slot Accessories • OJ14 - Jumper over barrier, consult factory for pole configuration 10-18 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Connector products — 10 KU Ratings • Volts 600 V • Amps 60 A* KU_ * 60 A rating achieved with 6 AWG Cu wire crimped to ring terminal. KU_SC Agency information • Poles 02 04 06 08 10 12 A 2.50 3.75 5.00 6.25 7.50 8.75 B 1.62 2.87 4.12 5.37 6.62 7.87 B KUX 0.62 only (15.9) A 2.00 3.25 4.50 5.75 7.00 #10 screw 0.43 clearance (11.1) 8.25 1.50 (38.1) 2.00 (50.8) 0.50 (12.7) 1" = 25.4mm. 1.25 (31.8) UL File E62622, CSA File 47235 A Specifications Accessories (order separately) • Poles: 2 to 12 • Wire range: 6-22 AWG Cu • Center spacing: 0.625" (16mm) • Screw size: #10-32 • Torque rating: 20 lb-in • Distance between barriers: 0.437" (11mm) • Mounting: Panel mount • Operating temperature: 105°C (221°F) max. MTMU(poles) Molded marking tape, matte finish NUM(poles) Molded marking tape JU12 Jumper, 12 circuits Materials • Molded black Noryl base, UL rated 94V1 • Terminal plating: Nickel-plated brass terminals • Zinc-plated steel screws NUE End piece for NUC NUC(poles) Cover Catalog number build-a-code - KU versions Symbol / for Poles Screw options Covers Marking strip 00 = Screws shipped bulk WC = Top cover and2 end plates MT = Matte finish — KU / Standard block KUX / Short block KURL / Standard w/removable link 2 4 6 8 10 12 KUXRL / Short block w/removable link BP = Brass phil-slot, nickel-plated NU = Numbered 1 to 12, horizontal P = Steel screw w/pressure plate zinc-plated NUV = Numbered 1 to 12, vertical W = Brass washer head, nickel-plated PT = Marker strip for cover† Catalog number build-a-code - KU__SC versions Symbol / for Poles Screw options Covers Marking strip 00 = Screws shipped bulk WC = Top cover and 2 end plates PT = Marker strip for cover† — KUSC / Standard w/shorting strap and 4 shorting screws KUXSC / Short block w/shorting strap and 4 shorting screws 2 4 6 8 10 12 BP = Brass phil-slot, nickel-plated P = Steel screw w/pressure plate, zinc-plated W = Brass washer head, nickel-plated † Requires WC cover option BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 10-19 Connector products Dimensions — in KU double row terminal blocks 10 — Connector products End brackets BRKT-ND Use with BRKT-NDSCRW DRL35MMHI Use with DRL35MMLO Dimensions — mm DRL35MMHI BRKT-NDSCRW2 Use with DRL35MMLO DRL35MMHI BRKT-NDSCRW3 Use with DRL35MMLO DRL35MMHI DRL35MMLO Dimensions — mm Dimensions — mm Dimensions — mm DRL35MMLO* DRL35MMHI* NFTA** NRA** Low profile High profile C-Rail C-Rail 35mm DIN-Rail 35mm DIN-Rail BRKT-ANGL BRKT-FLT Angle bracket Flat bracket Mounting rails and brackets * Available in 1 meter lengths only. ** Cut-to-length. Consult your Bussmann series product representative for details. 10-20 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 TM The Bussmann series Compact Circuit Protector for Class CF CUBEFuseTM delivers the smallest footprint compared to any Class J disconnect solution — requiring up to 51% less space. Compact Circuit Protector disconnect switches Compact Circuit Protector Base (CCP2B - CUBEFuse) 36-37 Class CC, UL supplemental and IEC 10x38 (CCP2) 38-42 Accessories for Class CC, UL supp. and IEC 10x38 CCP2 43-47 Multi-wire lug kits 43 Selector and pistol handles, shafts, NFPA 79 compliant handles 44 Auxiliary contacts 45 PLC fuse monitors 46-47 How to order Class CC, UL supplemental and IEC 10x38 switches 48-51 Low profile Class CC and G, UL supplemental and IEC 10x38 (CCPLP) 52-53 UL 98 fused disconnect switches, 30 to 800 A Introduction and agency information Product line summary — UL 54 55 30 A Class CC and compact Class J 56-57 30 A standard Class J 58-59 60 A compact Class J 60-61 60 A standard Class J 62-63 100 A standard Class J 64-65 200 A and 400 A standard Class J 66-68 600 A standard Class J and 800 A Class L 69-70 UL 98 non-fused disconnect switches, 30 to 1200 A Introduction, agency information and IEC product summary UL product summary 72 30 A, 60 A and 100 A compact Contents 71 73-74 100 A, 200 A and 400 A standard 75-76 600 A, 800 A, 1000 A and 1200 A standard 77-78 UL 508 non-fused disconnect switches, 16 to 80 A Section page Description Class CF CUBEFuse 200 and 400 A (CCP2-CF) Accessories for CUBEFuse CCP2 Multi-wire lug kits 2-8 9-12 1313-14 Selector and pistol handles, shafts, NFPA 79 compliant handles 15-16 Flange handle rod and cable operators 17 200 and 400 A switch rotary mechanisms 18 Auxiliary contacts 19-20 PLC fuse monitors (up to 100 A switches) 21-22 How to order Class CF switches UL product summary 79 80 16 A, 25 A, 40 A, 63 A and 80 A Compact Circuit Protector disconnect switches Class CF CUBEFuse up to 100 A (CCP2-CF) Introduction, agency information and IEC product summary 81-83 Enclosed UL 98 and UL 508 disconnect switches Introduction and agency information 84 Fused UL 98 enclosed disconnects, 30 to 800 A 85-86 Non-fused UL 98 enclosed disconnects, 30 to 1200 A 87-88 Non-fused UL 508 enclosed disconnects, 16 to 80 A 89-90 23-35 Switches up to 100 A 23-30 200 and 400 A switches 32-35 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-1 Disconnect switches The power of space Section page Description 11 — Disconnect switches Compact Circuit Protector UL 98 Class CF disconnect switches from 30 to 400 A Class CF CCP contents Section page 30, 60 and 100 amp switches Descriptions and specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .3-4 Catalog numbers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Terminal data . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .6-8 200 and 400 A switches Descriptions and specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-10 Catalog numbers and horsepower ratings . . . . . . . . . . . . . . . . . . . . . 10 Available lugs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 CCP2 switch up to 100 A with and without rotary operation mechanisms Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11-12 Accessories Multi-wire lug kits 30, 60 and 100 A switches . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 200 and 400 A switches . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Handles and shafts Selector and pistol handles . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Handle shafts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 NFPA 79 compliant handles . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Flange handle rod and cable operators . . . . . . . . . . . . . . . . . . . . . . . . 17 200 and 400 A switches Front rotary mechanisms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Side rotary mechanisms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Terminal shroud kits . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Phase barrier kits . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Handle extension . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Auxiliary contacts 200 A CCP2 switch with and without rotary operation mechanisms 30, 60 and 100 A switches . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 200 and 400 A switches . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 PLC fuse monitor (30, 60 and 100 A switches). . . . . . . . . . . . . . . .21-22 How to order 30 and 60 A switches Switch only . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Front and right side rotary switches . . . . . . . . . . . . . . . . . . . . . .24-25 Left side rotary switches . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 26 100 A switches Switch only. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27 Front and right side rotary switches . . . . . . . . . . . . . . . . . . . . . .28-29 Left side rotary switches . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 200 and 400 A switches 200 A switches . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .32-33 400 A switches . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .34-35 400 A CCP2 switch with and without rotary operation mechanisms 11-2 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 Symbol CCP2-(pole)-(amps)CF Description Switch only CCP2R-(pole)-(amps)CF Right front rotary, clockwise operated switch CCP2RL-(pole)-(amps)CF Left front rotary, clockwise operated switch CCP2S-(pole)-(amps)CF Right side rotary, clockwise operated switch side rotary, counterclockwise operated CCP2SL-(pole)-(amps)CF Left switch Description The revolutionary, next generation Bussmann™ series Compact Circuit Protector (cat. no. CCP2) is a fused UL® 98 branch circuit disconnect switch utilizing the UL Class CF time-delay or fast-acting CUBEFuse™ with Class J electrical performance. With up to a 51 percent smaller footprint than a traditional fusible solution, these switches provide a high 200 kA SCCR to help improve panel and assembly SCCR. The 35 mm DIN-Rail mount CCP2 is available in a variety of 30, 60 and 100 amp configurations to meet many application needs including rotary operation. The switch-only versions of the 30, 60 and 100 A disconnects are direct, drop-in replacements for the earlier models (noted by a catalog number starting “CCP-”). The auxiliary contacts and PLC remote fuse indicator are backwards compatible. The multi-wire lug kits and terminal shrouds are not. Conductors/terminals • 75°C Cu, see conductor tables for size, type and torque information • Box lug, single/dual conductor • Fork terminal suitable for line, load or accessory connection, max. 30 A suitable for use with: • 10-24 screw for 30 and 60 A switches • • 1/4-28 screw for 100 A switches Multi-wire lug kits — see accessories for details Disconnect switches Catalog symbols for 30, 60 and 100 A switches Storage and operating temperature • -20°C to 75°C (-4°F to 167°F)* * For fuse performance under or above 25°C, consult fuse performance derating charts in the Bussmann Division publication no. 3002, titled Selecting Protective Devices (SPD) Lockout/tagout provisions • 1/4” lock, direct use on switches without rotary mechanisms requires a lock with a straight shank of sufficient length to engage all poles Minimum enclosure size per UL 98* • 30 and 60 A switch 10”x 8”x 6”(254 x 203 x 152 mm) • 100 A switch, 12” x 10” x 6” (305 x 254 x 152 mm) Application flexibility is extended with an optional multi-wire lug kit, featuring finger-safe shrouds, that provides three (30 and 60 A switches) and six (100 A switches) additional wire ports on each pole for power distribution applications. * Smaller enclosures may be used at the discretion of the user, with adherence to NEC minimum wire bend radius requirements. Other accessories include a PLC fuse monitor for open fuse indication and NO/NC auxiliary contacts that easily integrate into various monitoring systems. • Front and side rotary operated versions are easily applied for through-the-door or through the left or right side operation to enhance safety. Ratings • • • Mounting** 35 mm DIN-Rail ** Switch is panel mount with flange handle cable operator. Local open fuse indication minimum voltage • 90 Vac, requires an open fuse to be in the CCP2 and the switch in the ON position Accessories Volts • Multi-wire lug kits with terminal shrouds • 347 Vac (1-pole switches) • Selector and pistol handles for use with rotary operated switches • 600 Vac (2- and 3-pole switches) • 8 mm shafts for use with selector and pistol handles • 125 Vdc* • Auxiliary contacts Amps • PLC fuse monitor • 30 A • NFPA 79 compliant handle • 60 A • Flange handle rod and cable operators • 100 A SCCR • 200 kA RMS Sym. • 100 kA DC Poles • 1-, 2- and 3-poles catalog number dependent * Switch amp rating and installed fuse amp rating dependent, see catalog number table for details. Agency information • UL 98 Listed, Guide WHTY, File E302370 • cULus to Canadian Standard 22.2 No. 4-04, Guide WHTY7, File E302370 • RoHS compliant • CE BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-3 11 — Disconnect switches Features • Uses UL Class CF time-delay or fast-acting CUBEFuse with Class J electrical performance • Extremely compact design at 25.4 mm (1 inch) wide per pole • Amp rating rejection disconnects will not accept a CUBEFuse amp rating greater than switch rating • High 200 kA short-circuit current rating • Disconnect rated to provide means for load isolation • Full voltage rated at 347 Vac (1-pole switches) and 600 Vac (2- and 3-pole switches) • 125 Vdc* rated to meet specialized applications • UL 98 Listed and suitable for branch circuit disconnect and branch circuit protection with installed fuses • Horsepower rated • Open fuse indication: • Local open fuse indication light standard on each pole • Optional PLC fuse monitor for wired remote open fuse indication by signaling a PLC and opening a contactor to de-energize all phases, if required • Additional open fuse indication can be provided by the indicating time-delay CUBEFuse (6 to 100 A) • Finger-safe construction with 10 AWG (6 mm2) wire or larger • Built-in switch interlock prohibits removing or installing the fuse while in the ON position • Padlockable for lockout/tagout procedures with a 1/4” lock • Rotary operated versions provide for through-the-door and through-the-side operation flexibility and enhanced safety with: • Right or left front operation • Right front rotary operated CCP2 switch with PLC fuse monitor. Right or left side operation • Optional selector and pistol handles, and shafts available for use with rotary operated versions • Multi-wire lug kits with terminal shrouds allow for power distribution to multiple loads. Each lug has three (30 and 60 A switches) or six (100 A switches) ports rated for single and dual wires (see lug kits in accessories for details). Rotary operating versions * Switch amp rating and installed fuse amp rating dependent, see catalog number table for details. Switch handle (ganged on 2- and 3-pole versions) Open fuse indicating light Fuse holder Left front Right front Uses clockwise handles Uses clockwise handles Fork terminal 1/4” Lockout/ tagout provision 11-4 Box lug terminal Left side Right side Uses counterclockwise handles Uses clockwise handles BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 30, 60 and 100 A switch catalog numbers Max Hp rating (Vac) Catalog no. Poles Description/switch operation Volts SCCR 120 240 480 600 CCP2-1-30CF 1 CCP2-2-30CF 2 347 Vac/125 Vdc 1-1/2 — — — 600 Vac/125 Vdc — 3 — CCP2-3-30CF — 3 600 Vac — 5 15 10 CCP2R-2-30CF 2 600 Vac/125 Vdc — 3 — — CCP2R-3-30CF 3 600 Vac — 5 15 10 CCP2RL-2-30CF 2 — 3 — — CCP2RL-3-30CF 3 CCP2S-2-30CF 2 CCP2S-3-30CF 3 CCP2SL-2-30CF 2 CCP2SL-3-30CF 3 Switch only Right front rotary, clockwise Left front rotary, clockwise Right side rotary, clockwise Left side rotary, counterclockwise 200 kA AC 600 Vac/125 Vdc 100 kA DC 600 Vac — 5 15 10 600 Vac/125 Vdc — 3 — — 600 Vac — 5 15 10 600 Vac/125 Vdc — 3 — — 600 Vac — 5 15 10 347 Vac/125 Vdc* 3 — — — 600 Vac/125 Vdc* — 7-1/2 — — 60 amp switches CCP2-1-60CF 1 CCP2-2-60CF 2 CCP2-3-60CF 3 600 Vac — 7-1/2 20 10 CCP2R-2-60CF 2 600 Vac/125 Vdc* — 7-1/2 — — CCP2R-3-60CF 3 600 Vac — 7-1/2 20 10 CCP2RL-2-60CF 2 — 7-1/2 — — CCP2RL-3-60CF 3 — 7-1/2 20 10 CCP2S-2-60CF 2 600 Vac/125 Vdc* — 7-1/2 — — CCP2S-3-60CF 3 600 Vac — 7-1/2 20 10 CCP2SL-2-60CF 2 600 Vac/125 Vdc* — 7-1/2 — — CCP2SL-3-60CF 3 600 Vac — 7-1/2 20 10 347 Vac/125 Vdc** 5 — — — 600 Vac/125 Vdc** — 10 — — Switch only Right front rotary, clockwise Left front rotary, clockwise Right side rotary, clockwise Left side rotary, counterclockwise 600 Vac/125 Vdc* 600 Vac 200 kA AC 100 kA DC 100 amp switches CCP2-1-100CF 1 CCP2-2-100CF 2 CCP2-3-100CF 3 600 Vac — 20 50 40 CCP2R-2-100CF 2 600 Vac/125 Vdc** — 10 — — CCP2R-3-100CF 3 600 Vac — 20 50 40 CCP2RL-2-100CF 2 — 10 — — CCP2RL-3-100CF 3 — 20 50 40 CCP2S-2-100CF 2 600 Vac/125 Vdc** — 10 — — CCP2S-3-100CF 3 600 Vac — 20 50 40 CCP2SL-2-100CF 2 600 Vac/125 Vdc** — 10 — — CCP2SL-3-100CF 3 600 Vac — 20 50 40 Switch only Right front rotary, clockwise Left front rotary, clockwise Right side rotary, clockwise Left side rotary, counterclockwise 600 Vac/125 Vdc** 600 Vac 200 kA AC 100 kA DC * 125 Vdc for installed fuse amp ratings up to 40 A. 24 Vdc for installed fuse amp ratings from 45 to 60 A. ** 125 Vdc for installed fuse amp ratings up to 80 A, 24 Vdc for installed fuse amp ratings from 90 to 100 A. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-5 Disconnect switches 30 amp switches 11 — Disconnect switches Dimensions – mm (in) Box lug terminal conductor data Wire type AWG range Class Quantity Torque N•m (lb-in) Switch (shown with optional terminal shrouds) 30 and 60 A switches 4-6 8-18 6-8 75°C Cu Stranded, Class B to K 3.95 (35) Single 2.26 (20) Stranded, Class B/C Stranded, Class K 3.39 (30) Dual 2.26 (20) 10-18 Stranded, Class B to K 10-18 Solid Single/dual 4-18 Stranded, UL ferrule, Class B/C Single Twin† Stranded, UL ferrule, Class K Twin† 6-18 4-18 6-18 114 4.5 206 8.1 2.26 (20) 76 3.0 50 2.0 3.39 (30) Single 25 1.0 2.82 (25) 83 3.3 75 3.0 30A Fuse 100 A switches 12-18 2.26 (20) 10 2.82 (25) 8 4-6 Stranded, Class B/C Single 4.52 (40 Dual 5.08 (45) 12-18 75°C Cu 1-8 10-18 Stranded, UL ferrule, Class B/C Solid Class K 3-10 3.95 (35) 4.52 (40) 2.26 (20) 2.82 (25) Single/Dual Class K, UL ferrule 6-18 2.26 (20) 75 3.0 50 2.0 25 1.0 2.26 (20) Single 3.39 (30) Dual 8-18 1-7 Single Twin† 8-18 1-7 30 and 60 amp switches 2.26 (20) 6-9 10-18 60A Fuse 6.21 (55) 4-12 89 3.5 5.08 (45) 1-3 10 75 3.0 5.08 (45) 148 5.8 240 9.5 2.26 (20) Single 3.39 (30) Twin 100 3.9 2.26 (20) † Two stranded conductors placed in one UL Listed twin ferrule. Lineside and loadside fork terminal • Fork terminal suitable for line, load or accessory connection, max. 30 A suitable for use with: • 10-24 screw for 30 and 60 A switches • 100 amp switches 1/4-28 screw for 100 A switches Available Bussmann series fuses UL fuse class CF 11-6 Type/description Indicating time-delay, Low-Peak™ CUBEFuse (6-100 A) Non-indicating time-delay, Low-Peak CUBEFuse (1-100 A) Non-indicating fast-acting CUBEFuse (1-100 A) Volts Data sheet no. 600 Vac/ 300 Vdc 9000 600 Vac/dc 2147 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 114 4.5 114 4.5 206 8.1 99 3.9 101 4.0 76 3.0 Right front rotary switches (shown with optional terminal shrouds) 83 3.3 99 3.9 76 3.0 30 A Fuse 99 3.9 101 4.0 83 3.3 30 A Fuse 99 3.9 89 3.5 60 A Fuse 89 3.5 60 A Fuse 30 and 60 amp switches 30 and 60 amp switches 101 4.0 76 3.0 206 8.1 148 5.8 101 4.0 76 3.0 240 9.5 148 5.8 240 9.5 100 106 3.9 4.2 100 amp switches Disconnect switches Left front rotary switches (shown with optional terminal shrouds) 100 106 3.9 4.2 100 amp switches BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-7 11 — Disconnect switches Left side rotary switches (shown with optional terminal shrouds) 114 4.5 114 4.5 206 8.1 206 8.1 83 3.3 75 3.0 101 4.0 Right side rotary switches (shown with optional terminal shrouds) 101 4.0 76 3.0 30 A Fuse 89 3.5 75 3.0 30 A Fuse 75 3.0 60 A Fuse 76 3.0 89 3.5 60 A Fuse 30 and 60 amp switches 101 4.0 83 3.3 75 3.0 30 and 60 amp switches 101 4.0 148 5.8 76 3.0 240 9.5 148 5.8 240 9.5 100 3.9 100 3.9 100 amp switches 11-8 100 amp switches BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 200 and 400 A switches Poles • 1-, 2- and 3-poles catalog number dependent Agency information • UL 98 Listed, Guide WHTY, File E302370 • cULus to Canadian Standard 22.2 No. 4-04, Guide WHTY7, File E302370 • RoHS compliant 400 A switch 200 A switch • See available lug table for size, type and torque information Storage and operating temperature • -20°C to 75°C (-4°F to 167°F)* * For fuse performance under or above 25°C, consult fuse performance derating charts in the Bussmann Division publication no. 3002, titled Selecting Protective Devices (SPD) Lockout/tagout provisions using 1/4” lock With front rotary accessory Catalog no. Poles CCP2-1-200CF 1 CCP2-2-200CF 2 CCP2-3-200CF 3 CCP2-1-400CF 1 CCP2-2-400CF 2 CCP2-3-400CF 3 With side rotary accessory Amps Description • Integral with switch handle • Front rotary operating mechanism • Rotary pistol handles • Flange rod and cable operators Minimum enclosure size 200 Switch only 400 Description • 200 A switch 16 x 12 x 6” (405 x 305 x 150 mm) • 400 A switch 24 x 16 x 8 (610 x 405 x 200 mm) Mounting • Local open fuse indication minimum voltage • The Bussmann series 200 and 400 A Compact Circuit Protector (CCP2) fused disconnect switches utilize the finger-safe UL Class CF time-delay CUBEFuse with Class J electrical performance. With up to a 69 percent smaller footprint than a traditional fusible solution, these switches provide a high 200 kA SCCR to help improve panel and assembly SCCR. The panel mount 200 and 400 A CCP2 switches are available with a variety of accessories to meet many application needs including rotary and flange handle operation. Rotary operators are available for front or side (right or left) operation. Front rotary operators are for three-pole switches only while the side operator may be applied to the right or left side of 1-, 2- and 3-pole units. Panel mount 90 Vac, requires an open fuse to be in the CCP2 and the switch in the ON position Accessories • Lugs and lug kits with terminal shrouds • Pistol handles for use with rotary operated switches • NFPA 79 compliant handle • 12 mm shafts for use with selector and pistol handles • Auxiliary contacts • Flange handle rod and cable operators Other accessories include lugs, terminal shrouds, rotary pistol handles, flange rod and cable operating mechanisms, NO/NC auxiliary contacts that easily integrate into various monitoring systems and a handle extension. Front and side rotary operated versions are easily applied for through-the-door or through the left or right side operation to enhance safety. Ratings • Volts • • • 347 Vac (1-pole) 600 Vac (2- and 3-pole) Amps • 200 A • 400 A SCCR • 200 kA RMS Sym. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-9 Disconnect switches Conductors/terminals 11 — Disconnect switches Features • Uses UL Class CF time-delay CUBEFuse with Class J electrical performance • Standard local open fuse indication light on each pole speeds troubleshooting • Amp rating rejection feature will not accept a CUBEFuse amp ratings greater than switch rating • Built-in switch interlock prevents inserting or removing fuse while in the ON position • High 200 kA short-circuit current rating • Padlockable for lockout/tagout procedures with a 1/4” lock • Disconnect rated to provide means for load isolation • • Full voltage rated at 600 Vac • UL 98 Listed and suitable for branch circuit disconnect and branch circuit protection with installed fuses Front and side rotary operator accessories provide for throughthe-door and through-the-side operation flexibility and enhanced safety • • Horsepower rated (see table below) Optional pistol handles and shafts available for use with rotary operator accessories • Multi-wire lug kits with terminal shrouds allow for power distribution to multiple loads. Catalog numbers and horsepower ratings Catalog no. 200 amp switches CCP2-1-200CF CCP2-2-200CF CCP2-3-200CF 400 amp switches CCP2-1-400CF CCP2-2-400CF CCP2-3-400CF Poles Description 1 2 3 Switch only 1 2 3 Switch only Volts AC SCCR 240 Max Hp rating (Vac) 480 600 200 kA — 10 50 — — 100 — — 150 200 kA — — 100 — — 200 — — 250 347 600 347 600 Available lugs, conductor ratings and terminal torques Catalog no. Description 200 A switches CCP2-L2-1 Stainless steel lug CCP2-L2-1A Aluminum lug* CCP2-MW2-3 3-port multi-wire terminal with shroud* CCP2-MW2-6 6-port multi-wire terminal with shroud* Lugs per cat. no. Wire range AWG (mm2) Wire type/ temp. 1 1 3 3 350-4 (185-25) 350-4 (185-25) 2-14 (35-2.5) 6-14 (16-2.5) Cu 75°C Cu/Al 75°C Cu/Al 75°C Cu/Al 75°C Conductor torque Lug mounting screw N•m (lb-in) torque N•m (lb-in) 20.3 (180) 28.2 (250) 7.9 (70) 2.8 (25) 0.9 (8) 13.5 (120) 10.8 (95) 10.8 (95) * These lugs also accept 1/4” quick connect control wire terminals. Order catalog number CCP2-CWK2 (package of 12 terminals). 400 A Switches CCP2-L4-1 CCP2-L4-1A CCP2-L4B-3 CCP2-L4B-3A CCP2-L6-3 CCP2-L6-3A Stainless steel lug Aluminum lug Stainless steel lug kit with shroud Aluminum lug kit with shroud 2-port stainless steel lug kit with shroud 2-port aluminum lug kit with shroud 1 1 3 3 3 3 500-3 (240-35) 500-3 (240-35) 750-500 (400-240) 750-500 (400-240) (2) 500-2 (240-35) (2) 500-2 (240-25) Cu 75°C Cu/Al 75°C Cu 75°C Cu/Al 75°C Cu 75°C Cu/Al 75°C 42.0 (375) 42.0 (375) 57.0 (500) 62.0 (550) 42.0 (375) 42.0 (375) 10-14 = 3.9 (35) CCP2-MW6-6 6-port multi-wire terminal with shroud 3 1/0-14 (50-2.5) Cu/Al 75°C 8 = 4.5 (40) 4-6 = 5.0 (45 1/0-2 = 5.6 (50) Accessories Catalog no. CCP2-TS2-3 CCP2-PB2 CCP2-RM2 CCP2-TS6-3 CCP2-PB6 CCP2-RM4 CCP2-SM Switch amps 200 400 200/400 Description 3-pole terminal shroud Phase barriers (pack of 2) Front rotary operator* (3-pole switch only) 3-pole terminal shroud Phase barriers (pack of 2) Front rotary operator* (3-pole switch only) Side rotary operator* (1-, 2- or 3-pole switches) * Complete installation requires pistol handle and shaft, order separately. 11-10 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 22.0 (200) Disconnect switches — 11 200 amp switch dimensions — mm (in) Ø 5.0 (0.2) Thru Ø 9.2 (0.4) 5.4 (0.2) 133.2 (5.2) 104.7 (4.1) 160.4 (6.3) 119.7 (4.7) 85.4 (3.4) Disconnect switches 34.9 (1.4) 34.9 (1.4) 56.0 (2.2) 55.2 (2.2) 177.9 (7.0) Front rotary mechanism accessory CCP2-RM2 152.4 (6.0) 139.7 (5.5) Side rotary mechanism accessory CCP2-SM 34.9 (1.4) 87.3 (3.4) 335.9 (13.2) 34.9 (1.4) 119.7 (4.7) 3-pole terminal shroud accessory CCP2-TS2-3 104.8 (4.1) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-11 11 — Disconnect switches 400 amp switch dimensions — mm (in) Ø 5.0 (0.2) Thru Ø 14.0 (0.5) 5.9 (0.2) 175.8 (6.9) 132.8 (5.2) 159.3 (6.3) 130.8 (5.1) 102 (4.0) 43.6 (1.7) 43.6 (1.7) 56.0 (2.2) 98.8 (3.9) 257 (10.1) Front rotary mechanism accessory CCP2-RM4 225.0 (8.8) 214.4 (8.4) Side rotary mechanism accessory CCP2-SM 43.6 (1.7) 43.6 (1.7) 132.9 (5.2) 101.4 (4.0) 365.0 (14.3) 3-pole terminal shroud accessory CCP2-TS6-3 139.2 (5.4) 11-12 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 30, 60 and 100 A switch multi-wire lug kits Installed on CCP2-3-xx Catalog numbers • CCP2-MW1-3 (30 and 60 A switches only) • CCP2-MW1-6 (100 A switches only) Description The multi-wire lug kits permit expanding each box lug terminal on the switch into a three-port (30 and 60 A switches) or six-port (100 A switches) terminal for power distribution applications. Disconnect switches Each multi-wire lug kit comes with three lugs and three terminal shrouds. Shrouds provide finger-safe protection when properly installed. Lugs may be mounted on either the loadside or lineside to meet various application needs. Ports on any one lug accept any conductor combination listed, e.g., one of the ports may have dual 14 AWG wires and the other two ports single 10 AWG wires. Multi-wire lugs mount in switch box lug terminals to provide three additional wire ports per pole. Lugs can be mounted on the switch lineside or loadside. Each multi-wire lug kit comes with three lugs and three shrouds. Ratings • Volts 600 V • Amps • 60 A max (CCP2-MW1-3) • • Wire insulation strip lengths 100 A max (CCP2-MW1-6) Agency information • UL Recognized, Guide WHTY2, File E302370 1 = 11/16” • RoHS compliant 2 = 1-1/8” Storage and operating temperature • 1/8” Allen head screw 1/8” Allen head screw SCCR 200 kA 1 = 11/16” 2 = 1-1/8” 3 = 1-9/16” 3 = 1-9/16” -20°C to 75°C (-4°F to 167°F) Multi-wire lug conductor information Strip back wire insulation to the lengths as indicated in the illustration above and the table below. • 75°C Cu/AL • AWG size and quantity per port - see table below Type Cu/Al Cu AWG range 4-6 Class Quantity Torque N•m (lb-in) 3.95 (35) Stranded, Class B/C Single 10-14 Stranded, Class B/C Single/dual* 2.26 (20) 10-14 Solid Single 2.26 (20) UL ferrule, Class B to K Single/twin† 8 8 10-14 2.82 (25) Lug port Strip wire insulation back (inch) 1 11/16 2 1-1/8 3 1-9/16 2.82 (25) 2.26 (20) * Dual wire to be same size and type. † Two stranded conductors placed in one UL Listed twin ferrule. CCP2 box lug torque for multi-wire lugs • 30/60 A switch lug, 4.52 N•m (40 lb-in) • 100 A switch lug, 5.09 N•m (45 lb-in) Wiring versatility is provided by single/dual rated box lug terminals on the switch, or by the three-port or six-port multi-wire lug kits that are also single/dual wire rated. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-13 11 — Disconnect switches Installed on CCP2-3-xx 200 and 400 A switch multi-wire lug kits Catalog numbers • CCP2-MW2-3 ( 3-port, 200 A switches only) • CCP2-MW2-6 (6-port, 200 A switches only) • CCP2-MW6-6 (6-port, 400 A switches only) Description The multi-wire lug kits permit expanding the terminal on the switch into a three-port (200 A switches) or six-port (200 and 400 A switches) terminal for power distribution applications. Each multi-wire lug kit comes with three lugs and a 3-pole terminal shroud. The shroud provides finger-safe protection when properly installed. 3- and 6-port multi-wire lugs mounted on 200 A switches Lugs can only be mounted on loadside to meet application needs. Ports on any one lug accept any conductor combination listed, e.g., one of the ports may have dual 14 AWG wires and the other two ports single 10 AWG wires. Ratings • Volts 600 V • Amps • 225 A max (CCP2-MW2-3 and CCP2-MW2-6) • • 600 A max (CCP2-MW6-6) SCCR 200 kA Agency information • UL Recognized, Guide WHTY2, File E302370 6-port multi-wire lugs mounted on 400 A switches • RoHS compliant Multi-wire lugs mount on the switch terminals to provide three or six additional wire ports per pole. Lugs to be mounted only on the loadside. Each multi-wire lug kit comes with three lugs, a shroud and mounting hardware. Storage and operating temperature • -20°C to 75°C (-4°F to 167°F) Multi-wire lug conductor information Wire insulation strip lengths • 75°C Cu/AL • AWG size and quantity per port - see table below Type AWG range Class Quantity Stranded, Class B/C Single 10-14 Stranded, Class B/C Single/dual* 2.26 (20) 10-14 Solid Single 2.26 (20) UL ferrule, Class B to K Single/twin† 4-6 Cu/Al Cu Torque N•m (lb-in) 8 8 10-14 * Dual wire to be same size and type. † Two stranded conductors placed in one UL Listed twin ferrule. 3.95 (35) 2.82 (25) 1 = 3/8 to 1/2” 1 = 3/8 to 1/2” 2 = 3/4 to 7/8” 2 = 3/4 to 7/8” 3 = 1-1/4 to 1-3/8” 3 = 1-1/4 to 1-3/8” CCP2-MW2-3 2 = 1-3/8 to 1-1/2” 3 = 2 to 2-1/8” CCP2-MW6-6 CCP2-MW2-6 Wire insulation strip length (inch) Lug kit CCP2-MW2-3 CCP2-MW2-6 CCP2-MW6-6 11-14 1 = 3/4 to 7/8” Strip back wire insulation to the lengths indicated in the illustration above and the table below. 2.82 (25) 2.26 (20) Straight blade head screw 4 mm Allen head screw 4 mm Allen head screw BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Lug port 1 Lug port 2 Lug port 3 3/8 to 1/2 3/4 to 7/8 1-1/4 to 1-3/8 3/4 to 7/8 1-3/8 to 1-1/2 2 to 2-1/8 Eaton.com/bussmannseries Disconnect switches — 11 Selector and pistol handles Selector handles Pistol handles —short and long Catalog symbol • CCP2-H4X-_1 (selector handle for 30, 60 and 100 A switches) • CCP2-H4X-_2 (pistol handle for 30, 60 and 100 A switches) • CCP2-H4X-_3 (short pistol handle for 200 and 400 A switches) • CCP2-H4X-_4 (long pistol handle for 200 and 400 A switches) Description Installation requires an 8 mm shaft for 30, 60 and 100 A switches and a 12 mm shaft for 200 and 400 A switches (ordered separately). Each handle is rated Type 1, 4X and 12, and accepts up to three (3) 1/4” diameter shank locks for lockout/tagout in the OFF position. They can also be field configured for lock-on and are defeatable. Agency information • UL Listed, Guide DIHS/DIHS7, File E140305 • Type 1, 4X and 12 • RoHS compliant • CE Disconnect switches Selector and pistol handles are used with rotary operated switches. Pistol handles for 200 and 400 A switches come in short and long versions. All handles are available in black/gray and red/yellow colors, and clockwise/counterclockwise operating modes. Front and right side operated switches use clockwise handles while left side operated switches use counterclockwise handles. Storage and operating temperature • -20°C to 75°C (-4°F to 167°F) Only the clockwise operating handles in combination with front rotary operating switches provide a door interlock means to ensure the enclosure door remains shut during lockout/tagout or lock-on. Rotary handles mounted on the enclosure’s left or right side do NOT provide a door interlock means. See the catalog number table below for applicable rotary switch, handle and shaft combinations. Handles and shafts for 30, 60 and 100 A switches For catalog no. CCP2R-(pole)-30CF CCP2R-(pole)-60CF CCP2R-(pole)-100CF CCP2RL-(pole)-30CF CCP2RL-(pole)-60CF CCP2RL-(pole)-100CF CCP2S-(pole)-30CF CCP2S-(pole)-60CF CCP2S-(pole)-100CF Description/operation Order handle cat. no. Order either 8 mm shaft cat. no. Right front rotary, clockwise CCP2-H4X-B1 (selector, black/grey) Left front rotary, clockwise CCP2-H4X-R1(selector, red/yellow) CCP2-H4X-B2 (pistol, black/grey) CCP2-H4X-R2 (pistol, red/yellow) Right side rotary, clockwise CCP2SL-(pole)-30CF CCP2-SH1-290 (11.5”/290 mm) CCP2-SH1-490 (19.3”/490 mm) CCP2-H4X-B1L (selector, black/grey) Left side rotary, counterclockwise CCP2SL-(pole)-60CF CCP2-H4X-R1L (selector, red/yellow) CCP2-H4X-B2L (pistol, black/grey) CCP2-H4X-R2L (pistol, red/yellow) CCP2SL-(pole)-100CF Handles and shafts for 200 and 400 A switches For catalog no. Order front rotary mechanism cat. no. CCP2-(poles)-200CF CCP2-RM2* Order right/ left side rotary Order left side counterclockwise mechanism Order front/right side clockwise handles (use only with CCP2-SM) cat. no. handle cat. no. cat. no. CCP2-SM CCP2-(poles)-400CF CCP2-RM4* CCP2-H4X-B3 (short - black/grey) CCP2-H4X-B3L (short - black/grey) CCP2-H4X-R3 (short - red/yellow) CCP2-H4X-R3L (short - red/yellow) CCP2-H4X-B4 (long - black/grey) CCP2-H4X-B4L (long - black/grey) CCP2-H4X-R4 (long - red/yellow) CCP2-H4X-R4L (long - red/yellow) Order either 12 mm shaft cat. no. CCP2-SH2-225 (8.9”/225 mm) CCP2-SH2-425 (16.7”/425 mm) * For three-pole switches only. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-15 11 — Disconnect switches Handle dimensions — mm (in) Handle shafts Selector for 8 mm shafts 28 (1.1) 8 mm shafts 71 (2.8) 26 (1.0) 73 (2.9) 85 (3.3) 48 (1.9) Ø7 (0.3) 85 (3.3) 71 (2.8) Short pistol for 8 mm and 12 mm shafts 12 mm shafts 33 (1.3) 85 (3.3) Ø7 (0.3) 71 (2.8) 85 (3.3) 96 (3.8) 69 (2.7) ON OFF 27 (1.1) 129 (5.1) 71 (2.8) Catalog numbers Long pistol for 12 mm shafts 85 (3.3) 34 (1.3) Ø7 (0.3) 68 (2.7) 96 85 (3.8) (3.3) 28 (1.1) 71 (2.8) 179 (7.0) 71 (2.8) • CCP2-SH1-290 (8 mm, 290 mm long) • CCP2-SH1-490 (8 mm, 490 mm long) • CCP2-SH2-225 (12 mm, 225 mm long) • CCP2-SH2-425 (12 mm, 425 mm long) Description Square shafts available in: • 8 mm square by 290 and 490 mm lengths for 30, 60 and 100 A switches • 12 mm square by 225 and 425 mm lengths for 200 and 400 A switches All shafts are indexed to ensure handle/switch orientation for correct operation. Shafts are to be cut to length when installed. NFPA 79 compliant handles Catalog numbers • CCP2-NFPA-1 (8 mm shafts for 30-100 A switches) • CCP2-NFPA-2 (12 mm shafts for 200 and 400 A switches) Description NFPA 79 handles mount on the shaft of front rotary operated switch installations and provide a lockout means independent of the door position. 11-16 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 Flange handle rod and cable operators Catalog no. Description Rating 30, 60 and 100 amp switches CCP2-FLR1 Rod operator with painted handle Type 1, 3R, 12 CCP2-FLR1X Rod operator with chrome handle Type 4X CCP2-FLC1-36 36” Cable with painted handle CCP2-FLC1-36X 36” Cable with chrome handle Type 4X CCP2-FLC1-60 60” Cable with painted handle Type 1, 3R, 12 CCP2-FLC1-60X 60” Cable with chrome handle Type 4X CCP2-FLC1-120 120” Cable with painted handle Type 1, 3R, 12 CCP2-FLC1-120X 120” Cable with chrome handle Type 4X Flange rod operator kit for 30, 60 and 100 A switches. 200 and 400 amp switches CCP2-FLR2 Rod operator with painted handle Type 1, 3R, 12 CCP2-FLR2X Rod operator with chrome handle Type 4X CCP2-FLC2-36 36” Cable with painted handle Type 1, 3R, 12 CCP2-FLC2-36X 36” Cable with chrome handle Type 4X CCP2-FLC2-60 60” Cable with painted handle 1, 3R, 12 CCP2-FLC2-60X 60” Cable with chrome handle Type 4X CCP2-FLC2-120 120” Cable with painted handle Type 1, 3R, 12 CCP2-FLC2-120X 120” Cable with chrome handle Type 4X Description Flange rod and cable operators for use on 2- and 3-pole CCP2 switches (cannot be used with 2- or 3-pole 30, 60 or 100 amp switches already having a front or side rotary operating mechanism). Flange rod operator kit for 200 and 400 A switches. Handles are available in painted versions with NEMA 1, 3R and 12 ratings or chrome versions with a NEMA 4X rating. Cable operators are available with 36, 60 and 120 inch cable lengths. Agency information • Type 1, 4X and 12 • RoHS compliant Storage and operating temperature • -20°C to 75°C (-4°F to 167°F) Packaging • Each handle is packaged individually as a kit Flange cable operator kit for 30, 60 and 100 A switches. Flange cable operator kit for 200 and 400 A switches. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-17 Disconnect switches Type 1, 3R, 12 11 — Disconnect switches Front rotary mechanisms for 200 and 400 A switches Phase barriers Catalog numbers • CCP2-PB2 (3-pole 200 A switches) • CCP2-PB6 (3-pole 400 A switches) Description Phase barrier kit with two phase barriers for isolation between the lugs on 3-pole 200 and 400 A switches. Catalog numbers • CCP2-RM2 (3-pole 200 A switches) • CCP2-RM4 (3-pole 400 A switches) Packaged individually. Handle extension Description Front rotary mechanisms for through-the-door operation and install on the front of 3-pole switches only. These units provide at-switch lockout/tagout capability for enhanced safety. Complete installation requires installing pistol handle (short or long) and 12 mm shaft. Packaged individually. Side rotary mechanism for 200 and 400 A switches Catalog number • CCP2-HEX (1-, 2- and 3-pole 200 and 400 A switches) Description A handle extension to provide additional leverage for operating the switch in installations that do not have rotary mechanisms or flange operators installed. Does not mount on switch, provision for tether provided. Packaged individually. Catalog number • CCP2-SM (1-, 2- or 3-pole 200 and 400 A switches) Description Side rotary mechanism for through-the-side operation and installs on the left or right side (right side installation recommended) of any 1-, 2- or 3-pole 200 and 400 A switch. The side rotary mechanism does not provide for door interlock nor local lockout/tagout capability. Complete installation requires installing pistol handle (short or long) and 12 mm shaft. Packaged individually. Terminal shrouds Catalog numbers • CCP2-TS2-3 (3-pole 200 A switches) • CCP2-TS6-3 (3-pole 400 A switches) Description 3-pole shroud kit with shields for isolating the lugs on 3-pole 200 and 400 A switches. Packaged individually. 11-18 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 Auxiliary contacts for 30, 60 and 100 A switches Installed on a CCP2-3-xx Catalog numbers Note: CCP2-AUX and CCP2-AUX-100 CANNOT be mounted on the right front and right side rotary operated versions, nor installed with the flange handle rod or cable operator. • CCP2-AUX (30 and 60 A switches) • CCP2-AUX-100 (100 A switches) Description Disconnect switches NO+NC contact output to indicate the switching mechanism status on the CCP2. A single unit can be mounted on any 1-, 2- or 3-pole CUBEFuse CCP2 switch and the left front/left side rotary operated switches. Ratings • 240 Vac max • 5 A max • NC/NO contacts are closed/open when the CCP2 switch is in the “ON” position (closed) Catalog no. Switch CCP2-AUX 30/60 A only CCP2-AUX-100 100 A only Description Max per CCP2* Ratings Auxiliary contacts N/NC for switch status 1 per CCP2 (1-, 2- or 3-pole) 5 A / 240 Vac Dimensions — in 1.8 * The CCP2-AUX CANNOT be mounted on the right front and right side rotary operated versions, nor installed with the flange handle rod or cable operator. De-energize all circuits and follow all prescribed safety procedures before installing or removing the auxiliary contact device. Agency information • UL 98 Recognized, Guide WHTY2, File E155130 • cURus to Canadian Standard 22.2 No. 4-04 • Finger-safe in installed state • RoHS compliant • CE 2.6 STRIP 33 NO 34 NO 41 NC 42 NC Wiring • 16-20 AWG (1.5 to 0.5 mm2) single and dual stranded wire • 20 AWG (1.5 mm2) single and dual solid wire • Torque 0.56 N•m (5 lb-in) • Use only 75°C Cu wire .190 3.7 0.3 CCP2-AUX Packaging • 1.9 1.8 CCP2-AUX and CCP2-AUX-100 are packaged individually Installation technique • Mounts on the CCP2’s right side ONLY and mechanically interlocks with the CCP2 switch handle with provided hardware. The CCP2-AUX and CCP2-AUX-100 CANNOT be mounted on the right front and right side rotary operated versions, nor installed with the flange handle rod or cable operator. 2.9 33 NO STRIP 34 NO 2.2 Storage and operating temperature • -20°C to 75°C (-4°F to 167°F) 42 NC 41 NC .190 3.7 0.3 CCP2-AUX-100 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-19 11 — Disconnect switches Auxiliary contacts for 200 and 400 A switches Installed on a CCP2-3-xx Catalog number Note: CCP2-AUX-S CANNOT be mounted on the same side as the side rotary mechanism CCP2-SM or the right side if a flange handle rod or cable operator is installed. • CCP2-AUX-S (200 and 400 A switches) Description NO+NC contact output to indicate the switching mechanism status on the CCP2. A single unit can be mounted on either side of any 1-, 2- or 3-pole switch (cannot be mounted on the same side as the CCP2-SM side rotary mechanism or the right side if a flange handle rod or cable operator is installed). Ratings • 240 Vac max • 5 A max • NC/NO contacts are closed/open when the CCP2 switch is in the “ON” position (closed) Catalog no. CCP2-AUX-S Switch Description Max per CCP2* Ratings 200 and 400 A Auxiliary contacts NO+NC for switch status 1 per CCP2 (1-, 2- or 3-pole) 5 A / 240 Vac * The CCP2-AUX-S CANNOT be mounted on the same side where the side rotary mechanism (CCP2-SM) is installed. De-energize all circuits and follow all prescribed safety procedures before installing or removing the auxiliary contact device. Agency information • UL 98 Recognized, Guide WHTY2, File E155130 • cURus to Canadian Standard 22.2 No. 4-04 • Finger-safe in installed state • RoHS compliant Wiring • 16-20 AWG (1.5 to 0.5 mm2) single and dual stranded wire • 20 AWG (1.5 mm2) single and dual solid wire • Torque 0.56 N•m (5 lb-in) • Use only 75°C Cu wire Installation technique • Mounts on either side of the 200 and 400 A switches and mechanically interlocks with the switch’s handle with provided hardware. The CCP2-AUX-S CANNOT be mounted on the same side with an installed CCP2-SM side rotary mechanism, or the flange cable/rod operating mechanisms. Storage and operating temperature • -20°C to 75°C (-4°F to 167°F) Packaging • Packaged individually. 11-20 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 PLC fuse monitor for 30, 60 and 100 A switches Agency information Catalog numbers • UL 98 Recognized, Guide WHTY2, File E155130 • cURus to Canadian Standard 22.2 No. 4-04 CCP2-PLC-IND (30/60 A switches) • CCP2-PLC-100 (100 A switches) Local indication • Description A resettable three-phase fuse monitor that integrates with the I/O card in a Programmable Logic Controller (PLC). A single unit can be mounted on any 1-, 2- or 3-pole CUBEFuse CCP2 switch up to 100 A and the left front/ left side rotary operated switches. A single unit monitors up to three phases. When used on 1- and 2-pole switches unused conductor(s) are removed after installation. The CCP2-PLC-IND and CCP2-PLC-100 CANNOT be mounted on the left front/left side rotary operated versions or if a multi-wire lug kit is installed or if a multi-wire lug kit is installed, or if the flange handle rod operator is installed. Ratings Signal output to PLC* • +24 Vdc, 10 mA max • Output signals • Digital 0 Vdc (low), 24 Vdc max (high) 0 Vdc Low – fuse is good • 24 Vdc High – fuse has opened Wiring • For power, signal and ground connections use shielded twisted pair 22-24 AWG (0.34-0.25 mm2) 300 V rated wire Installation technique • Mounts on the left side ONLY of the CCP2 and mechanically interlocks with the CCP2 switch handle with hardware provided. The CCP2-PLC-IND and CCP2-PLC-100 CANNOT be mounted on the left front/left side rotary operated versions or if a multi-wire lug kit is installed or if the flange handle rod operator is installed. IP20 rating — yes Storage and operating temperature • -20°C to 75°C (-4°F to 167°F) PLC programming • • Two distinct LEDs indicate unit power (green) and open fuse (red). Open fuse LED is resettable upon fuse replacement and the actuating the reset switch • The CCP2-PLC-IND or CCP2-PLC-100 signal line is designed to provide a digital input to a PLC I/O card. In this case, a Programmable Logic Control program must be written to properly interpret the input signal to the PLC. The PLC program should check for consecutive high signals before taking action on a critical process. * When the fuse opens, the output signal is sent high and will remain high until the unit is reset. Emissions and immunity testing • IEC 60947-1: Voltage Switchgear and Control Gear • IEC 61000-6-2: Electromagnetic Compatibility (EMC) • IEC 61000-4-2: Electrostatic Discharge Immunity - Test at level 3 (6 kV-Contact Discharge) and level 2 (4 kV-Air Discharge) • IEC 61000-4-3: Electromagnetic Compatibility - Radiated, Radiofrequency, Electromagnetic Field Immunity test at level x (20 V/m) • IEC 61000-4-4: Electromagnetic Compatibility - Testing and Measurement Techniques at level 3 (± 2kV - Power Port and ±1 kV - I/O Ports) • IEC 61000-4-5: Electromagnetic Compatibility - Surge Immunity test at level 4 (±4 kV) • IEC 61000-4-6: Immunity to Conducted Disturbances at level 3 (10 V) Catalog no. CCP2-PLC-IND CCP2-PLC-100 Switch Description Max per CCP2** 30/60 A Wired only remote fuse 1 per CCP2 indication (1, 2- or 3-pole) 100 A for PLC only applications Signal output to PLC Min. circuit volts 24 Vdc/ 10 mA 100 Vac ** The CCP2-PLC-IND and CCP2-PLC-100 CANNOT be mounted on the left front/ left side rotary operated versions or if a multi-wire lug kit is installed. De-energize all circuits and follow all prescribed safety procedures before installing or removing the CCP2-PLC-IND or CCP2-PLC-100. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-21 Disconnect switches • 11 — Disconnect switches PLC wiring schematic Installed on a CCP2-3-xx PLC power supply PLC fuse monitor +24 Vdc +24 Vdc 0 Vdc/Gnd 0 Vdc/Gnd Signal 10 mA max. The PLC fuse monitor needs to be powered by the same +24 Vdc and ground (0 Vdc/Gnd return) terminals that feed the PLC input card. If it is not, it may improperly signal. +24 Vdc 0 Vdc/Gnd PLC input card CCP2-PLC-IND mounted on a 3-pole switch and using the fork terminals. When mounted on a 2- or 1-pole switch, remove unused leads. If feeding multiple PLC fuse monitors from different power supplies, there must be multiple input cards being powered by those same power supplies as well. Note: the CCP2-PLC-IND CANNOT be mounted on the left front/left side rotary operated versions or if the multi-wire lug kit is installed or if the flange handle rod operator is installed. Dimensions — in Pin interlocks with CCP2 switch handle SIG GND +24vDC +24vDC RESET STATUS 2 4T 1.9 6T 5L 3 3 2.6 3L 2 2T 1L 1 1 ON 1.8 3.7 30 and 60 A CCP 0.3 Pin interlocks with CCP2 switch handle 4T 2 2.2 6T 3 5L 3 2.9 3L 2 2T 1L 1 SIG GND +24vDC +24vDC RESET STATUS 1 ON 2.0 3.7 0.3 100 A CCP 11-22 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 Ordering a complete switch installation 30 and 60 A CCP2 switches For a complete assembly, select from the following required and optional components, and accessories. Switches Amps Poles Switch (used alone or with flange cable or flange rod handles) CCP2-1-30CF 1 CCP2-2-30CF 30 2 CCP2-3-30CF Disconnect switches Required Catalog no. 3 CCP2-1-60CF 1 CCP2-2-60CF 60 2 CCP2-3-60CF 3 And Flange handle rod operator Description — 3-pole switches only CCP2-FLR1-21 Red/black painted handle CCP2-FLR1-21X Chrome handle Flange handle cable operator Description - 3-pole switches only, cannot be used with side or front rotary mechanisms CCP2-FLC1-36 36” cable, red/black painted handle CCP2-FLC1-36X 36” cable, chrome handle CCP2-FLC1-60 60” cable, red/black painted handle CCP2-FLC1-60X 60” cable, chrome handle CCP2-FLC1-120 120” cable, red/black painted handle CCP2-FLC1-120X 120” cable, chrome handle Multi-wire lug kits Description CCP2-MW1-3 3-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shrouds, pack of 3 Terminal shrouds Description CCP2-TS1-3 Pack of 3 Auxiliary contacts Description — mounts on right side, cannot be used with flange handle rod or cable operator CCP2-AUX NO/NC, 5 A / 240 V PLC fuse monitor Description — mounts on left side, cannot be used with flange handle rod operator CCP2-PLC-IND Signal output 24 Vdc / 10 mA Rating 1, 3R and 12 4X Optional Or Rating Type 1, 3R, 12 Type 4X Type 1, 3R, 12 Type 4X Type 1, 3R, 12 Type 4X Accessories And BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-23 11 — Disconnect switches Ordering a complete switch installation 30 and 60 A CCP2 clockwise rotary switches For a complete assembly, select from the following required and optional components, and accessories. Catalog no. Switches Amps Poles Right front rotary CCP2R-2-30CF 2 30 CCP2R-3-30CF CCP2R-2-60CF 3 2 60 CCP2R-3-60CF 3 Left front rotary CCP2RL-2-30CF 2 30 CCP2RL-3-30CF CCP2RL-2-60CF 3 2 60 CCP2RL-3-60CF 3 Right side rotary CCP2S-2-30CF CCP2S-3-30CF CCP2S-2-60CF 3 2 60 CCP2S-3-60CF Required 2 30 3 And Rotary handles Description Rating CCP2-H4X-B1 Selector handle — black/grey CCP2-H4X-R1 Selector handle — red/yellow Type 1, 4X, 12 CCP2-H4X-B2 Pistol handle — black/grey CCP2-H4X-R2 Pistol handle — red/yellow And Shafts (8 mm) Length CCP2-SH1-290 290 mm CCP2-SH1-490 490 mm NFPA 79 compliant handle Color CCP2-NFPA-1 Red Multi-wire lug kits Description CCP2-MW1-3 3-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shrouds, pack of 3 Optional And 11-24 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 Accessories And Description CCP2-TS1-3 Pack of 3 Auxiliary contacts Description — use with CCP2RL-(poles)-30/60CF switches CCP2-AUX NO/NC, 5 A / 240 V PLC fuse monitor Description — use with CCP2R-(poles)-30/60CF and CCP2S-(poles)-30/60CF switches CCP2-PLC-IND Signal output 24 Vdc / 10 mA BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Disconnect switches Terminal shrouds Eaton.com/bussmannseries 11-25 11 — Disconnect switches Ordering a complete switch installation 30 and 60 A CCP2 counterclockwise switches For a complete assembly, select from the following required and optional components, and accessories. Catalog no. Switches Amps Poles Left side rotary CCP2SL-2-30CF 2 30 CCP2SL-3-30CF CCP2SL-2-60CF 3 2 60 CCP2SL-3-60CF 3 Required And Rotary handles Description Rating CCP2-H4X-B1L Selector handle — black/grey CCP2-H4X-R1L Selector handle — red/yellow Type 1, 4X, 12 CCP2-H4X-B2L Pistol handle — black/grey CCP2-H4X-R2L Pistol handle — red/yellow And Shafts (8 mm) Length CCP2-SH1-290 290 mm CCP2-SH1-490 490 mm NFPA 79 compliant handle Color CCP2-NFPA-1 Red Multi-wire lug kits Description CCP2-MW1-3 3-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shrouds, pack of 3 Terminal shrouds Description CCP2-TS1-3 Pack of 3 Auxiliary contacts Description —mounts on right side CCP2-AUX NO/NC, 5 A / 240 V Optional And Accessories And 11-26 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 Ordering a complete switch installation 100 A CCP2 switches For a complete assembly, select from the following required and optional components, and accessories. Catalog no. Amps Poles Switch (used alone or with flange cable or flange rod handles) CCP2-1-100CF 1 CCP2-2-100CF 100 Disconnect switches Required Switches 2 CCP2-3-100CF 3 And Flange handle rod operator Description — 3-pole switches only CCP2-FLR1-21 Red/black painted handle CCP2-FLR1-21X Chrome handle Flange handle cable operator Description - 3-pole switches only, cannot be used with side or front rotary mechanisms CCP2-FLC1-36 36” cable, red/black painted handle CCP2-FLC1-36X 36” cable, chrome handle CCP2-FLC1-60 60” cable, red/black painted handle CCP2-FLC1-60X 60” cable, chrome handle CCP2-FLC1-120 120” cable, red/black painted handle CCP2-FLC1-120X 120” cable, chrome handle Multi-wire lug kits Description CCP2-MW1-6 6-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shrouds, pack of 3 Rating 1, 3R and 12 4X Optional Or Rating Type 1, 3R, 12 Type 4X Type 1, 3R, 12 Type 4X Type 1, 3R, 12 Type 4X Accessories And Terminal shrouds Description CCP2-TS1-6 Pack of 3 Auxiliary contacts Description — mounts on right side, cannot be used with flange handle rod or cable operator CCP2-AUX-100 NO/NC, 5 A / 240 V PLC fuse monitor Description — mounts on left side, cannot be used with flange handle rod operator CCP2-PLC-100 Signal output 24 Vdc / 10 mA BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-27 11 — Disconnect switches Ordering a complete switch installation 100 A CCP2 clockwise rotary switches For a complete assembly, select from the following required and optional components, and accessories. Catalog no. Switches Amps Poles Right front rotary CCP2R-2-100CF 2 100 CCP2R-3-100CF 3 Left front rotary CCP2RL-2-100CF 2 100 CCP2RL-3-100CF 3 Right side rotary CCP2S-2-100CF 2 100 Required CCP2S-3-100CF 3 And Rotary handles Description Rating CCP2-H4X-B1 Selector handle — black/grey CCP2-H4X-R1 Selector handle — red/yellow Type 1, 4X, 12 CCP2-H4X-B2 Pistol handle — black/grey CCP2-H4X-R2 Pistol handle — red/yellow And Shafts (8 mm) Length CCP2-SH1-290 290 mm CCP2-SH1-490 490 mm NFPA 79 compliant handle Color CCP2-NFPA-1 Red Optional And 11-28 Multi-wire lug kits Description CCP2-MW1-6 6-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shrouds, pack of 3 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 Terminal shrouds Description CCP2-TS1-6 Pack of 3 Auxiliary contacts Description — cannot be used on right front or right side operated switches CCP2-AUX-100 NO/NC, 5 A / 240 V PLC fuse monitor Description — Cannot be used on left front or left side operated switches CCP2-PLC-100 Signal output 24 Vdc / 10 mA BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Disconnect switches Accessories And Eaton.com/bussmannseries 11-29 11 — Disconnect switches Ordering a complete switch installation 100 A CCP2 counterclockwise switches For a complete assembly, select from the following required and optional components, and accessories. Catalog no. Switches Amps Poles Left side rotary CCP2SL-2-100CF 2 100 CCP2SL-3-100CF 3 Required And Rotary handles Description Rating CCP2-H4X-B1L Selector handle — black/grey CCP2-H4X-R1L Selector handle — red/yellow CCP2-H4X-B2L Pistol handle — black/grey CCP2-H4X-R2L Pistol handle — red/yellow Shafts (8 mm) Length CCP2-SH1-290 290 mm CCP2-SH1-490 490 mm NFPA 79 compliant handle Color CCP2-NFPA-1 Red Multi-wire lug kits Description CCP2-MW1-6 6-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shrouds, pack of 3 Terminal shrouds Description CCP2-TS1-6 Pack of 3 Auxiliary contacts Description — mounts on right side CCP2-AUX-100 NO/NC, 5 A / 240 V Type 1, 4X, 12 And Optional And Accessories And 11-30 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 The Bussmann series Low-Peak CUBEFuse is a UL Class CF currentlimiting, dual-element, time-delay branch circuit fuse with Class J electrical performance. Available in indicating and non-indicating versions, this finger-safe fuse has a very compact, space-saving size and is easily applied using the CUBEFuse holder (TCFH_N), UL 98 Compact Circuit Protector switch (CCP2-_CF) or Compact Circuit Protector Base (CCP2B up to 100 A) used in the Quik-Spec Coordination Panelboard). Ratings • • • • Smallest installed footprint of any UL Class CC, J, or R fuse solution • Easy application using CUBEFuse holders (TCFH_N), UL 98 Compact Circuit Protector (CCP2) switches and Compact Circuit Protector Base (CCP2B up to 100 A). See data sheet 9007 for details on the CUBEFuse holder, 10801 for details on the CCP2-_CF switch and 1161 for the CCP2B. • Holders and switches have an amp rating rejection feature to help prevent overfusing; 30, 60 and 100 A switches and holders will hold any CUBEFuse up to its rating, 200 and 400 A switches and 200, 225 and 400 A holders will hold any CUBEFuse 110 A and above up to its rating • UL Class CF with Class J time-delay electrical performance • Available in indicating and non-indicating versions • The indicating version features local easyID™ open fuse technology for faster troubleshooting and reduced downtime • Faster response to damaging faults helps reduce destructive thermal and magnetic forces • True dual-element fuse construction with a minimum 10 seconds time-delay at 500% of rating • Long time-delay minimizes nuisance openings caused by temporary overloads and transient surges • Up to 300 kA interrupting rating safely interrupts virtually any fault • Robust cycling and inrush current withstand Low let-through currents under fault conditions Volts • 600 Vac • 300 Vdc Amps • 6-400 A (indicating) • • 1-400 A (non-indicating) • Provides Type 2 “No Damage” protection for IEC motor starters when properly sized • Easy selective coordination with any other Bussmann series Low-Peak Class CC, J, L or RK1 fuse with simple 2:1 amp ratio between upstream and downstream fuses Interrupting rating • 300 kA RMS Sym. (Up to 100 A UL) • 200 kA RMS Sym. (110 to 400 A UL) • 200 kA RMS Sym. (Up to 100 A CSA) • 100 kA DC (Up to 400 A UL and up to 100 A CSA) * Finger-safe status depends on final, installed application, and will require using accessory shrouds for 110 to 400 A ratings. CUBEFuse (cat. no. TCFH_N) holders Agency information • UL Listed Class CF fuse: Guide JDDZ, File E4273 (up to 400 A) • CSA® Certified fuse: Class 1422-02, File 053787_C_000 (up to 100 A) • CE • RoHS compliant The CUBEFuse is also used in holders that can be dovetail together for the smallest footprint possible of any Class J fuse solution (see data sheet no. 9007 for details). Finger-safe DIN-Rail or panel mount holders up to 100 A. • 30 A holder accepts any CUBEFuse up to 30 A. Catalog numbers (amps) • 60 amp holder accepts any CUBEFuse up to 60 A. Indicating CUBEFuse TCF6 TCF30 TCF70 TCF150 TCF350 TCF10 TCF35 TCF80 TCF175 TCF400 TCF15 TCF40 TCF90 TCF200 TCF17-1/2 TCF45 TCF100 TCF225 TCF20 TCF50 TCF110 TCF250 TCF25 TCF60 TCF125 TCF300 • 100 amp holder accepts any CUBEFuse up to 100 A. Panel mount holders from 200 to 400 A. • 200 A holder accepts any CUBEFuse from 110 to 200 A Non-Indicating CUBEFuse • 225 TCF1RN TCF20RN TCF50RN TCF110RN TCF250RN TCF3RN TCF25RN TCF60RN TCF125RN TCF300RN TCF6RN TCF30RN TCF70RN TCF150RN TCF350RN TCF10RN TCF35RN TCF80RN TCF175RN TCF400RN TCF15RN TCF40RN TCF90RN TCF200RN TCF17-1/2RN TCF45RN TCF100RN TCF225RN A* holder accepts any CUBEFuse from 110 to 225 A • 400 A holder accepts any CUBEFuse from 110 to 400 A Finger-safe installation achievable for three ganged holders and lug kits with shroud * 200 A and 225 A holders share the same overall dimensions, but the 200 A holder will reject a 225 A fuse. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-31 Disconnect switches Features About the UL Class CF CUBEFuse 11 — Disconnect switches Ordering a complete switch installation 200 A CCP2 switches For a complete installation, select from the following required and optional components, and accessories. Catalog no. Switches Amps Poles CCP2-1-200CF 1 CCP2-2-200CF 200 2 Required CCP2-3-200CF 3 And Lug kits Description CCP2-L2-1 Stainless steel lug, 75° Cu only, 350 kcmil-4, 1 per pack CCP2-L2-1A Aluminum lug, 75°C Cu/Al, 350 kcmil-4, 1 per pack CCP2-MW2-3 3-port multi-wire lug, 75°C Cu/Al, 2-14, 3 per pack, includes terminal shroud CCP2-MW2-6 6-port multi-wire lug, 75°C Cu/Al, 6-14, 3 per pack, includes terminal shroud And Rotary mechanisms Description CCP2-SM Side rotary mechanism - mounts on left or right side of 1-, 2- and 3-pole switches CCP2-RM2 Front rotary mechanism - mounts only on 3-pole switches, requires clockwise rotating handle Optional And Rotary handles Description Rotation - must match switch rotation CCP2-H4X-B3 Short pistol handle — black/grey Clockwise CCP2-H4X-R3 Short pistol handle — red/yellow CCP2-H4X-B4 Long pistol handle — black/grey CCP2-H4X-R4 Long pistol handle — red/yellow For use with front rotary mechanism or side rotary mechanism CCP2-SM on the switch’s right side CCP2-H4X-B3L Short pistol handle — black/grey Counterclockwise CCP2-H4X-R3L Short pistol handle — red/yellow CCP2-H4X-B4L Long pistol handle — black/grey CCP2-H4X-R4L Long pistol handle — red/yellow Use only if installing side rotary mechanism CCP2SM on the switch’s left side Shafts (12 mm) Length CCP2-SH2-225 225 mm CCP2-SH2-425 425 mm NFPA 79 compliant handle Color CCP2-NFPA-2 Red And 11-32 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Rating Type 1, 4X, 12 Disconnect switches — 11 Flange handle rod operator CCP2-FLR2-21 Red/black, painted handle CCP2-FLR2-21X Chrome handle Flange handle cable operator Description - 3-pole switches only, cannot be used with side or front rotary mechanisms CCP2-FLC2-36 36“ cable, red/black painted handle CCP2-FLC2-36X 36“ cable, chrome handle CCP2-FLC2-60 60“ cable, red/black painted handle CCP2-FLC2-60X 60“ cable, chrome handle CCP2-FLC2-120 120“ cable, red/black painted handle CCP2-FLC2-120X 120“ cable, chrome handle Rating Type 1, 3R and 12 Disconnect switches Optional Or Description — 3-pole switches only, cannot be used with side or front rotary mechanisms Type 4X Or Rating Type 1, 3R and 12 Type 4X Type 1, 3R and 12 Type 4X Type 1, 3R and 12 Type 4X And Terminal shrouds Description CCP2-TS2-3 3-pole terminal shroud with phase shields, 1 per pack Phase barriers Description CCP2-PB2 Phase barriers, 2 per pack Accessories And Control wire terminals Description CCP2-CWK2 1/4” quick-connect control wire terminals - mounts on installed lug (cannot be used with lug CCP2-L2-1), 12 per pack Auxiliary contacts Description CCP2-AUX-S NO/NC, 5 A, 240 V - Can be mounted on right or left side Handle extension Description CCP2-HEX Handle extension to facilitate operating 1-, 2 and 3-pole switches. Cannot be used when side or front rotary mechanisms or flange handle rod or cable operators are installed. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-33 11 — Disconnect switches Ordering a complete switch installation 400 A CCP2 switches For a complete installation, select from the following required and optional components, and accessories. Catalog no. Switches Amps Poles CCP2-1-400CF 1 CCP2-2-400CF 400 2 CCP2-3-400CF 3 Required And Lug kits Description CCP2-L4-1 Stainless steel lug, 75° Cu only, 500 kcmil-3, 1 per pack CCP2-L4-1A Aluminum lug, 75° Cu only, 500 kcmil-3, 1 per pack CCP2-L4B-3 Stainless steel lug, 75° Cu only, 750-500 kcmil, 3 per pack, includes terminal shroud CCP2-L4B-3A Aluminum lug, 75°C Cu/Al, 750-500 kcmil, 3 per pack, includes terminal shroud CCP2-MW6-6 6-port multi-wire lug, 75°C Cu/Al, 1/0-14, 3 per pack, includes terminal shroud CCP2-L6-3 2-port stainless steel lug, 75° Cu only, 500 kcmil-2, 3 per pack, includes terminal shroud CCP2-L6-3A 2-port aluminum lug kit, 75° Cu/Al only, 500 kcmil-2, 3 per pack, includes terminal shroud And Rotary mechanisms Description CCP2-SM Side rotary mechanism - mounts on left or right side of 1-, 2- and 3-pole switches CCP2-RM4 Front rotary mechanism - mounts only on 3-pole switches, requires clockwise rotating handle Optional And Rotary handles Description Rotation - must match switch rotation CCP2-H4X-B3 Short pistol handle — black/grey Clockwise CCP2-H4X-R3 Short pistol handle — red/yellow CCP2-H4X-B4 Long pistol handle — black/grey CCP2-H4X-R4 Long pistol handle — red/yellow For use with front rotary mechanism or side rotary mechanism CCP2-SM on the switch’s right side CCP2-H4X-B3L Short pistol handle — black/grey Counterclockwise CCP2-H4X-R3L Short pistol handle — red/yellow CCP2-H4X-B4L Long pistol handle — black/grey CCP2-H4X-R4L Long pistol handle — red/yellow Use only if installing side rotary mechanism CCP2SM on the switch’s left side Shafts (12 mm) Length CCP2-SH2-225 225 mm CCP2-SH2-425 425 mm NFPA 79 compliant handle Color CCP2-NFPA-2 Red And 11-34 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Rating Type 1, 4X, 12 Disconnect switches — 11 Or Description - 3-pole switches only, cannot be used with side or front rotary mechanisms CCP2-FLR2-21 Red/black, painted handle CCP2-FLR2-21X Chrome handle Rating Type 1, 3R, 12 Type 4X Or Flange handle cable operator Description - 3-pole switches only, cannot be used with side or front rotary mechanisms CCP2-FLC2-36 36“ cable, red/black painted handle CCP2-FLC2-36x 36“ cable, chrome handle Rating Type 1, 3R, 12 Type 4X CCP2-FLC2-60 60“ cable, red/black painted handle CCP2-FLC2-60x 60“ cable, chrome handle Type 1, 3R, 12 Type 4X CCP2-FLC2-120 120“ cable, red/black painted handle CCP2-FLC2-120x 120“ cable, chrome handle Type 1, 3R, 12 Terminal shrouds Description CCP2-TS6-3 3-pole terminal shroud with phase shields, 1 per pack Phase barriers Description CCP2-PB6 Phase barriers, 2 per pack Type 4X And Accessories And Auxiliary contacts Description CCP2-AUX-S NO/NC, 5 A, 240 V - Can be mounted on right or left side Handle extension Description CCP2-HEX Handle extension to facilitate operating 1-, 2 and 3-pole switches. Cannot be used when side or front rotary mechanisms, or flange handle rod and cable mechanisms are installed. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-35 Disconnect switches Optional Flange handle rod operator 11 — Disconnect switches CUBEFuse Compact Circuit Protector Base Agency information 2011/65/EU • UL 98 Listed, Guide WHTY, File E302370 • cULus to Canadian Standard 22.2 No. 4, Guide WHTY7, File E302370 • RoHS compliant • CE Lineside bolt-on bus connector and torque • Bolt-mounted design into Quik-Spec Coordination Panelboard bus • #10-32 UNC hex flange Phillips screw; 2.8 N•m (25 lb-In) Loadside box lug terminal conductor data 1-Pole 2-Pole 3-pole CCP2B-1-_CF CCP2B-2-_CF CCP2B-3-_CF • Loadside fork terminal • Description The revolutionary Bussmann series Compact Circuit Protector Base (CCP2B) with CUBEFus™ is a UL 98 horsepower rated fused branch circuit disconnect. Primarily used in the Bussmann series Quik-Spec™ Coordination Panelboard, the CCP2B with CUBEFuse simplifies selective coordination for code complaince along with a lockout/tagout feature for isolating individual branch circuit loads to promote safe work practices. Features See conductor table for details Max. 30 A suitable for use with #8-32 UNC screw Lockout/tagout • 1/4” lock Local open fuse indication • Light illumination requires closed circuit and minimum 90 volts Carton quantity and shipping weight Item up to 60 amp switches 70 to 100 amp switches Poles 6 6 lbs (kg) 1.7 (0.77) 2.6 (1.18) • Uses finger-safe, current-limiting Class CF CUBEFuse with Class J performance available, time-delay or fast-acting versions from 1 to 100 amps • Patented amp rating rejection feature helps prevent overfusing • High 200 kA short-circuit current rating • Disconnect rated to provide a means for load isolation • • 2- and 3-pole versions full voltage rated at 600 Vac • Up to 125 Vdc ratings ** For fuse performance under or above 25°C, consult fuse performance derating charts. • UL 98 Listed for branch circuit disconnect • 1-, 2- and 3-pole versions are horsepower rated • Listed to UL and cULus • Open fuse indication lamp per pole speeds troubleshooting • Additional open fuse indication can be provided by using the timedelay indicating CUBEFuse in ratings from 6 to 100 A • Built-in switch/fuse interlock prevents removing or installing a fuse while energized • Permanent lockout/tagout and lock-on provision usign a 1/4” lock Environmental data Storage and operating temperature -20°C to 75°C** Available Bussmann series fuses UL fuse class CF Specifications: 15, 20, 30, 40, 50, 60, 70, 90 and 100 A Poles • Volts Data sheet no. 600 Vac/ 300 Vdc 9000 600 Vac/dc 2147 Lineside bolt-on bus connector Switch amp ratings and rejection breaks • Type/description Indicating time-delay, Low-Peak CUBEFuse (6-100 A) Non-indicating time-delay, Low-Peak CUBEFuse (1-100 A) Non-indicating fast-acting CUBEFuse (1-100 A) Switch ON and OFF symbols Lockout/tagout provision 1-, 2- and 3-poles Volts • 600 Vac (or less) • 125 Vdc* Switch handle Local open fuse indication light * Switch amp rating and installed fuse amp rating dependent, see catalog number table for details. CUBEFuse base Loadside box lug and fork terminals Data sheet no: 1161 11-36 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 Box lug conductor data Catalog numbers Poles CCP2B-1-15CF 1 CCP2B-2-15CF 2 CCP2B-3-15CF 3 CCP2B-1-20CF 1 CCP2B-2-20CF 2 CCP2B-3-20CF 3 CCP2B-1-30CF 1 CCP2B-2-30CF 2 CCP2B-3-30CF 3 CCP2B-1-40CF CCP2B-2-40CF CCP2B-3-40CF 1 2 3 CCP2B-1-50CF 1 CCP2B-2-50CF 2 CCP2B-3-50CF 3 CCP2B-1-60CF 1 CCP2B-2-60CF 2 CCP2B-3-60CF 3 CCP2B-1-70CF 1 CCP2B-2-70CF 2 CCP2B-3-70CF 3 CCP2B-1-90CF 1 CCP2B-2-90CF 2 CCP2B-3-90CF 3 CCP2B-1-100CF 1 CCP2B-2-100CF 2 CCP2B-3-100CF 3 † †† ††† * ** Voltage ratings 347 Vac, 125 Vdc 600 Vac, 125 Vdc Accepts CUBEFuse amp range Hp ratings SCCR (Vac)††† 0.5 Hp @ 120 V 1.5 Hp @ 240 V 1 to 15 3 Hp @ 240 V 5 Hp @ 480 V 7.5 Hp @ 600 V 600 Vac 347 Vac, 125 Vdc 600 Vac, 125 Vdc 0.75 Hp @ 120 V 2 Hp @ 240 V 1 to 20 3 Hp @ 240 V 7.5 Hp @ 480 V 10 Hp @ 600 V 600 Vac 347 Vac, 125 Vdc 600 Vac, 125 Vdc 1.5 Hp @ 120 V 3 Hp @ 240 V 1 to 30 5 Hp @ 240 V 15 Hp @ 480 V 10 Hp @ 600 V 600 Vac 347 Vac, 125 Vdc 600 Vac, 125 Vdc 7.5 Hp @ 240 V 20 Hp @ 480 V 10 Hp @ 600 V 1 to 50 1 to 60 600 Vac 3-12 75°C Cu 3.0 Hp @ 120 V 5 Hp @ 240 V 100 kA 7.5 Hp @ 240 V DC 20 Hp @ 480 V 10 Hp @ 600 V 7.5 Hp @ 240 V 1 to 70 Class Torque N•m (lb-in) Quantity Stranded, Class B to K Stranded, Class B/C Stranded, Class K Stranded, Class B to K Solid Stranded, UL ferrule, Class B/C Stranded, UL ferrule, Class K 3.95 (35) 2.26 (20) 3.39 (30) Single Dual 2.26 (20) Single/dual Single Twin† Single Twin† 2.26 (20) 3.39 (30) 2.82 (25) Stranded, Class B to K Single 2.26 (20) 2.82 (25) 4.52 (40 5.08 (45) 6.21 (55) Stranded, Class B to K Dual 3.95 (35) 2.26 3.95 4.52 2.26 2.82 2.26 2.26 2.26 3.39 5.08 2.26 3.39 2.26 Single Stranded, UL ferrule, Class B/C Twin† Single Dual Solid Single Class K Dual Single Class K, UL ferrule Twin Dimensions — in (mm) Ø 0.2 (Ø 5.1) 3.0 (76) 2.0 (51) 1.0 (25) 0.5 (13) 2.7 (69) 7.5 Hp @ 240 V 15 Hp @ 240 V 30 Hp @ 480 V 40 Hp @ 600 V 3.9 (99) 15-60 A 5.3 (133) 70-100 A 5.0 Hp @ 120 V 1 to 90 10 Hp @ 240 V 20 Hp @ 240 V 50 Hp @ 480 V 40 Hp @ 600 V Ø 0.2 (Ø 5.1) 5.0 Hp @ 120 V 1 to 100 (20) (35) (40) (20) (25) (20) (20) (20) (30) (45) (20) (30) (20) † Two stranded conductors placed in one UL Listed twin ferrule. 3.0 (76) 2.0 (51) 1.0 (25) 0.03 (0.8) 2.9 (73) 2.7 (70) 0.54 (14) 10 Hp @ 240 V 20 Hp @ 240 V 50 Hp @ 480 V 40 Hp @ 600 V 1 and 3 A indicating CUBEFuse not available. Correct fit with CCP2B disconnect requires indicating CUBEFuse with date code R38 or later. Not for use with motors. Indicating or non-indicating time-delay CUBEFuse only. 125 Vdc for installed fuse amp ratings up to 40 A. 24 Vdc for installed fuse amp ratings from 45 to 60 A. 125 Vdc for installed fuse amp ratings up to 80 A, 24 Vdc for installed fuse amp ratings from 90 to 100 A. Data sheet no: 1161 12-18 10 1-8 10-18 6-8 10-18 10-18 8-18 1-6 3-10 8-18 1-6 6-18 3.0 Hp @ 120 V 600 Vac 347 Vac, 125 Vdc** 600 Vac, 125 Vdc** 200 kA AC 7.5 Hp @ 240 V 20 Hp @ 480 V 10 Hp @ 600 V 600 Vac 347 Vac, 125 Vdc** 600 Vac, 125 Vdc** 10-18 4-18 6-18 4-18 6-18 70 to 100 A switches 12-18 10 8 4-6 1-3 3.0 Hp @ 120 V 600 Vac 347 Vac, 125 Vdc 600 Vac, 125 Vdc 10-18 75°C Cu 3 Hp @ 240 V 1 to 40 600 Vac 347 Vac, 125 Vdc* 600 Vac, 125 Vdc* 6-8 2.0 Hp @ 120 V 600 Vac 347 Vac, 125 Vdc* 600 Vac, 125 Vdc* AWG Wire type range 15 to 60 A switches 4-6 8-18 3.4 (86) For details on the CCP2B and its use in the Quik-Spec Coordination Panelboard, see data sheet no. 1160. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-37 Disconnect switches Catalog numbers and ratings 11 — Disconnect switches Compact Circuit Protector (cat. no. CCP2) For use with Class CC, Supplemental and IEC 10x38 mm fuses Class CC and midget CCP contents Section page Description and specifications. . . . . . . . . . . . . . . . . . . . . . . . . . . . .39-40 Catalog numbers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 41 Conductor information and available fuses . . . . . . . . . . . . . . . . . . . . . 42 Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 42 Accessories Multi-wire lug kit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 43 Selector and pistol handles . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 44 NFPA 79 compliant handle . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 44 Shafts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 44 Auxiliary contacts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 45 PLC fuse monitor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .46-47 How to order tables Clockwise rotary operated switches . . . . . . . . . . . . . . . . . . . . . . . .48-49 CCP2 switch 11-38 Switches only . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 50 Counterclockwise rotary operates switches . . . . . . . . . . . . . . . . . . . . 51 CCP2 right front rotary switch CCP2 left front rotary switch CCP2 right side rotary switch CCP2 left side rotary switch BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 Symbol CCP2-(poles)-30CC CCP2-(poles)-30M CCP2-1-DCC CCP2-1-DCM CCP2R-(pole)-30CC CCP2R-(pole)-30M CCP2RL-(pole)-30CC CCP2RL-(pole)-30M CCP2S-(pole)-30CC CCP2S-(pole)-30M CCP2SL-(pole)-30CC CCP2SL-(pole)-30M • Fuse type Class CC UL sup./IEC 10x38 Class CC Vdc UL sup./IEC 10x38 Vdc Class CC UL sup./IEC 10x38 Class CC UL sup./IEC 10x38 Class CC UL sup./IEC 10x38 Class CC UL sup./IEC 10x38 Description Switch only 1-pole switch only • UL Supplemental and IEC 10x38 mm fuse versions • UL 508 Listed, Guide NRNT, File E320230 • cULus Certified 22.2 No. 14-05 • IEC 60947-3 AC-23A DC voltage UL Class CC version (CCP2-1-DCC) • UL 508 Listed, cULus 22.2, No. 1405 DC IEC 10x38 version (CCP2-1-DCM) Right front rotary switch • Left front rotary switch • RoHS compliant • CE • Right side rotary switch IEC 60947-3, DC-23A Disconnect switches Catalog symbols Conductors/terminals • 75°C Cu/Al, see conductor tables for size, type and torque information • Box lug, single/dual conductor The revolutionary next generation Bussmann™ series Compact Circuit Protector (cat. no. CCP2) fused disconnect switch is 3/5 the footprint of a traditional fusible switch and provides up to a high 200 kA Short-Circuit Current Rating (SCCR) to help improve panel and assembly SCCR. • Fork terminal suitable for line, load or accessory connection • Multi-wire lug kit — see accessories for details The 35 mm DIN-Rail mount CCP is available in a variety of configurations to meet many application needs including rotary operation. • Left side rotary switch Description Application flexibility is extended with an optional multi-wire lug kit, with finger-safe shrouds, that provides three additional wire ports on each pole for power distribution applications. Other accessories include a PLC interface device for open fuse monitoring and NO/NC auxiliary contacts that easily integrate into many monitoring systems. Storage and operating temperature - 20°C to 75°C (-4°F to 167°F)* * For fuse performance under or above 25°C, consult fuse performance derating charts in the Bussmann Division publication no. 3002, titled Selecting Protective Devices (SPD) Lockout/tagout provisions • Switch only — 4 mm lock or Brady pin-out device part number 90850 • Switch with rotary operating mechanism — 1/4” lock Front and side rotary operated versions are easily applied for through-the-door or through the left or right side operation to enhance safety. Minimum enclosure size Ratings Mounting • • • • • Volts 10” x 8” x 6” (254 x 203 x 152 mm) 35 mm DIN-Rail • 600 Vac (UL Class CC) Local open fuse indication minimum voltage** • 240 Vac (UL Supplemental) • 90 Vac for AC switches • 400 Vac (IEC 10x38 mm) • 12 Vdc for DC switches • 80 Vdc (DC Class CC, DC UL Supplemental/IEC) ® Amps • 30 A (UL) • 32 A (IEC) ** Open fuse indication requires an open fuse to be in the CCP2 and the switch in the ON position. Accessories SCCR • Multi-wire lug kit with terminal shrouds • 200 kA (UL Class CC) Selector and pistol handles for use with rotary operated switches • • 10 kA (UL Supplemental) 8 mm shafts for use with selector and pistol handles • • 120 kA (IEC 10x38 mm max) Auxiliary contacts • • 20 kA (DC Class CC/UL) PLC fuse monitor • • 10 kA (DC UL Supplemental/IEC) Poles • 1-, 2- and 3-poles catalog number dependent Agency information • UL Class CC fuse versions • UL 98 Listed, Guide WHTY, File E302370 • cULus to Canadian Standard 22.2 No. 4-04, UL Guide WHTY7, File 302370 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-39 11 — Disconnect switches Features • Extremely compact (18 mm wide per pole ) design • High SCCR up to 200 kA (UL Class CC) and 120 kA (IEC) • Disconnect rated for load isolation • Full voltage rated up to 600 Vac or 80 Vdc • UL 98 Listed Class CC version is horsepower rated and suitable for branch circuit protection and disconnect • IEC 10x38 version complies with IEC 60947-3 and suitable for branch circuit protection and disconnect • Suitable for global installations, the switches comply with UL, cULus and IEC standards accepting UL Class CC, Supplemental or IEC aM and gG/gL fuses • Open fuse indication • Standard local open fuse indicating light for each pole • Optional PLC fuse monitor can be utilized to signal a PLC and open a contactor to de-energize all phases, if required • IP20 finger-safe with 10 AWG (6 mm2) or larger wire (box lug terminals only) • Built-in switch interlock prohibits removing the fuse under load • Padlockable handle for lockout/tagout • 4 mm lock for switch only • • 1/4” lock for rotary operated switches Rotary operated versions provide for through-the-door and through-the-side operation flexibility and enhanced safety with: • Right front switch operation • Left front switch operation • Right side switch operation • Left side switch operation Right front rotary operated CCP2 switch with PLC fuse monitor. • Optional selector and pistol handles available for use with rotary operated versions • Multi-wire lug kit with terminal shrouds allows for power distribution to multiple loads. Each lug has three ports rated for single and dual wires (see lug kit in accessories for conductor and torque details). Open fuse indicating light Rotary operating switch versions Switch handle (ganged on 2- and 3-pole versions) Fuse access door Left front rotary switch Right front rotary switch Clockwise operating handles Clockwise operating handles Fork terminal Box lug terminal Lockout/tagout provision 11-40 Right side rotary switch Left side rotary switch Clockwise operating handles Counterclockwise operating handles BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 Catalog numbers Max horsepower rating (Vac) Catalog no. Poles Description Amps Volts SCCR Wire type/ size* 120 240 480 600 1/2 — — — — 2 — — 3/4 3 5 7.5 7.5 75°C Cu/Al CCP2-1-30CC 1 CCP2-2-30CC 2 CCP2-3-30CC 3 CCP2R-2-30CC 2 CCP2R-3-30CC 3 CCP2RL-2-30CC 2 CCP2RL-3-30CC 3 CCP2S-2-30CC 2 CCP2S-3-30CC 3 CCP2SL-2-30CC 2 CCP2SL-3-30CC 3 347 Vac Switch only 600 Vac Switch with right front rotary operation Switch with left front rotary operation 600 Vac 30 A 600 Vac Switch with right side rotary operation 600 Vac Switch with left side rotary operation 600 Vac 200 kA — 2 3/4 3 5 — 2 — — 18-4 AWG 3/4 3 5 7.5 Fork terminal†† — 2 — — 3/4 3 5 7.5 — 2 — — 3/4 3 5 7.5 UL Supplemental and IEC 10x38 mm CCP2-1-30M 1 CCP2-2-30M 2 CCP2-3-30M 3 CCP2R-2-30M 2 CCP2R-3-30M 3 CCP2RL-2-30M 2 CCP2RL-3-30M 3 CCP2S-2-30M 2 CCP2S-3-30M 3 CCP2SL-2-30M 2 CCP2SL-3-30M 3 Switch only Switch with right front rotary operation Switch with left front rotary operation UL 30 A IEC 32 A** UL 240 Vac† IEC 400 Vac† 75°C Cu/Al UL 10 kA† IEC 120 kA† — — — — 18-4 AWG Fork terminal†† Switch with right side rotary operation Switch with left side rotary operation Single-pole DC switches CCP2-1-DCC 1 CCP2-1-DCM 1 UL Class CC 30 A UL supplemental 30 A IEC 10x38 32 A** 80 Vdc† 20 kA† — — — — 80 Vdc† 10 kA† — — — — 75°C Cu/Al 18-4 AWG Fork terminal†† * See box lug terminal conductor data table for details. ** 32 A Class aM, 25 A Class gG. † SCCR may be lower, refer to installed fuse data sheet for interrupting rating at applied voltage. †† Fork terminal with a 4.3 mm gap for a #8-32 stud, 30 A max, insulated flange, wire size 12-10 AWG. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-41 Disconnect switches Class CC 11 — Disconnect switches Box lug terminal conductor data Type Cu AWG range 4-18 6-8 6-8 10-18 Class Stranded, Stranded, Stranded, Stranded, 10-18 Solid 4-18 6-18 4-18 6-18 Class Class Class Class B to K B/C K B to K Left front and right front rotary switches Quantity Single Dual Dual 6 78 3.1 99 3.9 49 1.9 53 2.1 35 1.4 18 0.7 2.26 (20) Single/dual Single Stranded, UL ferrule, Class B/C 3.39 (30) Twin† Single Stranded, UL ferrule, Class K Single Stranded 2.26 (20) 80 3.1 2.82 (25) Dual 8 93 3.7 2.82 (25) Twin† 4-8 Al Torque N•m (lb-in) 2.26 (20) 3.39 (30) 2.26 (20) 99 [3.9] † Two stranded conductors placed in one UL Listed twin ferrule. 49 [1.9] 18 [0.7] 35 [1.4] 78 [3.1] 53 [2.1] Available Bussmann series fuses Fuse class CC M gG/gL aM Type/description LP-CC time-delay FNQ-R time-delay KTK-R fast-acting FNM time-delay FNQ time-delay KTK fast-acting BAF fast-acting KLM fast-acting C10G C10M Data sheet Volts no. 600 Vac/300 Vdc* 1023 600 Vac/300 Vdc 1014 600 Vac 1015 250 Vac 2028 500 Vac 1012 600 Vac 1011 250 Vac 2011 600 Vac/dc 2020 500 V (400 V@32 A) 720115 500 V (400 V@20@25 A) 720115 93 [3.7] 93 [3.7] 80 [3.1] Left side and right side rotary switches 78 3.1 * 1/2 to 2-1/2 and 20 to 30 A are 300 Vdc, 2-8/10 to 15 A are 150 Vdc. Dimensions – mm (in) 53 2.1 35 1.4 49 1.9 18 0.7 93 3.7 Switch 49 1.9 18 0.7 35 1.4 53 2.1 80 3.1 49 1.9 18 0.7 35 1.4 93 3.7 93 3.7 80 3.1 80 3.1 11-42 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 53 2.1 78 3.1 Disconnect switches — 11 Installed on CCP2-3-xx Multi-wire lug kit Catalog number • CCP2-MW1-3 Description The multi-wire lug kit permits expanding each box lug terminal on the switch into a three-port terminal for power distribution applications. Disconnect switches Each multi-wire lug kit comes with three (3) three-port lugs and three terminal shrouds. Shrouds provide finger-safe protection when properly installed. Lugs may be mounted on either the loadside or lineside to meet various application needs. Ports on any one lug accept any conductor combination listed, e.g., one of the three ports may have dual 14 AWG wires and the other two ports single 10 AWG wires. Ratings • Volts 600 V • Amps 60 A max • SCCR 200 kA Multi-wire lugs mount in switch box lug terminals to provide three additional wire ports per pole. Lugs can be mounted on the switch lineside or loadside. Each multi-wire lug kit comes with three lugs and three shrouds. Agency information Wire insulation strip lengths • UL Recognized (lug only) • RoHS compliant 1/8” Allen head screw Storage and operating temperature • 1 = 11/16” - 20°C to 75°C (-4°F to 167°F) 2 = 1-1/8” Multi-wire lug conductor information 3 = 1-9/16” • 75°C Cu/AL • AWG size and quantity per port - see table below Type Cu/Al Cu AWG range Class Quantity Stranded, Class B/C Single 10-14 Stranded, Class B/C 10-14 4-6 8 8 10-14 Torque N•m (lb-in) Strip back wire insulation to the lengths as indicated in the illustration above and the table below. 3.95 (35) Lug port 2.82 (25) 1 11/16 Single/dual* 2.26 (20) 2 1-1/8 Solid Single 2.26 (20) 3 1-9/16 UL ferrule, Class B to K Single/twin † Strip wire insulation back (inch) 2.82 (25) 2.26 (20) * Dual wire to be same size and type. † Two stranded conductors placed in one UL Listed twin ferrule. CCP2 box lug torque for multi-wire lug • 4.52 N•m (40 lb-in) Terminal shroud accessory Terminal shrouds are available without multi-wire terminals. Catalog no. Description CCP2-TS1-3 Pack of three Wiring versatility is provided by single/dual rated box lug terminals on the switch, or by the three-port multi-wire lug kit that’s also single/dual wire rated. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-43 11 — Disconnect switches Selector handles Selector and pistol handles Catalog symbol • CCP2-H4X-_ Description Selector and pistol handles for use with any 2- and 3-pole CCP2 rotary operated switch. Both selector and pistol handles are available in black/grey and red/yellow colors and clockwise/counterclockwise operating modes. Applying clockwise and counterclockwise operation depends upon the CCP2 rotary switch configuration. Installation requires an 8 mm shaft (ordered separately). Pistol handles Each handle is rated NEMA 4X and capable of accepting up to three (3) 1/4” diameter shank locks for lockout/tagout in the OFF position. They can also be field configured for lock-on. In application, only the clockwise operating handles in combination with either the left front or right front rotary switches provide a door interlock means to ensure the enclosure door remains shut during lockout/tagout or lock-on. Both clockwise and counterclockwise operating handles when mounted on the enclosure’s left or right side do NOT provide a door interlock means. See the catalog number table below for applicable rotary switch, handle and shaft combinations. Handle shafts Agency information • UL Listed, Guide DIHS, File E140305 • NEMA 4X rating • RoHS compliant • CE Storage and operating temperature • NFPA 79 compliant handle -20°C to 75°C (-4°F to 167°F) Packaging • Catalog number Each handle is packaged individually • Handle shafts NFPA 79 compliant handle mounts on the shaft of front rotary operated switch installations and provide a lockout means independent of the door position. Catalog symbol • CCP2-NFPA-1 Description CCP2-SH1-_ Description Eight millimeter square shafts available in 290 and 490 millimeter (11.5 and 19.3 inch) lengths. Shafts are indexed to ensure handle/ switch orientation for correct operation. Shafts are cut to length when installed. Packaging • Each shaft is packaged separately For these switch catalog numbers CCP2R-(pole)-30CC CCP2R-(pole)-30M CCP2RL-(pole)-30CC CCP2RL-(pole)-30M CCP2S-(pole)-30CC CCP2S-(pole)-30M Description/operation Right front rotary, clockwise Left front rotary, clockwise Right side rotary, clockwise Left side rotary, counterclockwise 11-44 Order either shaft catalog number • CCP2-H4X-B1 (selector, black/grey) • CCP2-H4X-R1(selector, red/yellow) • CCP2-H4X-B2 (pistol, black/grey) • CCP2-SH1-290 (11.5”/290 mm) • CCP2-H4X-R2 (pistol, red/yellow) • CCP2-H4X-B1L (selector, black/grey) CCP2SL-(pole)-30CC CCP2SL-(pole)-30M Order these handle catalog numbers (description) • CCP2-SH1-490 (19.3”/490 mm) • CCP2-H4X-R1L (selector, red/yellow) • CCP2-H4X-B2L (pistol, black/grey) • CCP2-H4X-R2L (pistol, red/yellow) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 Auxiliary contacts Installed on a CCP2-3-xx Catalog number Note: CCP2-AUX CANNOT be mounted on the right front and right side rotary operated versions. • CCP2-AUX Description Disconnect switches NO+NC contact output to indicate the switching mechanism status on the CCP2. A single unit can be mounted on any 1-, 2- or 3-pole CCP2 switch and the left front/left side rotary operated switches. Ratings • Amps up to 5 A • Volts up to 240 Vac • NC/NO contacts are closed/open when the CCP2 switch is in the “ON” position (closed) Description Max per CCP2* Signal output Auxiliary contacts NO+NC for switch status 1 per CCP2 (1-, 2- or 3-pole) 5 A / 240 Vac Dimensions — in 1.8 * The CCP2-AUX CANNOT be mounted on the right front and right side rotary operated versions. De-energize all circuits and follow all prevailing safety procedures before installing or removing the CCP2-AUX. 2.6 Agency information • UL 98 Recognized, Guide WHTY2, File E155130 • cURus to Canadian Standard 22.2 No. 4-04 • IP20 finger-safe in installed state • RoHS compliant • CE STRIP 33 NO 34 NO 41 NC 42 NC 3.7 1.9 0.19 0.3 Wiring • 75°C Cu, 20-16 AWG (0.5 to 1.5 mm2) wire • Torque 0.56 N•m (5 lb-in) Packaging • The CCP2-AUX is packaged individually Installation technique • Mounts on the CCP2’s right side ONLY and mechanically interlocks with the CCP2 switch handle with provided hardware. The CCP2-AUX CANNOT be mounted on the right front and right side rotary operated versions. Storage and operating temperature • -20°C to 75°C (-4°F to 167°F) CCP2-AUX auxiliary contacts mounted on a 3-pole CCP2 switch. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-45 11 — Disconnect switches PLC fuse monitor Wiring Catalog number • • CCP2-PLC-IND Packaging Description A resettable three-phase fuse monitor that integrates with the I/O card in a Programmable Logic Controller (PLC). A single unit can be mounted on any 1-, 2- or 3-pole CCP2 switch and the right front/ right side rotary operated switches. A single unit monitors up to three phases. When used on 1- and 2-pole switches unused conductor(s) are removed after installation. The CCP2-PLC-IND CANNOT be mounted on the left front/left side rotary operated versions or if the multi-wire lug kit is installed. Ratings • • • 24 Vdc High – fuse has opened • Includes 0.110” (2.8 mm) quick connects for power, signal and ground connections Installation technique • Mounts on the left side ONLY of the CCP2 and mechanically interlocks with the CCP2 switch handle with hardware provided. The CCP2-PLC-IND CANNOT be mounted on the left front/ left side rotary operated versions or if the multi-wire lug kit is installed. IP20 rating — yes Storage and operating temperature • Output signals • Digital 0 Vdc (low), 24 Vdc max (high) 0 Vdc Low – fuse is good The CCP2-PLC-IND is packaged individually -20°C to 75°C (-4°F to 167°F) PLC programming +24 Vdc, 10 mA max • • • Signal output to PLC* • For power, signal and ground connections use shielded twisted pair 22-24 AWG (0.34-0.25 mm2) 300 V rated wire * When the fuse opens, the output signal is sent high and will remain high until the unit is reset. The CCP2-PLC-IND signal line is designed to provide a digital input to a PLC I/O card. In this case, a Programmable Logic Control program must be written to properly interpret the input signal to the PLC. The PLC program should check for consecutive high signals before taking action on a critical process. Installed on a CCP2-3-xx Emissions and immunity testing • IEC 60947-1: Voltage Switchgear and Control Gear • IEC 61000-6-2: Electromagnetic Compatibility (EMC) • IEC 61000-4-2: Electrostatic Discharge Immunity - Test at level 3 (6 kV-Contact Discharge) and level 2 (4 kV-Air Discharge) • IEC 61000-4-3: Electromagnetic Compatibility - Radiated, Radiofrequency, Electromagnetic Field Immunity test at level x (20 V/m) • IEC 61000-4-4: Electromagnetic Compatibility - Testing and Measurement Techniques at level 3 (± 2 kV - Power Port and ±1 kV - I/O Ports) • IEC 61000-4-5: Electromagnetic Compatibility - Surge Immunity test at level 4 (±4 kV) • IEC 61000-4-6: Immunity to Conducted Disturbances at level 3 (10 V) Description Wired remote fuse indication for PLC applications Max per CCP2** Signal output to PLC Min. circuit volts 1 per CCP2 (1, 2- or 3-pole) 24 Vdc/ 10 mA 100 Vac CCP2-PLC-IND mounted on a 3-pole switch and using the fork terminals. When mounted on a 2- or 1-pole switch, remove unused leads. Note: The CCP2-PLC-IND CANNOT be mounted on the left front/left side rotary operated versions or if the multi-wire lug kit is installed. ** The CCP2-PLC-IND CANNOT be mounted on the left front/left side rotary operated versions or if the multi-wire lug kit is installed. De-energize all circuits and follow all prescribed safety procedures before installing or removing the CCP2-PLC-IND. Agency information • UL 98 Recognized, Guide WHTY2, File E155130 • cURus to Canadian, Standard 22.2 No. 4-04 Local indication • Two distinct LEDs indicate unit power (green) and open fuse (red). Open fuse LED is resettable upon fuse replacement and actuating the reset switch. 11-46 CCP2-PLC-IND fuse monitor mounted on a right front rotary operated switch. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 PLC wiring schematic PLC fuse monitor Circuit monitoring leads from CCP2-PLC-IND to CCP2 (100 – 600 Vac) +24 Vdc +24 Vdc 0 Vdc/Gnd 0 Vdc/Gnd Signal 10 mA max. Circuit monitoring leads from PLC or remote monitoring device. The PLC fuse monitor needs to be powered by the same +24 Vdc and ground (0 Vdc/Gnd return) terminals that feed the PLC input card. Disconnect switches PLC power supply CCP2-PLC-IND connections from a CCP2-3-xx to a remote monitoring device If it is not, it may improperly signal. If feeding multiple PLC fuse monitors from different power supplies, there must be multiple input cards being powered by those same power supplies as well. +24 Vdc 0 Vdc/Gnd PLC input card Connection from CCP2-PLC-IND to CCP2-3-xx Lead from CCP2-PLC-IND Power lead Leads from CCP2-PLC-IND are connected to the fork terminals as shown. Note: When monitoring a 1- or 2-pole switch, remove unused leads. Dimensions — in 2T 1 SIG GND Pin interlocks with CCP2 switch handle 4T 2 3L 2 1.9 3 3 6T 5L 2.6 +24vDC +24vDC RESET STATUS 1L 1 ON 1.8 3.7 0.3 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-47 11 — Disconnect switches Class CC and UL Supplemental (IEC 10x38) clockwise rotary switches For a complete assembly, select from the following required and optional components, and accessories. Catalog no. Switches Amps Poles Right front rotary CCP2R-2-30CC 2 CCP2R-3-30CC 3 30 CCP2R-2-30M 2 CCP2R-3-30M 3 Left front rotary CCP2RL-2-30CC 2 CCP2RL-3-30CC 3 30 CCP2RL-2-30M 2 CCP2RL-3-30M 3 Right side rotary CCP2S-2-30CC 2 CCP2S-3-30CC 3 30 CCP2S-2-30M 2 Required CCP2S-3-30M 3 And Rotary handles Description NEMA rating CCP2-H4X-B1 Selector handle — black/grey CCP2-H4X-R1 Selector handle — red/yellow 4X CCP2-H4X-B2 Pistol handle — black/grey CCP2-H4X-R2 Pistol handle — red/yellow And Shafts (8 mm) Length CCP2-SH1-290 290 mm CCP2-SH1-490 490 mm NFPA 79 compliant handle Color CCP2-NFPA-1 Red Optional And 11-48 Lug kits Description CCP2-MW1-3 3-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shrouds, pack of 3 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 Accessories Description CCP2-TS1-3 Pack of 3 Auxiliary contacts Description — cannot be used on right front or right side operated switches CCP2-AUX NO + NC, 5 A / 240 V PLC fuse monitor Description — Cannot be used on left front operated switches CCP2-PLC-IND Signal output 24 Vdc / 10 mA BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-49 Disconnect switches And Terminal shrouds 11 — Disconnect switches Class CC and UL Supplemental (IEC 10x38) Switches For a complete assembly, select from the following required and optional components, and accessories. Catalog no. Switches Amps Poles Required Switch CCP2-1-30CC 1 CCP2-2-30CC 2 CCP2-3-30CC 30 CCP2-1-30M CCP2-2-30M 3 1 2 CCP2-3-30M 3 Optional And Lug kits Description CCP2-MW1-3 3-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shrouds, pack of 3 Terminal shrouds Description CCP2-TS1-3 Pack of 3 Auxiliary contacts Description CCP2-AUX NO + NC, 5 A / 240 V PLC fuse monitor Description CCP2-PLC-IND Signal output 24 Vdc / 10 mA Accessories And 11-50 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 Class CC and UL Supplemental (IEC 10x38) counterclockwise switches For a complete assembly, select from the following required and optional components, and accessories. Catalog no. Switches Amps Poles Left side rotary CCP2SL-2-30CC 2 3 30 CCP2SL-2-30M Disconnect switches CCP2SL-3-30CC 2 CCP2SL-2-30M 2 Required And Rotary handles Description NEMA rating CCP2-H4X-B1L Selector handle — black/grey CCP2-H4X-R1L Selector handle — red/yellow 4X CCP2-H4X-B2L Pistol handle — black/grey CCP2-H4X-R2L Pistol handle — red/yellow And Shafts (8 mm) Length CCP2-SH1-290 290 mm CCP2-SH1-490 490 mm Optional And Lug kits Description CCP2-MW1-3 3-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shrouds, pack of 3 Terminal shrouds Description CCP2-TS1-3 Pack of 3 Auxiliary contacts Description —mounts on right side CCP2-AUX NO + NC, 5 A / 240 V Accessories And BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-51 11 — Disconnect switches CCPLP UL 98 Listed low profile Compact Circuit Protector The revolutionary Bussmann series low profile Compact Circuit Protector (CCPLP) is a UL 98/508 Listed fused disconnect switch. This front panel mount switch is available in 1-, 2- and 3-pole versions, and has the smallest footprint of any fused disconnect switch. It features an SCCR up to 200 kA to help improve equipment SCCR. 2011/65/EU Poles 1-, 2- and 3-pole factory configured* * 2- and 3-pole versions supplied as ganged switches with phase barriers. Agency information • • Four fuse types The CCPLP is available for UL Class CC and G, UL supplemental (13/32” x 1-1/2”) and IEC 10x38 mm fuses. • Class CC and G versions are easily selectively coordinated with the upstream Bussmann series CUBEFuse™ using published fuse ampacity ratio tables. Class G fuse versions • UL 98 Listed, Guide WHTY, File E302370 • IEC 60947-3 AC-23A Class CC fuse versions • UL 98 Listed, Guide WHTY, File E302370 • cULus to Canadian Standard 22.2 No. 4-04, Guide WHTY7, File E302370 • IEC 60947-3 AC-23A UL supplemental and IEC 10x38mm fuse versions • UL 508 Listed, Guide NRNT, File E320230 • cULus Listed to Canadian Standard 22.2 No. 14-05, Guide NRNT7, File E320230 • IEC 60947-3 AC-23A Design/application flexibility The CCPLP is easily integrated into many panel designs and provides a high SCCR alternative to low profile circuit breakers on the market. Ratings • • • • 600 Vac (Class CC up to 30 A, Class G 20 A) • 550 Vac (10x38mm IEC Class aM 0.16-16 A) • 500 Vac (10x38mm IEC Class gG 0.5-25 A) • 400 Vac (10x38mm IEC Class aM 20-32 A, gG 32 A) • 240 Vac (13/32” x 1-1/2” UL supplemental 30 A) Amps Up to 30 A (UL) • Up to 32 A (IEC) RoHS compliant • CE Safety Volts • • • Finger-safe IP20 from panel front Mounting • Front panel mounting with customer supplied M3 screws Open fuse indication* • Local open fuse indication provided for each pole by an orange neon lamp (minimum 90 V) * Open fuse indication requires an energized, closed circuit with an open fuse in the CCPLP and the switch in the ON position. SCCR • 200 kA (Class CC) • 120 kA (10x38mm IEC Class gG and aM) • 100 kA (Class G) • 10 kA (13/32” x 1-1/2” UL supplemental) • Frequency 50/60 Hz • Impulse voltage 8 kV Terminals and conductors 75°C/90°C Cu Lockout/tagout provision • Circuit labeling provision • Screw terminal, 10-32 phil-slot screw with external tooth lock washer (use with properly rated/UL Listed ring or fork terminal) • Pressure plate terminal, 10-32 phil-slot screw (single 22-6 AWG solid or stranded) Accepts up to two universal marker labels, catalog number TM26CB Carton quantity • • Brady pin-out device, part number 90844 12 poles (1-pole: 12 units, 2-pole: 6 units, 3-pole: 4 units) Minimum enclosure size • 6” x 6” x 4” per UL 98 Listing Ambient storage and operating temperature • -20 to 90°C, 85% relative humidity, non-condensing Data sheet no.10372 11-52 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 Available CCPLP versions Horsepower (Vac) 240 480 600 Poles Volts AC Amps SCCR (kA) CCPLP-1-20G-P CCPLP-2-20G-P CCPLP-3-20G-P 1 2 3 600 20 100 — — — — — — — — — — — — CCPLP-1-30CC-P CCPLP-2-30CC-P CCPLP-3-30CC-P fuses CCPLP-1-30M-P 1 2 3 600 30 200 0.5 — — — 2 3 — — 4 — — 7. 5 — — — — CCPLP-2-30M-P 2 240 30 10 — — — — CCPLP-3-30M-S CCPLP-3-30M-P IEC 10x38 gG and aM fuses 3 — — — — CCPLP-1-30M-S CCPLP-1-30M-P 1 120 — — — — CCPLP-2-30M-S CCPLP-2-30M-P 2 120 — — — — CCPLP-3-30M-S CCPLP-3-30M-P 3 120 — — — — CCPLP-2-30M-S Pressure plate terminal 1 gG fuses: up to 25 A @ 500 V 32 A @ 400 V aM fuses: up to 16 A @ 550 A 20-23 A @ 400V 120 Switch handle (ganged on 2- and 3-pole versions) Fuse access door Open fuse indicating light Mounting holes for customer supplied M3 screws Lockout/tagout provision* Circuit marking area Phase barrier 10/32 phil-slot screw or pressure plate terminal * Use Brady pin-out device, P/N 90844 Available Bussmann series fuses Fuse class Catalog symbol CC FNQ-R, KTK-R, LP-CC G SC M BAF, FNM, FNQ, KLM, KTK gG C10G aM C10M Data sheet no.10372 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-53 Disconnect switches Catalog no. Screw terminal UL Class G fuse CCPLP-1-20G-S CCPLP-2-20G-S CCPLP-3-20G-S UL Class CC fuses CCPLP-1-30CC-S CCPLP-2-30CC-S CCPLP-3-30CC-S UL 13/32”x1-1/2” midget CCPLP-1-30M-S 11 — Disconnect switches UL 98 fused disconnect switches up to 800 A Bussmann series UL 98 and UL 489 fused disconnect switches “break” and “make” power circuits ON and OFF load. The switches employ double break contacts per pole that help ensure complete isolation of the fuse when the switch is in the "OFF" position. Agency information • UL 98, Guide WHTY, File E155130 • UL 489, Guide WJAZ, File E359801 • CSA 22.2 No. 4, File 257020 • Conforms with IEC 60947-3 • NFPA 79 Features • Make and break power under load • Double break by pole • 30-60 A DIN-Rail or panel mount, 100-800 A panel mount only • Up to 200 kA short-circuit current rating • Finger-safe covers • Compact footprints available • Defeatable handles automatically re-latch when the panel door is closed • Most disconnect switches are front, right side, flange or direct handle operable • NFPA 79 compliant handle kits Online resources available at Eaton.com/bussmannseries • CAD drawings • Instruction sheets • UL information Available Bussmann series fuses Fuse class CC J L 11-54 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Catalog symbol/type LP-CC time-delay, current limiting FNQ-R time-delay KTK-R fast-acting LPJ time-delay, current limiting JKS fast-acting fuses DFJ high speed drive fuse KRP-C time-delay, current limiting KTU fast-acting KLU time-delay KRP-CL (225-600 A) Eaton.com/bussmannseries Disconnect switches — 11 UL 98 fused disconnect switches — 30 to 800 A Poles 2-pole — — RDF30J-3RDF30CC-3 COMP RDF30J-3NRDF30CC-3N COMP — — UL 489 UL 489 CC J 30 30 Compact Compact 3-pole 3-pole + neutral 4-pole UL standard Fuse class Max fuse/ampacity Switch type Handle operation UL electrical ratings Max AC volts Max DC volts* 1-phase, 240 3-phase, 240 Std. AC Hp ratings 3-phase, 480 3-phase, 600 3-phase, 240 Max. AC Hp 3-phase, 480 ratings 3-phase, 600 125 Vdc DC Hp ratings 250 Vdc Electrical characteristics SCCR Terminal lugs/kits Mounting torque - lb-in (N•m) Wire type Wire range, torque - lb-in (N•m) Solid Stranded Mechanical characteristics Endurances/cycles Physical characteristics Dimensions 2-pole 3-pole Weight - lbs 3-pole + (kg) neutral 4-pole Environmental Operating temp. range Flammability rating Accessories Lug Kit Direct Front selector Handles Front pistol Side pistol Cable Flange Shaft NFPA through door handle Shafts c/s - mm Terminal shrouds Auxiliary contacts AC ratings RDF30J-3 / RDF60J-3-COMP (1) NO (1) NC Volts Amps RDF60J-3 RDF200J-3 RDF600J-3 RDF30J-2 RDF60J-2-COMP Catalog no. RDF60J-2 RDF100J-2 RDF200J-2 RDF400J-2 RDF600J-2 RDF800L-2 RDF30J-3 RDF60J-3-COMP RDF60J-3 RDF200J-3 RDF400J-3 RDF600J-3 RDF800L-3 RDF100J-3 — — — — — — — — RDF30J-4 UL 98 J 30 Standard RDF60J-4-COMP UL 98 J 60 Compact RDF60J-4 UL 98 J 60 Standard RDF100J-4 UL 98 J 100 Standard Front/Side , Flange RDF200J-4 UL 98 J 200 Standard Front/Side , Flange RDF400J-4 UL 98 J 400 Standard Front/Side , Flange RDF600J-4 UL 98 J 600 Standard RDF800L-4 UL 98 L 800 Standard Front Front Front/Side Front/Side Front/Side 600 Vac — — 3 5.0 7.5 7.5 15 20 — — 600 Vac — — 3 5.0 7.5 7.5 15 20 — — 600 Vac 250 Vdc 3 3 5.0 7.5 7.5 15 20 3 5 600 Vac 250 Vdc 10 7.5 15 15 15 30 50 5 10 600 Vac 250 Vdc 10 7.5 15 15 15 30 50 5 10 600 Vac 250 Vdc 10 15 25 30 30 60 75 7.5 20 600 Vac — 10 25 50 60 60 125 150 — — 600 Vac 250 Vdc 10 50 100 125 125 250 350 20 50 600 Vac 600 Vdc — 75 150 200 200 400 500 — — 600 Vac 600 Vdc — 75 200 250 200 500 500 — — 100 kA Integral — 75°C Cu 14-10, 27 100 kA Integral — 75°C Cu 14-10, 27 200 kA Integral — 75°C Cu 14-10, 31 100 kA Integral — 75°C Cu 200 kA Integral — 75°C Cu 12-10, 35.4 200 kA Integral — 75°C Cu 12-10, 35.4 200 kA • 160 (18) 75°C Cu/ Al 200 kA • 310 (35) 75°C Cu/ Al 200 kA • 310 (35) 75°C Cu/ Al 200 kA • 310 (35) 75°C Cu/ Al — — — (3.1) 14-10 27 (3.1) (3.5) 14-10, 31 (3.5) (4) 12-1, 35.4 Front , Flange Front , Flange (4) — 12-1, 35.4 (4) 6-300 kcmil, 275 (31) 550 (62), Dual 1/0-250 kcmil 550 (62) (2) 2-600 kcmil, 375 (2) 2-600 kcmil, 375 10,000 8000 6000 5000 5000 11.4 (5.2) 16.6 (7.6) 31.7 (14.4) 44.2 (20.1) 31.7 (14.4) 44.2 (20.1) 4-600 kcmil, 14-10 27 (3.1) 14-6 , 31 (3.5) 14-6, 31 (3.5) 10,000 10,000 10,000 10,000 — 1.3 (0.6) — 1.4 (0.6) 3.0 (1.3) 3.8 (1.7) 3.1 (1.4) 4.1 (1.8) 1.4 (0.6) 1.5 (0.7) — — — — — — — — — — 4.7 (2.1) 4.8 (2.2) 6.49 (2.9) 6.49 (2.9) 10.8 (4.9) 21.8 (9.9) 56.8 (25.8) 56.8 (25.8) -20-70°C UL 94-V0 -20-70°C UL 94-V0 -20-70°C UL 94-V0 -20-70°C UL 94-V0 -20-70°C UL 94-V0 -20-70°C UL 94-V0 -20-70°C UL 94-V0 -20-70°C UL 94-V0 -20-70°C UL 94-V0 -20-70°C UL 94-V0 Integral • Integral • Integral • Integral • Integral • Integral • • • • • • • • • • • — — — — — — — — • — — — • 5x5 Not Required • • 600 10 • — — — • 5x5 Not Required • • 600 10 • • • • • 10x10 Not Required • • 600 10 • • • • • 10x10 • • • • • 10x10 Not Required • • 600 10 • • • • • 10x10 Not Required • • 600 10 • • • • • 10x10 • • — — • 10x10 • — — — • 12X12 • — — — • 12X12 (3.1) 10,000 See drawings on product pages 4.1 (1.8) 4.1 (1.8) 5.7 (2.6) 5.3 (2.4) 5.3 (2.4) 7.8 (3.5) Not Required • • 600 10 (4) (42.4) (42.4) • • • • • • 600 10 • • 600 10 • • 600 10 • • 600 10 • Available, see product page for details and catalog numbers. — Not available. * General purpose only, not photovoltaic rated. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-55 Disconnect switches RDF30CC-3 11 — Disconnect switches UL 98 fused rotary disconnect switches — 30 A Standard 30 amp Class CC and compact 30 amp Class J For a complete assembly, select: Switch Switch Fuse Amps class Poles 30 3 CC 30 3 + Ntrl.* 30 3 J 30 3 + Ntrl.* * Neutral is switched. SCCR (kA) 100 100 100 100 Max Hp rating, 3-phase 220/240 440/480 600 7.5 15 20 7.5 15 20 7.5 15 20 7.5 15 20 Conductor AWG size /type 14-10 Sol/Str 75°C Cu Plus Direct mount handle - mounts directly to switch, no shaft required For switch cat. no. Color Test function Padlockable Catalog no. RDF30CC-_ DIR-05 Black Y Y RDF30J-_-COMP Handle Select for standard applications + or DIR-06 OR External front operated selector handle - shaft required NEMA type Color Test function Padlockable Defeatable 1, 3R, 4, 4X, 12 Black N Y Y 1, 3R, 4, 4X, 12 Red/yellow Shafts for selector handles Length - in (mm) Mounting depth (X) - in (mm) 7.9 (200) 4.02~9.65 (102~245) 12.6 (320) 4.02~14.37 (102~365) 15.7 (400) 4.02~17.52 (102~445) OR External front operated pistol handles - shaft required NEMA type Color Test function Padlockable Defeatable 1, 3R, 12 Black 1, 3R, 12 Red/yellow N 1, 3R, 4, 4X, 12 Black Y Y 1, 3R, 4, 4X, 12 Red/yellow 1, 3R, 4, 4X, 12 Black Y 1, 3R, 4, 4X, 12 Red/yellow Metallic hasp (heavy duty) external front operated pistol handles - shaft required NEMA type Color Test function Padlockable Defeatable Catalog no. 1, 3R, 4, 4X, 12 Black H4X-05BHD 1, 3R, 4, 4X, 12 Red/yellow N + Catalog no. RDF30CC-3 RDF30CC-3N RDF30J-3-COMP RDF30J-3N-COMP Y Catalog no. SH1-200 SH1-320 SH1-400 Catalog no. H12-05B H12-05R H4X-05B H4X-05R H4X-05TB H4X-05TR Y H4X-05RHD Shafts for pistol handles Length - in (mm) Mounting depth (X) - in (mm) 7.9 (200) 4.02~9.65 (102~245) 12.6 (320) 4.02~14.37 (102~365) 15.7 (400) 4.02~17.52 (102~445) Catalog no. SH2-200 SH2-320 SH2-400 OR NFPA through the door handle kit - to be used with front pistol handle Color Test function Padlockable Red Catalog no. H4X-04B H4X-04R N Y Defeatable N Catalog no. H79-1 Auxiliary contacts Accessories AND... 11-56 Auxiliary contacts Contact No. of Continuous type contacts amp rating NO 1 10 NC 1 2 Voltage (Vac) 600 Auxiliary contact holder BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Maximum number of auxiliary contacts per disconnect switch catalog number Catalog no. RDF30CC-_: 4 / 8 with BAC-HOLDER2 BAC05 (1) BAC05 (1) RDF30J-_-COMP: 2 /6 with BACBAC06 (1) HOLDER2 Accepts 4 Auxiliary contacts: BAC05 or BAC06 BAC-HOLDER2 (2) Eaton.com/bussmannseries Disconnect switches — 11 Dimensions — in (mm) RDF30CC-_ 3.78 96 1.47 37.5 1.12 28.5 0.59 15 Disconnect switches 3.3 84 4.56 116 1 25.5 3.28 83.3 5.19 (131.8) Fuse Cover Fully Open RDF30J-_-COMP 4.13 105 0.59 15 1.47 37.5 1 25.5 1.12 28.5 3.3 84 4.56 116 3.89 99 External front selector handle Direction of front operation Door drilling layout 1.57 40 I 9 H4X-04_ 0.11 3 4 Ø 0.27 4Ø7 0 1.10 28 3.46 88 Ø3.07 Ø78 0° 1.45 37 Ø 1.22 Ø 31 0.53 13.5 Selector handle type With 4 Mounting Screws Ø 0.88 Ø 22.5 With mounting nut External front pistol handles Pistol handle type Direction of front operation Door drilling layout I 1.73 44 0.78 20 0 TEST BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 0.78 20 H4X-05__ H12-05__ Ø 1.46 Ø 37 4 Ø 0.27 4Ø7 65° 2.75 70 90 ° Ø3.07 Ø78 0.55 14 0.55 14 Eaton.com/bussmannseries 11-57 11 — Disconnect switches Standard 30 amp Class J For a complete assembly, select: Switch SCCR (kA) Poles 2 30 J 3 200 4 * DC ratings use two poles in series. Switch Amps Fuse class Max horsepower rating 1-phase 3-phase 220/240 220/240 440/480 600 3 7.5 15 20 7.5 15 20 PLUS Direct mount handle - mounts directly to switch, no shaft required For switch cat. no. Color Test function Or + Handle Select for standard applications All switches 2 1 3 4 Black Y DC* 125 250 3 5 3 5 3 5 Conductors AWG size / type 14-10 Sol/14-6 Str 75°C Cu Padlockable Catalog no. Y - On switch DIR-07 OR External front operated pistol handles - shaft required NEMA type Color Test function Padlockable Defeatable Black 1, 3R, 12 Red/yellow N Black Y Y Red/yellow 1, 3R, 4, 4X, 12 Black Y Red/yellow Metallic hasp (heavy duty) external front operated pistol handles - shaft required NEMA Color Color Test function Padlockable Defeatable type Black 1, 3R, 4, 4X, 12 N Y Y Red/yellow External right side operated pistol handles - shaft required NEMA type Color Test function Padlockable Defeatable Black 1, 3R, 4, 4X, 12 N Y N/A Red/yellow Shafts for pistol handles Length — in (mm) Mounting depth (X) — in (mm) 7.9 (200) 5.30~9.06 (135~230) 12.6 (320) 5.30~13.78 (135~350) 15.7 (400) 5.30~16.93 (135~430) OR Flange handle (1) - requires shaft operated mechanism or cable operated mechanism + cable NEMA type Flange style Test function Padlockable Defeatable 1, 3R, 4, 12 Standard N Y Y 1, 3R, 4, 4X, 12 Chrome plated Shaft operated flange mechanism (2) - includes shaft For enclosure depth - in (mm) 6~24 (152~613) Cable operated flange mechanism and cable - must select mechanism (3) and cable (4) Item / length — in (mm) Cable mechanism 36 (900) cable 60 (1500) cable 120 (3000) cable OR NFPA through the door handle kit - to be used with front pistol handle Color Test function Padlockable Defeatable Red N Catalog no. RDF30J-2 RDF30J-3 RDF30J-4 Y N Catalog no. H12-05B H12-05R H4X-05B H4X-05R H4X-05TB H4X-05TR Catalog no. H4X-05BHD H4X-05RHD Catalog no. H4X-05SB H4X-05SR Catalog no. SH5-200 SH5-320 SH5-400 Catalog no. FLH1 FLH2 Catalog no. FLRM Catalog no. FLCM FLC36 FLC60 FLC120 Catalog no. H79-2 Aux. contacts Accessories AND... 11-58 Auxiliary contacts Contact No. of contacts type Continuous amp rating Voltage (Vac) Max. aux contacts per switch 10 600 4 NO Catalog no. BAC05 1 NC BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 BAC06 Eaton.com/bussmannseries Disconnect switches — 11 Dimensions — in (mm) 5.87 149.3 1.41 36 1.46 37.2 4.84 123 Disconnect switches 4.02 102.1 5.35 136 2.68 68.07 1.41 36 Direct mount handle 1.79 45.5 5.31 135 1.57 40 DIR-07 Flange handle 3.50 (88.9) Ø0.28 (Ø7.1) Ø0.50 1.55 (39.4) (Ø12.7) 2.16 (54.9) 1.06 (26.9) 0.86 (21.8) 5.66 (143.8) 6.22 (158.0) 4.68 (118.9) 1.00 (25.4) 1.00 0.88 (25.4) (22.3) 7.10 (180.3) 2.32 (58.9) 2.70 (68.6) FLH_ External front and right side pistol handle Direction of front operation Direction of right side operation Door drilling layout I I 90 0 TEST BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 0.78 20 1.73 44 0 Ø 1.46 Ø 37 4 Ø 0.27 4Ø7 65° 2.75 70 H4X-05__ H12-05__ ° 90 ° Ø3.07 Ø78 0.78 20 Handle type 0.55 14 0.55 14 Eaton.com/bussmannseries 11-59 11 — Disconnect switches Compact 60 amp Class J For a complete assembly, select: Switch SCCR (kA) Poles 2 60 J 3 100 4 * DC ratings use two poles in series. Switch Amps Fuse class Max horsepower 3-phase 220/240 440/480 15 30 15 30 1-phase 220/240 10 - rating 600 50 50 PLUS Direct mount handle - mounts directly to switch, no shaft required For switch cat. no. Color Test function Or + Handle Select for standard applications All switches 2 1 3 4 Black Y 125 5 5 5 DC* 250 10 10 10 Conductor AWG size / type 14-10 Sol/14-6 Str 75°C Cu Padlockable Catalog no. Y - on switch DIR-07 OR External front operated pistol handles - shaft required NEMA type Color Test function Padlockable Defeatable 1, 3R, 12 Black 1, 3R, 12 Red/yellow N 1, 3R, 4, 4X, 12 Black Y Y 1, 3R, 4, 4X, 12 Red/yellow 1, 3R, 4, 4X, 12 Black Y 1, 3R, 4, 4X, 12 Red/yellow Metallic hasp (heavy duty) external front operated pistol handles - shaft required NEMA type Color Test function Padlockable Defeatable 1, 3R, 4, 4X, 12 Black N Y Y 1, 3R, 4, 4X, 12 Red/yellow External right side operated pistol handles - shaft required NEMA type Color Test function Padlockable Defeatable 1, 3R, 4, 4X, 12 Black N Y N/A 1, 3R, 4, 4X, 12 Red/yellow Shafts for pistol handles Length — in (mm) Mounting depth (X) - in (mm) 7.9 (200) 5.30~9.06 (135~230) 12.6 (320) 5.30~13.78 (135~350) 15.7 (400) 5.30~16.93 (135~430) OR Flange handle (1) - requires shaft operated mechanism or cable operated mechanism + cable NEMA type Flange style Test function Padlockable Defeatable 1, 3R, 4, 12 Standard N Y Y 1, 3R, 4, 4X, 12 Chrome plated Shaft operated flange mechanism (2) - includes shaft For enclosure depth - in (mm) 6~24 (152~613) Cable operated flange mechanism and cable - must select mechanism (3) and cable (4) Item / length — in (mm) Cable mechanism 36 (900) cable 60 (1500) cable 120 (3000) cable OR NFPA through the door handle kit - to be used with selector handle or front pistol handle Color Test function Padlockable Defeatable Red N Catalog no. RDF60J-2-COMP RDF60J-3-COMP RDF60J-4-COMP Y N Catalog no. H12-05B H12-05R H4X-05B H4X-05R H4X-05TB H4X-05TR Catalog no. H4X-05BHD H4X-05RHD Catalog no. H4X-05SB H4X-05SR Catalog no. SH5-200 SH5-320 SH5-400 Catalog no. FLH1 FLH2 Catalog no. FLRM Catalog no. FLCM FLC36 FLC60 FLC120 Catalog no. H79-2 AND... Aux. contacts Accessories Auxiliary contacts 11-60 Contact type No. of contacts Continuous amp rating Voltage (Vac) Max. aux contacts per switch 1 10 600 4 NO Catalog no. BAC05 NC BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 BAC06 Eaton.com/bussmannseries Disconnect switches — 11 Dimensions — in (mm) 3.89 99 4.13 105 1.47 37.5 0.59 15 3.3 84 Disconnect switches 4.56 116 1 25.5 1.12 28.5 Direct mount handle 1.79 45.5 5.31 135 1.57 40 DIR-07 Flange handle 3.50 (88.9) Ø0.28 (Ø7.1) Ø0.50 1.55 (39.4) (Ø12.7) 2.16 (54.9) 1.06 (26.9) 0.86 (21.8) 5.66 (143.8) 6.22 (158.0) 4.68 (118.9) 1.00 (25.4) 1.00 0.88 (25.4) (22.3) 7.10 (180.3) 2.32 (58.9) 2.70 (68.6) FLH_ External front and right side pistol handle Direction of front operation Direction of right side operation Door drilling layout I I 0.78 20 90 1.73 44 0 Ø 1.46 Ø 37 4 Ø 0.27 4Ø7 0 65° 2.75 70 H4X-05__ H12-05__ ° 90 ° Ø3.07 Ø78 TEST BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 0.78 20 Handle type 0.55 14 0.55 14 Eaton.com/bussmannseries 11-61 11 — Disconnect switches Standard 60 amp Class J For a complete assembly, select: Switch Max horsepower 3-phase 220/240 440/480 15 30 15 30 1-phase SCCR Amps Poles (kA) 220/240 2 200 10 60 J 3 200 4 200 * DC ratings use two poles in series. Switch Fuse class rating 600 50 50 PLUS Direct mount handle - mounts directly to switch, no shaft required For switch cat. no. Color Test function Or Black Y Conductor AWG size/type Catalog no. RDF60J-2 12-10 Sol/12-1 Str RDF60J-3 75°C Cu RDF60J-4 Padlockable Catalog no. Y OR External front operated pistol handles - shaft required NEMA type Color Test function Padlockable 1, 3R, 12 Black 1, 3R, 12 Red/yellow N 1, 3R, 4, 4X, 12 Black Y 1, 3R, 4, 4X, 12 Red/yellow 1, 3R, 4, 4X, 12 Black Y 1, 3R, 4, 4X, 12 Red/yellow Metallic hasp (heavy duty) external front operated pistol handles - shaft required NEMA type Color Test function Padlockable 1, 3R, 4, 4X, 12 Black N Y 1, 3R, 4, 4X, 12 Red/yellow DIR-07 Defeatable Y Defeatable Y Catalog no. H12-03B H12-03R H4X-06B H4X-06R H4X-06TB H4X-06TR Catalog no. H4X-06BHD H4X-06RHD External right side operated pistol handles - shaft required Handle Select for standard applications All switches DC* 125 250 5 10 5 10 5 10 + 2 1 3 4 NEMA type Color 1, 3R, 4, 4X, 12 Black 1, 3R, 4, 4X, 12 Red/yellow Shafts for pistol handles Length — in (mm) Mounting depth (X) — in (mm) 7.9 (200) 5.30~9.06 (135~230) 12.6 (320) 5.30~13.78 (135~350) 15.7 (400) 5.30~16.93 (135~430) Test function Padlockable Defeatable N Y N/A Catalog no. SH5-200 SH5-320 SH5-400 OR Flange handle (1) - requires shaft operated mechanism or cable operated mechanism + cable NEMA type Flange style Test Function Padlockable Defeatable 1, 3R, 4, 12 Standard N Y Y 1, 3R, 4, 4X, 12 Chrome plated Shaft operated flange mechanism (2) - includes shaft For enclosure depth — in (mm) 6~24 (152~613) Cable operated flange mechanism and cable - must select mechanism (3) and cable (4) Item / length — in (mm) Cable mechanism 36 (900) cable 60 (1500) cable 120 (3000) cable OR NFPA through the door handle kit - to be used with front pistol handle Color Test function Padlockable Defeatable Red Catalog no. H4X-06SB H4X-06SR N Y N Catalog no. FLH1 FLH2 Catalog no. FLRM Catalog no. FLCM FLC36 FLC60 FLC120 Catalog no. H79-2 Accessories Aux. contacts AND... 11-62 Auxiliary contacts Contact type NO NC No. of contacts Continuous amp rating Voltage (Vac) 1 10 600 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Max number of aux contacts per Catalog no. switch BAC05 4 BAC06 Eaton.com/bussmannseries Disconnect switches — 11 Dimensions — in (mm) 4.81 122.2 1.41 36 1.46 37.2 Disconnect switches 5.23 133 6.77 172 7.32 186 3.66 92.96 5.87 149.3 1.41 36 Direct mount handle 1.79 45.5 5.31 135 1.57 40 DIR-07 Flange handle 3.50 (88.9) Ø0.28 (Ø7.1) Ø0.50 1.55 (39.4) (Ø12.7) 2.16 (54.9) 1.06 (26.9) 0.86 (21.8) 5.66 (143.8) 6.22 (158.0) 4.68 (118.9) 1.00 (25.4) 1.00 0.88 (25.4) (22.3) 7.10 (180.3) 2.32 (58.9) 2.70 (68.6) FLH_ External front and right side pistol handle Handle type Direction of front operation Direction of right side operation I I Ø3.07 Ø78 ° 0 Ø 1.46 Ø 37 4 Ø 0.27 4Ø7 0.78 20 90 ° 90 0 1.77 45 TEST BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 0.78 20 65° 4.92 125 H4X-06__ H12-03__ Door drilling layout 0.55 14 0.55 14 Eaton.com/bussmannseries 11-63 11 — Disconnect switches Standard 100 amp Class J For a complete assembly, select: Switch 1-phase Amps Poles 220/240 2 10 100 J 3 200 4 * DC ratings use two poles in series. Switch Fuse class SCCR (kA) Max horsepower 3-phase 220/240 440/480 30 60 30 60 rating 600 75 75 PLUS Direct mount handle - mounts directly to switch, no shaft required For switch cat. Color Test function no. Or + Handles Select for standard applications All switches 2 1 3 4 Black Y DC* 125 250 7.5 20 7.5 20 7.5 20 Conductor AWG size/type 12-10 Sol/12-1 Str 75°C Cu Padlockable Catalog no. Y DIR-07 OR External front operated pistol handles - shaft required NEMA type Color Test function Padlockable Defeatable Black 1, 3R, 12 Red/yellow N Black Y Y Red/yellow 1, 3R, 4, 4X, 12 Black Y Red/yellow Metallic hasp (heavy duty) external front operated pistol handles - shaft required NEMA type Color Test function Padlockable Defeatable 1, 3R, 4, 4X, 12 Black N Y Y 1, 3R, 4, 4X, 12 Red/yellow External right side operated pistol handles - shaft required NEMA type Color Test function Padlockable Defeatable Black 1, 3R, 4, 4X, 12 N Y N/A Red/yellow Shafts for pistol handles Length — in Mounting depth (X) - in (mm) (mm) 7.9 (200) 5.30~9.06 (135~230) 12.6 (320) 5.30~13.78 (135~350) 15.7 (400) 5.30~16.93 (135~430) OR Flange handle (1) - requires shaft operated mechanism or cable operated mechanism + cable NEMA type Flange style Test function Padlockable Defeatable 1, 3R, 4, 12 Standard N Y Y 1, 3R, 4, 4X, 12 Chrome plated Shaft operated flange mechanism (2) - includes shaft For enclosure depth — in (mm) 6~24 (152~613) Cable operated flange mechanism and cable - must select mechanism (3) and cable (4) Item / length — in (mm) Cable mechanism 36 (900) cable 60 (1500) cable 120 (3000) cable OR NFPA through the door handle kit - to be used with front pistol handle Color Test function Padlockable Defeatable Red N Catalog no. RDF100J-2 RDF100J-3 RDF100J-4 Y N Catalog no. H12-03B H12-03R H4X-06B H4X-06R H4X-06TB H4X-06TR Catalog no. H4X-06BHD H4X-06RHD Catalog no. H4X-06SB H4X-06SR Catalog no. SH5-200 SH5-320 SH5-400 Catalog no. FLH1 FLH2 Catalog no. FLRM Catalog no. FLCM FLC36 FLC60 FLC120 Catalog no. H79-2 Aux. contacts Accessories AND... 11-64 Auxiliary contacts Contact type No. of contacts Continuous amp rating Voltage (Vac) Max number of aux contacts per switch NO NC Catalog no. BAC05 1 10 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 600 4 Eaton.com/bussmannseries BAC06 Disconnect switches — 11 Dimensions — in (mm) 4.81 122.2 1.41 36 1.46 37.2 Disconnect switches 5.23 133 6.77 172 7.32 186 3.66 92.96 5.87 149.3 1.41 36 Direct mount handle 1.79 45.5 5.31 135 1.57 40 DIR-07 Flange handle 3.50 (88.9) Ø0.28 (Ø7.1) Ø0.50 1.55 (39.4) (Ø12.7) 2.16 (54.9) 1.06 (26.9) 0.86 (21.8) 5.66 (143.8) 6.22 (158.0) 4.68 (118.9) 1.00 (25.4) 1.00 0.88 (25.4) (22.3) 7.10 (180.3) 2.32 (58.9) 2.70 (68.6) FLH_ External front and right side pistol handle Handle type Direction of front operation Direction of right side operation I I Ø3.07 Ø78 ° 0 Ø 1.46 Ø 37 4 Ø 0.27 4Ø7 0.78 20 90 ° 90 0 1.77 45 TEST BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 0.78 20 65° 4.92 125 H4X-06__ H12-03__ Door drilling layout 0.55 14 0.55 14 Eaton.com/bussmannseries 11-65 11 — Disconnect switches Standard 200 and 400 amp Class J For a complete assembly, select: Switch Switch + lugs Amps Select for standard applications + Handles Or + 2 3 4 11-66 SCCR (kA) Poles 2 200 3 4 J 200 2 400 3 4 * DC ratings use two poles in series. Terminal lug kit Switch amps Poles 2 200 3 4 2 400 3 4 Max horsepower rating 3-phase 220/240 440/480 600 60 125 150 60 125 150 125 250 350 125 250 350 1-phase 220/240 10 10 - 125 20 20 20 DC* 250 50 50 50 Catalog no. RDF200J-2 RDF200J-3 RDF200J-4 RDF400J-2 RDF400J-3 RDF400J-4 Lugs per kit AWG wire / type 2 6-300 kcmil 3 75°C Cu/Al 4 2 4-600 kcmil or dual 1/0-250 kcmil 3 75°C Cu/Al 4 PLUS Direct mount handle - mounts directly to switch, no shaft required For switch cat. no. Color Test function Padlockable Catalog no. All switches DIR-07 Black Y Y OR External front operated pistol handles - shaft required NEMA type Color Test function Padlockable Defeatable Black 1, 3R, 12 Red/yellow N Black Y Y Red/yellow 1, 3R, 4, 4X, 12 Black Y Red/yellow Metallic hasp (heavy duty) external front operated pistol handles - shaft required NEMA type Color Test function Padlockable Defeatable Black 1, 3R, 4, 4X, 12 N Y Y Red/yellow External right side operated pistol handles - shaft required NEMA type Color Test function Padlockable Defeatable Black 1, 3R, 4, 4X, 12 N Y N/A Red/yellow Shafts for pistol handles Length — in (mm) Mounting depth (X) — in (mm) 200 A: 5.70-9.06 (145-230) 7.9 (200) 400 A: 7.87-10.24 (200-260) 200 A: 5.70-13.78 (145-350) 12.6 (320) 400 A: 7.87-16.93 (200-380) 15.7 (400) 1 Fuse class 200 A: 5.70-16.93 (145-430) 400 A: 7.87-18.10 (200-460) Catalog no. LUG1-2 LUG1-3 LUG1-4 LUG2-2 LUG2-3 LUG2-4 Catalog no. H12-03B H12-03R H4X-06B H4X-06R H4X-06TB H4X-06TR Catalog no. H4X-06BHD H4X-06RHD Catalog no. H4X-06SB H4X-06SR Catalog no. SH5-200 SH5-320 SH5-400 OR Flange handle (1) 200 A only - requires shaft operated mechanism or cable operated mechanism + cable NEMA type Flange style Test function Padlockable Defeatable Catalog no. 1, 3R, 4, 12 Standard FLH1 N Y Y 1, 3R, 4, 4X, 12 Chrome plated FLH2 Shaft operated flange mechanism (2) 200 A only - includes shaft For enclosure depth — in (mm) Catalog no. 6~24 (152~613) FLRM Cable operated flange mechanism and cable 200 A only - must select Mechanism (3) and Cable (4) Item — in (mm) Catalog no. Cable mechanism FLCM 36 (900) cable FLC36 60 (1500) cable FLC60 120 (3000) cable FLC120 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 OR NFPA through the door handle kit - to be used with front pistol handle Use with switch Color Test function Padlockable Defeatable RDF200J-_ Catalog no. H79-2 Red RDF400J-_ N Y N H79-3 AND... Contact type No. of contacts Continuous amp rating Voltage (Vac) 1 10 600 NO NC Max number of aux contacts per Catalog no. switch catalog number RDF200J-__: 4 BAC05 RDF400J-__: 8 BAC06 Shrouds Accessories AND... Terminal shrouds - includes terminal shroud for lineside or loadside Switch amps Poles 2 3 200 4 Catalog no. TSH8-2TB TSH8-3TB TSH8-4TB 2 3 TSH9-2TB TSH9-3TB 4 TSH9-4TB 400 Dimensions — in (mm) RDF200J-3 RDF400J-3 7.72 196.2 7.08 180 6.61 168 4.37 111.1 10.19 (3P) - 12.79 (4P) 259 (3P) - 325 (4P) 9.44 240 15.35 390 7.97 202.5 3.98 101.25 11.46 291.3 7.67 195 6.50 165.2 5.28 134.2 3.98 101.25 2.95 75 6.18 157 0.98 24.9 5.11 130 2.95 75 1.41 36 1.96 50 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 3.26 83 2.59 66 2.59 66 Eaton.com/bussmannseries 11-67 Disconnect switches Aux. contacts Auxiliary contacts 11 — Disconnect switches Dimensions — in (mm) DIR-07 direct mount handle 1.57 40 FLH_ flange handle 3.50 (88.9) 1.79 45.5 1.06 (26.9) 0.86 (21.8) 5.31 135 Ø0.28 (Ø7.1) Ø0.50 1.55 (39.4) (Ø12.7) 2.16 (54.9) 5.66 (143.8) 6.22 (158.0) 4.68 (118.9) 1.00 (25.4) 1.00 0.88 (25.4) (22.3) 2.32 (58.9) 7.10 (180.3) 2.70 (68.6) External front and right side pistol handle Handle type Direction of front operation Direction of right side operation I I Ø3.07 Ø78 Door drilling layout ° 0 0.78 20 0 H4X-06__ H12-03__ 1.77 45 0.78 20 65° 4.92 125 Ø 1.46 Ø 37 4 Ø 0.27 4Ø7 90 ° 90 TEST 0.55 14 0.55 14 Terminal lugs BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 0.63 15.88 0.44 11.13 2.8 71.5 0.46 11.68 0.25 6.35 1.12 28.6 Ø 0.4 Ø 4.7 1.3 35 0.45 Ø11.6 1.52 38.8 11-68 400 A (LUG2-__) 1.8 46 1 25 200 A (LUG1-__) Eaton.com/bussmannseries Disconnect switches — 11 Standard 600 amp Class J and 800 amp Class L For a complete assembly, select: Amps Fuse class 600 J 800 + L Terminal lug kit Switch amps 600-800 Poles 2 3 4 2 3 4 SCCR ()kA) Poles Lugs per kit 2 2 3 3 4 4 200 Max horsepower rating, 3-phase 220/240 440/480 600 200 400 500 200 400 500 200 500 500 200 500 500 Conductor AWG size / type Catalog no. RDF600J-2 RDF600J-3 RDF600J-4 RDF800L-2 RDF800L-3 RDF800L-4 Catalog no. LUG5-2 (2) 2-600 kcmil 75°C Cu/ Al LUG5-3 LUG5-4 PLUS Select for standard application Direct mount handle - mounts directly to switch, no shaft required Handles Or For switch cat. no. Color Test function Padlockable Defeatable All switches Black Y Y N OR External front operated pistol handles - shaft required Test NEMA type Color Padlockable Defeatable function Black 1, 3R, 4, 4X, 12 N Y Y Red/yellow Metallic hasp (heavy duty) external front operated pistol handles - shaft required NEMA Test Color Padlockable Defeatable type function Black DIR-08 Catalog no. H4X-07B H4X-07R Catalog no. H4X-07BHD 1, 3R, 4, 4X, 12 N Y Y Red/yellow + Catalog no. H4X-07RHD Shafts for pistol handles Length — in (mm) Mounting depth (X) — in (mm) Catalog no. 7.9 (200) SH7-200 10.63~11.97 (270~304) 12.6 (320) 10.63~16.69 (270~424) SH7-320 15.7 (400) 10.63~19.84 (270~504) SH7-400 OR NFPA through the door handle kit - to be used with front pistol handle Test funcFor switch cat. no. Color Padlockable Defeatable tion All switches Red N Y N Catalog no. H79-4 Contact type NO NC No. of contacts Continuous amp rating Voltage (Vac) Max number of aux contacts per switch 1 10 600 8 AND... Terminal shrouds - includes terminal shroud for lineside or loadside Switch amps Poles Shrouds Accessories Aux. contacts AND... Auxiliary contacts 600-800 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Catalog no. BAC05 BAC06 Catalog no. 2 TSH10-2TB 3 TSH10-3TB 4 TSH10-4TB Eaton.com/bussmannseries 11-69 Disconnect switches Switch + lugs Switch 11 — Disconnect switches Dimensions — in (mm) RDF600J-3 and RDF800L-3 min 10.43 min 265 9.84 250 11.18 (3P) - 14.88 (4P) 284 (3P) - 378 (4P) 1.34 2.56 65 34 6.10 155 3.36 85.5 3.12 79.5 14.96 380 Fuse Cover Fully Open 18.58 472 18.54 471 fix 9.84 fix 250 5 126.5 10.23 260 3.36 85.5 0.27 7 11.81 300 0.27 7 3.54 90 11.81 300 0.27 7 0.43 11 2.32 59 0.35 9 Ø 0.51 Ø13 2 51 3.7 3.7 94 94 14.33 (3P) - 18.03 (4P) 364 (3P) - 458 (4P) Dir-08 drect mount handle 7.48 190 2.36 60 3.35 85 External front pistol handle Direction of front operation Handle type Ø3.07 Ø78 Door drilling layout Ø 1.46 Ø 37 0.78 20 4 Ø 0.27 4Ø7 0.78 20 0 210 90 ° I H4X-07__ 0.55 14 61 0.55 14 Terminal lugs 600 to 800 A (LUG5-__) 1.49 38 3.76 95.5 0.40 Ø10.2 11-70 0.64 16.2 2.87 73 3.15 80 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 UL 98 non-fused rotary disconnect switches — 30 to 1200 amps Bussmann series UL 98 non-fused rotary disconnect switches are versatile switches that “break” and “make” power circuits ON and OFF load. • UL 98, Guide WHTY, File E155130 • CSA 22.2 No. 4, File 257020 • Conforms with IEC 60947-3 Disconnect switches Agency information Features Related Bussmann series products • Make and break power under load • Up to 200 kA SCCR • Panel mount (30-100 A compact DIN-Rail or panel mount) • Disconnect switches are front, right side and direct handle operable (30-100 A) • Finger-safe (30-100 A compact only) • Fully visualized breaking (100-1200 A) Fuse blocks Modular Class H(K), J and RK fuse blocks up to 600 A Modular Class H(K), J and RK power distribution fuse blocks up to 400 A Modular, finger-safe CH Class CC and J, and UL supplemental and IEC 10x38mm DIN-Rail holders up to 60 A Finger-safe Optima Class CC, UL supplemental and IEC 10x38mm DINRail/panel mount holders up to 30 A Finger-safe Optima™ Class CC, UL supplemental and IEC 10x38mm DIN-Rail/panel mount protection modules up to 30 A Online resources Visit Eaton.com/bussmannseries for: • CAD drawings • Instruction sheets • UL information IEC specifications RD30-3 3-pole 4-pole Thermal current Ith @ 40°C (A) Rated insulation voltage Ui (V) Rated impulse withstand voltage Uimp (kV) Rated operation currents Ie (A) Load duty Rated voltage (Vac) category AC-22 A 400 AC-23 A AC-22 A 690 AC-23 A Operational power (Vac) in AC-23 (kW) 400 V w/o prebreak AC 1, 2 500 V w/o prebreak AC 1, 2 690 V w/o prebreak AC 1, 2 Overload capacity (Ue 415 Vac) Rated short-circuit making capacity Icm (kA peak) 3 Fuse protected short-circuit withstand (kA RMS prospective) Short-circuit current (kA) 3 Associated fuse rating (A) 3 Connection Minimum Cu cable cross section (mm2) Minimum Cu busbar section (mm2) Maximum Cu cable section (mm2) RD200-3 RD600-3 Catalog no. RD30-3 RD60-3 RD100-3 RD100-3-SCCR RD200-3 RD400-3 — — — — RD200-4 RD400-4 30 60 100 100 200 400 800 800 800 1000 1000 1000 8 8 8 8 8 8 A 1 A 1 A 1 A 1 A 1 100 32 15 63 30 80 63 45 18.5 100 200 A 1 RD600-3 RD600-4 — 1000 12 A 1 RD800-3 RD800-4 — 1000 12 A RD1000-3 RD1000-4 — 1000 12 A 1 1 RD1200-3 RD1200-4 — 1000 12 A 1 630 800 1000 315 500 200 630 400 630 400 1200 1000 630 400 400 51 63 90 100 140 185 220 280 185 355 450 185 450 560 400 560 560 400 400 12 12 12 17.6 32 48 48 75 48 75 50 32 50 63 25 100 200 100 200 200 400 100 630 100 800 100 1000 100 1250 2.5 — 70 2.5 — 70 10 — 70 35 — 300 70 — 300 185 — 600 2x150 2x30x5 — 2x185 2x40x5 — 2x240 2x50x5 — — 2x60x5 — 1 A/B: Category with index A = frequent operation; category with index B = infrequent operation. 2 The power value is given for information only; the current values vary from one manufacturer to another. 3 For a rated operating voltage, Ue = 400 Vac. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-71 11 — Disconnect switches UL specifications RD30-3 RD200-3 RD600-3 Catalog no. 3-pole 4-pole UL standard Max ampacity Switch type Handle operation UL electrical ratings Max voltage (AC) Max voltage (DC) 1-phase, 120 1-phase, 240 Max. AC Hp 3-phase, 240 ratings 3-phase, 480 3-phase, 600 125 DC Hp ratings 250 Electrical characteristics SCCR with fuse (kA) Fuse class Max. fuse rating (A) Terminal lugs/kits Lug mounting torque - lb-in (N•m) Wire type Solid Wire range and torque lb-in (N•m) Stranded RD30-3 — UL 98 30 A Compact Front/Side RD60-3 — UL 98 60 A Compact Front/Side RD100-3 — UL 98 100 A Compact Front/Side RD100-3SCCR — UL 98 100 A Standard Front 600 Vac — 2 5 10 20 25 — — 600 Vac — 3 10 20 40 50 — — 600 Vac — 5 10 20 50 50 — — 600 Vac 250 Vdc — 10 30 75 100 — — 600 Vac 250 Vdc — 10 75 150 200 — — 600 Vac — — — 125 250 350 — — 600 Vac 250 Vdc — — 200 400 350 20 50 600 Vac — — — 200 500 500 — — 600 Vac — — — 200 500 500 — — 600 Vac — — — 200 500 500 — — 100 J 30 Integral 100 J 60 Integral 25 /100* J 100 Integral 200 J 10A • 200 J 200 • 200 J 600 • 100 L 800 • 100 L 1000 • 100 L 1200 • — — — 160 (18) 160 (18) 200 J 400 • LUG2-_ 310 (35) LUG3-_ 398 (45) 310 (35) 310 (35) 310 (35) 310 (35) 75°C Cu 75°C Cu 75°C Cu 75°C Cu/ Al 75°C Cu/ Al 75°C Cu/ Al 75°C Cu/ Al 75°C Cu/ Al 12-10, 35.4 (4) 12-10, 35.4 (4) 12-10, 35.4 (4) — — — — — — — LUG2-_ 4-600 kcmil, 550 (62) (2) 2-600 kcmil, 375 (42.4) (4) 2-600 kcmil, 375 (42.4) (4) 2-600 kcmil, 375 (42.4) (4) 2-600 kcmil, 375 (42.4) 6000 3500 3500 3500 18.1 (8.2) 23.9 (10.9) 19.6 (8.9) 25.3 (11.5) 19.6 (8.9) 25.3 (11.5) 19.6 (8.9) 25.3 (11.5) 10-1, 35.4 (4) 10-1, 35.4 (4) 10-1, 35.4 (4) 1/0, 39.8 (4.5) 1/0, 39.8 (4.5) 1/0, 39.8 (4.5) 2/0, 44.3 (5) 2/0, 44.3 (5) 2/0, 44.3 (5) Mechanical characteristics Endurances/Cycles Physical characteristics Dimensions 3-pole Weight - lbs (kg) 4-pole Environmental Operating Temperature Flammability Rating Accessories 3-pole Lug kit cat. no. 4-pole NEMA 1, 3R, 12 NEMA 1, 3R, 4, 4X, 12 Handles Direct Front Pistol Front or Side Selector Shaft c/s - mm Shaft guide Shrouds Additional pole accessory NO + NC Auxiliary contacts (2) NO 10,000 10,000 10,000 1.3 (0.6) — 1.3 (0.6) — 1.3 (0.6) — -20 to 70°C -20 to 70°C UL 94-V0 UL 94-V0 -20 to 70°C UL 94-V0 Integral — Integral — • • 6-300 kcmil, 275 (31) RD200-3 RD200-4 UL 98 200 A Standard Front RD400-3 RD400-4 UL 98 400 A Standard Front RD600-3 RD600-4 UL 98 600 A Standard Front RD800-3 RD800-4 UL 98 800 A Standard Front RD1000-3 RD1000-4 UL 98 1000 A Standard Front RD1200-3 RD1200-4 UL 98 1200 A Standard Front 6-300 kcmil, 275 (31) 75°C Cu/ Al 75°C Cu/ Al Dual 1/0-250 kcmil, 550 (62) LUG3-_: (2) 6-2, 200 (22.6) (2) 1-350 kcmil, 375 (42.4) 10,000 8000 6000 See drawings on product pages 4.2 (1.91) 4.2 (1.91) 10.0 (4.6) — 5.0 (2.3) 12.3 (5.6) -20 to 70°C -20 to 70°C -20 to 70°C UL 94-V0 UL 94-V0 UL 94-V0 -20 to 70°C -20 to 70°C -20 to 70°C -20 to 70°C UL 94-V0 UL 94-V0 UL 94-V0 UL 94-V0 Integral — • — • • • • • • • • • • • • • • • • — — — — • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • — — — — — — — 5x5 • • • • • 5x5 • • • • • 5x5 • • • • • 10x10 • • — • — 10x10 • • — • — 10x10 • • — • — 12x12 • • — • — 12x12 • • — • — 12x12 •• • — • — 12x12 • • — • — • Available, see product page for details and catalog numbers. — Not available. * 25 kA @ 600 Vac, 100 kA @ 480 Vac. 11-72 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 UL 98 non-fused rotary disconnect switches — 30, 60 and compact 100 A For a complete assembly, select: Switch 2 Or Handles Select for standard application 1 + 1 2 + Conductor 600 AWG size/type 25 10-2/0 Str/12-10 Sol 50 75°C Cu 50 PLUS Direct mount handle - mounts directly to switch, no shaft required For switch cat. no. Color Test function Padlockable All switches Black N Y - On Switch OR External front or right side operated selector handles - shaft required Handle NEMA type Color Test function Padlockable length Black Short Red/yellow Short 1, 3R, 4, 4X, 12 N Y Black Long Red/yellow Long External front operated pistol handles - shaft required Handle NEMA type Color Test function Padlockable Defeatable length Black — 1, 3R, 4, 4X, 12 N Y Y Red/yellow — Metallic hasp (heavy duty) external front operated pistol handles - shaft required Handle NEMA type Color Test function Padlockable Defeatable length Black — 1, 3R, 4, 4X, 12 N Y Y Red/yellow — Shafts for selector handles Length — in (mm) Mounting depth (X) — in (mm) 5.9 (150) 3.50~7.60 (89~193) 7.9 (200) 3.50~9.50 (89~241) 12.6 (320) 3.50~14.9 (89~378) Shafts for pistol handles Length — in (mm) Mounting depth (X) - in (mm) 7.9 (200) 3.30~7.40 (84~188) 12.6 (320) 3.30~9.30 (84~236) 15.7 (400) 3.30~14.7 (84~373) Shaft guide for selector handles Aux. contacts Shrouds Accessories NO + NC 1 of each NO 2 Catalog no. H4X-01B (1) H4X-01R (1) H4X-02B (2) H4X-02R (2) Catalog no. H4X-03B H4X-03R Catalog no. H4X-03BHD H4X-03RHD Catalog no. SH4-150 (1) SH4-200 (1) SH4-320 (1) Catalog no. SH3-200 (2) SH3-320 (2) SH3-400 (2) Catalog no. SH-GUIDE2 Voltage (Vac) 240 10 Catalog no. DIR-02 Catalog no. SH-GUIDE1 Required for 12.6" (320mm) long shafts, optional for other lengths Shaft guide for pistol handles Required for 15.7î (400mm) long shafts, optional for other lengths AND... Auxiliary contacts Continuous amp Contact type No. of contacts rating Catalog no. RD30-3 RD60-3 RD100-3 Max number of units per Catalog no. switch 2 (1 per side/4 contacts BAC01 total) 2 (1 per side/4 contacts BAC02 total) AND... Terminal shrouds - includes terminal shroud for both lineside and loadside Switch Poles Location on switch amps 1 (for switched 4th pole) All switchLineside and loadside es 3 AND... Catalog no. TSH3-1TB TSH3-3TB Sw. 4th pole Switched 4th Pole - converts 3-pole switch to 4-pole Switch amps Catalog no. 30 POLE98-30 60 POLE98-60 100 Auxiliary contact configurations POLE98-100 Possible 4 pole configurations th BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-73 Disconnect switches Switch Amps Poles SCCR (kA) 30 100 60 3 100 25/100* * 100 kA @480 Vac, 25 kA @ 600 Vac. Max horsepower rating 1-phase 3-phase 120 220/240 220/240 440/480 2 5 10 20 3 10 20 40 5 10 20 50 11 — Disconnect switches Dimensions - in (mm) Direct handle operation 2 1.42 36 3.07 78 1.02 26 1 1 2 External right side operation 3.94 min./14.65 max. 100 min./372 max. 3.19 81 2.52 64 1.99 50.6 3.07 78 1.02 26 0.51 13 1 1.18 min./7.91 max. 30 min./201 max. 1 2 0.24 6 0.35 1.02 8.8 26 1.02 26 M5 1.02 0.35 26 8.8 2.08 53 5.17 131.4 7.44 189 2.79 71 4.90 124.6 7.44 189 5.17 131.4 4.91 124.6 2 2.09 53 0.34 1.02 8.8 26 0.26 6 1.02 26 M5 1.02 26 0.34 8.8 1. Position for 1 switched 4th pole (1 per device max.) or 1 auxiliary contact. 2. Position for 1 auxiliary contact only. Note: Maximum of 4 Auxiliary contacts, or 3 Auxiliary contacts + one switched 4th pole. External front/right side operated selector handle, front operated pistol handle Handle type Door drilling layouts Ø3.07 Ø78 1.57 40 1.42 36 I 3.46 88 Ø3.07 Ø78 Selector H4X-02_ I ° 90 ° 90 Ø 1.22 Ø 31 0 0.11 3 4 Ø 0.27 4Ø7 Direction of right side operation 0 Ø 0.88 Ø 22.5 With 4 Mounting Screws 1.45 37 0.53 13.5 Direction of front operation 1.10 28 2.79 71 Selector H4X-01_ With mounting nut 1.57 40 1.10 28 4 Ø 0.27 4Ø7 Pistol H4X-03_ H4X-03_ with 4 mounting screws Ø 1.45in/37mm screw clip (from front) Ø 1.22in/31mm screw (from rear) 11-74 1.42 36 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 2.79 71 2.95 75 2.52 64 External front operation Disconnect switches — 11 UL 98 non-fused rotary disconnect switches—100, 200 and compact 400 A For a complete assembly, select: Amps 100 + Select for standard application Switch 200 Handle Or + + Poles 1-phase 220/240 10 10 10 - SCCR (kA) 3 4 3 400 4 Terminal lug kit Switch Poles amps 2 100-200 3 4 2 3 4 400 2 3 4 200 Lugs per kit 2 3 4 2 3 4 2 3 4 Max horsepower rating 3-phase 220/240 440/480 30 75 75 150 75 150 125 250 125 250 600 100 200 200 350 350 Conductor AWG size/type 6-300 kcmil 75°C Cu/ Al 4-600 kcmil or Dual 1/0-250 kcmil 75°C Cu/ Al (2) 6-350 kcmil 75°C Cu/ Al PLUS Direct mount handle - mounts directly to switch, no shaft required Test For switch cat. no. Color Padlockable function All switches Black N Y OR External front operated pistol handles - shaft required Test NEMA type Color Padlockable Defeatable function Black 1, 3R, 12 Red/yellow N Y Y Black 1, 3R, 4, 4X, 12 Red/yellow Metallic hasp (heavy duty) external front operated pistol handles - shaft required Test NEMA type Color Padlockable Defeatable function Black 1, 3R, 4, 4X, 12 N Y Y Red/yellow Shafts for pistol handles Length — in (mm) Mounting depth (X) - in (mm) 7.9 (200) 5.31~10.43 (135~265) 12.6 (320) 5.31~15.16 (135~385) 15.7 (400) 5.31~18.31 (135~465) Shaft Guide Catalog no. RD100-3-SCCR RD200-3 RD200-4 RD400-3 RD400-4 Catalog no. LUG1-2 LUG1-3 LUG1-4 LUG2-2 LUG2-3 LUG2-4 LUG3-2 LUG3-3 LUG3-4 Catalog no. DIR-03 Catalog no. H12-03B H12-03R H4X-06B H4X-06R Catalog no. H4X-06BHD H4X-06RHD Catalog no. SH5-200 SH5-320 SH5-400 Catalog no. Required for 15.7î (400mm) long shafts, optional for other lengths SH-GUIDE2 Accessories Aux. contacts AND... Auxiliary contacts Contact No. of Continuous amp rating type contacts NO + NC 10.1 NO + NC 1 of each NO + NC 1 NO + NC Voltage Vac Max number of aux contacts per switch 125-250 2 125 Catalog no. BAC03* BAC04* BAC11* BAC12* Shrouds * For one auxiliary contact, install either BAC03 or BAC11. For two auxiliary contacts, install BAC03 + BAC04, or BAC11 + BAC12. AND... Terminal shrouds - includes terminal shroud for Lineside or loadside Switch Poles Location on switch amps Lineside 3 100-200 Loadside 4 Lineside or loadside Lineside 3 400 Loadside 4 Lineside or loadside BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Catalog no. TSH4-3T TSH4-3B TSH4-4TB TSH5-3T TSH5-3B TSH5-4TB 11-75 Disconnect switches Switch 11 — Disconnect switches Dimensions — in (mm) M J1 U Z Y 1 W H N AA AC K V CA R1 R2 T AD C F Switch Overall amps dim. C 100 3.72 (95) 200 3.72 (95) 400 4.92 (128) Terminal shrouds AC AD 10.1 3.05 (78) (256) 10.1 3.05 (78) (256) 16 4.15 (115) (406) F 3p. 7.09 (180) 7.09 (180) 9.05 (230) DIR-03 direct mount handle 1.57 40 1.79 45.5 F 4p. 9.06 (230) 9.06 (230) 11.4 (290) Switch body H J1 3p. 4.22 2.17 (107) (55) 4.22 2.17 (107) (55) 6.53 2.95 (166) (75) J1 4p. 4.13 (105) 4.13 (105) 5.31 (135) K 1.8 (46) 1.8 (46) 2.65 (68) M 3p. 6.3 (160) 6.3 (160) 8.26 (210) Switch M 4p. 8.27 (210) 8.27 (210) 10.6 (270) mounting N R1 5.31 0.35 (135) (9) 5.31 0.35 (135) (9) 7.67 0.35 (195) (9) R2 0.27 (7) 0.27 (7) 0.27 (7) T 1.97 (50) 1.97 (50) 2.56 (65) U 0.98 (25) 0.98 (25) 1.77 (45) V 1.18 (30) 1.18 (30) 1.97 (50) Connection W Y 0.43 0.14 (11) (4) 0.43 0.14 (11) (4) 0.43 0.2 (13) (5) Z 1.35 (34) 1.35 (34) 2.08 (53) AA 6.3 (160) 6.3 (160) 10.2 (260) External front handle Handle type Direction of front operation Door drilling layout I 0.78 20 90 H4X-06__ H12-03__ 1.77 45 0.78 20 65° 0 4.92 125 5.31 135 Ø 1.46 Ø 37 4 Ø 0.27 4Ø7 ° Ø3.07 Ø78 TEST 0.55 14 0.55 14 1.52 38.8 2.8 71.5 0.46 11.68 0.88 2.31 73.15 58.67 Ø 0.4 Ø 4.7 0.63 15.88 0.53 13.46 1.94 49.30 0.45 Ø11.6 1.3 35 1 25 Terminal lugs LUG1-_ 100 to 200 A 11-76 LUG2-_ 400 A BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 1.25 31.75 0.44 11.13 1.8 46 1.12 28.6 0.25 6.35 1.19 30.23 0.25 6.35 LUG3-_ 400 A Eaton.com/bussmannseries AC 0.6 (15) 0.6 (15) 0.8 (20) Disconnect switches — 11 UL 98 non-fused rotary disconnect switches — 600, 800, 1000 and 1200 A For a complete assembly, select: Switch 600 800 1000 Switch 220/240 240 240 200 200 200 200 200 200 Poles Lugs per kit Lugs required per pole 3 4 3 4 3 4 6 8 Poles 3 4 3 4 3 4 3 4 1200 200 100 DC* 125 20 20 - 250 50 50 - Catalog no. RD600-3 RD600-4 RD800-3 RD800-4 RD1000-3 RD1000-4 RD1200-3 RD1200-4 Disconnect switches Amps Max horsepower rating 3-phase 440/480 600 400 350 400 350 500 500 500 500 500 500 500 500 500 500 500 500 SCCR (kA) * DC ratings use two poles in series. + Terminal lug kit Switch amps 600 Select for standard application 800-1200 1 2 PLUS Direct mount handle - mounts directly to switch, no shaft required For switch cat. no. Color Test function All switches Handles 1 3 2 Or + + 4 Black Conductor AWG Catalog no. size/type (2) 2-600 kcmil LUG5-3 75°C Cu/ Al LUG5-4 (4) 2-600 kcmil LUG6-6 75°C Cu/ Al LUG6-8 Padlockable N Y OR External front operated pistol handles - shaft required NEMA type Color Test function Padlockable Defeatable Black Red/yellow 1, 3R, 4, 4X, 12 N Y Y Black Red/yellow Metallic hasp (heavy duty) external front operated pistol handles - shaft required NEMA type Color Test function Padlockable Defeatable Black Red/yellow 1, 3R, 4, 4X, 1 N Y Y Black Red/yellow Shafts for pistol handles Length — in (mm) Mounting depth (X) — in (mm) 7.9 (200) 8.70~13.50 (221~343) 12.6 (320) 8.70~18.23 (221~463) 15.7 (400) 8.70~21.38 (221~543) Shaft guide Catalog no. DIR-04 Catalog no. H4X-07B (1) H4X-07R (1) H4X-08B (2) H4X-08R (2) Catalog no. H4X-07BHD H4X-07RHD H4X-08BHD H4X-08RHD (3) (3) (4) (4) Catalog no. SH6-200 SH6-320 SH6-400 Catalog no. Required for 15.7" (400mm) long shafts, optional for other lengths SH-GUIDE2 AND... Aux. contacts Contact type No. of contacts Continuous amp rating Voltage (Vac) NO NO NO NO + + + + NC NC NC NC 1 1 1 1 of of of of each each each each 10.1 125-250 1 125 Max number of aux contacts Catalog no. per switch BAC03* BAC04* 2 BAC11* BAC12* * For one auxiliary contact, install either BAC03 or BAC11. For two auxiliary contacts, install BAC03 + BAC04, or BAC11 + BAC12. Shrouds Accessories Auxiliary contacts AND... Terminal shrouds* — includes terminal shroud for lineside or loadside Switch amps Poles Location on switch 3 600 4 Lineside or loadside 3 800-1200 4 * Shroud for lineside included with switch. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Catalog no. TSH6-3TB TSH6-4TB TSH7-3TB TSH7-4TB 11-77 11 — Disconnect switches Dimensions — in (mm) 600 A 800 to 1200 A Switch body Switch mounting Connection Switch amps Terminal shrouds B F 3p. F 4p. H J 3p. J 4p. M 3p. M 4p. N N1 N2 AA Z 600 18.12 (460) 11 (280) 14.17 (360) 5.5 (140) 5 (128) 6.59 (168) 10.03 (255) 13.19 (335) 6.88 (175) 2.34 (60) 1.1 (28) 12.6 (320) 1.85 (47) 800 18.12 (460) 14.64 (372) 19.37 (492) 5.5 (140) 6.83 (174) 9.19 (234) 13.66 (347) 18.38 (467) 6.88 (175) 2.34 (60) 1.1 (28) 13 (330) 1.85 (47) 1000 18.12 (460) 14.64 (372) 19.37 (492) 5.5 (140) 6.83 (174) 9.19 (234) 13.66 (347) 18.38 (467) 6.88 (175) 2.34 (60) 1.1 (28) 13 (330) 1.85 (47) 1200 18.12 (460) 14.64 (372) 19.37 (492) 5.5 (140) 6.83 (174) 9.19 (234) 13.66 (347) 18.38 (467) 6.88 (175) 2.34 (60) 1.1 (28) 13 (330) 1.85 (47) DIR-04 Direct mount handle 2.36 60 External front pistol handles Direction of Front Operation Handle Type I Door drilling layout 8.27 210 3.35 85 H4X-07__ Ø 1.46 Ø 37 4 Ø 0.27 4Ø7 2.4 61 0.78 20 7.48 190 0 90 ° Ø3.07 Ø78 Terminal lugs H4X-08__ ° 90 13.78 350 0.78 20 I Ø3.07 Ø78 0.55 14 0 2.36 60 LUG5-__, LUG6-__ 600 to 1200 A 1.49 38 3.76 95.5 0.40 Ø10.2 11-78 0.64 16.2 2.87 73 3.15 80 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 0.55 14 Disconnect switches — 11 UL 508 non-fused rotary disconnect switches — 16 to 80 A Eaton UL 508 load break disconnect switches allow safe control and safe disconnection of any motor application or to isolate a circuit within the panel. These disconnect switches are compact and offer a wide variety of accessories like 4th poles, Auxiliary contacts, door mounting and 6/8-Pole kits. Disconnect switches Features • Suitable for motor disconnect • DIN-Rail or panel mount • Door mount option • Disconnect switches are front, right side or direct handle operable • Finger-safe Agency information Related Bussmann series products • UL 508, Guide NLRV, File E155129 • CSA C22.2 No. 14, File 257020 • Conforms with IEC 60947-3 Online resources Visit Eaton.com/bussmannseries for: • CAD drawings • Instruction sheets • UL information IEC specifications RD16-3-508 Catalog no. RD16-3-508 Thermal current Ith at 40°C (A) 16 Rated insulation voltage Ui (V) 800 Rated impulse withstand voltage Uimp (kV) 8 Rated operation currents Ie (A) Load duty category Rated voltage A/B 1 AC-22 A/ AC-22 B 16/16 500 AC-23A/ AC-23 B 16/16 AC-21 A/ AC-21 B 16/16 690 AC-22 A/ AC-22 B 16/16 AC-23A/ AC-23 B 16/16 Operational power in AC-23 (kW) 400 Vac without prebreak AC 1, 2 7.5 500 Vac without prebreak AC 1, 2 7.5 690 Vac without prebreak AC 1, 2 7.5 Overload capacity (Ue 415 Vac) Rated short-time withstand current 0.3 s. ICW (kA 2.5 RMS) 3 6 Rated short-time making capacity Icm (kA peak) 3 Fuse protected short-circuit withstand (kA RMS prospective) Prospective short-circuit current (kA RMS) 3 50 Associated fuse rating (A) 3 16 Connection Minimum Cu cable cross section (mm2) 1.5 Maximum Cu cable section (mm2) 16 Tightening torque min/max (N•m) 2/2.2 Fuse blocks Modular Class H(K), J and RK fuse blocks up to 600 A Modular Class H(K), J and RK power distribution fuse blocks up to 400 A Modular, finger-safe CH Class CC and J, and UL supplemental and IEC 10x38mm DIN-Rail holders up to 60 A Finger-safe Optima Class CC, UL supplemental and IEC 10x38mm DINRail/panel mount holders up to 30 A Finger-safe Optima™ Class CC, UL supplemental and IEC 10x38mm DIN-Rail/panel mount protection modules up to 30 A RD16-3-508 with 6-pole conversion kit RD25-3-508 25 800 8 RD40-3-508 40 800 8 RD63-3-508 63 800 8 RD80-3-508 80 800 8 A/B 1 25/25 25/25 25/25 25/25 25/25 A/B 1 40/40 25/25 40/40 32/40 25/25 A/B 1 63/63 63/63 63/63 40/63 40/40 A/B 1 80/80 63/63 80/80 63/80 40/40 11 11 15 18.5 15 18.5 30 30 30 37 37 37 2.5 2.5 3 3 6 6 9 9 50 25 50 40 50 63 50 80 1.5 16 2/2.2 1.5 16 2/2.2 2.5 35 3.5/3.85 2.5 35 3.5/3.85 1 A/B: Category with index A = frequent operation; category with index B = infrequent operation. 2 The power value is given for information only; the current values vary from one manufacturer to another. 3 For a rated operating voltage, Ue = 400 Vac. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-79 11 — Disconnect switches UL specifications RD16-3-508 Catalog no. UL standard Max ampacity Handle operation UL ratings Max voltage (AC) 3-phase, 3-phase, 3-phase, 3-phase, Max. Hp ratings 208 240 480 600 Electrical characteristics SCCR with fuse (kA) Recommended upstream Fuse class Max. fuse rating (A) Terminals Wire type Wire range and torque - lb-in (N•m) Solid single Solid dual Stranded single Stranded dual Mechanical characteristics Endurances/cycles Physical characteristics Dimensions Weight- lb (kg) Environmental Operating temperature Flammability rating Accessories Long selector/NEMA 1, 3R, 4, 4X, 12 Pistol handle/NEMA 1, 3R, 4, 4X, 12 Selector handle shafts - 5x5mm Pistol handle shafts - 5x5mm RD16-3-508 UL 508 16 A Front/Side RD25-3-508 UL 508 25 A Front/Side RD40-3-508 UL 508 40 A Front/Side RD63-3-508 UL 508 63 A Front/Side RD80-3-508 UL 508 80 A Front/Side 600 Vac 3 5 10 10 600 Vac 7.5 7.5 15 20 600 Vac 7.5 7.5 20 25 600 Vac 15 20 40 40 600 Vac 15 20 40 40 65 J 30 Integral 75°C Cu 14-10, 26.5 (3) 12, 26.5 (3) 14-4, 26.5 (3) 14-12, 26.5 (3) 65 J 30 Integral 75°C Cu 14-10, 26.5 (3) 12, 26.5 (3) 14-4, 26.5 (3) 14-12, 26.5 (3) 10/65 J 60/30 Integral 75°C Cu 14-10, 26.5 (3) 12, 26.5 (3) 14-4 , 26.5 (3) 14-12, 26.5 (3) 50/65 J 100/60 Integral 75°C Cu 14-10, 31.1 (3.5) 12, 31.1 (3.5) 14-1, 31.1 (3.5) 10-6, 31.1 (3.5) 50/65 J 100/60 Integral 75°C Cu 14-10, 31.1 (3.5) 12, 31.1 (3.5) 14-1, 31.1 (3.5) 10-6, 31.1 (3.5) 10,000 10,000 10,000 10,000 10,000 0.7 (0.32) 0.7 (0.32) 0.5 (0.2) Direct Short selector/NEMA 1, 3R, 4, 4X, 12 Handles RD16-3-508 with 6-pole conversion kit Metallic hasp (HD) pistol handle/ NEMA 1, 3R, 4, 4X, 12 5.9"/150mm 7.9"/200mm 12.6"/320mm 7.9"/200mm 12.6"/320mm 15.75"/400mm Selector handle shaft guide Pistol handle shaft guide Door mount kit 1-Pole 3-Pole (loadside and lineside) Switched 4th pole/switch amps Shrouds/switch amps Ground module (conforms to IEC 60947-3) Neutral module (conforms to IEC 60947-3) NO + NC (1 ea.) (2) NO AC ratings Auxiliary contacts Volts Amps 6-/8-pole conversion kit gangs two switches of same rating, 16-80 A switch amps See drawings on product pages 0.5 (0.2) 0.5 (0.2) -20 to 70°C UL 94-V0 -20 to 70°C UL 94-V0 -20 to 70°C UL 94-V0 -20 to 70°C UL 94-V0 -20 to 70°C UL 94-V0 DIR-01 H4X-01B H4X-01R H4X-02B H4X-02R H4X-03B H4X-03R H4X-03BHD H4X-03RHD SH4-150 SH4-200 SH4-320 SH3-200 SH3-320 SH3-400 SH-GUIDE1 SH-GUIDE2 DOOR-508 TSH1-1TB TSH1-3TB POLE-16 DIR-01 H4X-01B H4X-01R H4X-02B H4X-02R H4X-03B H4X-03R H4X-03BHD H4X-03RHD SH4-150 SH4-200 SH4-320 SH3-200 SH3-320 SH3-400 SH-GUIDE1 SH-GUIDE2 DOOR-508 TSH1-1TB TSH1-3TB POLE-25 DIR-01 H4X-01B H4X-01R H4X-02B H4X-02R H4X-03B H4X-03R H4X-03BHD H4X-03RHD SH4-150 SH4-200 SH4-320 SH3-200 SH3-320 SH3-400 SH-GUIDE1 SH-GUIDE2 DOOR-508 TSH1-1TB TSH1-3TB POLE-40 DIR-01 H4X-01B H4X-01R H4X-02B H4X-02R H4X-03B H4X-03R H4X-03BHD H4X-03RHD SH4-150 SH4-200 SH4-320 SH3-200 SH3-320 SH3-400 SH-GUIDE1 SH-GUIDE2 DOOR-508 — TSH2-3TB — DIR-01 H4X-01B H4X-01R H4X-02B H4X-02R H4X-03B H4X-03R H4X-03BHD H4X-03RHD SH4-150 SH4-200 SH4-320 SH3-200 SH3-320 SH3-400 SH-GUIDE1 SH-GUIDE2 DOOR-508 — TSH2-3TB — GND-16-40 GND-16-40 GND-16-40 GND-63-80 GND-63-80 NTRL-16-40 NTRL-16-40 NTRL-16-40 NTRL-63-80 NTRL-63-80 BAC01 BAC02 BAC01 BAC02 BAC01 BAC02 BAC01 BAC02 BAC01 BAC02 240 Vac 10 KIT-6POLE 240 Vac 10 KIT-6POLE 240 Vac 10 KIT-6POLE 240 Vac 10 KIT-6POLE 240 Vac 10 KIT-6POLE — Not available. 11-80 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 UL 508 non-fused rotary disconnect switches —16, 25, 40, 63 and 80 A For a complete assembly, select: Switch Poles 40 3 63 80 Max. Class J fuse amps 65 30 10 65 50 65 50 65 60 30 100 60 100 60 Max horsepower rating, 3-Phase 208 3 7.5 220/240 5 7.5 440/480 10 15 600 10 20 7.5 7.5 20 25 15 20 40 40 15 20 40 40 PLUS Direct mount handle - mounts directly to switch, no shaft required For switch cat. no. Color Test function All switches 2 Or Handles Select for standard application 1 + 1 2 + 14-10 Sol, Dual 12 Sol, 14-1 Str, Dual 10-6 Str, 75°C Cu Padlockable N Y - On Switch OR External front or right side operated selector handles - shaft required NEMA type Color Handle length Test function Padlockable Black Short Red/yellow 1, 3R, 4, 4X, 12 N Y Black Long Red/yellow External front operated pistol handles - shaft required NEMA type Color Handle length Test function Padlockable Defeatable Black 1, 3R, 4, 4X, 12 — N Y Y Red/yellow Metallic hasp (heavy duty) external front operated pistol handles - shaft required NEMA type Color Handle length Test function Padlockable Defeatable Black 1, 3R, 4, 4X, 12 — N Y Y Red/yellow Shafts for selector handles Length — in (mm) Mounting depth (X) - in (mm) 5.9 (150) 3.50~7.60 (89~193) 7.9 (200) 3.50~9.50 (89~241) 12.6 (320) 3.50~14.9 (89~378) Shafts for pistol handles Length — in (mm) Mounting depth (X) - in (mm) 7.9 (200) 3.30~7.40 (84~188) 12.6 (320) 3.30~9.30 (84~236) 15.7 (400) 3.30~14.7 (84~373) Shaft guides for selector and pistol handles Handle type Selector Required for 12.6" (320mm) long shafts, optional for other lengths Pistol + Black Conductor AWG size/ type Catalog no. RD16-3-508 14-10 Sol, Dual 12 RD25-3-508 Sol, 14-4 Str, Dual 14-12 Str, 75°C Cu RD40-3-508 Required for 15.7" (400mm) long shafts, optional for other lengths RD63-3-508 RD80-3-508 Catalog no. DIR-01 Catalog no. H4X-01B (1) H4X-01R (1) H4X-02B (2) H4X-02R (2) Catalog no. H4X-03B H4X-03R Catalog no. H4X-03BHD H4X-03RHD Catalog no. SH4-150 (1) SH4-200 (1) SH4-320 (1) Catalog no. SH3-200 (2) SH3-320 (2) SH3-400 (2) Catalog no. SH-GUIDE1 SH-GUIDE2 Door mount kit For mounting switch on the right side of the enclosure or directly on the enclosure door using switch side operation shaft location. Kit includes a shaft. Order switch and selector handle separately. Switch Catalog no. All switches - kit includes shaft DOOR-508 AND... BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-81 Disconnect switches Switch Amps 16 25 SCCR @600V (kA) 11 — Disconnect switches Aux.Contacts Auxiliary contacts NO + NC NO Continuous amp rating Voltage (Vac) rating Max number of units per switch Shrouds 4th pole Catalog no. BAC01 10 2 240 2 (1 per side/4 contacts total) AND... Terminal shrouds - includes terminal shroud for both lineside and loadside Switch Poles amps 16-40 1 (for switched 4th pole) 16-40 3 63-80 AND... Switched 4th pole - converts 3-pole switch to 4-pole switch Switch amps Gnd./neut. mods BAC02 Location on switch Catalog no. Lineside and loadside TSH1-1TB TSH1-3TB TSH2-3TB Catalog no. 16 POLE-16 25 POLE-25 40 POLE-40 AND... Ground and Neutral Modules - provides unswitched ground or neutral pole - conforms to IEC 60947-3 Switch amps Module Type Catalog no. 16-40 GND-16-40 Ground 63-80 16-40 GND-63-80 NTRL-16-40 Neutral 63-80 NTRL-63-80 Ground and neutral module, and switched 4th pole configurations. N or G N or G N or G Auxiliary contact configurations N or G Order switches separately N or G 6 pole kit AND... 6-pole conversion kit - creates a 6-pole switch by ganging two 3-pole switches of equal rating Switch amps Catalog no. All switches KIT-6POLE* * Kit ships with a direct handle. If external handle is needed order a selector handle and shaft for the UL 508 Rotary Disconnect Switches. Note: To create an 8-pole switch from 16 to 40 amp switches, use two 3-pole switches of equal ratings plus two switched 4th poles (part # POLE-_). N or G Accessories No. of contacts 1 Ea. Contact type Dimensions — in (mm) 1 1.97 50 0.24 6 0.35 8.8 2 F 3.19 81 2.52 64 1.99 50.6 F1 M5 T F1 2 1 J 1 G 2.68 68 0.35 8.8 0.35 8.8 0.23 6 1.96 50 Direct handle operation D M N AC G 2.67 68 2 F M 1 E F1 F1 T 1.42 36 2 ø 2.79 ø 71 1.42 36 N AC 2.95 75 2.52 64 0.35 8.8 M5 External front operation External side operation 1. Position for 1 switched 4th pole (1 per device max.), or ground or neutral module (2 per device max.) or 1 auxiliary contact. 2. Position for 1 auxiliary contact only. Note: Maximum of 4 Auxiliary contacts, or 3 Auxiliary contacts + one ground or neutral module, or one switched 4th pole. Switch amps 16 to 40 63 to 80 11-82 Overall dimensions D min D max E min E max 1.18 (30) 9.25 (235) 3.94 (100) 14.64 (372) 1.18 (30) 9.25 (235) 3.93 (100) 14.64 (372) Terminal shroud AC 4.33 (110) 4.33 (110) Switch body F 1.77 (45) 2.06 (53) F1 0.59 (15) 0.69 (18) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 G 2.67 (68) 2.99 (76) Switch mounting J 0.59 (15) 0.69 (18) M 1.18 (30) 1.38 (35) N 2.95 (75) 3.35 (85) Eaton.com/bussmannseries Connection T 0.59 (15) 0.69 (18) Disconnect switches — 11 Dimensions — in (mm) 2 1.77 45 0.35 F1 T T 8.8 2.06 52.5 F1 0.35 8.8 0.29 7.5 0.24 6 1.69 43 1 1.36 34.7 0.35 F1 T T 8.8 2.06 52.5 Direct front operation for 6/8-pole disconnects 1 2.06 52.5 E 2 1.42 36 0.29 7.5 Disconnect switches 2 ø 2.79 ø 71 1 2.06 52.5 F J F2 X M N G 2.67 68 1 3.50 89 3.07 78 N G 2.67 68 2 F J F2 X M F1 0.35 8.8 External front operation for 6/8-pole disconnects 1. Position for 1 switched 4th pole (1 per device max.) or 1 auxiliary contact. 2. Position for 1 auxiliary contact only. Note: Maximum of 4 auxiliary contacts, or 3 auxiliary contacts + one switched 4th pole. Overall dimensions Switch body Switch mounting Connection Switch amps E min E max F F1 F2 G J M N T X 16 to 40 4.13 (105) 14.64 (372) 3.83 (98) 0.59 (15) 1.77 (45) 2.67 (68) 1.92 (48.75) 1.18 (30) 2.95 (75) 0.59 (15) 0.29 (8) 63 to 80 4.13 (105) 14.65 (372) 4.13 (105) 0.69 (18) 2.06 (53) 2.99 (76) 2.06 (52.5) 1.38 (35) 3.35 (85) 0.69 (18) 0.34 (9) External selector and pistol handles Handle type Door drilling layouts Ø3.07 Ø78 Direction of front operation 1.42 36 I ° 3.46 88 Selector H4X-02_ I ° 90 Ø3.07 Ø78 90 Ø 1.22 Ø 31 0 0.11 3 4 Ø 0.27 4Ø7 Direction of right side operation 0.53 13.5 Selector H4X-01_ 1.10 28 2.79 71 1.57 40 0 Ø 0.88 Ø 22.5 With 4 Mounting Screws 1.45 37 With mounting nut 1.57 40 1.10 28 4 Ø 0.27 4Ø7 Pistol H4X-03_ H4X-03_ with 4 mounting screws Ø 1.45in/37mm screw clip (from front) Ø 1.22in/31mm screw (from rear) BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-83 11 — Disconnect switches UL 98 and UL 508 enclosed disconnect switches Enclosed fused and non-fused rotary disconnect switches from 16 to 1200 A in NEMA 1, 3R, 4, 4X, 12 enclosures. Ratings • Volts • 600 Vac • 250-600 Vdc* • Amps 16-1200 A • SCCR 2011/65/EU • UL 98 25-200 kA • UL 508 10-65 kA NEMA 1, 3R, 4 and 12 * Some non-fused disconnect switches are not rated for DC applications. Agency information • UL 98 Listed, Guide WIAX, WIAX7, File E182262 • UL 508 Listed, Guide NLRV, NLRV, File E155129 • cULus Listed to Canadian Standard 22.2, No. 14 • cULus Listed to Canadian Standard 22.2, No. 4 • Conforms with IEC 60947-3 • RoHS compliant • CE Operating temperature • NEMA 4X 304 stainless steel -20ºC to 70ºC 4X plastic enclosure flammability ratings • Polycarbonate UL 94-5V A-0 • Fiberglass UL 94-5V Field installed accessories • Auxiliary contacts • Terminal shrouds • Switched 4th pole (UL 508 only) NEMA 4X polycarbonate or fiberglass Online resources Visit Eaton.com/bussmannseries for: • CAD drawings • Instruction sheets • UL information Features • UL 98 Listed for general purpose, main disconnect, or branch circuit protection up to 600 Vac/dc • UL 508 Listed for motor disconnect applications up to 600 Vac • Multiple field installed accessories enhance the enclosed disconnect switches to fit the desired application • Lockout/tagout: Up to three 1/4" shank padlocks can be installed on external handles 11-84 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 UL 98 enclosed fused disconnects — 30 to 800 A 3-pole UL 98 600 Vac Catalog number system: ER 4X - 60 J 3 P B ER Enclosed Rotary disconnect NEMA 1, 3R, 4 and 12 1, 3R, 4, 4X (304 SST), 4P (4X Plastic), 12 NEMA 4X 304 stainless steel NEMA 4X Disconnect switches NEMA rating 30-800A UL 98 fused switches Amp rating 30, 60, 100, 200, 400, 600, 800 Fuse class Available Bussmann series fuses J = Class J, L = Class L Fuse class Number of poles 3 = 3-pole Catalog symbol/type LPJ time-delay, current limiting JKS fast-acting fuses DFJ high speed drive fuse KRP-C time-delay, current limiting KTU fast-acting KLU time-delay KRP-CL (225-600 A) J Handle type P = Pistol Handle color L B = Black, R = Red Catalog numbers All catalog numbers provided with integral or installed lugs and a black selector handle. Order Red/yellow handle by changing the suffix “B” to “R.” Switch amps 30 60 100 200 400 600 800 Fuse class J L NEMA enclosure type and catalog no. 1 3R ER1-30J3PB ER3R-30J3PB ER1-60J3PB ER3R-60J3PB ER1-100J3PB ER3R-100J3PB ER1-200J3PB ER3R-200J3PB ER1-400J3PB ER3R-400J3PB ER1-600J3PB ER3R-600J3PB ER1-800L3PB ER3R-800L3PB 4 ER4-30J3PB ER4-60J3PB ER4-100J3PB ER4-200J3PB ER4-400J3PB ER4-600J3PB ER4-800L3PB 4X plastic1 ER4P-30J3PB ER4P-60J3PB ER4P-100J3PB ER4P-200J3PB ER4P-400J3PB ER4P-600J3PB ER4P-800L3PB 4X 304 stainless ER4X-30J3PB ER4X-60J3PB ER4X-100J3PB ER4X-200J3PB ER4X-400J3PB ER4X-600J3PB ER4X-800L3PB 12 ER12-30J3PB ER12-60J3PB ER12-100J3PB ER12-200J3PB ER12-400J3PB ER12-600J3PB ER12-800L3PB 1 Enclosures ≤100 A are polycarbonate, flammability rating UL 94-5V A-V0, ≥200 A are fiberglass, flammability rating UL 94-5V. Switch ratings For wire types, ranges and terminal torques, see table on page 11-55. Voltage Switch amps 30 60 100 200 400 600 Switch cat. no. RDF30J-3 RDF60J-3 RDF100J-3 RDF200J-3 RDF400J-3 RDF600J-3 Fuse class 800 RDF800L-3 L Poles Vac Vdc SCCR @ Vac (kA) 250 J 3 600 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 N/A 250 200 Max. Hp @ 600 Vac 20 50 75 150 350 600 Eaton.com/bussmannseries 500 11-85 11 — Disconnect switches UL 98 enclosed fused disconnects — 30 to 800 A W Enclosure weights and dimensions Catalog no. family Amps ER_-30J 30 ER_-60J 60 ER_-100J Fuse class 100 J ER_-200J ER_-400J ER_-600J ER_-800L 200 400 600 800 L NEMA enclosure 1, 3R, 4, 12 4X-SST 4X-plastic 1 1, 3R, 4, 12 4X-SST 4X-plastic 1 1, 3R, 4, 12 4X-SST 4X-plastic 1 1, 3R, 4, 12 4X-SST 4X-plastic 1 1, 3R, 4, 12 4X-SST 4X-plastic 1 1, 3R, 4, 12 4X-SST 4X-plastic 1 1, 3R, 4, 12 4X-SST 4X-plastic 1 H x W x D (in) 10x10x6 12x10x6 13x13x6 14x12x6 13x13x6 24x20x8 27x21x10 48x36x12 51x37x14 48x36x12 51x37x14 48x36x12 51x37x14 A 8.3x8.3 — — 10.3x8.3 — — 12.3x10.3 — — 22.3x18.3 — — 46.3x34.3 — — 46.3x34.3 — — 46.3x34.3 — — Mounting centers h x w (in) B C Weight (lbs) — — 15 10.7x8.3 8.3x10.7 12x5.6 7.6x10 8 — — 19 12.7x8.3 8.3x10.7 14x7.6 9.6x12 11 — — 21 14.7x10.3 12.3x12.7 14x7.6 9.6x12 12 — — 55 24.7x18.3 22.3x20.7 25.75x14 — 39 — — 188 48.7x34.3 46.3x36.7 50x28.5 — 186 — — 216 48.7x34.3 46.3x36.7 50x28.5 — 214 — — 216 48.7x34.3 46.3x36.7 50x28.5 — 214 1 Enclosures ≤100 A are polycarbonate, flammability rating UL 94-5V A-V0, ≥200 A are fiberglass, flammability rating UL 94-5V. A MW W B W Auxiliary contacts - for 30 to 800 amp switches Contact type No. of contacts NO 1 NC Cont. amp rating 10 Vac 600 Max. units per switch Catalog no. 4 (30 to 200 A) BAC05 8 (400 to 800 A) BAC06 MW Terminal shrouds For 200 to 800 amp switches - includes terminal shroud for lineside or loadside Switch amps 200 400 600-800 11-86 Poles 3 Catalog no. TSH8-3TB TSH9-3TB TSH10-3TB BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 H MH MW C Available field-Installed accessories - order separately MH H Eaton.com/bussmannseries MH H Disconnect switches — 11 UL 98 enclosed non-fused disconnects — 30 to 1200 A 3-pole UL 98 600 Vac Catalog number system: ER 4X - 60 N 3 P B ER NEMA 1, 3R, 4 and 12 Enclosed Rotary disconnect NEMA 4X 304 stainless steel NEMA 4X Disconnect switches 200-1200A UL 98 non-fused switches NEMA rating 1, 3R, 4, 4X (304 SST), 4P (4X Plastic), 12 Amp rating 30, 60, 100, 200, 400, 600, 800, 1200 N = non-fused Number of poles 3 = 3-pole Handle type NEMA 1, 3R, 4 and 12 P = Pistol NEMA 4X 304 stainless steel NEMA 4X 30-800A UL 98 non-fused switches Handle color B = Black, R = Red Catalog numbers All Catalog numbers provided with integral or installed lugs and a black selector handle. Order Red/yellow handle by changing the suffix “B” to “R.” Amps 30 60 100 200 400 600 800 1200 1 ER1-30N3PB ER1-60N3PB ER1-100N3PB ER1-200N3PB ER1-400N3PB ER1-600N3PB ER1-800N3PB ER1-1200N3PB 3R ER3R-30N3PB ER3R-60N3PB ER3R-100N3PB ER3R-200N3PB ER3R-400N3PB ER3R-600N3PB ER3R-800N3PB ER3R-1200N3PB NEMA enclosure type and catalog no. 4 4X plastic 1 ER4-30N3PB ER4P-30N3PB ER4-60N3PB ER4P-60N3PB ER4-100N3PB ER4P-100N3PB ER4-200N3PB ER4P-200N3PB ER4-400N3PB ER4P-400N3PB ER4-600N3PB ER4P-600N3PB ER4-800N3PB ER4P-800N3PB ER4-1200N3PB N/ A 4X 304 stainless ER4X-30N3PB ER4X-60N3PB ER4X-100N3PB ER4X-200N3PB ER4X-400N3PB ER4X-600N3PB ER4X-800N3PB ER4X-1200N3PB 12 ER12-30N3PB ER12-60N3PB ER12-100N3PB ER12-200N3PB ER12-400N3PB ER12-600N3PB ER12-800N3PB ER12-1200N3PB 1 Enclosures ≤100 A are polycarbonate, flammability rating UL 94-5V A-V0, ≥200 A are fiberglass, flammability rating UL 94-5V. Switch ratings For wire types, ranges and terminal torques, see table on page 11-72. Amps Switch catalog no. 30 RD30-3 60 RD60-3 100 RD100-3 200 RD200-3 400 RD400-3 600 RD600-3 800 RD800-3 1200 RD1200-3 Poles Vac SCCR (kA) 100 25/100* 3 600 Max. Hp @ 600 Vac 25 50 200 200 100 350 500 * 25 kA @ 600 Vac, 100 kA @ 480 Vac. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-87 11 — Disconnect switches UL 98 enclosed non-fused disconnects — 30 to 1200 A W Enclosure weights and dimensions Catalog no. family ER_-30 ER_-60 ER_-100 ER_-200 ER_-400 ER_-600 ER_-800 ER_-1200 Amps 30 60 100 200 400 600 800 1200 NEMA enclosure 1, 3R, 4, 12 4X-SST 4X-plastic (1) 1, 3R, 4, 12 4X-SST 4X-plastic (1) 1, 3R, 4, 12 4X-SST 4X-plastic (1) 1, 3R, 4, 12 4X-SST 4X-plastic (1) 1, 3R, 4, 12 4X-SST 4X-plastic (1) 1, 3R, 4, 12 4X-SST 4X-plastic (1) 1, 3R, 4, 12 4X-SST 4X-plastic (1) 1, 3R, 4, 12 4X-SST H x W x D (in) 10x8x6 9x9x6 10x8x6 9x9x6 12x10x6 13x13x6 20x16x8 20x17x12 36x30x8 37x32x14 48x36x12 51x37x 14 48x36x12 51x37x 14 60x36x16 60x36x16 Mounting centers h A B 8.3x6.3 — — 10.7x6.3 — 10x3.6 8.3x6.3 — — 10.7x6.3 — 10x3.6 10.3x8.3 — — 12.7x8.3 — 14x7.6 18.3x14.3 — — 20.7x14.3 — 21.5x10.1 34.3x28.3 — — 36.7x28.3 — 38x28.9 46.3x34.3 — — 48.7x34.3 — 50x28.5 46.3x34.3 — — 48.7x34.3 — 50x28.5 58.3x34.3 — — 60.7x34.3 x w (in) C — 8.3x8.7 5.6x8 — 8.3x8.7 5.6x8 — 8.3x10.7 9.6x12 — 18.3x16.7 — 34.3x30.7 — — 46.3x36.7 — — 46.3x36.7 — — 58.3x36.7 A Weight (lbs) 11 11 5 12 12 5 12 12 8 39 39 31 122 122 103 209 209 187 211 211 189 268 268 MH H MW W B H MH MW W C MH H MW 1 Enclosures ≤100 A are polycarbonate, flammability rating UL 94-5V A-V0, ≥200 A are fiberglass, flammability rating UL 94-5V. Available field-installed accessories - order separately Auxiliary contacts for 30 to 1200 amp switches. Switch amps 30-100 200-1200 Contact type NO + NC NO NO + NC NO + NC NO + NC NO + NC No. of contacts 1 of each 2 1 of each 1 of each 1 of each 1 of each Cont. amp rating Vac 10 240 10.1 125-250 1 125 Max. units per switch Catalog no. BAC01* 4 BAC02* BAC03** BAC04** 2 BAC11** BAC12** * Two (2) Units per switch max. ** For one auxiliary contact, install either BAC03 or BAC11. For two auxiliary contacts, install BAC03 + BAC04, or BAC11 + BAC12. Terminal shrouds for 200 to 800 amp switches Switch amps 30-100 Poles 200 400 600 800-1200 11-88 3 Location on switch Lineside and loadside Lineside Loadside Lineside Loadside Lineside or loadside Catalog no. TSH3-3TB TSH4-3T TSH4-3B TSH5-3T TSH5-3B TSH6-3TB TSH7-3TB BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Disconnect switches — 11 UL 508 enclosed non-fused disconnect — 16 to 80 A 3-/6-pole UL 508 600 Vac Catalog number system: ER 4X - 63 N 6 P B ER Enclosed Rotary disconnect NEMA 1, 3R, 4 and 12 1, 3R, 4, 4X (304 SST), 4P (4X Plastic), 12 NEMA 4X 304 stainless steel NEMA 4X Disconnect switches NEMA rating 16-80 A UL 508 non-fused switches Amp rating 16, 25, 40, 63, 80 N = non-fused Number of poles 3 = 3-pole, 6 = 6-pole Handle type S = Selector*, P = Pistol** Handle color B = Black, R = Red * 6-Pole switches only, selector handle does not interlock the enclosure door. ** 3-pole switches only. Catalog numbers All catalog numbers provided with a black selector handle. Order red/ yellow handle by changing the suffix “B” to “R.” Amps 16 25 40 63 80 Poles 3 6 3 6 3 6 3 6 3 6 1 ER1-16N3PB ER1-16N6SB ER1-25N3PB ER1-25N6SB ER1-40N3PB ER1-40N6SB ER1-63N3PB ER1-63N6SB ER1-80N3PB ER1-80N6SB 3R ER3R-16N3PB ER3R-16N6SB ER3R-25N3PB ER3R-25N6SB ER3R-40N3PB ER3R-40N6SB ER3R-63N3PB ER3R-63N6SB ER3R-80N3PB ER3R-80N6SB NEMA enclosure and catalog no. 4 4X plastic 1 ER4-16N3PB ER4P-16N3PB ER4-16N6SB ER4P-16N6SB ER4-25N3PB ER4P-25N3PB ER4-25N6SB ER4P-25N6SB ER4-40N3PB ER4P-40N3PB ER4-40N6SB ER4P-40N6SB ER4-63N3PB ER4P-63N3PB ER4-63N6SB ER4P-63N6SB ER4-80N3PB ER4P-80N3PB ER4-80N6SB ER4P-80N6SB 4X 304 stainless ER4X-16N3PB ER4X-16N6SB ER4X-25N3PB ER4X-25N6SB ER4X-40N3PB ER4X-40N6SB ER4X-63N3PB ER4X-63N6SB ER4X-80N3PB ER4X-80N6SB 12 ER12-16N3PB ER12-16N6SB ER12-25N3PB ER12-25N6SB ER12-40N3PB ER12-40N6SB ER12-63N3PB ER12-63N6SB ER12-80N3PB ER12-80N6SB 1 Polycarbonate enclosure flammability rating UL 94-5V A-V0. Switch ratings For wire types, ranges and terminal torques, see table on page 11-80. Amps 16 25 40 63 80 Switch catalog no. RD16-3-508 RD25-3-508 RD40-3-508 RD63-3-508 RD80-3-508 Vac SCCR with max upstream Class J fuse 65 kA /30 A 600 65 kA /30 A — 10 kA / 60 A 65 kA /60 A — 50 kA / 100 A 50 kA / 100 A Max. Hp @ 600 V 10 20 25 40 40 Note: Voltage, SCCR and horsepower ratings are the same for 3- and 6-pole switches. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 11-89 11 — Disconnect switches UL 508 enclosed non-fused disconnect — 16 to 80 A W Enclosure weights and dimensions NEMA enclosure 1, 3R, 4, 12 4X-304 SST 4X-plastic Poles 3 6 3 6 3 1 6 Switch amps H x W x D (in) 8x6x6 10x8x6 8x6x6 10x8x6 7.4x8.7x5.8 9.4x8.7x5.9 11.4x10.7x6.3 16-80 16-63 80 16-8 A A 6.3x4.3 8.3x6.3 — — — — — Mounting centers h x w (in) B C Weight (lbs) — — 8 — — 11 8.7x4.3 6.3x6.7 8 10.7x6.3 8.3x8.7 11 8x3.6 3.6x8 4 10x3.6 5.6x8 5 12x5.6 7.6x10 6 A MH H MW W 1 Polycarbonate. B Available field-installed accessories - order separately H MH Auxiliary contacts Contact type NO + NC NO Cont. No. of amp contacts rating 1 Ea. 10 2 MW Vac Max. units per switch 240 2 (1 per side, 4 contacts total) Auxiliary contact configurations Catalog no. BAC01 BAC02 W C Terminal shrouds MW Includes terminal shroud for both lineside and loadside. Switch amps 16-40 63-80 Poles Location on switch 3 Lineside and loadside Catalog no. TSH1-3TB TSH2-3TB Switched 4th pole Converts 3-pole switch to 4-pole switch. Switch amps 11-90 Catalog no. 16 POLE-16 25 POLE-25 40 POLE-40 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries MH H Quik-Spec™ electrical gear — 12 Contents Section page Description Quik-Spec™ Coordination Panelboards TM Bussmann series Quik-Spec Coordination Panelboard QSCP Up to 400 A 2 QSCP 600 to 1200 A 3 Quik-Spec elevator disconnects Power Module™ switches and panels 4-5 HVAC disconnects 6 Quik-Spec Electrical gear Fused, non-fused, GFCI Up to 200 kA SCCR in 40% less space than traditional solutions Plus, the easiest way to achieve selective coordination BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 12-1 12 — Quik-Spec™ electrical gear 30-400A Quik-Spec™ Coordination Panelboard (QSCP) Configurable 600 Vac fused panelboard with from 30 to 400 amp mains, 15 to 100 amp 1-, 2- and 3-pole branch switches and 18, 30 or 42 branch circuit positions. Finger-safe fused branch circuit switches use the time-delay or fast-acting CUBEFuse available in ratings from 1 to 100 amps. Ratings • Volts • Up to 600 Vac • Up to 125 Vdc * • Amps 30, 60, 100, 200, 225 or 400 A • SCCR • 200 kA, 100 kA or 50 kA AC • 100 kA or 20 kA@125 Vdc* * Vdc rating applicable to MLO panels only. 50 and 60 amp switches are rated 125 Vdc for installed fuse amp ratings up to 40 A and 24 Vdc for installed fuse amp ratings from 45 to 60 A. 90 and 100 amp switches are rated 125 Vdc for installed fuse amp ratings up to 80 A and 24 Vdc for installed fuse amp ratings from 90 to 100 A. Agency information • UL Listed to UL 67 • Complies with NFPA 70 Mains CCP2B 3-pole branch switch features lockout provision for 1/4" lock Loadside lugs and disconnect • Feed-through single and double • Fused loadside disconnect, ≥100 to ≤200 amp (400 amp panels only) Neutrals • • MLO (main lug only) • Fused disconnect • Non-fused disconnect Ground • Enclosure** • NEMA 1 (top or bottom feed) • NEMA 3R (bottom feed only) • Consult factory for other ratings ** Standard size 20" W x 5" D x various heights, depending on configuration. Flush mount and door-in-door not available with NEMA 3R enclosure. Surface – NEMA 1 and 3R • Flush – NEMA 1 only • UL Listed and cULus to Canadian Standard 22.2, No. 29-M1989 make it easy to address NEC and CEC selective coordination requirements in an all fused system or upstream Eaton circuit breakers • Value-engineered for greater flexibility with up to 400 amp mains, 200 kA SCCR, 100 A branches with 18, 30 and 42 branch positions • Same size footprint as traditional circuit breaker panelboards and 40% smaller than standard fusible panelboards: 20" W x 5-3/4" D x various heights (depending on configuration) • Increased safety with the current-limiting finger-safe Class CF CUBEFuse that helps reduce arc flash hazard levels Optional surge protection Doors • Single - NEMA 1 and 3R • Door-in-Door – NEMA 1 only Branch positions • Non-isolated or isolated Features Mounting • 200, 400 and 800 A unbonded and bonded 18, 30 and 42 (factory configured) 2017 NEC 700.8 requires a listed SPD to be installed in or on all emergency system panelboards. Any QSCP intended for installation on an AC circuit can be ordered with an Surge Protective Device to comply with NEC 700.8. The installed SPDs feature a remote Form C contact relay (rated at 250 Vac/0.5 A ) for easy integration into a monitoring system. Ordering Branch switches • 1-, 2- and 3-pole amp rating rejecting CCP2B fused switches† (field installable) • Amp rejection breaks 15, 20, 30, 40, 50, 60, 70, 90, 100 A The QSCP is factory configured to the specific electrical system. To place your order, contact your Bussmann series product distributor or representative and provide the relevant electrical and circuit information for your installation. † CCP2Bs will not accept a fuse with a greater amp rating than the switch. Data sheet no. 1160 12-2 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Quik-Spec™ electrical gear — 12 600-1200A Quik-Spec Coordination Panelboard (QSCP) Configurable fused panelboard with 600, 800 and 1200 amp MLO mains and branch switches up to 600 amps. Ratings • Volts • Up to 600 Vac • Up to 125 Vdc • Amps 600, 800, 1200 A • SCCR 200 kA • UL Listed to UL 67 • Complies with NFPA 70 Quik-Spec Electrical gear Agency information Assembly • Main lug only • Floor mount NEMA 1 enclosure • Branch switches 1-, 2- and 3-pole, 15 to 600 A Available branch switch fuses • Fast-acting or time-delay Class J (time-delay LPJ or fast-acting JKS) non-CCP2B disconnects only • High speed DFJ Class J fuses (non-CCPB disconnects only) • Fast-acting or time-delay Class CF (time-delay TCF or fast-acting FCF) CCP2B disconnects only Configuration and dimensions — in Panel amps • • 600 D 200 A single + 200 A single 65 27 15 89 38 15 65 38 15 89 38 15 89 38 15 102 38 15 200 A single + 200 A twin 200 A twin + 200 A twin The CCP2B finger-safe branch switches (utilizing the UL Class CF CUBEFuse up to 100 A) features amp rating rejection to help prevent overfusing Fused switches make it simple to address NEC selective coordination system requirements in an all fused system or qwith upstream Eaton circuit breakers. W (18) 1-100 A + 200 A single (18) 1-100 A + 200 A twin Configurable panelboards with options for 600, 800 and 1200 A MLO mains and branches from 15-600 A all rated 200 kA SCCR at 600 Vac H (18) 1-100 A Features • Branch configurations (2) 300 A single (18) 1-100 A + 200 A single (18) 1-100 A + 200 A twin 800 Ordering (2) 200 A twin (18) 1-100 A + 400 A single 200 A twin + 400 A single (2) 400 A single The QSCP is factory configured to the specific electrical system. To place your order, contact your Bussmann series product distributor or representative and provide the relevant electrical and circuit information for your installation. (18) 1-100 A + 600 A single (3) 200 A twin 200 A twin + 600 A single 1200 (2) 200 A twin + 400 A single (3) 400 A single 600 A single + 400 A single + 200 A single 600 A single + 400 A single + 200 A twin (2) 600 A single Data sheet no. 1171 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 12-3 12 — Quik-Spec™ electrical gear Quik-Spec Power Module switch and panel all-in-one elevator disconnects Fused power switch (PS) or panel (PMP) with shunt trip and fire safety interface provide a single point tie in with fire alarm systems. Ratings • Volts 600 Vac, 3Ø • Amps* • • 30-400 A (PS) • 30-200 A (PMP feeder switches) • 400-800 A (PMP main switches) PS† Power Module Switch for single elevator applications. SCCR 200 kA RMS * Contact your Bussmann series product representative for applications greater than 800 amps. Agency information • Power Module switch (PS) — UL Listed (UL 98) enclosed and dead front switch Guide 96NK3917, File E182262, NEMA 1, UL 50 Listed enclosure**, cUL per Canadian Standards C22.2, No. 0-M91-CAN/CSA C22.2, No. 4-M89 Enclosed switch. • Power Module Panel (PMP) — UL 98 enclosed and deadfront switches, complies with NFPA 70 ** NEMA 12, 3R, and 4 enclosures also available. Elevator shutdown • ANSI/ASME A17.1, 2.8.3.3.2 • NEC 620.51(B) (elevator shutdown) • NEC 240.12 (orderly shutdown) • Shunt trip voltage monitoring • NFPA 72, 6.16.4.4 Selective coordination • PMP† Power Module Panel for multiple elevator applications. NEC 620.62 † Fused main disconnect requires Class J fuses, not supplied with switch. Auxiliary contact (hydraulic elevator) • NEC 620.91(C) Features Typical applications • Elevator disconnects • Computer room shunt trip disconnect • Fire safety interface relay • Internally powered, relay activated shunt trip system • Mechanically interlocked auxiliary contact Accessories • Self-contained adherence to elevator consensus standards, NFPA 70, NFPA 72, ANSI/ASME A17.1 • • Shunt trip capability • Fire safety signal interface • Shunt trip voltage monitoring • Component protection with Low-Peak™ Class J fuses • Lockable in the open position with three-lock capability • Optional key-test switch and optional pilot light for easy inspection • No annual calibration or testing of overcurrent protection required • Padlockable for service-work safety and open-door “override” for troubleshooting For added safety, use the Bussmann series SAMI™ fuse covers to improve maintenance personnel protection (OSHA 1910.333, Paragraph C) Ordering • The Quik-Spec Power Module Switch and Panel are factory configured. To place your order, have all relevant electrical and circuit information contact your Bussmann series product representative. Data sheet no. 1145 (switch) 1146 (panel) 12-4 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Quik-Spec™ electrical gear — 12 Hydraulic elevators Power Module Switch catalog number system Hydraulic elevators need battery backup to help prevent stranding passengers. To keep the elevator from moving when it’s been manually shut down for maintenance, the NEC requires battery backup be connected to the elevator disconnecting means through an auxiliary contact. To order, use this build-a-code to specify your Power Module switch. However, an unintended consequence can be passengers getting stranded because of devices that open automatically (circuit breakers and disconnects utilizing a molded case switch with a trailing fuse block) will operate with a fault on their loadside. That operation also disables the battery backup and strands passengers. That’s why the Power Module has a non-automatic fusible shunt trip switch. If the Power Module has a fault on its loadside, the fuses open and the battery stays enabled. Thus the Power Module ensures that battery power is enabled when the passengers need it to exit - and disabled to allow safe maintenance of the elevator and hoistway. Amp rating† Power failure Fire in shaft or machine room Disconnect manually opened Fault on loadside of disconnect Reason Offered by Power Module Yes Need to lower elevator and allow passengers to exit. Yes Yes No Recall is initiated by smoke detector and lowers elevator to a safe floor. Battery not needed. Yes Yes No Worker to perform maintenance. Elevator must remain stationary to prevent injury. Yes Yes Need to lower elevator and allow passengers to exit. Yes PS = Power Module Switch • Control transformer*† • • Yes No Ship-direct service within three business days for Power Module switches (PS_) and 10 business days for Power Module panels (PMP_). Power Module switch* Amps Volts 60 480 PS1T48R1KGBF3-X 100 480 PS1T20R1KGBF3-X 100 208 PS2T48R1KGBF3-X 200 480 200 208 PS2T20R1KGBF3-X R1 = 120 Vac coil, R2 = 24 Vdc coil Optional key test switch • K = Key Optional pilot light ON • G = Green, R = Red W = White Optional neutral lug†† • N6 = 30-60 A, N1 = 100 A N2 = 200 A, N4 = 400 A Auxiliary contacts† QuikShip service program, 3 days for switches and 10 days for panels! Catalog no. T20 = 208 V, T24 = 240 V T48 = 480 V, T60 = 600 V Fire safety interface relay (3PDT, 10A, 12V)† • B = 2 NO/NC Fire alarm voltage monitoring relay (to monitor shunt trip voltage) • PS6T48R1KGBF3-X 3 = 30, 6 = 60, 1 = 100 2 = 200, 4 = 400 Quik-Spec Electrical gear Scenario Battery lowering required Offered by other elevator disconnects PS 1 T48 R1 K G N1 B F1 U F1 = Single-pole, F3 = Three-pole** Optional NEMA enclosures (Type 1 standard with no suffix designation required) • U = Type 3R, Y = Type 4, Z = Type 12 * 100 Va with primary and secondary fusing (120 V secondary). ** Only for use with R1 option. † Required equipment. †† Neutral lug rating should be equal to or greater than the switch amp rating. Power Module panel** Catalog no. Amps PMP-400-X 400 PMP-600-X 600 PMP-800-X 800 * Three day PS_ shipment requires ordering from catalog numbers shown, limit three units or less per order. ** 10 day PMP_ shipment covers NEMA 1 enclosures with the amp ratings shown and all requirements for relay type (AC or DC), accessory options and number of switches. To order PMP_, contact your Bussmann series product representative with all relevant electrical and circuit information. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Data sheet no. 1145 (switch) 1146 (panel) Eaton.com/bussmannseries 12-5 12 — Quik-Spec™ electrical gear Fused and non-fused AC disconnects Enclosure Fused and non-fused pullout AC disconnects in NEMA 3R enclosures. Fused versions are available in 30 and 60 amp ratings with or without selftesting GFCI receptacles. Nonfused versions are available in 60 amp versions with or without self-testing GFCI receptacles. • Ratings Dimensions • • 120 Vac single-phase Fused disconnect • 240 Vac split-phase • AC disconnects meet NEC Code requirements under article 440.14 • Self-testing GFCI units meet NEC Code requirements under articles 210.63, 210.8, and 406.8(B)(1) • NEMA 3R enclosures withstand outdoor environment • Padlockable with two-position pullout handle to lock safety shield when in the ON position. (Not available on GFCI or 60 A switched units.) For added safety, pullout handle can be stored in the compartment in the OFF position Amps 30 or 60 A • Typical applications Agency Information UL Listed to UL 1429, cUL Certified, UL Guide WGEW • See catalog numbers table Features Volts • Metallic NEMA 3R housing with weather resistant coating Non-fused disconnect Conductors • Residential, light industrial/commercial AC and heat pump service • Spas/whirlpools, swimming pools, pump houses • Suitable for use as service entrance equipment with field-installed ground bar. Order catalog number DPFG 3-14 AWG Cu/Al • Non-fused disconnect with GFCI receptacle Catalog no. Fused disconnects B221-30F B221-30FGFST Amp rating Description Pullout disconnect Pullout disconnect with Pullout disconnect with B221-30FGFWTST resistant rated GFCI B222-60F Pullout disconnect B222-60FGFST Pullout disconnect with Pullout disconnect with B222-60FGFWTST resistant rated GFCI Non-fused disconnects B222-60NF Pullout disconnect B222-60NFGFST Pullout disconnect with Pullout disconnect with B222-60NFGFWTST resistant rated GFCI B222-60NFNA Disconnect switch GFCI weather-resistant/tamper- GFCI weather-resistant/tamper- GFCI weather-resistant/tamper- 30 Max Hp rating 120 V 240 V 1.5 60 3 3 60 3 10 10 Fuse class H or R H or R * — Approximate dimensions (in) Height Width Depth 8-3/4 5-3/8 2-7/8 13 7-1/2 4-3/4 8-3/4 5-3/8 2-7/8 13 7-1/2 4-3/4 8-3/4 5-3/8 2-7/8 11-3/4 6-1/2 4-1/2 8-3/4 5-3/8 3-5/8 * Upstream overcurrent protective device (OPCD) not to exceed 60 A. For a 30 and 60 amp pullout replacement handle, order catalog number 96-3258-4. Recommended Bussmann series fuses Fuse class H R Catalog symbol NON-(amp) FRN-R-(amp) LPN-RK-(amp)SP (non-indicating) LPN-RK-(amp)SPI (indicating Operation One time, general purpose Available amps Up to 60 Dual element, time-delay Up to 60 35 to 60 Data sheet no. 1030 1019 1003 1003 Data sheet no. 1143 12-6 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Surge protective devices — 13 Contents Section page Description Selecting Type 1 SPDs 2-3 Type 1 SPDs SurgePOD PRO Type 1, NEMA 4X 4-5 BSPA, Type 1 and 2, NEMA 4X 6-9 BSPD high capacity Type 1 and 2, NEMA 1 and 4X 10-14 UL DIN-Rail high SCCR Type 1 SPDs 1-pole, BSPM_S2G 15-16 2-pole, BSPM_S3G 17-18 3-pole, BSPM_WYG/DLG 19-20 4-pole, BSPM_WYNG/HLG 21-22 UL DIN-Rail power and control voltage Type 4 SPDs 1-pole, Type 4 power BSPM_LV 23-24 2-pole, Type 4 voltage BSPH2A_LV 25-26 RJ45/Ethernet 27 Universal 4 wire BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 28-29 Eaton.com/bussmannseries 13-1 Surge protective devices UL 497B DIN-Rail data signal SPDs 13 — Surge protective devices Selecting a Type 1 SPD Electrical systems and connections Step 1: Review the following system diagrams that show the SPD connection points for the Bussmann series SPD models that may be applied. Step 2: Locate the system diagram that matches your application, note the applicable SPD model numbers and then proceed to the product pages for their details. Understanding the following will help assure that the correct surge protective device is specified: • Typical North American electrical systems include single-phase, split-phase, Delta and Wye. • Selecting the wrong SPD generally arises from misunderstanding the nominal system voltage, ground and neutral connections. • General convention has it that a “ground” wire is not counted as a wire in the system description (e.g., 3 wire, 4 wire, etc.), but it is counted as a connection point if the SPD has a ground wire. • Selecting a voltage rating for Wye systems must be based upon its nominal system voltage rating and not on the leg-to-leg voltages. • Bonded N-G configurations do not require protection at the service entrance transformer, but protection is suggested in downstream bonded N-G systems if the length of conductor making the bond is greater than 10 feet (3m). BSPD high capacity SurgePOD PRO Two wire single-phase 2 connection points Three wire split-phase/twopole - 3 connection points Three wire split-phase/twopole - 3 connection points Application: Sub-panel or feeder panel Application: Service entrance panel Application: Sub-panel or feeder panel Volts: 120, 240 (L-N) Volts: 120, 240 (L-N) Note: Must be installed within 10 feet (3m) of a bonded neutral ground connection per IEEE C62.41-1991. Note: Installation for where the SPD is greater than 10 feet (3m) from a bonded neutral-ground connection. Volts: 120, 240 (L-N), 240, 480 (L1-L2) Note: Installation at or less than 10 feet (3m) from the transformer and within 10 feet (3m) of a bonded-neutral ground connection. G Dedicated one-pole circuit breaker, or one-pole fusible switch BSPA L1 N L2 Dedicated one-pole circuit breaker, or one-pole fusible switch Three wire split-phase/twopole plus ground 4 connection points Application: Service entrance equipment Volts: 120, 240 (L-N), 240 (L1-L2) Note: Installation where greater than 10 feet (3m) of a bondedneutral ground connection. Dedicated two-pole common trip circuit breaker, or two-pole fusible switch Dedicated two-pole common trip circuit breaker, or two-pole fusible switch Black Black Black Black Black Black White White White White L1 L1 L1 Green L1 G G G N L2 N N G SPD catalog numbers: • BSPA • • Specify from build-a-code catalog number system SurgePOD™ PRO • BSPA • • Specify from build-a-code catalog number system BSPA • N SPD catalog numbers: SPD catalog numbers: • SPP40SP1120SN 13-2 SPD catalog numbers: • L2 Green • Specify from build-a-code catalog number system BSPA • Specify from build-a-code catalog number system SurgePOD PRO • SPP40SP2240PN BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Surge protective devices — 13 Three wire split-phase/twopole plus ground 4 connection points Application: Sub-panel or feeder panel Volts: 120, 240 (L-N), 240 (L1-L2) Note: For installation greater than 10 feet (3m) of a bondedneutral ground connection. Three wire Wye plus ground - 4 connection points Four wire Wye plus ground 5 connection points Four wire Wye plus ground 5 connection points Application: Sub-panel or feeder panel Application: Service entrance equipment Application: Sub-panel or feeder panel Volts: 208, 480, 600 (L-L) Volts: 120, 127, 277, 347 (L-N), 208, 220, 480, 600 (L-L) Volts: 120, 127, 277, 347 (L-N), 208, 220, 480, 600 (L-L) Note: Common system configuration with Neutral pulled into facility and bonded to ground. Note: Common system configuration with Neutral pulled into facility and bonded to ground. Note: A common MCC configuration for pumping and water/waste water treatment. L1 N L2 N L2 Dedicated two-pole common trip circuit breaker, or two-pole fusible switch Dedicated three-pole common trip circuit breaker, or three-pole fusible switch Black Black White L2 Black Dedicated three-pole common trip circuit breaker, or three-pole fusible switch Black Black Black White Black L1 Black Green L1 L2 L3 Green N L2 G SPD catalog numbers: BSPA • L3 Green G N G L1 • L2 Black White G Dedicated three-pole common trip circuit breaker, or three-pole fusible switch Black Black L1 L3 Green SPD catalog numbers: N SPD catalog numbers: • Specify from build-a-code catalog number system BSPA • • Specify from build-a-code catalog number system • • SurgePOD PRO • SPP40SP3208WYG • SPP4SP3480WYG BSPA • • • Specify from build-a-code catalog number system BSPA • SPD catalog numbers: Specify from build-a-code catalog number system BSPD • Specify from build-a-code catalog number system BSPD • Three wire Delta plus ground - 4 connection points L3 Specify from build-a-code catalog number system Application: Service entrance equipment, sub-panel or feeder panel Volts: 240, 480, 600 (L-L) Dedicated three-pole common trip circuit breaker, or three-pole fusible switch Black Black Black L1 L2 L3 Green G SPD catalog numbers: • BSPA • • Specify from build-a-code catalog number system BSPD • Specify from build-a-code catalog number system BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 13-3 Surge protective devices L1 13 — Surge protective devices SurgePOD™ PRO for UL 1449 4th Edition Listed loadside and lineside protection The Bussmann series SurgePOD PRO is a Type 1 UL Listed 1449 4th Edition surge protective device suitable for installation on both the loadside or lineside of the service entrance overcurrent protective device and is well suited for light commercial and residential applications. Available in popular voltage and system specific versions to match common residential and light commercial electrical system and equipment requirements. The SurgePOD PRO delivers superior surge protection using MOV thermal disconnect technology that eliminates the need for additional overcurrent protection. Catalog no. SPP40SP1120SN SPP40SP2240PN SPP40SP3600WYG SPP40SP3208WYG SPP40SP3480WYG See catalog number explanation below for details. Catalog number explanation This is not a build-a-code for configuring an orderable catalog number. It's purpose is to show what portions of the catalog number denotes which specification. SPP 40S Px xxx xxx SPP = Product family Surge rating • 2011/65/EU easyID™ LED Status Indicator • P1 = 1, P2 = 2, P3 = 3 System voltage (Vac) • Type 1 UL 1449 4th Edition Listed SPDs are easily selected and installed on the loadside or lineside of the service entrance overcurrent protective device • Voltage specific models precisely match and protect electrical systems and equipment better than “one-size-fits-all” SPDs • Thermal disconnect technology eliminates the need for additional fusing • NEMA 4X enclosure for indoor or outdoor applications • easyID™ LED status indicator provides surge protection status at a glance • 120, 208, 240, 480, 600 System type/wires and connection points • SN = Single-phase 2 wire, 2 connection points • PN = Split-phase 3 wire , 3 connection points • DLG = Three-phase Delta 3 wire + G, 4 connection points • WYG = Three-phase Wye 3 wire + G, 4 connection points easyID™ LED status indicator Dimensions — in Ø 1-1/16” 40 kA surge current capacity Number of wires Parallel connection to the electrical system permits the SurgePOD PRO SPD to be installed on any ampacity panel. The easyID LED status indicator will illuminate when the unit is properly installed and the system or equipment being protected is energized. The following LED color/status indicates: GREEN LED = Good 4-1/8” The circuit is energized and protected. 1-11/16” 3-3/16” 4-1/16” 3-3/8” 1-11/16” 2-1/16” SPP40SP3240DLG SPP40SP3480DLG 2-1/16” 7/8” Mounting RED LED = Replace The circuit is energized and unprotected. SurgePOD PRO is a panel mount device. It may also be mounted using a customer supplied bracket or directly onto a female threaded conduit fitting. For NEMA 4X installation, install appropriate customer supplied gasket between SPD and enclosure wall. The unit needs replacing. LED is Out / Unlit: The circuit is most likely deenergized The unit’s leads are disconnected Tighten locknut to 20.3 Lb-In (2.3N•m) The unit is damaged Authorized personnel should follow all prescribed lockout/tagout and safety procedures in troubleshooting the cause for the above conditions. Opening SurgePOD PRO enclosure will void the warranty. Data sheet no. 10033 13-4 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Surge protective devices — 13 SurgePOD PRO Catalog no. SPP40SP1120SN Nominal system voltage 120 SPP40SP2240PN Max. continuous operating AC voltage (MCOV) (VC) 150 System type Single-phase 2 wire Connection points 2 120/240 150 Split-phase 3 wire 3 SPP40SP3240DLG 240 320 Three-phase Delta 3 wire + G 4 SPP40SP3480DLG 480 550 Three-phase Delta 3 wire + G 4 SPP40SP3208WYG 208 150 Three-phase Wye 3 wire + G 4 SPP40SP3480WYG 480 320 Three-phase Wye 3 wire + G 4 SPP40SP3600WYG* 600 420 Three-phase Wye 3 wire + G 4 * Not CSA Certified. Values 200 kA 10 kA 40 kA 600 A 2 Motor starter overload relay M 5 Feeder with no motor load 3 6a 6b Feeder with all motor load 4 Feeder with combo motor/ no motor load 4. Feeder circuit with mixed loads∆. (430.63) Size fuse at sum of: a. 150% to 175%†† of the largest motor’s full-load current**, plus b. 100% of all other motors’ full-load current**, plus c. 125% of the continuous, non-motor load†, plus d. 100% of the non-continuous, non-motor load 5. Branch circuit with no motor load. (210.20) The fuse size must be at least 125% of the continuous load† plus 100% of the non-continuous load. Do not size larger than the conductor’s ampacity*. 6. Motor branch circuit with overload relays. Where overload relays are sized per 430.32 for motor running overload protection, there are various alternatives: 6a. Motor branch circuit short-circuit and ground fault protection. (430.52) (most common). Size the fuse between 150 to 175%†† of the full load current.** Provides branch circuit short-circuit and ground fault protection only. 11 6b. Motor branch circuit short-circuit and ground fault protection (430.52) as well as backup overload protection. Size FRN-R and FRS-R Class RK5 dual-element, time-delay fuses at 125% and LPN-RK-SP and LPS-RK-SP Class RK1 dual-element, time-delay fuses at 130% of motor full-load current or next higher size. This results in closer fuse sizing and provides some backup running overload protection. In addition, it provides motor branch circuit shortcircuit and ground fault protection. Sizing in this manner may result in better motor protection if the overload relays are not properly sized or calibrated. 12 7 Large motor 5 5 M NonCont. cont. loads, lighting/ loads heating M 7 7 7 M 7. M M 9 5 • Motor 1.15 service factor or 40°C rise. Size the fuse at 110% to 125% of the motor full-load current on the name plate [430.6(a)(2)]. 5 • Motor less than 1.15 service factor or over 40°C rise. Size fuse at 100% to 115% of motor full-load current on the name plate [430.6(a)(2)]. M Continuous loads Power factor correction capacitor 8. Large motor branch circuit. Fuse larger than 600 A. [436.52(c) and 430.52(c)(1) Exceptions 2(d)]. For large motors, size LowPeak KRP-C-SP time-delay fuse at 175% to 300% of the motor full-load current**, depending on the starting method; i.e., partwinding starting, reduced voltage starting, etc. 9. Power factor correction capacitors. [460.8(b)]. Size dualelement fuses as low as practical, typically 150% to 175% of capacitor rated current. Dual-element, time-delay fuses Class CF (up to 400 A), and J, RK1 and RK5 ( up to 600 A) For fuses above 600 A, use Class L time-delay fuses with ratings from 601-6000 A. While these fuses are not dual-element construction, the Bussmann series KRP-C-SP is a time-delay fuse. 1. Main service. Size fuse according to method in 4 below. 2. Feeder circuit with no motor loads. (215.3) The fuse size must be at least 125% of the continuous load† plus 100% of the non-continuous load. Do not size larger than the conductor’s ampacity*. 3. Feeder circuit with all motor loads. (430.62) Size the fuse at 150% to 175% of the largest motor’s full load current** plus the full-load current** of all other motor's∆. Motor branch circuit with only fuse protection. Where the fuse is the only motor protection, the following FRS-R and FRN-R, Class RK5, fuses provide motor running overload protection (430.32) and short-circuit protection (430.52): 10. Transformer primary fuse (without secondary fuse protection). [450.3(b)] When transformer primary current is equal to or greater than 9 amps, the dual-element, time-delay fuse should be sized at 125% of transformer primary current or the next size larger if 125% does not correspond to a standard fuse size. Note: Secondary conductors must be protected from overcurrent damage per Article 240. 11. Transformer primary fuse (with secondary fuse protection). [450.3(b)] May be sized at 250% of transformer primary current if the secondary is fused per 12 below. 12. The secondary fuse is sized at no more than 125% of secondary full-load current. [450.3(b)] Note: Secondary conductors must be protected at their ampacities per Article 240. 16-2 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse and fuse block cross reference, and index — 16 (FCF, JKS, KTN-R, KTS-R, JJN, JJS, LP-CC, KTK-R and FNQ-R) 1. Main service. Size fuse according to method in 4. 2. Feeder circuit with no motor loads. (215.3) The fuse size must be at least 125% of the continuous load† plus 100% of the non-continuous load. Do not size larger than the conductor’s ampacity.* 3. Feeder circuit with all motor loads. (430.62) Size the fuse at 300% of the largest motor’s full-load current** plus the full-load current** of all other motors. 4. Feeder circuit with mixed loads. (430.62) Size fuse at sum of: a. 300% of the full-load current** of the largest motor, plus 3. Feeder circuit with all motor loads. (430.24) Conductor ampacity at least 125% of the largest motor full-load amps plus 100% of all other motors’ full-load amps. 4. Feeder circuit with mixed loads. (430.24) Size according to method 1 above. 5. Branch circuit with no motor load. [210.19(a)(10] Conductor ampacity at least 125% of the continuous load plus 100% of the non-continuous load. 6, 7 and 8. Motor branch circuits. (430.22) Conductor ampacity at least 125% of the motor full-load current. 9. Capacitor connected to motor branch circuit. (460.8) Conductor ampacity at least 135% of capacitor rated current, and at least 1/3 the motor circuit conductors’ ampacity. b. 100% of the full-load current** of all other motors, plus 10, 11. Conductor ampacity minimum 125% of transformer fullload current. c. 125% of the continuous, non-motor load†, plus 12. Conductor ampacity per 1 above. d. 100% of the non-continuous, non-motor load † 5. Branch circuit with no motor loads. (210.20) The fuse size must be at least 125% of the continuous load† plus 100% of the non-continuous load. Do not size larger than the conductor’s ampacity.* 6a. Motor branch circuit with overload relays. (430.52) Size the fuse at 300% of the full load current**. Provides branch circuit short-circuit and ground fault protection only. Other means must be utilized to provide motor overload protection (see 430.32). (If 300% is not a standard fuse amp rating, 430.52(C)(1) Exception 1 permits the next standard fuse amp rating. If the motor cannot start with this size fuse, 430.52(C) (1) Exception 2 permits increasing the fuse size up to 400% provided the fuse rating does not exceed 600 A.) 6b. Motor branch circuit short-circuit and ground fault protection (430.52) as well as backup overload protection. Not applicable for non-time-delay fuses; use FRN-R and FRS-R, Class RK5, dual-element time-delay fuses or LPN-RKSP and LPS-RK-SP Class RK1, dual-element, time-delay fuses (see 6b under dual-element time-delay fuse selection). Nontime-delay fuses cannot be sized close enough to provide motor running backup overload protection. If sized for motor overload backup protection, non-time-delay fuses would open due to motor starting current. 7. Motor branch circuit with only fuse protection. Not applicable for non-time-delay fuses; use FRN-R and FRS-R, Class RK5, dualelement time-delay fuses (see 7 under dual-element time-delay fuse selection). Non-time-delay fuses cannot be sized close enough to provide motor running overload protection. If sized for motor overload protection, non-time-delay fuses would open due to motor starting current. 8. Power factor correction capacitors. [460.8(B)] Size non-timedelay fuses as low as practical, typically 250% to 300% of capacitor rated current. Conductor ampacity selection 1. Feeder circuit and main circuit with mixed loads. (430.24) conductor ampacity at least sum of: 100% of the continuous load can be used rather than 125% when the switch and fuse are listed for 100% continuous operation as an assembly (e.g., 215.3 Exc 1). Some bolted pressure switches and high pressure contact switches 400 A to 6000 A with Class J and L fuses in specified assemblies are listed for 100% continuous operation. * Where conductor ampacity does not correspond to a standard fuse amp rating, the next higher amp rating fuse is permitted when 800 A or less [(240.4(B)]. Above 800 A the conductor ampacity must be equal or greater than the fuse amp rating [(240.4(C)]. However, per 240.91(B), when above 800 A for supervised industrial installations, the conductor ampacity is permitted to be 95% of the fuse amp rating as long as the equipment is listed for that size conductor and the conductor is protected within its time vs. current limits [240.4 Informational Note]. ∆ In many motor feeder applications dual-element fuses can be sized at ampacity of feeder conductors. • Available short-circuit current and the clearing time of the overcurrent device must be considered so that the conductor’s ICEA (P32.382) withstand rating is not exceeded. ** On general motor applications, motor full load amps for calculating conductor ampacity and for calculating fuse amp ratings for motor branch circuit shortcircuit and ground fault protection (430.52) are selected from NEC Tables 430.247 through 430.250 per 430.6(A)(1). However, the motor nameplate current rating is used for sizing motor overload protection (430.32) per 430.6(A)(2). †† 430.52(C)(1) allows a maximum of 175% for time-delay fuses, for all but wound rotor and DC motors. A range of 150% to 175% was used for these guidelines, even though 430.52(C)(1) allows a maximum of 175% for timedelay fuses as stated above. The reason for showing this range is to highlight the possibility for application selection. In some situations, there may be a difference in the switch amp rating or fuse block amp rating in selecting 150% versus 175%. Using 175% is permitted and is suggested for heavy starting current or longer starting time applications. Further note: the NEC permits larger sizing via two exceptions. 430.52(C) (1) Exception 1 permits the next standard size if 175% does not correspond with a standard fuse amp rating. If the motor cannot start with this size fuse, 430.52(C)(1) Exception 2 permits increasing a time-delay fuse size up to 225%. (Note that while a time-delay fuse may not exceed 225% when using Exception 2, using a time-delay fuse could exceed 225% when applying Exception 1. For example, assume a motor with a FLA of 1.0 amp. 430.52(C) (1) would allow a 1.75 amp fuse. Exception 1 would allow a 3 amp timedelay fuse per 240.6(A). Exception 2 limits the time-delay fuse to 2.25 amps as a maximum, but Exception 2 is not utilized or needed if Exception 1 is adequate.) *** The conductor ampacity may have to be greater due to using adjustment or correction factors per 210.(19)(A)(1) and 215.2(A)(1). a. 100%†† of the full-load current** of the largest motor, plus a. 100% of the full-load current** of all other motors, plus c. 125% of the continuous, non-motor load†, plus d. 100% of the non-continuous, non-motor load 2. Feeder circuit with no motor load. [215.2(a)(1)] Conductor ampacity at least 125% of the continuous load plus 100% of the non-continuous load. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 16-3 Cross reference and index Non-time delay and all Class CC fuses 16 — Fuse and fuse block cross reference, and index Selective coordination While important, selecting overcurrent protective devices (OCPDs) based solely on their ability to carry system load current and interrupting the maximum fault current at their respective application points is not enough. As the demand for power system reliability increases, the OCPD’s performance in the system becomes more and more critical as its function should, ideally, limit a power system outage to only that portion of the circuit which is faulted. The selected OCPD types and ratings (or settings) determine whether they are selectively coordinated upstream and downstream in a system so that only the nearest upstream OCPD will open for the full range of overcurrents and opening times, and leave the remainder of the system undisturbed to preserve service continuity. X LPS-RK-200SP LPS-RK-400SP KRP-C-800SP 2:1 (or more) 2:1 (or more) It’s a simple matter to selectively coordinate a system using published fuse amp rating ratio tables and maintaining the minimum ratios between an upstream and downstream fuse. This will ensure selective coordination is achieved for all fault currents up to the fuse’s interrupting rating. These selectivity ratios are for all overcurrent levels up to the fuse interrupting or 200 kA, whichever is lower. For an in-depth examination of this subject, see selective coordination in Section 4 of the Selecting Protective Devices handbook, publication number 3002. Coordination, Selective (selective coordination) Localization of an overcurrent condition to restrict outages to the circuit or equipment affected, accomplished by the selection and installation of overcurrent protective devices and their ratings or settings for the full range of available overcurrents, from overload to the maximum available fault current, and for the full range of overcurrent protective device opening times associated with those overcurrents. Selective coordination is mandatory per the NEC for the circuit paths of some vital loads on specific systems including: Figure 1 Low-Peak fuses applied with a simple 2:1 amp rating ratio achieves selective coordination. Figure 1 shows the minimum amp rating ratios for Bussmann series Low-Peak fuses required to provide “selective coordination” (discrimination) between upstream and downstream fuses. • • • • • • Elevator circuits — 620.62 Critical operations data systems — 645.27 Campus style fire pumps — 695.3 Emergency systems — 700.32 Legally required standby systems — 701.27 Critical operations power systems — 708.54 Bussmann series fuse selectivity ratios This selectivity ratio table identifies the fuse amp rating ratios that ensure selective coordination. Circuit Downstream / loadside fuse Amp rating range 6016000 A 0-600 A 01200 A 0-600 A 060 A Dual-element, time-delay Fastacting Fastacting Fastacting Fastacting Timedelay Fusetron (RK5) Limitron (L) Limitron (RK1) Limitron (T) Limitron (J) SC (G) (CC) LPN-RK-SP LPS-RK-SP FRN-R FRS-R KTU KTN-R KTS-R JJN JJS JKS SC LP-CC FNQ-R KTK-R 2:1 2:1 4:1 2:1 2:1 2:1 2:1 2:1 2:1 6014000 A Timedelay Timedelay Time-delay Low-Peak (L) Limitron (L) CUBEFuse (CF2) Low-Peak (J) Low-Peak (RK1) Bussmann fuse symbol KRP-C_SP KLU TCF LPJ-SP KRP-C-SP 2:1 2.5:1 2:1 Fuse type Trade name (fuse class) Upstream / lineside fuse 0-600 A 6016000 A 1-100 A 0-30 A 601 to 6000 A Timedelay Low-Peak (L) 601 to 4000 A Timedelay Limitron (L) KLU 2:1 2:1 2:1 2:1 2:1 4:1 2:1 2:1 2:1 2:1 2:1 2:1 0 to 600 A Dualelement Low-Peak (RK1) LPN-RK-SP LPS-RK-SP — — 2:1 2:1 2:1 8:1 — 3:1 3:1 3:1 4:1 2:1 0 to 600 A Dualelement Low-Peak (J) LPJ-SP — — 2:1 2:1 2:1 8:1 — 3:1 3:1 3:1 4:1 2:1 0 to 100 A Dualelement CUBEFuse (CF2) TCF — — 2:1 2:1 2:1 8:1 — 3:1 3:1 3:1 4:1 2:1 0 to 600 A Dualelement Fusetron (RK5) FRN-R FRS-R — — 1.5:1 1.5:1 1.5:1 2:1 — 1.5:1 1.5:1 1.5:1 1.5:1 2:1 601 to 6000 A Fastacting Limitron (L) KTU 2:1 2.5:1 3:1 3:1 3:1 6:1 2:1 2:1 2:1 2:1 2:1 2:1 0 to 600 A Fastacting Limitron (RK1) KTN-R KTS-R — — 3:1 3:1 3:1 8:1 — 3:1 3:1 3:1 4:1 — 0 to 1200 A Fastacting Limitron (T) JJN JJS — — 3:1 3:1 3:1 8:1 — 3:1 3:1 3:1 4:1 — 0 to 600 A Fastacting Limitron (J) JKS — — 3:1 3:1 3:1 8:1 — 3:1 3:1 3:1 4:1 — 0 to 60 A Timedelay SC (G) SC — — 3:1 3:1 3:1 4:1 — 2:1 2:1 2:1 2:1 — General notes: Ratios given in this table apply to only Bussmann fuses. When fuses are within the same case size, consult Bussmann. 1. Where applicable, ratios are valid for indicating and non-indicating versions of the same fuse. At some values of fault current, specified ratios may be lowered to permit closer fuse sizing. Consult Bussmann. 2. Time-delay Class CF TCF CUBEFuse OCPDs are 1 to 100 A Class J performance; dimensions and construction are a unique, finger-safe design. 16-4 BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse and fuse block cross reference, and index — 16 Low voltage, branch circuit fuse types and classes The NEC defines the branch circuit OCPD as capable of providing protection for service, feeder and branch circuits, and equipment over the full range of overcurrents between its rated current and its interrupting rating. They’re also the only OCPDs the NEC permits to be installed in a building’s electrical system. The definition found in Article 100 is as follows: “Overcurrent Protective Device, Branch Circuit. A device capable of providing protection for service, feeder, and branch-circuits and equipment over the full-range of overcurrents between its rated current and its interrupting rating. Such devices are provided with interrupting ratings appropriate for the intended use but no less than 5,000 amperes.” Per this definition, branch circuit OCPDs are suitable to protect branch or feeder circuits and service conductors at any point in the electrical system, and must be capable of protecting against the full range of overcurrents, including overloads and faults. In addition, the OCPD must have an interrupting rating sufficient for the application per NEC 110.9. Branch circuit OCPDs meet common, minimum standard requirements for spacing and operating time-current characteristics defined by UL. For example, by using Class J fuses and equipment, only Class J fuses can be installed. This ensures the voltage rating is always 600 V (whether the system is 120, 208, 480, or 575 V), the interrupting rating is at least 200 kA, and the fault current protection provided by its current-limiting, let-through characteristics. If the fuse needs replacing, only a Class J fuse can be installed. Class R fuse rejection clips (restriction on the ferrule or notch on the blade) that will only accept Class R fuses. Class R rejection ferrule Class R rejection blade Common current-limiting Bussmann series fuses Device type UL 248 branch circuit fuses Acceptable devices Class CC Class CF Class G Class H(K) Class J Class L Class RK1 Class RK5 Class T Plug fuses Bussmann series fuses LP-CC, FNQ-R, KTK-R TCF, FCF SC NON, NOS LPJ-, JKS, DFJ KRP-C, KLU, KTU LPN-RK, LPS-RK, KTN-R, KTS-R FRN-R, FRS-R JJN, JJS W, T, TL, S, SL The UL 248 fuse standards cover distinct low-voltage (600 volts or less) fuse classes. Of these, modern current-limiting fuse Classes CC, CF, G, J, L, R and T are the most important. The branch circuit current-limiting fuses’ rejection feature helps ensure electrical system safety over its life because it prevents installing other fuse types or larger case sizes. Thus, fuses that cannot provide a comparable minimum protection level for critical ratings and performance cannot be inadvertently installed. FRN-R — Class RK5, 250 V, 200 kA IR up to 600 A LPN-RK — Class RK1, 250 V, 300 kA IR up to 600 A FRS-R — Class RK5, 600 V, 200 kA IR up to 600 A LPS-RK — Class RK1, 600 V, 300 kA IR up to 600 A This is inherent in all current-limiting fuse classes. Each fuse class must meet: • Maximum let-through limits (Ip and I2t) during fault conditions • Minimum voltage ratings • Minimum 200 kA interrupting ratings for Class CC, CF, J, L, R and T • Physical rejection of • Different fuse classes and case sizes* • Non current-limiting fuses LPJ — Class J, 600 V, 300 kA IR up to 600 A LP-CC, FRQ-R, KTK-R — Class CC, 600 V, 200 kA IR up to 30 A JJN — Class T, 300 V, 200 kA IR up to 1200 A JJS — Class T, 600 V, 200 kA IR up to 800 A * Branch circuit fuse blocks and holders are made to hold a fuse class case size that corresponds to a particular amp range. This prevents fuses from the same class with a larger case size from being installed and helps prevent overfusing. There are instances where it is desirable to install a class fuse with a smaller case size than the block or holder. For these situations, it is permitted to use fuse reducers. These product standards ensure branch circuit fuses provide specific, minimum circuit protection when current-limiting fuses and equipment are used. A given fuse class will ensure the voltage and interrupting rating, and degree of current limitation for the electrical system’s life. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 16-5 Cross reference and index The table below contains the acceptable fuses that can be used for branch circuit protection. 16 — Fuse and fuse block cross reference, and index Glossary of common electrical terms Class T fuse — An industry class of 300 V and 600 V fuses in ratings electrons in an electrical circuit. An amp is the amount of current that will flow through a resistance of one ohm under a pressure of one volt. from 1 through 1200 amps (300 V) and 1 through 800 amps (600 V). They are physically very small and can be applied where space is at a premium. They are fast-acting fuses, with an interrupting rating of 200 kA RMS. Amp rating — The current-carrying capacity of a fuse. When a fuse is Classes of fuses — The industry has developed basic physical Ampere (amp) — The measurement of intensity of rate of flow of subjected to a current above its amp rating, it will open the circuit after a predetermined period of time. Amp squared seconds, l2t —The measure of heat energy developed within a circuit during the fuse’s clearing. It can be expressed as “Melting I2t”, “Arcing I2t” or the sum of them as “Clearing l2t”. “l” stands for effective let-through current (RMS), which is squared, and “t” stands for time of opening, in seconds. Arcing time — The amount of time from the instant the fuse link has melted until the overcurrent is interrupted, or cleared. Breaking capacity — (See Interrupting rating) Cartridge fuse — A fuse consisting of a current responsive element inside a fuse tube with terminals on both ends. Class CC fuse — 600 V, 200 kA amp interrupting rating, branch circuit fuses with overall dimensions of 13/32” x 1-1/2”. Their design incorporates a rejection feature that allows them to be inserted into rejection fuse holders and fuse blocks that reject all lower voltage, lower interrupting rating 13/32” x 1-1/2” fuses. They are available from 1/10 through 30 amps. Class CF fuse — A finger-safe UL Listed branch circuit rated fuse. Available in time-delay or fast-acting versions, the Class CF fuse has Class J electrical performance and is available in ratings from 1 to 100 A in 30, 60 and 100 A case sizes. Class G fuse — A size rejecting branch circuit fuse in ratings from 1/2 through 20 amps (600 Vac) and 25 through 60 amps (480 Vac) with a 100 kA interrupting rating. The size rejecting feature helps to eliminate overfusing. The fuse diameter is 13/32” while the length varies from 1-5/16” to 2-1/4”. specifications and electrical performance requirements for fuses with voltage ratings of 600 V or less. These are known as standards. If a type of fuse meets the requirements of a standard, it can fall into that class. Typical UL branch circuit fuse classes are CC, CF, G, H, J, K, L, RK1, RK5 and T. Clearing time — The total time between the beginning of the overcurrent and the final opening of the circuit at rated voltage by an overcurrent protective device. Clearing time is the total of the melting time and the arcing time. Current limitation — A fuse operation relating to short-circuits only. When a fuse operates in its current-limiting range, it will clear a shortcircuit in less than 1/2 cycle. Also, it will limit the instantaneous peak letthrough current to a value substantially less than that obtainable in the same circuit if that fuse were replaced with a solid conductor of equal impedance. Dual-element fuse — A fuse with a special design that utilizes two individual-elements in series inside the fuse tube. One element, the spring actuated trigger assembly, operates on overloads up to 5 - 6 times the fuse current rating. The other element, the short-circuit section, operates on short-circuits up to its interrupting rating. Electrical load — The part of the electrical system that actually uses the energy or does the work required. Fast-acting fuse — A fuse that opens on overload and short-circuits very quickly. This type of fuse is not designed to withstand temporary overload currents associated with some electrical loads, when sized near the full load current of the circuit. Fault current — Fault currents can be short-circuit currents, ground fault currents or arcing fault currents. Class H fuse — 250 V and 600 V, 10 kA interrupting rating branch Fuse — An overcurrent protective device with a fusible link that operates and opens the circuit on an overcurrent condition. Class J fuse — These rejection style fuses are rated to interrupt a High speed fuse — A fuse with no intentional time-delay in the overload range and designed to open as quickly as possible in the shortcircuit range. These fuses are often used to protect solid-state devices. circuit fuses that may be renewable or non-renewable. These are available in ratings from 70 through 600 amps. minimum of 200 kA AC. They are labeled as “current-limiting”, are rated for 600 Vac and are not interchangeable with other classes. They are available from 1 through 600 amps. Class K fuses — These are fuses listed as K-1, K-5, or K-9 fuses. Each subclass has designated I2t and lp maximums. These are dimensionally the same as Class H fuses, and they can have interrupting ratings of 50 kA, 100 kA, or 200 kA. While these fuses are current-limiting, they are not marked “current-limiting” on their label since they do not have a rejection feature. Class L fuse — These fuses are rated for 601 through 6000 amps, and are rated to interrupt a minimum of 200 kA AC. They are labeled “currentlimiting” and are rated for 600 Vac. They are intended to be bolted into their mountings and are not normally used in clips. Some Class L fuses have designed-in time-delay features for all purpose use. Class R fuse — These are high performance fuses rated 1/10 through 600 amps in 250 V and 600 V ratings. All are marked “current-limiting” on their label and all have a minimum of 200 kA interrupting rating. They have identical outline dimensions with the Class H fuses but have a rejection feature that prevents the user from mounting a fuse of lesser capabilities (lower interrupting capacity) when used with special Class R Clips. Class R fuses will fit into either rejection or non-rejection clips. 16-6 Inductive load — An electrical load which pulls a large amount of current – an inrush current – when first energized. After a few cycles or seconds, the current “settles down” to the full-load running current. Interrupting rating — The rating which defines a fuse’s ability to safely interrupt and clear short-circuits. This rating is much greater than the amp rating of a fuse. The NEC defines interrupting rating as “The highest current at rated voltage that an overcurrent protective device is intended to interrupt under standard test conditions.” Melting time — The amount of time required to melt the fuse link during a specified overcurrent. (See arcing time and clearing time.) “NEC” Dimensions — These are dimensions once referenced in the NEC. They are common to Class H and K fuses and provide interchangeability between manufacturers for fuses and fusible equipment of given amp and voltage ratings. Ohm — The unit of measure for electric resistance. An ohm is the amount of resistance that will allow one amp to flow under a pressure of one volt. BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries Fuse and fuse block cross reference, and index — 16 Ohm’s Law — The relationship between voltage, current, and resistance, expressed by the equation E = IR, where E is the voltage in volts, I is the current in amps, and R is the resistance in ohms. One time fuse — Generic term used to describe a Class H nonrenewable cartridge fuse, with a single-element. Overcurrent — Any current in excess of the rated current of equipment or the ampacity of a conductor. It may result from overload, short-circuit or ground fault. (Ref. NEC Article 100.) Overload — Operation of equipment in excess of normal, full load rating, or of a conductor in excess of rated ampacity that, when it persists for a sufficient length of time, would cause damage or dangerous overheating. A fault, such as a short-circuit or ground fault, is not an overload. (Ref. NEC Article 100.) Peak let-through current, lp — The instantaneous value of peak current let-through by a current-limiting fuse, when it operates in its currentlimiting range. Renewable fuse (600 V and below) — A fuse in which the element, typically a zinc link, may be replaced after the fuse has opened, and then reused. Renewable fuses are made to Class H standards. Resistive load — An electrical load which is characteristic of not having any significant inrush current. When a resistive load is energized, the current rises instantly to its steady-state value, without first rising to a higher value. RMS current — The RMS (root-mean-square) value of any periodic current is equal to the value of the direct current which, flowing through a resistance, produces the same heating affect in the resistance as the periodic current does. Short-circuit current rating (SCCR) — This term applies to components (single devices) and assemblies (equipment). For the component, it is the maximum fault current it can sustain without the occurrence of excessive damage. For equipment, it is the assembly’s rating, generally limited by the lowest component SCCR in the circuit as determined by an approved method such as UL 508A, Supplement SB. Short-circuit withstand — The maximum current that an unprotected electrical component can sustain for a specified period of time without the occurrence of extensive damage. Typically applies to devices or components that do not have a marked short-circuit current rating, such as conductors, transfer switches or semiconductor devices. Single-phasing — The condition that occurs when one phase of a three-phase system opens, either in a low voltage (secondary) or high voltage (primary) distribution system. Primary or secondary singlephasing can be caused by any number of events. This condition results in unbalanced currents in polyphase motors and unless protective measures are taken, may cause overheating and failure. Threshold current — The symmetrical RMS (root mean square) available current at the threshold of the current-limiting range, where the fuse becomes current-limiting when tested to the industry standard. This value can be read off a peak let-through chart where the fuse curve intersects the A—B line. A threshold ratio is the relationship of the threshold current to the fuse’s continuous current rating. Time-delay fuse — A fuse with a built-in delay that allows temporary and harmless inrush currents to pass without opening, but is so designed to open on sustained overloads and short-circuits. Voltage rating — The maximum open circuit voltage in which a fuse can be used, yet safely interrupt an overcurrent. Exceeding the voltage rating of a fuse impairs its ability to clear an overload or short-circuit safely. Semiconductor fuse — Fuses used to protect solid-state devices. See “high speed fuse.” Short-circuit — Can be classified as an overcurrent which exceeds the normal full load current of a circuit by a factor many times (tens, hundreds or thousands greater). Also characteristic of this type of overcurrent is that it leaves the normal current carrying path of the circuit – it takes a “short cut” around the load and back to the source. To find Amps when kVA is known Amps when horsepower is known Amps when kilowatts are known Kilowatts Kilovolt-amps Horsepower Watts Single-phase kVA x 1000 E Hp x 746 E x % eff. x pf kW x 1000 E x pf I x E x pf 1000 IxE 1000 I x E % eff. x pf 746 E x I x pf Energy efficiency Power factor (pf) Power consumed Apparent power = Two-phase kVA x 1000 Ex2 Hp x 746 E x 2 x % eff. x pf kW x 1000 E x 2 pf I x E x 2 x pf 1000 IxEx2 1000 I x E x 2 x % eff. x pf 746 I x E x 2 x pf Load horsepower x 746 Load input kVA x 1000 W or VA Three-phase kVA x 1000 E x 1.73 Hp x 746 E x 1.73 x % eff. x pf kW x 1000 E x 1.73 x pf I x E x 1.73 x pf 1000 I x E x 1.73 1000 I x E x 1.73 x % eff. x pf 746 I x E x 1.73 x pf kW kVA Direct current Not applicable Hp x 746 E x % eff. kW x 1000 E IxE 1000 Not applicable I x E x % eff. 746 ExI = cosØ Where: I = Amps, E = Volts, Hp = Horsepower, kVA = Kilovolt-amps, kW = Kilowatts, pf = Power factor, % eff. = Percent efficiency BUSSMANN SERIES FULL LINE CATALOG 1007 — OCTOBER 2018 Eaton.com/bussmannseries 16-7 Cross reference and index Electrical formulas 16 — Fuse and fuse block cross reference, and index FuseFinder fuse and fuse block cross reference Eaton, the leader in circuit protection, power management and electrical safety offers an extensive selection of Bussmann series fuses and fuse blocks to meet your overcurrent protection needs. If you need to find a replacement to another manufacturer's glass tube, low voltage branch and supplemental or high speed fuse, or fuse block or holder, use this quick cross reference FuseFinder to identify the Bussmann series replacement. If you cannot find a product cross, more extensive listings are available online at Eaton.com/bussmannseries/FuseFinder. Or email our Application Engineers at FuseTech@Eaton.com. Fuse cross reference Competitor 0481(amp) 211(amp) 212(amp) 213(amp) 215(amp) 216(amp) 217(amp) 218(amp) 221(amp) 226(amp) 227(amp) 228(amp) 230(amp) 235(amp) 236(amp) 238(amp) 239(amp) 257(amp) 297(amp) [auto fuse] 299(amp) 2AG220 2AG230 301(amp) 303(amp) 307(amp) 311(amp) 312(amp) 313(amp) 314(amp) 315(amp) 318(amp) 322(amp) 323(amp) 324(amp) 325(amp) 326(amp) Bussmann series GMT-(amp)A GDC-(amp) GDB-(amp) GDC-(amp) S505-(amp) GDA-(amp) GDB-(amp) GDC-(amp) S505-V-(amp) GDA-V-(amp) GDB-V-(amp) GDC-V-(amp) C515-(amp) GMA-(amp) GMA-V-(amp) GMD-V-(amp) GMD-(amp) ATC-(amp) ATM-(amp) MAX-(amp) C517-(amp) C515-(amp) AGA-(amp) AGW-(amp) SFE-(amp) AGC-(amp) AGC-(amp) MDL-(amp) ABC-(amp) MDL-V-(amp) AGC-V-(amp) GBB-(amp) MDA-(amp) ABC-V-(amp) MDA-V-(amp) MDA-(amp) Competitor 413(amp) 414(amp) 417(amp) 418(amp) 429(amp) 431(amp) 5140(amp) 5170(amp) 523(amp) 5HF(amp) 5HFP(amp) 5HT(amp) 5MF(amp) 5MFP(amp) 5SF(amp) 5ST(amp) 6J(amp)X 6R(amp)D 702(amp) 703(amp) 81200(amp)ST A70P(amp)-1 or Type 1 A70P(amp)-4 or Type 4 A70Q(amp)-4 or Type 4 A70QS(amp)-14F A70QS(amp)-22F A70QS [35-200]-4 A70QS [225-400]-4 or 4K A70QS [450-600]-4K A70QS [700-800]-4 A50P(amp)-1 A50P(amp)-4 A50QS(amp)-4 or Type 4 A30QS(amp)-1 or Type 1 A30QS [35-700]-4 or Type 4 A30QS [1000-1200]-128 Bussmann series MDM-(amp) ABS-(amp) ABS-(amp) TR/3216FF-(amp) 3216FF(amp) 0603FA(amp) BAF-(amp) AGU-(amp) FNM-(amp) GDA-(amp) GDA-V-(amp) S505-(amp)A GMA-(amp) GMA-V-(amp) GDB-(amp) GDC-(amp) KTK-(amp) LPS-RK-(amp)SP HVJ-(amp) HVL-(amp) CBS-(amp) FWP-(amp)A14F FWP-(amp)A orB FWP-(amp)A or B FWP-(amp)A14F FWP-(amp)A22F FWP-(amp)A or B FWP-(amp)A or B FWP-(amp)A or B FWP-(amp)A or B FWH-(amp)A14F FWH-(amp)A or B FWH-(amp)A or B FWX-(amp)A14F FWX-(amp)A FWX-(amp)AH Bussmann series KTK-R(amp) FNQ-(amp) FNQ-R-(amp) ABC-(amp) GDB-(amp) GDC-(amp) MDL-(amp) AGC-(amp) AGX-(amp) BAF-(amp) BAN-(amp) BBS-(amp) GDA-(amp) HBO-(amp) ACK-(amp) ACL-(amp) KGJ-E-(amp) KGJ-(amp) LP-CC(amp) CDN(amp)†† CDS(amp)††† ANL-(amp) ANN-(amp) PV-(amp)A10F (amp)FC (amp)FE (amp)FET (amp)FM (amp)FMM (amp)LCT (amp)LET (amp)LMMT (amp)LMT FWJ-(amp)A14F FWJ-(amp) FWA-(amp)A FWA-(amp)A21F FWA-(amp)B LPN-RK(amp)SP KTN-R(amp) JJN(amp) KRP-CL-(amp) KRP-C-(amp)SP KLU [601-4000] KLU(amp) JKS(amp) LPS-RK(amp)SP Competitor ATMR(amp) ATQ(amp) ATQR(amp) BBC(amp) BDB(amp) BDC(amp) BDL(amp) BGC(amp) BGX(amp) BLF(amp) BLN(amp) BLS(amp) BMA(amp) CBO(amp) [4-160A] CCK(amp) [1-300A] CCL(amp) [30-100A] CCLB(amp) [20-250A] CCLW(amp) [1-300A] CCMR [1-30A Only] CDNC(amp) CDSC(amp) CNL(amp) CNN(amp) DCT [1-15A] E(amp)FC E(amp)FE E(amp)FET E(amp)FM E(amp)FMM E(amp)LCT [6-20A] E(amp)LET [25-180A] E(amp)LMMT [315-900A] E(amp)LMT [160-450A] E100SF(amp) [20-30A] E100S(amp) [40-2000A] E15S(amp) [35-3000A] E15SF(amp) [5, 10, 15, 20, 25, 30A] E25S(amp) [1000-2500A] E25S(amp) [35-800A] E25SFX(amp) [5-30A] E50S(amp) E50SF(amp) [5-30A] E70S(amp) ECK(amp) [1-300A] ECL(amp) [30-100A] ECN(amp) ECNR(amp) ECS(amp) 334(amp) GLD-(amp) A15QS [1-30]-2 FWA-(amp)A10F 336(amp) 361(amp) 362(amp) 3770(amp) 3780(amp) 3785(amp) 3AB(amp) 3ABP(amp) 3AG(amp) 3AG311(amp) 3AG312(amp) GBA-(amp) AGX-(amp) AGX-(amp) SL-(amp) S-(amp) T-(amp) ABC-(amp) AGC-V-(amp) AGC-(amp) AGC-(amp) AGC-(amp) A15QS [35-60]-1 A15QS [70-400]-4 A2D(amp)R A2K(amp) A3T(amp) A4BQ [225-600] A4BQ [601-6000] A4BT [601-4000] A4BY(amp) A4J(amp) A6D(amp)R 3AG313(amp) MDL-(amp) 3AG315(amp) 3AG318(amp) 3SB(amp) 3SBP(amp) 401(amp) 411(amp) MDL-V-(amp) AGC-V-(amp) MDL-(amp) MDL-V-(amp) GMT-(amp)A ABS-(amp) A6K(amp) KTS-R(amp) ECSR(amp) FRS-R-(amp) A6T(amp) AG(amp) AJT(amp) AM10/(amp) AOK(amp) ATDR(amp) JJS(amp) SC(amp) LPJ(amp)SP LP-CC-(amp) ALS-(amp) LP-CC-(amp) ELR(amp) ENLE(amp) ENNE(amp) ERN(amp) ERS(amp) ESA(amp) GLR-(amp) ANL-(amp) ANN-(amp) REN-(amp)* RES-(amp)** S-(amp) 412(amp) ABS-(amp) ATM(amp) KLM(amp) FA(amp) SA(amp) FWA-(amp)A10F FWX-(amp)AH FWX-(amp)A FWX-(amp)14F FWH-(amp) FWH-(amp)14F FWP-(amp) ACK-(amp) ACL-(amp) FRN-R-(amp) FRN-R-(amp) FRS-R-(amp) * >60 A use FRN-R (250 V) ** >60 A use FRS-R (600 V) † >12 A use TL †† 60 A use FRS-R (600 V) † >12 A use TL. ††
BK/HLRGMF-1.6 价格&库存
很抱歉,暂时无法提供与“BK/HLRGMF-1.6”相匹配的价格&库存,您可以联系我们找货
