BP/HHA-RP
BP/HHA-RP
    EATON(伊顿)
    FUSEHOLDRBLADE32V40AINLINE
BP/HHA-RP 数据手册
Consumer Aftermarket Product Catalog Fuse Holders and Taps Consumer Aftermarket Catalog Fuse Holders & Taps Cooper Bussmann offers a complete line of fuse holders to install either blade-type or glass tube fuses. Choose water resistant and/or splash-proof versions for extra protection in special applications. Four types of connectors are available to meet the needs of technicians and do-it-yourselfers: • Wire Loop. To install, simply cut the wire, strip ends and attach each end to the circuit. Requires the use of additional connectors. • Crimp-On. Strip wire and insert into fuse holder. Crimp the connections tightly, and you're done. No additional hardware needed. • Self-Stripping. Easy to install — simply locate fuse holder at a convenient spot along the wire. Snap fuse holder closed around wire to pierce insulation automatically. • Quick-Connect. Attach fully insulated female push-on terminal onto the 1 /4” quick-connect terminals. When selecting a fuse holder, always match the device to the wire being fused. Using an undersized fuse holder will increase electrical resistance in the circuit and reduce performance. NOTE: Never install a fuse with a larger amp rating than specified for the holder. Blade-Type Fuse Holders HHU In-Line Fuse Holders for ATM Fuses Blister Tri-Lingual Maximum Pack Blister Volts/Amps Part No. HHL HHM HHU ATM-FHID* X X X X X 32V/20A 32V/30A 32V/30A 32V/20A Leadwire Description 2x4”/#16 2x4”/#12 2x4”/#12 2x4”/#16 Holder with cover Holder with cover Water-resistant holder Illuminating holder HHL HHM * For use with regular ATM fuses. For details on the easyID™ line of illuminating ATM blade fuses, see page 9. ATM-FHID In-Line Fuse Holders for ATC Fuses Part No. HHC HHD HHD-30 HHF HHG HHR HHS ATC-FHID* Blister Tri-Lingual Maximum Pack Blister Volts/Amps X X X X X X X X X X X 32V/20A 32V/30A 32V/30A 32V/20A 32V/30A 32V/30A 32V/20A 32V/20A HHC HHD HHF Leadwire Description 2x4”/#16 2x4”/#12 2x4”/#12 2x4”/#16 2x4”/#12 2x5”/#12 #18 to #14 2x6”/#16 Yellow water-resistant holder Heavy-duty fuse holder Holder with ATC-30A fuse Holder with protective cover Heavy-duty holder with cover Heavy-duty water-resistant holder Self-stripping fuse holder Illuminating holder HHR HHG * For use with regular ATC fuses. For details on the easyID™ line of illuminating ATC blade fuses, see page 9. HHS ATC-FHID In-Line Fuse Holders for Maxi Fuses Part No. Volts/Amps Leadwire Description HHX Fuse holder with cover 32V/20-60A 2x5”/#6 HHX For product information and data sheets, visit www.cooperbussmann.com 17 Consumer Aftermarket Catalog Fuse Holders & Taps Fuse Taps For ATM and ATC Fuses Tap into an existing circuit to power a mobile phone, stereo components, etc. with Cooper Bussmann fuse tap accessories. Part No. Description BP/ATM-TAP 5-Count: Taps into existing ATM fuse for additional non-fused circuit, includes crimp-on connector that attaches easily to the power lead for electronic gear. 5-Count: Taps into existing ATC fuse by fitting over the leg for additional non-fused circuit, includes crimp-on connector. Converts ATM fuse circuit into two fusible circuits. Inserts into ATM fuse block, added circuit 10A max. Converts an ATC fuse circuit into two fusible circuits. Inserts into ATC fuse block, added circuit 10A max. BP/ATC-TAP BP/HHH BP/HHA BP/ATM-TAP BP/ATC-TAP BP/HHH BP/HHA Glass Tube In-Line Holders For 1/4" Diameter Fuses Blister TriPart No. Pack Lingual Fuse/Size Ratings Leads/ Volts/Amps Terminals HFA HFB HHB HHK HHN HMJ HMK HRH HRI HRJ /4” x 11/4” 250V/20A /4” x 11/4” 32V/30A 1 /4” x 7/8” to 11/4” 32V/30A 1 /4” x 5/8” to 11/4” & SFE-20 32V/20A 1 /4” x 11/4” 32V/30A For SFE-20 (included) 32V/20A 1 /4” x 11/4” & SFE-20 32V/30A For SFE-9 (included) 32V/9A For SFE-14 (included) 32V/14A For SFE-20 (included) 32V/20A Crimp #12 to 16 wire Crimp #12 to 18 wire Crimp #12 to 16 wire #14 leadwire/yellow #12 leadwire/yellow 8" of #14 leadwire/bk #12 leadwire/bk 19" of #14 leadwire 19" of #14 leadwire/bk 19" of #14 leadwire/bk /4” dia. x 7/8” to 11/4” #14 leadwire/bk 1 HRK X X X X X X X X X X X X X HHK 1 32V/15A 1 HMJ HHN Description Feature Water-resistant-black body Water-resistant-yellow body Universal-yellow body Universal nylon, twist lock, no fuse-black body Nylon heavy-duty w/ AGC-30 fuse-white body With fuse and wire loop leads-black body No fuse, wire loop leads-black body With fuse and wire loop leads-black body With fuse and wire loop leads-gray body With fuse and wire loop leads-black body Universal with wire loop leads and springs for different fuse lengths-black body HRI HMK HRJ HFB HFA HHB HRK Panel-Mount Holders For 1/4" x 11/4" Fuses Part No. HKP HKP-HH HTB-26I HTB-38I HTB-68I HTB-88I HKP 18 Blister Max. Panel Pack Thickness X X 0.3” 0.3" 0.3" 0.3" 0.3" 0.125" Knob Type Knob Knob Knob Screwdriver/slotted Knob Knob HKP-HH Description/Mounting Terminals Ratings Volts/Amps High-profile cover knob, rear hexnut High-profile cover knob, rear hexnut Low-profile cover knob, rear hexnut Low-profile cover knob, rear hexnut Low-profile cover knob, front hexnut Low-profile cover knob, through-hole snap Solder terminals /4” quick-connect terminals In-line 1/4” quick-connect terminals Right angle 1/4” quick-connect terminals Right angle 1/4” quick-connect terminals Right angle 1/4” quick-connect terminals 250V/30A 250V/15A 250V/20A 250V/20A 250V/20A 250V/20A HTB-26I 1 HTB-38I HTB-68I For product information and data sheets, visit www.cooperbussmann.com HTB-88I
BP/HHA-RP 价格&库存
很抱歉,暂时无法提供与“BP/HHA-RP”相匹配的价格&库存,您可以联系我们找货
