CHM1DIU
CHM1DIU
    EATON(伊顿)
    CHM1DIU
CHM1DIU 数据手册
Effective October 2017 Supersedes August 2016 Technical Data 10430 BUSSMANN SERIES CH Modular, IP20 finger-safe DIN-Rail holders for Class CC, midget and PV fuses Specifications: 2011/65/EU Ratings • • Volts • 600 V (or less) UL • 690 V (or less) IEC • 1000 Vdc (or less) photovoltaic (PV) Amps • 30 A UL • • 32 A IEC Short-Circuit Current Rating (SCCR) • 33 kA photovoltaic • 200 kA RMS Sym. (CHCC, CHM*) * CHM SCCR is fuse interrupting rating dependent. Agency information Catalog symbol: • CHCC_ (Class CC) • CHM_ (UL® midget/IEC 10x38) • CHPV_ (13/32 x 1-1/2 and 10x38 photovoltaic) Description: Eaton’s Bussmann™ series CH DIN-Rail fuse holders are for UL Class CC and midget fuses, and IEC 10x38 fuses. They are available with and without indication in 1-, 2- and 3-pole IP20 finger-safe versions. A variety of accessories extends their application flexibility and they may be ganged together to meet specific application requirements. For other Bussmann series CH fuse holders, please see the following data sheets. Fuse class Class J IEC Fuse size 30 and 60A 8x32mm 14x51mm 22x58mm Data sheet No. 2144 720147 10080 10015 • UL Listed File E14853, Guide IZLT, Recognized IZLT2 • UL Listed to E348242 and Guide IZMR (CHPV) • CSA® File 47235, CHPV and CHM Class 6225-30, CHCC - Class 6225-01 • IEC 60269-2 (CHM, CHPV) • CCC • RoHS compliant Mounting • 35mm DIN-Rail Wire range • 75°C and 90°C Cu • #18 to #4 (0.8mm2 to 21.1mm2) • Solid • Stranded • Fine stranded Terminals • Single or dual conductors • Comb busbar • Torque 30 Lb-In (3.4 N•m) maximum • Terminal screws • Standard phil-slot • Optional hex head (order by adding “-H” suffix to the catalog number, e.g., CHM1DU-H) Flammability • UL 94V0, self-extinguishing Technical Data 10430 CH Modular, IP20 finger-safe DIN-Rail holders for Class CC, midget and PV fuses Effective October 2017 Dimensions - mm (in): Storage and operating temperature • -4°F (-20°C) to 194°F (90°C) indicating • -4°F (-20°C) to 248°F (120°C) non-indicating 61.83 [ 2.434 ] 18.59 [ 0.732 ] Features and benefits: • High SCCR rated, UL Listed Class CC holder with optional open fuse indication for 600 Vac/dc and 48V dc (see catalog number table for details). • Enhanced safety with IP20 finger-safe construction. • UL Recognized midget and IEC 10x38 holders with factory assembled neutral pole option. • Agency ratings up to 1000 Vdc for use with PV fuses. • Available remote PLC indication module. • Wiring flexibility with terminals rated for use with 75°C or 90°C solid, stranded and fine stranded wire, and spade terminals and comb-bus bars. (Use any higher temperature insulations at the 90°C ampacity.) • 42.58 [ 1.676 ] 52.83 [ 2.080 ] 83.19 [ 3.275 ] 70 [ 2.756 ] Complete range of UL Listed and high SCCR rated one- and threephase finger-safe comb-bus bars and power feed lugs. 52.5 [ 2.067 ] 35 [ 1.378 ] Features: Fuse access door accommodates 4mm lockout/tagout device 17.5 [ 0.689 ] IP20 finger-safe construction Optional open fuse indicator Captive phil-slot or optional hex head terminal screw 73.88 [ 2.909 ] Fork lug connection Toolless ganging for multiple poles Toolless 35mm DIN-Rail mounting Wire strip gauge Dual conductor rated box lug clamp 9 [ 0.354 ] 7.0 [ 0.276 ] Gang multiple poles to meet application requirements using kit catalog number JV-L (gangs up to four poles). 2 Eaton.com/bussmannseries Technical Data 10430 CH Modular, IP20 finger-safe DIN-Rail holders for Class CC, midget and PV fuses Effective October 2017 UL midget and IEC 10x38 CHM holder catalog numbers Catalog number† Volts and amps With indication* Without indication CHM1DIU CHM1DU 1 CHM2DIU CHM2DU CHM3DIU CHM3DU CHM4DIU CHM4DU UR, CSA, 2 IEC 60269-2, 3 CCC 4 CHM1DNIU CHM1DNU CHM3DNIU CHM3DNU UL 600 V/30 A Agency marks IEC 690 V/32 A Poles IEC 60269-2 200 kA** RMS 1 + neutral Sym.†† 3 + neutral CHM1DI-48U — UR, CSA, 48 Vdc/30 A 48 Vdc/32 A IEC 60269-2, 1 CCC — CHM1DNXU — CHM1DCIU CHM1DCU 1 CHM2DCIU CHM2DCU 2 CHM3DCIU CHM3DCU CHM4DCIU 600 Vac, 1000 Vdc, 30 A 690V/32 A IEC 60269-2 N/A UR, CSA, IEC 60269-2 CHM4DCU BAF, BAN, FNM, FNQ, FWA, FWC, KLM, KTK, AGU, C10G_, C10M_ N/A 600/690V BAF, BAN, FNM, FNQ, FWA, FWC, 200 kA** KLM, KTK, RMS Sym., AGU, C10G_, 33 kA DC†† C10M_, 3 690 V, 32 A SCCR Recommended Bussmann series fuses 4 1000Vdc PV-(amp)A10F, PV10M-(amp) † Available with optional hex head terminal screws. To order, add “-H” suffix to the desired catalog number. †† SCCR is limited to the interrupting rating of the installed fuse or 200 kA, which ever is less. * All models require 90V minimum for illumination, except CHM1DI-48U that requires 15V minimum. ** SCCR is limited to the interrupting rating of the installed fuse or 200kA, which ever is less. UL Class CC CHCC holder catalog numbers Catalog number† With indication* CHCC1DIU CHCC2DIU CHCC3DIU CHCC1DI-48U Without indication CHCC1DU CHCC2DU CHCC3DU — Volts / amps 600 V/30 A Agency marks UL, CSA, CCC 48 Vdc/30 A Poles 1 2 3 1 SCCR 200 kA RMS Sym. 33 kA DC Recommended Bussmann series fuses LP-CC, FNQ-R, KTK-R † Available with optional hex head terminal screws. To order, add “-H” suffix to the desired catalog number. * All models require 90V minimum for illumination, except CHCC1DI-48U that requires 15V minimum. UL and IEC photovoltaic CHPV holder catalog numbers Catalog number† With indication CHPV1IU Without indication CHPV1U CHPV2IU CHPV2U Volts / amps 1000 Vdc/30 A Agency marks UL, CSA, , UL 4248-18, IEC 60269-1, CCC Poles 1 2 SCCR Recommended Bussmann series fuses 33 kA DC PV-(amp)A10F, PV10M-(amp) † Available with optional hex head terminal screws. To order, add “-H” suffix to the desired catalog number. * All models require 90V minimum for illumination. Eaton.com/bussmannseries 3 Technical Data 10430 CH Modular, IP20 finger-safe DIN-Rail holders for Class CC, midget and PV fuses Effective October 2017 Accessories: Bussmann series CH modular fuse holders can be applied using a variety of accessories that facilitate or simplify installation. 35mm DIN-Rails CH fuse holders • Constructed of high strength stainless steel • Sold in 1 meter lengths • Available in high- or low-profile versions Catalog numbers DRL35MMLO DRL35MMHI Power feed terminals 1- and 3-phase comb busbars Profile Low High Contact safety covers Height 7.5mm 15mm Comb busbars • Easily distribute power in single-or three-phase systems • Flexible cut-to-length busbars do not compromise the finger-safe protection (requires using endcaps) • • 100 kA SCCR when protected by a max 200 A Class J fuse Single-phase busbars rated to 1000 Vdc and 100 A • Three-phase busbars rated to 600 Vac/dc and 100 A • Power feed terminals for single-and three-phase systems Specifications: Single-phase comb busbars Available in 3, 6, 9, 12,15 and 57 pin constructions. Agency information • UL 508, File E195399 Pitch • Three-phase comb busbars 17.8mm Ratings • Volts • 600 Vac/dc max. (three-phase) • 1000 Vdc/600Vac max. (single-phase) • Amps 100 A max. • SCCR • 10 kA (default) • 100 kA (with upstream Class J max 200 A fuses) Available in 6, 9, 12, 15 and 57 pin constructions. 4 Eaton.com/bussmannseries Technical Data 10430 CH Modular, IP20 finger-safe DIN-Rail holders for Class CC, midget and PV fuses Effective October 2017 Comb busbar dimensions - mm: Single-phase A 17.8 2.5 5.5 15.6 5.0 15.0 B Single- and three-phase dimensions - mm Three-phase 21.6 24.9 36.5 13.5 6.0 2.0 Poles 3 6 9 A 35.6 89.0 142.4 B 52 106 160 C — 104 159 12 15 57 195.8 249.2 996.8 208 272 1012 214 266 1009 All 15-pole or fewer comb busbars come with endcaps installed. If a comb busbar will be cutto-length, order additional endcaps to maintain electrical protection. End caps are sold in carton quantities of 50. Order ECAP1P for single-phase and ECAPMP for three phase. 17.8 A C Comb busbar catalog numbers: Catalog number BB1P100M3 BB1P100M6 BB1P100M9 BB1P100M12 BB1P100M15 BB1P100M57 BB3P100M6 BB3P100M9 BB3P100M12 BB3P100M15 BB3P100M57 Phase Voltage Amps Single-phase 1000 Vdc 100 A Three-phase 600 V 100 A Number of pins 3 6 9 12 15 57 pin cuttable 6 9 12 15 57 pin cuttable Endcaps With endcaps assembled. If cut to length, order additional endcaps separately. Without endcaps (order separately) With endcaps assembled. If cut to length, order additional endcaps separately. Without endcaps (order separately) Eaton.com/bussmannseries 5 Technical Data 10430 CH Modular, IP20 finger-safe DIN-Rail holders for Class CC, midget and PV fuses Effective October 2017 Power feed terminals: PWR1PLP 28.5 16.1 21.0 36.1 Single-phase, low profile power feed terminal 12.4 11.0 Ratings • Volts 1000 Vac/dc • Amps 115 A • Wire range 1/0-10 AWG Cu, max torque 50 lb-in (5.6 N•m) • Wire temp. rating 60°C* 3.0 6.0 PWR35MM 35mm2 three-phase power feed terminal for three-phase busbars Ratings • Volts 1000 Vac/dc • Amps 115 A • Wire range 1/0-10 AWG Cu, max torque 50 lb-in (5.6 N•m) • Wire temp. rating 60°C* PWR50MM 12.3 4.0 50mm2 direct feed power terminal 40.0 17.75 Ratings • Volts 1000 Vac/dc • Amps 115 A • Wire range 1-14AWG Cu, max torque 35 lb-in (3.9 N•m) • Wire temp. rating 75°C* 29.8 28.8 17.75 * Higher temperature rated wire may be used with appropriate derating. 6 Eaton.com/bussmannseries 17.75 Technical Data 10430 CH Modular, IP20 finger-safe DIN-Rail holders for Class CC, midget and PV fuses Effective October 2017 Comb busbar safety covers and end caps: FSCVR 71.2 17.8 14.0 3.8 85.2 R 0.5 Spare comb busbar pin safety protection covers (used to cover exposed pins on comb busbars). Sold in quantity of ten strips of five covers each. (FSCVR comes with five covers on a strip. Minimum order is 10 strips or 50 safety covers total.) 4.6 24.2 5.7 23.8 ECAP1P 1.0 1.7 14.0 End cap for single-phase comb busbars. Sold in quantity of fifty. 8.5 1.1 2.1 4.9 ECAPMP 24.0 21.6 End cap for three-phase comb busbars. Sold in quantity of fifty. 9.5 18.6 Accessory catalog numbers Catalog number PWR1PLP PWR35MM PWR50MM ECAP1P ECAPMP FSCVR Description Single-phase low-profile power feed terminal (115 A, 1000 Vac/dc) 35mm2 power feed terminal for three-phase busbar (115 A, 1000 Vac/dc) 50mm2 direct power feed terminal (1000 Vac/dc) Single-phase busbar endcap Three-phase comb busbar end cap Spare comb busbar pin safety protection covers Carton quantity 10 10 10 50 50 10 strips of five covers each, total 50 individual covers Eaton.com/bussmannseries 7 Technical Data 10430 CH Modular, IP20 finger-safe DIN-Rail holders for Class CC, midget and PV fuses Effective October 2017 PLC remote fuse monitor Installation • Mounts on the left side of the fuse holder and mechanically interlocks with the fuse holder switch handle with hardware provided Degree of protection • Finger-safe IP20 Storage and operating temperature • -4°F (-20°C) to 167°F (75°C) Agency information • UL 508 • cULus to CSA Standard 22.2 No.14 PLC programming • The CH-PLC signal line is designed to provide a digital input to a PLC I/O card • Programmable Logic Control program must be written to properly interpret the input signal to the PLC • The PLC program should check for consecutive high signals before taking action on a critical process Packaging The Bussmann series resettable remote fuse monitor permits easy integration with a Programmable Logic Controller (PLC) or other monitoring and control equipment. Signals up to three-phases. Specifications: • Power input: 24 Vdc / 5 mA • Sensing voltage: 600 V/30 mA • Digital output signals • 0 Vdc (low) – fuse is good • 24 Vdc (high) – fuse has opened When the fuse opens, the output signal is sent high and will remain high until the unit is reset. • • Rated impulse voltage • 8 kV The CH-PLC is packaged individually • A single unit monitors up to three phases • Package includes 0.11” (2.8mm) quick connects for power, signal and ground connections To order • Specify catalog number CH-PLC PLC wiring schematic PLC power supply CH-PLC Twisted, shielded pair +24Vdc +24Vdc 0Vdc/Gnd 0Vdc/Gnd Ground shield on one side only Local indication • Two distinct LEDs indicate unit power (green) and open fuse (red) • • • The CH-PLC needs to be powered by the same +24Vdc and ground (0Vdc/Gnd return) terminals that are feeding the PLC input card. If it is not, it may signal improperly. Upon fuse replacement, the actuation of the reset switch will reset the open fuse LED Flammability rating • UL 94V0 Wiring For power, signal and ground connections use shielded twisted pair 22-24 AWG (0.34-0.25 mm2) 300 V rated wire. Minimum circuit voltage • 8 Minimum circuit voltage required across the CH holder is 100 Vac for the remote indication device to operate Eaton.com/bussmannseries Signal output 10mA max. +24Vdc 0Vdc/Gnd PLC input card If feeding multiple CH-PLCs from different power supplies, there must be multiple input cards being powered by those same power supplies as well. Technical Data 10430 CH Modular, IP20 finger-safe DIN-Rail holders for Class CC, midget and PV fuses Effective October 2017 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2017 Eaton All Rights Reserved Printed in USA Publication No. 10430 — BU-MC15033 October 2017 Eaton and Bussmann are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. UL is a registered trademark of the Underwriters Laboratories, Inc. For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Follow us on social media to get the latest product and support information.
CHM1DIU 价格&库存
很抱歉,暂时无法提供与“CHM1DIU”相匹配的价格&库存,您可以联系我们找货
CHM1DIU
    • 1+652.13023
    • 25+642.47596
    库存:27
