15600-04-21
15600-04-21
    EATON(伊顿)
    FUSE BLOCK BLADE 30A PANEL MNT
15600-04-21 数据手册
® Series 15600 ATC Blade-Type Fuse Panels Specifications Input Terminal Rating: #10-32 Threaded studs (100A max). Output Terminal Rating: 30A Max per circuit. Temperature Rating: –20°F (0°C) to 150°F (65°C). Materials: Black thermoplastic. Termination: .250" x .032" quick-connect terminals. Ground terminal pad option available. Input wire size: #4-6 AWG. Output wire size: #12-16 AWG. Torque Rating: 20 in-lbs (2.25Ntm) max. Mounting Torque Rating: 8 in-lbs (0.9Ntm) max. Power Distribution The 15600 ATC® fuse panel is a compact, yet rugged, power distribution module. It is available in a single or dual internal buss electrical configuration featuring an optional ground pad terminal strip. The 15600 fuse panel is surface mounted, uses convenient quick-connect terminals, and is recommended as a supplemental power distribution module. It can be used to accompany main PDMs such as the Cooper Bussmann 31000/32000 Series VEC/DVEC, 15710 Series RTA, and the 1540X Series RFRM. Fuse Panels Options Positions: 4-20 circuits available. Split Power: Single or dual buss options. Dimensions - mm(in) 15600 Series 15602 Series .22" DIA. HOLE WITH .41 x .12 DEEP C'BORE (4X) "L" "L" "C" "C" Series 15600 85.59 (3.37) 26.92 (1.06) 26.92 (1.06") 63.50 (2.50) 15.75 (.62) .250" QC (COPPER ALLOY - TIN PLATED) No. of Fuse 15.75 TYP (.62") 20.32 (.80) 30.98 (1.22) Ground Terminal Base Option (12) .250" QC TERMINALS W/COMMON WIRING STUD, ADD 1.300" TO "L" FOR OVERALL LENGTH 04 06 08 10 12 (15600 -10-20 SHOWN) “C” – .62 1.25 1.87 2.50 15600 “L” 1.84 2.47 3.09 3.75 4.34 (15602-04/08-20 SHOWN) 15602 “L” 2.44 3.06 3.68 4.32 4.94 No. of Fuses 14 16 18 20 “C” 3.12 3.76 4.37 5.00 15600 “L” 4.97 5.59 6.22 6.84 15602 “L” 5.56 6.19 6.81 7.43 Dimensions in inches. Multiply by 25.4 for metric. Part Numbering System No. of Fuses &/or Circuit Breaker Positions Series 0 – Hardware Options Ground Terminal Base 0 – W/O nuts 1 – Nuts shipped bulk 2 – Nuts assembled 0 – None 1 – Include Ground Pad – 04-20 1 5 6 0 2 – 0 – Single Stud, Single Supply Circuit 2 – Double Stud, Split Supply Circuits – Left Side Right Side 04-16 04-16 (max. combination of 20) – Cooper Bussmann Transportation Products t1IPOFt'BYtXXXDPPQFSCVTTNBOODPN 47
15600-04-21 价格&库存
很抱歉,暂时无法提供与“15600-04-21”相匹配的价格&库存,您可以联系我们找货
