Fuseholders for Indicating Fuses
GMT Type
Dimensional Data
Printed Circuit Board Application
Shown With GMT Fuse Installed
Note: Similar Body Dimensions
of All Holders Are Identical.
0.31" Approx.
0.84"
0.84"
(7.7mm)
(21.4mm)
(21.4mm)
0.64"
(16.3mm)
1.02"
0.64"
(16.3mm)
0.13"
1.02"
HLT
(25.9mm)
(25.9mm)
(3.2mm)
0.15"
(3.8mm)
HLS
0.15"
(3.8mm)
HLS-F
HLS-C
0.25"
(6.4mm)
0.13"
(3.2mm)
(6.4mm)
(10.3mm)
0.84"
CATALOG SYMBOL: HLS, HLT, PCT
FUSEHOLDERS FOR GMT TYPE INDICATING FUSES
ELECTRICAL RATING–60V DC, 125V AC
UL RECOGNIZED (GUIDE # IZLT2, FILE E14853)
15AMP (60V DC)
Materials:
Body:
Terminals:
HLT-F
0.08"
(2.0mm)
0.41"
0.25"
HLT-D
(21.3mm)
Wire Wrap Terminal
0.025" x 0.063"
0.64"
(16.3mm)
(0.64mm)
(1.6mm)
0.45"
(11.4mm)
0.11"
Fuse Terminal
Alarm Terminal
PCT-A
(2.8mm)
PCT
Thermosplastic, UL 94V0 flammability rating
Tin-plated bifrucated copper
For use with GMT Type Indicating Fuses
0.19"
(4.8mm)
(6.4mm) x "A" Spaces
Tolerance to be non-accumulative
0.25"
Panel Mounting Data
0.15"(3.8mm) Dia.
0.16"(3.9mm) Dia.
.041"
Multiple Fuseholders with bus bars
Ordering Information–Catalog No.
0.86"
(21.8mm)
(10.4mm)
1.21"
(30.8mm)
0.27"
(6.7mm)
0.25"
(6.4mm)
.09" Dia. Holes
(2.4mm) (3 Holes Per Poles of Fuseholder)
Termination Location
Body Style
HLT
HLS (No flanges)
L
(Left only)
No. of Poles 01 thru 25
(Min. of 2 poles required for bus bars)
Type of bus bars used
B1*, B2, B3,
B4, B5, SL** (Short Leads .135")
ML** (Medium Leads .250")
** Not available with bus bars
B1
(Angle Bar Only)*
B2
("L" Bar Only)
B3
("U" Bar Only)
* Angle Bar mounts on common or center terminals only.
†Minimum of 4 Poles Required.
**SL Version is not available with bus bars.
Bus Bar Position
P1†
(Inside–
Both Sides)
P2
(Outside–
Both Sides)
B4
(Angle & "L" Bars)
R
(Right only)
P3
(Outside–
Right Only)
B
(Both ends)
P4
(Outside–
Left Only)
B5
("L" &"U" Bars)
The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this BIF document are by definition uncontrolled.This bulletin is intended to
clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any
products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
0712
BU-SB12567
Page 1 of 1
Data Sheet 5010
很抱歉,暂时无法提供与“HLS-10-ML”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 96+877.3379796+113.56226
