Technical Data 2157
Effective August 2018
Supersedes February 2018
BUSSMANN
SERIES
HPV single-pole, non-serviceable in-line PV fuse holder
and fuse assembly: 1-20 A, 1000 Vdc / 4 A, 1500 Vdc
Boot material
UL 5VA flammability resistant rated elastomer.
UV resistant to UL F1 suitable for outdoor use.
Operating and storage temperature range
Catalog symbols:
2011/65/EU
HPV-DV-(amp)A (1-20 A, 1000 Vdc)
HPV-D15V-4A (4 A, 1500 Vdc)
Description:
Eaton’s Bussmann™ series of HPV single-pole,
non-serviceable photovoltaic in-line fuse holders/
assemblies are available in an IP67 dust-tight and
temporary water immersion resistant insulating
boot for use in photovoltaic wire harnesses.
Final assembly of conductors (customer supplied),
insulating boots and labeling to be performed by
customer following the directions contained in
assembly guide no. 3A1963.
Ratings
Volts
1000 Vdc
1500 Vdc (HPV-D15V-4A only)
Sta-Kon™ terminal crimping tool, catalog
#ERG4002
Multi-Contact assembly tool, catalog #PV-RWZ
with PV-KOI+II and PV-KOIII tapered spindles
Packing
Bulk packed in cartons, 180 fuse assemblies per
carton. Carton weight 19.3 lbs (8.7 kg)
Fuse assemblies poly bagged with PV fuse
element, two insulating boots (lineside and
loadside), and one pressure sensitive label to be
applied on outside after complete assembly to the
wire harness.
Catalog numbers (amps) and fuse elements*
HPV catalog no.
Fuse element cat. no.
Amps
1000 Vdc
HPV-DV-2A
PV-2A10F-CT
HPV-DV-2.5A
PV-2.5A10F-CT
HPV-DV-3A
PV-3A10F-CT
HPV-DV-3.5A
PV-3.5A10F-CT
HPV-DV-4A
PV-4A10F-CT
4
UL Listed to 4248-1 and 4248-19.
File E348242,
HPV-DV-5A
PV-5A10F-CT
5
CSA® Component Acceptance, Class 6225 30,
File 47235
HPV-DV-6A
PV-6A10F-CT
6
HPV-DV-8A
PV-8A10F-CT
8
HPV-DV-10A
PV-10A10F-CT
10
HPV-DV-12A
PV-12A10F-CT
12
HPV-DV-15A
PV-15A10F-CT
15
HPV-DV-20A
PV-20A10F-CT
P15V-4A10F-CT
4
Amps
1-20 A
IR 33 kA
CE, RoHS compliant, IP20 finger-safe, IP67
Terminals/conductors
PV-1A10F-CT
Agency information
Recommended tools
HPV-DV-1A
-40°C to +90°C
Crimp connection for single, stranded
75°C/90°C Cu 12-10 AWG PV wire
1
2
2.5
3
3.5
1500 Vdc
HPV-D15V-4A
For fuse specifications and derating curves see data
sheet no. 10121 at Eaton.com/bussmannseries.
For assistance with design, installation or
assembly related to this product, call Application
Engineering at 855-287-7626, Monday-Friday,
7:00 a.m. to 5:00 p.m. Central Time, or email
FuseTech@Eaton.com.
Technical Data 2157
HPV single-pole, non-serviceable in-line PV fuse holder and fuse assembly:
Dimensions - mm:
Inner insulating boot
11.1±0.7
29.0±1.0
13.1±1.0
56.9±1.0
Outer insulating boot
27.6±1.0
89.5±1.0
(135 ref.)
13.1±1.0
15.2±0.7
Fuse element
(76.00 ref.)
(13.3 ref.)
Estimated total length
after fully assembled
Catalog number system:
HPV - DV - XXA
Series
Amps
Voltage
HPV
DV = 1000 DC volts 1- 20 A
D15V = 1500 DC volts 4 A only)
XX = 1, 2, 2.5, 3, 3.5, 4,
5, 6, 8, 10, 12, 15, 20
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are
by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the
end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit
distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once
a product has been selected, it should be tested by the user in all possible applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2018 Eaton
All Rights Reserved
Printed in USA
Publication No. 2157 — BU-SB14182
August 2018
Eaton, and Bussmann are valuable trademarks
of Eaton in the U.S. and other countries. You
are not permitted to use the Eaton trademarks
without prior written consent of Eaton.
CSA is a registered trademark of the Canadian
Standards Group.
Sta-Kon is a registered trademark of Thomas
& Betts.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
Follow us on social media to get the
latest product and support information.
