Bussmann®
Semiconductor Fuseblocks
J70100 Series
700 Volt, 100 Amps
Catalog Symbol: J70100
Ampere Rating: 100A
Voltage Rating: 700Vac
Agency Information:
UL Recognized, Guide IZLT2, File E14853
Withstand Rating: 200,000 RMS Sym. Amps
For use with 22 ≈ 58mm fuses
(FWP-40A22F, FWP-100A22F, etc.)
Materials: Thermoplastic
UL Flammability: 94VO
Amps
100
Poles
1
2
3
Catalog Numbers
Box Lug w/
Fig.
Wire
Retaining Clip
No.
Range
J70100-1CR
1
#2-14 CU/AL
J70100-2CR
2
#2-14 CU/AL
J70100-3CR
3
#2-14 CU/AL
Dimensional Data
100A
1.702
3.202
.750
2.250
2.415
4.702
2.250
.750
C
L
3.994
CL
1.500
FIGURE 1
FIGURE 2
FIGURE 3
The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is
intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change
design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
9-18-02
SB02295
Form No. J70100
Page 1 of 1
Data Sheet: 1211
很抱歉,暂时无法提供与“J70032-1CR”相匹配的价格&库存,您可以联系我们找货
