BG3022PQ
BG3022PQ
    EATON(伊顿)
    BG3022PQ
BG3022PQ 数据手册
Technical Data 1106 Effective January 2023 Supersedes December 2015 BUSSMANN SERIES Class G Open fuse blocks Agency information • 1-30A: UL® Recognized, UL 512, Guide IZLT2, File E14853 • 35-60A: UL Listed, UL 512, Guide IZLT, File E14853 • 1-60A cULus, C22.2 No. 39, Class 6225-01; File 47235 • RoHS compliant Recommended fuses: • SC Material Base: Catalog symbols: • Thermoplastic (1-30A models) • Phenolic (35-60A models) Fuse clip: • BG_ (1-30A) • Bimetallic copper alloy (1-30A models) • G_ (35-60A) • Plated copper (35-60A models) Description: A range of open 1-, 2- and 3-pole fuse blocks for Class G fuses. Specifications: Ratings • Volts: • 600V (1-20A) • 480V (25-60A) • Amps: 1 to 60A • Withstand rating: 100kA RMS Sym DIN-Rail adapters: • DRA-1 and DRA-2 Technical Data 1106 Class G open fuse blocks Effective December 2015 Catalog numbers: Terminal type Amps 1 to 15 20 25 to 30 35 to 60 Poles Screw with quick-connect* Pressure plate with quick-connect* Box lug Box lug with retaining clip Fig. No. 1 BG3011SQ BG3011PQ BG3011B — 1 2 BG3012SQ BG3012PQ BG3012B — 2 3 BG3013SQ BG3013PQ BG3013B — 3 1 BG3021SQ BG3021PQ BG3021B — 1 2 BG3022SQ BG3022PQ BG3022B — 2 3 BG3023SQ BG3023PQ BG3023B — 3 1 BG3031S BG3031P BG3031B — 1 2 BG3032S BG3032P BG3032B — 2 3 BG3033S BG3033P BG3033B — 3 1 — — — G30060-1CR+ 4 2 — — — G30060-2CR+ 5 3 — — G30060-3C**+ G30060-3CR+ 6 #10 - #18Cu #6 - #14Cu (1-30A) #2 - #14Cu, #2 - #8Al (35-60A) #2 - #14Cu, #2 - #8Al Wire range #10 - #14Cu * Quick connect rated for 20A maximum. ** Not RoHS compliant. + Rated for #8 class H wire; 40 In.-Lbs Dimensions - in (±0.015): 1-30A 35-60A 1.38" 1.53" 0.36" 1.22" 0.425" 0.22" 0.5" 0.47" 0.84" 0.425" 0.29" Dia. hole 0.38" C'bore 0.360" 0.200" ±0.003 3" (±0.031) 4.25" 1.5" 2.125" 0.86" .765" 1.63" Figure 1. Figure 2. 2.38" 0.169 x 0.210 0.94" Figure 3. 1.78" Figure 4. 1.41" Figure 5. 1.69" 0.53" 0.22" Dia. hole 3.56" 1.78" 2.75" Figure 6. 2 Eaton.com/bussmannseries Technical Data 1106 Class G open fuse blocks Effective December 2015 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2023 Eaton All Rights Reserved Printed in USA Publication No. 1106 – BU-SB13774 January 2023 For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Eaton and Bussmann are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information.
BG3022PQ 价格&库存
很抱歉,暂时无法提供与“BG3022PQ”相匹配的价格&库存,您可以联系我们找货
