CH60J1
CH60J1
    EATON(伊顿)
    CH60J1
CH60J1 数据手册
CH Series Modular Fuse Holders Class J Class J – 600V 1-60A Features: • Choice of Indication: –easyID™ window to view indicator on Cooper Bussmann LPJ-(amp)SPI fuses. –Neon lamp open fuse indicator. • Comes in standard 1-, 2- & 3-Pole ganged assemblies (all fuses are extracted simultaneously). • Kits are available for ganging units in the field. • Meets requirements of IEC 60529 for IP20 finger-safe rating. • 35mm DIN rail and panel (6-32 UNC pan head recommended) mounting. • Fuse holder wire ports dual wire rated from 18 to 3AWG. Specifications: Fuse Sizes 600Vac/dc Amperage Rating Up to 30A Wire Range 30A Version 60A Version Catalog Symbol: CH30J_(I) - 30A CH60J_(I) - 60A Amp Range: 1 to 60A Voltage Rating: 600Vac/dc (or less) Withstand Rating (SCCR): 200kA RMS Sym. Agency Information: CE, Listed UL 512, Guide IZLT, File E14853 CSA Certified per C22.2 Nos. 39 Class 6225-01, File LR47235 Recommended Cooper Bussmann Fuses: Class J time-delay with indication LPJ-SPI (Data Sheet 1062) Class J time-delay LPJ (Data Sheet 1006) Class J fast-acting JKS (Data Sheet 1026) High Speed Class J Drive Fuse DFJ (Data Sheet 1048) 01-09 BU-SB08182 0 to 30A Class J Voltage Rating 35 to 60A Class J 600Vac/dc Up to 60A IP Rating 18-1AWG Single 18-3AWG Dual 75°C 10-18AWG/24in-lb 1-8AWG/35in-lb IP20 (Finger-Safe) 18-1AWG Single 18-3AWG Dual 75°C 10-18AWG/24in-lb 1-8AWG/35in-lb IP20 (Finger-Safe) Clip Material Tin-Plated Copper Tin-Plated Copper UL 94V0 Thermoplastic 90Vac/115Vdc UL 94V0 Thermoplastic 90Vac/115Vdc Terminal Torque Housing Material Minimum Indicating Voltage (Neon Lamp) Nominal Operating Current (Neon Lamp) Max Operating Temperature Storage & Operating Temperature Range* 34mA (460Vac) 85°C -20°C to 75°C 34mA (460Vac) 85°C -20°C to 75°C *For fuse selection on applications above or below 25°C, consult derating charts in Cooper Bussmann publication “Selecting Protective Devices” (SPD). Page 1 of 2 Data Sheet 2144 Catalog Numbers Max Fuse Size 30A AND 60A Ganging Assembly 30A 60A easyID™ Window Neon Lamp Indicating 1-Pole CH30J1 CH30J1I 2-Pole CH30J2 CH30J2I 3-Pole CH30J3 CH30J3I 1-Pole CH60J1 CH60J1I 2-Pole CH60J2 CH60J2I 3-Pole CH60J3 CH60J3I Accessories Part Number Description Carton Qty. 2A1073 Ganging Kit (Single Pole) 1 Spring Pins 3 Plastic Connectors 2A1777 Circuit Markers 100 E H D 3-Pole Class J Modular Fuse Holder G Dimensions - in (mm) F Dimension CH30J CH60J A 1.28 (32.5) 1.58 (40.0) B 2.56 (65.0) 3.16 (80.0) C 3.84 (97.5) 4.72 (120.0) D 4.59 (116.6) 4.88 (124.0) E 2.83 (71.8) 3.31 (84.1) F 3.56 (90.4) 3.85 (97.9) G 1.28 (32.5) 1.58 (40.0) H 0.18 (4.44) 0.18 (4.44) A B C The only controlled copy of this Data Sheet is the electronic read-only version located on the Cooper Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Cooper Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. © 2009 Cooper Bussmann St. Louis, MO 63178 www.cooperbussmann.com 01-09 BU-SB08182 Page 2 of 2 Data Sheet 2144
CH60J1 价格&库存
很抱歉,暂时无法提供与“CH60J1”相匹配的价格&库存,您可以联系我们找货
