CHCC2DIU
CHCC2DIU
    EATON(伊顿)
    CHCC2DIU
CHCC2DIU 数据手册
BUSSMANN SERIES CH global modular fuse holders Protect electrical systems while simplifing installation Product description: Features and benefits: Eaton’s Bussmann series CH global modular fuse holders accommodate many fuses from around the world, including North American Class CC, midget, IEC 10x38mm and solar PV fuses. • Easy color coding for use: yellow for PV, red for IEC, and black for UL applications. • Bussmann series Class CC and midget holders have a high Short-Circut Current Rating (SCCR), and are available with optional indicator. Holders are also available for Class J and other IEC size fuses. • Agency ratings up to 1000Vdc for use with solar PV fuses. ® Bussmann series CH global modular fuse holders offer the industry’s best ratings. DIN-Rail mount CH global modular fuse holders are compact, finger-safe and available in ratings up to UL® 600V/30A, IEC® 690V/32A and UL/IEC 1000Vdc/30A for photovoltaic applications. • Available with remote PLC indication with Bussmann series CH-PLC module. • Terminals rated for use with 75ºC or 90ºC wire, fine stranded wire, fork terminals and with comb busbars. Use any higher temperature rated wire with appropriate derating. • Complete range of UL Listed and high SCCR rated 1- and 3-phase finger-safe comb busbars and power feed lugs. Comb busbar easily distributes power in 1- and 3-phase configurations. UL midget and IEC 10x38 CHM holder catalog numbers Catalog number With indication* Without indication CHM1DIU CHM1DU CHM2DIU CHM2DU CHM3DIU CHM3DU CHM4DIU CHM4DU CHM1DNIU CHM1DNU Volts and amps UL Agency marks IEC Poles UR, CSA, IEC 60269-2, CCC 600V/30A 3 4 48Vdc/30A 48Vdc/32A UR, CSA, IEC 60269-2, CCC 690V/32A IEC 60269-2 CHM1DNXU 2 690V/32A CHM3DNU CHM1DI-48U 1 CHM1DCU 1 CHM2DCIU CHM2DCU 2 CHM3DCIU CHM3DCU 600Vac, 1000Vdc, 30A 3 690V, 32A AGU, C10G_, C10M_, BAF, BAN, FNM, FNQ, FWA, FWC, KLM, KTK 200kA RMS Sym. 1+ neutral 3+ neutral CHM1DCIU CHM4DCIU SCCR 1 IEC 60269-2 CHM3DNIU Recommended Bussmann series fuses UR, CSA, IEC 60269-2 CHM4DCU 4 N/A N/A 200kA RMS Sym., 33kA DC 600/690V AGU, C10G_, C10M_, BAF, BAN, FNM, FNQ, FWA, FWC, KLM, KTK 1000Vdc PV-(amp)A10F, PV10M-(amp) * All models requires 90V minimum for illumination, except CHM1DI-48U that requieres 15V minimum. UL Class CC CHCC holder catalog numbers Catalog With indication* CHCC1DIU CHCC2DIU CHCC3DIU CHCC1DI-48U number Without indication CHCC1DU CHCC2DU CHCC3DU — Volts / amps 600V/30A Agency marks UL, CSA, CCC 48Vdc/30A Poles 1 2 3 1 SCCR Recommended Bussmann series fuses 200kA RMS Sym. LP-CC, FNQ-R, KTK-R 33kA DC * All models requires 90V minimum for illumination, except CHCC1DI-48U that requieres 15V minimum. UL and IEC photovoltaic CHPV holder catalog numbers Catalog With indication CHPV1IU number Without indication CHPV1U CHPV2IU CHPV2U Volts / amps 1000Vdc/30A Agency marks UL, CSA, UL 4248-18, IEC 60269-1, CCC Poles 1 2 SCCR 33kA DC Recommended Bussmann series fuses PV-(amp)A10F, PV10M-(amp) * All models requires 90V minimum for illumination. See brochure No. 3185 for more information. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2015 Eaton All Rights Reserved Printed in USA Publication No. 3184 September 2015 Eaton and Bussmann are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. The CCC mark is administered by the Certification and Accreditation Administration of the People's Republic of China. CSA is a registered trademark of the Canadian Standards Group. IEC is a registered trademark of the International Electrotechnical Commission. UL is a registered trademark of the Underwriters Laboratories, Inc. For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Follow us on social media to get the latest product and support information.
CHCC2DIU 价格&库存
很抱歉,暂时无法提供与“CHCC2DIU”相匹配的价格&库存,您可以联系我们找货
CHCC2DIU
  • 1+2091.092711+270.67016
  • 6+1696.709146+219.62132
  • 12+1563.9505112+202.43710
  • 54+1425.2267154+184.48075
