CM32FC
CM32FC
    EATON(伊顿)
    CM32FC
CM32FC 数据手册
BUSSMANN Technical Data 10415 Effective June 2015 SERIES Bussmann series Camaster and Safeloc fuse holders Product description Eaton’s Bussmann series British standard fuse holders range is specifically designed to fit British standard fuse links. Technical Data 10415 Bussmann series Camaster and Safeloc fuse holders Effective June 2015 Catalogue symbol for Camaster range Weights: • CM(amp)F: Front connected • CM20F: 130 grams • CM(amp)FC: Front connected compact • CM32FC: 130 grams • CM32F: 158 grams • CM63F: 210 grams • CM100F: 207 grams Agency information: ASTA Certified to IEC 60269 • Technical data: • Rated voltage: 690 V a.c. • Rated current: 20 to 100 A Packaging: • 20 to 63 A: 10 per pack • 100 A: 5 per pack Table 1. Part numbers details Fuse holder description Front connected Front connected compact Colour 20 A Black CM20F 32 A 63 A 100 A CM32F* CM63F* CM100F* CM63FW* CM100FW* Green CM32FG* White CM32FW* Black CM32FC Green CM32FCG White CM32FCW * Back studs can be retrofitted as standard Table 2. Technical data Part numbers Rated current (Amps) Rated voltage (V a.c.) CM20F 20 690 Agency markings ASTA certified to IEC 60269 Minimum conductor size Maximum conductor size Suggested terminal torque values Compatible fuse links Packaging 0.5 mm2 16 mm2 2 to 2.5 Nm NITD, NIT 10 2 2 CM32FC 32 0.5 mm 16 mm 2 to 2.5 Nm NITD, NIT 10 CM32F 32 1.5 mm2 16 mm2 2 to 2.5 Nm AAO, TIA 10 CM63F 63 1.5 mm2 70 mm2 3 to 3.5 Nm BAO, TIS 10 CM100F 100 1.5 mm2 70 mm2 3 to 3.5 Nm OSD 5 2 EATON www.eaton.com Bussmann series Camaster and Safeloc fuse holders Technical Data 10415 Effective June 2015 Table 3. Accessories Catalogue numbers 32BSC 32BS 63-100BS 32CMLC 32CML 63-100CML 32LSCC 32LSC 63-100LSC NI Pack quantity 10 10 5 10 1 1 3 3 3 3 Description Back stud for 20-32 A Compact Camaster Back stud conversion kit for 32 A Camaster Back stud for 63-100 A Camaster Neutral link for 32 A Compact Camaster Neutral link for 32 A Camaster Neutral link for 63-100 A Camaster Lockable safety carrier 20-32 A Compact Lockable safety carrier 32 A Lockable safety carrier 63-100 A Neon indicator for 32-100 A 32BS 63-100BS 32CMLC 32CML 63-100CML NI Dimensions - mm “ “ “ “ CM20F and CM32FC EATON www.eaton.com 3 Technical Data 10415 Bussmann series Camaster and Safeloc fuse holders Effective June 2015 Dimensions - mm “    “ “ “ CM32F “    “ “ “ CM63F 4 EATON www.eaton.com Bussmann series Camaster and Safeloc fuse holders Technical Data 10415 Effective June 2015 Dimensions - mm “    “ “ “ CM100F EATON www.eaton.com 5 Bussmann series Camaster and Safeloc fuse holders Technical Data 10415 Effective June 2015 Catalogue symbol for Safeloc • See table below Agency information: • ASTA Certified to IEC 60269 Technical data: • Rated voltage: 550 V a.c. • Rated current: 32 to 63 A Packaging: • 32 A: 10 per pack • 63 A: 5 per pack Table 4. Part numbers details Fuse holder description Colour 32 A 63 A Back stud/back stud Black 32NNSBS 63ENSBS Green 32NNSBSGREEN White 32NNSBSWHITE 63ENSBSWHITE Black 32NNSF 63ENSF Green 32NNSFGREEN White 32NNSFWHITE 63ENSFWHITE Black 32NNSFBS 63ENSFBS White 32NNSFBSWHITE 63ENSFBSWHITE Front connected/front connected Front connected/back stud Table 5. Technical data Rated current (Amps) Rated voltage (V a.c.) 32 550 63 Agency markings ASTA certified to IEC 60269 Minimum conductor size Maximum conductor size Suggested terminal torque values Compatible fuse links Packaging 0.5 mm2 16 mm2 2-2.5 Nm NSD 10 1.5 mm2 35 mm2 3-3.5 Nm ESD 5 Weights: • 32NNSBS: 113 grams • 32NNSF: 85 grams • 32NNSFBS: 100 grams • 63ENSBS: 255 grams • 63ENSF: 175 grams • 63ENSFBS: 215 grams EATON www.eaton.com 6 Bussmann series Camaster and Safeloc fuse holders Technical Data 10415 Effective June 2015 Dimensions - mm “ “ “ “ “ “ “ “  32NNSBS 116%6 Back stud/back stud  32NNSFBS 116)%6 Front connected/back stud 0    “ “  “ “ “ “ 32NNSF Front connected/front connected EATON www.eaton.com 7 Technical Data 10415 Bussmann series Camaster and Safeloc fuse holders Effective June 2015 Dimensions - mm “ “  “ “ “ 63ENSFBS (16)%6 Front connected/ back stud 63ENSBS (16%6 Back stud/ back stud   63ENSF(16) Front connected/ front connected 0 “  Changes to the products, to the information contained in this document, and to prices are reserved; so are errors and omissions. Only order confirmations and technical documentation by Eaton is binding. Photos and pictures also do not warrant a specific layout or functionality. Their use in whatever form is subject to prior approval by Eaton. The same applies to Trademarks (especially Eaton, Moeller, and Cutler-Hammer). The Terms and Conditions of Eaton apply, as referenced on Eaton Internet pages and Eaton order confirmations. Eaton EMEA Headquarters Route de la Longeraie 7 1110 Morges, Switzerland Eaton.eu © 2015 Eaton All Rights Reserved PDF only Publication No. 10415 June 2015 Eaton is a registered trademark. All other trademarks are property of their respective owners.
CM32FC 价格&库存
很抱歉,暂时无法提供与“CM32FC”相匹配的价格&库存,您可以联系我们找货
