Bussmann®
TRON® In-Line Fuseholders
HEJ
Series
Single-Pole for SC-35 – 60A and HVW Fuses
Catalog and Specification Data
Conductor Terminals
Stranded
Catalog
Symbol
Load &
Line
Solid
Conductor Data
Size
No. Per
Terminal
Terminal Type
#12 to #8
#12
#10
#6
#4
#8
#4
#6
#2
1
2
2
1
1
2
1
2
1
HEJ — For SC fuses; 35A to 60A and high voltage fuses.
Type HVW, ⁄Ω™ to 6A, 1200Vac (or less).
Fuse size ⁄‹Ω£™∑ ≈ 2⁄Ω¢∑. Holder rated 60A, 480V
#12 to #3
1
J
Example:
A single-pole, in-line holder for a SC-40 fuse. A single #8
copper, stranded wire is on the load. Copper crimp connection desired. Two #10 copper, stranded wires are on the line
side. Copper crimp is the desired connection.
1. Choose HEJ- series.
2. Choose “A” for load side.
3. Choose “B” for line side.
Complete Part Number: HEJ-AB
#12 to #2
2
K
#6
1
#4
1
#3, #4
1
#2
1
#12 to #2
1
Non-Breakaway Holders
HEJ Series Catalog Symbol: HEJ-AA(1) (2) (3), HEJ-AB,
HEJ-AC, HEJ-BB, HEJ-CC, HEJ-DD, HEJ-JJ, HEJ-JK,
HEJ-LL, HEJ-PP, and HEJ-QQ
In-Line Fuseholders, Single-Pole
Water-Resistant
Agency Information:
(1)UL Recognized, Guide IZLT2, File E14853
(2)CSA Certified, Class 6225-01, File 47235
(3)CE
Copper Crimp
A
B
C
D
Copper Set-Screw
Aluminum Crimp
P
Q
Aluminum Set-Screw
L
Ordering Information:
HEJ
Load
Terminal
Line
Terminal
Recommended Torque on Coupling Nut: 10-20 in-lb.
Catalog Data — Insulating Boots
Catalog
Numbers
Type
2A0660
Single Conductor
2A0661
Two Conductor
Insulating boots are not included with non-breakaway parts
and must be ordered separately. They come standard with the
breakaway series. When boots are utilized, extra heat retention
requires that fuses are sized at a minimum of 200% of the
RMS load current.
The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is
intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change
design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
7-16-03
N03082
Form No. HEJ Series
Page 1 of 1
Data Sheet: 2123
很抱歉,暂时无法提供与“HEJ-WW”相匹配的价格&库存,您可以联系我们找货
