Effective January 2019
Supersedes April 2017
Technical Data 2127
BUSSMANN
SERIES
HEB breakaway and non-breakaway
in-line fuse holders for UL 13/32” x 1-1/2”
supplemental fuses
Use these part numbers to order insulating
boots for a non-breakaway HEB holder
Description
Single conductor
Dual conductor
Catalog Symbol: HEB*
Catalog no.
2A0660
2A0661
Boot reference
Description
The Bussmann™ series of HEB submersible,
single-pole in-line fuse holders for UL 13/32”
x 1-1/2” supplemental fuses. Available in nonbreakaway and breakaway versions with an array
of terminal options to meet application needs.
Breakaway versions come with insulating boots to
provide submersibility per UL IP67. Non-breakaway
versions require ordering optional insulating boots
for submersibility.
Recommended fuses
BAF, FNM, FNQ, KLM and KTK
Ratings
Volts:
600 V
Amps:
up to 30 A limited by conductor size
0.8
(ø20)
4.1
(104)
1.3
(ø33)
4.7
(119)
Installation instructions
Strip wire insulation equal to the depth of the
crimp or screw terminal. Torque screw terminal to
35 lb-In (3.9 N•m) or crimp terminal twice, spacing
crimps a distance of one-third from each end (as
shown below) using an appropriate crimp tool and
die. See page 5 for recommended crimping tools.
Crimp terminal twice
at locations 1/3 distance
from each end
Withstand: 200 kA RMS Sym.
Agency information
UL® Recognized, Guide IZLT2, File E14853
CSA® Certified, Class 622501, File 47235
CE, RoHS compliant†
to depth of terminal
Coupling nut torque
10-20 lb-In (1.1-2.2 N•m)
Operating and storage temperature
-40°F (-40°C) to 221°F (105°C)
Insulating boots
Two insulating boots come standard with the
breakaway holder configurations. Insulating boots
are not included as standard with non-breakaway
holders. Two insulating boots must be ordered
separately, if required, for each non-breakaway
holder ordered. When insulating boots are utilized,
extra heat retention requires that fuses are sized
at a minimum of 200% of the RMS load current.
Related products:
Catalog
Data
no.
Description
sheet no.
Two-pole supplemental in-line
HEX
2126
fuse holder
One-pole Class CC in-line
HEZ
2130
fuse holder
Two-pole Class CC in-line
HEY
2126
fuse holder
One-pole in-line, permanently
HET
2125
installed neutral
13/32” x 1-1/2” neutral
NNB
dummy link (not a fuse)
* The Bussmann series HEB in-line fuse holders are the legacy
Bussmann TRON™ HEB in-line fuse holders.
† See terminal data tables for exceptions.
Technical Data 2127
Bussmann series HEB breakaway and non-breakaway
in-line fuse holders for UL 13/32” x 1-1/2” supplemental fuses
Non-breakaway catalog number system
To order:
Specify catalog symbol HEB and the loadside terminal code. Then select a lineside
terminal code that is available with the loadside terminal. Example: HEB-BB defines a
non-breakaway holder with a loadside copper crimp terminal for a single #6 or two #10
wires with a lineside copper crimp terminal for a single #6 or two #10 wires.
Agency
Info.
Loadside terminal
Lineside terminal
Lineside
terminal
Loadside
terminal
Catalog
symbol
HEB - A A
UL
CSA
A
X
X
Cu crimp
#8-16; (2) #12-16
Sol/Str
Cu crimp
#8-16; (2) #12-16
Sol/Str
4.4 (112)
HEB-AW-RLC-A
B
X
X
Cu crimp
#8-16; (2) #12-16
Sol/Str
Cu crimp
#6; (2) #10
4.4 (112)
HEB-AW-RLC-B
C
X
X
Cu crimp
#8-16; (2) #12-16
Sol/Str
Cu crimp
#4; (2) #8
4.7 (119)
HEB-AW-RLC-C
D
X
X
Cu crimp
#8-16; (2) #12-16
Sol/Str
Cu crimp
#2; (2) #6
4.7 (119)
J
X
X
Cu crimp
#8-16; (2) #12-16
Sol/Str
Cu
setscrew
#3-12 Str;
#10-12 Sol
4.7 (119)
HEB-AW-RLC-J
K
X
X
Cu crimp
#8-16; (2) #12-16
Sol/Str
Cu dual
setscrew
#2-12 Str†;
#10-12 Sol†
4.8 (122)
HEB-AW-RYC
R
Cu crimp
#8-16; (2) #12-16
Sol/Str
Al crimp
#1-2
4.9 (124)
L
Cu crimp
#8-16; (2) #12-16
Sol/Str
Al
setscrew
#2-12
4.7 (119)
HEB-AW-RLA
W
Cu crimp
#8-16; (2) #12-16
Sol/Str
Cu solid
4.4 (112)
Y
Cu crimp
#8-16; (2) #12-16
Sol/Str
Al dual
setscrew
#2-12†
4.8 (122)
HEB-AW-RYA
A
X
X
Cu crimp
#6; (2) #10
Cu crimp
#8-16; (2) #12-16
Sol/Str
4.4 (112)
HEB-BW-RLC-A
B
X
X
Cu crimp
#6; (2) #10
Cu crimp
#6; (2) #10
4.4 (112)
HEB-BW-RLC-B
C
X
X
Cu crimp
#6; (2) #10
Cu crimp
#4; (2) #8
4.7 (119)
D
X
X
Cu crimp
#6; (2) #10
Cu crimp
#2; (2) #6
4.7 (119)
W
Cu crimp
#6; (2) #10
Cu solid
4.4 (112)
C
C
X
X
Cu crimp
#4; (2) #8
Cu crimp
#4; (2) #8
5 (127)
D
D
X
X
Cu crimp
#2; (2) #6
Cu crimp
#2; (2) #6
5 (127)
Z
A
Cu crimp
#18-20
Cu crimp
#8-16; (2) #12-16
Sol/Str
4.4 (112)
J
X
X
Cu
setscrew
#3-12 Str;
#10-12 Sol
Cu
setscrew
#3-12 Str;
#10-20 Sol
5 (127)
HEB-JW-RLC-J
K
X
X
Cu
setscrew
#3-12 Str;
#10-12 Sol
Cu dual
setscrew
#3-12 Str†;
#10-20 Sol†
5.1 (129)
HEB-JW-RYC
L
Cu
setscrew
#3-12 Str;
#10-12 Sol
Al
setscrew
#2-12
5 (127)
W
Cu
setscrew
#3-12 Str;
#10-12 Sol
Cu solid
4.8 (122)
Y
Cu
setscrew
#3-12 Str;
#10-12 Sol
Al dual
setscrew
#2-12†
5.1 (129)
Terminal type
A
HEB
B
J
Wire
range*
Terminal type
* Stranded conductors unless otherwise noted.
† Not dual wire rated. One wire per opening.
Non-breakaway dimensions - in (mm):
A
9.125 (232)
Assembled length
2
Eaton.com/bussmannseries
Wire range*
Ref.
length
A
Breakaway
equivalent
Technical Data 2127
Lineside
terminal
Agency
Information
Loadside
terminal
Catalog
symbol
HEB - A A
L
L
Al
setscrew
#2-12
Al
setscrew
#2-12
5 (127)
HEB-LW-RLA
N
N
Al crimp
#8 Str;
#6 Sol
Al crimp
#8 Str;
#6 Sol
5.4 (137)
P
P
X
Al crimp
#6 Str;
#4 Sol
Al crimp
#6 Str;
#4 Sol
5.4 (137)
Q
Q
X
Al crimp
#3-4 Str;
#2 Sol
Al crimp
#3-4 Str;
#2 Sol
5.4 (137)
R
R
X
Al crimp
#1-2
Al crimp
#1-2
5.4 (137)
T
T
X
Al crimp
1/0
Al crimp
1/0
5.4 (137)
W
W
Cu solid
Cu solid
4.4 (112)
HEB
UL
CSA
Loadside terminal
Lineside terminal
Wire
range*
Terminal type
Terminal type
Wire
range*
Reference
length
A
Breakaway
equivalent
#6
1
#10
2
#4
1
#8
2
#2
1
#6
2
#18-20
1
#3-12
1
#10-12
1
#2-12
2†
#10-12
2†
A
B
C††
Catalog symbol
[Load /Line]
Stranded
Stranded
Solid
2
Solid
Cu solid
1
Terminal type
Al crimp
No. per
terminal
Cu dual
setscrew
#8-16
#12-16
Conductor data
Wire range
Cu setscrew
No. per
terminal
Terminal type
Cu crimp
Wire range
Conductor data
Catalog symbol
[Load /Line]
Non-Breakaway terminal data
#8
1
#6
1
#6
1
#4
1
#3-4
1
#2
1
#1-2
1
R
#1/0
1
T
#2-12
1
L
#2-12
2†
Y
N
P
Q
D††
Z
J
Al setscrew
K
Al dual
setscrew
W
†† Fuse holder assemblies using this terminal are not RoHS compliant.
3
Technical Data 2127
Breakaway catalog number system
A
HEB
B
Agency
Info.
UL
CSA
RLC-A
X
X
Cu crimp
#8-16; (2) #12-16
Cu crimp
Sol/Str
#8-16; (2) #12-16
Sol/Str
5.8 (147)
HEB-AA
RLC-B
X
X
Cu crimp
#8-16; (2) #12-16
Cu crimp
Sol/Str
#6; (2) #10
5.9 (150)
HEB-AB
RLC-C
X
X
Cu crimp
#8-16; (2) #12-16
Cu crimp
Sol/Str
#4; (2) #8
6.2 (158)
HEB-AC
RLC-J
X
X
Cu crimp
#8-16; (2) #12-16 Cu
Sol/Str
setscrew
#3-12 Str
#10-12 Sol
6.2 (158)
HEB-AJ
RYC
X
X
Cu crimp
#8-16; (2) #12-16 Cu dual
Sol/Str
setscrew
#2-12 Str†;
#10-12 Sol†
6.3 (159)
HEB-AK
RLA
Cu crimp
#8-16; (2) #12-16 Al
Sol/Str
setscrew
#2-12
6.2 (158)
HEB-AL
RYA
Cu crimp
#8-16; (2) #12-16 Al dual
Sol/Str
setscrew
#2-12†
6.3 (159)
HEB-AY
RLC-A
X
X
Cu crimp
#6; (2) #10
Cu crimp
#8-16; (2) #12-16
5.8 (147)
HEB-BA
RLC-B
X
X
Cu crimp
#6; (2) #10
Cu crimp
6#; (2) #10
5.9 (150)
HEB-BB
RYC
X
X
Cu crimp
#6; (2) #10
Cu dual
setscrew
#2-12 Str†;
#10-12 Sol†
6.3 (159)
RLC-J
X
X
Cu
setscrew
#3-12 Str;
#10-12 Sol
Cu
setscrew
#3-12 Str;
#10-12 Sol
6.2 (158)
HEB-JJ
RYC
X
X
Cu
setscrew
#3-12 Str;
#10-12 Sol
Cu dual
setscrew
#2-12 Str†;
#10-12 Sol†
6.3 (159)
HEB-JK
RLC-J
X
X
Cu dual
setscrew
#2-12 Str†;
#10-12 Sol†
Cu
setscrew
#3-12 Str;
#10-12 Sol
6.2 (158)
RYC
X
X
Cu dual
setscrew
#2-12 Str†;
#10-12 Sol†
Cu dual
setscrew
#2-12 Str†;
#10-12 Sol†
6.3 (159)
RLA
Al
setscrew
#2-12
Al
setscrew
#2-12
6.2 (158)
HEB-LL
RLC-J
Al
setscrew
#2-12
Cu
setscrew
#3-12
6.2 (158)
RYA
Al
setscrew
#2-12
Al dual
setscrew
#2-12†
6.3 (159)
J
K
L
Specify catalog symbol HEB and the loadside terminal code plus the letter “W.” Then
select a lineside terminal code that is available with the loadside terminal. Example:
HEB-BW-RCL-B defines a breakaway holder with a loadside copper crimp terminal for
a single #6 or two #10 wires with a lineside copper crimp terminal for a single #6 or
two #10 wires.
Lineside
terminal
Loadside
terminal
Catalog
symbol
HEB - A W - RYC
To order:
Loadside terminal
Terminal type
Lineside terminal
Wire range*
Dimensions - in (mm):
Breakaway
A
10.375 (263)
Assembled length
4
Terminal type
Wire range*
Length
A
(ref.)
Nonbreakaway
equivalent
Cu dual setscrew
2
#6
1
#10
2
#3-12
1
#10-12
1
#2-12
2
#10-12
2†
B
J
K
Cu setscrew
Cu dual setscrew
Al setscrew
#2-12
1
L
#8-16
1
#12-16
2
#6
1
#10
2
#4
1
#8
2
Catalog
symbol
#10-16
A
Stranded
Solid
Stranded
Terminal type
Cu crimp
No. per
terminal
Solid
1
Conductor data
Wire range
No. per
terminal
#8-16
Catalog symbol
[Load /Line
(2) & (3)]
Wire range
Conductor data
Cu setscrew
Breakaway lineside terminal data
Breakaway loadside terminal data
Terminal type
Cu crimp
Technical Data 2127
-RLC-A
-RLC-B
-RLC-C††
#3-12
1
#10-12
1
#2-12
2†
#10-12
2
#2-12
1
-RLA
#2-12
2†
-RYA
-RLC-J
-RYC
Al setscrew
Al dual setscrew
5
Technical Data 2127
Recommended crimping tools
A wide variety of crimping tools can be used with the HEB fuse
holders. Some of the commercially available tools are listed in the
table below. This list is not intended to exclude the use of other
crimping tools that can provide similar crimps or indents.
HEB terminal
A
B
C
D
Z
N, P, Q, R, T
T & B P/N (Die)
WT-111M (Die C)
Sta-Kon ERG4002 (Die C)
WT-115A (Die D)
TBM5 (Grey Die)
WT-115A (Die E)
TBM5 (Brown Die)
TBM8 (Brown Die)
WT-115A (Die F)
WT-111M (Die A)
Sta-Kon ERG4002 (Die A)
TBM8 (Orange Die)
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are
by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the
end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit
distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once
a product has been selected, it should be tested by the user in all possible applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2019 Eaton
All Rights Reserved
Printed in USA
Publication No. 2127 - BU-SB15154
January 2019
Eaton and Bussmann are valuable trademarks
of Eaton in the US and other countries. You
are not permitted to use the Eaton trademarks
without prior written consent of Eaton.
CSA is a registered trademark of the Canadian
Standards Group.
Sta-Kon is a registered trademark of Thomas
& Betts.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“HEB-JY”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+1881.3956910+244.10954
- 国内价格
- 1+443.83680
- 200+171.76320
- 500+165.72600
- 1000+162.74520
