Bussmann®
Class J Fuseblocks
JP Series
Pyramid Style
600 Volt, 30 Amps
Dimensional Data
*All other dimensions (± 0.015∑)
(± 0.40mm)
DIN-RAIL MOUNTING SCREW 8" (203.2mm) APART.
END STOPS - PREVENT BLOCK MOVEMENT WHEN CHANGING FUSES
4.00" MAX.
(101.6mm)
3.75" (± 0.02)
(95.3mm) (± 0.50)
1.88"
(47.6mm)
1.19"
(30.2mm)
2.38"
(60.4mm)
Catalog Symbol: JP Series
Pyramid Style Fuseblock
Ampere Rating: 30 Amperes
Voltage Rating: 600 Volts
Withstand Rating: 200,000 RMS Sym. Amps
Agency Information:
U.L. Listed, U.L. 512, Guide IZLT, File E14853
CSA Certified, C22.2 No. 39, Class 4225-04, File 47235
For use with Class J Fuses (Bussmann LPJ, JKS)
U.L. Flammability: 94VO
Material: Thermoplastic
Pyramid® J Fuseblock; 30A, 600V; 3-Pole; Panel or 35mm
DIN-Rail Mount; Clips with Reinforcing Springs
Mounting
Panel
With
DIN-Rail
Adapter*
Screws with
Pressure
Plate
JP60030-3PR
(#10-14 CU ONLY)
JP60030-3PRA
(#10-14 CU ONLY)
3.29" (± 0.03)
(83.6mm) (± 0.76)
2.78"
3.06"
(70.6mm)
(77.8mm)
3.13"
(79.5mm)
ADAPTER FOR 35mm
SYMMETRICAL DIN-RAIL MOUNTING
Catalog Numbers
Box
Aluminum
JP60030-3CR
(#2-14 CU/AL)
JP60030-3CRA
(#2-14 CU/AL)
Copper
Only
JP60030-3COR
(#2-14 CU ONLY)
JP60030-CORA
(#2-14 CU ONLY)
*Adapter Only for DIN-Rail - Cat No. JPA-3.
CE logo denotes compliance with European Union Low Voltage Directive
(50-1000 Vac, 75-1500 Vdc). Refer to BIF document #8002 or contact
Bussmann Application Engineering at 314-527-1270 for more information.
The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is
intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change
design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained
in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
1-16-02
SB02003
Form No. JP Series
Page 1 of 1
BIF Doc #1108
很抱歉,暂时无法提供与“JP60030-3PRA”相匹配的价格&库存,您可以联系我们找货
