Technical Data 1106
Effective January 2023
Supersedes December 2015
BUSSMANN
SERIES
Class G
Open fuse blocks
Agency information
1-30A: UL® Recognized, UL 512, Guide IZLT2,
File E14853
35-60A: UL Listed, UL 512, Guide IZLT,
File E14853
1-60A cULus, C22.2 No. 39,
Class 6225-01; File 47235
RoHS compliant
Recommended fuses:
SC
Material
Base:
Catalog symbols:
Thermoplastic (1-30A models)
Phenolic (35-60A models)
Fuse clip:
BG_ (1-30A)
Bimetallic copper alloy (1-30A models)
G_ (35-60A)
Plated copper (35-60A models)
Description:
A range of open 1-, 2- and 3-pole fuse blocks for
Class G fuses.
Specifications:
Ratings
Volts:
• 600V (1-20A)
480V (25-60A)
Amps: 1 to 60A
Withstand rating: 100kA RMS Sym
DIN-Rail adapters:
DRA-1 and DRA-2
Technical Data 1106
Class G open fuse blocks
Effective December 2015
Catalog numbers:
Terminal type
Amps
1 to 15
25 to 30
35 to 60
Poles
Screw with
quick-connect*
Pressure plate with
quick-connect*
Box lug
Box lug with
retaining clip
Fig. No.
1
BG3011SQ
BG3011PQ
BG3011B
1
2
BG3012SQ
BG3012PQ
BG3012B
2
3
BG3013SQ
BG3013PQ
BG3013B
3
1
BG3021SQ
BG3021PQ
BG3021B
1
2
BG3022SQ
BG3022PQ
BG3022B
2
3
BG3023SQ
BG3023PQ
BG3023B
3
1
BG3031S
BG3031P
BG3031B
1
2
BG3032S
BG3032P
BG3032B
2
3
BG3033S
BG3033P
BG3033B
3
1
G30060-1CR+
4
2
G30060-2CR+
5
3
G30060-3C**+
G30060-3CR+
6
#10 - #18Cu
#6 - #14Cu (1-30A)
#2 - #14Cu, #2 - #8Al (35-60A)
Wire range
#10 - #14Cu
* Quick connect rated for 20A maximum.
** Not RoHS compliant.
+ Rated for #8 class H wire; 40 In.-Lbs
Dimensions - in (±0.015):
1-30A
35-60A
1.38"
1.53"
0.36"
1.22"
0.425"
0.22"
0.5"
0.47"
0.84"
0.425"
0.29" Dia. hole
0.38" C'bore
0.360"
0.200"
±0.003
3" (±0.031)
4.25"
1.5"
2.125"
0.86"
.765"
1.63"
Figure 1.
Figure 2.
2.38"
0.169 x 0.210
0.94"
Figure 3.
1.78"
Figure 4.
1.41"
Figure 5.
1.69"
0.53"
0.22" Dia. hole
3.56"
1.78"
2.75"
Figure 6.
2
Eaton.com/bussmannseries
Technical Data 1106
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this
document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical
information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of
any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any
technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2023 Eaton
All Rights Reserved
Printed in USA
Publication No. 1106 – BU-SB13774
January 2023
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Eaton and Bussmann are valuable
trademarks of Eaton in the US and other
countries. You are not permitted to use
the Eaton trademarks without prior written
consent of Eaton.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“G30060-3CRH”相匹配的价格&库存,您可以联系我们找货
