HEB-1K0364
HEB-1K0364
    EATON(伊顿)
    HEB-1K0364
HEB-1K0364 数据手册
Effective January 2019 Supersedes April 2017 Technical Data 2127 BUSSMANN SERIES HEB breakaway and non-breakaway in-line fuse holders for UL 13/32” x 1-1/2” supplemental fuses Use these part numbers to order insulating boots for a non-breakaway HEB holder Description Single conductor Dual conductor Catalog Symbol: HEB* Catalog no. 2A0660 2A0661 Boot reference Description The Bussmann™ series of HEB submersible, single-pole in-line fuse holders for UL 13/32” x 1-1/2” supplemental fuses. Available in nonbreakaway and breakaway versions with an array of terminal options to meet application needs. Breakaway versions come with insulating boots to provide submersibility per UL IP67. Non-breakaway versions require ordering optional insulating boots for submersibility. Recommended fuses BAF, FNM, FNQ, KLM and KTK Ratings Volts: 600 V Amps: up to 30 A limited by conductor size 0.8 (ø20) 4.1 (104) 1.3 (ø33) 4.7 (119) Installation instructions Strip wire insulation equal to the depth of the crimp or screw terminal. Torque screw terminal to 35 lb-In (3.9 N•m) or crimp terminal twice, spacing crimps a distance of one-third from each end (as shown below) using an appropriate crimp tool and die. See page 5 for recommended crimping tools. Crimp terminal twice at locations 1/3 distance from each end Withstand: 200 kA RMS Sym. Agency information UL® Recognized, Guide IZLT2, File E14853 CSA® Certified, Class 622501, File 47235 CE, RoHS compliant† Strip wire insulation to depth of terminal Coupling nut torque 10-20 lb-In (1.1-2.2 N•m) Operating and storage temperature -40°F (-40°C) to 221°F (105°C) Insulating boots Two insulating boots come standard with the breakaway holder configurations. Insulating boots are not included as standard with non-breakaway holders. Two insulating boots must be ordered separately, if required, for each non-breakaway holder ordered. When insulating boots are utilized, extra heat retention requires that fuses are sized at a minimum of 200% of the RMS load current. Related products: Catalog Data no. Description sheet no. Two-pole supplemental in-line HEX 2126 fuse holder One-pole Class CC in-line HEZ 2130 fuse holder Two-pole Class CC in-line HEY 2126 fuse holder One-pole in-line, permanently HET 2125 installed neutral 13/32” x 1-1/2” neutral NNB — dummy link (not a fuse) * The Bussmann series HEB in-line fuse holders are the legacy Bussmann TRON™ HEB in-line fuse holders. † See terminal data tables for exceptions. Technical Data 2127 Bussmann series HEB breakaway and non-breakaway in-line fuse holders for UL 13/32” x 1-1/2” supplemental fuses Effective January 2019 Non-breakaway catalog number system To order: Specify catalog symbol HEB and the loadside terminal code. Then select a lineside terminal code that is available with the loadside terminal. Example: HEB-BB defines a non-breakaway holder with a loadside copper crimp terminal for a single #6 or two #10 wires with a lineside copper crimp terminal for a single #6 or two #10 wires. Agency Info. Loadside terminal Lineside terminal Lineside terminal Loadside terminal Catalog symbol HEB - A A UL CSA A X X Cu crimp #8-16; (2) #12-16 Sol/Str Cu crimp #8-16; (2) #12-16 Sol/Str 4.4 (112) HEB-AW-RLC-A B X X Cu crimp #8-16; (2) #12-16 Sol/Str Cu crimp #6; (2) #10 4.4 (112) HEB-AW-RLC-B C X X Cu crimp #8-16; (2) #12-16 Sol/Str Cu crimp #4; (2) #8 4.7 (119) HEB-AW-RLC-C D X X Cu crimp #8-16; (2) #12-16 Sol/Str Cu crimp #2; (2) #6 4.7 (119) — J X X Cu crimp #8-16; (2) #12-16 Sol/Str Cu setscrew #3-12 Str; #10-12 Sol 4.7 (119) HEB-AW-RLC-J K X X Cu crimp #8-16; (2) #12-16 Sol/Str Cu dual setscrew #2-12 Str†; #10-12 Sol† 4.8 (122) HEB-AW-RYC R — — Cu crimp #8-16; (2) #12-16 Sol/Str Al crimp #1-2 4.9 (124) ­— L — — Cu crimp #8-16; (2) #12-16 Sol/Str Al setscrew #2-12 4.7 (119) HEB-AW-RLA W — — Cu crimp #8-16; (2) #12-16 Sol/Str Cu solid — 4.4 (112) — Y — — Cu crimp #8-16; (2) #12-16 Sol/Str Al dual setscrew #2-12† 4.8 (122) HEB-AW-RYA A X X Cu crimp #6; (2) #10 Cu crimp #8-16; (2) #12-16 Sol/Str 4.4 (112) HEB-BW-RLC-A B X X Cu crimp #6; (2) #10 Cu crimp #6; (2) #10 4.4 (112) HEB-BW-RLC-B C X X Cu crimp #6; (2) #10 Cu crimp #4; (2) #8 4.7 (119) — D X X Cu crimp #6; (2) #10 Cu crimp #2; (2) #6 4.7 (119) — W — — Cu crimp #6; (2) #10 Cu solid — 4.4 (112) — C C X X Cu crimp #4; (2) #8 Cu crimp #4; (2) #8 5 (127) — D D X X Cu crimp #2; (2) #6 Cu crimp #2; (2) #6 5 (127) — Z A — — Cu crimp #18-20 Cu crimp #8-16; (2) #12-16 Sol/Str 4.4 (112) — J X X Cu setscrew #3-12 Str; #10-12 Sol Cu setscrew #3-12 Str; #10-20 Sol 5 (127) HEB-JW-RLC-J K X X Cu setscrew #3-12 Str; #10-12 Sol Cu dual setscrew #3-12 Str†; #10-20 Sol† 5.1 (129) HEB-JW-RYC L — — Cu setscrew #3-12 Str; #10-12 Sol Al setscrew #2-12 5 (127) — W — — Cu setscrew #3-12 Str; #10-12 Sol Cu solid — 4.8 (122) — Y — — Cu setscrew #3-12 Str; #10-12 Sol Al dual setscrew #2-12† 5.1 (129) — Terminal type A HEB B J Wire range* Terminal type * Stranded conductors unless otherwise noted. † Not dual wire rated. One wire per opening. Non-breakaway dimensions - in (mm): A 9.125 (232) Assembled length 2 Eaton.com/bussmannseries Wire range* Ref. length A Breakaway equivalent Bussmann series HEB breakaway and non-breakaway in-line fuse holders for UL 13/32” x 1-1/2” supplemental fuses Technical Data 2127 Effective January 2019 Non-breakaway catalog number system Lineside terminal Agency Information Loadside terminal Catalog symbol HEB - A A L L — — Al setscrew #2-12 Al setscrew #2-12 5 (127) HEB-LW-RLA N N — — Al crimp #8 Str; #6 Sol Al crimp #8 Str; #6 Sol 5.4 (137) — P P — X Al crimp #6 Str; #4 Sol Al crimp #6 Str; #4 Sol 5.4 (137) — Q Q — X Al crimp #3-4 Str; #2 Sol Al crimp #3-4 Str; #2 Sol 5.4 (137) — R R — X Al crimp #1-2 Al crimp #1-2 5.4 (137) — T T — X Al crimp 1/0 Al crimp 1/0 5.4 (137) — W W — — Cu solid — Cu solid — 4.4 (112) — HEB UL CSA Loadside terminal Lineside terminal Wire range* Terminal type Terminal type Wire range* Reference length A Breakaway equivalent * Stranded conductors unless otherwise noted. • #6 1 • • #10 2 • • #4 1 — • #8 2 • • #2 1 — • #6 2 • • #18-20 1 • • #3-12 1 — • #10-12 1 • • #2-12 2† — • #10-12 2† • • — — — — A B C†† Catalog symbol [Load /Line] Stranded • • Stranded Solid • 2 Solid Cu solid 1 Terminal type Al crimp No. per terminal Cu dual setscrew #8-16 #12-16 Conductor data Wire range Cu setscrew No. per terminal Terminal type Cu crimp Wire range Conductor data Catalog symbol [Load /Line] Non-Breakaway terminal data #8 1 — • #6 1 • — #6 1 — • #4 1 • — #3-4 1 — • #2 1 • — #1-2 1 — • R #1/0 1 — • T #2-12 1 • • L #2-12 2† • • Y N P Q D†† Z J Al setscrew K Al dual setscrew W † Not dual wire rated. One wire per opening. †† Fuse holder assemblies using this terminal are not RoHS compliant. Eaton.com/bussmannseries 3 Technical Data 2127 Bussmann series HEB breakaway and non-breakaway in-line fuse holders for UL 13/32” x 1-1/2” supplemental fuses Effective January 2019 Breakaway catalog number system A HEB B Agency Info. UL CSA RLC-A X X Cu crimp #8-16; (2) #12-16 Cu crimp Sol/Str #8-16; (2) #12-16 Sol/Str 5.8 (147) HEB-AA RLC-B X X Cu crimp #8-16; (2) #12-16 Cu crimp Sol/Str #6; (2) #10 5.9 (150) HEB-AB RLC-C X X Cu crimp #8-16; (2) #12-16 Cu crimp Sol/Str #4; (2) #8 6.2 (158) HEB-AC RLC-J X X Cu crimp #8-16; (2) #12-16 Cu Sol/Str setscrew #3-12 Str #10-12 Sol 6.2 (158) HEB-AJ RYC X X Cu crimp #8-16; (2) #12-16 Cu dual Sol/Str setscrew #2-12 Str†; #10-12 Sol† 6.3 (159) HEB-AK RLA — — Cu crimp #8-16; (2) #12-16 Al Sol/Str setscrew #2-12 6.2 (158) HEB-AL RYA — — Cu crimp #8-16; (2) #12-16 Al dual Sol/Str setscrew #2-12† 6.3 (159) HEB-AY RLC-A X X Cu crimp #6; (2) #10 Cu crimp #8-16; (2) #12-16 5.8 (147) HEB-BA RLC-B X X Cu crimp #6; (2) #10 Cu crimp 6#; (2) #10 5.9 (150) HEB-BB RYC X X Cu crimp #6; (2) #10 Cu dual setscrew #2-12 Str†; #10-12 Sol† 6.3 (159) — RLC-J X X Cu setscrew #3-12 Str; #10-12 Sol Cu setscrew #3-12 Str; #10-12 Sol 6.2 (158) HEB-JJ RYC X X Cu setscrew #3-12 Str; #10-12 Sol Cu dual setscrew #2-12 Str†; #10-12 Sol† 6.3 (159) HEB-JK RLC-J X X Cu dual setscrew #2-12 Str†; #10-12 Sol† Cu setscrew #3-12 Str; #10-12 Sol 6.2 (158) — RYC X X Cu dual setscrew #2-12 Str†; #10-12 Sol† Cu dual setscrew #2-12 Str†; #10-12 Sol† 6.3 (159) — RLA — — Al setscrew #2-12 Al setscrew #2-12 6.2 (158) HEB-LL RLC-J — — Al setscrew #2-12 Cu setscrew #3-12 6.2 (158) — RYA — — Al setscrew #2-12 Al dual setscrew #2-12† 6.3 (159) — J K L Specify catalog symbol HEB and the loadside terminal code plus the letter “W.” Then select a lineside terminal code that is available with the loadside terminal. Example: HEB-BW-RCL-B defines a breakaway holder with a loadside copper crimp terminal for a single #6 or two #10 wires with a lineside copper crimp terminal for a single #6 or two #10 wires. Lineside terminal Loadside terminal Catalog symbol HEB - A W - RYC To order: Loadside terminal Terminal type Lineside terminal Wire range* * Stranded conductors unless otherwise noted. † Not dual wire rated. One wire per opening. Dimensions - in (mm): Breakaway A 10.375 (263) Assembled length 4 Eaton.com/bussmannseries Terminal type Wire range* Length A (ref.) Nonbreakaway equivalent Bussmann series HEB breakaway and non-breakaway in-line fuse holders for UL 13/32” x 1-1/2” supplemental fuses Cu dual setscrew 2 • • #6 1 • • #10 2 • • #3-12 1 — • #10-12 1 • — #2-12 2 — • #10-12 2† • — † B J K Cu setscrew Cu dual setscrew Al setscrew #2-12 1 • • † Not dual wire rated. One wire per opening. †† Fuse holder assemblies using this terminal are not RoHS compliant. L #8-16 1 • • #12-16 2 • • #6 1 • • #10 2 • • #4 1 — • #8 2 • • Catalog symbol #10-16 A Stranded • Solid Stranded • Terminal type Cu crimp No. per terminal Solid 1 Conductor data Wire range No. per terminal #8-16 Catalog symbol [Load /Line (2) & (3)] Wire range Conductor data Cu setscrew Effective January 2019 Breakaway lineside terminal data Breakaway loadside terminal data Terminal type Cu crimp Technical Data 2127 -RLC-A -RLC-B -RLC-C†† #3-12 1 — • #10-12 1 • — #2-12 2† — • #10-12 2 † • — #2-12 1 • • -RLA #2-12 2† • • -RYA -RLC-J -RYC Al setscrew Al dual setscrew Eaton.com/bussmannseries 5 Technical Data 2127 Bussmann series HEB breakaway and non-breakaway in-line fuse holders for UL 13/32” x 1-1/2” supplemental fuses Effective January 2019 Recommended crimping tools A wide variety of crimping tools can be used with the HEB fuse holders. Some of the commercially available tools are listed in the table below. This list is not intended to exclude the use of other crimping tools that can provide similar crimps or indents. HEB terminal A B C D Z N, P, Q, R, T T & B P/N (Die) WT-111M (Die C) Sta-Kon ERG4002 (Die C) WT-115A (Die D) TBM5 (Grey Die) WT-115A (Die E) TBM5 (Brown Die) TBM8 (Brown Die) WT-115A (Die F) WT-111M (Die A) Sta-Kon ERG4002 (Die A) TBM8 (Orange Die) The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2019 Eaton All Rights Reserved Printed in USA Publication No. 2127 - BU-SB15154 January 2019 Eaton and Bussmann are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. Sta-Kon is a registered trademark of Thomas & Betts. UL is a registered trademark of the Underwriters Laboratories, Inc. For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Follow us on social media to get the latest product and support information.
HEB-1K0364 价格&库存
很抱歉,暂时无法提供与“HEB-1K0364”相匹配的价格&库存,您可以联系我们找货
