Bussmann®
Modular Fuseblocks
BH-0 Series
0-700 Volts, 100 Amps
Dimensional Data - All tolerances
(± 0.25) mm
(± 0.01) inches
B
71.42
2.81"
54.23
2.13"
Buss
5.33 x 6.60
.21" x .26"
(Typ. 2)
Catalog Symbol: BH-0 Series
Base: Light-weight, high temperature
thermoplastic
Mounting Studs: Plated steel
Nut: Plated steel
Washer: Spring steel
Connector: Tin-plated aluminum. One
hole connector accepts 14 - 2/0 AWG
copper wire. Two hole connector accepts
14 - 1/0 AWG copper wire.
Agency Information:
UL Recognized, Guide IZLT2, File E14853
up to 700V
CSA Certified, Class 6225-01, File 47235
up to 700V
Withstand Rating: 200,000A RMS Sym.
or interrupting rating of fuse used, whichever
is smaller.
Catalog Code Description:
Block Series
Agency Information
0 No Agency Information
1 UL Recognition and CSA Certification
2 UL Recognition Only
3 CSA Certification Only
53.98
2.12"
11.68 x 12.95
.46" x .51"
(Typ. 2)
Buss
A
C
68.20
2.68"
8.64
.34"
6.35
.25"
39.62
1.56"
BH - 0 X X X
Wire Connector
0 No Connector
1 1 Hole for 14 - 2/0 AWG Copper Wire
(for use with Base 0)
2 2 Hole for 14 - 1/0 AWG Copper Wire
Stud Size
1⁄Ω¢ - 20
2fiΩ¡§ - 18
3‹Ω• - 16
NOTES: 1. Always check applicable end use standards for required spacing between blocks, fuses or other hardware.
2. For applications above 700V, consult appropriate electrical standard for proper creepage distances, clearance distances and insulator
voltage withstand ratings.
CE logo denotes compliance with European Union Low Voltage Directive
(50-1000Vac, 75-1500Vdc). Refer to Data Sheet: 8002 or contact
Bussmann Application Engineering at 314-527-1270 for more information.
11-20-02
J02322
Form No. BH-0
Page 1 of 2
Data Sheet: 1200
Bussmann®
Modular Fuseblocks
BH-0 Series
Electrical Characteristics
Fuseblock
Part No.
Stud
Ref.
Fuse Volt
Rating
"A"
Dimensions mm / Inches
"B"
"C"
FBP 35-60
BH-0111
⁄Ω¢
700V
25.41 / 1.482
162.87 / 6.412
71.42 / 2.812
FBP 70-100
BH-0121
⁄Ω¢
700V
38.46 / 1.514
163.68 / 6.444
72.24 / 2.844
FWA 70-100
BH-0111
⁄Ω¢
150V
18.21 / 0.717
143.43 / 5.647
52.00 / 2.047
FWH 35A-60A
BH-0112
fiΩ¡§
500V
27.74 / 1.092
152.96 / 6.022
61.52 / 2.422
FWH 70A-100A
BH-0122
fiΩ¡§
500V
38.86 / 1.530
164.08 / 6.460
72.64 / 2.860
FWP 35A-60A
BH-0112
fiΩ¡§
700V
57.91 / 2.280
183.13 / 7.210
91.69 / 3.610
FWP 70A-100A
BH-0122
fiΩ¡§
700V
56.72 / 2.233
105.74 / 7.163
90.50 / 3.563
FWX 35A-60A
BH-0112
fiΩ¡§
250V
27.74 / 1.092
152.96 / 6.022
61.52 / 2.422
FWX 70A-100A
BH-0112
fiΩ¡§
250V
24.97 / 0.983
15.19 / 5.913
58.75 / 2.313
JJS 70-100
BH-0111
⁄Ω¢
600V
25.96 / 1.022
151.18 / 5.952
59.74 / 2.352
JKS 65-100
BH-0111
⁄Ω¢
600V
53.17 / 2.290
183.39 / 7.220
91.95 / 3.620
KAB 35-60
BH-0112
fiΩ¡§
250V
28.12 / 1.107
153.34 / 6.037
61.90 / 2.437
KAB 70-100
BH-0112
fiΩ¡§
250V
26.54 / 1.045
151.77 / 5.975
60.33 / 2.375
KAC 35-60
BH-0112
fiΩ¡§
600V
58.29 / 2.295
183.52 / 7.225
92.08 / 3.625
KAC 70-100
BH-0113
‹Ω•
600V
64.34 / 2.530
189.48 / 7.460
98.04 / 3.860
KAX 35-60
BH-0112
fiΩ¡§
250V
28.12 / 1.107
153.34 / 6.037
61.90 / 2.437
KAX 70-100
BH-0112
fiΩ¡§
250V
26.54 / 1.045
151.77 / 5.975
60.33 / 2.375
KBC 35-60
BH-0112
fiΩ¡§
600V
58.29 / 2.295
183.52 / 7.225
92.08 / 3.625
KBC 70-100
BH-0121
⁄Ω¢
600V
59.08 / 2.326
184.30 / 7.256
92.86 / 3.656
KBH 35-60
BH-0112
fiΩ¡§
500V
28.12 / 1.107
153.34 / 6.037
61.90 / 2.437
KBH 65-100
BH-0121
⁄Ω¢
500V
39.24 / 1.545
164.47 / 6.475
73.03 / 2.875
KBP 35-100
BH-0111
⁄Ω¢
700V
58.29 / 2.295
183.52 / 7.225
92.08 / 3.625
LPJ 65-100
BH-0111
⁄Ω¢
600V
58.17 / 2.290
183.39 / 7.220
91.95 / 3.620
170M0108 thru 170M0167
BH-0112
⁄Ω¢
660V
44.20 / 1.74
169.42 / 6.67
77.98 / 3.070
170M0208 thru 170M0267
BH-0111
⁄Ω¢
660V
31.24 / 1.23
156.46 / 6.16
65.02 / 2.560
Buss Cat. No.
The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is
intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change
design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
11-20-02
J02322
Form No. BH-0
Page 2 of 2
Data Sheet: 1200
很抱歉,暂时无法提供与“BH-0111”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2837.084531+364.17358
