BH-1003
BH-1003
    EATON(伊顿)
    BH-1003
BH-1003 数据手册
Technical Data 1201 Effective December 2016 Supersedes December 1998 BH-1 modular fuse blocks, 700 V, 400 A Agency information • UL® Recognized, Guide IZLT2, File E14853 up to 700 V • CSA® Certified, Class 6225-01, File 47235 up to 700 V • CE • RoHS compliant Materials Catalog symbol: • BH-1_ Description: Bussmann™ series modular fuse blocks for bolton high speed, 300V and 600 V Class T fuses. See mounting dimensions table for applicable Bussmann series fuse catalog symbols and amp ratings. Specifications: Ratings • Volts - 700 V • Amps - 400 A • Withstand rating - 200 kA RMS Sym. or the applied fuse interrupting rating, whichever is less • Base - light-weight, high temperature thermoplastic • Mounting studs - plated steel • Washer - spring steel • Nuts - plated steel • Connector: tin-plated aluminum Conductors — AWG Cu • Connector accepts 6 - 250 kcmil Technical Data 1201 BH-1 modular fuse blocks, 700 V, 400 A Effective December 2016 Catalog number build-a-code BH - 1 X X X Block family Stud size Agency information* 1: 1/4 - 20 2: 5/16 - 18 3: 3/8 - 16 Wire connector (AWG Cu)* 0: No agency information 1: UL Recognized and CSA Certified 0: No connector 3: 2 hole for 6 - 250 kcmil Notes: 1. Always check applicable end use standards for required spacing between blocks, fuses or other hardware. 2. For applications above 700 V, consult appropriate electrical standard for proper creepage distances, clearance distances and insulator voltage withstand ratings. * Applicable only to BH-100_ configuration — no agency information, no connector. Dimensions: —­mm/in See Table 1 for A, B and C dimensions per fuse catalog symbol/ ampacity and block catalog number from build-a-code. 79.50 3.130" 31.75 1.250" (Typ. 3) 6.60 x 9.53 (Typ. 3) 0.26” x 0.375” 13.97 x 15.62 0.55” x 0.615” B 17.78 0.7" 31.75 1.250" 99.82 3.930" 67.31 2.650" A C 100.96 3.975" 2 Eaton.com/bussmannseries Technical Data 1201 BH-1 modular fuse blocks, 700 V, 400 A Effective December 2016 Table 1. Mounting dimensions - mm (in) Bussmann series fuse catalog symbol (amp range) FBP-_ (125-200 FWA-_ (125-400 FWH-_ (125-200 FWH-_ (225-400 FWP-_ (125-200 FWP-_ (250-400 FWX-_ (125-200 FWX-_ (225-300 JJN-_ (225-400 JJS-_ (110-200 JJS-_ (225-400 KAB-_ (125-200 KAB-_ (225-400 KAC-_ (110-200 KAX-_ (110-200 KAX-_ (225-400 KBC-_ (110-200 KBC-_ (225-400 KBH-_ (125-200 KBH-_ (225-400 KBP-_ (125-200 KBP-_ (225-400 SPJ-4B-_ (50-250 SPJ-4E-_ (50-250 SPP-4B-_ (50-400 SPP-4E-_ (50-400 SPP-4F-_ (50-400 SPP-4H-_ (50-400 170E5448 thru 170E5451 170E7863 thru 170E7864 170E8272 thru 170E8273 170L3661 thru 170L3680 170L3668 thru 170L3670 170L3671 thru 170L3673 170L3675 thru 170L3677 170L3678 thru 170L3680 170L3688 thru 170L3690 170L3691 thru 170L3693 170L3694 thru 170L3696 170L3697 thru 170L3699 170L3775 and 170L3776 170L3779 and 170L3780 170L3783 and 170L3784 170L3787 and 170L3788 170L3791 and 170L3792 170L3795 and 170L3796 170L3800 and 170L3801 170L3804 and 170L3805 170L3808 and 170L3809 170L5777 and 170L5778 )170L5779 thru 170L5783 170L5787 and 170L5788 170L5789 thru 170L5793 Fuse block cat. no. BH-1133 BH-1131 BH-1132 BH-1133 BH-1133 BH-1133 BH-1132 BH-1132 BH-1133 BH-1132 BH-1133 BH-1132 BH-1133 BH-1133 BH-1132 BH-1133 BH-1131 BH-1133 BH-1131 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1132 BH-1133 BH-1132 BH-1132 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 Stud dia. (in) 3/8 1/4 5/16 3/8 3/8 3/8 5/16 5/16 3/8 5/16 3/8 3/8 5/16 3/8 1/4 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 5/16 3/8 5/16 5/16 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 Fuse volts 700 150 500 500 700 700 250 250 300 600 600 250 250 600 250 250 600 600 50 500 700 700 1000 1000 700 700 700 700 2500 2500 2500 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 A 37.59 (1.480) 10.59 (0.417) 29.72 (1.170) 42.42 (1.670) 61.47 (2.420) 63.75 (2.510) 17.02 (0.670) 17.02 (0.670) 1.88 (0.074) 1.872 ( 0.737) 24.08 (0.948) 15.31 (0.605) 25.68 (1.011) 66.17 (2.605) 15.37 (0.605) 25.68 (1.011) 47.90 (1.886) 58.22 (2.292) 28.07 (1.105) 38.38 (1.511) 57.43 (2.261) 57.43 (2.261) 77.27 (3.042) 77.27 (3.042) 40.77 (1.605) 40.77 (1.605) 78.87 (3.105) 78.87 (3.105) 163.07 (6.420) 163.07 (6.420) 163.07 (6.420) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 65.02 (2.560) 65.02 (2.560) 65.02 (2.560) 65.02 (2.560) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) Dimensions — mm B 216.92 (8.540) 189.92 (7.477) 162.89 (8.23) 221.74 (8.730) 238.76 (9.40) 243.08 (9.570) 196.34 (7.73) 196.34 (7.73) 181.20 (7.134) 197.61 (7.78) 203.40 (8.008) 194.6 (7.665) 205.00 (8.071) 245.36 (9.66) 194.69 (7.665) 205.00 (8.071) 227.10 (8.941) 23.754 ( 9.352) 207.34 (8.163) 217.70 (8.571) 236.75 (9.321) 236.75 (9.321) 256.59 (10.102) 256.59 (10.102) 220.09 (8.665) 220.09 (8.665) 258.19 (10.165) 258.19 (10.165) 342.40 (13.480) 342.40 (13.480) 342.40 (13.480) 242.31 (9.542) 242.37 (9.542) 242.37 (9.542) 242.37 (9.542) 242.37 (9.542) 244.35 (9.620) 244.35 (9.620) 244.35 (9.620) 244.35 (9.620) 242.3 (9.542) 242.3 (9.542) 242.3 (9.542) 242.3 (9.542) 242.3 (9.542) 242.3 (9.542) 242.3 (9.542) 242.3 (9.542) 242.3 (9.542) 242.3 (9.542) 242.3 (9.542) 242.3 (9.542) 242.3 (9.542) (in) C 82.55 (3.250) 55.55 (2.187) 74.68 (2.940) 87.38 (3.440) 106.43 (4.190) 87.38 (4.280) 61.98 (2.440) 61.98 (2.440) 46.84 (1.844) 63.68 (2.507) 69.04 (2.718) 60.33 (2.375) 70.64 (2.781) 111.13 (4.375) 60.32 (2.375) 70.64 (2.781) 92.86 (3.656) 103.17 (4.062) 73.03 (2.875) 83.34 (3.281) 102.39 (4.031) 102.39 (4.031) 122.22 (4.812) 122.22 (4.812) 85.73 (3.375) 85.73 (3.375) 123.83 (4.875) 123.83 (4.875) 208.03 (8.190) 208.03 (8.190) 208.03 (8.190) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 109.98 (4.330) 109.98 (4.330) 109.98 (4.330) 109.98 (4.330) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) Eaton.com/bussmannseries 3 Technical Data 1201 BH-1 modular fuse blocks, 700 V, 400 A Effective December 2016 Table 1. Mounting dimensions - mm (in) — continued) Bussmann series fuse catalog symbol (amp range) 170M1308 thru 170M1317 170M1318 thru 170M1322 170M1358 thru 170M1367 170M1368 thru 170M1372 170M1408 thru 170M1417 170M1418 thru 170M1422 170M1458 thru 170M1467 170M1468 thru 170M1472 170M1508 thru 170M1517 170M1518 thru 170M1522 170M2608 thru 170M2614 170M2615 thru 170M2621 170M2658 thru 170M2664 170M2665 thru 170M2671 170M3008 thru 170M3012 170M3013 thru 170M3019 170M3058 thru 170M3062 170M3063 thru 170M3069 170M3108 thru 170M3112 170M3113 thru 170M3119 170M3138 thru 170M3141 170M3142 thru 170M3148 170M3158 thru 170M3162 170M3163 thru 170M3169 170M3188 thru 170M3191 170M3192 thru 170M3198 170M3208 thru 170M3212 170M3213 thru 170M3219 170M3238 thru 170M3241 170M3242 thru 170M3248 170M3258 thru 170M3262 170M3263 thru 170M3269 170M3308 thru 170M3312 170M3313 thru 170M3319 170M3358 thru 170M3362 170M3363 thru 170M3369 170M3608 thru 170M3612 170M3613 thru 170M3619 170M3658 thru 170M3662 170M3663 thru 170M3669 170M3688 thru 170M3691 170M3692 thru 170M3697 170M3708 thru 170M3712 170M3713 thru 170M3719 170M3738 thru 170M3741 170M3742 thru 170M3747 170M3758 thru 170M3762 170M3763 thru 170M3769 4 Fuse block cat. no. BH-1131 BH-1131 BH-1131 BH-1131 BH-1131 BH-1131 BH-1132 BH-1132 BH-1132 BH-1132 BH-1133 BH-1131 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1132 BH-1132 BH-1132 BH-1132 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 BH-1133 Eaton.com/bussmannseries Stud dia. (in) 1/4 1/4 1/4 1/4 1/4 1/4 5/16 5/16 5/16 5/16 3/8 1/4 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8) 3/8) 3/8 3/8 5/16 5/16 5/16 5/16 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 Fuse volts 660 660 660 660 660 660 660 660 660 660 660 660 660 660 660 660 660 660 660 660 1250 1250 660 660 1250 1250 660 660 1250 1250 660 660 660 660 660 660 660 660 660 660 1250 1250 660 660 1250 1250 660 660 A 33.04 (1.300) 33.04 (1.300) 33.04 (1.300) 33.04 (1.300) 33.04 (1.300) 33.04 (1.300) 25.04 (0.986) 25.04 (0.986) 25.04 (0.986) 25.04 (0.986) 33.04 (1.300) 33.04 (1.300) 33.04 (1.300) 33.04 (1.300) 33.04 (1.300) 33.04 (1.300) 33.04 (1.300) 33.04 (1.300) 33.04 (1.300) 33.04 (1.300) 63.04 (2.560) 63.04 (2.560) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 63.04 (2.482) 31.04 (1.222) 31.04 (1.222) 31.04 (1.222) 31.04 (1.222) 40.03 (1.576) 40.03 (1.576) 40.03 (1.576) 40.03 (1.576) 85.04 (3.348) 85.04 (3.348) 78.03 (3.072) 40.03 (1.576) 85.04 (3.348) 85.04 (3.348) 78.03 (3.072) 40.03 (1.576) Dimensions — mm B 212.34 (8.360) 212.34 (8.360) 212.34 (8.360) 212.34 (8.360) 212.34 (8.360) 212.34 (8.360) 204.37 (8.046) 204.37 (8.046) 204.37 (8.046) 204.37 (8.046) 212.34 (8.360) 212.34 (8.360) 212.34 (8.360) 212.34 (8.360) 212.34 (8.360) 212.34 (8.360) 212.34 (8.360) 212.34 (8.360) 212.34 (8.360) 212.34 (8.360) 244.35 (9.620) 244.35 (9.620) 242.37 (9.542) 242.37 (9.542) 242.37 (9.542) 242.37 (9.542) 242.37 (9.542) 242.37 (9.542) 242.37 (9.542) 242.37 (9.542) 242.37 (9.542) 242.37 (9.542) 210.36 (8.282) 210.36 (8.282) 210.36 (8.282) 210.36 (8.282) 219.35 (8.636 219.35 (8.636 219.35 (8.636 219.35 (8.636 264.36 (10.408) 264.36 (10.408) 257.35 (10.132) 219.35 (8.636 264.36 (10.408) 264.36 (10.408) 257.35 (10.132) 219.35 (8.636) (in) C 78.00 (3.070) 78.00 (3.070) 78.00 (3.070) 78.00 (3.070) 78.00 (3.070) 78.00 (3.070) 70.00 (2.756) 70.00 (2.756) 70.00 (2.756) 70.00 (2.756) 78.00 (3.070) 78.00 (3.070) 78.00 (3.070) 78.00 (3.070) 78.00 (3.070) 78.00 (3.070) 78.00 (3.070) 78.00 (3.070) 78.00 (3.070) 78.00 (3.070) 109.98 (4.330) 109.98 (4.330) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 108.00 (4.252) 76.00 (2.992) 76.00 (2.992) 76.00 (2.992) 76.00 (2.992) 84.99 (3.346) 84.99 (3.346) 84.99 (3.346) 84.99 (3.346) 130.00 (5.118) 130.00 (5.118) 122.99 (4.842) 84.99 (3.346) 130.00 (5.118) 130.00 (5.118) 122.99 (4.842) 84.99 (3.346 Technical Data 1201 BH-1 modular fuse blocks, 700 V, 400 A Effective December 2016 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2016 Eaton All Rights Reserved Printed in USA Publication No. 1201 — J02322 December 2016 Eaton.com/bussmannseries Eaton and Bussmann are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information.
BH-1003 价格&库存
很抱歉,暂时无法提供与“BH-1003”相匹配的价格&库存,您可以联系我们找货
BH-1003
  • 1+3445.087001+445.07838
