BH-0112
BH-0112
    EATON(伊顿)
    BH-0112
BH-0112 数据手册
Technical Data 1200 Effective December 2016 Supersedes November 2002 BH-0 modular fuse blocks, 700 V, 100 A Agency information • UL® Recognized, Guide IZLT2, File E14853 up to 700 V • CSA® Certified, Class 6225-01, File 47235 up to 700 V • CE • RoHS compliant Materials Catalog symbol: • BH-0_ Description: Bussmann™ series modular fuse blocks for bolton high speed, Class J (65-100A) and 600 V Class T (700-100 A) fuses. See mounting dimensions table for applicable Bussmann series fuse catalog symbols and amp ratings. Specifications: Ratings • Volts - 700 V • Amps - 100 A • Withstand rating - 200 kA RMS Sym. or the applied fuse interrupting rating, whichever is less • Base - light-weight, high temperature thermoplastic • Mounting studs - plated steel • Washer - spring steel • Nuts - plated steel • Connector: tin-plated aluminum Conductors — AWG Cu • One hole connector accepts 14 - 2/0 • Two hole connector accepts 14 - 1/0 Technical Data 1200 BH-0 modular fuse blocks, 700 V, 100 A Effective December 2016 Catalog number build-a-code BH - 0 X X X Block family Stud size Agency information* Wire connector (AWG Cu)* 0: No agency information 1: UL Recognized and CSA Certified 1: 1/4 - 20 2: 5/16 - 18 3: 3/8 - 16** 0: No connector 1: 1 hole for 14 - 2/0 2: 2 hole for 14 - 1/0 Notes: 1. Always check applicable end use standards for required spacing between blocks, fuses or other hardware. 2. For applications above 700 V, consult appropriate electrical standard for proper creepage distances, clearance distances and insulator voltage withstand ratings. * Applicable only to BH-000_ configuration — no agency information, no connector. ** Not applicable with 2 two (2) hole wire connector option. Dimensions: —­mm/in See Table 1 for A, B and C dimensions per fuse catalog symbol/ ampacity and block catalog number from build-a-code. B 71.42 2.81" 54.23 2.13" 5.33 x 6.60 0.21" x 0.26" (Typ. 2) 53.98 2.12" 11.68 x 12.95 0.46" x 0.51" (Typ. 2) A C 68.20 2.68" 6.35 0.25" 2 Eaton.com/bussmannseries 8.64 0.34" 39.62 1.56" Technical Data 1200 BH-0 modular fuse blocks, 700 V, 100 A Effective December 2016 Table 1. Mounting dimensions - mm (in) Bussmann series fuse catalog symbol FBP-_ FBP-_ FWA-_ FWH-_ FWH-_ FWP-_ FWP-_ FWX-_ FWX-_ JJS-_ JKS-_ KAB-_ KAB-_ KAC-_ KAC-_ KAX-_ KAX-_ KBC-_ KBC-_ KBH-_ KBH-_ KBP-_ LPJ-_ Fuse amp range Fuse block cat. no. Stud dia. (in) 35-60 BH-0111 1/4 70-100 BH-0121 1/4 70-100 BH-0111 1/4 35-60 BH-0112 5/16 70-100 BH-0122 5/16 35-60 BH-0112 5/16 70-100 BH-0122 5/16 35-60 BH-0112 5/16 70-100 BH-0112 5/16 70-100 BH-0111 1/4 65-100 BH-0111 1/4 35-60 BH-0112 5/16 70-100 BH-0112 5/16 35-60 BH-0112 5/16 70-100 BH-0113 3/8 35-60 BH-0112 5/16 70-100 BH-0112 5/16 35-60 BH-0112 5/16 70-100 BH-0121 1/4 35-60 BH-0112 5/16 65-100 BH-0121 1/4 35-100 BH-0111 1/4 65-100 BH-0111 1/4 Fuse volts 700 700 150 500 500 700 700 250 250 600 600 250 250 600 600 250 250 600 600 500 500 700 600 A 25.41 (1.482) 38.46 (1.514) 18.21 (0.717) 27.74 (1.092) 38.86 (1.530) 57.91 (2.280) 56.72 (2.233) 27.74 (1.092) 24.97 (0.983) 25.96 (1.022) 53.17 (2.290) 28.12 (1.107) 26.54 (1.045) 58.29 (2.295) 64.34 (2.530) 28.12 (1.107) 26.54 (1.045) 58.29 (2.295) 59.08 (2.326) 28.12 (1.107) 39.24 (1.545) 58.29 (2.295) 58.17 (2.290) Dimensions — mm B 162.87 (6.412) 163.68 (6.444) 143.43 (5.647) 152.96 (6.022) 164.08 (6.460) 183.13 (7.210) 105.74 (7.163) 152.96 (6.022) 15.19 (5.913) 151.18 (5.952) 183.39 (7.220) 153.34 (6.037) 151.77 (5.975) 183.52 (7.225) 189.48 (7.460) 153.34 (6.037) 151.77 (5.975) 183.52 (7.225) 184.30 (7.256) 153.34 (6.037) 164.47 (6.475) 183.52 (7.225) 183.39 (7.220) (in) C 71.42 (2.812) 72.24 (2.844) 52.00 (2.047) 61.52 (2.422) 72.64 (2.860) 91.69 (3.610) 90.50 (3.563) 61.52 (2.422) 58.75 (2.313) 59.74 (2.352) 91.95 (3.620) 61.90 (2.437) 60.33 (2.375) 92.08 (3.625) 98.04 (3.860) 61.90 (2.437) 60.33 (2.375) 92.08 (3.625) 92.86 (3.656) 61.90 (2.437) 73.03 (2.875) 92.08 (3.625) 91.95 (3.620) The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2016 Eaton All Rights Reserved Printed in USA Publication No. 1200 — J02322 December 2016 Eaton.com/bussmannseries Eaton and Bussmann are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information.
BH-0112 价格&库存
很抱歉,暂时无法提供与“BH-0112”相匹配的价格&库存,您可以联系我们找货
BH-0112
  • 1+3233.179391+418.26111
