Technical Data 1203
Effective December 2016
Supersedes June 2002
BH-3 modular fuse blocks, 700 V, 700 A
Agency information
UL® Recognized, Guide IZLT2, File E14853 up
to 700 V
CSA® Certified, Class 6225-01, File 47235 up to
700 V
CE
RoHS compliant
Materials
Catalog symbol:
BH-3_
Description:
Bussmann™ series modular fuse blocks for bolt-on
high speed, Class J (225-600 A), and 300 V and
600 V Class T (450-600 A)fuses. See mounting
dimensions table for applicable Bussmann series
fuse catalog numbers.
Specifications:
Ratings
Volts - 700 V
Amps - 700 A
Withstand rating - 200 kA RMS Sym. or the
applied fuse interrupting rating, whichever is
less
Base - light-weight, high temperature
thermoplastic
Mounting studs - plated steel
Washer - spring steel
Nuts - plated steel
Connector: tin-plated aluminum
Conductors — AWG Cu
Connector accepts 6 - 250 kcmil
Technical Data 1203
Catalog number build-a-code
BH - 3 X X X
Block family
Stud size
Agency information*
3: 3/8-16
4: 7/16-14
5: 3/8-16L
Wire connector (AWG Cu)*
0: No agency information
1: UL Recognized and CSA Certified
0: No connector
3: 2 hole for 6 - 250 kcmil
4: 2 hole for 4 - 500 kcmil
Notes:
1. The #4 connector must be used with either the 7/16-14 or the 3/8-16L stud.
2. The only compatible connector for the 7/16-14 stud is #4.
3. Always check applicable end use standards for required spacing between blocks, fuses or other hardware.
4. For applications above 700 V, consult appropriate electrical standard for proper creepage distances, clearance distances and insulator
voltage withstand ratings.
* Applicable only to BH-300_ configuration — no agency information, no connector.
Dimensions: —mm/in
See Table 1 for A, B and C dimensions per fuse catalog symbol/
ampacity and block catalog number from Build-a-Code.
B
101.6
4.0"
17.78
0.7"
125.6
4.945"
82.55
3.25"
46.99
(TYP. 3) 1.85"
6.6 x 9.53
0.26" x 0.375"
13.97 x 15.62
0.55" x 0.615"
(TYP. 3)
46.99
1.85"
A
C
98.6
3.882"
2
Eaton.com/bussmannseries
Technical Data 1203
Table 1. Mounting dimensions - mm (in)
Bussmann series fuse catalog symbol
(amp range)
FBP-_ (250-400)
FBP-_ (450-600)
FWA-_ (450-600)
FWH-_ (450-600)
FWP-_ (450-600)
FWX-_ (350-600)
JJN-_ (450-600)
JJS-_ (450-600)
JKS-_ (225-400)
JKS-_ (450-600)
KAA-_ (450-600)
KAB-_ (450-600)
KAC-_ (225-400)
KAC-_ (425-600)
KAX-_ (450-600)
KBC-_ (450-600)
KBP-_ (450-600)
LPJ-_ (225-400)
LPJ-_ (450-600)
SPJ-5B-_ (200-400)
SPJ-5E-_ (200-400)
SPJ-6B-_ (300-600)
SPJ-6E-_ (300-600)
SPP-5B-_ (225-600)
SPP-5E-_ (225-600)
SPP-5F-_ (225-600)
SPP-5H-_ (225-600)
SPP-6B-_ (300-600)
SPP-6E-_ (300-600)
SPP-6F -_ (300-600)
SPP-6H-_ (300-600)
SPP-7B-_ (450-600)
SPP-7E-_ (450-600)
SPP-7F-_ (450-600)
SPP-7H-_ (450-600)
170L4702 thru 170L4720
170L5195 thru 170L5299
170L7295 thru 170L7296
170L7635 thru 170L7636
170L7697 thru 170L7699
170L8124 thru 170L8379
170L8423 thru 170L8429
170L8684 thru 170L8982
170L9300 thru 170L9302
170L9306 thru 170L9308
170M3020 thru 170M3023
170M3070 thru 170M3073
170M3120 thru 170M3123
170M3170 thru 170M3173
170M3220 thru 170M3223
170M3270 thru 170M3273
170M3320 thru 170M3323
170M3370 thru 170M3373
Fuse block
cat. no.
BH-3144
BH-3144
BH-3145
BH-3145
BH-3144
BH-3145
BH-3144
BH-3144
BH-3145
BH-3144
BH-3145
BH-3145
BH-3144
BH-3144
BH-3145
BH-3145
BH-3144
BH-3145
BH-3144
BH-3144
BH-3144
BH-3144
BH-3144
BH-3144
BH-3144
BH-3144
BH-3144
BH-3144
BH-3144
BH-3144
BH-3144
BH-3144
BH-3144
BH-3144
BH-3144
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3144
BH-3144
BH-3144
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3144
BH-3144
Stud dia. (in) Fuse volts
7/16
700
7/16
700
3/8
150
3/8
500
7/16
700)
3/8
250)
7/16)
300
7/16
600
3/8
600
7/16
600
3/8
130
3/8
250)
7/16
600
7/16
600
3/8
250)
3/8
600
7/16
700
3/8
600
7/16
600
7/16
1000
7/16
1000
7/16
1000
7/16
1000
7/16
700
7/16
700
7/16
700
7/16
700
7/16
700
7/16
700
7/16
700
7/16
700
7/16
700
7/16
700
7/16
700
7/16
700
3/8
1000
3/8
1000
3/8
1000
3/8
1000
3/8
1000
3/8
1000
3/8
1000
7/16
1000
7/16
1000
7/16
1000
3/8
660
3/8
660
3/8
660
3/8
660
3/8
660
3/8
660
7/16
660)
7/16
660)
A
59.46 (2.341)
65.02 (2.56)
20.57 (0.81)
46.74 (1.84)
102.36 (4.03)
31.75 (1.25)
8.66 (0.341)
32.08 (1.263)
90.42 (3.56)
109.47 (4.31)
18.97 (0.747)
27.71 (1.091)
77.72 (3.06)
77.72 (3.06)
27.71 (1.091)
60.33 (2.372)
86.44 (3.403)
90.42 (3.56)
109.47 (4.31)
82.83 (3.261)
82.83 (3.261)
84.86 (3.341)
84.86 (3.341)
61.04 (2.403))
61.04 (2.403))
82.47 (3.247)
82.47 (3.247)
61.04 (2.403)
61.04 (2.403)
82.47 (3.247)
82.47 (3.247)
62.64 (2.466)
62.64 (2.466)
81.69 (3.216)
81.69 (3.216)
67.06 (2.64)
65.07 (2.562)
65.07 (2.562)
65.07 (2.562)
65.07 (2.562)
65.07 (2.562)
65.07 (2.562)
72.06 (2.837)
72.06 (2.837)
72.06 (2.837)
35.05 (1.38)
35.05 (1.38)
35.05 (1.38)
65.07 (2.562)
65.07 (2.562)
65.07 (2.562)
33.07 (1.302)
33.07 (1.302)
Dimensions — mm (in)
B
C
288.06 (11.341)
102.39 (4.031)
293.62 (11.56)
107.95 (4.25)
249.1 (79.81)
63.50 (2.50)
275.34 (10.84)
89.68 (3.53)
330.96 (13.03)
145.29 (5.72)
260.35 (10.25)
74.68 (2.94)
237.26 (9.341)
51.59 (2.031)
260.68 (10.263)
75.01 (2.953)
319.02 (12.56)
133.35 (5.25)
338.07 (13.31)
152.40 (6.00)
247.57 (9.747)
61.90 (2.437)
256.31 (10.091
70.64 (2.781)
306.32 (12.06)
120.65 (4.75)
306.32 (3.06)
120.65 (4.75)
256.31 (10.091)
70.64 (2.781)
288.85 (11.372)
103.17 (4.062)
315.04 (12.403)
129.36 (5.093)
319.02 (12.56)
133.35 (5.25)
338.07 (13.31)
152.40 (6.00)
262.15 (10.321)
127.79 (5.031)
262.15 (10.321)
127.79 (5.031)
313.46 (12.341)
127.79 (5.031)
313.46 (12.341)
127.79 (5.031)
289.64 (11.403)
103.96 (4.093)
289.64 (11.403)
103.96 (4.093)
311.07 (12.247)
125.40 (4.937)
311.07 (12.247)
125.40 (4.937)
289.64 (11.403)
103.96 (4.093)
289.64 (11.403)
103.96 (4.093)
311.07 (12.247)
125.40 (4.937)
311.07 (12.247)
125.40 (4.937)
291.24 (11.466)
105.56 (4.156)
291.24 (11.466)
105.56 (4.156)
310.29 (12.216)
124.61 (4.906)
310.29 (12.216)
124.61 (4.906)
295.66 (11.642)
109.98 (4.33)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
300.66 (11.837)
114.99 (4.527)
300.66 (11.837)
114.99 (4.527)
300.66 (11.837)
114.99 (4.527)
263.65 (10.38)
77.98 (3.07)
263.65 (10.38)
77.98 (3.07)
263.65 (10.38)
77.98 (3.07)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
261.67 (10.302)
76.00 (2.992)
261.67 (10.302)
76.00 (2.992)
3
Technical Data 1203
Table 1. Mounting dimensions - mm (in) continued
(amp range)
170M3620 thru 170M3623
170M3670 thru 170M3673
170M3720 thru 170M3723
170M3770 thru 170M3773
170M4008 thru 170M4017
170M4058 thru 170M4067
170M4108 thru 170M4117
170M4138 thru 170M4247
170M4158 thru 170M4166
170M4167 thru 170M4208
170M4217 thru 170M4247
170M4258 thru 170M4267
170M4308 thru 170M4317
170M4358 thru 170M4367
170M4608 thru 170M4617
170M4658 thru 170M4667
170M4688 thru 170M4697
170M4708 thru 170M4717
170M4738 thru 170M4747
170M4758 thru 170M4767
170M5008 thru 170M5013
170M5058 thru 170M5063
170M5108 thru 170M5113
170M5138 thru 170M5147
170M5158 thru 170M5163
170M5188 thru 170M5197
170M5208 thru 170M5213
170M5238 thru 170M5247
170M5258 thru 170M5263
170M5308 thru 170M5313
170M5358 thru 170M5363
170M5608 thru 170M5613
170M5658 thru 170M5663
170M5688 thru 170M5696
170M5708 thru 170M5713
170M5738 thru 170M5746
170M5758 thru 170M5763
170M6008 thru 170M6011
170M6058 thru 170M6061
170M6108 thru 170M6111
170M6138 thru 170M6145
170M6158 thru 170M6161
170M6188 thru 170M6195
170M6208 thru 170M6211
170M6238 thru 170M6245
170M6258 thru 170M6261
170M6308 thru 170M6311
170M6358 thru 170M6361
4
Fuse block
cat. no.
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3144
BH-3144
BH-3144
BH-3144
BH-3144
BH-3144
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3144
BH-3144
BH-3144
BH-3144
BH-3144
BH-3144
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3145
BH-3144
BH-3144
Stud dia.
(in)
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
7/16
7/16
7/16
7/16
7/16
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
7/16
7/16
7/16
7/16
7/16
7/16
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
7/16
7/16
Fuse volts
660
660
660
660
660
660
660
1250
660
660
660
660
660
660
660
660
1250
660
1250
660
660
660
660
1250
660
1250
660
1250
660
660
660
660
660
1250
660
1250
660
660
660
660
1250
660
1250
660
1250
660
660
660
A
42.06 (1.656)
42.06 (1.656)
80.06 (3.152)
80.06 (3.152)
35.05 (1.38)
35.05 (1.38)
35.05 (1.38)
65.07 (2.562)
65.07 (2.562)
65.07 (2.562)
65.07 (2.562)
65.07 (2.562)
43.08 (1.696)
43.08 (1.696)
61.06 (2.404)
61.06 (2.404)
84.07 (3.31)
83.06 (3.27)
84.07 (3.31)
83.06 (3.27)
35.05 (1.38)
35.05 (1.38)
35.05 (1.38)
65.07 (0.562)
65.07 (0.562)
65.07 (0.562)
65.07 (0.562)
65.07 (0.562)
65.07 (0.562)
48.08 (1.893)
48.08 (1.893)
62.08 (2.444)
62.08 (2.444)
84.07 (3.31)
82.07 (3.231)
84.07 (3.31)
82.07 (3.231)
35.05 (1.38)
35.05 (1.38)
35.05 (1.38)
65.07 (2.562)
65.07 (2.562)
65.07 (2.562)
65.07 (2.562)
65.07 (2.562)
65.07 (2.562)
48.08 (1.893)
48.08 (1.893)
B
C
270.66 (10.656)
84.99 (3.346)
270.66 (10.656)
84.99 (3.346)
308.66 (12.152)
122.99 (4.842)
308.66 (12.152)
122.99 (4.842)
263.65 (10.38)
77.98 (3.07)
263.65 (10.38)
77.98 (3.07)
263.65 (10.38)
77.98 (3.07)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
271.68 (10.696)
86.00 (3.386)
271.68 (10.696)
86.00 (3.386)
289.66 (11.404)
103.99 (4.094)
289.66 (11.404)
103.99 (4.09)
312.67 (12.31)
127.00 (5.00)
311.66 (12.27)
125.98 (4.96)
312.67 (12.31)
127.00 (5.00)
311.66 (12.27)
125.98 (4.96)
263.65 (10.38)
77.98 (3.07)
263.65 (10.38)
77.98 (3.07)
263.65 (10.38)
77.98 (3.07)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
276.68 (10.893)
91.01 (3.583)
276.68 (10.893)
91.01 (3.583)
290.68 (11.444)
105.00 (4.134)
290.68 (11.444)
105.00 (4.134)
312.67 (12.31)
127.00 (5.00)
310.67 (12.231)
124.99 (4.921)
312.67 (12.31)
127.00 (5.00)
310.67 (12.231)
124.99 (4.921)
263.65 (10.38)
77.98 (3.07)
263.65 (10.38)
77.98 (3.07)
263.65 (10.38)
77.98 (3.07)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
293.67 (11.562)
108.00 (4.252)
276.68 (10.893)
91.01 (3.583)
276.68 (10.893)
91.01 (3.583)
Technical Data 1203
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are
by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the
end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit
distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once
a product has been selected, it should be tested by the user in all possible applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2016 Eaton
All Rights Reserved
Printed in USA
Publication No. 1203 — N02099
December 2016
Eaton and Bussmann are valuable trademarks
of Eaton in the U.S. and other countries. You
are not permitted to use the Eaton trademarks
without prior written consent of Eaton.
CSA is a registered trademark of the Canadian
Standards Group.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“BH-3033”相匹配的价格&库存,您可以联系我们找货
