170H3005
170H3005
    EATON(伊顿)
    170H3005
170H3005 数据手册
Bussmann ® Square Body – Accessories Fuse Bases (Blocks) DIN 43 653 Fuse Bases For the Typower ZILOX fuses according to DIN 43 653, the following fuse bases are available: Part Number 170H3003 170H3004 170H3005 170H3006 Max. Voltage 1000V 1000V 1400V 1400V Rated Current 630A 1250A 630A 1250A DIN 43 653 Center Distance 80mm 80mm 110mm 110mm The fuse bases rated 1250A can also be used for the fuses with higher rated current if the maximum load current is derated according to the table below: Fuse Rating 1400A 1500A 1600A 1800A 2000A Max. Load Current In Fuse Base 1325A 1400A 1500A 1650A 1800A DIN 43 653 Fixed Center Base Style Max. Voltage 170H1007 1000V 170H1013 660V U.L. Recognized to U.L. 512. Max. Fuse Current Rating 400A 200A Fuse Size 00, 000 0000,000 Universal Fuse Bases For the Typower ZILOX fuses according to DIN 43 653, French style and North American style, the following fuse bases are available: Modular Base Style 1BS101 1BS102 1BS103 1BS104 BH-0xxx BH-1xxx BH-2xxx BH-3xxx Max. Voltage 600V 600V 600V 600V 700V 2500V 5000V 1250V Max. Fuse Current Rating 100A 400A 400A 600A 100A 400A 400A 700A BIF Document 1206 1207 1208 1209 1200 1201 1202 1203 Universal Modular fuse bases are U.L. Recognized to U.L. 512 and meet the spacing requirements of U.L. 347. Contact Bussmann sales representative for more complete ordering information. DIN 43 620 Fuse Bases For fuse bases used with Typower ZILOX fuses according to DIN 43 620, please contact your local Bussmann sales representative. 7-11-01 SB01191 The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Form No. Page 1 of 1 BIF Doc #720036
170H3005 价格&库存
很抱歉,暂时无法提供与“170H3005”相匹配的价格&库存,您可以联系我们找货
170H3005
  • 1+3386.80892
  • 5+3251.34572
  • 20+3115.87212
  • 50+3048.19259
库存:2
