Technical Data 1201
Effective December 2016
Supersedes December 1998
BH-1 modular fuse blocks, 700 V, 400 A
Agency information
UL® Recognized, Guide IZLT2, File E14853 up
to 700 V
CSA® Certified, Class 6225-01, File 47235 up to
700 V
CE
RoHS compliant
Materials
Catalog symbol:
BH-1_
Description:
Bussmann™ series modular fuse blocks for bolton high speed, 300V and 600 V Class T fuses.
See mounting dimensions table for applicable
Bussmann series fuse catalog symbols and amp
ratings.
Specifications:
Ratings
Volts - 700 V
Amps - 400 A
Withstand rating - 200 kA RMS Sym. or the
applied fuse interrupting rating, whichever is
less
Base - light-weight, high temperature
thermoplastic
Mounting studs - plated steel
Washer - spring steel
Nuts - plated steel
Connector: tin-plated aluminum
Conductors — AWG Cu
Connector accepts 6 - 250 kcmil
Technical Data 1201
Catalog number build-a-code
BH - 1 X X X
Block family
Stud size
Agency information*
1: 1/4 - 20
2: 5/16 - 18
3: 3/8 - 16
Wire connector (AWG Cu)*
0: No agency information
1: UL Recognized and CSA Certified
0: No connector
3: 2 hole for 6 - 250 kcmil
Notes:
1. Always check applicable end use standards for required spacing between blocks, fuses or other hardware.
2. For applications above 700 V, consult appropriate electrical standard for proper creepage distances, clearance distances and insulator
voltage withstand ratings.
* Applicable only to BH-100_ configuration — no agency information, no connector.
Dimensions: —mm/in
See Table 1 for A, B and C dimensions per fuse catalog symbol/
ampacity and block catalog number from build-a-code.
79.50
3.130"
31.75
1.250"
(Typ. 3)
6.60 x 9.53
(Typ. 3)
0.26” x 0.375” 13.97 x 15.62
0.55” x 0.615”
B
17.78
0.7"
31.75
1.250"
99.82
3.930"
67.31
2.650"
A
C
100.96
3.975"
2
Eaton.com/bussmannseries
Technical Data 1201
Table 1. Mounting dimensions - mm (in)
symbol (amp range)
FBP-_ (125-200
FWA-_ (125-400
FWH-_ (125-200
FWH-_ (225-400
FWP-_ (125-200
FWP-_ (250-400
FWX-_ (125-200
FWX-_ (225-300
JJN-_ (225-400
JJS-_ (110-200
JJS-_ (225-400
KAB-_ (125-200
KAB-_ (225-400
KAC-_ (110-200
KAX-_ (110-200
KAX-_ (225-400
KBC-_ (110-200
KBC-_ (225-400
KBH-_ (125-200
KBH-_ (225-400
KBP-_ (125-200
KBP-_ (225-400
SPJ-4B-_ (50-250
SPJ-4E-_ (50-250
SPP-4B-_ (50-400
SPP-4E-_ (50-400
SPP-4F-_ (50-400
SPP-4H-_ (50-400
170E5448 thru 170E5451
170E7863 thru 170E7864
170E8272 thru 170E8273
170L3661 thru 170L3680
170L3668 thru 170L3670
170L3671 thru 170L3673
170L3675 thru 170L3677
170L3678 thru 170L3680
170L3688 thru 170L3690
170L3691 thru 170L3693
170L3694 thru 170L3696
170L3697 thru 170L3699
170L3775 and 170L3776
170L3779 and 170L3780
170L3783 and 170L3784
170L3787 and 170L3788
170L3791 and 170L3792
170L3795 and 170L3796
170L3800 and 170L3801
170L3804 and 170L3805
170L3808 and 170L3809
170L5777 and 170L5778
)170L5779 thru 170L5783
170L5787 and 170L5788
170L5789 thru 170L5793
Fuse block cat.
no.
BH-1133
BH-1131
BH-1132
BH-1133
BH-1133
BH-1133
BH-1132
BH-1132
BH-1133
BH-1132
BH-1133
BH-1132
BH-1133
BH-1133
BH-1132
BH-1133
BH-1131
BH-1133
BH-1131
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1132
BH-1133
BH-1132
BH-1132
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
Stud dia. (in)
3/8
1/4
5/16
3/8
3/8
3/8
5/16
5/16
3/8
5/16
3/8
3/8
5/16
3/8
1/4
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
5/16
3/8
5/16
5/16
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
Fuse volts
700
150
500
500
700
700
250
250
300
600
600
250
250
600
250
250
600
600
50
500
700
700
1000
1000
700
700
700
700
2500
2500
2500
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
1000
A
37.59 (1.480)
10.59 (0.417)
29.72 (1.170)
42.42 (1.670)
61.47 (2.420)
63.75 (2.510)
17.02 (0.670)
17.02 (0.670)
1.88 (0.074)
1.872 ( 0.737)
24.08 (0.948)
15.31 (0.605)
25.68 (1.011)
66.17 (2.605)
15.37 (0.605)
25.68 (1.011)
47.90 (1.886)
58.22 (2.292)
28.07 (1.105)
38.38 (1.511)
57.43 (2.261)
57.43 (2.261)
77.27 (3.042)
77.27 (3.042)
40.77 (1.605)
40.77 (1.605)
78.87 (3.105)
78.87 (3.105)
163.07 (6.420)
163.07 (6.420)
163.07 (6.420)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
65.02 (2.560)
65.02 (2.560)
65.02 (2.560)
65.02 (2.560)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
Dimensions — mm
B
216.92 (8.540)
189.92 (7.477)
162.89 (8.23)
221.74 (8.730)
238.76 (9.40)
243.08 (9.570)
196.34 (7.73)
196.34 (7.73)
181.20 (7.134)
197.61 (7.78)
203.40 (8.008)
194.6 (7.665)
205.00 (8.071)
245.36 (9.66)
194.69 (7.665)
205.00 (8.071)
227.10 (8.941)
23.754 ( 9.352)
207.34 (8.163)
217.70 (8.571)
236.75 (9.321)
236.75 (9.321)
256.59 (10.102)
256.59 (10.102)
220.09 (8.665)
220.09 (8.665)
258.19 (10.165)
258.19 (10.165)
342.40 (13.480)
342.40 (13.480)
342.40 (13.480)
242.31 (9.542)
242.37 (9.542)
242.37 (9.542)
242.37 (9.542)
242.37 (9.542)
244.35 (9.620)
244.35 (9.620)
244.35 (9.620)
244.35 (9.620)
242.3 (9.542)
242.3 (9.542)
242.3 (9.542)
242.3 (9.542)
242.3 (9.542)
242.3 (9.542)
242.3 (9.542)
242.3 (9.542)
242.3 (9.542)
242.3 (9.542)
242.3 (9.542)
242.3 (9.542)
242.3 (9.542)
(in)
C
82.55 (3.250)
55.55 (2.187)
74.68 (2.940)
87.38 (3.440)
106.43 (4.190)
87.38 (4.280)
61.98 (2.440)
61.98 (2.440)
46.84 (1.844)
63.68 (2.507)
69.04 (2.718)
60.33 (2.375)
70.64 (2.781)
111.13 (4.375)
60.32 (2.375)
70.64 (2.781)
92.86 (3.656)
103.17 (4.062)
73.03 (2.875)
83.34 (3.281)
102.39 (4.031)
102.39 (4.031)
122.22 (4.812)
122.22 (4.812)
85.73 (3.375)
85.73 (3.375)
123.83 (4.875)
123.83 (4.875)
208.03 (8.190)
208.03 (8.190)
208.03 (8.190)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
109.98 (4.330)
109.98 (4.330)
109.98 (4.330)
109.98 (4.330)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
3
Technical Data 1201
Table 1. Mounting dimensions - mm (in) — continued)
symbol (amp range)
170M1308 thru 170M1317
170M1318 thru 170M1322
170M1358 thru 170M1367
170M1368 thru 170M1372
170M1408 thru 170M1417
170M1418 thru 170M1422
170M1458 thru 170M1467
170M1468 thru 170M1472
170M1508 thru 170M1517
170M1518 thru 170M1522
170M2608 thru 170M2614
170M2615 thru 170M2621
170M2658 thru 170M2664
170M2665 thru 170M2671
170M3008 thru 170M3012
170M3013 thru 170M3019
170M3058 thru 170M3062
170M3063 thru 170M3069
170M3108 thru 170M3112
170M3113 thru 170M3119
170M3138 thru 170M3141
170M3142 thru 170M3148
170M3158 thru 170M3162
170M3163 thru 170M3169
170M3188 thru 170M3191
170M3192 thru 170M3198
170M3208 thru 170M3212
170M3213 thru 170M3219
170M3238 thru 170M3241
170M3242 thru 170M3248
170M3258 thru 170M3262
170M3263 thru 170M3269
170M3308 thru 170M3312
170M3313 thru 170M3319
170M3358 thru 170M3362
170M3363 thru 170M3369
170M3608 thru 170M3612
170M3613 thru 170M3619
170M3658 thru 170M3662
170M3663 thru 170M3669
170M3688 thru 170M3691
170M3692 thru 170M3697
170M3708 thru 170M3712
170M3713 thru 170M3719
170M3738 thru 170M3741
170M3742 thru 170M3747
170M3758 thru 170M3762
170M3763 thru 170M3769
4
Fuse block cat.
no.
BH-1131
BH-1131
BH-1131
BH-1131
BH-1131
BH-1131
BH-1132
BH-1132
BH-1132
BH-1132
BH-1133
BH-1131
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1132
BH-1132
BH-1132
BH-1132
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
BH-1133
Stud dia. (in)
1/4
1/4
1/4
1/4
1/4
1/4
5/16
5/16
5/16
5/16
3/8
1/4
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8)
3/8)
3/8
3/8
5/16
5/16
5/16
5/16
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
3/8
Fuse volts
660
660
660
660
660
660
660
660
660
660
660
660
660
660
660
660
660
660
660
660
1250
1250
660
660
1250
1250
660
660
1250
1250
660
660
660
660
660
660
660
660
660
660
1250
1250
660
660
1250
1250
660
660
A
33.04 (1.300)
33.04 (1.300)
33.04 (1.300)
33.04 (1.300)
33.04 (1.300)
33.04 (1.300)
25.04 (0.986)
25.04 (0.986)
25.04 (0.986)
25.04 (0.986)
33.04 (1.300)
33.04 (1.300)
33.04 (1.300)
33.04 (1.300)
33.04 (1.300)
33.04 (1.300)
33.04 (1.300)
33.04 (1.300)
33.04 (1.300)
33.04 (1.300)
63.04 (2.560)
63.04 (2.560)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
63.04 (2.482)
31.04 (1.222)
31.04 (1.222)
31.04 (1.222)
31.04 (1.222)
40.03 (1.576)
40.03 (1.576)
40.03 (1.576)
40.03 (1.576)
85.04 (3.348)
85.04 (3.348)
78.03 (3.072)
40.03 (1.576)
85.04 (3.348)
85.04 (3.348)
78.03 (3.072)
40.03 (1.576)
Dimensions — mm
B
212.34 (8.360)
212.34 (8.360)
212.34 (8.360)
212.34 (8.360)
212.34 (8.360)
212.34 (8.360)
204.37 (8.046)
204.37 (8.046)
204.37 (8.046)
204.37 (8.046)
212.34 (8.360)
212.34 (8.360)
212.34 (8.360)
212.34 (8.360)
212.34 (8.360)
212.34 (8.360)
212.34 (8.360)
212.34 (8.360)
212.34 (8.360)
212.34 (8.360)
244.35 (9.620)
244.35 (9.620)
242.37 (9.542)
242.37 (9.542)
242.37 (9.542)
242.37 (9.542)
242.37 (9.542)
242.37 (9.542)
242.37 (9.542)
242.37 (9.542)
242.37 (9.542)
242.37 (9.542)
210.36 (8.282)
210.36 (8.282)
210.36 (8.282)
210.36 (8.282)
219.35 (8.636
219.35 (8.636
219.35 (8.636
219.35 (8.636
264.36 (10.408)
264.36 (10.408)
257.35 (10.132)
219.35 (8.636
264.36 (10.408)
264.36 (10.408)
257.35 (10.132)
219.35 (8.636)
(in)
C
78.00 (3.070)
78.00 (3.070)
78.00 (3.070)
78.00 (3.070)
78.00 (3.070)
78.00 (3.070)
70.00 (2.756)
70.00 (2.756)
70.00 (2.756)
70.00 (2.756)
78.00 (3.070)
78.00 (3.070)
78.00 (3.070)
78.00 (3.070)
78.00 (3.070)
78.00 (3.070)
78.00 (3.070)
78.00 (3.070)
78.00 (3.070)
78.00 (3.070)
109.98 (4.330)
109.98 (4.330)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
108.00 (4.252)
76.00 (2.992)
76.00 (2.992)
76.00 (2.992)
76.00 (2.992)
84.99 (3.346)
84.99 (3.346)
84.99 (3.346)
84.99 (3.346)
130.00 (5.118)
130.00 (5.118)
122.99 (4.842)
84.99 (3.346)
130.00 (5.118)
130.00 (5.118)
122.99 (4.842)
84.99 (3.346
Technical Data 1201
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are
by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the
end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit
distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once
a product has been selected, it should be tested by the user in all possible applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2016 Eaton
All Rights Reserved
Printed in USA
Publication No. 1201 — J02322
December 2016
Eaton and Bussmann are valuable trademarks
of Eaton in the U.S. and other countries. You
are not permitted to use the Eaton trademarks
without prior written consent of Eaton.
CSA is a registered trademark of the Canadian
Standards Group.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“BH-1133”相匹配的价格&库存,您可以联系我们找货
