14x51mm Modular Fuse Holder
Description: Compact DIN-Rail mount fuse holders for
14x51mm cylindrical fuse links. Available in different versions
with fuse indicator, neutral and microswitch.
CH14B-PV models for use with solar gPV fuse links available
in 1 and 2-pole versions
Packaging: 1-pole: 6 per pack
2-pole: 3 per pack
3-pole: 2 per pack
4-pole: 1 per pack
Catalogue Symbol:
CH14(# of poles)B: standard fuse holder
CH141BNX: neutral fuse holder
CH14(# of poles)BN: standard fuse holder and neutral
CH14(# of poles)BI: fuse holder with neon indicator
CH14(# of poles)BNI: fuse holder with neutral and neon indicator
CH14(# of poles)BMS-F: fuse holder with microswitch
(pre-breaking/fuse operation/presence)
CH14(# of poles)BNMS-F: fuse holder with neutral and microswitch
CH14(# of poles)BMS: fuse holder with microswitch (fuse operation)
CH143BNMS: 3-pole and neutral with microswitch (fuse operation)
CH14(# of poles)B-PV: photovoltaic fuse holder
Technical Data:
Number of Poles: 1 to 4
FWH-5A14F
FWH-10A14F
FWH-15A14F
FWH-20A14F
FWH-25A14F
FWH-30A14F
FWX-5A14F
FWX-10A14F
FWX-15A14F
FWX-20A14F
FWX-25A14F
FWX-30A14F
Maximum
Continuous
Fuse Current
5A
10A
14A
18A
21A
22A
5A
10A
15A
20A
24A
27A
Part Number*
FWP-5A14F
FWP-10A14F
FWP-15A14F
FWP-20A14F
FWP-25A14F
FWP-30A14F
FWP-32A14F
FWP-40A14F
FWP-50A14F
Maximum
Continuous
Fuse Current
5A
10A
14A
18A
21A
22A
27A
32A
38A
CH14B Series
690Vac
750Vac
CH14B-PV Series 1500Vdc
N/A
Rated Current
IEC
UL
CH14B Series
50A
50A
CH14B-PV Series
32A
N/A
Features
Silver-plated copper contacts
Engineered polymer enables greater performance with
melting temperature in excess of 300°C
Ventilation zones optimized for a better heat dissipation
Accessory to isolate the fuse holder via a padlock
IP20 security accessory to improve protection
Label holder for easy circuit identification
PV version rated at 1500Vdc (IEC only) for use with gPV
fuse links
Standards/Certifications:
IEC 60269-1, 60269-2, 60947-1, 60947-3
UL4248-1 Fuse Holders, UL 486A-B Wiring Terminals
CSA C22.2 No 4248.1 Fuse Holders, C22.2 No 65 Wiring Terminals
18-12-12
UL
Environmental
RoHS compliant
*Please contact Cooper Bussmann Application Engineers if you wish to use
a FWP fuse link with a striker option.
IEC
Rated Power Acceptance: 5W
Maximum Power Acceptance: 6W
Utilisation Category: 50A at AC-21B 690V/AC-22B 500V
Pollution Degree: 3
Protection Index: IP20
Rated Insulation Voltage: 8kV Uimp
SCCR Rating: 200kA, 33kAdc for CH14B-PV
Terminal Size: 1.5-35mm2 /16-3 AWG solid cable, Cu only
1.5-25mm2 / 16-4 AWG stranded cable, Cu only
Service Temperature: -20oC to 70oC
Storage Temperature: -40oC to 80oC
Compatible Fuse Links:
C14G and C14M 14x51mm fuse links
PV-(amp rating)A14F Photovoltaic gPV fuse links
FW ferrule fuse links, see table below
Part Number
Rated Voltage
UL File: E14853
BU-SB12028
Form 14x51MFH
Page 1 of 3
Data Sheet 720148
Part Numbers System
Old Part
Number
Neutral Only
New Part
Number
CH141DNX
CH141BNX
Number
Description
of Poles
1
Neutral cylindrical fuse holder
Fuse Holder Only
CH141D
CH141B
1
1-pole cylindrical fuse holder
CH142D
CH142B
2
2-pole cylindrical fuse holder
CH143D
CH143B
3
3-pole cylindrical fuse holder
CH144D
CH144B
4
4-pole cylindrical fuse holder
Fuse Holder and Neutral
CH141DN
CH141BN
2
1-pole + neutral cylindrical fuse holder
CH143DN
CH143DN
4
3-pole + neutral cylindrical fuse holder
Fuse Holder with Neon Indicator
CH141DI
CH141BI
1
1-pole cylindrical fuse holder with neon indicator
CH142DI
CH142BI
2
2-pole cylindrical fuse holder with neon indicator
CH143DI
CH143BI
3
3-pole cylindrical fuse holder with neon indicator
CH144DI
CH144BI
4
4-pole cylindrical fuse holder with neon indicator
Fuse Holder with Neon Indicator and Neutral
CH141DNI
CH141BNI
2
1-pole + neutral cylindrical fuse holder with neon indicator
CH143DNI
CH143BNI
4
3-pole + neutral cylindrical fuse holder with neon indicator
Fuse Holder with Microswitch
CH141DMS
CH141BMS
1
1-pole cylindrical fuse holder with microswitch (fuse operation)
CH141DMS-F
CH141BMS-F
1
1-pole cylindrical fuse holder with microswitch (pre-breaking/fuse operation/presence)
CH143DMS
CH143BMS
3
3-pole cylindrical fuse holder with microswitch (fuse operation)
CH143DMS-F
CH143BMS-F
3
3-pole cylindrical fuse holder with microswitch (pre-breaking/fuse operation/presence)
Fuse Holder with Microswitch and Neutral
CH143DNMS-F CH143BNMS-F
4
CH143DNMS
4
CH143DNMS
3-pole + neutral cylindrical fuse holder with microswitch (pre-breaking/fuse operation/
presence)
3-pole + neutral cylindrical fuse holder with microswitch (fuse operation)
Accessories
Part Number
Description
Unit Packing
AL-D
Multi-pole ganging clips, one kit will gang up to 4-poles together
12
CH14-HP
Multi-pole handle pins, one kit will gang up to 12 handles together
12
CH14-L
Lockout padlock support, it will accept up to 5mm diameter padlock shank
10mm2
5
CH14-IP20
IP20 protection accessory, provides IP20 protection to terminals with
CH14-MS1
1-pole microswitch accessory, provides detection of a blown fuse link
5
CH14-MS3
3-pole microswitch accessory, provides detection of a blown fuse link
3
18-12-12
BU-SB12028
Form 14x51MFH
Page 2 of 3
or less cable
Data Sheet 720148
12
Dimensions (mm)
18-12-12
BU-SB12028
Form 14x51MFH
Page 3 of 3
Data Sheet 720148
很抱歉,暂时无法提供与“CH143BMS”相匹配的价格&库存,您可以联系我们找货
