Bussmann®
Class R Fuseblocks
R600 Series
600 Volts
Catalog Symbol: R600 Series
Ampere Rating: ⁄Ω¡º to 600A
Voltage Rating: 600V
Agency Information:
UL Listed, UL 512, Guide IZLT, File E14853
CSA Certified, C22.2 No. 39, Class 6225-01, File 47235
Withstand Rating: 200,000A RMS Sym.
For use with Class R fuses (LPS-RK and FRS-R)
UL Flammability: 94VO
Materials: Thermoplastic
Class R Fuseblocks (600V) Catalog Data (for LRS-RK, FRS-R, DLS-R and KTS-R Fuses)
Poles
Terminal Type (Suffix No.)
Basic
Catalog
Number
R60030-1
R60030-2
R60030-3
R60060-1
R60060-2
R60060-3
R60100-1
R60100-2
R60100-3
Screw w/
Pres.
Plate
SR
PR
SR
PR
SR
PR
Amps
⁄Ω¡º
1
to
2
30
3
31
1
to
2
60
3
61
1
to
2
100
3
101
1
R60200-1 —
to
3
R60200-3 —
200
201
1
R60400-1 —
to
3
R60400-3 —
400
401
1
R60600-1 —
to
3
R60600-3 —
600
†No UL, No CSA Certification.
‡UL Recognized, CSA Certification
Box Lug w/
Clip
— Cu Only
CR
COR
CR
COR
CR
COR
CR
COR
CR
COR
CR
COR
CR
COR
CR
COR
CR
COR
Dimensions (Inches)
0.259
Quick- Fig.
Connect No.
1
2
3
4
5
6
7
8
CRQ†
9
A
B
6.25
1.73
C
1.54
2.90
4.25
D
E
F
G
H
J Dia.
x
C’ Bore
1.56
0.25
0.62
3.13
1.56
0.28 x 0.5
K
.26
COR #2-14 CU ONLY
(See Figures)
CR #2-14 CU, #2-8 AL
9.5
2.38
2.22
4.03
5.84
2.63
0.67
4.25
1.81
0.28 x 0.5
0.34
0.88
Wire
Range
COR #6-14 CU ONLY
CR #2-14 CU, #2-12 AL
PR, SR #10-18 CU ONLY
CR
CR
CRQ†
10
11
9.63
3.09
3.0
3.31
0.5
2.0
3.0
(See Figures)
0.75
0.31
CR‡
CR†
COR‡
10
12
12.0
4.0
3.0
4.5
0.63 1.75
3.0
(See Figures)
1.0
0.56
CR
CR†
10
13
14.0
4.97
3.0
5.5
1.125 1.75
4.0
(See Figures)
1.0
0.56
COR 1/0 -8 CU ONLY
CR, CRQ 1/0-8 CU/AL
CR, CRQ
250kcmil-6 CU/AL
COR
500kcmil-4/0 CU ONLY
CR 500kcmil-4 CU/AL
CR (2) 500kcmil-4/0 CU/AL
Dimensional Data: See pages 2 and 3.
CE logo denotes compliance with European Union Low Voltage Directive (50-1000Vac, 75-1500Vdc). Refer to
Data Sheet: 8002 or contact Bussmann Application Engineering at 314-527-1270 for more information.
10-4-02
SB02295
Form No. R600 Series
Page 1 of 3
Data Sheet: 1111
Bussmann®
Class R Fuseblocks
R600 Series
600 Volts
Dimensional Data
600V, ⁄Ω¡º to 30A
C
B
K
E
F
C
C
H
E
F
F
H
H
J
J
J
A
G
D
FIGURE 1.
FIGURE 2.
FIGURE 3.
600V, 31 to 60A
3.38"
1.56"
0.59"
1.81"
2.06"
0.25"
0.62"
4.94"
1.56"
1.56"
0.59"
0.62"
0.62"
0.28" DIA. x
0.5" C'BORE
7.36"
2.38"
3.125"
2.125"
FIGURE 4.
FIGURE 5.
FIGURE 6.
600V, 61 to 100A
C
B
K
C
C
F
E
E
F
H
F
H
H
J
J
J
A
G
D
FIGURE 7.
10-4-02
SB02295
FIGURE 8.
FIGURE 9.
Page 2 of 3
Data Sheet: 1111
Bussmann®
Class R Fuseblocks
R600 Series
600 Volts
600V, 101 to 200A
600V, 101 to 600A
B
H
K
G
F
E
9.0"
8.0"
6.5"
3.15"
.75"
0.34
DIAMETER
0.75"
C'BORE
0.34
DIAMETER
0.75" DIA.
C'BORE
.50" Deep
C A
9.58"
5.5"
3.0"
D
2.04"
FIGURE 10.
FIGURE 11.
600V, 201 to 400A
600V, 401 to 600A
11.63"
9.25"
4.02"
1.00"
1.19"
2.13"
0.34
DIAMETER
0.75" DIA.
C'BORE
.67" Deep
12.00"
7.00"
0.34
DIAMETER
0.75" DIA.
C'BORE
.67" Deep
15.26"
11.0"
4.987"
1.00"
14.00"
8.00"
2.5"
3.00"
FIGURE 12.
FIGURE 13.
The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is
intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change
design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
10-4-02
SB02295
Page 3 of 3
Data Sheet: 1111
很抱歉,暂时无法提供与“R60100-3COR”相匹配的价格&库存,您可以联系我们找货
