CH Series Modular Fuse Holders
Class J
Class J – 600V 1-60A
Features:
• Choice of Indication:
–easyID™ window to view indicator on Cooper Bussmann
LPJ-(amp)SPI fuses.
–Neon lamp open fuse indicator.
• Comes in standard 1-, 2- & 3-Pole ganged assemblies
(all fuses are extracted simultaneously).
• Kits are available for ganging units in the field.
• Meets requirements of IEC 60529 for IP20 finger-safe rating.
• 35mm DIN rail and panel (6-32 UNC pan head
recommended) mounting.
• Fuse holder wire ports dual wire rated from 18 to 3AWG.
Specifications:
Fuse Sizes
600Vac/dc
Amperage Rating
Up to 30A
Wire Range
30A Version
60A Version
Catalog Symbol: CH30J_(I) - 30A
CH60J_(I) - 60A
Amp Range: 1 to 60A
Voltage Rating: 600Vac/dc (or less)
Withstand Rating (SCCR): 200kA RMS Sym.
Agency Information:
CE, Listed UL 512, Guide IZLT, File E14853
CSA Certified per C22.2 Nos. 39 Class 6225-01,
File LR47235
Recommended Cooper Bussmann Fuses:
Class J time-delay with indication LPJ-SPI (Data Sheet 1062)
Class J time-delay LPJ (Data Sheet 1006)
Class J fast-acting JKS (Data Sheet 1026)
High Speed Class J Drive Fuse DFJ (Data Sheet 1048)
01-09 BU-SB08182
0 to 30A Class J
Voltage Rating
35 to 60A Class J
600Vac/dc
Up to 60A
IP Rating
18-1AWG Single
18-3AWG Dual
75°C
10-18AWG/24in-lb
1-8AWG/35in-lb
IP20 (Finger-Safe)
18-1AWG Single
18-3AWG Dual
75°C
10-18AWG/24in-lb
1-8AWG/35in-lb
IP20 (Finger-Safe)
Clip Material
Tin-Plated Copper
Tin-Plated Copper
UL 94V0
Thermoplastic
90Vac/115Vdc
UL 94V0
Thermoplastic
90Vac/115Vdc
Terminal Torque
Housing Material
Minimum Indicating Voltage
(Neon Lamp)
Nominal Operating Current
(Neon Lamp)
Max Operating Temperature
Storage & Operating
Temperature Range*
34mA (460Vac)
85°C
-20°C to 75°C
34mA (460Vac)
85°C
-20°C to 75°C
*For fuse selection on applications above or below 25°C, consult derating charts in Cooper Bussmann publication
“Selecting Protective Devices” (SPD).
Page 1 of 2
Data Sheet 2144
Catalog Numbers
Max Fuse Size
30A AND 60A
Ganging Assembly
30A
60A
easyID™ Window
Neon Lamp Indicating
1-Pole
CH30J1
CH30J1I
2-Pole
CH30J2
CH30J2I
3-Pole
CH30J3
CH30J3I
1-Pole
CH60J1
CH60J1I
2-Pole
CH60J2
CH60J2I
3-Pole
CH60J3
CH60J3I
Accessories
Part Number
Description
Carton Qty.
2A1073
Ganging Kit
(Single Pole)
1 Spring Pins
3 Plastic Connectors
2A1777
Circuit Markers
100
E
H
D
3-Pole Class J
Modular Fuse Holder
G
Dimensions - in (mm)
F
Dimension
CH30J
CH60J
A
1.28 (32.5)
1.58 (40.0)
B
2.56 (65.0)
3.16 (80.0)
C
3.84 (97.5)
4.72 (120.0)
D
4.59 (116.6)
4.88 (124.0)
E
2.83 (71.8)
3.31 (84.1)
F
3.56 (90.4)
3.85 (97.9)
G
1.28 (32.5)
1.58 (40.0)
H
0.18 (4.44)
0.18 (4.44)
A
B
C
The only controlled copy of this Data Sheet is the electronic read-only version located on the Cooper Bussmann Network Drive. All other copies of
this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Cooper Bussmann reserves the right, without notice, to change design or construction of
any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice,
any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
© 2009 Cooper Bussmann
St. Louis, MO 63178
www.cooperbussmann.com
01-09 BU-SB08182
Page 2 of 2
Data Sheet 2144
很抱歉,暂时无法提供与“CH60J3I”相匹配的价格&库存,您可以联系我们找货
