BH-3144
BH-3144
    EATON(伊顿)
    BH-3144
BH-3144 数据手册
Technical Data 1203 Effective December 2016 Supersedes June 2002 BH-3 modular fuse blocks, 700 V, 700 A Agency information • UL® Recognized, Guide IZLT2, File E14853 up to 700 V • CSA® Certified, Class 6225-01, File 47235 up to 700 V • CE • RoHS compliant Materials Catalog symbol: • BH-3_ Description: Bussmann™ series modular fuse blocks for bolt-on high speed, Class J (225-600 A), and 300 V and 600 V Class T (450-600 A)fuses. See mounting dimensions table for applicable Bussmann series fuse catalog numbers. Specifications: Ratings • Volts - 700 V • Amps - 700 A • Withstand rating - 200 kA RMS Sym. or the applied fuse interrupting rating, whichever is less • Base - light-weight, high temperature thermoplastic • Mounting studs - plated steel • Washer - spring steel • Nuts - plated steel • Connector: tin-plated aluminum Conductors — AWG Cu • Connector accepts 6 - 250 kcmil Technical Data 1203 BH-3 modular fuse blocks, 700 V, 700 A Effective December 2016 Catalog number build-a-code BH - 3 X X X Block family Stud size Agency information* 3: 3/8-16 4: 7/16-14 5: 3/8-16L Wire connector (AWG Cu)* 0: No agency information 1: UL Recognized and CSA Certified 0: No connector 3: 2 hole for 6 - 250 kcmil 4: 2 hole for 4 - 500 kcmil Notes: 1. The #4 connector must be used with either the 7/16-14 or the 3/8-16L stud. 2. The only compatible connector for the 7/16-14 stud is #4. 3. Always check applicable end use standards for required spacing between blocks, fuses or other hardware. 4. For applications above 700 V, consult appropriate electrical standard for proper creepage distances, clearance distances and insulator voltage withstand ratings. * Applicable only to BH-300_ configuration — no agency information, no connector. Dimensions: —­mm/in See Table 1 for A, B and C dimensions per fuse catalog symbol/ ampacity and block catalog number from Build-a-Code. B 101.6 4.0" 17.78 0.7" 125.6 4.945" 82.55 3.25" 46.99 (TYP. 3) 1.85" 6.6 x 9.53 0.26" x 0.375" 13.97 x 15.62 0.55" x 0.615" (TYP. 3) 46.99 1.85" A C 98.6 3.882" 2 Eaton.com/bussmannseries Technical Data 1203 BH-3 modular fuse blocks, 700 V, 700 A Effective December 2016 Table 1. Mounting dimensions - mm (in) Bussmann series fuse catalog symbol (amp range) FBP-_ (250-400) FBP-_ (450-600) FWA-_ (450-600) FWH-_ (450-600) FWP-_ (450-600) FWX-_ (350-600) JJN-_ (450-600) JJS-_ (450-600) JKS-_ (225-400) JKS-_ (450-600) KAA-_ (450-600) KAB-_ (450-600) KAC-_ (225-400) KAC-_ (425-600) KAX-_ (450-600) KBC-_ (450-600) KBP-_ (450-600) LPJ-_ (225-400) LPJ-_ (450-600) SPJ-5B-_ (200-400) SPJ-5E-_ (200-400) SPJ-6B-_ (300-600) SPJ-6E-_ (300-600) SPP-5B-_ (225-600) SPP-5E-_ (225-600) SPP-5F-_ (225-600) SPP-5H-_ (225-600) SPP-6B-_ (300-600) SPP-6E-_ (300-600) SPP-6F -_ (300-600) SPP-6H-_ (300-600) SPP-7B-_ (450-600) SPP-7E-_ (450-600) SPP-7F-_ (450-600) SPP-7H-_ (450-600) 170L4702 thru 170L4720 170L5195 thru 170L5299 170L7295 thru 170L7296 170L7635 thru 170L7636 170L7697 thru 170L7699 170L8124 thru 170L8379 170L8423 thru 170L8429 170L8684 thru 170L8982 170L9300 thru 170L9302 170L9306 thru 170L9308 170M3020 thru 170M3023 170M3070 thru 170M3073 170M3120 thru 170M3123 170M3170 thru 170M3173 170M3220 thru 170M3223 170M3270 thru 170M3273 170M3320 thru 170M3323 170M3370 thru 170M3373 Fuse block cat. no. BH-3144 BH-3144 BH-3145 BH-3145 BH-3144 BH-3145 BH-3144 BH-3144 BH-3145 BH-3144 BH-3145 BH-3145 BH-3144 BH-3144 BH-3145 BH-3145 BH-3144 BH-3145 BH-3144 BH-3144 BH-3144 BH-3144 BH-3144 BH-3144 BH-3144 BH-3144 BH-3144 BH-3144 BH-3144 BH-3144 BH-3144 BH-3144 BH-3144 BH-3144 BH-3144 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3144 BH-3144 BH-3144 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3144 BH-3144 Stud dia. (in) Fuse volts 7/16 700 7/16 700 3/8 150 3/8 500 7/16 700) 3/8 250) 7/16) 300 7/16 600 3/8 600 7/16 600 3/8 130 3/8 250) 7/16 600 7/16 600 3/8 250) 3/8 600 7/16 700 3/8 600 7/16 600 7/16 1000 7/16 1000 7/16 1000 7/16 1000 7/16 700 7/16 700 7/16 700 7/16 700 7/16 700 7/16 700 7/16 700 7/16 700 7/16 700 7/16 700 7/16 700 7/16 700 3/8 1000 3/8 1000 3/8 1000 3/8 1000 3/8 1000 3/8 1000 3/8 1000 7/16 1000 7/16 1000 7/16 1000 3/8 660 3/8 660 3/8 660 3/8 660 3/8 660 3/8 660 7/16 660) 7/16 660) A 59.46 (2.341) 65.02 (2.56) 20.57 (0.81) 46.74 (1.84) 102.36 (4.03) 31.75 (1.25) 8.66 (0.341) 32.08 (1.263) 90.42 (3.56) 109.47 (4.31) 18.97 (0.747) 27.71 (1.091) 77.72 (3.06) 77.72 (3.06) 27.71 (1.091) 60.33 (2.372) 86.44 (3.403) 90.42 (3.56) 109.47 (4.31) 82.83 (3.261) 82.83 (3.261) 84.86 (3.341) 84.86 (3.341) 61.04 (2.403)) 61.04 (2.403)) 82.47 (3.247) 82.47 (3.247) 61.04 (2.403) 61.04 (2.403) 82.47 (3.247) 82.47 (3.247) 62.64 (2.466) 62.64 (2.466) 81.69 (3.216) 81.69 (3.216) 67.06 (2.64) 65.07 (2.562) 65.07 (2.562) 65.07 (2.562) 65.07 (2.562) 65.07 (2.562) 65.07 (2.562) 72.06 (2.837) 72.06 (2.837) 72.06 (2.837) 35.05 (1.38) 35.05 (1.38) 35.05 (1.38) 65.07 (2.562) 65.07 (2.562) 65.07 (2.562) 33.07 (1.302) 33.07 (1.302) Dimensions — mm (in) B C 288.06 (11.341) 102.39 (4.031) 293.62 (11.56) 107.95 (4.25) 249.1 (79.81) 63.50 (2.50) 275.34 (10.84) 89.68 (3.53) 330.96 (13.03) 145.29 (5.72) 260.35 (10.25) 74.68 (2.94) 237.26 (9.341) 51.59 (2.031) 260.68 (10.263) 75.01 (2.953) 319.02 (12.56) 133.35 (5.25) 338.07 (13.31) 152.40 (6.00) 247.57 (9.747) 61.90 (2.437) 256.31 (10.091 70.64 (2.781) 306.32 (12.06) 120.65 (4.75) 306.32 (3.06) 120.65 (4.75) 256.31 (10.091) 70.64 (2.781) 288.85 (11.372) 103.17 (4.062) 315.04 (12.403) 129.36 (5.093) 319.02 (12.56) 133.35 (5.25) 338.07 (13.31) 152.40 (6.00) 262.15 (10.321) 127.79 (5.031) 262.15 (10.321) 127.79 (5.031) 313.46 (12.341) 127.79 (5.031) 313.46 (12.341) 127.79 (5.031) 289.64 (11.403) 103.96 (4.093) 289.64 (11.403) 103.96 (4.093) 311.07 (12.247) 125.40 (4.937) 311.07 (12.247) 125.40 (4.937) 289.64 (11.403) 103.96 (4.093) 289.64 (11.403) 103.96 (4.093) 311.07 (12.247) 125.40 (4.937) 311.07 (12.247) 125.40 (4.937) 291.24 (11.466) 105.56 (4.156) 291.24 (11.466) 105.56 (4.156) 310.29 (12.216) 124.61 (4.906) 310.29 (12.216) 124.61 (4.906) 295.66 (11.642) 109.98 (4.33) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 300.66 (11.837) 114.99 (4.527) 300.66 (11.837) 114.99 (4.527) 300.66 (11.837) 114.99 (4.527) 263.65 (10.38) 77.98 (3.07) 263.65 (10.38) 77.98 (3.07) 263.65 (10.38) 77.98 (3.07) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 261.67 (10.302) 76.00 (2.992) 261.67 (10.302) 76.00 (2.992) Eaton.com/bussmannseries 3 Technical Data 1203 BH-3 modular fuse blocks, 700 V, 700 A Effective December 2016 Table 1. Mounting dimensions - mm (in) continued Bussmann series fuse catalog symbol (amp range) 170M3620 thru 170M3623 170M3670 thru 170M3673 170M3720 thru 170M3723 170M3770 thru 170M3773 170M4008 thru 170M4017 170M4058 thru 170M4067 170M4108 thru 170M4117 170M4138 thru 170M4247 170M4158 thru 170M4166 170M4167 thru 170M4208 170M4217 thru 170M4247 170M4258 thru 170M4267 170M4308 thru 170M4317 170M4358 thru 170M4367 170M4608 thru 170M4617 170M4658 thru 170M4667 170M4688 thru 170M4697 170M4708 thru 170M4717 170M4738 thru 170M4747 170M4758 thru 170M4767 170M5008 thru 170M5013 170M5058 thru 170M5063 170M5108 thru 170M5113 170M5138 thru 170M5147 170M5158 thru 170M5163 170M5188 thru 170M5197 170M5208 thru 170M5213 170M5238 thru 170M5247 170M5258 thru 170M5263 170M5308 thru 170M5313 170M5358 thru 170M5363 170M5608 thru 170M5613 170M5658 thru 170M5663 170M5688 thru 170M5696 170M5708 thru 170M5713 170M5738 thru 170M5746 170M5758 thru 170M5763 170M6008 thru 170M6011 170M6058 thru 170M6061 170M6108 thru 170M6111 170M6138 thru 170M6145 170M6158 thru 170M6161 170M6188 thru 170M6195 170M6208 thru 170M6211 170M6238 thru 170M6245 170M6258 thru 170M6261 170M6308 thru 170M6311 170M6358 thru 170M6361 4 Eaton.com/bussmannseries Fuse block cat. no. BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3144 BH-3144 BH-3144 BH-3144 BH-3144 BH-3144 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3144 BH-3144 BH-3144 BH-3144 BH-3144 BH-3144 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3145 BH-3144 BH-3144 Stud dia. (in) 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 7/16 7/16 7/16 7/16 7/16 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 7/16 7/16 7/16 7/16 7/16 7/16 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 3/8 7/16 7/16 Fuse volts 660 660 660 660 660 660 660 1250 660 660 660 660 660 660 660 660 1250 660 1250 660 660 660 660 1250 660 1250 660 1250 660 660 660 660 660 1250 660 1250 660 660 660 660 1250 660 1250 660 1250 660 660 660 A 42.06 (1.656) 42.06 (1.656) 80.06 (3.152) 80.06 (3.152) 35.05 (1.38) 35.05 (1.38) 35.05 (1.38) 65.07 (2.562) 65.07 (2.562) 65.07 (2.562) 65.07 (2.562) 65.07 (2.562) 43.08 (1.696) 43.08 (1.696) 61.06 (2.404) 61.06 (2.404) 84.07 (3.31) 83.06 (3.27) 84.07 (3.31) 83.06 (3.27) 35.05 (1.38) 35.05 (1.38) 35.05 (1.38) 65.07 (0.562) 65.07 (0.562) 65.07 (0.562) 65.07 (0.562) 65.07 (0.562) 65.07 (0.562) 48.08 (1.893) 48.08 (1.893) 62.08 (2.444) 62.08 (2.444) 84.07 (3.31) 82.07 (3.231) 84.07 (3.31) 82.07 (3.231) 35.05 (1.38) 35.05 (1.38) 35.05 (1.38) 65.07 (2.562) 65.07 (2.562) 65.07 (2.562) 65.07 (2.562) 65.07 (2.562) 65.07 (2.562) 48.08 (1.893) 48.08 (1.893) Dimensions — mm (in) B C 270.66 (10.656) 84.99 (3.346) 270.66 (10.656) 84.99 (3.346) 308.66 (12.152) 122.99 (4.842) 308.66 (12.152) 122.99 (4.842) 263.65 (10.38) 77.98 (3.07) 263.65 (10.38) 77.98 (3.07) 263.65 (10.38) 77.98 (3.07) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 271.68 (10.696) 86.00 (3.386) 271.68 (10.696) 86.00 (3.386) 289.66 (11.404) 103.99 (4.094) 289.66 (11.404) 103.99 (4.09) 312.67 (12.31) 127.00 (5.00) 311.66 (12.27) 125.98 (4.96) 312.67 (12.31) 127.00 (5.00) 311.66 (12.27) 125.98 (4.96) 263.65 (10.38) 77.98 (3.07) 263.65 (10.38) 77.98 (3.07) 263.65 (10.38) 77.98 (3.07) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 276.68 (10.893) 91.01 (3.583) 276.68 (10.893) 91.01 (3.583) 290.68 (11.444) 105.00 (4.134) 290.68 (11.444) 105.00 (4.134) 312.67 (12.31) 127.00 (5.00) 310.67 (12.231) 124.99 (4.921) 312.67 (12.31) 127.00 (5.00) 310.67 (12.231) 124.99 (4.921) 263.65 (10.38) 77.98 (3.07) 263.65 (10.38) 77.98 (3.07) 263.65 (10.38) 77.98 (3.07) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 293.67 (11.562) 108.00 (4.252) 276.68 (10.893) 91.01 (3.583) 276.68 (10.893) 91.01 (3.583) Technical Data 1203 BH-3 modular fuse blocks, 700 V, 700 A Effective December 2016 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2016 Eaton All Rights Reserved Printed in USA Publication No. 1203 — N02099 December 2016 Eaton.com/bussmannseries Eaton and Bussmann are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information.
BH-3144 价格&库存
很抱歉,暂时无法提供与“BH-3144”相匹配的价格&库存,您可以联系我们找货
