BH-2033
BH-2033
    EATON(伊顿)
    BH-2033
BH-2033 数据手册
Technical Data 1202 Effective December 2016 Supersedes June 2002 BH-2 modular fuse blocks, 700 V, 400 A Agency information • UL® Recognized, Guide IZLT2, File E14853 up to 700 V • CSA® Certified, Class 6225-01, File 47235 up to 700 V • CE • RoHS compliant Materials Catalog symbol: • BH-2_ Description: Bussmann™ series modular fuse blocks for bolton high speed fuses. See mounting dimensions table for applicable Bussmann series fuse catalog numbers. Specifications: Ratings • Volts - 700 V • Amps - 400 A • Withstand rating - 200 kA RMS Sym. or the applied fuse interrupting rating, whichever is less • Base - light-weight, high temperature thermoplastic • Mounting studs - plated steel • Washer - spring steel • Nuts - plated steel • Connector: tin-plated aluminum Conductors — AWG Cu • Connector accepts 6 - 250 kcmil Technical Data 1202 BH-2 modular fuse blocks, 700 V, 400 A Effective December 2016 Catalog number build-a-code BH - 2 X X X Block family Stud size Agency information* Wire connector (AWG Cu)* 0: No agency information 1: UL Recognized and CSA Certified 1: 1/4 - 20 2: 5/16 - 18 3: 3/8 - 16 0: No connector 3: 2 hole for 6 - 250 kcmil Notes: 1. Always check applicable end use standards for required spacing between blocks, fuses or other hardware. 2. For applications above 700 V, consult appropriate electrical standard for proper creepage distances, clearance distances and insulator voltage withstand ratings. * Applicable only to BH-200_ configuration — no agency information, no connector. Dimensions: —­mm/in See Table 1 for A, B and C dimensions per fuse catalog symbol/ ampacity and block catalog number from build-a-code. (Typ. 3) 13.97 x 15.62 0.55" x .615" 79.50 3.13” B 17.78 0.7" 99.82 3.93" 6.60 x 9.53 0.26" x 0.375" (Typ. 3) 67.31 2.65" 31.75 1.25" 31.75 1.25" A C 126.36 4.975" Table 1. Mounting dimensions - mm (in) Bussmann series fuse catalog symbol (amp range) 170E7183 170E7184 170E7185 170E7187 170E7188 170E7189 170E8129 170E9629 170E9630 2 Fuse block cat. no. Stud dia. (in) BH-2033 3/8 BH-2033 3/8 BH-2033 3/8 BH-2033 3/8 BH-2033 3/8 BH-2033 3/8 BH-2033 3/8 BH-2033 3/8 BH-2033 3/8 Eaton.com/bussmannseries Fuse volts 5000 5000 5000 5000 5000 5000 3300 4000 4000 A 450.09 (17.720) 450.09 (17.720) 450.09 (17.720) 450.09 (17.720) 450.09 (17.720) 450.09 (17.720) 163.07 (6.420) 299.97 (11.810) 299.97 (11.810) Dimensions — mm (in) B C 629.41 (24.780) 495.05 (19.490) 629.41 (24.780) 495.05 (19.490) 629.41 (24.780) 495.05 (19.490) 629.41 (24.780) 495.05 (19.490) 629.41 (24.780) 495.05 (19.490) 629.41 (24.780) 495.05 (19.490) 342.39 (13.480) 208.03 (8.190) 479.30 (18.870) 344.93 (13.580) 479.30 (18.870) 344.93 (13.580) Technical Data 1202 BH-2 modular fuse blocks, 700 V, 400 A Effective December 2016 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2016 Eaton All Rights Reserved Printed in USA Publication No. 1201 — N02099 December 2016 Eaton.com/bussmannseries Eaton and Bussmann are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information.
BH-2033 价格&库存
很抱歉,暂时无法提供与“BH-2033”相匹配的价格&库存,您可以联系我们找货
BH-2033
  • 1+8466.732041+1100.64777
