Technical Data 1202
Effective December 2016
Supersedes June 2002
BH-2 modular fuse blocks, 700 V, 400 A
Agency information
UL® Recognized, Guide IZLT2, File E14853 up
to 700 V
CSA® Certified, Class 6225-01, File 47235 up to
700 V
CE
RoHS compliant
Materials
Catalog symbol:
BH-2_
Description:
Bussmann™ series modular fuse blocks for bolton high speed fuses. See mounting dimensions
table for applicable Bussmann series fuse catalog
numbers.
Specifications:
Ratings
Volts - 700 V
Amps - 400 A
Withstand rating - 200 kA RMS Sym. or the
applied fuse interrupting rating, whichever is
less
Base - light-weight, high temperature
thermoplastic
Mounting studs - plated steel
Washer - spring steel
Nuts - plated steel
Connector: tin-plated aluminum
Conductors — AWG Cu
Connector accepts 6 - 250 kcmil
Technical Data 1202
Catalog number build-a-code
BH - 2 X X X
Block family
Stud size
Agency information*
Wire connector (AWG Cu)*
0: No agency information
1: UL Recognized and CSA Certified
1: 1/4 - 20
2: 5/16 - 18
3: 3/8 - 16
0: No connector
3: 2 hole for 6 - 250 kcmil
Notes:
1. Always check applicable end use standards for required spacing between blocks, fuses or other hardware.
2. For applications above 700 V, consult appropriate electrical standard for proper creepage distances, clearance distances and insulator
voltage withstand ratings.
* Applicable only to BH-200_ configuration — no agency information, no connector.
Dimensions: —mm/in
See Table 1 for A, B and C dimensions per fuse catalog symbol/
ampacity and block catalog number from build-a-code.
(Typ. 3)
13.97 x 15.62
0.55" x .615"
79.50
3.13”
B
17.78
0.7"
99.82
3.93"
6.60 x 9.53
0.26" x 0.375"
(Typ. 3)
67.31
2.65"
31.75
1.25"
31.75
1.25"
A
C
126.36
4.975"
Table 1. Mounting dimensions - mm (in)
catalog symbol (amp range)
170E7183
170E7184
170E7185
170E7187
170E7188
170E7189
170E8129
170E9629
170E9630
2
Fuse block cat.
no.
Stud dia. (in)
BH-2033
3/8
BH-2033
3/8
BH-2033
3/8
BH-2033
3/8
BH-2033
3/8
BH-2033
3/8
BH-2033
3/8
BH-2033
3/8
BH-2033
3/8
Eaton.com/bussmannseries
Fuse volts
5000
5000
5000
5000
5000
5000
3300
4000
4000
A
450.09 (17.720)
450.09 (17.720)
450.09 (17.720)
450.09 (17.720)
450.09 (17.720)
450.09 (17.720)
163.07 (6.420)
299.97 (11.810)
299.97 (11.810)
Dimensions — mm (in)
B
C
629.41 (24.780)
495.05 (19.490)
629.41 (24.780)
495.05 (19.490)
629.41 (24.780)
495.05 (19.490)
629.41 (24.780)
495.05 (19.490)
629.41 (24.780)
495.05 (19.490)
629.41 (24.780)
495.05 (19.490)
342.39 (13.480)
208.03 (8.190)
479.30 (18.870)
344.93 (13.580)
479.30 (18.870)
344.93 (13.580)
Technical Data 1202
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are
by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the
end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit
distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once
a product has been selected, it should be tested by the user in all possible applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2016 Eaton
All Rights Reserved
Printed in USA
Publication No. 1201 — N02099
December 2016
Eaton and Bussmann are valuable trademarks
of Eaton in the U.S. and other countries. You
are not permitted to use the Eaton trademarks
without prior written consent of Eaton.
CSA is a registered trademark of the Canadian
Standards Group.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“BH-2002”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1834.63920
- 200+709.98120
- 500+685.03320
- 1000+672.71040
