Technical Data 10192
Effective June 2021
Supersedes June 2016
Up to 400 A Class J ferrule and
knifeblade power distribution fuse blocks
Features and benefits:
30 and 60 amp modular ferrule
blocks.
100, 200 and 400 amp
modular knifeblade blocks.
Combination power distribution block and fuse
block reduces wire connections and total panel
components, using up to 65 percent less panel
space and reducing installation time and labor
by an average of 33 percent when compared
with traditional fuse block/power distribution
block solutions.
A 200,000 amp withstand rating helps achieve
a higher assembly short-circuit current rating
(SCCR) for compliance with NEC® sections
110.10, 409.110(4), 409.22, 440.4(B), 670.3(A)(4)
and 670.5.
Optional see-through cover enhances safety
with IP20 finger-safe protection, lockout/tagout
capability and open circuit indication.
Available in 1-, 2- and 3-pole configurations to
meet stocking requirements.
To reduce inventory, assembly time and labor,
modular single-pole blocks snap-together for
tool-less assembly of multiple poles at point of
use.
Blocks rated up to 60 amps feature DIN-Rail
and panel mount versatility, which allows one
product to be used for multiple applications
without incurring additional inventory cost.
Catalog symbols:
JM60030-_MW_
JM60060-_MW_
JM60100-_MW_
JM60200-_MW_
JM60400-_MW_
Description:
Bussmann® series Class J fuse block features
power distribution capability.
This patented design simplifies panel layouts
and uses up to 65 percent less panel space.
Additionally, it lowers inventory costs while
reducing installation time and labor by an average
of 33 percent.
Furthermore, this design uses fewer wire
connections, reducing watts loss and overall
operating temperature of the panel.
Class J ferrule and knifeblade power distribution fuse blocks
Effective June 2021
Specifications:
Operating and storage temperature range
Fuse class
Blocks: -40°C to +120°C
Covers:
• Non-indicating -40°C to +120°C
Class J
Ratings
Volts: 600 V
Amps: up to 400 A
Withstand rating (SCCR): 200 kA Sym RMS
Materials
Agency information
Base: Thermoplastic
Terminals: Tin-plated aluminum
CSA Certified 47235 — 6225-01
Covers: UL Listed UL E58836 – JDVS
RoHS compliant
1-, 2-, 3-pole
Mounting
30 and 60 amp blocks DIN-Rail and panel mount
100, 200 and 400 amp blocks panel mount only
75°C/90°C Cu/Al (unless otherwise noted)
Accessories:
Poles
Conductors
Blocks:
• UL® Listed E14853 – IZLT
Indicating -20°C to +90°C
Optional IP20 finger-safe covers in indicating and non-indicating
versions. Order one for each pole.
Universal marker labels for 30 and 60 amp blocks, Bussmann
series catalog number TM26CB.
DIN-Rail end stops for blocks rated up to 60 A, Bussmann series
catalog numbers BRKT-ND or BRKT-NDSCRW2.
Recommended fuses (order separately)
Description
Flammability ratings
Blocks: UL 94V0, self-extinguishing
Covers: UL 94HB, self-extinguishing
Ultimate protection Low-Peak™ LPJ
time-delay fuses
Advanced protection Limitron™ JKS
fast-acting fuses
High speed Class J DFJ drive fuses
Optional see-through, snap-on
cover for easy visual inspection
Available two-port lineside lug
for easy daisy-chain wiring
configuration. See catalog
number table for applicable
catalog numbers.
Finger grips on cover
for easy removal
Amps
up to 60
70 to 600
up to 60
70 to 600
up to 600
Data sheet no.
1006
1007
1026
1027
1048
Lockout/tagout feature
improves safety
Probe holes for easy testing
without removing cover
Vent slots improve cooling
(no fuse derating necessary)
Standard phase barriers
for additional safety
Optional open fuse indication
speeds troubleshooting
Tool-less interlocking modular design
for easy point-of-use assembly
DIN-Rail or panel mounting on each
pole provides installation flexibility
(DIN-Rail mounting applies to 30
and 60 A blocks only)
Multi-port loadside lug
for power distribution to
multiple branch circuit
connections
2
Eaton.com/bussmannseries
Ports on power distribution lugs rated
for dual-wire application, increasing the
number of branch circuit connections
(see catalog number table for details)
Marker label provision
for easy circuit
identification (applies to
30 and 60 A blocks only)
Effective June 2021
Catalog numbers:
Optional
covers*
Catalog no.
Fuse
amp
range
Lineside (conductors per port)
Poles
Conductors
Ports/
pole
Loadside (conductors per port)
Torque AWG
N•m
(lb-in)
Conductors
Ports/
pole
Torque
AWG
N•m
(lb-in)
Cu (1) 8
3.4 (30)
JM60030-1MW14
1
2-3
5.6 (50)
JM60030-2MW14
2
4-6
5.1 (45)
8
4.5 (40)
10-14
4.0 (35)
Al (1) 8-10
3.4 (30)
2-4
5.6 (50)
2-3
5.6 (50)
6-10
4.5 (40)
4-6
5.1 (45)
8
4.5 (40)
10-14
4.0 (35)
Cu (1) 8
3.4 (30)
N/A
up to 30
JM60030-3MW14
3
JM60060-1MW12
1
JM60060-2MW12
2
Cu 2-14
Al 2-8
Cu 2-14
Al 2-8
1
2
JM60060-3MW12†
3
12-14
1.7 (15)
JM60060-1MW14†
1
2-3
5.6 (50)
JM60060-2MW14
CVR-J-60060
CVRI-J-60060**
35 - 60
2
JM60060-3MW14†
3
JM60060-1MW24
1
JM60060-2MW24
2
JM60060-3MW24
JM60100-1MW14
JM60100-2MW14
CVR-J-60100-M
70 - 100
CVRI-J-60100-M**
4.5 (40)
10-14
4.0 (35)
2-4
5.6 (50)
1.7 (15)
1
1/0-3; Cu (2) 4-6 5.6 (50)
2
2
JM60200-3MW16
3
JM60400-1MW16
1
JM60400-2MW16
2
Cu 2-14
Al 2-8
Cu 1/0-14
Al 1/0-12
Cu/Al (1) 250kcmil-6
Cu (2) 2-6
2
1
1
2
Cu/Al 350kcmil-6
3.4 (30)
Cu (1) 8
3.4 (30)
Cu (1) 10-14 2.8 (25)
Cu (2) 12-14 3.4 (30)
Cu 10-14
2.3 (20)
(2) 10-14
3.4 (30)
4-6
4.0 (35)
8
2.8 (25)
10-14
2.3 (20)
(2) 10-14
3.4 (30)
2-3
5.6 (50)
4-6
8
(2) 8
5.0 (45)
4.5 (40)
4.5 (40)
57 (500)
10-14
4.0 (35)
34 (300)
(2) 10-14
4.5 (40)
42 (375)
2-3
4-6
8
5.6 (50)
5.0 (45)
4.5 (40)
(2) 8
4.5 (40)
10-14
4.0 (35)
(2) 10-14
4.5 (40)
4.5 (40)
4.0 (35)
250kcmil-1
42 (375)
2-6
31 (275)
Cu (1) 4-14
Al (1) 4-8
4
Cu (2) 10-14***
Cu (1) 4-14
Al (1) 4-8
6
Cu (2) 10-14***
57 (500)
51 (450)
2
3
2-6
Al (1) 8-10
2.8 (25)
10-14
350kcmil-1
8
8; Cu (2) 10-14
Cu (2) 3/0-4
Al (2) (3/0-4
Cu (1) 8-14
Cu (2) 12-14***
4
Al (1) 8 Str
Al (1) 10 Sol
4.0 (35)
1
CVR-J-60400-M
225-400
CVRI-J-60400-M**
Cu (1) 8-14
Cu (2) 12-14***
4
Al (1) 8 Str
Al (1) 10 Sol
3.4 (30)
1
3
1
4-6
5.0 (45)
500kcmil-4
Cu 2-14
Al 2-8
Al (1) 8-10
4-6; Cu (2) 8
600kcmil
Cu/Al (1) 600kcmil-4
Cu/Al (2) 3/0-4
JM60400-3MW26
8
12-14
1
JM60400-1MW26
JM60400-2MW26
5.1 (45)
3
JM60200-1MW16
JM60400-3MW16
4-6
4.5 (40)
3
CVR-J-60200-M
110-200
CVRI-J-60200-M**
1
6-10
JM60100-3MW14
JM60200-2MW16
Cu 2-14
Al 2-8
Cu (1) 8-14
Cu (2) 12-14***
4
Al (1) 8 Str
Al (1) 10 Sol
31 (275)
Cu (1) 2-14
Al (1) 2-8
Cu (2) 8-14***
Cu (1) 2-14
Al (1) 2-8
Cu (2) 8-14***
6
6
Order one cover per pole.
With open fuse indication. 90 V minimum and closed circuit required for illumination.
Dual wire rated lugs with same wire size and stranding.
Rated for 75°C Cu/Al conductors. Conductors with higher ratings may be used with appropriate derating.
3
Effective June 2021
30 A dimensions — mm (in)
Catalog nos. JM60030-(poles)MW14 — One port in, four ports out (covers not available)
4
Effective June 2021
60 A dmensions — mm (in)
Catalog nos. JM60060-(poles)MW12 — Two ports in, one port out
With optional cover, see catalog number table on page three for available versions
5
Effective June 2021
60 A dimensions — mm (in)
Catalog nos. JM60060-(poles)MW14 — One port in, four ports out
6
Effective June 2021
Catalog nos. JM60060-(poles)MW24 — Two ports in, four ports out
7
Effective June 2021
100, 200 and 400 A dimensions — mm (in)
Catalog nos. JM60100-(poles)MW14 (100 A), JM60200-(poles)MW16 (200 A) and JM60400-(poles)MW16/26 (400 A)
Block size
100 A
200 A
400 A
8
A
B
C
D
E
F
G
H
I
J
K
L
M
ØN
ØO
in
2.0
4.0
6.0
5.5
5.5
2.8
2.2
6.0
2.8
0.9
2.0
0.4
1.1
0.4
0.5
mm
51
102
153
139
139
72
55
152
72
22
51
10
29
9
13
in
2.6
5.3
8.0
6.8
6.8
3.8
3.0
7.3
3.8
1.4
2.6
0.3
1.3
0.4
0.7
mm
67
134
203
172
172
97
75
186
97
35
67
8
32
9
19
in
3.5
7.0
10.6
8.0
8.0
4.8
4.1
8.7
4.8
2.0
3.5
0.3
1.6
0.4
0.7
mm
88
177
268
202
202
121
105
220
121
50
88
8
41
9
19
Effective June 2021
Installing/removing covers on 30 to 400 amp blocks
Installing 30 and 60 amp blocks on a 35mm DIN-Rail
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are
by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the
end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit
distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once
a product has been selected, it should be tested by the user in all possible applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2021 Eaton
All Rights Reserved
Publication No. 10192
June 2021
9
Eaton, Bussmann, Low-Peak and Limitron are
valuable trademarks of Eaton in the U.S. and
other countries. You are not permitted to use
the Eaton trademarks without prior written
consent of Eaton.
CSA is a registered trademark of the Canadian
Standards Group.
NEC is a registered trademark of the National
Fire Protection Association, Inc.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“JM60200-3MW16”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+12675.109021+1644.58492
