JM60400-2CR
JM60400-2CR
    EATON(伊顿)
    JM60400-2CR
JM60400-2CR 数据手册
Modular Knifeblade Fuse Blocks Industry’s first modular fuse block simplifies design and enhances safety Increase flexibility and electrical safety with Bussmann’s snap-together Class H(K), J, and R knifeblade fuse blocks. protection solutions to meet every application need, Eaton and Bussmann offer unmatched leadership in circuit protection. As the only company with a complete portfolio of circuit More expertise. More solutions. Expect more. Leadership in Circuit Protection. The only company that can provide a complete circuit protection solution for all applications. Only Eaton can deliver... • The most diverse solutions to mitigate arc flash energy to keep people and equipment safe • The smallest and most cost effective way to meet selective coordination requirements • The most experienced, time-tested solutions to meet national & local code requirements • The easiest specifications with the most tested fuse/circuit breaker and circuit breaker/circuit breaker series rated combinations • The only one-stop shop to solve your design challenges using our expertise and an unmatched portfolio The Eaton advantage. Powering business worldwide As a global diversified power management company, we help customers worldwide manage the power needed for buildings, aircraft, trucks, cars, machinery and businesses. Eaton’s innovative technologies help customers manage electrical, hydraulic and mechanical power more reliably, efficiently, safely and sustainably. We provide integrated solutions that help make energy, in all its forms, more practical and accessible. With 2012 sales of $16.3 billion, Eaton has approximately 103,000 employees around the world and sells products in more than 175 countries. Eaton.com Knifeblade Fuse Blocks with IP20 Finger-Safe Covers Bussmann knifeblade fuse blocks offer advantages you can’t find anywhere else. Modularity The only snap-together design on the market permits assembly of required poles at point-of-use. Factory assembled two- and three-pole configurations are also available. Best Ratings All fuse blocks meet UL creep and clearance requirements for Industrial Control Circuits (UL 508, UL 845). 200 to 600A blocks meet the higher UL Industrial Power Distribution Standards (UL 98, UL 67, UL 489, UL 891, and UL 869A). Ease-of-Use Optional high-clarity, see-through finger-safe covers with test probe holes make routine maintenance activities easy. No need to open the cover to inspect wire terminations or to take thermography measurements. Available with any Class H(K), J or R fuse block. Safety For added safety and convenience, only Bussmann offers optional IP20 finger-safe covers across the entire knifeblade fuse block product line. Built-in lockout/ tagout feature improves safety. Blown fuse indication option on fuse cover assists in troubleshooting, while standard phase barriers between poles enhance safety. QuikShip Services In stock for QuikShip Everyday Service - 90% of orders ship within 24 hours. QuikShip Emergency Service ensures availability 24/7, 365 with “Next flight out” courier service. ™ ™ Knifeblade Fuse Block Features & Specifications Features and Benefits • Integral dovetails allow assembly of multiple poles at point-of-use for greater application flexibility • Factory assembled two- and three-pole configurations available • Up to four mounting holes per pole increase installation flexibility • Standard phase barriers between poles for additional safety • Design meets UL creep and clearance requirements for Industrial Power Circuits (UL 508 and UL 845) • 200 to 600A blocks meet the higher UL creep and clearance requirements for Power Distribution Standards (UL 98, UL 67, UL 489, UL 891 and UL 869A) • Optional IP20 finger-safe covers available on entire knifeblade fuse block product line: – High-clarity see-through covers allow for inspecting wire terminations or thermography measurements without removing cover – Probe holes included for easy, safer testing and troubleshooting – Built-in lockout/tagout feature improves safety • Standard fuse clip reinforcing springs enhance electrical contact Specifications Agency information: Blocks - UL - Listed cULus E14853 – IZLT & IZLT7 CSA - Certified 47235 – 6225-01 Covers - UL - Listed UL E58836 – JDVS2 Ratings: Volts - 250V, 600V Amps - 70-600A SCCR - 200kA (Class J & R) 10kA (Class H & K) Flammability ratings: Blocks - UL 94V0, self-extinguishing Covers - UL 94HB, self-extinguishing Operating and storage temperature range: Blocks - -40ºC to 120ºC Covers - Non-indicating covers -40ºC to 120ºC - Indicating covers -20ºC to 90ºC Materials: Base - Thermoplastic Box Lug Terminals - Tin-plated aluminum Wire:* Cu/Al – 75ºC/90ºC (100 - 200A) Cu/Al – 75ºC only (400 - 600A)** *Higher temperature rated wire can be used with appropriate derating. **400A Class J double box lug rated for 75ºC/90ºC Cu/Al. 4 For more information visit www.cooperbussmann.com/KnifebladeFuseBlocks Knifeblade Fuse Block Feature Highlights Features Optional blown fuse indication speeds troubleshooting Optional seethrough, snap-on cover for easy visual inspection Lockout/tagout feature improves safety • Vent slots improve cooling* • • Probe holes for easy testing without removing cover • • • • • • Finger grips on cover for easy removal Standard phase barriers for additional safety • Multiple mounting holes for each pole provide flexible, secure mounting Toolless interlocking modular design for easy point-of-use assembly Finger-safe wire entry with cutout tabs for larger wires on all versions *No fuse derating necessary. 600A Version 400A Class J Version (double box lug standard for easier wiring with smaller, dual conductors) (JM60400-_MW22 with double box lug for easier wiring with smaller, dual conductors) For more information visit www.cooperbussmann.com/KnifebladeFuseBlocks 5 Knifeblade Fuse Block Part Number Table - 250 and 600V Class H(K) & R 250V Class H(K) and R Catalog Number Class H(K) Class R Covers* w/o Indication w/ Indication 600V Class H(K) and R Volts Fuse Range (amps) Number Wire Range of Poles (solid and stranded)*** HM25100-1CR RM25100-1CR CVR-RH-25100 CVRI-RH-25100 100 2 4-6 AWG; (2) Cu 8 AWG 8 AWG 5.1 (45) 8 AWG; (2) Cu 10-14 AWG – 4.5 (40) Cu 10-14 AWG; Al 10-12 AWG – 4.0 (35) 1 HM25200-3CR RM25200-3CR 200 250 1 225CVR-RH-25400 CVRI-RH-25400 2 400 HM25400-3CR RM25400-3CR 3 HM25600-1CR RM25600-1CR HM25600-2CR RM25600-2CR 2 450CVR-RH-25600 CVRI-RH-25600 600 3 HM60100-1CR RM60100-1CR 1 70100 CVR-RH-60100 CVRI-RH-60100 HM60100-3CR RM60100-3CR HM60200-2CR RM60200-2CR 110CVR-RH-60200 CVRI-RH-60200 HM60200-3CR RM60200-3CR 200 600 1 2 1 CVR-RH-60400 CVRI-RH-60400 225- 2 400 HM60400-3CR RM60400-3CR 3 HM60600-1CR RM60600-1CR 1 HM60600-2CR RM60600-2CR 450CVR-RH-60600 CVRI-RH-60600 42 (375) 2-6 AWG; (2) Cu 2-6 AWG 2-6 AWG 31 (275) 600 HM60600-3CR RM60600-3CR *Covers sold serarately. Blown fuse indication requires 90 volts minimum and closed circuit to operate. **With easy ID™ blown fuse indication. ***Ratings for copper and aluminum wire except where otherwise noted. Class R: LPN-RK_SP LPN-RK_SPI** 600kcmil 57 (500) FRN-R 500kcmil-4 AWG 51 (450) KTN-R N/A (2) Cu 3/0 - 4 AWG 57 (500) (2) Al 3/0 - 4 AWG 34 (300) (2) 500kcmil-4 AWG N/A 51 (450) – 1/0-3 AWG; (2) Cu 4-6 AWG 1-3 AWG 4-6 AWG 6.2 (55) 5.6 (50) 4-6 AWG; (2) Cu 8 AWG 8 AWG 5.1 (45) 8 AWG; (2) Cu 10-14 AWG – 4.5 (40) Cu 10-14 AWG; Al 10-12 AWG – 4.0 (35) 250 MCM-1 AWG 3/0-1 AWG 42 (375) 2-6 AWG; (2) Cu 2-6 AWG 2-6 AWG 31 (275) 3 HM60400-1CR RM60400-1CR HM60400-2CR RM60400-2CR 2 3 HM60200-1CR RM60200-1CR 3/0-1 AWG NON 1 2 HM25600-3CR RM25600-3CR HM60100-2CR RM60100-2CR 250 MCM-1 AWG 3 HM25400-1CR RM25400-1CR HM25400-2CR RM25400-2CR Class H(K): 6.2 (55) 5.6 (50) HM25200-1CR RM25200-1CR 110- Bussmann Fuses 1-3 AWG 4-6 AWG 3 CVR-RH-25200 CVRI-RH-25200 Torque – 1/0-3 AWG; (2) Cu 4-6 AWG HM25100-3CR RM25100-3CR HM25200-2CR RM25200-2CR (fine stranded Cu) N•m (Lb-In) 1 70- HM25100-2CR RM25100-2CR Wire Range 2 3 Class H(K): NOS Class R: LPS-RK_SP LPS-RK_SPI** 600kcmil 500kcmil-4 AWG 57 (500) FRS-R 51 (450) KTS-R (2) Cu 3/0 - 4 AWG 57 (500) KWS-R (2) Al 3/0 - 4 AWG 34 (300) PVS-R (2) 500kcmil-4 AWG N/A N/A 51 (450) Knifeblade Fuse Block Part Number Table - Class J Class J Catalog Number Class J Covers* w/o Indication w/ Indication Volts Fuse Range (amps) JM60100-1CR JM60100-2CR CVR-J-60100 70- CVRI-J-60100 Number of Poles Wire Range (solid and stranded)*** Wire Range Torque (fine stranded) N•m (Lb-In) 1 – 1/0-3 AWG; (2) Cu 4-6 AWG 1-3 AWG 6.2 (55) 4-6 AWG 5.6 (50) 2 4-6 AWG; (2) Cu 8 AWG 8 AWG 5.1 (45) 8 AWG; (2) Cu 10-14 AWG – 4.5 (40) Cu 10-14 AWG; Al 10-12 AWG – 4.0 (35) 250 MCM-1 AWG 3/0-1 AWG 42 (375) 2-6 AWG; (2) Cu 2-6 AWG 2-6 AWG 31 (275) 100 JM60100-3CR 3 JM60200-1CR JM60200-2CR 110CVR-J-60200 CVRI-J-60200 200 JM60200-3CR 2 3 600 JM60400-1CR 2 CVR-J-60400-M CVRI-J-60400-M 225-400 JM60400-1MW22† 3 JM60400-3MW22† 3 JM60600-1CR 1 JM60600-2CR 450CVR-J-60600 CVRI-J-60600 JM60600-3CR 600 2 600kcmil 57 (500) JKS 500kcmil-4 AWG 51 (450) DFJ (2) Cu 3/0 - 4 AWG 57 (500) (2) Al 3/0 - 4 AWG 1 2 JM60400-2MW22† LPJ_SP LPJ_SPI** 1 JM60400-2CR JM60400-3CR 1 Bussmann Fuses N/A 34 (300) (2) 350kcmil-1 AWG 42 (375) (2) 2 AWG - 6 AWG 51 (275) (2) 500kcmil-4 AWG N/A 51 (450) 3 *Covers sold serarately. Blown fuse indication requires 90 volts minimum and closed circuit to operate. **With easyID™ blown fuse indication. ***Ratings for copper and aluminum wire except where otherwise noted. †400A Class J double box lug rated for 75oC/90oC Cu/Al. Double Box Lug Configurations • Allows for ease of installation with smaller, more flexible wire • Capable of achieving maximum current rating with parallel copper or aluminum wires • Standard on all 600A blocks • Optional on 400A Class J blocks • Compatible with IP20 finger-safe covers†† For Class J 400A double box lug configuration, optional cover provides IP20 finger-safe protection for dual 350kcmil-1 AWG wires or one single 350kcmil-6 AWG wire. †† Optional 400A Class J Version (JM60400-_MW22) All 600A Versions For engineering drawings, go to www.cooperbussmann.com/KnifebladeFuseBlocks 7 250V Class H(K) and R Dimensional Specifications Dimensions - mm (in) 70-100A 110-200A 225-400A 450-600A 8 For engineering drawings, go to www.cooperbussmann.com/KnifebladeFuseBlocks 600V Class H(K) & R Dimensional Specifications Dimensions - mm (in) 70-100A 110-200A 225-400A 450-600A For engineering drawings, go to www.cooperbussmann.com/KnifebladeFuseBlocks 9 Class J Dimensional Specifications Dimensions - mm (in) 70-100A 110-200A 225-400A 1.26 [4.9] Optional Lug Standard Lug 450-600A 10 For more information visit www.cooperbussmann.com/KnifebladeFuseBlocks 1.26 [4.9] More Bussmann Fuse Blocks, Holders and Accessories Modular knifeblade fuse blocks with finger-safe covers UL, IEC & PV CH modular fuse holder series UL Type 1 NEMA 4X SPDs Comb-bus bar accessories for CH Series fuse holders IEC CH fuse holder series CUBEFuse™ holder series Class J CH fuse holder series Open design ferrule fuse block series Class J JTN 600 fuse holder series Finger-safe, high SCCR power distribution blocks Optima™ midget & Class CC series DIN-Rail terminal blocks Open design Class CC & midget series Compact circuit protector fused disconnect switches For product data sheets, visit www.cooperbussmann.com/DatasheetsEle 11 Customer Assistance Customer Satisfaction Team Application Engineering Available to answer questions regarding Bussmann products & services Monday-Friday, 7:00 a.m. – 6:00 p.m. Central Time. Contact: Technical assistance is available to all customers. Application support is available Monday-Friday, 7:00 a.m. – 5:00 p.m. Central Time. Contact: • Toll-free phone: 855-287-7626 (855-BUSSMANN) • Toll-free phone: 855-287-7626 (855-BUSSMANN) • Toll-free fax: 800-544-2570 • E-mail: fusetech@cooperindustries.com • E-mail: busscustsat@cooperindustries.com Online Resources Emergency and After-Hours Orders Next flight out or will call shipment for time-critical needs. Customers pay only standard product price, rush freight charges, & modest emergency service fee. Place these orders through the Customer Satisfaction Team during regular business hours. For after-hours, contact: • After hours 314-995-1342 Visit www.cooperbussmann.com for the following resources: • Product search & cross-reference • Product & technical materials • Solutions centers for information on topical issues including arc flash, selective coordination & short-circuit current rating • Technical tools, like our arc flash calculator C3 – the Enhanced, Online Cooper Customer Center • Where to purchase Bussmann product Provides real time product availability, net pricing, order status & shipment tracking for: B-Line, Bussmann, Crouse-Hinds, Lighting, Power Systems & Wiring Devices. Call 877-995-5955 for log-in assistance. Available at: • www.cooperc3.com Eaton’s Bussmann Business PO Box 14460 St. Louis, MO 63178-44602 www.bussmann.com Your authorized distributor is: Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com © 2013 Eaton All Rights Reserved Printed in USA Publication No. 3192 August 2013 Eaton is a registered trademark. All other trademarks are property of their respective owners.
JM60400-2CR 价格&库存
很抱歉,暂时无法提供与“JM60400-2CR”相匹配的价格&库存,您可以联系我们找货
JM60400-2CR
  • 1+15881.343701+2060.59121
