BK/HHF-B
BK/HHF-B
    EATON(伊顿)
    BK/HHF-B
BK/HHF-B 数据手册
Bussmann® Automotive In-Line Fuseholder HHC, HHD, HHF, & HHG For ATC Blade-Type Fuses ® Dimensional Data 0.78" 0.364" 0.91" 0.5" 0.38" 0.30" 0.25" 4.0" + 0.25" CATALOG SYMBOL: HHC, HHD, HHF, AND HHG IN-LINE FUSEHOLDERS RATED 32Vdc MAXIMUM CURRENT RATING: See Table 4.0" + 0.25" 1.125" COVER FOR HHD FUSEHOLDER CATALOG SYMBOL: HHD-C Electrical Ratings Catalog Symbol Description Fuse Size Electrical Connection Maximum Continuous Current Rating HHC Yellow fuseholder 3-20A #16 black leadwire 16A* HHD Black fuseholder 3-30A #12 yellow leadwire 24A* Fits HHD only Clear polycarbonate HHD-C Cover only HHF Black fuseholder with cover 3-20A #16 yellow leadwire 16A* HHG Black fuseholder with cover 3-30A #12 yellow leadwire 24A* * Or 80% of fuse rating, whichever is less. • For ATC® blade-type fuses. • “Write-in” space for circuit identification on HHC holders (bright yellow). Bulk Products (Bulk Quantity - 1000 pieces) Catalog Symbol Description Fuse Size Electrical Connection Maximum Continuous Current Rating BK/HHC-R Yellow fuseholder 3-20A #16 red leadwire 16A* BK/HHF-B Black fuseholder with cover 3-20A #16 black leadwire 16A* * Or 80% of fuse rating, whichever is less. A fuse must be properly and fully inserted into the holder to provide a solid connection. Poor or improper insertion of the fuse can result in failure of the fuse and holder, thus not protecting the device for which it was intended. The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this Data Sheet are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 1-22-03 SB03020 Form No. HHC, HHD ,HHF and HHG Page 1 of 1 Data Sheet: 2107
BK/HHF-B 价格&库存
很抱歉,暂时无法提供与“BK/HHF-B”相匹配的价格&库存,您可以联系我们找货
