SB3-D
SB3-D
    EATON(伊顿)
    SB3-D
SB3-D 数据手册
Circuit Protection Solutions Low Voltage Fuse Links Catalogue Low Voltage Fuse Links Catalogue Table of Contents Domestic Applications to BS1361 & BS1312 Consumer Unit Fuse Link 4 Plug Top Fuse Links 4 Industrial & Motor Applications to BS88 Offset Bolted Tags 5-7 Centre Bolted Tags 8-9 Offset Blade Tags 10 Merchandising Stand 11 Industrial Applications to BS88 - 500Vdc Special DC Range Offset/Centre Bolted Tag 12 Industrial Applications to BS88 - 660/690V Offset Bolted Tags 13 Centre Bolted Tags 14 Special Tag Arrangements 15 Street Lighting Applications to BS88 Offset Bolted Tags 16 Utility Applications to BS88 House-Service Cut-Out Fuse Links 17 J Type Fuse Links to BS88: Part 5 Cylindrical 17 J Type Fuse Links to BS88: Part 5 Slotted/Non Slotted 18 Joint NATO Reference System Cylindrical/Offset Bolted Tag 19 BS88 Fuseholders Camaster HRC Fuseholder 20 Safeloc Fuseholder 21 Cylindrical Domestic Fuses 22 Domestic Fuses 23 Cylindrical Industrial Fuses Class gG 24 Class aM 25 CHD 26 CHM 27 CH 28 NH Fuses - Dual Indicator Class gG - Low Power Loss 29 - 30 Class gG 31 Class aM 32 -33 Class gG - aM 34 NH Fuses - Dimensions 35 NH Fuseholders for Knife Fuses 36 Dimensions for Knife fuse and Fuseholders (NH) 37 - 38 NH Fuse Rails and Disconnectors 39 - 41 DO Fuses 42 DO Fuseholders 43 D Fuses 44 D Fuseholders 45 Other Low Voltage Fuse Ranges 46 Medium Voltage Fuses and Isolators 47 Ultra Fast Fuses and Holders 48 - 49 Low Voltage Fuse Links Catalogue Domestic Applications to BS1361 & BS1312 Consumer Unit Fuse Link 240V / 5 - 45 A Plug Top Fuse Links 240V / 1 - 13A Specifications Specifications Description: Cylindrical Fuse Links for domestic application according to BS1361 Description: Cylindrical Fuse links for domestic applications according to BS1362, to be fitted into domestic BS1363 plug top to conform with the requirements of the Plug and Socket Safety Regulations 1995 Ratings: Volts: - 240V Amps: - 5 - 45A Ratings: IR - 16.5kA Applications: Protection of domestic distribution systems. Agency Information: Approved to BS1361 Catalogue Numbers Rating (A) Catalogue Number Colour Code 5 C55 White 15 20 C1515 C1520 Blue Yellow 30 45 C3030 C4545 Red Green Unit Packing 10 Volts: - 240V Amps: - 1 - 13A IR - 6kA Applications: protection of the cables connected to domestic equipment against overloads or small overcurrents. Agency Information: BSI Kite Mark, ASTA accreditation (except 1A Fuse), BS1362 RoHS Compliant Catalogue Numbers BK (Part Number), Unit packing = 100 Dimensions Rating (A) 1 Catalogue Number C180-1A 2 3 C180-2A C180-3A Black Red 5 C180-5A Black 7 10 C180-7A C180-10A Black Black 13 C180-13A Black Colour Code Unit Packing Black 10 BK-(Part Number), Unit packing= 100 Dimensions 4 Catalogue Number C55 C1515 A B 5.35 10.2 23 26 C1520 C3030 C4545 10.32 12.7 16.67 26 29 35 Catalogue Number C180-RatingA A B 6.45 25.4 For Product Data Sheets, visit www.cooperbussmann.com Low Voltage Fuse Links Catalogue Industrial & Motor Applications to BS88 Ratings: Offset Bolted Tags 240 - 550V ac / 2 - 32A Volts: - 415 - 550V ac Amps: - 2 - 32A IR - 80kA @ 415/550V ac Specifications Description: Fuse Links for general industrial applications with Q1 fusing factor - general purpose (gG) and motor protection (gM) characteristics Applications: General Industrial & Motors applications NITD 550V ac (gG) / 2 - 32A 415V ac (gM) Catalogue Number 2 4 6 NITD2 NITD4 NITD6 10 16 NITD10 NITD16 20 25 NITD20 NITD25 32 20M25 20M32 NITD32 NITD20M25 NITD20M32 32M40 32M50 NITD32M40 NITD32M50 32M63 NITD32M63 RoHS Compliant AAO 550V ac / 2 - 32A Catalogue Numbers Rating (A) Agency information: Meets BS88: Part 1 & 2 (1988), IEC 269: Parts 1 (1986) Catalogue Numbers Class BS Ref Fixing Centres mm Unit Packing gG A1 44 20 gM Rating (A) 2 4 Catalogue Number AAO2 AAO4 6 10 AAO6 AAO10 16 20 AAO16 AAO20 25 32 32M40 AAO25 AAO32 AAO32M40 32M50 32M63 AAO32M50 AAO32M63 Class BS Ref Fixing Centres mm Unit Packing 73 20 gG A2 gM Fuseholders: CAMASTER CM32F, see page 20 Fuseholders: CAMASTER CM32FC, see page 20 Dimensions Dimensions Part No NITD NITD32M Dimensions (mm) Dimensions (mm) A B C D E F G 55.0 44 34.6 35.6 11.2 13.8 17.5 0.8 1.2 14.0 18.5 Data Sheet: 4106 Part No AAO AAO32M A B C D E F G H J 85 73 35.5 54.5 13.7 21 14 22.3 1.2 8.7 8.0 5.5 Data Sheet: 4109 For Product Data Sheets, visit www.cooperbussmann.com 5 Low Voltage Fuse Links Catalogue Industrial & Motor Applications to BS88 Offset Bolted Tags (Cont.../...) 240-550V / 32 - 100A Ratings: Volts: - 415 - 550V ac Amps: - 32 - 100A IR - 80kA @ 415 / 550V ac Specifications Description: Fuse Links for general industrial applications with Q1 fusing factor - general purpose (gG) and motor protection (gM) characteristics Applications: General Industrial & Motors applications Agency information: Meets BS88: Part 1 & 2 (1988), IEC 269: Parts 1 (1986) and CSA C22.2 No 106-M 1985 RoHS Compliant BAO 550V ac / 35-63A CEO 550V ac / 32-100A 415V ac (gM) Catalogue Numbers Catalogue Numbers Rating (A) Catalogue Number 35 40 50 BAO35 BAO40 BAO50 63 63M80 BAO63 BAO63M80 63M100 BAO63M100 Class BS Ref Fixing Centres mm Unit Packing 73 20 gG A3 gM Fuseholder: CAMASTER CM63F, see page 20 Dimensions Part No BAO BAO63M 87 Catalogue Number CEO32 CEO40 50 63 CEO50 CEO63 80 100 CEO80 CEO100 100M125 100M160 100M200 CEO100M125 CEO100M160 CEO100M200 B 73 C 54.5 D 21 E 22.5 F 1.2 G 12.7 H 8.0 J 5.5 Part No 6 Fixing Centres mm Unit Packing 94 10 gG A4 gM Dimensions (mm) A B C CEO CEO100M125 & 160 D E F G H J 21.0 24.5 110 CEO100M200 Data Sheet: 4112 Class BS Ref Dimensions Dimensions (mm) A Rating (A) 32 40 94 58.5 25.8 26.8 3.2 47.0 31 29.5 Data Sheet: 4115 For Product Data Sheets, visit www.cooperbussmann.com 14.3 11.0 8.7 19.0 10.0 9.0 Low Voltage Fuse Links Catalogue Industrial & Motor Applications to BS88 Offset Bolted Tags (Cont.../...) 240 - 550V ac / 80 - 200A Ratings: Volts: - 415 - 550V ac Amps: - 80 - 200A IR - 80kA @ 415 / 550V ac Specifications Description: Fuse Links for general industrial applications with Q1 fusing factor - general purpose (gG) and motor protection (gM) characteristics Agency information: Meets BS88: Part 1 & 2 (1988), IEC 269: Parts 1 (1986) Applications: General Industrial & Motors applications RoHS Compliant OSD 550V ac (gG) / 80 - 100A 415V ac (gM) DEO 415V ac / 125 - 200A (gG) (gM) Catalogue Numbers Catalogue Numbers Rating (A) Catalogue Number Class 80 100 OSD80 OSD100 gG 100M125 100M160 OSD100M125 OSD100M160 BS Ref Fixing Centres mm Unit Packing N/A 73 20 gM Fuseholders: CAMASTER CM100F, see page 20 Dimensions OSD OSD100M A 95.0 Data Sheet: 4107 Catalogue Number 125 160 DEO125 DEO160 200 200M250 DEO200 DEO200M250 200M315 DEO200M315 Class BS Ref Fixing Centres mm Unit Packing N/A 94 5 gG gM Dimensions Dimensions (mm) Part No Rating (A) B 73 C 54.5 D E F 21.0 22.5 26.0 25.7 1.2 G 12.7 H 8.0 J 5.5 Part No DEO DEO200M Dimensions (mm) A B C D E F G H J 110 94 47.0 31.0 29.5 3.2 19.0 10.0 9.0 Data Sheet: 4117 For Product Data Sheets, visit www.cooperbussmann.com 7 Low Voltage Fuse Links Catalogue Industrial & Motor Applications to BS88 Centre Bolted Tags 415 - 550V ac / 2 - 1250A 250V dc Ratings: Volts: - 415 - 550V ac / 250V dc Amps: - 2 - 1250A IR - 40kA @ 250V dc - 80kA @ 415 / 550V ac Specifications Description: Fuse Links for general industrial applications with Q1 fusing factor - general purpose (gG) and motor protection (gM) characteristics Agency information: Meets BS88: Part 1 & 2 (1988), IEC 269: Parts 1 (1986) Applications: General Industrial & Motors applications RoHS Compliant AC / BC 550V ac / 2 - 63A 250 V dc (except gM) AD / BD / CD / DD / ED 550V ac / 2 - 400A 415V ac (Types gM, DD, ED) 250 V dc (Types AD, BD) Catalogue Numbers Catalogue Numbers Type Rating (A) Catalogue Number 2 AC2 4 6 AC4 AC6 10 16 AC10 AC16 20 25 AC20 AC25 32 40 AC32 BC40 50 63 BC50 BC63 63M80 63M100 BC63M80 BC63M100 AC BC Class Fixing Centres mm Unit Packing gG 97.5 20 Rating (A) 2 4 6 10 16 20 25 32 40 50 63 80 100 100M125 100M160 100M200 125 160 200 200M250 200M315 250 315 355 400 315M400 400M500 Type AD BD gG 97.5 20 CD gM DD Dimensions ED Catalogue Number AD2 AD4 AD6 AD10 AD16 AD20 AD25 AD32 BD40 BD50 BD63 CD80 CD100 CD100M125 CD100M160 CD100M200 DD125 DD160 DD200 DD200M250 DD200M315 ED250 ED315 ED355 ED400 ED315M400 ED400M500* Class Ref BS Fixing Centres mm Unit Packing gG N/A 111 20 gG N/A 111 20 B1 111 10 B2 111 5 B3/B4 111 1 gG gM gG gM gG gM *-550V ac Part No AC AD BC BC63M BD CD CD100M125 & CD100M160 CD100M200 DD DD200M ED250 ED315 ED315M4009.0 ED400M500 Dimensions A B C D E F G H K 113.5 128.5 97.5 111 55.5 55.0 21.0 21.0 1.6 1.4 12.7 14.2 13.5 11.8 7.0 8.7 11.2 11.2 113.5 97.5 55.0 21.0 1.6 7.0 13.5 12.7 11.2 128.5 111 55.0 1.4 14.2 11.8 8.7 14.3 11.1 47.0 21.0 21.0 26.0 31.0 19.0 12.5 11.2 19.5 22.0 2.5 47.0 31.0 3.2 19.0 12.5 47.0 31.0 50.0 38.0 75.0 59.0 126 111 136 136 136 111 111 58.5 3.2 9.0 19.0 4.7 25.4 Data Sheets: AC: 4110 / BC: 4113 / AD: 4111 / BD: 4114 / CD: 4116 / DD: 4118 / ED: 4119 8 8.7 For Product Data Sheets, visit www.cooperbussmann.com 22.5 22.5 12.5 9.0 31.0 Low Voltage Fuse Links Catalogue Industrial & Motor Applications to BS88 Centre Bolted Tags (Cont.../...) 415 - 550Vac / 125 - 1250A 250 - 400Vdc Ratings: Volts: Amps: IR - Specifications Description: Fuse Links for general industrial applications with Q1 fusing factor - general purpose (gG) and motor protection (gM) characteristics Applications: General Industrial & Motors applications Catalogue Numbers EFS EF Rating (A) Catalogue Number 125 160 EFS125 EFS160 200 250 315 EFS200 EFS250 EFS315 355 400 EF355 EF400 FF GF 500 560 630 FF500 FF560 FF630 710 800 GF710 GF800 1000 1250 GF1000 GF1250 RoHS Compliant Catalogue Numbers Class gG Ref Fixing Unit Interrupting BS Centres mm Packing Rating 133 N/A Type 1 80kA @ 415 Vac FG 1 80kA @ 415 Vac GG 133/184 gG 400M500 EF400M500 450 FF400 Agency information: Meets BS88: Part 1 & 2 (1988), IEC 269: Parts 1 (1986) FG / GG / GH 550V ac / 450 - 1250A 250V dc (Type GG 710-800A only) 400V dc (Type FG) EFS / EF / FF / GF 415V ac / 125 - 800A 550V ac (Types EF - gM, FF, FG, GF) 250V dc (Type GF) Type 415 - 550V ac / 250V dc 2 - 1250A 40kA @ 250V dc GF, GG except 1000 & 1250A 40kA @ 400V dc FG, FF 80kA @ 415/550V ac C1 133/184 gM gG C2 133/184 1 80kA @ 415 Vac 40kA @ 400Vdc gG C3 133/184 1 80kA @ 550Vac 40kA @ 250Vdc GH Rating (A) Catalogue Fixing Unit Class Number Centres mm Packing 450 500 FG450 FG500 560 630 710 FG560 FG630 GG710 800 1000 GG800 GG1000 1250 GG1250 710 GH710 800 1000 1250 GH800 GH1000 GH1250 gG 167/231 Interrupting Rating 80kA @ 550Vac 40ka @ 400vdc 1 80kA @ 550Vdc 40kA @ 250Vdc 165/231 gG 1 80kA @ 550Vdc No DC Rating 165/228.5 gG 149 1 80kA @ 550Vac Dimensions Dimensions Part No Dimensions (mm) G H J 77.5 10.5 15.5 38.0 167 74 6.4 80.5 10.5 15.5 25.4 77.5 262 10.5 15.5 38.0 GG1000 & 1250 228.5 84.0 133 83.0 83.0 9.5 6.4 100 12.7 FG GF A B 262 231 210 184 231 GG710 & 800 Part No Dimensions (mm) A B C 209 184 50.0 EF400M500 210 184 75.0 EFS315 EF355 & 400 D 10.5 E 12.5 F G 25.4 133 15.5 H 38.0 C D E F 165 J 4.7 59.0 FF 210 184 77.5 10.5 15.5 25.4 133 74.0 6.4 FG 262 231 77.5 10.5 15.5 38.0 167 74 6.4 GF 210 184 80.5 10.5 15.5 25.4 133 83.0 9.5 Part No GH710 & 800 GH1000 & 1250 Data Sheets: EFS: 4121 / EF: 4120 / FF: 4102 / GF: 4103 Dimensions (mm) A 198 B C D E F G 149 81.0 32.0 63.5 19.0 14.0 H 9.5 J 83.0 100 Data Sheets: FG: 4122 / GG: 4104 / GH: 4108 For Product Data Sheets, visit www.cooperbussmann.com 9 Low Voltage Fuse Links Catalogue Industrial & Motor Applications to BS88 Catalogue Numbers Offset Blade Tags 240 - 550V / 2 - 63A Rating (A) Catalogue Number 2 4 6 SSD2 SSD4 SSD6 10 16 SSD10 SSD16 20 32 SSD20 SSD32 Rating (A) Catalogue Number 2 NSD2 4 6 10 NSD4 NSD6 NSD10 16 20 32 20M25 20M32 20M36 NSD16 NSD20 NSD32 NSD20M25 NSD20M32 NSD20M36 32M36 32M40 NSD32M36 NSD32M40 32M50 32M63 NSD32M50 NSD32M63 Rating (A) Catalogue Number 2 ESD2 4 6 ESD4 ESD6 10 16 20 ESD10 ESD16 ESD20 32 40 ESD32 ESD40 50 63 ESD50 ESD63 63M80 63M100 ESD63M80 ESD63M100 Specifications Description: Fuse Links for general industrial applications with Q1 fusing factor general purpose (gG) and motor protection (gM) characteristics. Ratings: Volts: Amps: IR - 240V ac (SSD) 415V ac (NSD gM) / ESD gG (40 - 63A) 550V ac (NSD gG) / ESD gG (2 - 32A) 2 - 63A 33kA @ 240V ac 80kA @ 500V ac Applications: General Industrial and Motors applications Agency Information: Meets BS88: Part 6, 1988 and IEC 269: Parts 1, 1986 RoHS Compliant Dimensions Part No SSD NSD & NSD20M NSD20M36 & NSD32M ESD - 32A ESD40 - 63A Dimensions (mm) A B D E F N 23.0 12.0 47.0 13.0 0.8 3.2 58.5 12.7 0.8 3.5 68.0 15.0 1.2 3.5 Class BS Reference Fuseholder Unit Packing gG E1 N/A 20 Class BS Reference Fuseholder Unit Packing F1 SAFELOC 32NNSF 20 gR gM Class gG F2 gM 13.8 34.5 17.5 35.5 ESD63M 13.8 17.5 21.0 Data Sheet SSD: 4105 Data Sheet NSD: 4100 10 BS Fuse Holder Reference For Product Data Sheets, visit www.cooperbussmann.com SAFELOC 63ENSF Unit Packing 20 Low Voltage Fuse Links Catalogue Point of Sale Stand Catalogue Numbers Merchandising Stand Specifications Description: Merchandising stand with BS88 fuses packed in packs of 3’s or 10’s Stand dimensions: 1.88 Metre tall x 0.91 Metre wide x 0.51 Metre deep* (including hooks) Please note this stand is for the UK market only Part Number Part Description Pack Qty (Nb of fuses per pack) Outer box Qty (MOQ) M-AAO10 10A 550V BS88 Fuse 3 30 M-AAO16 16A 550V BS88 Fuse 3 30 M-AAO20 20A 550V BS88 Fuse 3 30 M-AAO25 25A 550V BS88 Fuse 3 30 M-AAO32 32A 550V BS88 Fuse 3 30 M-BAO40 40A 550V BS88 Fuse 3 30 M-BAO50 50A 550V BS88 Fuse 3 30 M-BAO63 63A 550V BS88 Fuse 3 30 M-CD100 100A 550V BS88 Fuse 3 30 M-CEO80 80A 550V BS88 Fuse 3 30 M-CEO100 100A 550V BS88 Fuse 3 30 M-NITD2 2A 550V BS88 Fuse 3 30 M-NITD10 10A 550V BS88 Fuse 3 30 M-NITD16 16A 550V BS88 Fuse 3 30 M-NITD20 20A 550V BS88 Fuse 3 30 M-NITD32 32A 550V BS88 Fuse 3 30 M-C180-3A 3A BS1362 Fuse 10 100 M-C180-5A 5A BS1362 Fuse 10 100 M-C180-13A 13A BS1362 Fuse 10 100 M-NSD4 4A 550V BS88 Fuse 3 30 M-NSD6 6A 550V BS88 Fuse 3 30 M-NSD10 10A 550V BS88 Fuse 3 30 M-NSD16 16A 550V BS88 Fuse 3 30 M-NSD20 20A 550V BS88 Fuse 3 30 M-NSD32 32A 550V BS88 Fuse 3 30 M-NITD6 6A 550V BS88 Fuse 3 30 M-STD6 6A 240V BS88 Fuse 3 30 M-STD10 10A 240V BS88 Fuse 3 30 M-32NNSF 32A Safeloc Fuseholder 1 5 M-63ENSF 63A Safeloc Fuseholder 1 5 M-CM20F 20A Camaster Fuseholder 1 5 M-CM32FC 32A Camaster Fuseholder Compact 1 5 M-CM32F 32A Camaster Fuseholder 1 5 M-CM63F 63A Camaster Fuseholder 1 5 M-CM100F 100A Camaster Fuseholder 1 5 For Product Data Sheets, visit www.cooperbussmann.com 11 Low Voltage Fuse Links Catalogue Industrial Applications to BS88 - 500Vdc Catalogue Numbers Special DC Range Offset/Centre Bolted Tag 500Vdc / 10 - 63A Rating (A) Offset Bolted Center fixings Centre Bolted 73mm 98mm 111mm Unit Packing Specifications 10 10HS07 - 10KS09 Description: Fuse links for industrial DC applications available in offset and centre bolted tags 16 20 25 16HS07 20HS07 25HS07 - 16KS09 20KS09 25KS09 Ratings: 32 40 32HS07 40KS07 40KS08 32KS09 40KS09 50 63 50KS07 63KS07 50KS08 63KS08 50KS09 63KS09 Volts: - 500V dc Amps: - 10 - 63A IR - 40kA @ 500V dc Applications: Protection of DC electrical circuits Agency information: ASTA approved to BS88 part 2 RoHS Compliant Dimensions Part No HS07 KS07 Part No KS08 KS09 Dimensions (mm) A 86.0 91.0 B C 73 54.0 A B C 113.0 138.0 98 111 56.0 D 22.0 27.0 F 0.8 1.2 Dimensions (mm) D E 27.0 2.5 G 9.2 13.0 H 8.0 10.5 J 5.0 F G H 13.0 14.5 13.0 15.0 5.0 8.0 Data Sheet: E5785017 12 For Product Data Sheets, visit www.cooperbussmann.com 20 Low Voltage Fuse Links Catalogue Industrial Applications to BS88 - 660/690V Offset Bolted Tags 660-690V / 2 - 200A Catalogue Numbers Specifications Description: Fuse links for industrial applications at 660/690V that meets dimensional and performance requirements of BS88 and IEC 269-1-2 standards Ratings: Volts: Amps: IR - 660 / 690V ac 250V dc (2 - 63A) 400V dc (80 - 200A) 2 - 200A 80kA @ 660V ac 40kA @ 400V dc Rating (A) Catalogue Number 2 2H07-660 4 4H07-660 6 6H07-660 10 10H07-660 16 16H07-660 20 20H07-660 25 25H07-660 32 32H07-660 40 40K07-660 50 50K07-660 63 63K07-660 80 80L14-660 100 100L14-660 125 125M14-660 160 160M14-660 200 200M14-660 BS Reference Unit Packing CAMaster fuseholder A2 20 CM32F A3 20 CM63F CM100F A4 10 N/A N/A 5 N/A Applications: Protection of large industrial installations at 600/690Vac Agency information: Meets BS88: Part 1 & 2 and IEC 269: Parts 1 & 2 RoHS Compliant Dimensions (mm) Part No A B C D E F G H J H07-660 82.3 73 52.0 22.0 22.4 11.5 8.7 7.7 5.4 K07-660 86.0 73 54.2 25.8 26.9 14.0 12.7 10.5 5.5 L14-660 111.0 94 67.0 35.5 37.0 19.2 19.0 10.3 8.7 M14-660 112.0 94 66.0 38.0 38.0 19.0 19.0 10.0 8.5 Data Data Data Data Sheet Sheet Sheet Sheet H07: 4150 K07: 4151 L14: 4152 M14: 4153 For Product Data Sheets, visit www.cooperbussmann.com 13 Low Voltage Fuse Links Catalogue Industrial Applications to BS88 - 660/690V Catalogue Numbers Centre Bolted Tags 660 - 690V ac / 2 - 630A 250 - 400V dc Specifications Description: Fuse Links for industrial applications at 660/690V that meets dimensional and performance requirements of BS88 and IEC 269-1-2 standards. Ratings: Volts: - Amps: IR - 660 / 690V ac 250V dc (2 - 63A) (K08, K09) 400V dc (80 - 630A) (L09, M09, N09, P09, N11, P11, P12, R11, R12) 2 - 630A 80kA @ 660V ac 40kA @ 250V dc/400V dc Applications: Protection of large industrial installations at 660/690Vac Agency Information: Meets BS88: Part 1 & 2 and IEC 269: Parts 1 & 2 RoHS Compliant Rating (A) Catalogue Number BS Reference Fixing Centres (mm) Unit Packing 2 4 6 10 16 20 32 40 50 63 2K08-660 4K08-660 6K08-660 10K08-660 16K08-660 20K08-660 32K08-660 40K08-660 50K08-660 63K08-660 N/A 93 20 2 4 6 10 16 20 32 40 50 63 80 100 125 160 200 250 315 355 400 2K09-660 4K09-660 6K09-660 10K09-660 16K09-660 20K09-660 32K09-660 40K09-660 50K09-660 63K09-660 80L09-660 100L09-660 125M09-660 160M09-660 200M09-660 250N09-600 315N09-660 355P09-660 400P09-660 111 20 125 160 200 250 315 125N11-660 160N11-660 200N11-660 250N11-660 315N11-660 N/A 133 1 355 400 450 500 560 630 355P11-660 400P11-660 450R11-660 500R11-660 560R11-660 630R11-660 C1 133/184 1 C2 133/184 1 355 400 450 500 560 630 355P12-660 400P12-660 450R12-660 500R12-660 560R12-660 630R12-660 N/A 167/231 1 N/A B1 B2 B3 B4 Dimensions Part No A C 92.5 53.7 22.0 111.5 93.0 54.2 25.0 111 53.7 22.0 111 54.2 25.0 K08-660 2-32A 111.0 K08-660 40-63A K09-660 2-32A 127.0 K09-660 40-63A Dimensions (mm) D E F B 128.0 G H 2.4 12.7 13.0 7.5 2.4 14.0 15.2 8.7 Dimensions (mm) Part No A Dimensions (mm) D E F Part No A B C L09-660 136.0 111 65.5 35.5 3.2 M09-660 135.0 111 65.0 37.0 N09-660 135.0 111 73.0 49.0 P09-660 135.5 111 75.0 162.0 133 73.0 N11-660 P11-660 212.0 G H 19.0 15.1 8.7 3.2 19.0 15.0 8.7 3.2 25.4 12.7 9.5 58.5 4.7 25.4 12.7 9.5 49.0 3.2 25.4 15.8 10.5 P12-660 262.0 R11-660 210.0 R12-660 262.0 B C 184 231 133 167 184 231 133 167 D E F G H J 75.0 25.4 16.0 10.0 59.0 5.0 76.0 26.0 16.0 10.0 74.0 6.5 Data Sheets: K08: 415 / L09: 4156 / M09: 4157 / N09: 4158 / P09: 4159 / N11: 4160 / P11: 4161 / R11: 4162 / R12: 4162 14 For Product Data Sheets, visit www.cooperbussmann.com Low Voltage Fuse Links Catalogue Industrial Applications to BS88 - 660/690V Special Tag Arrangements 660 - 690V / 125 - 800A Catalogue Numbers 125 Catalogue Number 125M13 160 200 160M13 200M13 250 315 125 250M13 315M13 125M23 160 200 160M23 200M23 250 315 250N15 315N15 250 315 355 250N34 315N34 355P35 400 450 400P35 450R40 500 125 500R40 125N20 Applications: Protection of large industrial installations at 600 / 690Vac 160 200 250 160N20 200N20 250N20 Agency Information: BS88 part 1 section 2-1 & 2-2 315 355 315N20 355P20 Dimensions 400 450 500 400P20 450R20 500R20 Offset Bolted Tag 560 630 560R20 630R20 710 800 710S20 800S20 Tag Types Rating (A) Specifications Description: Fuse Links for industrial applications at 660/690V that meets dimensional and performance requirements of BS88 and IEC 269-1-2 standards. Offset Bolted Tag Ratings: Volts: Amps: IR - 660 / 690V ac (except S20 type - 550V ac) 400V dc (except S20 type) 125 - 800A 80kA @ 660V ac 40kA @ 400V (except S20 type) Centre Bolted Tag Special Offset Tag RoHS Compliant Fixing Centres Unit Packing (mm) 99 5 231 1 100 1 113 1 133/184 1 133/184 1 92.5 1 92.5 1 94 1 94 1 Centre Bolted Tag Dimensions (mm) Part No A B C M13 120.0 99.0 70.0 M23 262.0 231.0 167.0 N15 120.0 100.0 79.0 D 38.0 49.0 E F 27.0 8.0 38.5 19.0 41.0 16.5 G H 12.0 26.0 14.0 15.0 J 8.7 9.8 Special Tag Arrangement Dimensions (mm) Part No A B C D E F G H N34 135.0 111 74.5 66.5 5.0 25.4 12.5 9.5 A B C Dimensions (mm) Part No A N20 110.0 P20 111.0 R20 112.0 S20 112.0 B 92.0 94.0 G H 75.0 C 49.0 49.0 76.0 47.0 59.0 62.0 74.0 66.0 83.0 77.0 77.0 D 22.0 E 44.5 F 8.8 J Part No 6.4 P35 R40 Dimensions (mm) 210.0 184 133 D 75.0 81.0 E 19.0 F 16.0 G 10.0 H J 59.0 5.0 74.0 9.5 Data Sheets: M13 & M23: 4153 / N15: 4164 / N34: 4165 / P35: 4161 / R40: 4162 / N20: 4166 / P20: 4167 / R20: 4168 / S20: E5785045 For Product Data Sheets, visit www.cooperbussmann.com 15 Low Voltage Fuse Links Catalogue Street Lighting Applications to BS88 Offset Bolted Tags 240 - 550V / 2 - 32A Ratings: Specifications Description: Fuse Links for general street lighting applications with Q1 fusing factor - general purpose (gG) Applications: Street lighting applications Volts: - 240 - 415V ac Amps: - 2 - 32A IR - 33kA @ 240V ac (STD) - 80kA @ 415 / 550V ac (SMD) Agency information: Meets BS88: Part 1 & 2 (1988), IEC 269: Parts 1 (1986) RoHS Compliant SMD 415V ac (gG) / 2 - 32A STD 240V ac /2 - 32A Catalogue Numbers Catalogue Numbers Rating (A) Part Reference 2 4 SMD2 SMD4 6 10 16 SMD6 SMD10 SMD16 20 25 SMD20 SMD25 32 SMD32 Unit Packing 20 Dimensions Rating (A) 2 4 Part Reference STD2 STD4 6 10 16 STD6 STD10 STD16 20 25 STD20 STD25 32 STD32 20 Dimensions Dimensions (mm) Part No A B C D SMD 29.0 - - 12.7 Part No STD Dimensions (mm) A B C D E F G H 47.0 35 24.0 11.0 4.7 12.0 0.8 13.0 Also available as Offset Bladed Tags “SSD”, see page 10 Data Sheet: 4123 16 Unit Packing For Product Data Sheets, visit www.cooperbussmann.com Low Voltage Fuse Links Catalogue Utility Applications to BS88 House Service Cut-Out Fuse Links 415V / 5 - 100A Specifications Description: Cylindrical Fuse Links for electrical utilities to BS Standard Specifications Description: Cylindrical type fuses designed for use with wedge type fuse carriers on BS applications Ratings: Volts: - 415V Amps: - 5 - 100A IR - 33kA @ 415V Ratings: Applications: Fuses to use in connection with House Service cut-outs. Agency Information: ASTA certified and tested in accordance to BS 1361 Catalogue Numbers Catalogue Number Diameter Unit Packing 22mm 30mm 5 10 5KR85 10KR85 - 15 20 25 15KR85 20KR85 25KR85 - 30 40 30KR85 40KR85 30LR85 40LR85 45 50 45KR85 50KR85 50LR85 60 70 80 60KR85 70KR85 80KR85 90 100 90KR85 100KR85 Dimensions Volts: - 415V Amps: - 20 - 250A IR - 80kA @ 415V Applications: For use by Electrical Authorities in distribution pillars, open type substation boards, heavy duty cut-outs, and underground connection boxes. Cylindrical type to be used in pole or wall mounted outdoor service fuse units. RoHS Compliant Rating (A) J Type Fuse Links to BS88: Part 5 Cylindrical Type 415V / 20 - 250A Agency information: ASTA certifed and tested to BS88: Part 5 RoHS Compliant Catalogue Numbers: Rating (A) Catalogue Number 20 20MJ25-6 60LR85 80LR85 32 40 63 32MJ25-6 40MJ25-6 63MJ25-6 80 100 80MJ25-6 100MJ25-6 100LR85 125 160 125MJ25-6 160MJ25-6 200 250 200MJ25-6 250MJ25-6 20 Unit Packing 20 KR85 Type Dimensions LR85 Type Data Sheet KR85: 4185 Data Sheet LR85: 4186 Data Sheet: 4177 For Product Data Sheets, visit www.cooperbussmann.com 17 Low Voltage Fuse Links Catalogue Utility Applications to BS88 Catalogue Numbers J Type Fuse Links to BS88: Part 5 Slotted/Non Slotted Types 415V / 20 - 800A Rating (A) Slotted Fixing Center Non Slotted 76mm 82mm 92mm Specifications 20 - - 20MJ31-8 - Description: Slotted type fuses designed for use with wedge type fuse carriers on BS applications 25 - - 25MJ31-8 - 32 - 32MJ30-8 32MJ31-8 - 40 - 40MJ30-8 40MJ31-8 - 50 - 50MJ30-8 50MJ31-8 - Ratings: 63 63MJ29-6 63MJ30-8 63MJ31-8 - Volts: - 415V Amps: - 20 - 630A (Slotted Type) 800A (Non Slotted Type) IR - 80kA @ 415V 80 80MJ29-6 80MJ30-7 80MJ31-7 - 100 100MJ29-6 100MJ30-7 100MJ31-7 - 125 - 125MJ30-7 125MJ31-7 - 160 160MJ29-6 160MJ30-7 160MJ31-7 - 200 200MJ29-6 200MJ30-7 200MJ31-7 - 250 250MJ29-6 250MJ30-7 250MJ31-7 - 315 - 315MJ30-7 315MJ31-7 - 355 - 355PJ30-7 355PJ31-7 - 400 - 400PJ30-7 400PJ31-7 - 450 - - 450RJ31-7 - 500 - - 500RJ31-7 - 560 - - 560SJ31-6 - 630 - - 630SJ31-6 800 - - Applications: For use by Electrical Authorities in distribution pillars, open type substation boards, heavy duty cut-outs, and underground connection boxes. Agency information: ASTA certified and tested BS88: Part 5 RoHS Compliant 800SJ28 Dimensions Type A B C D E F G H I J K MJ30-8 110 82 45.2 40.5 30 14.8 17.5 9.8 30.9 2.4 6.45/6.53 MJ30-7 (Up to 200A) 110 82 45.2 40.5 30 14.8 17.5 9.8 30.9 2.4 6.45/6.53 MJ30-7 (315-400A) 110 82 44.8 40 30 14.4 17.5 9.8 38 2.4 6.45/6.53 MJ31-7 (Up to 200A) 131 92 46.8 40.5 41 17.4 20.7 10.9 30.8 3.2 8.05/8.73 MJ31-7 (315-400A) 131 92 46.4 40 41 17.4 20.7 10.2 38.1 3.2 8.05/8.73 PJ30-7 110 82 44.8 40 30 14.4 17.5 9.8 38 2.4 6.45/6.53 PJ31-7 131 92 46.4 40 41 17.4 20.7 10.2 38.1 3.2 8.05/8.73 RJ31-7 131 92 45 38 16.5 15.5 10.9 49.1 3.2 8.05/8.73 SJ31-6 128.5 92 44.5 38.1 16.5 20.6 11 73.3 3.2 8.05/8.73 SJ28 128.5 92 44.5 38.1 16.5 20.5 73.3 3.2 8.05/8.73 Slotted Type (MJ31-7 up to 200A) Data Sheets: MJ30-8: 4178A / MJ30-7: 4178B / MJ31-7 or 8: 4180 / PJ31: 4181 / RJ: 4182 / SJ: 4183 18 For Product Data Sheets, visit www.cooperbussmann.com Unit Packing 10 Low Voltage Fuse Links Catalogue Joint NATO Reference System Cylindrical/Offset Bolted Tag 440V / 0.25 - 150A Catalogue Numbers Size Rating (A) Cylindrical Offset Bolted Unit Packing 0 0.25 0.5 1 2 3 5 7 10 15 059-0107 059-0108 059-0109 059-0110 059-0111 059-0112 059-0113 059-9925 059-9926 N/A 100 0.5 1 2 3 5 7 10 15 20 30 10 15 20 30 40 50 60 059-0140 059-0141 059-0142 059-0143 059-0144 059-0145 059-0146 059-0147 011-9483 40 50 80 100 125 160 059-0152 059-0153 059-0154 059-0155 Specifications Description: Cylindrical Fuse links originally developped for the Admiralty but are now used in a wide variety of applications Ratings: Volts: - 440V Amps: - 0.25 - 100A (Cylindrical) - 0.5 - 150A (Offset Bolted Tag) IR - 33kA @ 440Vac Applications: defence, aeronautical, allied industries, electronics 1 Agency information: Defence standard 59-96 (superceding DEF 63). Tested to BS88 at 440V/33kA RoHS Compliant Dimensions 2 Cylindrical 3 Size 0 A 32.05 D 6.37 B 5.55 1 2 33.6 37.6 11.86 16.7 7.14 8.71 3 47.9 33.3 11.9 059-0148 059-0149 059-0150 059-0151 059-0114 059-0115 059-0116 059-0117 059-0118 059-0119 059-0120 059-0121 011-9679 012-0140 059-0122 059-0123 059-0124 059-0125 059-0067 011-9127 012-0141 059-0126 059-0127 059-0128 059-0129 011-9128 011-9129 25 25 25 Offset Bolted Tag Size 1 A 56.03 B 44.65 C 33.9 D 11.96 2 3 70.7 88.6 55.84 69.77 37.4 47.4 16.7 33.3 Data Sheets: size 0: 4188/ size 1: 4189 / size 2: 4190 / size 3: 4191 For Product Data Sheets, visit www.cooperbussmann.com 19 Low Voltage Fuse Links Catalogue BS88 Fuseholders Catalogue Numbers CM CAMASTER HRC Fuseholder 690V ac / 20 - 400A Rating (A) Specifications Description: Fully shrouded fuse bases with unique cam action system for BS88 Fuse link applications. Catalogue Number Recommended Fuse Link Unit Packing 20 CM20F NITD 10 32 CM32FC NITD 10 32 CM32F AAO 10 63 CM63F BAO 10 100 CM100F OSD 5 200DF 200* Ratings: 200DFBS Front/Back DD 200DBS Back/Back Volts: - 660V ac Amps: - 20, 32 (Compact) 32, 63 and 100A 400* 400EF ED * 200A & 400A do not have the CAM action Applications: Lighting and heating equipment, circuit protection, Motor protection, Control equipment circuit protection Accesories Numbers Agency Information: CE Compliance to BS88, EN IEC 60269. For UL and CSA approved versions also available,consult Cooper Bussmann® RoHS Compliant Accessory Rating (A) Catalogue No Unit Packing Back Stud 32 32 63/100 32BSC 32BS 63/100BS 10 10 5 GLP 1 set NI 3 32LSCC 32LSC 63/100LSC 3 3 3 32CMLC 32CML 63/100CML 1 CMSC 20 Ganging Links Dimensions Neon Indicator 90-415V ac Lockable Safety Carriers Neutral Links 32 32 63/100 Security Clip Notes: 1 - Type CM32FC is also available rated at 20A, catalogue number CM20F 2 - For colours other than Black (standard) add the appropriate letter code: W = White; G = Green, GY = Grey Max Cat. No cable mm2 CM20F 20 3 - Care must be taken when fitting solid single or stranded cables of small cross-sectional area to ensure correct clamping. Small Multi-stranded cables must be terminated with bootlace ferrules to ensure correct clamping. Bootlace ferrules should not be used on standard power cables or high current applications. If in doubt please consult Cooper Bussmann® Dimensions (mm) A B C D E F G H J K 16 25.4 93.7 60 3.2 17.5 66.0 58.0 28.6 11.9 M6 CM32FC 16 25.4 93.7 60 3.2 17.5 66.0 58.0 28.6 11.9 M6 CM32F 16 31.8 117.5 60 3.2 17.5 66.0 74.0 28.6 11.9 M6 CM63F 70 35.6 125 60 4.75 16.4 86.5 81.0 28.6 11.9 M8 CM100F 70 35.6 125 60 4.75 16.4 86.5 81.0 28.6 11.9 M8 200DF 95 149 17.5 35.6 8 138 30 24 M12 400EF 240 98.4 254 192.1 31.8 36.5 70 193 - - - - - 4 - A +5% tolerance should be allowed on dimensions when cutting metal work to fit CAMaster fuse holders For Product Data Sheets, visit www.cooperbussmann.com Low Voltage Fuse Links Catalogue BS88 Fuseholders NNS, ENS Safeloc Fuseholder 660V ac / 32 - 63A Catalogue Numbers Rating (A) Specifications Description: Fuseholder to be used with BS88 Fuse links for bolted panel mounting or DIN rail. Catalogue Number Available Variants 32NNSF Front connected/ Front connected 32NNSBS Back stud/ Back stud 32 Ratings: Volts: - 550V ac, 415V ac (63A) Amps: - 32, 63A Applications: Lighting and heating equipment, circuit protection, Motor protection, Control equipment circuit protection Agency Information: CE Compliance to BS88, EN IEC 60269 Required Fuse Link Unit Packing 10 10 NSD 32NNSFBS Front connected/ Back stud 32NNL Neutral links 10 63ENSF Front connected/ Front connected 5 63ENSBS Back stud/ Back stud 63 63ENSFBS Front connected/ Back stud 63ENL Neutral links 10 5 ESD 5 1 Notes: 1 - For colours other than Black (standard), add the appropriate letter code: W = White, G = Green, GY = Grey, at the end of the catalogue reference. RoHS Compliant Dimensions 2 - Security seal (ref. 32551) available for 32A Safeloc 3 - Care must be taken when fitting solid single or stranded cables of small cross-sectional area to ensure correct clamping. Small Multi-stranded cables must be terminated with bootlace ferrules to ensure correct clamping. Bootlace ferrules should not be used on standard power cables or high current applications. If in doubt please consult Cooper Bussmann® 4 - A +5% tolerance should be allowed on dimensions when cutting metal work to fit Safeloc fuse holders Max Rating Part Cable (A) No mm2 Dimensions (mm) A B C D E F G H J K 32 NNS 16 25.4 80.3 48.5 2.3 16.0 39.2 57.7 17.0 9.7 M6 63 ENS 35 29.1 90.0 55.0 3.3 17.7 75.0 67.9 39.2 11.0 M8 For Product Data Sheets, visit www.cooperbussmann.com 21 Low Voltage Fuse Links Catalogue Cylindrical Domestic Fuses Class gG (gF) 250 - 400V / 0.5 - 32A Sizes: 6x23, 8x23, 10x25 8x31, 10x31, 8x36 10x38 Catalogue Numbers References Interrupting Voltage with Rating (V) Indicator (kA) UP* 250V 6kA 10 CD0823G2I CD0823G4I CD0823G6I CD0823G10I CD0823G16I 250V 6kA 10 CD1025G6 CD1025G10 CD1025G16 CD1025G6I CD1025G10I CD1025G16I 250V 6kA 10 0.5 1 2 4 6 8 10 12 16 20 CD0831G0.5 CD0831G1 CD0831G2 CD0831G4 CD0831G6 CD0831G8 CD0831G10 CD0831G12 CD0831G16 CD0831G20 CD0831G2I CD0831G4I CD0831G6I CD0831G8I CD0831G10I CD0831G12I CD0831G16I CD0831G20I 400V 20kA 10 10x31 16 20 25 CD1031G16 CD1031G20 CD1031G25 CD1031G16I CD1031G20I CD1031G25I 400V 20kA 10 8x36 2 4 6 10 16 20 25 32 CD0836G2 CD0836G4 CD0836G6 CD0836G10 CD0836G16 CD0836G20 CD0836G25 CD0836G32 CD0836G2I CD0836G4I CD0836G6I CD0836G10I CD0836G16I CD0836G20I CD0836G25I CD0836G32I 400V 20kA 12 10x38 25 32 CD1038G25 CD1038G32 CD1038G25I CD1038G32I 400V 20kA 10 Size Currrent (A) References without Indicator 2 4 6 10 2 4 6 10 16 CD0623G2 CD0623G4 CD0623G6 CD0623G10 CD0823G2 CD0823G4 CD0823G6 CD0823G10 CD0823G16 6 10 16 6x23 Specifications Description: Cylindrical fuses for domestic protection. Available in types with and without striker indicator. 8x23 Ratings: 10x25 Volts: - 250V ac (6x23, 8x23, 10x25) 400V ac (8x31, 10x31, 8x36, 10x38) Amps: - 0.5 - 32A IR - 6kA (6x23, 8x23, 10x25) - 20kA (8x31, 10x31, 8x36, 10x36) 8x31 Applications: Protection of power lines, heating circuits, lighting circuits. electrical domestic appliances and domestic electricity meters Agency Information: NF C 62203, EN IEC 60269-3, NF marking (see references in bold in catalogue numbers chart) RoHS Compliant Dimensions 22 Size A B C 6 x 23 6.3 23 5 8 x 23 8.5 23 5 8 x 31 8.5 31.5 6.3 8 x 36 8.5 36 6.3 10 x 25 10.3 25.8 6.3 10 x 31 10.3 31.5 6.3 10 x 38 10.3 38 10 *UP = Unit Packing NFC 60203 For Product Data Sheets, visit www.cooperbussmann.com Low Voltage Fuse Links Catalogue Domestic Fuses AD 440V ac / 15 - 90A Sizes: 10x38, 14x51, 22x58 (cylindrical fuses) 00 (Knife fuses) Catalogue Numbers Size Current (A) Catalogue Number 10x38 15 CA10D15 14x51 30 CA14D30 22x58 15 30 45 60 CA22D15 CA22D30 CA22D45 CA22D60 0 30 45 60 90 30NH00AD 45NH00AD 60NH00AD 90NH00AD Specifications Description: fuse cartridge type AD for fitting to circuit breakers on low-voltage branch circuits. Ratings: Volts: - 440V ac Amps: - 15 - 60A (Cylindrical fuses) Voltage (V) Unit Packing 440V 10 440V 3 - 30 - 90A (Fuse size 00) IR - 20kA (size 10x38) - 32kA (size 14x51, 22x58, 00) Applications: Fitting for circuit breakers in public branch panels Agency Information: Conform to standards NF C 62921, EN IEC 60269 RoHS Compliant Dimensions Sizes A B C 10x38 10.3 38 10 14x51 14.3 51 13 22x58 22.2 58 16 For Product Data Sheets, visit www.cooperbussmann.com 23 Low Voltage Fuse Links Catalogue Cylindrical Industrial Fuses Catalogue Numbers Class gG 400 - 690V / 0.5 - 125A Sizes: 8x31, 10x38, 14x51, 22x58 Size Specifications Description: Cylindrical fuses for gG Industrial protection (general applications). Available with or without indicators and visual fuse activation indicator. Striker fitted to activate an auxiliary contact. 8 x 31 Ratings: Volts: - 400, 500, 690V ac Amps: - 0.25 - 125A IR - 20kA - 400V ac (size 8 x 31) - 120kA - 400 and 500V ac - 80 kA - 690V ac 10 x 38 Applications: Protection of electrical distribution circuits and electrical appliances (with the exception of electrical motors) Agency Information: EN IEC 60269 RoHS Compliant Dimensions Size A B C 8 x 31 8.5 31.5 6.3 10 x 38 10.3 38 10 14 x 51 14.3 51 13 22 x 58 22.2 58 16 D E 14 x 51 8 8 Current (A) References References References without with with Indicator Indicator Striker 0.5 C08G0.5 1 C08G1 - 2 C08G2 C08G2I 4 C08G4 C08G4I 6 C08G4 C08G4I 8 C08G8 C08G8I 10 C08G10 C08G10I 12 C08G12 C08G12I 16 C08G16 C08G16I 20 C08G20 C08G20I 0.5 C10G0.5 - 1 C10G1 - 2 C10G2 C10G2I 4 C10G4 C10G4I 6 C10G6 C10G6I 8 C10G8 C10G8I 10 C10G10 C10G10I 12 C10G12 C10G12I 16 C10G16 C10G16I 20 C10G20 C10G20I 25 C10G25 C10G25I 32 C10G32 C10G32I 2 C14G2 C14G2I C14G2S 4 C14G4 C14G4I C14G4S 6 C14G6 C14G6I C14G6S 8 C14G8 C14G8I C14G8S 10 C14G10 C14G10I C14G10S 12 C14G12 C14G12I C14G12S 16 C14G16 C14G16I C14G16S 400V 500V C14G20 C14G20I C14G20S 25 C14G25 C14G25I C14G25S 4 32 C14G32 C14G32I C14G32S 40 C14G40 C14G40I C14G40S 50 C14G50 C14G50I C14G50S 2 C22G2 C22G2I 4 C22G4 C22G4I C22G4S 6 C22G6 C22G6I C22G6S 8 C22G8 C22G8I C22G8S 10 C22G10 C22G10I C22G10S 12 C22G12 C22G12I C22G12S 16 C22G16 C22G16I C22G16S 20 C22G20 C22G20I C22G20S 25 C22G25 C22G25I C22G25S 32 C22G32 C22G32I C22G32S 40 C22G40 C22G40I C22G40S 50 C22G50 C22G50I C22G50S 63 C22G63 C22G63I C22G63S 80 C22G80 C22G80I C22G80S 100 C22G100 C22G100I C22G100S 125 C22G125 C22G125I C22G125S For Product Data Sheets, visit www.cooperbussmann.com 20kA 10 120kA 10 400V 20 *UP: Unit Packing 24 Disconnection UP* power (kA) - 4 22 x 58 Voltage (V) 690V 80kA 10 500V 120kA 400V 690V 80kA 10 500V 400V 120kA Low Voltage Fuse Links Catalogue Cylindrical Industrial Fuses Class aM 400 - 690V / 0.16 - 125A Sizes: 8 x 31, 10 x 38, 14 x 51, 22 x 58 Catalogue Numbers Size Specifications Description: Cylindrical fuses for aM industrial protection range (protection of motors). Available in types without indicators, with visual fuse activation indicator and plunger for activation of an auxiliary contact. Ratings: Volts: - 440, 500, 690V ac Amps: - 0.16 - 125A IR - 20kA - 400V ac (size 8 x 31) 120kA - 400 and 500V ac 80kA - 690Vac Applications: Direct protection of motors Agency information: Conform to standard EN IEC 60269 RoHS Compliant Dimensions Size A B C 8 x 31 8.5 31.5 6.3 D E 10 x 38 10.3 38 10 14 x 51 14.3 51 13 8 4 22 x 58 22.2 58 16 8 4 Current (A) References References References without with Indicator with striker Indicator 1 2 4 8 x 31 6 8 10 0.16 0.25 0.5 1 2 4 6 10 x 38 8 10 12 16 20 25 32 0.25 0.5 1 2 4 6 8 14 x 51 10 12 16 20 25 32 40 50 2 4 6 8 C8M1 C8M2 C8M4 C8M6 C8M8 C8M10 C10M0.16 C10M0.25 C10M0.5 C10M1 C10M2 C10M4 C10M6 C10M8 C10M10 C10M12 C10M16 C10M20 C10M25 C10M32 C14M0.25 C14M0.50 C14M1 C14M2 C14M4 C14M6 C14M8 C14M10 C14M12 C14M16 C14M20 C14M25 C14M32 C14M40 C14M50 C22M2 C22M4 C22M6 C22M8 C8M1I C8M2I C8M4I C8M6I C8M10I C10M1I C10M2I C10M4I C10M6I C10M8I C10M10I C10M12I C10M16I C10M20I C10M25I - 10 12 16 20 25 32 40 50 63 80 100 125 C22M10 C22M12 C22M16 C22M20 C22M25 C22M32 C22M40 C22M50 C22M63 C22M80 C22M100 C22M125 C22M10I C22M12I C22M16I C22M16S C22M20I C22M20S C22M25I C22M25S C22M32I C22M32S C22M40I C22M40S C22M50I C22M50S C22M63I C22M63S C22M80I C22M80S C22M100I C22M100S C22M125I C22M125S 22 x 58 C14M1I C14M2I C14M4I C14M6I C14M8I C14M10I C14M12I C14M16I C14M20I C14M25I C14M32I C14M40I C14M50I C22M2I C22M4I C22M6I C22M8I Voltage Disconnection UP* (V) power (kA) N/A 400V 20kA 10 N/A 500V 120kA 10 120kA 10 400V C14M2S C14M4S C14M6S C14M8S C14M10S C14M12S C14M16S C14M20S C14M25S C14M32S C14M40S C14M50S 500V 400V 690V 80kA 10 500V 120kA 400V *UP: Unit Packing Neutral Cartridges 8 x 31 10 x 38 14 x 51 22 x 58 Neutral C8NL C10NL C14NL C22NL For Product Data Sheets, visit www.cooperbussmann.com 25 Low Voltage Fuse Links Catalogue Modular Domestic Fuse Holders CHD 250 - 400V / 10 - 32A Sizes: 8x23, 10x25, 8x31 10x31, 10x38 Catalogue Numbers Size Rating Voltage (A) (V) Single Pole without Indicator with Indicator without Indicator with Indicator UP Specifications 8x23 10 250 CHD8231D CHD8231DI CHD8231DN CHD8231DNI 12 Description: Fuse Holder for domestic cylindrical fuses. Secured to DIN rail and available with light indicator for active fuse function. Range as single-pole and single-pole plus neutral in one module. 10x25 16 250 CHD10251D CHD10251DI CHD10251DN CHD10251DNI 12 8x31 20 400 CHD8311D CHD8311DI 10x31 25 400 CHD10311D CHD10311DI CHD10311DN CHD10311DNI 12 Ratings: 10x38 32 400 CHD1038D CHD1038DI CHD1038DN CHD1038DNI 12 Volts: - 250V ac (8x31, 10x25) - 400V ac (8x31, 10x31, 10x38) Amps: - 10 - 32A Neutral 32 400 CHDND UP: Unit Packing IR - 6kA (6x23, 8x23, 10x25) - 20kA (8x31, 10x31, 8x36, 10x38) Applications: Protection for power lines, heating circuits, lighting circuits. electrical domestic appliances and domestic electricity meters Agency Information: NF C 62203, EN IEC 60269-3, NF marking on all models 26 Single Pole + Neutral For Product Data Sheets, visit www.cooperbussmann.com - CHD8311DN - CHD8311DNI 12 - 12 Low Voltage Fuse Links Catalogue Cylindrical Industrial Fuses Catalogue Numbers CHM 690V / 25 - 32A Sizes: 8x31, 10x38 Size Specifications Description: Fuse Holder for cylindrical industrial fuses. Secured to DIN rail and available with and without light indicator for active fuse function. Range as multi-pole and single-pole plus neutral fuse holders in one module. Accessories for the assembly of modules. Volts: - 690V ac Amps: - 25 - 32A Applications: Protection of industrial electrical distribution circuits and electrical appliances No of Modules Neutral 1 CHMDNX - 12 1P 1 CH081D CH081DI 12 1P + N 1 1P + N 2 CH081DN CH081DNI 2P 2 CH082D CH082DI 3P 3 CH083D CH083DI 3P + N 3 3P + N 4 CH083DN CH083DNI 4P 4 CH084D CH084DI 3 Neutral 1 CHMDNX - 12 CHM1D CHM1DI 12 8 x 31 Ratings: CH081DNS CH081DNSI 12 6 25A 690V 6 4 CH083DNS CH083DNSI 4 3 1P 1 1P + N 1 1P + N 2 CHM1DN CHM1DNI 2P 2 CHM2D CHM2DI 3P 3 CHM3D CHM3DI 3P + N 3 3P + N 4 CHM3DN CHM3DNI 3 4P 4 CHM4D CHM4DI 3 10 x 38 Agency Information: EN IEC 60269-3, EN IEC 60947 Dimensions References References Current Voltage Unit without with (A) (V) Packing Indicator Indicator Poles CHM1DNS CHM1DNSI 12 6 32A 690V 6 4 CHM3DNS CHM3DNSI 4 Catalogue Number Size References Unit Packing Clips for assembly of multi-pole fuse holders 8 x 31 - 10 x 38 14 x 51 - 22 x 58 AL-D 12 Multi phase handle pin connector 8 x 31 - 10 x 38 CH810-HP 12 Description For Product Data Sheets, visit www.cooperbussmann.com 27 Low Voltage Fuse Links Catalogue Cylindrical Industrial Fuses Catalogue Numbers CH 690V / 50 - 125A Sizes: 14 x 51, 22 x 38 Size Specifications Description: Fuse Holders for cylindrical industrial fuses. Secured to DIN rail and screwed. Available with and without light indicator for active fuse function and with auxiliary contact for use with plunger fuses. The auxiliary contact is available in two versions: one for the detection of fuse actuation and pre-disconnected, and the other fuse actuation only. 14 x 51 Ratings: Volts: - 690V ac Amps: - 25 - 32A Applications: Protection of industrial circuits and electrical appliances. Agency Information: EN IEC 60269-3, EN IEC 60947 Dimensions 22 x 58 Nb of Poles Modules References with auxiliary contact References References Current Voltage without with UP* (A) (V) Indicator Indicator Fuse response/ presence and Fuse response pre-disconnect Neutral 1.5 CH141DNX - - 6 1P 1.5 CH141D CH141DI CH141DMS-F CH141DMS 6 1P + N 3 CH141DN CH141DNI - - 3 2P 3 CH142D CH142DI - - 3P 4.5 CH143D CH143DI CH143DMS-F CH143DMS 2 3P + N 6 CH143DN CH143DNMS 1 4P 6 CH144D Neutral 2 CH221DNX - 1P 2 CH221D - 1P + N 4 CH221DN - 2P 4 CH222D - 3P 6 CH223D - CH223DMS 2 3P + N 8 CH223DN - CH22MDNMS 1 4P 8 CH224D - CH143DNI CH143DNMS-F CH144DI 50A 690V - 3 1 6 CH221DMS 6 3 125A 690V 3 1 *UP: Unit Packing 14 x 51 Catalogue Numbers Description Clips for assembly of multi-pole fuse holder Ref UP* AL-D 12 Multi phase handle Pin connector 14x51 CH14-P 12 Auxiliary contact for fuse response - 1 pole Auxiliary contact for fuse response - 3 pole 14x51 14x51 CH14MS-1D CH14MS-3D 5 2 *UP: Unit Packing 22 x 58 28 Size 8x31, 10x38, 14x51, For Product Data Sheets, visit www.cooperbussmann.com Low Voltage Fuse Links Catalogue NH Fuses - Dual Indicator Class gG - Low Power Loss 400V / 2 - 630A Sizes 000, 00, 01, 1, 02, 2, 03, 3 Catalogue Numbers Size Specifications Description: Low Power Loss NH Fuses for industrial protection, gG range (general protection). Dual Indicator system for fuse operation function (in the body and in the side plate). Version with voltage free metal gripping lugs for insulated fuses. The components used are lead and cadmium free. Fuses subject to HRC recycling commitment. 000 Ratings: Volts: - 400V ac Amps: - 2 - 630A 0 IR - 120kA - 400V ac Applications: Protection of large electric distribution networks, cables and distribution boards where the minimization of power losses is a requirement. Electrical utilities and electrical distribution networks 01 Standards and Approvals: Conform to standards EN IEC 60269, VDE 0636, DIN 43620, VDE approval. Dimensions: see page 35 1 02 2 03 3 gG-gL Rated Unit Dual Indicator Current Packing voltage conducting voltage free metal (A) gripping lugs gripping lugs 2 4 2NHG000B-400 4NHG000B-400 2NHG000BI-400 4NHG000BI-400 3 3 6 10 16 6NHG000B-400 10NHG000B-400 16NHG000B-400 6NHG000BI-400 10NHG000BI-400 16NHG000BI-400 3 3 3 20 25 20NHG000B-400 25NHG000B-400 20NHG000BI-400 25NHG000BI-400 3 3 32 35 40 32NHG000B-400 35NHG000B-400 40NHG000B-400 32NHG000BI-400 35NHG000BI-400 40NHG000BI-400 3 3 3 50 63 50NHG000B-400 63NHG000B-400 50NHG000BI-400 63NHG000BI-400 3 3 80 100 80NHG000B-400 100NHG000B-400 80NHG000BI-400 100NHG000BI-400 3 3 125 160 35 125NHG00B-400 160NHG00B-400 35NHG01B-400 125NHG00BI-400 160NHG00BI-400 35NHG01BI-400 3 3 3 40 50 40NHG01B-400 50NHG01B-400 40NHG01BI-400 50NHG01BI-400 3 3 63 80 63NHG01B-400 80NHG01B-40 63NHG01BI-400 80NHG01BI-400 3 3 100 125 160 100NHG01B-400 125NHG01B-400 160NHG01B-400 100NHG01BI-400 125NHG01BI-400 160NHG01BI-400 3 3 3 200 224 200NHG1B-400 224NHG1B-400 200NHG1BI-400 224NHG1BI-400 3 3 250 35 250NHG1B-400 35NHG02B-400 250NHG1BI-400 35NHG02BI-400 3 40 50 63 40NHG02B-400 50NHG02B-400 63NHG02B-400 40NHG02BI-400 50NHG02BI-400 63NHG02BI-400 3 3 3 80 100 80NHG02B-400 100NHG02B-400 80NHG02BI-400 100NHG02BI-400 3 3 125 160 200 125NHG02B-400 160NHG02B-400 200NHG02B-400 125NHG02BI-400 160NHG02BI-400 200NHG02BI-400 3 3 3 224 250 224NHG02B-400 250NHG02B-400 224NHG02BI-400 250NHG02BI-400 3 3 315 355 315NHG2B-400 355NHG2B-400 315NHG2BI-400 355NHG2BI-400 3 3 400 250 315 400NHG2B-400 250NHG03B-400 315NHG03B-400 400NHG2BI-400 250NHG03BI-400 315NHG03BI-400 3 3 3 355 400 355NHG03B-400 400NHG03B-400 355NHG03BI-400 400NHG03BI-400 3 3 500 630 500NHG3B-400 630NHG3B-400 500NHG3BI-400 630NHG3BI-400 3 3 Data Sheets: 720097 / 720099 For Product Data Sheets, visit www.cooperbussmann.com 29 Low Voltage Fuse Links Catalogue NH Fuses - Dual Indicator Class gG - Low Power Loss 500V / 2 - 1600A Catalogue Numbers Size Sizes C00, 0, 1, 2, 3, 4, 4A Specifications Description: Low Power Loss NH Fuses for industrial protection, gG range (general protection). Dual Indicator system for fuse operation function (in the body and in the side plate) except for the sizes 4 & 4A. Version with voltage free metal gripping lugs for insulated fuses. The components used in manufacture are lead and cadmium free. Fuses subject to HRC recycling commitment. 000 00 Ratings: Volts: - 500V ac Amps: - 2 - 1600A IR - 120kA - 500V ac - 50kA - 250V dc 0 Applications: Protection of large electric distribution networks, cables and distribution boards (except motors) where the minimize of power losses is a requirement. Standards and Approvals: Conform to standards EN IEC 60269, VDE 0636, DIN 43620, VDE approval. Dimensions: see page 35 01 1 02 2 03 3 4 Slotted End Tags 4A Data Sheets: 2142 30 None Slotted End Tags Rated Current (A) 2 4 6 10 16 20 25 32 35 40 50 63 80 100 125 160 10 16 20 25 32 35 40 50 63 80 100 125 160 10 16 20 25 32 35 40 50 63 80 100 125 160 200 224 250 35 40 50 63 80 100 125 160 200 224 250 315 355 400 250 315 355 400 500 630 500 630 800 1000 1250 630 800 900 1000 1250 1600 gG-gL Dual Indicator voltage conducting gripping lugs voltage free metal gripping lugs 2NHG000B 4NHG000B 6NHG000B 10NHG000B 16NHG000B 20NHG000B 25NHG000B 32NHG000B 35NHG000B 40NHG000B 50NHG000B 63NHG000B 80NHG000B 100NHG000B 125NHG00B 160NHG00B 10NHG0B 16NHG0B 20NHG0B 25NHG0B 32NHG0B 35NHG0B 40NHG0B 50NHG0B 63NHG0B 80NHG0B 100NHG0B 125NHG0B 160NHG0B 10NHG01B 16NHG01B 20NHG01B 25NHG01B 32NHG01B 35NHG01B 40NHG01B 50NHG01B 63NHG01B 80NHG01B 100NHG01B 125NHG01B 160NHG01B 200NHG1B 224NHG1B 250NHG1B 35NHG02B 40NHG02B 50NHG02B 63NHG02B 80NHG02B 100NHG02B 125NHG02B 160NHG02B 200NHG02B 224NHG02B 250NHG02B 315NHG2B 355NHG2B 400NHG2B 250NHG03B 315NHG03B 355NHG03B 400NHG03B 500NHG3B 630NHG3B 500NHG4G 630NHG4G 800NHG4G 1000NHG4G 1250NHG4G 630NH4AG 800NH4AG 900NH4AG 1000NH4AG 1250NH4AG 1600NH4AG 2NHG000BI 4NHG000BI 6NHG000BI 10NHG000BI 16NHG000BI 20NHG000BI 25NHG000BI 32NHG000BI 35NHG000BI 40NHG000BI 50NHG000BI 63NHG000BI 80NHG000BI 100NHG000BI 125NHG00BI 160NHG00BI 10NHG01BI 16NHG01BI 20NHG01BI 25NHG01BI 32NHG01BI 35NHG01BI 40NHG01BI 50NHG01BI 63NHG01BI 80NHG01BI 100NHG01BI 125NHG01BI 160NHG01BI 200NHG1BI 224NHG1BI 250NHG1BI 35NHG02BI 40NHG02BI 50NHG02BI 63NHG02BI 80NHG02BI 100NHG02BI 125NHG02BI 160NHG02BI 200NHG02BI 224NHG02BI 250NHG02BI 315NHG2BI 355NHG2BI 400NHG2BI 250NHG03BI 315NHG03BI 355NHG03BI 400NHG03BI 500NHG3BI 630NHG3BI - For Product Data Sheets, visit www.cooperbussmann.com Unit Packing 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Low Voltage Fuse Links Catalogue NH Fuses - Dual Indicator Catalogue Numbers Class gG 690V / 2 - 630A Sizes 000, 00, 0, 1, 2, 3 Size Specifications Description: NH Fuses for gG range industrial protection (general protection). Double indicator system for fuse operation (in the body and in the side plate). Version with voltage free metal gripping lugs for insulated fuses. The components used in manufacture are lead and cadmium free. Fuses subject to HRC recycling commitment. 000 00 Ratings: Volts: - 690V ac Amps: - 2 - 630A IR - 120kA - 690V ac Applications: Protection of electrical distribution circuits, cables and electrical appliances (with the exception of motors). 0 Standards and Approvals: Conform to standards EN IEC 60269, VDE 0636, DIN 43620. Dimensions: see page 35 1 2 3 gG - gL Rated Dual Indicator Unit Current voltage conducting voltage free metal Packing (A) gripping lugs gripping lugs 2 4 2NHG000B-690 4NHG000B-690 2NHG000BI-690 4NHG000BI-690 6 10 16 6NHG000B-690 10NHG000B-690 16NHG000B-690 6NHG000BI-690 10NHG000BI-690 16NHG000BI-690 20 25 20NHG000B-690 25NHG000B-690 20NHG000BI-690 25NHG000BI-690 32 35** 32NHG000B-690 35NHG000B-690 32NHG000BI-690 35NHG000BI-690 40 50 63 40NHG000B-690 50NHG00B-690 63NHG00B-690 40NHG000BI-690 50NHG00BI-690 63NHG00BI-690 80 100 80NHG00B-690 100NHG00B-690 80NHG00BI-690 100NHG00BI-690 6 10 6NHG0B-690 10NHG0B-690 - 16 20 25 16NHG0B-690 20NHG0B-690 25NHG0B-690 - 32 35 32NHG0B-690 35NHG0B-690 - 40 50 63 40NHG0B-690 50NHG0B-690 63NHG0B-690 - 80 100 80NHG0B-690 100NHG0B-690 - 50 63 50NHG1B-690 63NHG1B-690 50NHG1BI-690 63NHG1BI-690 80 100 125 80NHG1B-690 100NHG1B-690 125NHG1B-690 80NHG1BI-690 100NHG1BI-690 125NHG1BI-690 160 200 160NHG1B-690 200NHG1B-690 160NHG1BI-690 200NHG1BI-690 63 80 63NHG2B-690 80NHG2B-690 63NHG2BI-690 80NHG2BI-690 100 125 160 100NHG2B-690 125NHG2B-690 160NHG2B-690 100NHG2BI-690 125NHG2BI-690 160NHG2BI-690 200 224 200NHG2B-690 224NHG2B-690 200NHG2BI-690 224NHG2BI-690 250 315 250 250NHG2B-690 315NHG2B-690 250NHG3B-690 250NHG2BI-690 315NHG2BI-690 250NHG3BI-690* 315 355 315NHG3B-690 355NHG3B-690 315NHG3BI-690* 355NHG3BI-690* 400 500 400NHG3B-690 500NHG3B-690 400NHG3BI-690* 500NHG3BI-690* 630 - - 3 3 3 3 3 3 * Contact Cooper Bussmann for availibility ** Interrupting Rating for the 35 A size 000 is 80kA For Product Data Sheets, visit www.cooperbussmann.com 31 Low Voltage Fuse Links Catalogue NH Fuses - Dual Indicator Catalogue Numbers Class aM 500 - 690V / 2 - 630A Size Sizes 000, 00, 0, 1, 2, 3A 2 4 - - 6 10 6NHM000B-690 10NHM000B-690 6NHM000BI-690 10NHM000BI-690 16 20 16NHM000B-690 20NHM000B-690 16NHM000BI-690 20NHM000BI-690 25 32 35 25NHM000B-690 32NHM000B-690 35NHM000B-690 25NHM000BI-690 32NHM000BI-690 35NHM000BI-690 40 50 40NHM000B-690 50NHM00B 40NHM000BI-690 50NHM00BI 63 80 63NHM00B 80NHM00B 63NHM00BI 80NHM00BI 100 160 6 100NHM00B 160NHM00B 6NHM0B 100NHM00BI 160NHM00BI - 10 16 10NHM0B 16NHM0B - 20 25 32 20NHM0B 25NHM0B 32NHM0B - 35 40 35NHM0B 40NHM0B - Standards and Approvals: Conform to standards EN IEC 60269, VDE 0636, DIN 43620. 50 63 50NHM0B 63NHM0B - Dimensions: see page 35 80 100 50 80NHM0B 100NHM0B - - 63 80 63NHM1B-690 80NHM1B 63NHM1BI-690 80NHM1BI 100 125 100NHM1B 125NHM1B 100NHM1BI 125NHM1BI 160 200 224 160NHM1B 200NHM1B 224NHM1B 160NHM1BI 200NHM1BI 224NHM1BI 250 63 250NHM1B - 250NHM1BI - 80 100 125 125NHM2B-690 125NHM2BI-690 160 200 160NHM2B-690 200NHM2B-690 160NHM2BI-690 200NHM2BI-690 224 250 224NHM2B-690 250NHM2B-690 224NHM2BI-690 250NHM2BI-690 315 355 400 315NHM2B-690 355NHM2B-690 400NHM2B 315NHM2BI-690 355NHM2BI-690 400NHM2BI 250 315 315NHM3B-690 315NHM3BI-690 355 400 355NHM3B-690 400NHM3B-690 355NHM3BI-690 400NHM3BI-690 500 630 500NHM3B-690 630NHM3B 500NHM3BI-690 630NHM3BI Specifications Description: NH Fuses for aM range industrial protection (general protection). Double indicator system for fuse operation (in the body and in the side plate). Version with voltage free metal gripping lugs for insulated fuses. The components used in manufacture are lead and cadmium free. Fuses subject to HRC recycling commitment. 000 00 Ratings: Volts: - 690V ac Amps: - 25 - 32A IR - 80 kA - 500Vac (sizes 000,00 - up to 100A) - 120kA - 500Vac/690Vac Applications: Protection of electrical motors. 0 1 2 3 32 aM Rated Dual Indicator Unit Current voltage conducting voltage free metal Packing (A) gripping lugs gripping lugs For Product Data Sheets, visit www.cooperbussmann.com 3 3 3 3 3 3 Low Voltage Fuse Links Catalogue NH Fuses Catalogue Numbers Class aM 500V / 2 - 630A Size Sizes C00, 0, 1, 2, 3 Specifications C00 Description: NH Fuses for aM range industrial protection (general protection). Indicator for fuse activation in the side panel. The components used in manufacture are lead and cadmium free. Fuses subject to HRC recycling commitment. Ratings: Volts: Amps: IR - 00 500V ac 2 - 630A 120kA - 500Vac 50kA - 250V dc Applications: Protection of direct starter motors 0 Standards and Approvals: Conform to standards EN IEC 60269, VDE 0636, DIN 43620. Dimensions: see page 35 1 2 3 Rated current (A) Voltage conducting gripping lugs 2 4 2NHC00M 4NHC00M 6 10 6NHC00M 10NHC00M 16 20 25 16NHC00M 20NHC00M 25NHC00M 32 40 32NHC00M 40NHC00M 50 63 80 50NHC00M 63NH00M 80NH00M 100 125 100NH00M 125NH00M 160 32 160NH00M 32NH0M 50 63 80 50NH0M 63NH0M 80NH0M 100 125 100NH0M 125NH0M 160 40 160NH0M 40NH1M 50 63 80 50NH1M 63NH1M 80NH1M 100 125 100NH1M 125NH1M 160 200 250 160NH1M 200NH1M 250NH1M 100 125 100NH2M 125NH2M 160 200 160NH2M 200NH2M 250 315 355 250NH2M 315NH2M 355NH2M 400 315 400NH2M 315NH3M 400 500 400NH3M 500NH3M 630 630NH3M For Product Data Sheets, visit www.cooperbussmann.com Disconnect Power (kA) Unit Packing 120kA 3 120kA 3 120kA 3 120kA 3 120kA 3 120kA 3 33 Low Voltage Fuse Links Catalogue NH Fuses with Striker Class gG - aM 500 - 690V / 63 -1250A Catalogue Numbers Size Sizes 1, 2, 3, 4 Specifications Description: NH Fuses for industrial applications class gG and aM with integrated side striker for visual or remote indication of the fuse status. To be used with NH fuse holders fitted with micro-switch. 1 Ratings: Volts: Current IR - 500V ac Size 4 690V ac Size 1,2,3 63A - 1250A 120kA - 500V ac 80kA - 690V ac 2 Applications: Protection of electrical distribution circuits (Class gG) and motor protection (Class aM) 3 Standards and Approvals: Conform to standards EN IEC 60269, VDE 0636, DIN 43620. 4 gG aM Voltage conducting metal gripping lugs Voltage conducting metal gripping lugs 63 80 100 63NHG1BS-690* 80NHG1BS-690* 100NHG1BS-690* 63NHM1BS-690* 80NHM1BS-690* 100NHM1BS-690* 125 160 125NHG1BS-690* 160NHG1BS-690* 125NHM1BS-690* 160NHM1BS-690* 200 224 200NHG1BS-690* - 200NHM1BS-690* 224NHM1BS-690* 250 125 160 125NHG2BS-690* 160NHG2BS-690* 250NHM1BS-690* 125NHM2BS-690* 160NHM2BS-690* 200 224 200NHG2BS-690* 224NHG2BS-690* 200NHM2BS-690* 224NHM2BS-690* 250 315 250NHG2BS-690* 315NHG2BS-690* 250NHM2BS-690* 315NHM2BS-690* 355 400 315 315NHG3BS-690* 355NHM2BS-690* 400NHM2BS-690* - 355 400 355NHG3BS-690* 400NHG3BS-690* 400NHM3BS-690* 500 630 500 500NHG3BS-690* 630NHG3BS-690* 500NH4G-S 500NHM3BS-690* 630NHM3BS-690* - 630 800 630NH4G-S 800NH4G-S - 1000 1250 1000NH4G-S 1250NH4G-S - Rated Current (A) * Contact Cooper Bussmann for availibility 34 For Product Data Sheets, visit www.cooperbussmann.com Pack Qty 3 3 3 3 Low Voltage Fuse Links Catalogue NH Fuses - Dimensions Knife Fuses (NH) Size a a1 a2 (max) a3 a4 b (rated) c1(±8) c2 (rated) D (rated) e1 (max) e2 (max) e3 (max) e4 (rated) f (max) 000 78.5±1.5 54 45±1.5 49±1.5 15 35 10 2±0.5 48 30 25 6 15 00 78.5±1.5 54 45±1.5 49±1.5 15 35 11 2±0.5 48 30 25 6 15 68±+1.5/-3 15 35 11 2.5±0.5 48 30 25 6 15 0 125±2.5 68 62±+3/-1.5 01 135±2.5 75 62±2.5 68±2.5 15 40 11 2.5±0.5 48 30 25 6 15 1 135±2.5 75 62±2.5 68±2.5 20 40 11 2.5±0.5 53 52 25 6 15 02 150±2.5 75 62±2.5 68±2.5 20 48 11 2.5±0.5 53 52 25 6 15 2 150±2.5 75 62±2.5 68±2.5 25 48 11 2.5±0.5 61 60 25 6 15 03 150±2.5 75 62±2.5 68±2.5 25 60 11 2.5±0.5 61 60 25 6 15 3 150±2.5 75 62±2.5 68±2.5 32 60 11 3±0.5 76 60 25 6 18 4a 200 84 80 90 50 85 3 102 87 30 4a -1600A 200 84 80 90 50 85 3 102 87 30 For Product Data Sheets, visit www.cooperbussmann.com 35 Low Voltage Fuse Links Catalogue NH Fuse Holders for Knife Fuses SB-D, SB-S, SB-DMS 690V / 160 - 1600A Catalogue Numbers Poles Current (A) 00 1 3 160A SB00-S TB00-S 0 1 3 160A SB0-S TB0-S SB0-D TB0-D SB0-DMS 3 1 1 1 3 250A SB1-S TB1-S SB1-D TB1-D SB1-DMS 3 1 2 1 3 400A SB2-S TB2-S SB2-D TB2-D SB2-DMS 3 1 3 1 3 630A SB3-S TB3-S SB3-D TB3-D SB3-DMS 3 1 4 1 1600A SB4-S SB4-DMS 3 Size Current (A) Part Ref NH00 160 SL00 NH0 160 SL0 NH1 250 SL1 NH2 400 SL2 NH3 630 SL3 NH4 1000 SL4 Sizes 00, 0, 1, 2, 3, 4 Specifications Description: Knife fuses, NH, thermoplastic bodies for knife fuses. Securing to DIN rail and by screws (size 4 screw fixation only). Range of protection accesories for live parts in order to obtain IP20 protection standard. Available with micro- switch contact for use with fuses with striker (see page 30). With microswitch Screw DIN Rail connection connection contact Part References Size UP* 3 1 1 SB00-D TB00-D TB00-D-IP20 Ratings: Volts: - up to 690V ac Amps: - 2 - 1600A Neutral Applications: Protection of industrial circuits and electrical apparatus Standards and Approvals: IEC 60269, VDE 0636, DIN 43620 Dimensions Unit Packing 3 Fuse extraction handle Size Part Ref Unit Packing C00-3 FEH 1 Protection accessories Size Current (A) NH00 NH0 NH1 NH2 NH3 NH4 160A 160A 250A 400A 630A 1250A Separation Partition 4 Fuse Cover 5 Separator 3 Part Ref Unit Packing Part Ref Unit Packing Part Ref Unit Packing Part Ref Unit Packing SP00 SP0 SP1-2 SP1-2 SP3 SP4 2 2 2 2 2 2 FC00 FC0 FC1 FC2 FC3 3 3 3 3 3 CS00 CS0 CS1 CS2 CS3 6 6 6 6 6 BC00 BC0 BC1-2 BC1-2 BC3 2 2 2 2 2 IP Protection Kits 36 Terminal Cover 1 TB00-D-IP20 Complete triple pole fuse base IP20 rated FPK0-3P IP20 kit for TB0-D fuse base FPK1-3P IP20 kit for TB1-D fuse base FPK2-3P IP20 kit for TB2-D fuse base FP3K-3P IP20 kit for TB3-D fuse base For Product Data Sheets, visit www.cooperbussmann.com Low Voltage Fuse Links Catalogue Dimensions for Knife Fuse and Fuseholders (NH) Knife Fuseholders (NH) Bases for fuseholders size 00 Bases for fuseholders size 0, 1, 2, 3, 4 Size NH0 A 170 B 150 C 47 D 24 E 122 F 63 G 63 H 29 I 74 J 48.5 K 91.5 L 185 M MB N 25 O - P 7.5 Q 15 NH1 NH2 NH3 200 225 240 175 200 210 60 60 60 28 32 38 148 148 148 77.5 88 97 35 35 35 80 80 80 192 192 224 66 66 82 123 123 143 250 250 270 M10 M12 M12 25 25 25 30 30 30 10.5 10.5 10.5 20.5 20.5 20.5 Bases for fuse holders size 4 For Product Data Sheets, visit www.cooperbussmann.com 37 Low Voltage Fuse Links Catalogue Dimensions for Knife Fuses and Fuseholders NH Knife Fuseholders (NH) Bases for fuseholders with micro circuit-breaker 38 Size A B C NH0 90 193 65.5 NH1 98 215 76 NH2 102 227 76 NH3 102 235 76 NH4 140 284 113 For Product Data Sheets, visit www.cooperbussmann.com Low Voltage Fuse Links Catalogue NH Fuse Rail Vertical Style BFRD 690V / 250-630A Catalogue Numbers Size Rating (A) Sizes 1, 2, 3 1 Part Reference Leading out Terminals BFR1-3K/LM/C (*) Pressed-in Nuts with M10 Screw BFR1-3K/LW V-Shaped Clamps BFR1-3K/LL Busbar Systems 185mm Busbar Spacing Connects to Busbar with M12 bolts BFR2-3K/LM/C (*) Pressed-in Nuts with M10 Screw BFR2-3K/LW V-Shaped Clamps BFR2/3K/LL Busbar Systems 185mm Busbar Spacing Connects to Busbar with M12 bolts BFR3-3K/LM/C (*) Pressed-in Nuts with M10 Screw BFR3-3K/LW V-Shaped Clamps BFR3-3K/LL Busbar Systems 185mm Busbar Spacing Connects to Busbar with M12 bolts 250 Specifications Description: Vertical Fuse Rails are designed to be used with NH Fuses. Fully protected against accidental contacts. Main features are: - Contact covers - Inter polar barriers - Label for protected circuit identification - Busbar mounting with screws 2 3 Ratings: 400 630 Volts: - 690V ac Amps: - 250 - 630A (*) with Leading-out Terminal cover Applications: Disconnecting cabinets and low voltage distribution switchboards with busbar spacing of 185mm Standards and Approvals: CE, IEC EN 60269-1, IEC EN 60269-3-1 Dimensions: For Product Data Sheets, visit www.cooperbussmann.com 39 Low Voltage Fuse Links Catalogue NH Fuse Switch Disconnectors Vertical Style BFD 690V / 250 - 630A Catalogue Numbers Sizes 1, 2, 3A Size Rating (A) 1 250 Part Reference Terminals UP* BFD1-31/LM BFD1-33/LM Pressed-in Nuts with M10 Screw 1 BFD1-31/LW BFD1-33/LW V-shaped Clamps 1 BFD1-33/LL Switch Disconnector for Busbar Systems 185mm Busbar Spacing Connects to Busbar with M12 bolts 1 BFD2-31/LM BFD2-33/LW Pressed-in Nuts with M10 Screw 1 BFD2-31/LW BFD2-33/LW V-Shaped Clamps 1 BFD2-33/LL Switch Disconnector for Busbar Systems 185mm Busbar Spacing Connects to Busbar with M12 bolts 1 BFD3-31/LM BFD3-33/LM Pressed-in Nuts with M12 Screw 1 BFD3-31/LW BFD3-33/LW V-Shaped Clamps 1 Switch Disconnector for Busbar Systems 185mm Busbar Spacing Connects to Busbar with M12 bolts 1 1 Pole Switching 3 Poles Switching Specifications Description: Vertical Fuse Switch disconnectors are designed to be used with NH Fuses. Enabling safe connection and disconnection operations. Main features are: - Measuring holes in the fuse cover - Possibility to lock the fuse cover - Label for protected circuit identification - Busbar mounting with screws. BFD1-31/LL 2 400 BFD2-31/LL Ratings: Volts: Amps: Utilization category - 690V ac 250 - 630A 3 400V ac - AC23B 630 690V ac - AC22B BFD3-31/LL Applications: Distribution and Industrial switchboards with busbar spacing of 185mm BFD3-33/LL * UP = Unit Packing Approvals: CE, IEC EN 60947-1, IEC EN 60947-3 Dimensions: 40 For Product Data Sheets, visit www.cooperbussmann.com Low Voltage Fuse Links Catalogue NH Fuse Switch Disconnectors Horizontal Style BFH 690V / 160 - 1600A Catalogue Numbers Size Rating (A) Catalogue Number 1 Pole 3 Poles Terminals UP* 000 160 BFH000-1A/T BFH000-3A/T Terminal Clips for 1.5- to 50mm2 cable 1 00 160 BFH00-1A/F BFH00-3A/F Terminal Screw M8 1 Specifications 1 250 BFH1-1A/F BFH1-3A/F Terminal Screws M10 1 Description: Horizontal Switch disconnectors are designed to be used with NH Fuses. Enabling safe connection and disconnection operations. Main features are: - Measuring holes in the fuse cover - Possibility to lock the fuse cover - Label for protected circuit identification - Panel mounting with screws. On 35mm DIN Rail (only size 000) 2 400 BFH2-1A/F BFH2-3A/F Terminal Screws M10 1 3 630 BFH3-1AF BFH3-3A/F Terminal Screws M12 1 4A 1600 LBS4/1 LBS4/3 Terminal Screws 2xM12 1 Sizes 000, 00, 1, 2, 3, 4A * UP = Unit Packing Ratings: Volts: - Amps: Utilization category - 690V ac / 250V dc (sizes 1,2,3) / 400V dc (size 000) 160 - 1600A 400V ac - AC23B 500V ac - AC22B - 690V ac - AC21B - 250V dc - DC21B (sizes 1,2,3) - 250V dc - DC22B (sizes 000, 00) - 440V dc - DC20B Applications: Industrial control panels, motor control panels Approvals: CE, IEC EN 60947-1, IEC EN 60947-3 Dimensions: For Product Data Sheets, visit www.cooperbussmann.com 41 Low Voltage Fuse Links Catalogue DO Fuses Class gG 400V / 2 - 100A Catalogue Numbers Sizes D01, D02, D03 Current (A) Colour Code Part Ref Voltage (V) DO1 2 4 6 10 16 Pink Brown Green Red Grey 2NZ01 4NZ01 6NZ01 10NZ01 16NZ01 400V 100kA 10 DO2 20 25 35 50 63 Blue Yellow White Black Copper 20NZ02 25NZ02 35NZ02 50NZ02 63NZ02 400V 100kA 10 DO3 80 100 Silver Red 80NZ03 100NZ03 400V 100kA 10 Specifications Description: DO fuses, gG range, for industrial and domestic protection. All the fuses incorporate a visual display of fuse actuation. Additional range of fuse holders and accesories. Ratings: Volts: - 690V ac Amps: - 160 - 1600A IR - 50kA - 400V ac Disconnection Unit Power Packing (kA) Size Applications: Protection of electrical distribution circuits, cables and electrical apparatus (with the exception of motors). Standards and Approvals: IEC 60269, VDE 0636, Dimensions D02 D01 42 D03 In(A) A In(A) A 2 7.3 20 10.9 4 7.3 25 12.1 6 7.3 35 13.3 10 8.5 50 14.5 16 9.7 63 15.9 For Product Data Sheets, visit www.cooperbussmann.com In(A) A 80 21.4 100 21.4 Low Voltage Fuse Links Catalogue DO Fuseholders FN C , TFN C, FRN C, TFRN C 400V / 16 - 100A Catalogue Numbers Part Ref DIN Rail Connection Part Ref Screw Connection Sizes D01, D02, D03 Size Current (A) Single Pole Specifications Description: DO fuse carriers in ceramic bodies with versions for securing to DIN rail or screw connection. Complete range of accessories. DO1 DO2 16A 63A Three Pole FN01C FN02C Single Pole Unit Packing Three Pole TFN01C FRN01C TFRN1C TFN02C FRNC02C TFRN2C 15/5 (Three Pole) 15/5 (Three Pole) Ratings: Volts: - 400V ac Amps: - 16 - 100A Accessories Applications: Protection of industrial circuits and electrical apparatus. Standards and Approvals: IEC 60269, VDE 0636, Accessories Size Current (A) Fuse Base Type References Unit Packing Fuse Carrier DO1 DO2 16 63 E14 E18 CN01 CN02 20 DO1 2 4 6 10 E14 2GN01 4GN01 6GN01 10GN01 50 DO2 16 20 25 35 50 E18 16GN02 20GN02 25GN02 35GN02 50GN02 16 63 16 63 E14 E18 E14 E18 SFPCDO1 SFPCDO2 TFPCDO1 TFPCDO2 Dimensions Gauge/ Calibration ring Size A DO1 53 DO2 57 Covers DO1 DO2 DO1 DO2 1 1 3 3 pole pole pole pole For Product Data Sheets, visit www.cooperbussmann.com 50 30 43 Low Voltage Fuse Links Catalogue D Fuses Class gG 500V / 2 - 200A Catalogue Numbers Sizes: DI, DII, DIII, DIV, DV Current (A) Colour Code References Voltage (V) DI 2 4 6 10 16 20 25 Pink Brown Green Red Grey Blue Yellow 2D16 4D16 6D16 10D16 16D16 20D16 25D16 500V 100kA 10 DII 2 4 6 10 16 20 25 Pink Brown Green Red Grey Blue Yellow 2D27 4D27 6D27 10D27 16D27 20D27 25D27 500V 100kA 10 DIII 35 50 63 Black White Copper 35D33 50D33 63D33 500V 100kA 10 DIV 80 100 Silver Red 80D125 100D125 500V 100kA 10 Specifications Description: D fuses, gG range, for industrial and domestic protection. All the fuses incorporate a visual display of fuse actuation. Additional range of fuse holders and accesories. Ratings: Volts: - 690V ac Amps: - 2 - 200A IR - 50kA - 500V ac Applications: Protection of electrical distribution circuits, cables and electrical apparatus (with the exception of motors). Disconnection Unit Power Packing (kA) Size Standards and Approvals: IEC 60269, VDE 0636, Dimensions Int (A) Int (A) A B 2 6 35 27 16 4 6 50 27 16 6 6 63 27 18 Int (A) 2 6 4 6 6 6 8 10 16 10 16 10 20 12 20 12 25 14 25 14 10 44 B B A 13.2 Int (A) A B 35 27 16 50 27 16 A 21.5 8 For Product Data Sheets, visit www.cooperbussmann.com Low Voltage Fuse Links Catalogue D Fuseholders Catalogue Numbers SFD, TFD, SFRD C , TFR 500V / 25 - 63A Part Ref Screw Connection Current (A) Size Unit Packing Single Pole Sizes: DII, DIII Part Ref DIN Rail Connection Three Pole Single Pole Three Pole DI 25A SFD27 TFD27 SFRD27 TFRD27 15/4 DIII 63A SFD33 TFD33 SFRD33 TFRD33 (Three Terminal) 15/6 (Three Terminal) Specifications Description: D fuse carriers in ceramic bodies with versions for securing to DIN rail or screw connection. Complete range of accessories. Accessories Current Fuse Base Unit References (A) Type Packing Ratings: Accessories Size Volts: - 500V ac Amps: - 25 - 63A Fuse Carrier DII DIII 25A 63A DII E27 E33 CD27 CD33 2 4 6 10 16 20 25 E27 2GD27 4GD27 6GD27 10GD27 16GD27 20GD27 25GD27 DIII 35 50 63 E33 35GD33 50GD33 63GD33 DII 1 pole DIII 1 pole DII 3 pole DIII 3 pole 25 63 25 63 E27 E33 E27 E33 SFPRD27 SFPRD27 TFPCD27 TFPCD33 Applications: Protection of industrial circuits and electrical apparaturs. Gauge/ Calibration Ring Standards and Approvals: IEC 60269, VDE 0636, Dimensions Covers Size A B C D E F Size A B C D E F G H DII 41 39 44 47 60 62 DII 41 121 44 47 60 30 4.3 DIII 43 47 44 47 56 79 DIII 43 148 44 47 56 32 4.3 1 Pole A B C D DII 40 24 10.8 DIII 49 21 9 50 30 50 50 30 Size A B C D 50 DII E 44 12 34 62 DIII E 44 12 43 3 Pole A B C D 80 DII 121 24 10.8 80 80 DIII 148 21 9 80 For Product Data Sheets, visit www.cooperbussmann.com 45 Low Voltage Fuse Links Catalogue Other Low Voltage Fuse Ranges North American Standard Fuses and Holders Specifications Description: Round fuses and holders in accordance with North American standards. Some ranges available with fuse actuation display. Makes: CUBEFuse TM low-peak, Fusetron, Limitron, CCTron, Dura-LagTM, T-Tron, Optima. Modular fuse holders (class CC, Midget and class J), fuse holders and isolator circuit-breakers. Ratings: Volts: - 125 to 600V ac Amps: - 100mA to 6000A IR - 300kA Applications: General use for all types of protection and also motor protection. Standards and Approvals: Classes UL and CSA certified (consult us for types) Dimensions: Miniature, class CC, class RK5, class RK1, class J, class G, Midget, class L. 46 For Product Data Sheets, visit www.cooperbussmann.com Low Voltage Fuse Links Catalogue Medium Voltage Fuses and Isolators Fuses for Voltage and Transformer Auxiliary Fuses Other MV Fuses DIN Fuses Specifications Specifications Description: Complete range of fuses (back-up, full range), and also motor protection. Description: Medium Voltage fuses with low current values, which allow for the associated system to be isolated in the event of a fault in the transformer circuit. Ratings: Ratings: Volts: - 1 to 36kV ac Amps: - 2 - 10A IR - 25 - 50kA Volts: - 12 to 36kV ac Amps: - 6.3 to 160A Dimensions: DIN 43625, EN IEC 60782-1, VDE 0670-4 Applications: For use in the voltage transformer primary circuit and in transformer auxiliary elements, etc. Oil Fuses Standards and Approvals: BS2692-1, IEC 60282-1 Dimensions: Cylindrical body fuses with various length and diameter dimensions Specifications Description: Fuses for use in oil-insulated isolators and circuit breakers. Fuses fitted with a pyrotechnic plunger. Ratings: Volts: - 3.6 to 24kV ac Amps: - 6.3 to 250A Dimensions: BS 2692-1, ESI 12-8, EN IEC 60292-1 Starter Motor Fuses Specifications Description: Fuses to provide protection against shortcircuit in motor and engine circuits. Ratings: Volts: - 3.6 to 7.2kV ac Amps: - 5 to 400A Dimensions: Conform to British Standards, Standards UL and IEC DIN 43625 For Product Data Sheets, visit www.cooperbussmann.com 47 Low Voltage Fuse Links Catalogue Ultra Fast Fuses and Holders British Standard Fuses and Holders North American Standard Fuses and Holders Specifications Description: Standard British ultra-fast fuses. Possibility of adapting side indicators and auxiliary micro-switch as accessories. Ratings: Volts: - 240 - 690V ac / 150 to 500V dc Amps: - 6 - 900A IR - 200ka RMS Sym Applications: Protection of semiconductors, UPS (ASI), rectifiers, static relays, converters etc Standards and Approvals: Conform to standards BS884, EN IEC 60269-5, UL recognized Dimensions: Various fuses sizes in single or double cylindrical body 48 Specifications Description: Standard North American ultra-fast fuses. Fuse actuation display available on external and internal versions. Limited range of fuse bases Ratings: Volts: - 130 to 1000V ac / 130 to 800V dc Amps: - 1 to 4000A IR - 200kA RMS Sym Applications: Protection of semiconductors, UPS (ASI), rectifiers, static relays, converters, etc. Standards and Approvals: UL Recognised, CSA, Component Acceptance Dimensions: There are no standard dimensions with these types of fuses. For Product Data Sheets, visit www.cooperbussmann.com Low Voltage Fuse Links Catalogue Ultra Fast Fuses and Holders Cylindrical Fuses and Holders Square Body Fuses and Holders Specifications Specifications Description: Ultra Fast cylindrical fuses. Standard ranges without fuses actuation indicator and ranges with fuse blown indicator. Modular fuse holders (type CH) for sizes 10x38, 14x51 and 22x58, with light display and ancillary elements. Fuse holders for size 22x58. Description: Ultra Fast square-body fuses, in versions with visual indicator and striker for use with auxiliary microswitch. Fuses in formats DIN 43620, DIN 43653 (DIN 110 and DIN 80), French standard, North American standard. Ratings: Fuse bases to DIN 43620 and 43653. Volts: - 150 - 2000V ac / 150 to 1000V dc Amps: - 1 - 100A IR - 25 to 200kA RMS Sym Ratings: Applications: Protection of semi-conductors, UPS (ASI), rectifiers, static relays, converters. Standards and Approvals: Conform to standards IEC 60269, UL Recognition, CSA Component Acceptance (consult us). Dimensions: Variety of fuse sizes: from 6x32, 25x146 Volts: - 690 to 3000V ac Amps: - 10 to 700A IR - 300kA RMS Sym Applications: Protection of semidconductors, UPS (ASI), rectifiers, static relays, converters. Standards and Approvals: Conform to standards IEC 60269-4, UL Recognition, CSA Component Acceptance (consult us). Dimensions: Sizes 000, 00, 0, 1*, 1, 2, 3, 4, 5 For Product Data Sheets, visit www.cooperbussmann.com 49 Low Voltage Fuse Links Catalogue Index Catalogue Number 011-9127 011-9128 011-9129 011-9483 011-9679 012-0140 012-0141 059-0067 059-0107 059-0108 059-0109 059-0110 059-0111 059-0112 059-0113 059-0114 059-0115 059-0116 059-0117 059-0118 059-0119 059-0120 059-0121 059-0122 059-0123 059-0124 059-0125 059-0126 059-0127 059-0128 059-0129 059-0140 059-0141 059-0142 059-0143 059-0144 059-0145 059-0146 059-0147 059-0148 059-0149 059-0150 059-0151 059-0152 059-0153 059-0154 059-0155 059-9925 059-9926 1000NH4AG 1000NH4G-S 1000NHG4G 100D125 100KR85 100L09-660 100L14-660 100LR85 100MJ25-6 100MJ29-6 100MJ30-7 100MJ31-7 100NH00M 100NH0M 100NH1M 100NH2M 100NHG000B 100NHG000B-400 100NHG000BI 100NHG000BI-400 100NHG00B-690 100NHG00BI-690 100NHG01B 50 Page Catalogue Number Page Catalogue Number Page Catalogue Number Page 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 26 30 26 37 16 13 12 16 16 17 17 17 29 29 29 29 26 25 26 25 27 27 26 100NHG01B-400 100NHG01BI 100NHG01BI-400 100NHG02B 100NHG02B-400 100NHG02BI 100NHG02BI-400 100NHG0B 100NHG0B-690 100NHG1B-690 100NHG1BI-690 100NHG1BS-690 100NHG2B-690 100NHG2BI-690 100NHM00B 100NHM00BI 100NHM0B 100NHM1B 100NHM1BI 100NHM1BS-690 100NZ03 10D16 10D27 10GD27 10GN01 10H07-660 10HS07 10K08-660 10K09-660 10KR85 10KS09 10NHC00M 10NHG000B 10NHG000B-400 10NHG000B-690 10NHG000BI 10NHG000BI-400 10NHG000BI-690 10NHG01B 10NHG01BI 10NHG0B 10NHG0B-690 10NHM000B-690 10NHM000BI-690 10NHM0B 10NZ01 1250NH4AG 1250NH4G-S 1250NHG4G 125M09-660 125M13 125M14-660 125M23 125MJ25-6 125MJ30-7 125MJ31-7 125N11-660 125N20 125NH00M 125NH0M 125NH1M 125NH2M 125NHG00B 125NHG00B-400 125NHG00BI 125NHG00BI-400 125NHG01B 125NHG01B-400 125NHG01BI 125NHG01BI-400 125NHG02B 125NHG02B-400 25 26 25 26 25 26 25 26 27 27 27 30 27 27 28 28 28 28 28 30 35 37 37 38 36 12 11 13 13 16 11 29 26 25 27 26 25 27 26 26 26 27 28 28 28 35 26 30 26 13 14 12 14 16 17 17 13 14 29 29 29 29 26 25 26 25 26 25 26 25 26 25 125NHG02BI 125NHG02BI-400 125NHG0B 125NHG1B-690 125NHG1BI-690 125NHG1BS-690 125NHG2B-690 125NHG2BI-690 125NHG2BS-690 125NHM00B 125NHM00BI 125NHM1B 125NHM1BI 125NHM1BS-690 125NHM2B-690 125NHM2BI-690 125NHM2BS-690 15KR85 1600NH4AG 160M09-660 160M13 160M14-660 160M23 160MJ25-6 160MJ29-6 160MJ30-7 160MJ31-7 160N11-660 160N20 160NH00M 160NH0M 160NH1M 160NH2M 160NHG00B 160NHG00B-400 160NHG00BI 160NHG00BI-400 160NHG01B 160NHG01B-400 160NHG01BI 160NHG01BI-400 160NHG02B 160NHG02B-400 160NHG02BI 160NHG02BI-400 160NHG0B 160NHG1B-690 160NHG1BI-690 160NHG1BS-690 160NHG2B-690 160NHG2BI-690 160NHG2BS-690 160NHM00B 160NHM00BI 160NHM1B 160NHM1BI 160NHM1BS-690 160NHM2B-690 160NHM2BI-690 160NHM2BS-690 16D16 16D27 16GD27 16GN02 16H07-660 16HS07 16K08-660 16K09-660 16KS09 16NHC00M 16NHG000B 16NHG000B-400 26 25 26 27 27 30 27 27 30 28 28 28 28 30 28 28 30 16 26 13 14 12 14 16 17 17 17 13 14 29 29 29 29 26 25 26 25 26 25 26 25 26 25 26 25 26 27 27 30 27 27 30 28 28 28 28 30 28 28 30 37 37 38 36 12 11 13 13 11 29 26 25 16NHG000B-690 16NHG000BI 16NHG000BI-400 16NHG000BI-690 16NHG01B 16NHG01BI 16NHG0B 16NHG0B-690 16NHM000B-690 16NHM000BI-690 16NHM0B 16NZ01 200DF 200M09-660 200M13 200M14-660 200M23 200MJ25-6 200MJ29-6 200MJ30-7 200MJ31-7 200N11-660 200N20 200NH1M 200NH2M 200NHG02B 200NHG02B-400 200NHG02BI 200NHG02BI-400 200NHG1B 200NHG1B-400 200NHG1B-690 200NHG1BI 200NHG1BI-400 200NHG1BI-690 200NHG1BS-690 200NHG2B-690 200NHG2BI-690 200NHG2BS-690 200NHM1B 200NHM1BI 200NHM1BS-690 200NHM2B-690 200NHM2BI-690 200NHM2BS-690 20D16 20D27 20GD27 20GN02 20H07-660 20HS07 20K08-660 20K09-660 20KR85 20KS09 20MJ25-6 20MJ31-8 20NHC00M 20NHG000B 20NHG000B-400 20NHG000B-690 20NHG000BI 20NHG000BI-400 20NHG000BI-690 20NHG01B 20NHG01BI 20NHG0B 20NHG0B-690 20NHM000B-690 20NHM000BI-690 20NHM0B 20NZ02 27 26 25 27 26 26 26 27 28 28 28 35 19 13 14 12 14 16 17 17 17 13 14 29 29 26 25 26 25 26 25 27 26 25 27 30 27 27 30 28 28 30 28 28 30 37 37 38 36 12 11 13 13 16 11 16 17 29 26 25 27 26 25 27 26 26 26 27 28 28 28 35 For Product Data Sheets, visit www.cooperbussmann.com Low Voltage Fuse Links Catalogue Index Catalogue Number Page Catalogue Number Page Catalogue Number Page Catalogue Number Page 224NHG02B 224NHG02B-400 224NHG02BI 224NHG02BI-400 224NHG1B 224NHG1B-400 224NHG1B-690 224NHG1BI 224NHG1BI-400 224NHG1BI-690 224NHG2B-690 224NHG2BI-690 224NHG2BS-690 224NHM1B 224NHM1BI 224NHM1BS-690 224NHM2B-690 224NHM2BI-690 224NHM2BS-690 250M13 250MJ25-6 250MJ29-6 250MJ30-7 250MJ31-7 250N09-600 250N11-660 250N15 250N20 250N34 250NH1M 250NH2M 250NHG02B 250NHG02B-400 250NHG02BI 250NHG02BI-400 250NHG03B 250NHG03B-400 250NHG03BI 250NHG03BI-400 250NHG1B 250NHG1B-400 250NHG1B-690 250NHG1BI 250NHG1BI-400 250NHG1BI-690 250NHG2B-690 250NHG2BI-690 250NHG2BS-690 250NHG3B-690 250NHG3BI-690 250NHM1B 250NHM1BI 250NHM1BS-690 250NHM2B-690 250NHM2BI-690 250NHM2BS-690 25D16 25D27 25GD27 25GN02 25H07-660 25HS07 25KR85 25KS09 25MJ31-8 25NHC00M 25NHG000B 25NHG000B-400 25NHG000B-690 25NHG000BI 25NHG000BI-400 25NHG000BI-690 26 25 26 25 26 25 27 26 25 27 27 27 30 28 28 30 28 28 30 14 16 17 17 17 13 13 14 14 14 29 29 26 25 26 25 26 25 26 25 26 25 27 26 25 27 27 27 30 27 27 28 28 30 28 28 30 37 37 38 36 12 11 16 11 17 29 26 25 27 26 25 27 25NHG01B 25NHG01BI 25NHG0B 25NHG0B-690 25NHM000B-690 25NHM000BI-690 25NHM0B 25NZ02 2D16 2D27 2GD27 2GN01 2H07-660 2K08-660 2K09-660 2NHC00M 2NHG000B 2NHG000B-400 2NHG000B-690 2NHG000BI 2NHG000BI-400 2NHG000BI-690 2NZ01 30KR85 30LR85 30NH00AD 315M13 315MJ30-7 315MJ31-7 315N09-660 315N11-660 315N15 315N20 315N34 315NH2M 315NH3M 315NHG03B 315NHG03B-400 315NHG03BI 315NHG03BI-400 315NHG2B 315NHG2B-400 315NHG2B-690 315NHG2BI 315NHG2BI-400 315NHG2BI-690 315NHG2BS-690 315NHG3B-690 315NHG3BI-690 315NHG3BS-690 315NHM2B-690 315NHM2BI-690 315NHM2BS-690 315NHM3B-690 315NHM3BI-690 32BS 32BSC 32CML 32CMLC 32H07-660 32HS07 32K08-660 32K09-660 32KS09 32LSC 32LSCC 32MJ25-6 32MJ30-8 32MJ31-8 32NH0M 32NHC00M 32NHG000B 26 26 26 27 28 28 28 35 37 37 38 36 12 13 13 29 26 25 27 26 25 27 35 16 16 23 14 17 17 13 13 14 14 14 29 29 26 25 26 25 26 25 27 26 25 27 30 27 27 30 28 28 30 28 28 19 19 19 19 12 11 13 13 11 19 19 16 17 17 29 29 26 32NHG000B-400 32NHG000B-690 32NHG000BI 32NHG000BI-400 32NHG000BI-690 32NHG01B 32NHG01BI 32NHG0B 32NHG0B-690 32NHM000B-690 32NHM000BI-690 32NHM0B 32NNL 32NNSBS 32NNSF 32NNSFBS 355NH2M 355NHG03B 355NHG03B-400 355NHG03BI 355NHG03BI-400 355NHG2B 355NHG2B-400 355NHG2BI 355NHG2BI-400 355NHG3B-690 355NHG3BI-690 355NHG3BS-690 355NHM2B-690 355NHM2BI-690 355NHM2BS-690 355NHM3B-690 355NHM3BI-690 355P09-660 355P11-660 355P12-660 355P20 355P35 355PJ30-7 355PJ31-7 35D33 35GD33 35GN02 35NHG000B 35NHG000B-400 35NHG000B-690 35NHG000BI 35NHG000BI-400 35NHG000BI-690 35NHG01B 35NHG01B-400 35NHG01BI 35NHG01BI-400 35NHG02B 35NHG02B-400 35NHG02BI 35NHG02BI-400 35NHG0B 35NHG0B-690 35NHM000B-690 35NHM000BI-690 35NHM0B 35NZ02 400EF 400NH2M 400NH3M 400NHG03B 400NHG03B-400 400NHG03BI 400NHG03BI-400 400NHG2B 400NHG2B-400 25 27 26 25 27 26 26 26 27 28 28 28 20 20 20 20 29 26 25 26 25 26 25 26 25 27 27 30 28 28 30 28 28 13 13 13 14 14 17 17 37 38 36 26 25 27 26 25 27 26 25 26 25 26 25 26 25 26 27 28 28 28 35 19 29 29 26 25 26 25 26 25 400NHG2BI 400NHG2BI-400 400NHG3B-690 400NHG3BI-690 400NHG3BS-690 400NHM2B 400NHM2BI 400NHM2BS-690 400NHM3B-690 400NHM3BI-690 400NHM3BS-690 400P09-660 400P11-660 400P12-660 400P20 400P35 400PJ30-7 400PJ31-7 40K07-660 40K08-660 40K09-660 40KR85 40KS07 40KS08 40KS09 40LR85 40MJ25-6 40MJ30-8 40MJ31-8 40NH1M 40NHC00M 40NHG000B 40NHG000B-400 40NHG000B-690 40NHG000BI 40NHG000BI-400 40NHG000BI-690 40NHG01B 40NHG01B-400 40NHG01BI 40NHG01BI-400 40NHG02B 40NHG02B-400 40NHG02BI 40NHG02BI-400 40NHG0B 40NHG0B-690 40NHM000B-690 40NHM000BI-690 40NHM0B 450R11-660 450R12-660 450R20 450R40 450RJ31-7 45KR85 45NH00AD 4D16 4D27 4GD27 4GN01 4H07-660 4K08-660 4K09-660 4NHC00M 4NHG000B 4NHG000B-400 4NHG000B-690 4NHG000BI 4NHG000BI-400 4NHG000BI-690 4NZ01 26 25 27 27 30 28 28 30 28 28 30 13 13 13 14 14 17 17 12 13 13 16 11 11 11 16 16 17 17 29 29 26 25 27 26 25 27 26 25 26 25 26 25 26 25 26 27 28 28 28 13 13 14 14 17 16 23 37 37 38 36 12 13 13 29 26 25 27 26 25 27 35 For Product Data Sheets, visit www.cooperbussmann.com 51 Low Voltage Fuse Links Catalogue Index 52 Catalogue Number Page Catalogue Number Page Catalogue Number Page 500NH3M 500NH4G-S 500NHG3B 500NHG3B-400 500NHG3B-690 500NHG3BI 500NHG3BI-400 500NHG3BI-690 500NHG3BS-690 500NHG4G 500NHM3B-690 500NHM3BI-690 500NHM3BS-690 500R11-660 500R12-660 500R20 500R40 500RJ31-7 50D33 50GD33 50GN02 50K07-660 50K08-660 50K09-660 50KR85 50KS07 50KS08 50KS09 50LR85 50MJ30-8 50MJ31-8 50NH0M 50NH1M 50NHC00M 50NHG000B 50NHG000B-400 50NHG000BI 50NHG000BI-400 50NHG00B-690 50NHG00BI-690 50NHG01B 50NHG01B-400 50NHG01BI 50NHG01BI-400 50NHG02B 50NHG02B-400 50NHG02BI 50NHG02BI-400 50NHG0B 50NHG0B-690 50NHG1B-690 50NHG1BI-690 50NHM00B 50NHM00BI 50NHM0B 50NZ02 560R11-660 560R12-660 560R20 560SJ31-6 5KR85 60KR85 60LR85 60NH00AD 63/100BS 63/100CML 63/100LSC 630NH3M 630NH4AG 630NH4G-S 630NHG3B 630NHG3B-400 29 30 26 25 27 26 25 27 30 26 28 28 30 13 13 14 14 17 37 38 36 12 13 13 16 11 11 11 16 17 17 29 29 29 26 25 26 25 27 27 26 25 26 25 26 25 26 25 26 27 27 27 28 28 28 35 13 13 14 17 16 16 16 23 19 19 19 29 26 30 26 25 630NHG3BI 630NHG3BI-400 630NHG3BS-690 630NHG4G 630NHM3B 630NHM3BI 630NHM3BS-690 630R11-660 630R12-660 630R20 630SJ31-6 63D33 63ENL 63ENSBS 63ENSF 63ENSFBS 63GD33 63K07-660 63K08-660 63K09-660 63KS07 63KS08 63KS09 63MJ25-6 63MJ29-6 63MJ30-8 63MJ31-8 63NH00M 63NH0M 63NH1M 63NHG000B 63NHG000B-400 63NHG000BI 63NHG000BI-400 63NHG00B-690 63NHG00BI-690 63NHG01B 63NHG01B-400 63NHG01BI 63NHG01BI-400 63NHG02B 63NHG02B-400 63NHG02BI 63NHG02BI-400 63NHG0B 63NHG0B-690 63NHG1B-690 63NHG1BI-690 63NHG1BS-690 63NHG2B-690 63NHG2BI-690 63NHM00B 63NHM00BI 63NHM0B 63NHM1B-690 63NHM1BI-690 63NHM1BS-690 63NZ02 6D16 6D27 6GD27 6GN01 6H07-660 6K08-660 6K09-660 6NHC00M 6NHG000B 6NHG000B-400 6NHG000B-690 6NHG000BI 6NHG000BI-400 6NHG000BI-690 26 25 30 26 28 28 30 13 13 14 17 37 20 20 20 20 38 12 13 13 11 11 11 16 17 17 17 29 29 29 26 25 26 25 27 27 26 25 26 25 26 25 26 25 26 27 27 27 30 27 27 28 28 28 28 28 30 35 37 37 38 36 12 13 13 29 26 25 27 26 25 27 6NHG0B-690 6NHM000B-690 6NHM000BI-690 6NHM0B 6NZ01 70KR85 710S20 800NH4AG 800NH4G-S 800NHG4G 800S20 800SJ28 80D125 80KR85 80L09-660 80L14-660 80LR85 80MJ25-6 80MJ29-6 80MJ30-7 80MJ31-7 80NH00M 80NH0M 80NH1M 80NHG000B 80NHG000B-400 80NHG000BI 80NHG000BI-400 80NHG00B-690 80NHG00BI-690 80NHG01B 80NHG01B-40 80NHG01BI 80NHG01BI-400 80NHG02B 80NHG02B-400 80NHG02BI 80NHG02BI-400 80NHG0B 80NHG0B-690 80NHG1B-690 80NHG1BI-690 80NHG1BS-690 80NHG2B-690 80NHG2BI-690 80NHM00B 80NHM00BI 80NHM0B 80NHM1B 80NHM1BI 80NHM1BS-690 80NZ03 900NH4AG 90KR85 90NH00AD AAO10 AAO16 AAO2 AAO20 AAO25 AAO32 AAO32M40 AAO32M50 AAO32M63 AAO4 AAO6 AC10 AC16 AC2 AC20 AC25 AC32 27 28 28 28 35 16 14 26 30 26 14 17 37 16 13 12 16 16 17 17 17 29 29 29 26 25 26 25 27 27 26 25 26 25 26 25 26 25 26 27 27 27 30 27 27 28 28 28 28 28 30 35 26 16 23 5 5 5 5 5 5 5 5 5 5 5 8 8 8 8 8 8 For Product Data Sheets, visit www.cooperbussmann.com Catalogue Number AC4 AC6 AD10 AD16 AD2 AD20 AD25 AD32 AD4 AD6 BAO35 BAO40 BAO50 BAO63 BAO63M100 BAO63M80 BC0 BC00 BC1-2 BC3 BC40 BC50 BC63 BC63M100 BC63M80 BD40 BD50 BD63 BFD1-31/LL BFD1-31/LM BFD1-31/LW BFD1-33/LL BFD1-33/LM BFD1-33/LW BFD2-31/LL BFD2-31/LM BFD2-31/LW BFD2-33/LL BFD2-33/LM BFD2-33/LW BFD3-31/LL BFD3-31/LM BFD3-31/LW BFD3-33/LL BFD3-33/LM BFD3-33/LW BFH000-1A/T BFH000-3A/T BFH00-1A/F BFH00-3A/F BFH1-1A/F BFH1-3A/F BFH2-1A/F BFH2-3A/F BFH3-1A/F BFH3-3A/F BFR1-3K/LL BFR1-3K/LM/C BFR1-3K/LW BFR2-3K/LL BFR2-3K/LM/C BFR2-3K/LW BFR3-3K/LL BFR3-3K/LM/C BFR3-3K/LW C08G0.5 C08G1 C08G10 C08G10I C08G12 C08G12I C08G16 Page 8 8 8 8 8 8 8 8 8 8 6 6 6 6 6 6 32 32 32 32 8 8 8 8 8 8 8 8 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 41 41 41 41 41 41 41 41 41 41 39 39 39 39 39 39 39 39 39 21 21 21 21 21 21 21 Low Voltage Fuse Links Catalogue Index Catalogue Number C08G16I C08G2 C08G20 C08G20I C08G25 C08G25I C08G2I C08G4 C08G4I C08G6 C08G6I C08G8 C08G8I C10G0.5 C10G1 C10G10 C10G10I C10G12 C10G12I C10G16 C10G16I C10G2 C10G20 C10G20I C10G25 C10G25I C10G2I C10G32 C10G32I C10G4 C10G4I C10G6 C10G6I C10G8 C10G8I C10M0.16 C10M0.25 C10M0.5 C10M1 C10M10 C10M10I C10M12 C10M12I C10M16 C10M16I C10M1I C10M2 C10M20 C10M20I C10M25 C10M25I C10M2I C10M32 C10M32I C10M4 C10M4I C10M6 C10M6I C10M8 C10M8I C10NL C14G10 C14G10I C14G10S C14G12 C14G12I C14G12S C14G16 C14G16I c14G16S C14G2 C14G20 Page 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 21 21 21 21 21 21 21 21 21 21 21 Catalogue Number C14G20I C14G20S C14G25 C14G25I C14G25S C14G2I C14G2S C14G32 C14G32I C14G32S C14G4 C14G40 C14G40I C14G40S C14G45S C14G4I C14G4S C14G50 C14G50I C14G50S C14G6 C14G6I C14G6S C14G8 C14G8I C14G8S C14M0.25 C14M0.50 C14M1 C14M10 C14M10I C14M10S C14M12 C14M12I C14M12S C14M16 C14M16I C14M16S C14M1I C14M2 C14M20 C14M20I C14M20S C14M25 C14M25I C14M25S C14M2I C14M2S C14M32 C14M32I C14M32S C14M4 C14M40 C14M40I C14M40S C14M4I C14M4S C14M50 C14M50I C14M50S C14M6 C14M6I C14M6S C14M8 C14M8I C14M8S C14NL C1515 C1520 C180-10A C180-13A C180-1A Page 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 4 4 4 4 4 Catalogue Number C180-2A C180-3A C180-5A C180-7A C22G10 C22G100 C22G100I C22G100S C22G10I C22G10S C22G12 C22G125 C22G125I C22G125S C22G12I C22G12S C22G16 C22G16I C22G16S C22G2 C22G20 C22G20I C22G20S C22G25 C22G25I C22G25S C22G2I C22G32 C22G32I C22G32S C22G4 C22G40 C22G40I C22G40S C22G4I C22G4S C22G50 C22G50I C22G50S C22G6 C22G63 C22G63I C22G63S C22G6I C22G6S C22G8 C22G80 C22G80I C22G80S C22G8I C22G8S C22M10 C22M100 C22M100I C22M100S C22M10I C22M12 C22M125 C22M125I C22M125S C22M12I C22M16 C22M16I C22M16S C22M2 C22M20 C22M20I C22M20S C22M25 C22M25I C22M25S C22M2I Page 4 4 4 4 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 For Product Data Sheets, visit www.cooperbussmann.com Catalogue Number C22M32 C22M32I C22M32S C22M4 C22M40 C22M40I C22M40S C22M4I C22M50 C22M50I C22M50S C22M6 C22M63 C22M63I C22M63S C22M6I C22M8 C22M80 C22M80I C22M80S C22M8I C22NL C3030 C4545 C55 C8M10 C8M10I C8M12 C8M12I C8M16 C8M16I C8M2 C8M20 C8M20I C8M25 C8M2I C8M4 C8M4I C8M6 C8M6I C8M8 C8NL CA10D15 CA14D30 CA22D15 CA22D30 CA22D45 CA22D60 CD0623G2 CD0623G4 CD0623G6 CD0823G10 CD0823G10I CD0823G16 CD0823G16I CD0823G2 CD0823G2I CD0823G4 CD0823G4I CD0823G6 CD0823G6I CD0831G0.5 CD0831G1 CD0831G10 CD0831G10I CD0831G12 CD0831G12I CD0831G16 CD0831G2 CD0831G20 CD0831G20I CD0831G25 Page 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 4 4 4 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 23 23 23 23 23 23 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 53 Low Voltage Fuse Links Catalogue Index Catalogue Number CD0831G25I CD0831G2I CD0831G4 CD0831G4I CD0831G6 CD0831G6I CD0831G8 CD0836G10 CD0836G10I CD0836G16 CD0836G16I CD0836G2 CD0836G20 CD0836G20I CD0836G25 CD0836G25I CD0836G2I CD0836G32 CD0836G32I CD0836G4 CD0836G4I CD0836G6 CD0836G6I CD100 CD100M125 CD100M160 CD100M200 CD1025G10 CD1025G10I CD1025G16 CD1025G16I CD1025G6 CD1025G6I CD1031G16 CD1031G16I CD1031G20 CD1031G20I CD1031G25 CD1031G25I CD1038G25 CD1038G25I CD1038G32 CD1038G32I CD27 CD33 CD80 CEO100 CEO100M125 CEO100M160 CEO100M200 CEO32 CEO40 CEO50 CEO63 CEO80 CH081D CH081DI CH081DN CH081DNI CH081DNS CH081DNSI CH082D CH082DI CH083D CH083DI CH083DN CH083DNI CH083DNS CH083DNSI CH084D CH084DI CH141D 54 Page 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 8 8 8 8 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 38 38 8 6 6 6 6 6 6 6 6 6 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 24 Catalogue Number CH141DI CH141DMS CH141DMS-F CH141DN CH141DNI CH141DNX CH142D CH142DI CH143D CH143DI CH143DMS CH143DMS-F CH143DN CH143DNI CH143DNMS CH143DNMS-F CH144D CH144DI CH14-HP CH14MS-1D CH14MS-3D CH221D CH221DMS CH221DN CH221DNX CH222D CH223D CH223DMS CH223DN CH224D CH22MDNMS CH810-HP CHM1D CHM1DI CHM1DN CHM1DNI CHM1DNS CHM1DNSI CHM2D CHM2DI CHM3D CHM3DI CHM3DN CHM3DNI CHM3DNS CHM3DNSI CHM4D CHM4DI CHMDNX CM100F CM20F CM32F CM32FC CM63F CMSC CN01 CN02 CS0 CS00 CS1 CS2 CS3 DD125 DD160 DD200 DD200M250 DD200M315 DEO125 DEO160 DEO200 DEO200M250 DEO200M315 Page 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 19 19 19 19 19 19 36 36 32 32 32 32 32 8 8 8 8 8 7 7 7 7 7 Catalogue Number ED250 ED315 ED315M400 ED355 ED400 ED400M500 EF355 EF400 EF400M500 EFS125 EFS160 EFS200 EFS250 EFS315 ESD10 ESD16 ESD2 ESD20 ESD32 ESD4 ESD40 ESD50 ESD6 ESD63 ESD63M100 ESD63M80 FC0 FC00 FC1 FC2 FC3 FEH FF400 FF500 FF560 FF630 FG450 FG500 FG560 FG630 FN01C FN02C FRN01C FRN02C GF1000 GF1250 GF710 GF800 GG1000 GG1250 GG710 GG800 GH1000 GH1250 GH710 GH800 GLP LBS4/1 LBS4/3 M-32NNSF M-63ENSF M-AAO10 M-AAO16 M-AAO20 M-AAO25 M-BAO40 M-BAO50 M-BAO63 M-C180-13A M-C180-3A M-C180-5A M-CD100 Page 8 8 8 8 8 8 9 9 9 9 9 9 9 9 10 10 10 10 10 10 10 10 10 10 10 10 32 32 32 32 32 32 9 9 9 9 9 9 9 9 36 36 36 36 9 9 9 9 9 9 9 9 9 9 9 9 19 41 41 11 11 11 11 11 11 11 11 11 11 11 11 11 For Product Data Sheets, visit www.cooperbussmann.com Catalogue Number M-CEO100 M-CEO80 M-CM100F M-CM20F M-CM32F M-CM32FC M-CM63F M-NITD10 M-NITD16 M-NITD2 M-NITD20 M-NITD32 M-NITD6 M-NSD10 M-NSD16 M-NSD20 M-NSD32 M-NSD4 M-NSD6 M-STD10 M-STD6 NI NITD10 NITD16 NITD2 NITD20 NITD20M25 NITD20M32 NITD25 NITD32 NITD32M40 NITD32M50 NITD32M63 NITD4 NITD6 NSD10 NSD16 NSD2 NSD20 NSD20M25 NSD20M32 NSD20M36 NSD32 NSD32M36 NSD32M40 NSD32M50 NSD32M63 NSD4 NSD6 OSD100 OSD100M125 OSD100M160 OSD80 SB00-D SB0-D SB0-DMS SB1-D SB1-DMS SB2-D SB2-DMS SB3-D SB3-DMS SB4-DMS SB4-S SFD27 SFD33 SFPCDO1 SFPCDO2 SFPRD27 SFPRD33 SFRD27 SFRD33 Page 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 19 5 5 5 5 5 5 5 5 5 5 5 5 5 10 10 10 10 10 10 10 10 10 10 10 10 10 10 7 7 7 7 32 32 32 32 32 32 32 32 32 32 32 38 38 36 36 38 38 38 38 Low Voltage Fuse Links Catalogue Index Catalogue Number SL0 SL00 SL1 SL2 SL3 SL4 SMD10 SMD16 SMD2 SMD20 SMD25 SMD32 SMD4 SMD6 SP0 SP00 SP1-2 SP3 SP4 SSD10 SSD16 SSD2 SSD20 SSD32 SSD4 SSD6 STD10 STD16 STD2 STD20 STD25 STD32 STD4 STD6 TB00-D TB0-D TB1-D TB2-D TB3-D TFD27 TFD33 TFN01C TFN02C TFPCD27 TFPCD33 TFPCDO1 TFPCDO2 TFRD27 TFRD33 TFRN1C TFRN2C Page 32 32 32 32 32 32 15 15 15 15 15 15 15 15 32 32 32 32 32 10 10 10 10 10 10 10 15 15 15 15 15 15 15 15 32 32 32 32 32 38 38 36 36 38 38 36 36 38 38 36 36 For Product Data Sheets, visit www.cooperbussmann.com 55 Cooper Bussmann® Products and Technical Support Delivered Worldwide Customer Assistance Web Services Customer Satisfaction Team www.cooperbussmann.com The Cooper Bussmann® Customer Satisfaction Team is available to answer questions regarding Cooper Bussmann® products and services. The Cooper Bussmann® website makes available free information and other resources that include:  Product Data Sheets for complete technical information on Cooper Bussmann® products  Online catalogue for the latest United States and European catalogues Contact should be made between: Monday to Friday: 7:30am to 5:30pm GMT The Customer Sastisfaction Team can be reached via:    Phone: 00 44 (0) 1509 882 600 Fax: 00 44 (0) 1509 882 786 Email: sales@cooperbussmann.co.uk  Safety BASCISTM for the essentials of electrical safety  Training modules for increasing skill levels of customers and end users  Fuse Cross-reference to find the correct Cooper Bussmann® replacement for a competitive fuse  Arc-Flash calculator to determine the incident energy level and flash protection boundry along with the recommendations the level of Personal Protective Equipment (PPE) Application Engineering Application Engineering assistance is available to all customers. The Application Engineering team is staffed by degreed electrical engineers and available by phone with technical and application support Monday to Friday: 7:30am to 5:30pm GMT. Application Engineering can be reached via:    Phone: 00 44 (0) 1509 882 699 Fax: 00 44 (0) 1509 882 794 Email: technical@cooperbussmann.co.uk Your authorised Cooper Bussmann® Distributor is: Cooper Bussmann (UK) Ltd  Burton-on-the-Wolds, Loughborough  Leicestershire LE12 5TH, UK Tel: 00 44 (0) 1509 882 600  Fax: 00 44 (0) 1509 882 786 Email: sales@cooperbussmann.co.uk  Website: www.cooperbussmann.com Reorder: LV-2007
SB3-D 价格&库存
很抱歉,暂时无法提供与“SB3-D”相匹配的价格&库存,您可以联系我们找货
SB3-D
  • 1+2872.211051+372.76057
