1610-21-10A
1610-21-10A
    E-T-A
1610-21-10A 数据手册
Thermal Automotive Circuit Breaker 1610-... Description Miniaturised single pole press-to-reset cycling trip free thermal circuit breaker designed for automotive fuse block installation. Extends the benefits of circuit breaker performance and convenience to applications which are cost critical. Colour-coded housing caps or manual release buttons available. Version 1616 is available especially for the automotive industry (current ratings correspond to those of blade fuses). Typical applications 1 Extra low voltage wiring systems on all types of vehicles and marine craft. 1610-21 1610-H2 1610-92 Ordering information Technical data Type No. 1610 single pole automotive circuit breaker Voltage rating 21 DC 24 V, with reset button H2 DC 24 V, with reset button and manual release facility 92 DC 12 V, autoreset (type I to SAE J 553) Current ratings 5 6 8 10 15 20 25 30 A 1610 - 21 - 8 A ordering example Please be informed that we have minimum ordering quantities to be observed. Preferred types Preferred types Standard current ratings (A) 1610-21- 5 6 8 10 15 20 25 30 x x x x x x x x Current ratings, typical voltage drop values and colour coding Current rating (A) Voltage drop (mV) Actuator colour manual release (1610-H2) or housing cap colour (1610-21) 5 < 150 light-brown 6 < 150 green 8 < 150 golden yellow 10 < 150 red 15 < 150 blue 20 < 150 yellow 25 < 150 pearl 30 < 150 light-green Caution: It is good practice to switch off the vehicle‘s ignition system before re-setting the circuit breaker. Free travel of the reset button must be ensured! Please ensure to push in the actuator smoothly and completely. Note Approvals The circuit breakers are marked with current rating, type and maximum voltage. Special machine readability is not guaranteed. 2239 For further details please see: www.e-t-a.de/ti_e Voltage rating 1610-92: DC 12 V 1610-21/1610-H2: DC 12 V / DC 24 V Max. voltage rating 1610-92 DC 14,5 V 1610-21/1610-H2 DC 32 V Current ratings 5...30 A Service short-circuit breaking capacity 300 operations at ≤ 50 A Reset period for 1610-92 (at 23 °C) ≤ 15 s Ambient temperature -40...+85 °C (-40...+185 °F) Degree of protection operating area IP30 (-21/-H2) (IEC 60529/DIN 40050) operating area IP54 (-92) terminal area IP00 Ultimate short-circuit breaking capacity ≥ 3 break operations at 150 A, or ≥ 1 break operation at 2,000 A Vibration 10 g (57-500 Hz) ± 0.38 mm (10-57 Hz) (with mounting socket 12) to IEC 60068-2-6, test Fc 10 frequency cycles/axis Shock 50 g (11 ms) (with mounting socket 12) to IEC 60068-2-27, test Ea Corrosion 96 hours at 5 % salt mist, to IEC 60068-2-11, test Ka Humidity 240 hours at 95 % RH, to IEC 60068-2-78, test Cab Mass approx. 5 g Authority Standard Rated voltage Current ratings UL UL 1500 Ignition Protected DC 24 V 5 A…30 A www.e-t-a.de 1 Thermal Automotive Circuit Breaker 1610-... Dimensions Internal connection diagrams 1610-21 Please leave space for button travel 20 .787 1610-92 1 1 1 2 2 2 2.7 .106 Typical time/current characteristic curve .252 7.5 .295 1 6.4 1610-H2 4.5 .177 3.4 6 .236 24 .945 0.8±0.5 ON .031.±.020 4±0.5 OFF 157±.020 1610-21 5.2 .205 0.6 .024 3.3 .130 14.5 .571 16.6 .654 18.8 .740 5...30 A 10000 3.9 .154 + 85 °C + 185 °F + 23 °C + 73.4 °F 1000 - 40 °C - 40 °F Trip time in seconds 20 .787 3.4 .134 6 .236 10 7.5 .295 0,1 .252 6.4 100 1 24 .945 29.5 4.5 3 .118 Please leave space for button travel .177 7.3 .287 0.8±0.5 ON .031±.020 4±0.5 OFF .157±.020 1610-H2 0,4 0,8 1 2 4 6 8 10 20 40 ... times rated current 5.2 .205 0.6 .024 3.3 .130 14.5 .571 16.6 .654 18.8 .740 3.9 .154 1610-92 20 6 .236 .787 The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below. See also section Technical information. Ambient temperature °F Ambient temperature °C -40 -40 -22 -30 -4 -20 +14 -10 +32 0 +50 +10 Derating factor 0.73 0.78 0.82 0.86 0.91 0.95 +73.4 +23 +104 +40 +122 +50 +140 +60 +158 +70 +185 +85 1 1.09 1.16 1.25 1.33 1.43 Ambient temperature °F Ambient temperature °C 6.4 .252 7.5 .295 24 .945 Derating factor 5.2 .205 14.5 .571 16.6 .654 18.8 .740 19.2 .756 0.6 .024 3.3 .130 1 .039 3.9 .154 This is a metric design and millimeter dimensions take precedence ( mm ) inch 2 www.e-t-a.de 2239 Thermal Automotive Circuit Breaker 1610-... Accessories Socket 12-P10 Ordering information Mounting socket 12 32.6 1.29 25.4 1.00 Weidmüller style label (not supplied) 3.5 .138 47 1.85 43 1.69 blade terminal DIN 46244-A6.3-0.8 (QC .250) 58 2.28 48 1.89 ø3.9 .154 12.7 .500 symmetrical hat rail EN 50022-35x7.5 Type No. 12 Mounting socket Terminal design P10 blade terminals A 6.3-0.8 (QC .250) J20 screw terminals 6-32 UNC A10 1 blade terminal A6.3-0.8 (QC .250) / 1 screw terminal 6-32 UNC Version (blank) single socket 20 two-way 30 three-way 40 four-way 60 six-way 12 - P10 - 20 ordering example Labels: Weidmüller, D-33102 Paderborn Accessories for mounting socket 12 Socket 12-J20 32.6 1.29 25.4 1.00 Weidmüller style label (not supplied) terminal screw 6-32 UNC tightening torque max. 1.2 Nm Connector bus links -P10 X 210 588 01/ 1.5 mm2 (AWG 16), brown (up to 13 A max. load) X 210 588 02/ 2.5 mm2 (AWG 14), black (up to 20 A max. load) X 210 588 03/ 2.5 mm2 (AWG 14), red (up to 20 A max. load) X 210 588 04/ 2.5 mm2 (AWG 14), blue (up to 20 A max. load) 100 quick-connect tabs 6.3 (.250) DIN 46247 tinned brass, insulated ~70 ~2.76 3.5 .138 47 1.85 43 1.69 spring washer 58 2.28 12.7 .500 symmetrical hat rail EN 50022-35x7.5 Bus bar (supplied as a complete package) (up to 100 A max. load) X 211 157 01 with terminal X 211 157 02 without terminal Socket 12-A10 32.6 1.29 25.4 1.00 Weidmüller style label (not supplied) washer A 4.3 DIN 125 nickel plated cylinder head screw ISO1207-M4x4 nickel plated Cu rail, tin-plated 7 .276 58 2.28 symmetrical hat rail EN 50022-35x7.5 12.8 .504 154.8 6.09 fusible link 1.1mm (.043 in.) thick constriction) 10 .394 3.5 .138 M4 48 1.89 ø3.9 .154 12.7 .500 spring washer max.cross section 35 mm2 (AWG 2) blade terminal DIN 46244-A6.3-0.8 (QC .250) 47 1.85 43 1.69 terminal screw 6-32 UNC tightening torque max. 1.2 Nm 2 .079 ø3.9 .154 48 1.89 7 60 2.36 48 1.89 .276 13 .512 ø4 .157 Dimensions for surface mounting Other sockets available to special order Labels: Weidmüller, D-33102 Paderborn 2239 This is a metric design and millimeter dimensions take precedence ( mm ) inch All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. www.e-t-a.de 3 1 1 2-4 www.e-t-a.de 2239
1610-21-10A 价格&库存
很抱歉,暂时无法提供与“1610-21-10A”相匹配的价格&库存,您可以联系我们找货
1610-21-10A
  • 1+110.899901+12.77153
  • 5+92.053265+10.60110
  • 10+84.9402110+9.78194
  • 50+70.4227650+8.11008
  • 100+64.93117100+7.47765
  • 250+58.28456250+6.71221
  • 500+53.67867500+6.18178
  • 1000+49.404231000+5.68953
库存:1475
