1658-G21-01-P10-10A
1658-G21-01-P10-10A
    E-T-A
    1658-G21-01-P10-10A
1658-G21-01-P10-10A 数据手册
Thermal Overcurrent Circuit Breaker 1658-... Description Very cost effective design to meet international requirements. No exposed metal parts which are, or could become, current-carrying except for terminals. R-type TO CBE to EN 60934. l Manual reset, cycling trip free mechanism l Extremely small and lightweight l UL, CSA, VDE and EN 60934 (IEC 60934) approved Typical applications Battery chargers, consumer products, power supplies, motors. 1 1658-... Ordering information Type No. 1658 single pole thermal circuit breaker Threadneck design G21 manual reset type, 3/8“-27 threadneck A00 auto reset type, without threadneck Hardware 00 no hardware 01 one PAL nut Y306 671 01, bulk 02 one PAL nut Y306 671 01, one knurled nut Y307 117 02, bulk Terminals P10 blade terminals A6.3-0.8 (QC .250) P13 blade terminals A6.3-0.8 (QC .250), 90° Current ratings 5 ...30 A 1658 - G21 - 02 - P10 - 5 A Technical data For further details please see: http://www.e-t-a.de/ti_e Voltage rating AC 240 V; DC 28 V Current ratings 5...30 A Typical life AC + DC 5...16 A 1,000 operations at 2 x IN, inductive 17...25 A 1,000 operations at 2 x IN, resistive operat. IN UN Behaviour at rated switching capacity (EN 60934; 40 5...16 A AC 240 V 6 x IN ind test sequence D) 40 5...16 A DC 28 V 4 x IN ind Ordering example 40 17...25 A AC 240 V 40 17...25 A DC 28 V * Screws and lock washers bulk shipped Please be informed that we have minimum ordering quantities to be observed. Compliances Preferred types Preferred types Standard current ratings (A) 5 6 7 8 9 1658-G21-02-P10- x x x x x 10 12 15 16 20 25 30 x x x x 1658-G21-02-P13- x x x x x x x x x 1658-A00-00-P10- x x x x x x x x x x x x Standard current ratings and typical voltage drop values Current rating (A) voltage drop values (mV) Current rating (A) voltage drop values (mV) 5 ≤ 250 12 ≤ 250 6 ≤ 250 15 ≤ 250 7 ≤ 250 16 ≤ 250 8 ≤ 250 20 ≤ 250 9 ≤ 250 25 ≤ 250 10 ≤ 250 30 ≤ 250 2147 120 A resistive 120 A resistive Ambient temperature -20...+60 °C (-4...+140 °F), ≤ 7 A max. +40 °C (+104 °F) Insulation co-ordination rated impulse pollution (IEC 60664 and 60664 A) withstand voltage degree 2.5 kV 2 reinforced insulation in operating area Dielectric strength (IEC 60664 and 60664A) test voltage operating area AC 3,000 V Insulation resistance > 100 MΩ (DC 500 V) Interrupting capacity Icn 5...7 A 180 A 8...30 A 200 A Interrupting capacity IN UN (UL 1077/EN 60934 PC1) 5...16 A AC 240 V 1 000 A, C, 1 5...30 A AC 125 V 2 000 A, C, 1 5...30 A DC 32 V 2 000 A, C, 1 5...30 A AC 125 V 2 000 A, C, 1 DC 28 V (1658-A...) Degree of protection operating area IP40 (IEC 60529/DIN 40050) terminal area IP00 Vibration 8 g (57-500 Hz) ± 0.61 mm (10-57 Hz), to IEC 60068-2-6, test Fc, 10 frequency cycles/axis Shock 30 g (11 ms) to IEC 60068-2-27, test Ea Corrosion 96 hours at 5 % salt mist, to IEC 60068-2-11, test Ka Humidity 240 hours at 95 % RH to IEC 60068-2-78, test Cab Mass approx. 16 g www.e-t-a.de 1 Thermal Overcurrent Circuit Breaker 1658-... Internal connection diagram ø6 .236 1 27 1.06 6 .236 1 .039 0.7 .028 12.7 .500 ON OFF Dimensions 2 2 12 .472 1 1 17.5 .689 Typical time/current characteristics 13.6 .535 14 .551 15.7 .618 10000 +60 °C +140 °F +23 °C +73.4 °F -20 °C -4 °F 32 1.26 A00 G21 Trip time in seconds 1000 tightening torque max. 0.8 Nm 3/8-27UNS-2A 100 4 .157 10 1 See ordering information for mounting hardware. 0.1 1 Terminal design 2 4 6 8 10 … times rated current 20 40 P13 3 .118 P10 2 1 12 .472 1 blade terminals DIN 46244-A6.3-0.8 (QC .250) 2 8.5 .335 blade terminals DIN 46244-A6.3-0.8 (QC .250) angled 90° Installation drawing The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below. See also section Technical information. Ambient temp. °F Ambient temp. °C -4 -20 +14 -10 +32 0 +73.4 +23 +104 +40 +122 +50 +140 +60 Derating factor IN > 7A IN < 7A 0.83 0.74 0.85 0.76 0.9 0.82 1 1 1.1 1.23 1.18 - 1.25 - 7 .276 operating area 34 1.34 1 5 .197 2 5 .197 4 .157 4 .157 mounting area This is a metric design and millimeter dimensions take precedence ( mm ) inch 2 www.e-t-a.de 2147 Thermal Overcurrent Circuit Breaker 1658-... Accessories Reset button seal for 3/8", 27-thread, short long X 201 285 01 (IP64) X 200 799 01 (IP64) PAL nut 3/8", 27-thread Y 306 671 01 2.5 .098 14.3 .563 0.5 .020 3/8-27 UNS-2B 3/8-27 UNS-2B 3/8-27UNS-2B Knurled nut 3/8", 27-thread plastic (standard) Y 307 117 02 1 Panel cut out ø15 .591 3 .118 1658-3/8-27 UNS-2A 9 Ø 9,6 3/8-27UNS-2B Knurled nut 3/8", 27-thread nickel-plated brass Y 300 190 03 ø13 .512 Approvals 2.5 .098 Authority Standard Rated voltage Current ratings Approval mark 1658-G VDE IEC/EN 60934 AC 240 V DC 28 V 5 A…25 A 5 A…25 A UL UL 1077 CSA C22.2 No 235 UL 1500 Ignition Protected AC 240 V DC 32 V 5 A…30 A 5 A…30 A CSA CSA C22.2 No 235 AC 240 V DC 32 V 5 A…30 A 5 A…30 A 3/8-27UNS-2B Hex nut 3/8", 27-thread nickel-plated brass Y 300 192 01 3/8-27UNS-2B 2.5 .098 1658-A SW14 .551 VDE IEC/EN 60934 AC 240 V DC 28 V 5 A…25 A 5 A…25 A UL UL 244A AC 125 V DC 28 V 5 A…30 A 5 A…30 A Press to Reset Plate for 3/8" thread, aluminium Y 301 059 02 ø21.4 .843 0.4 .016 BREA SS TO RE T PR E SE E- T - ® R KE A ø9.9 .390 This is a metric design and millimeter dimensions take precedence ( mm ) inch All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 2147 www.e-t-a.de 3
1658-G21-01-P10-10A 价格&库存
很抱歉,暂时无法提供与“1658-G21-01-P10-10A”相匹配的价格&库存,您可以联系我们找货
