1620-1-10A
1620-1-10A
    E-T-A
    1620-1-10A
1620-1-10A 数据手册
Thermal automotive Mini-CBE 1620-... Description Single pole, thermal miniaturised circuit breaker designed for automotive applications. Fits into fuse blocks designed to ISO 8820-3, Type F. Automatic reset (for DC 12 V only) and open circuit (modified reset to SAE) version optional. Open circuit version ensures contacts staying open as long as power is on. The circuit breaker will reset after the load is removed. Particularly suitable for installation in inaccessible locations. Current ratings correspond to those of blade fuses. Clear colour coding of the ratings: blade fuse and circuit breaker of the same colour have the same rating. 1 SAE type 1 SAE type 2 SAE type 3 Meets the requirements of SAE J553. US patent number: US 8,576,042,B2 Technical data Typical applications Protection of electrical systems of passenger cars, trucks, buses, watercraft, extra low voltage wiring systems. Ordering information Type No. 1620 single pole thermal Mini-CBE with standard characteristic curve Version, according to SAE J553 1 type 1, automatic reset 2 type 2, modified reset 3 type 3, with reset button Current ratings 5 7.5 10 15 20 25 30 A 1620 - 1 - 10 A ordering example Please be informed that we have minimum ordering quantities to be observed. Current ratings, typical voltage drop values and colour coding Current rating (A) Voltage drop (mV) Housing cap colour 5 < 150 light brown 7.5 < 150 brown 10 < 150 red 15 < 150 blue 20 < 150 yellow 25 < 150 white 30 < 150 light green Note The circuit breakers are marked with current rating, type and maximum voltage. Special machine readability is not guaranteed. For further details please Voltage rating Max. voltage rating Current ratings Service short-circuit breaking capacity see: www.e-t-a.de/ti_e 1620-1/-2: DC 12 V 1620-3: DC 12 V, DC 24 V 1620-1/-2: DC 14.5 V 1620-3: DC 29.0 V DC 12 V: 5...30 A DC 24 V: 5...25 A Ambient temperature Reset period for 1620-1 (at 23 °C) Reset period for 1620-2 (at 23 °C) after 5 sec at rated voltage Degree of protection (IEC 60529) Ultimate short-circuit breaking capacity Vibration Shock Corrosion Humidity Mass -40...+85 °C (-40…+185 °F) (for higher temperatures please enquire) 300 operations at 2 x IN ≤ 15 s < 35 s operating area IP40 (-3) operating area IP50 (-1, -2) terminal area IP00 ≥ 3 break operations at 150 A, or ≥ 1 break operation at 2,000 A 10 g (57-500 Hz), ± 0.38 mm (10-57 Hz) to IEC 60068-2-6, test Fc 10 frequency cycles/axis SAE-J553, Step No. 14, § 4.2.7.1.5 50 g (11 ms) to IEC 60068-2-27, test Ea SAE-J553, Step No. 14, § 4.2.7.1.6 48 hrs in 5 % salt mist, to IEC 60068-2-11, test Ka SAE-J553, Step No. 14, § 4.2.7.1.3 240 hrs in 95 % RH, to IEC 60068-2-78, test Cab SAE-J553, Step No. 14, § 4.2.7.1.2 approx. 3 g Caution: It is good practice to switch off the vehicle’s ignition system before manually releasing or re-setting the circuit breaker. Free travel of the reset button must be ensured! Please ensure to push in the actuator smoothly and completely. Depending on the socket used and with the 30 A device carrying a full load, the temperatures at the terminals may rise above the allowed SAE value. 2214 www.e-t-a.de 1 Thermal automotive Mini-CBE 1620-... Dimensions Internal connection diagrams 7 .276 1 1 2 2 1620-3H 1 1 2 2 1 10.4 .409 11.6 .457 GERMANY 2 .079 25 .984 13.3 .524 1620-3 1620-2 1620-1 1620-1 / 1620-2 Typical time/current characteristic curve at +23 °C / +73.4 °F 7.5 .295 5...30 A 4.5 .177 12.7 .500 1000 13.3 .524 3.5 .138 0.6 .024 1.8 .071 25 .984 2 .079 0.8±0.5 ON .031±.019 ON 2 .079 4.5±0.5 OFF .177±.019 OFF 1620-3 0.8 3.8 .032 .149 2.8 .110 trip time in seconds 2.8 10.9 .429 -40 °C +85 °C +23 °C 10000 100 10 1 GERMANY 11.6 .457 0.1 0.4 0.6 0.8 1 2 4 6 8 10 20 40 times rated current The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below. See also section Technical information. 1620-3H 4.8 .189 13.3 .524 Ambient temperature °F Ambient temperature °C 7 .275 3.5 .138 Derating factor Ambient temperature °F Ambient temperature °C -4 -20 +14 -10 +32 0 +50 +10 0.73 0.78 0.82 0.86 0.91 0.95 +73.4 +23 +104 +40 +122 +50 +140 +60 +158 +70 +185 +85 1 1.09 1.16 1.25 1.33 1.43 24.95 .982 30.2 1.19 GERMANY 11.6 .457 -22 -30 0.8±0.5 ON .031±.019 ON 4.5±0.5 OFF .177±.019 OFF Derating factor -40 -40 This ist a metric design and millimeter dimensions take precedence (mm inch) All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved. Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 2 www.e-t-a.de 2214
1620-1-10A 价格&库存
很抱歉,暂时无法提供与“1620-1-10A”相匹配的价格&库存,您可以联系我们找货
1620-1-10A
