N22-B1-24-610-121-C3
    CARLING
    CIRBRKRMAG-HYDR10A120VAC
N22-B1-24-610-121-C3 数据手册
N-Series Hydraulic-Magnetic Circuit Breaker P ROD UC T W E BP A GE request sample, configure part, watch video Low Profile Datacom/Telecom Applications The N-Series is a full-featured hydraulic-magnetic circuit breaker packaged in an innovative low profile design to meet the smaller size requirements of datacom/telecom power distribution units and rack systems. Its features include easy access line and load terminals with UL 489 compliant sliding terminal barriers, an optional current transformer capable of sensing current down to a level of 1%, and a patented flush rocker actuator with push-toreset guard to protect against inadvertent actuation. The N-Series is available as a one or two pole configuration with ratings from 1 to 30 amps, up to 277VAC for one pole or 120/240VAC for two poles with a max IC of 22,000 amps. 1-2 1-30 120/240 22,000 Amps Poles Amps Typical Applications ∙ Power Distribution Units www.carlingtech.com ∙ Data Servers 860.793.9281 ∙ Data Storage sales@carlingtech.com VAC Max Interrupting Capacity Design Features CURRENT TRANSFORMER Remote current sensing via Molex® connector UPPER ARC RUNNER Optional, for 277 VAC rated breakers GRIDS (5x) Arc deionizing splitter plates that increase arc voltage for quick interrupt “ LOAD “ “ LINE “ TERMINAL Allows for easy hook-up of wires on both sides of the breaker LOWER ARC RUNNER Motivates arc off of the stationary contact SLIDING TERMINAL BARRIERS 2. Tech Specs Environmental Electrical Dielectric Strength Current Ratings UL, CSA-1960V 50/60 Hz for one minute between all electrically isolated terminals. Comply with the 8mm spacing and 3750V 50/60 Hz dielectric requirements from hazardous voltage to operator accessible surfaces and between main circuits of adjacent poles per Publications EN 60950 and VDE 0805 Environmental MIL-PRF-55629 and MIL-STD-202G Operating Temp. -40°C to +85°C Vibration Withstands 0.06” excursion from 10-55 Hz and 10Gs 55-500 Hz at rated current per MIL-PRF-55629 and MIL-STD-202G, Method 204D, Test Condition A. Instantaneous and ultra-short curves tested at 90% of rated current Integrated current transformer. Measurement range: 1-30 Amps. Voltage output: 10mV per Amp according to the formula below: 2(Amp) ≤ I ≤ 30(Amp) V = 0.01× I ± 2% (with current metering codes 1 or 2) V = 0.01× I ±1% (with current metering codes 3 or 4) Shock MWithstands 50 Gs, 6 ms saw tooth while carrying rated current per MIL-PRF-55629 and MIL-STD-202G, Method 213B, test condition “I”. Instantaneous and ultra short curves tested at 90% of rated current Thermal Shock MIL-PRF-55629 and MIL-STD-202G, Method 107G, Condition A (5-cycles at -55ºC to +25ºC to +85ºC to +25ºC Moisture Resistance MIL-PRF-55629 and MIL-STD-202G, Method 106G, i.e., Ten 24-hour cycles at +25°C to +65°C, 80-98% RH Salt Spray Method 101, Condition A (90-95% RH @ 5% NaCl Solution, 96hrs) V V10 I I10 V10 I10 I~ (FROM 1 - 30 AMPS) 0.85% Where V=CT output in volts V10 =CT output in volts with I=I10 =10 (A); I=primary current in amperage (50/60 Hz). Phase shift between primary current and CT output is 0.25±0.25°. Maximum crest factor of primary current is 1.73. R1 shall be integrated in the breaker. R2 and R3 are provided by end user and external to the breaker. Connection: below Load Terminal. 2-pin connector, Molex® 35362-0250. Mating Connector housing – Molex® PN35507-0200. (Current metering is available on AC rated devices only) R2=14Ω±Y% R1=28Ω±Y% V R3=14Ω±Y% I : 1400 CT Impedance See next page Insulation Resistance Minimum of 100 Megohms @ 500VDC Overload 50 operations @ 600% of rated current for AC rated devices Interrupt Capacity See table A Mechanical 3. Number of Poles 1 - 2 poles Termination Wire ready and touch proof wire clamp (See Figure 1). Accepts up to (2) #10 AWG wires per terminal. Designed for use with solid, stranded and flexible stranded wires, with or without ferrule or pin terminals. Also accepts straight fork and flanged fork terminals. Termination Torque 15-20 in-lbs (Line & Load terminals) Termination Barrier Integral sliding barrier to comply with spacing requirements (See figure 1) Mounting Threaded Insert: #6-32 UNC-2B, or M3X0.5-6H B ISO Insert Termination Torque 7-9 in-lbs Actuator Rocker, with or without guard (See figures 1, 2, and 4) Internal Circuit Config. Series Trip Materials Housing - Glass Filled Polyester Rocker – Nylon Line/Load Terminals - Copper Alloy; Bright Acid Tin Plated Weights ~107 grams (~3.76 ounces) per pole Standard Color Housing – Black Rocker - Several (See ordering scheme for colors) V=0.01 X (I) Note: When current metering code is 1 or 2; Y to equal 1.0 When current metering code is 3 or 4; Y to equal 0.1 Current Ratings 10,000 “On-Off” operations @ 6 per minute; with rated current & voltage Trip Free Trips on overload even when actuator is forcibly held in the “On” position Trip Indication Physical The operating actuator moves positively to the “Off” position when an overload causes the breaker to trip *Manufacturer reserves the right to change product specification without prior notice. Tech Specs Electrical Tables Table A: Voltage and Current Ratings Electrical Ratings Interrupt Capacity (Amps) Voltage Current (Amps) UL 489 Number of Poles EN60947-2 1-20 A 21-30 A 1-20 A 21-30 A Icu Ics Icu Ics 120/240 VAC 1 - 30 2 22000 5000 10000 5000 10000 5000 240 VAC 1 - 20 1 10000 N/A 10000 5000 5000 5000 277 VAC 1 - 20 1 10000 N/A N/A N/A Electrical: Impedance / Resistance 60 Hz 1/2 Cycle Inrush Pulse Tolerance Time Delay Curves 42, 44 & 46 (30 Amps Max.) Multiple of Rated Current Ir 25x Time Delay Curves 22, 24 & 26 (30 Amps Max.) 12x t 4.165 16.67 8.33 Time in Milliseconds 50 Hz 1/2 Cycle Inrush Pulse Tolerance Ir CURRENT TOLERANCE 0.10 - 5.0 +/- 15 5.1 - 30.0 +/- 25 (AMPS) Multiple of Rated Current Time Delay Curves 42, 44 & 46 (30 Amps Max.) 22x Time Delay Curves 22, 24, & 26 (30 Amps Max.) 10x t 5.0 10.0 20.0 Time in Milliseconds Agency Approvals UL489, cUL, TUV EN60947-2 Time Delay Specs To view all hydraulic-magnetic circuit breaker time delay values, please visit www.carlingtech.com/sites/default/files/documents/Carling-HM-CB-Time-Delays.pdf 4. *Manufacturer reserves the right to change product specification without prior notice. (%) Ordering Scheme Sample Part Number Selection N 1 1 1 - B 0 - 24-620 - 1 2 1 - D G 2 3 4 5 1. SERIES 1 1 Single Color Low Profile Rocker, Vertical Legend Single Color Low Profile Rocker, Horizontal Legend Single Color Push To Reset Low Profile Rocker, Vertical Legend Single Color Push To Reset Low Profile Rocker, Horizontal Legend 3. POLES One 2 Two 4. CIRCUIT B Actuator Color White Black Red Green Blue Yellow Gray Orange I-O ON-OFF A B C D F G H J K L M N P Q R S 1 2 6. FREQUENCY & TIME DELAY 12. AGENCY APPROVAL 50/60 Hz Ultra Short 50/60 Hz Short 50/60 Hz Medium 50/60 Hz Long 42 44 46 50/60 Hz Short, High-inrush 50/60 Hz Medium, High-inrush 50/60 Hz Long, High-inrush 7. CURRENT RATING (AMPERES) 410 1.00 512 1.25 415 1.50 517 1.75 420 2.00 522 2.25 425 2.50 527 2.75 430 3.00 435 3.50 11 12 440 4.00 445 4.50 450 5.00 455 5.50 460 6.00 465 6.50 470 7.00 475 7.50 480 8.00 485 8.50 Dual Legend Color 1 Black 2 White 3 White 4 White 5 White 6 Black 7 Black 8 Black 6-32 x .195 inches Threaded Inserts ISO M3 x 5 mm Threaded Inserts 11. APPLICATION RATING CODE AMPERES 10 Screw Terminal 0 Without Current Transformer 1 1 Integrated Current Transformer, +/- 2%, 1 per unit 2 Integrated Current Transformer, +/- 2%, 1 per pole 3 2,6 Integrated Current Transformer, +/- 1%, 1 per unit 4 6 Integrated Current Transformer, +/- 1%, 1 per pole 21 22 24 26 9 10. MOUNTING Series Trip (Current) 5. CURRENT METERING 5. 8 9. ACTUATOR COLOR & LEGEND 2. ACTUATOR 1 2 3 4 7 8. TERMINAL N-Series Circuit Breaker N 6 490 9.00 495 9.50 610 10.00 710 10.50 611 11.00 711 11.50 612 12.00 712 12.50 613 13.00 614 14.00 615 15.00 616 16.00 617 17.00 618 18.00 620 20.00 622 22.00 624 24.00 625 25.00 630 30.00 C 120/240 VAC (2 Pole only) D 2 240 VAC 3 F 277 VAC A G U 4 3 5 Without Approvals UL 489 Listed TUV Certified, IEC 60947-2 UL 489 Listed, TUV Certified Notes: 1 On multi pole units one current transformer is supplied on the actuator pole 2 Available up to 20 amps 3 Voltage rating F only available as a 1 pole device at 20 amps maximum 4 TUV approval requires dual (I-O, ON-OFF) markings 5 Approval Code “3” requires Dual (I-O, ON-OFF) markings on rocker. 6 +/-1% tolerance only available when used with +/-0.1% tolerance external burden resistor. Configure Complete Part Number > Browse Standard Parts > Dimensional Specs inches [millimeters] Figure 1. N-Series 1-Pole Construction LINE 0.750 [19.05] MAXIMUM 0.185 [4.70] INSERT 6-32 or M3 x .195 [4.95] DEEP 0.187 [4.75] 1.760 [44.70] SEE DETAIL A 3.915 ± 0.015 [99.44 ± 0.38] TERMINAL BARRIER SHOWN IN OPEN POSTION 1.356 [34.44] 3.675 [93.34] TERMINAL BARRIER SHOWN IN CLOSED POSTION 0.187 [4.74] 1.135 [28.83] 0.490 [12.45] 0.105 [2.67] OFF O 0.603 [15.33] INTERGRATED MOLEX CONNECTOR CURRENT METERING SUPPLIED ON ACTUATOR POLE OR EVERY POLE ON I 37.0˚ 2X 1.400 [35.56] WIRE INSERTION POINT DETAIL A PUSH TO RESET ACTUATOR Notes: 1 Tolerance ±.020 [.51] unless otherwise specified. 6. Dimensional Specs inches [millimeters] Figure 2. N-Series 2-Pole Construction 1.500 [38.10] MAXIMUM #8-32 SCREW TOUCH PROOF WIRE CLAMP TERMINAL 2.962 [75.23]TYP TERMINAL BARRIER SHOWN IN OPEN POSTION N-Series 3-Pole Construction 2.250 [57.15] MAXIMUM Figure 3. Panel Cutout Details 1 POLE 0.75 [19.05] 1.73 [43.94] 2 POLE 0.156 TYP [3.96] 0.75 [19.05] 0.75 [19.05] 0.75 TYP [19.05] 0.75 TYP [19.05] 1.38 [35.05] 0.175 [4.45] Notes: 1 Tolerance ±.020 [.51] unless otherwise specified. 7. 3 POLE Authorized Sales Representatives and Distributors Click on a region of the map below to find your local representatives and distributors or visit www.carlingtech.com/findarep. CANADA EUROPE USA MIDDLE EAST MEXICO AFRICA ASIA-PACIFIC OCEANIA SOUTH AMERICA About Carling Founded in 1920, Carling Technologies is a leading manufacturer of electrical and electronic switches and assemblies, circuit breakers, electronic controls, power distribution units, and multiplexed power distribution systems. With six ISO9001 and IATF16949 registered manufacturing facilities and technical sales offices worldwide, Carling Technologies Sales, Service and Engineering teams do much more than manufacture electrical components, they engineer powerful solutions! To learn more about Carling please visit www.carlingtech.com/company-profile. To view all of Carling’s environmental, quality, health & safety certifications please visit www.carlingtech.com/environmental-certifications. 8. © Carling Technologies, Inc. Carling is a registered trademark of Carling Technologies, Inc. in the U.S. and other countries.
N22-B1-24-610-121-C3 价格&库存
很抱歉,暂时无法提供与“N22-B1-24-610-121-C3”相匹配的价格&库存,您可以联系我们找货
