1658-A21-00-P10-25A
1658-A21-00-P10-25A
    E-T-A
    CIR BRKR THRM 25A 240VAC 28VDC
1658-A21-00-P10-25A 数据手册
Thermal Overcurrent Circuit Breaker 1658-... Description Very cost effective design to meet international requirements. No exposed metal parts which are, or could become, current-carrying except for terminals. R-type TO CBE to EN 60934. ● Manual reset, cycling trip free mechanism ● Extremely small and lightweight ● UL, CSA, VDE and EN 60934 (IEC 60934) approved 1 Typical applications Battery chargers, consumer products, power supplies, motors. Ordering information 1658-F 1658-... Type No. 1658 single pole thermal circuit breaker Threadneck design G21 manual reset type, 3/8"-27 threadneck G41 manual reset type, 7/16"-28 threadneck E00 manual reset without threadneck F01 snap-in type F02 press to reset, snap-in type A21 auto reset type, 3/8"-27 threadneck A41 auto reset type, 7/16"-28 threadneck A00 auto reset type, without threadneck A01 auto reset, snap-in type Hardware bulk mounted configuration hex nut knurled nut hex nut knurled nut 00 0 0 0 0 01 1 (PAL) 0 0 0 02 1 (PAL) 1 0 0 03 0 0 1 (PAL) 0 04 0 0 1 (PAL) 1 05 0 1 1 (PAL) 0 06 0 1 0 0 07 1 0 0 0 08 2 0 0 0 09 1 1 0 0 10 0 0 0 1 1 (plastic) 0 0 12 (3/8-27 UNS) 1(PAL) 0 0 1 (PAL) 1 (plastic) 14 (3/8-27 UNS) 0 1 (plastic) 1 (PAL) 0 15 (3/8-27 UNS) 0 1 (plastic) 0 0 16 (3/8-27 UNS) 19 (3/8-27 UNS) 1 1 (plastic) 0 0 0 0 0 1 (plastic) 20 (3/8-27 UNS) Terminals P10 blade terminals A6.3-0.8 (QC .250) P13 blade terminals A6.3-0.8 (QC .250), 90° S80 straight screw terminals* S83 90° bent screw terminals* Current ratings 5 ... 30 A Technical data Voltage rating Current ratings Typical life AC 240 V; DC 28 V 5...30 A 1,000 operations at 2 x IN Ambient temperature -20...+60 °C (-4...+140 °F), 100 MΩ (DC 500 V) 200 A IN UN 5...16 A AC 240 V 2,000 A 18...30 A AC 120 V 2,000 A 5...30 A DC 28 V 2,000 A operating area IP 40 terminal area IP 00 8 g (57-500 Hz) ±0.61 mm (10-57 Hz), to IEC 60068-2-6, Test Fc, 10 frequency cycles/axis 30 g (11 ms) to IEC 60068-2-27, test Ea 96 hours at 5 % salt mist, to IEC 60068-2-11, test Ka 240 hours at 95 % RH to IEC 60068-2-3, test Ca approx. 16 g Approvals 1658 - G21 - 02 - P10 - 5 A Ordering example * Screws and lock washers bulk shipped Standard current ratings and typical voltage drop values Authority Voltage rating VDE (EN 60934) AC 240 V; DC 28 V Current ratings 5...25 A UL, CSA AC 250 V 5...15 A 1658-G... AC 240 V 16 A 1658-G... 1658-G... Current rating (A) 5 Voltage drop (mV) ≤ 150 Current rating (A) Voltage drop (mV)) AC 120 V 30 A 12 ≤ 140 AC 125 V 17...25 A 1658-G... 6 ≤ 150 15 ≤ 240 DC 28 V 5...30 A 1658-G... 7 ≤ 150 16 ≤ 240 8 ≤ 150 20 ≤ 240 9 ≤ 150 25 ≤ 240 10 ≤ 140 30 ≤ 240 Issue D ☎ All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. USA (847) 827-7600 - www.e-t-a.com - ☎ CANADA (905) 764-9510 65 Thermal Overcurrent Circuit Breaker 1658-... Installation drawing operating area 27 1.06 1 7 .276 0.7 .028 12.7 .500 ON ø6 .236 6 .236 0.5 .020 OFF Dimensions 1 2 2 34 1.34 12 .472 1 5 .197 17.5 .689 5 .197 15.7 .618 4 .157 4 .157 13.6 .535 14 .551 mounting area 32 1.26 Terminal design A00 S83 3 .118 P10 3/8-27UNS-2A A21 2 1 9.6 -0.1 .378 -.004 8.5 .335 P13 terminal screw 6-32 UNC P10-S83 1 2 1 3/8-27UNS-2A Tightening Torque= 0.8 Nm 8.5 .335 4 .157 blade terminals DIN 46244-A6.3-0.8 (QC .250) angled 90° lock washer terminal screw 6-32 UNC 2 12 .472 mounting hole 10.2 ±0.1 .402 ±.004 terminal screw 6-32 UNC lock washer G41 10 .394 7/16-28UNS-2A double “D” 11.2 ±0.1 .441 ±.004 10 .394 2 blade terminals DIN 46244-A6.3-0.8 (QC .250) S80 1 A41 lock washer 3 .118 8.9 -0.1 .350 -.004 blade terminals DIN 46244-A6.3-0.8 (QC .250) G21 2 12 .472 1 mounting hole See ordering information for mounting hardware mm This is a metric design and millimeter dimensions take precedence ( inch ) 66 ☎ USA (847) 827-7600 - www.e-t-a.com - ☎ CANADA (905) 764-9510 Issue D Thermal Overcurrent Circuit Breaker 1658-... Internal connection diagram 1 1 2 Typical time/current characteristics +60 °C +140 °F +23 °C +73.4 °F -20 °C -4 °F 10000 Trip time in seconds 1000 100 10 1 0.1 1 2 4 6 8 10 … times rated current 20 40 The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below. See also section 9 – Technical information. Ambient temperature °F °C Multiplication factor Issue D -4 +14 +32 +73.4 +104 +122 +140 -20 -10 0 +23 +40 +50 +60 0.76 0.84 0.92 1 1.08 1.16 1.24 ☎ USA (847) 827-7600 - www.e-t-a.com - ☎ CANADA (905) 764-9510 67 Thermal Overcurrent Circuit Breaker 1658-... Accessories Mounting nut 3/8", 27-thread Y306 671 01 14.3 .563 Mounting nut 7/16", 28-thread Y303 200 01 2.5 .098 1 16 .630 0.5 .020 0.5 .020 3 .118 Knurled nut 7/16", 28-thread nickel-plated brass Y302 294 03 Knurled nut 3/8", 27-thread nickel-plated brass Y300 190 03 2.5 .098 2.5 .098 7/16-28 UNS-2B 7/16-28UNEF-2B 2.5 .098 SW14 .551 ø21.4 .843 Press to Reset Plate for 7/16", 28-thread, aluminium Y302 732 01 ø24 .945 0.4 .016 T SE SS E E PR PR T E-T - TO RE BR E A R SS ® A KE BREA R KE A 0.4 .016 SE Press to Reset Plate for 3/8", 27-thread, aluminium Y301 059 02 E- T - 7/16-28 UNS-2B Hex nut 7/16", 28-thread nickel-plated brass Y302 295 01 SW14 .551 ® Reset button seal for 7/16", 28-thread, short long X222 119 01 X222 119 02 7/16-28UNEF-2B Hex nut 3/8", 27-thread nickel-plated brass Y300 192 01 3/8-27 UNS-2B 3.2 .126 ø16 .630 3/8-27UNS-2B 3/8-27UNS-2B 3/8-27 UNS-2B 7/16-28UNEF-2B 3/8-27UNS-2B ø13 .512 Reset button seal for 3/8", 27-thread, short long X201 285 01 X200 799 01 E TO R ø9.9 ø11.2+0.7 .390 .441+.028 Plastic knurled nut for 3/8", 27-thread Y307 117 02 mm This is a metric design and millimeter dimensions take precedence ( inch ) 68 ☎ USA (847) 827-7600 - www.e-t-a.com - ☎ CANADA (905) 764-9510 Issue D
1658-A21-00-P10-25A 价格&库存
很抱歉,暂时无法提供与“1658-A21-00-P10-25A”相匹配的价格&库存,您可以联系我们找货
