106-M3-P10-5A
106-M3-P10-5A
    E-T-A
    CIRBRKRTHRM5A
106-M3-P10-5A 数据手册
Thermal Overcurrent Circuit Breakers 104/105/106-... Description Miniaturised single pole thermal circuit breaker with push-to-reset tease free, trip-free, snap action mechanism (R-type TO CBE to EN 60934). Available in versions for PCB or panel mounting, snap-in or threadneck, or as an integral type. Manual release facility optional for type 105. Approved to CBE standard EN 60934 (IEC 60934). For higher current ratings see type 1140. 1 Typical applications Motors, transformers, solenoids, printed circuit boards, hand-held machines and appliances, marine applications, caravans. Type No. 104 PCB mounting type (-PR), or integral type (-P30/P10) 105 snap-in panel mounting 106 threadneck panel mounting with hex and knurled nut * (international version) 106-M1 as 106 but for standard fuseholder cut-out * (double D) 106-M2 threadneck panel mounting 3/8-27UNS with collar, hex nut and knurled nut* (US version) 106-M3 as 106-M2 but for standard fuseholder cut-out (double D) Terminal design P10 blade terminals A6.3-0.8 (QC .250) P30 blade terminals A2.8-0.8 (QC .110) PR solder terminal pins for PCB mounting (type 104 only) PR2 PCB mounting (vertical), type 104 only up to 6 A PR3 PCB mounting (vertical), type 104 only Shunt terminal (optional) A3 same as main terminals (up to IN 6 A/3 A max. load) Manual release facility H type 105 only Auxiliary contacts (optional) Si51 type 104 only Current ratings 0.05...10 A - - 105-... 106-... Technical data Ordering information 106-M2 - P30 104-... -5A Voltage rating Current ratings Auxiliary circuit Typical life AC 240 V; DC 48 V (UL: AC 250 V) 0.05...10 A 0.5 A, AC 240 V, DC 28 V 0.05...5 A: 3,000 operations at 2 x IN 6 ...8 A: 500 operations at 2 x IN 10 A 50 operations at 2 x IN with -H: 0.05...8 A 2,000 operations at 1 x IN 10 A 200 operations at 1 x IN Ambient temperature Insulation co-ordination (IEC 60664 and 60664 A) -20...+60 °C (-4...+140 °F) T 60 Rated impulse Pollution withstand voltage degree 2.5 kV 2 reinforced insulation in operating area Dielectric strength (IEC 60664 and 60664A) operating area Insulation resistance Interrupting capacity Icn Test voltage Interrupting capacity (UL 1077) = ordering example AC 3,000 V >100 MΩ (DC 500 V) 0.05 ... 2 A 6 x IN 2.5 ...10 A 5 x IN IN UN 0.05...10 A AC 250 V 0.05...10 A DC 48 V 2000 A 200 A The exact part number required can be built up from the table of choices shown above. Ordering references for optional features should be omitted if not required. Degree of protection (IEC 60529/DIN 40050) operating area IP 40 terminal area IP 00 * mounting hardware bulk shipped Vibration 10 g (57-500 Hz),±0.76 mm (10-57 Hz), to IEC 60068-2-6, test Fc, 10 frequency cycles/axis 25 g ( 11 ms) to IEC 60068-2-27, test Ea 96 hours at 5 % salt mist, to IEC 60068-2-11, test Ka Packaging quantity: 125 pcs Standard current ratings and typical internal resistance values Current rating (A) 0.05 0.08 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 1 1.2 1.5 Issue C Internal resistance (Ω) 285 134 81 22 8.7 5.5 3.3 2.45 1.6 1.45 0.9 0.6 0.4 Current rating (A) 1.8 2 2.5 3 3.5 4 4.5 5 6 7 8 10 ☎ Internal resistance (Ω) 0.28 0.25 0.18 0.11 0.076 0.067 0.051 ≤ 0.05 ≤ 0.05 ≤ 0.05 ≤ 0.05 ≤ 0.05 Shock Corrosion Humidity Mass 240 hours at 95 % RH, to IEC 60068-2-3, test Ca approx. 10 g Approvals Authority VDE (EN 60934), SEV Voltage ratings AC 240 V DC 48 V Demko AC 250 V, DC 28 V CSA, UL AC 250 V, DC 48 V Semko AC 250 V, DC 48 V Kema (EN 60934) AC 240 V DC 48 V Circuit breakers with -Si51 not approved USA (847) 827-7600 - CANADA (905) 764-9510 Current ratings 0,05...8 A 0.05...10 A 0.05...10 A 0.05...10 A 0.1...10 A 0,05...8 A 0.05...10 A 27 Thermal Overcurrent Circuit Breakers 104/105/106-... Dimensions 104-PR 7...10 A 0.05...6 A 9 .354 1 8±0.2 .315±.008 17.5 .689 19 .748 21 .827 3 9.5 .374 17.5 .689 ø1.5 .059 30 1.18 2 1 ø1.5 .059 2 9.5 .374 8±0.2 .315±.008 104-PR3 0.05...6 A 6.2 .244 1.2 .047 27.6 1.09 29.6 1.17 0.9 .035 1.2 .047 0.05...6 A 2.1 .083 7.7 .303 12.5 .492 ø1.5 .059 8±0.2 .315±.008 2 9.5 .374 5.4 .213 4 .157 6.5...10 A 0.9 .035 23.5 .925 1 15.4 .606 6.5...10 A 5 21.5 .846 23.5 .925 2 8±0.2 19 .748 ø1 .039 5 .197 4 0.9 .035 11 .433 ø1 .039 17.5 .689 max. 3 max .118 10 .394 4.5 .177 104-PR-Si51 7...10 A 3 9 .354 PCB mounting holes 21.5 .846 1 1.2 .047 hole for mounting screw M2x5 5 4 15.4 .606 6.5 .256 17.5 .689 19 .748 21 .827 12.5 .492 9.5 .374 4 .157 cut-out dimensions 11 .433 9 .354 ø4 .157 6.5 .256 21 .827 23 .906 27.6 1.09 31.6 1.24 1.2 .047 3.5 .138 0.8 .031 0.8 .031 (A3) ø7 .276 ON 9.5 OFF .374 6.5 .256 ø0.9 .035 ON ø4 .157 1 .039 .315±.008 ø1.5 .059 11 .433 104-P30-A3 terminal design for correct stand-off distances 5 .197 0.8 .031 0.5 .020 30 1.18 7.3 .287 104-P30 ø7 .276 10 OFF .394 1 .039 104-PR 7...10 A 0.5 .020 terminal design for correct stand-off distances 19 .748 104-PR-(A3-)Si51 104-PR-Si51 104-PR-A3-Si51 0.05...6 A PCB mounting holes 104-PR 104-PR-A3 0.05...6 A 4.5 .177 6.5 .256 11 .433 9 .354 max. 3 max .118 3.5 .138 blade terminals DIN 46244-A2.8-0.8 (QC .110) cut-out dimensions 6.5 .256 Ø 2.2 .087 hole for mounting screw M2 usable depth 4.5 mm (.177 in.) 29.6 1.16 27.6 1.09 6.5 .256 9.5 .374 1.2 .047 max. 3 max .118 27.6 1.09 29.6 1.16 6.5 .256 9.5 .374 max. 3 max .118 1 ø4 .157 ON 9.5 OFF .374 ø4 .157 ON OFF ø7 .276 1.2 .047 104-P30 5.4 .213 4 .157 7.7 .303 ø1.5 .059 mm This is a metric design and millimeter dimensions take precedence ( inch ) 28 ☎ USA (847) 827-7600 - CANADA (905) 764-9510 Issue C Thermal Overcurrent Circuit Breakers 104/105/106-... Dimensions ON 0.7 .028 27.6 1.09 19 .748 19 .748 9.6 .378- -0.1 .004 9 .354 ø7 .276 106-P30 7...10 A 106-P30-A3 0.05...6 A 27.6 1.09 29.6 1.16 6.5 .256 1.2 .047 14 .551 19 .748 blade terminals DIN 46244-A2.8-0.8 (QC .110) mounting hole a 12 .472 b a inch .862 .866 .870 .874 106-M2 11.3 +0.3 .445 +.012 3/8-27UNS-2A tightening torque 0.8 Nm mounting hole ø9.6 - 0.1 .378 - .004 mm 21.9 22 22.1 22.2 d d mm inch .031 0.8 .039 1.0 .059 1.5 2-3 .079-.118 ±0.1 panel thickness >0.8 mm ø16 >.031 in. .630 ± .004 b 25 .984 mounting hole 11 .433 11.3 +0.15 - 0.1 tightening torque 0.5 Nm ø18.8 .740 .445 +.006 - .004 106-M1 9.5 .374 max. 3 max .118 9.5 .374 2 .079 ø4 .157 ON OFF 105-P30 11 blade terminals .433 DIN 46244-A2.8-0.8 (QC .110) mounting hole 15.7 .618 SW14 .551 8.9 - 0.1 .350 - .004 9.5 .374 7 .276 8.8 .346 9 .354 1 1.2 .047 max. 3 max .118 1.2 .047 3.6 .142 2 .079 11 .433 hole for mounting screw M2x5 max. 3 max .118 0.8 .031 ø4 .157 27.6 1.09 29.6 1.17 6.5 .256 38.5 1.52 7 .276 15 .591 6.5 .256 3/8-27UNS-2A tightening torque 0.8 Nm 10.5 .413 OFF ø4 .157 13.5 .531 ON 9.5 OFF .374 106-P30 ø7 .276 7 .276 104-PR2 0.05...6 A 105P307...10 A 105-P30-A3 0.05...6 A 8.9 - 0.1 .350 - .004 3.8 .150 105-P30-H 106-M3 ø7 .276 3/8-27UNS-2A tightening torque 0.8 Nm mounting hole +0.15 Issue C .551±.016 14±0.4 12 .472 25 .984 13.8 - 0.1 ø16 ± 0.1 .630 ± .004 11 .433 .543+.006 -.004 6.5 .256 ø4 .157 2 .079 9.5 OFF .374 ON 0,05 ...6 A mm This is a metric design and millimeter dimensions take precedence ( inch ) ☎ USA (847) 827-7600 - CANADA (905) 764-9510 29 Thermal Overcurrent Circuit Breakers 104/105/106-... Installation drawings Internal connection diagrams operating area 104-… Types 104 105 106 Types 104-...-A3 105-...-A3 106-...-A3 Types 104-...-A3-Si51 1 1 1 3 3 4 8 .315 8 .315 1 5 2 2 mounting area 8 .315 2 8 .315 Typical time/current characteristics +23°C/+73.4°F operating area max. 2 max .079 105-… 10000 0.05 - 6 A 7 - 10 A 8 .315 8 .315 mounting area Trip time in seconds 8 .315 8 .315 1000 100 10 106-… max. 2 max .079 operating area 1 0.1 8 .315 2 4 6 8 10 … times rated current 20 40 The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below. See also section 9 – Technical information. 8 .315 8 .315 1 mounting area 8 .315 Terminal design Ambient temperature °F °C Multiplication factor -4 +14 +32 +73.4 +104 +122 +140 -20 -10 0 +23 +40 +50 +60 0.76 0.84 0.92 1 1.08 1.16 1.24 Accessories 104/105/106-P10 0.05...6 A 7...10 A 10 .394 blade terminals DIN 46244-A6.3-0.8 (QC .250) 6.3 .248 104/105/106-P10-A3 Water splash cover (transparent)/knurled nut assembly (type 106-... only) X 201 285 01 Degree of protection IP 64 polarizing tooth 104/105/106-P30-A3 0.05...6 A 0.05...6 A mm 9.5 .374 This is a metric design and millimeter dimensions take precedence ( inch ) polarizing tooth 30 All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 5.3 .209 ☎ USA (847) 827-7600 - CANADA (905) 764-9510 Issue C
106-M3-P10-5A 价格&库存
很抱歉,暂时无法提供与“106-M3-P10-5A”相匹配的价格&库存,您可以联系我们找货
106-M3-P10-5A
  • 50+136.0043650+17.62876
