1626-3-10A
1626-3-10A
    E-T-A
1626-3-10A 数据手册
Thermal automotive Mini-CBE 1626-... Description Single pole, thermal miniaturised circuit breaker designed for automotive applications. Fits into fuse blocks designed to ISO 8820-3, Type F. Automatic reset (for DC 12 V only) and open circuit (modified reset to SAE) version optional. Open circuit version ensures contacts staying open as long as power is on. The circuit breaker will reset after the load is removed. Particularly suitable for installation in inaccessible locations. Current ratings correspond to those of blade fuses. Clear colour coding of the ratings: blade fuse and circuit breaker of the same colour have the same rating. 1 SAE type 1 SAE type 2 SAE type 3 Breakers rated 7.5 A through 30 A have a fast characteristic curve and only hold 70 % of their rated current continuously. US patent number: US 8,576,042,B2 Technical data Typical applications Protection of electrical systems of passenger cars, trucks, buses, watercraft, extra low voltage wiring systems. Ordering information Type No. 1626 single pole thermal Mini-CBE with standard characteristic curve Version, according to SAE J553 1 type 1,automatic reset 2 type 2, modified reset 3 type 3, with reset button Current ratings 5 7.5 10 15 20 25 30 A 1626 - 1 - 10 A ordering example Please be informed that we have minimum ordering quantities to be observed. Current ratings, typical voltage drop values and colour coding Current rating (A) Voltage drop (mV) Housing cap colour 5 < 150 light brown 7.5 < 150 brown 10 < 150 red 15 < 150 blue 20 < 150 yellow 25 < 150 white 30 < 150 light green Note The circuit breakers are marked with current rating, type and maximum voltage. Special machine readability is not guaranteed. For further details please Voltage rating Max. voltage rating Current ratings Service short-circuit breaking capacity Ambient temperature Reset period for 1626-1 (at 23 °C) Reset period for 1626-2 (at 23 °C) after 5 sec at rated voltage Degree of protection (IEC 60529) Ultimate short-circuit breaking capacity Vibration Shock Corrosion Humidity Mass see: www.e-t-a.de/ti_e 1626-1/-2: DC 12 V 1626-3: DC 12 V, DC 24 V 1626-1/-2: DC 14.5 V 1626-3: DC 29.0 V 5...30 A 5 A: medium characteristic curve 7.5...30 A: fast characteristic curve 300 operations at 2 x IN -40...+85 °C (-40…+185 °F) (for higher temperatures please enquire) ≤ 15 s < 35 s operating area IP40 (-3) operating area IP50 (-1, -2) terminal area IP00 ≥ 3 break operations at 150 A, or ≥ 1 break operation at 2,000 A 10 g (57-500 Hz), ± 0.38 mm (10-57 Hz) to IEC 60068-2-6, test Fc 10 frequency cycles/axis SAE-J553, Step No. 14, § 4.2.7.1.5 50 g (11 ms) to IEC 60068-2-27, test Ea SAE-J553, Step No. 14, § 4.2.7.1.6 48 hrs in 5 % salt mist, to IEC 60068-2-11, test Ka SAE-J553, Step No. 14, § 4.2.7.1.3 240 hrs in 95 % RH, to IEC 60068-2-78, test Cab SAE-J553, Step No. 14, § 4.2.7.1.2 approx. 3 g Caution: It is good practice to switch off the vehicle’s ignition system before manually releasing or re-setting the circuit breaker. Free travel of the reset button must be ensured! Please ensure to push in the actuator smoothly and completely. All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved. Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 2214 www.e-t-a.de 1 Thermal automotive Mini-CBE 1626-... Dimensions Internal connection diagrams 7 .276 1 1 2 2 1626-3H 1 1 2 2 1 Typical time/current characteristic curve at +23 °C / +73.4 °F 10.4 .409 11.6 .457 GERMANY 2 .079 25 .984 13.3 .524 1626-3 1626-2 1626-1 1626-1 / 1626-2 5A 7.5 .295 10000 0.8 3.8 .032 .149 2.8 .110 12.7 .500 1000 trip time in seconds 4.5 .177 2.8 10.9 .429 1626-3 3.5 .138 1.8 .071 25 .984 2 .079 0.8±0.5 ON .031±.019 ON 2 .079 0.6 .024 4.5±0.5 OFF .177±.019 OFF 13.3 .524 100 10 1 0,1 0,4 0,6 0,81 11.6 .457 GERMANY 2 4 6 8 10 20 40 20 40 times rated current 7.5...30 A 10000 trip time in seconds 1000 1626-3H This ist a metric design and millimeter dimensions take precedence (mm inch) 13.3 .524 7 4.8 3.5 .275 .189 .138 10 1 0.8±0.5 ON .031±.019 ON 4.5±0.5 OFF .177±.019 OFF 25 .984 30.2 1.19 11.6 .457 GERMANY 100 0,1 0,4 0,6 0,8 1 4 6 8 10 The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below. See also section Technical information. Ambient temperature °F Ambient temperature °C Derating factor Ambient temperature °F Ambient temperature °C Derating factor 2 2 times rated current www.e-t-a.de -40 -40 -22 -30 -4 -20 +14 -10 +32 0 +50 +10 0.73 0.78 0.82 0.86 0.91 0.95 +73.4 +23 +104 +40 +122 +50 +140 +60 +158 +70 +185 +85 1 1.09 1.16 1.25 1.33 1.43 2214
1626-3-10A 价格&库存
很抱歉,暂时无法提供与“1626-3-10A”相匹配的价格&库存,您可以联系我们找货
