1160-02-12A
1160-02-12A
    E-T-A
    1160-02-12A
1160-02-12A 数据手册
Thermal Automotive Circuit Breaker 1160-... Description Thermal circuit breaker, with controlled self-resetting mechanism, specially suited to installation in inaccessible locations. Under overload conditions the circuit breaker contacts will open to protect the load circuit. A low current excitation circuit ensures that the contacts remain open thereby avoiding the hazards of automatic reset operation. The circuit breaker is reset by switching off the supply circuit for a short period. Class 2 device, contacts stay open until voltage is removed. Type II to SAE J 553. Typical applications 1 Automotive and marine extra low voltage wiring systems and components, battery powered appliances. Ordering information Technical data Type No. 1160 single pole plug-in type Design standard 02 standard version 12 V Current ratings 12, 15, 20, 30 A 1160 - 02 - 12A ordering example Please be informed that we have minimum ordering quantities to be observed. Standard current ratings and typical voltage drop values Current rating (A) Voltage drop (mV) 12 < 150 15 < 150 20 < 150 30 < 150 1942 1160-... Nähere Erläuterungen siehe: www.e-t-a.de/ti_d Voltage rating DC 12 V Current ratings 12...30 A Typical life 300 operations at 2 x IN Ambient temperature -30...+60 °C (-22...+140 °F) Holding current < 0.6 A Reset time at 23°C after 5 s of load with UN < 35 sec Interrupting capacity (o-o-o) 200 A, L/R = 2.5 ms Degree of protection housing area IP54 (IEC 60529/DIN 40050) terminal area IP00 Vibration 5 g (57-500 Hz) ± 0.38 mm (10-57 Hz), to IEC 60068-2-6, test Fc, 10 frequency cycles/axis Shock 25 g (11 ms) to IEC 60068-2-27, test Ea Corrosion 96 hours at 5 % salt mist, to IEC 60068-2-11, test Ka Humidity 240 hours at 95 % RH to IEC 60068-2-78, test Cab Mass approx. 6 g www.e-t-a.de 1 Thermal Automotive Circuit Breaker 1160-... Dimensions Internal connection diagram 1 2.2 .087 17.5s .689 25.1 .988 23.8 .937 1 7.6 .299 2 9.3 .366 2.5 .098 0.8 .031 5.2 .205 Typical time/current characteristics at +23 °C/+73.4 °F 9.2 .362 9.9 .390 10000 Trip time in seconds 1000 100 10 1 0.1 0.6 0.8 1 6 8 10 2 4 ... times rated current 20 40 The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below. See also section Technical information. Ambient temperature °F °C -4 -20 +14 -10 +32 0 +73.4 +23 +104 +40 +122 +50 +140 +60 Derating factor 0.76 0.84 0.92 1 1.08 1.16 1.24 Accessories Sockets available to special order. This is a metric design and millimeter dimensions take precedence ( mm ) inch All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 2 www.e-t-a.de 1942
1160-02-12A 价格&库存
很抱歉,暂时无法提供与“1160-02-12A”相匹配的价格&库存,您可以联系我们找货
