3131-AF1NT-000000-1T3-20A
    E-T-A
3131-AF1NT-000000-1T3-20A 数据手册
Thermal Circuit Breaker / Switch Series 3131 Description Combination of single pole circuit breaker and ON/OFF switch with soft-touch rocker actuation. Contoured rockers are available with a choice of colours and legends, with optional illumination. The 3131 is sealed to provide IP66 rated front of panel water splash protection. It meets the requirements of circuit breaker standard EN 60934 (IEC 60934): S type, TO. Typical applications Motor protection, transformer protection, household appliances and office equipment, electrical tools, mobile homes, watercraft, construction vehicles, medical equipment. Current ratings and typical internal resistance values Current rating (A) Internal resistance (Ω) Current rating (A) Internal resistance (Ω) 0.1 94 4 0.0435 0.2 24 5 0.0325 0.3 12 6 0.0215 0.4 5.30 7 0.0165 0.5 4.20 8 0.0165 0.8 1.50 10 < 0.02 1 0.9 12 < 0.02 1.2 0.80 14 < 0.02 1.5 0.45 15 < 0.02 2 0.27 16 < 0.02 2.5 0.0785 18 < 0.02 3 0.0595 20 < 0.02 3.5 0.0565 Illumination voltage / power consumption operating voltage 12 V 24 V 115 V 230 V power consumption (LED) Y = yellow T = blue 10 mA 10 mA < 1 mA < 1 mA 10 mA 10 mA - 1 3131 Circuit breaker Technical data For further details please see: http://www.e-t-a.de/ti_e Voltage rating AC 240 V; DC 28 V Current rating range 0.1...20 A Typical life 0.1...20 A 30,000 operations at 1 x IN, inductive Ambient temperature -20...+60 °C (-4...+140 °F) Insulation co-ordination 2.5 kV/2 (IEC 60664) re-inforced insulation in the operating area Dielectric strength operating area test voltage AC 3,000 V current path/current path test voltage AC 1,500 V Insulation resistance > 100 MΩ (DC 500 V) Interrupting capacity Icn 0.1...2 A 10 x IN 2.5...20 A 200 A Interrupting capacity 0.1...16 A: (UL 1077) AC 240 V 3,000 A DC 32 V 2,500 A Protection class operating area IP66 (IEC 60529) terminal area IP00 Vibration 5 g (57-500 Hz) ± 0.38 mm (10-57 Hz) test to IEC 60068-2-6, test Fc, 10 frequency cycles/axis Shock 25 g (11 ms), test to IEC 60068-2-27, test Ea Corrosion 96 hours at 5 % salt mist, test to IEC 60068-2-11,test Ka Humidity 240 hours at 95 % RH, test to IEC 60068-2-78, test Cab Mass approx. 30 g Approvals Authority Standard Rated voltage Current ratings VDE IEC 60934 AC 240 V DC 32 V 0.05 A…20 A 0.05 A…20 A UL UL 1077 C22.2 No 235 UL 1500 Ignition Protected AC 250 V DC 50 V DC 32 V 0.1 A…20 A 2 A…20 A 0.1 A…20 A 1942 www.e-t-a.de 1 Thermal Circuit Breaker / Switch Series 3131 3131 - A F 1 P T - 0 0 00 0 0 - 1 Y 3 - 10 A Position 0 OFF Position I 20.8 .819 3.4 .134 17.5 .689 4 2 3.2 .126 10.4 .409 1 10 .384 GERMANY Terminal X1 is for connection of the rocker illumination 10.4 .409 18 .709 36.5 1.44 3.2 .126 4.8 .189 6.3 .248 20.2 .795 24 .945 51 2.00 Panel cut-out -0.4 -.015 -0.2 -.008 min 1.5 min .059 ±0.05 ±.002 ma ma x. R x. 1.5 .05 9 +0,2 -0,1 +0,2 36.8 1.45 21.1-0,1 .830 Type number 3131 single pole thermal circuit breaker Function A circuit breaker single pole, latching switch C circuit breaker single pole, momentary switch Mounting F flange mounting Accessories 1 with sealing IP66 Terminal design H terminal 1: screws M3.5x5 ISO 1580 (DIN 85) terminal 2: blade terminal for 1x6.3x0.8 mm or 2x2.8x0.8 EN 60934 connectors N terminals 1,2 and 4: blade terminal for 1x6.3x0.8 mm or 2x2.8x0.8 EN 60934 connectors P terminals 1 and 2: blade terminal for 1x6.3x0.8 mm or 2x2.8x0.8 EN 60934 connectors Characteristic curve T thermal 1.0 – 1.4 times rated current Actuator style 0 without actuator rocker X3131-W... must be ordered separately Actuator colour 0 without actuator Rocker legends 00 without Rocker marking 0 without Orientation 0 without Illumination 1 illuminated when in position 1 (ON) 3 as 1, with dimmed illumination of window 1 Type of illumination T blue LED Y yellow LED Illumination voltage range 0 without illumination 2 10 - 14 V DC 3 20 - 32 V DC 7 185 - 275 V AC Current ratings 0.1...20 A panel thickness 2 - 3.5 1 Dimensions 29 1.14 Ordering Information ordering example Please be informed that we have minimum ordering quantities to be observed. Installation drawing Push here during installation operating area GERMANY 4 5 .197 2 1 5 .197 3 .118 3 .118 mounting area This is a metric design and millimeter dimensions take precedence ( mm ) inch 2 www.e-t-a.de 1942 Thermal Circuit Breaker / Switch Series 3131 Internal connection diagrams Typical time/current characteristics circuit breaker 0.1 … 2 A 1-pole switch line 1 +60 °C +140 °F 10000 1-pole momentary switch +23 °C +73.4 °F line 1 -20 °C -4 °F 2 load X2 2 load X2 Trip time in seconds 1000 switch 100 1 10 1 1-pole switch 1-pole momentary switch line 1 line 1 0.1 1 2 4 6 8 10 … times rated current 20 40 2.5 … 20 A +60 °C +140 °F 10000 X2 4 load +23 °C +73.4 °F X2 -20 °C -4 °F 1000 Trip time in seconds 4 load 100 10 1 0.1 1 2 4 6 8 10 … times rated current 20 40 The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below. See also section Technical information. 1942 Ambient temperature °F °C -4 -20 +14 -10 +32 0 +73.4 +23 +104 +40 +122 +50 +140 +60 Derating factor 0.84 0.88 0.92 1 1.08 1.14 1.23 www.e-t-a.de 3 Thermal Circuit Breaker / Switch Series 3131 List of available legends Ordering information 1 Ordering information Interior light 01 Navigation light (sailing ship) 27 Anchor light 02 Cockpit light (sailing ship) 28 Cockpit light 03 Deck light (sailing ship) 29 Navigation light 04 Anchor light (sailing ship) 30 UKW-radio 05 Toilet 31 Refrigerator 06 Anchor 07 Windshield wiper 08 41 Outlet Further symbols upon request orientation: 1 Bilge pump 09 Potable water 10 Horn 11 Ventilation fan 12 Panel light 13 Navigation instruments 14 Music 15 Heating 16 Shower pump 17 Icebox 19 Screenwash 20 Search light 23 Autopilot 24 Trim tabs 25 Mast lift 26 symbol 03 O O orientation: 4 O orientation: 2 orientation: 3 Ordering Information X3131-... Type number X3131 module for type 3131 Actuator style W rocker soft-touch, two illumination windows Actuator colour A blue / white translucent B black / white translucent C skyblue / white translucent Rocker legends 00 without ... see separate survey of legends Rocker marking 0 without A I and 0 Orientation 0 without orientation 1 orientation 1 (standard) 2 orientation 2 3 orientation 3 4 orientation 4 X3131 - W A 01 0 1 4 O www.e-t-a.de ordering example 1942 Thermal Circuit Breaker / Switch Series 3131 Accessories Mounting frame Consisting of a left- and right-side piece, can be expanded by a centre piece. (Please order 2 side pieces per mounting frame) The pieces firmly engage when stuck together. side piece Y 308 790 01 centre piece Y 308 791 01 51.3+0.2 26.5 48.2+0.2 1 panel cut-out for 2 side pieces plus 26.2 mm per centre piece max. R0.3 panel thickness 3.2 to 9.5 mm 68 36.8 21.1 35 side piece centre piece side piece This is a metric design and millimeter dimensions take precedence ( mm ) inch All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 1942 www.e-t-a.de 5 Thermal Circuit Breaker / Switch Series 3131 Accessories – Plug-in connector Plug-in connector Y31192901 Connecting cables can be pre-wired. Two retaining clips ensure a tight fit. 1 18,4 24 22 32,6 8,6 4 35,5 44,8 ± 1 20 Benefits: • Reduced installation time for final assembly • Quick replacement of devices Note: Delivery without receptacles. Dimensions of receptacles (width 6.3 mm) are in accordance with DIN 46340 part 3, shape A. Examples of suitable receptacles: Stocko RSB 7916 F6,3-1 / Klaucke type 2730 / Vogt type 3832d.67 / TE FASTON Terminals 250 Series / Delphi Packard 58 Series 24 8,6 29 Plug-in connector mounted on circuit breaker: 35,5 6 20 www.e-t-a.de 1942
物料型号:3131系列热过载继电器/开关
器件简介:3131系列是单极断路器和ON/OFF开关的组合,具有软触摸摇杆操作。摇杆有多种颜色和标识可选,并可选配照明。3131系列密封以提供IP66等级的面板前水花防护。它符合断路器标准EN 60934 (IEC 60934): S型,TO。
引脚分配:文档中未明确列出引脚分配,但提供了接线端子的设计信息,包括螺丝端子和刀片端子。
参数特性: - 额定电流范围:0.1...20A - 典型寿命:在1倍额定电流下,0.1...20A的继电器可进行30,000次操作 - 环境温度:-20...+60 °C(-4...+140F) - 绝缘协调:操作区域2.5kV/2次加强绝缘 - 断开容量:0.1...2A和2.5...20A的继电器分别为10xIN 200A - 保护等级:操作区域IP66,端子区域IP00
功能详解: - 提供电机保护、变压器保护、家用电器和办公设备、电动工具、移动房屋、船只、建筑车辆、医疗设备的保护。 - 具有热特性曲线,1.0 – 1.4倍额定电流。 - 可选配不同颜色和标记的摇杆,以及照明功能。
应用信息:适用于多种应用场景,如电机、变压器、家用电器、电动工具等的保护。
封装信息:文档提供了详细的安装图纸和尺寸信息,包括面板开孔尺寸和安装区域尺寸。
3131-AF1NT-000000-1T3-20A 价格&库存
很抱歉,暂时无法提供与“3131-AF1NT-000000-1T3-20A”相匹配的价格&库存,您可以联系我们找货
