3131-AF1PT-000000-1Y3-10A 数据手册
Thermal Circuit Breaker / Switch Series 3131
Description
Combination of single pole circuit breaker and ON/OFF switch with
soft-touch rocker actuation. Contoured rockers are available with a
choice of colours and legends, with optional illumination. The 3131 is
sealed to provide IP66 rated front of panel water splash protection.
It meets the requirements of circuit breaker standard EN 60934 (IEC
60934): S type, TO.
Typical applications
Motor protection, transformer protection, household appliances and office
equipment, electrical tools, mobile homes, watercraft, construction
vehicles, medical equipment.
Current ratings and typical internal resistance values
Current
rating (A)
Internal
resistance (Ω)
Current
rating (A)
Internal
resistance (Ω)
0.1
94
4
0.0435
0.2
24
5
0.0325
0.3
12
6
0.0215
0.4
5.30
7
0.0165
0.5
4.20
8
0.0165
0.8
1.50
10
< 0.02
1
0.9
12
< 0.02
1.2
0.80
14
< 0.02
1.5
0.45
15
< 0.02
2
0.27
16
< 0.02
2.5
0.0785
18
< 0.02
3
0.0595
< 0.02
3.5
0.0565
Illumination voltage / power consumption
operating voltage
12 V
24 V
115 V
230 V
power consumption (LED)
Y = yellow
T = blue
10 mA
10 mA
< 1 mA
< 1 mA
10 mA
10 mA
1
3131
Circuit breaker
Technical data
For further details please see: http://www.e-t-a.de/ti_e
Voltage rating
AC 240 V; DC 28 V
Current rating range
0.1...20 A
Typical life
0.1...20 A
30,000 operations at 1 x IN, inductive
Ambient temperature
-20...+60 °C (-4...+140 °F)
Insulation co-ordination 2.5 kV/2
(IEC 60664)
re-inforced insulation in the operating area
Dielectric strength
operating area
test voltage AC 3,000 V
current path/current path test voltage AC 1,500 V
Insulation resistance
> 100 MΩ (DC 500 V)
Interrupting capacity Icn 0.1...2 A
10 x IN
2.5...20 A 200 A
0.1...16 A:
(UL 1077)
AC 240 V 3,000 A
DC 32 V
2,500 A
Protection class
operating area IP66
(IEC 60529)
terminal area IP00
Vibration
5 g (57-500 Hz) ± 0.38 mm (10-57 Hz)
test to IEC 60068-2-6, test Fc,
10 frequency cycles/axis
Shock
25 g (11 ms),
test to IEC 60068-2-27, test Ea
Corrosion
96 hours at 5 % salt mist,
test to IEC 60068-2-11,test Ka
Humidity
240 hours at 95 % RH,
test to IEC 60068-2-78, test Cab
Mass
approx. 30 g
Approvals
Authority
Standard
Rated
voltage
Current ratings
VDE
IEC 60934
AC 240 V
DC 32 V
0.05 A…20 A
0.05 A…20 A
UL
UL 1077
C22.2 No 235
UL 1500
Ignition Protected
AC 250 V
DC 50 V
DC 32 V
0.1 A…20 A
2 A…20 A
0.1 A…20 A
1942
www.e-t-a.de
1
3131 - A F 1 P T - 0 0 00 0 0 - 1 Y 3 - 10 A
Position 0
OFF
Position I
20.8
.819
3.4
.134
17.5
.689
4
2
3.2
.126
10.4
.409
1
10
.384
GERMANY
Terminal X1 is
for connection
of the rocker
illumination
10.4
.409
18
.709
36.5
1.44
3.2
.126
4.8
.189
6.3
.248
20.2
.795
24
.945
51
2.00
Panel cut-out
-0.4
-.015
-0.2
-.008
min 1.5
min .059
±0.05
±.002
ma
ma x. R
x. 1.5
.05
9
+0,2
-0,1
+0,2
36.8
1.45
21.1-0,1
.830
Type number
3131 single pole thermal circuit breaker
Function
A
circuit breaker single pole, latching switch
C circuit breaker single pole, momentary switch
Mounting
F flange mounting
Accessories
1 with sealing IP66
Terminal design
H terminal 1: screws M3.5x5 ISO 1580 (DIN 85)
terminal 2: blade terminal for 1x6.3x0.8 mm or 2x2.8x0.8
EN 60934 connectors
N terminals 1,2 and 4: blade terminal for 1x6.3x0.8 mm or
2x2.8x0.8 EN 60934 connectors
P terminals 1 and 2: blade terminal for 1x6.3x0.8 mm or
Characteristic curve
T thermal 1.0 – 1.4 times rated current
Actuator style
0 without actuator
rocker X3131-W... must be ordered separately
Actuator colour
0 without actuator
Rocker legends
00 without
Rocker marking
0 without
Orientation
0 without
Illumination
1 illuminated when in position 1 (ON)
3 as 1, with dimmed illumination of
window 1
Type of illumination
T blue LED
Y yellow LED
Illumination voltage range
0 without illumination
2 10 - 14 V DC
3 20 - 32 V DC
7 185 - 275 V AC
Current ratings
0.1...20 A
panel thickness 2 - 3.5
1
Dimensions
29
1.14
Ordering Information
ordering example
Please be informed that we have minimum ordering quantities to be
observed.
Installation drawing
Push here during installation
operating area
GERMANY
4
5
.197
2
1
5
.197
3
.118
3
.118
mounting area
This is a metric design and millimeter dimensions take precedence ( mm )
inch
2
www.e-t-a.de
1942
Internal connection diagrams
Typical time/current characteristics
circuit breaker
0.1 … 2 A
1-pole switch
line
1
+60 °C
+140 °F
10000
1-pole momentary switch
+23 °C
+73.4 °F
line 1
-20 °C
-4 °F
2
load
X2
2
load
X2
Trip time in seconds
1000
switch
100
1
10
1
1-pole switch
line 1
line 1
0.1
1
2
4
6 8 10
… times rated current
2.5 … 20 A
+60 °C
+140 °F
10000
X2
4
load
+23 °C
+73.4 °F
X2
-20 °C
-4 °F
1000
4
load
100
10
1
0.1
1
2
4
6 8 10
The time/current characteristic curve depends on the ambient temperature
prevailing. In order to eliminate nuisance tripping, please multiply the circuit
breaker current ratings by the derating factor shown below. See also section
Technical information.
1942
Ambient temperature °F
°C
-4
-20
+14
-10
+32
+23
+104
+40
+122
+50
+140
+60
Derating factor
0.84
0.88
0.92
1
1.08
1.14
1.23
www.e-t-a.de
3
List of available legends
Ordering information
1
Interior light
01
Navigation light
(sailing ship)
27
Anchor light
02
Cockpit light
(sailing ship)
28
Cockpit light
03
Deck light
(sailing ship)
29
Navigation light
04
Anchor light
(sailing ship)
30
UKW-radio
05
Toilet
31
Refrigerator
06
Anchor
07
Windshield wiper
08
41
Outlet
Further symbols upon request
orientation: 1
Bilge pump
09
Potable water
10
Horn
11
Ventilation fan
12
Panel light
13
Navigation instruments
14
Music
15
Heating
16
Shower pump
17
Icebox
19
Screenwash
Search light
23
Autopilot
24
Trim tabs
25
Mast lift
26
symbol 03
O
O
orientation: 4
O
orientation: 2
orientation: 3
Ordering Information X3131-...
Type number
X3131 module for type 3131
Actuator style
W rocker soft-touch,
two illumination windows
Actuator colour
A blue / white translucent
B black / white translucent
C skyblue / white translucent
Rocker legends
00
without
... see separate survey of legends
Rocker marking
without
A I and 0
Orientation
0 without orientation
1 orientation 1 (standard)
2 orientation 2
3 orientation 3
4 orientation 4
X3131 - W A 01 0 1
4
O
www.e-t-a.de
ordering example
1942
Accessories
Mounting frame
Consisting of a left- and right-side piece, can be expanded by a centre piece.
(Please order 2 side pieces per mounting frame)
The pieces firmly engage when stuck together.
side piece Y 308 790 01
centre piece Y 308 791 01
51.3+0.2
26.5
48.2+0.2
1
panel cut-out for 2 side pieces
plus 26.2 mm per centre piece
max. R0.3
panel thickness 3.2 to 9.5 mm
68
36.8
21.1
35
side piece
centre piece
side piece
inch
All dimensions without tolerances are for reference only. In the interest of improved design,
performance and cost effectiveness the right to make changes in these specifications
without notice is reserved.Product markings may not be exactly as the ordering codes.
Errors and omissions excepted.
1942
www.e-t-a.de
5
Accessories – Plug-in connector
Plug-in connector
Y31192901
Connecting cables can be pre-wired. Two retaining clips ensure a tight fit.
1
18,4
24
22
32,6
8,6
4
35,5
44,8 ± 1
Benefits:
• Reduced installation time for final assembly
• Quick replacement of devices
Note:
Delivery without receptacles.
Dimensions of receptacles (width 6.3 mm) are in accordance with DIN 46340 part 3, shape A.
Examples of suitable receptacles: Stocko RSB 7916 F6,3-1 / Klaucke type 2730 / Vogt type 3832d.67 /
TE FASTON Terminals 250 Series / Delphi Packard 58 Series
24
8,6
29
Plug-in connector mounted on circuit breaker:
35,5
6
www.e-t-a.de
1942
3131-AF1PT-000000-1Y3-10A 价格&库存
很抱歉,暂时无法提供与“3131-AF1PT-000000-1Y3-10A”相匹配的价格&库存,您可以联系我们找货
