AB2-B0-26-620-6D1-C
AB2-B0-26-620-6D1-C
    CARLING
    AB2-B0-26-620-6D1-C
AB2-B0-26-620-6D1-C 数据手册
A-Series Hydraulic-Magnetic Circuit Breaker P ROD UC T W E BP A GE request sample, configure part Compact and Versatile Design The A-Series hydraulic-magnetic circuit breakers offer precise operation in a compact size for both general purpose as well as full amp load applications. Visi Rocker® and recessed paddle actuators are ideally suited for clean, front panel designs while the metal toggle configuration is ideal for harsh environments. The A-Series is available as a one to six pole configuration, rated up to 50 amps, 277VAC/80VDC and has a max IC of 7,500 amps. 1-6 50 Poles Typical Applications ∙ Marine ∙ Telecom ∙ Renewable Energy ∙ Generators www.carlingtech.com 860.793.9281 ∙ Welders ∙ Military Amps Max 277 VAC Max ∙ Industrial Automation ∙ Commercial Food sales@carlingtech.com 80 VDC Max 7500A Max IC ∙ Medical Equipment Tech Specs Mechanical Electrical Maximum Voltage 277VAC 50/60 Hz, 80VDC Current Ratings Standard current coils: 0.100, 0.250, 0.500, 0.750, 1.00, 2.50, 5.00, 7.50, 10.0, 15.0, 20.0, 25.0, 30.0, 35.0, 40.0, 50.0. Other ratings available - consult ordering scheme. Standard Voltage Coils DC-6V, 12V; AC-120V, Other ratings available, consult ordering scheme. Auxiliary Switch Rating SPDT; 10.1 A - 250VAC, 1.0 A-65VDC/0.5 A - 80 VDC, 0.1A - 125VAC (with gold contacts) Insulation Resistance Minimum: 100 Megohms at 500 VDC Dielectric Strength UL, CSA - 1500V 60 Hz for one minute between all electrically isolated terminals. A-Series rocker circuit breakers comply with the 8mm spacing & 3750V dielectric requirements from hazardous voltage to operator accessible surfaces per EN 60950 and VDE 0805. Resistance, Impedance Values from Line to Load Terminal based on Series Trip Circuit Breaker. Endurance 10,000 ON-OFF operations @ 6 per minute; with rated Current & Voltage. Trip Free All A-Series Circuit Breakers will trip on overload, even when the actuator is forcibly held in the ON position. Trip Indication The operating actuator moves positively to the OFF position when an overload causes the circuit breaker to trip. When mid-trip handle is specified, the handle moves to the mid position on electrical trip of the circuit breaker. When mid-trip handle with alarm switch is specified, the handle moves to the mid position & the alarm switch actuates when the circuit breaker is electrically tripped Physical Number of Poles 1 - 6 Poles (handle) and 1-3 poles (rocker) at 30 Amps or less.1 and 2 poles at 31 Amps thru 50 Amps. Internal Circuit Config. Series, (with or without auxiliary switch), Shunt and Relay with current or voltage trip coils, Dual Coil, Switch Only with or without auxiliary switch. Weight Approximately 65 grams/pole. (Approximately 2.32 ounces/pole) Standard Colors Housing - Black; Actuator- See Ordering Scheme. RESISTANCE PER POLEVALUES VALUES RESISTANCE, IMPEDANCE from Line Load Terminals from Line to to Load Terminals (Values Based Series Trip Circuit Breaker) (Values Based onon Series Trip Circuit Breaker) 1000 100 10 O H M CURRENT TOLERANCE (AMPS) (%) 0.10 - 5.0 5.1 - 20.0 15 25 20.1 - 50.0 35 Environmental 1 S Designed and tested in accordance with requirements of specification MIL-PRF-55629 & MIL-STD-202 as follows: 0.1 60 Hz 1/2 Cycle Inrush Pulse Tolerance 0.001 0.01 10 1 0.1 100 Time Delay Curves 42, 44 & 46 (50 Amps Max.) Multiple of Rated Current 0.01 Shock Withstands 100 Gs, 6ms, sawtooth while carrying rated current per Method 213, Test Condition “I”. Instantaneous and ultra-short curves tested @ 90% of rated current. Vibration Withstands 0.060” excursion from 10-55 Hz, and 10 Gs 55-500 Hz, at rated current per Method 204C, Test Condition A. Instantaneous and ultrashort curves tested at 90% of rated current. Moisture Resistance Method 106D; ten 24-hour cycles @ + 25°C to +65°C, 80-98% RH.56 days @ +85°C, 85% RH. Salt Spray Method 101, Condition A (90-95% RH @ 5% NaCl Solution, 96 hrs). Thermal Shock Method 107D, Condition A (Five cycles @ -55°C to +25°C to +85°C to +25°C). Operating Temperature -40° C to +85° C Time Delay Curves 22, 24 & 26 (50 Amps Max.) AMPERE RATING Pulse Tolerance Curves CURRENT (AMPS) TOLERANCE (%) Time in Milliseconds 0.100-5.0 60 Hz 1/2 Cycle15% Inrush Pulse Tolerance 5.1-20.0 25% 20.1-50.0 35% 50 Hz 1/2 Cycle Inrush Pulse Tolerance Multiple of Rated Current Multiple of Rated Current Time Delay Curves 42, 44 & 46 FIGURE 1 (50 Amps Max.) Time Delay Curves 42, 44 & 46 (50 Amps Max.) 22x Time Delay Curves 22, 24 & 26 (50 Amps Max.) Time Delay Curves 22, 24 & 26 (50 Amps Max.) 10x 5.0 Time in Milliseconds 10.0 20.0 Time in Milliseconds 50 Hz 1/2 Cycle Multiple of Rated Current Inrush Pulse Tolerance Time Delay Curves 42, 44 & 46 (50 Amps Max.) 22x Time Delay Curves 22, 24 & 26 (50 Amps Max.) 10x 02. 5.0 10.0 20.0 *Manufacturer reserves the right to change product specification without prior notice. Time in Milliseconds Tech Specs Electrical Tables Table A: Lists UL Recognized & CSA Accepted configurations and performance capabilities as a Component Supplementary Protector. Component Supplementary Protectors Voltage Circuit Configuration Series Max Rating Current Rating Frequency Phase 03. CSA DC --- 0.02 - 15 --- --- 5000 TC1, OL1, U2 TC1, OL1, U2 --- 31 - 50 --- --- 7500 TC1, 2, OL1, U1 TC1, 2, OL1, U1 80 DC --- 0.02 - 30 --- --- 7500 TC1, 2, OL1, U1 TC1, 2, OL1, U1 --- 31 - 50 --- 7500 TC1, 2, OL0, U1 TC1, 2, OL0, U1 125 50 / 60 1 0.02 - 30 --- --- 3000 TC1, OL1, U2 TC1, OL1, U2 125 50 / 60 1 14 1 - 50 --- --- 2000 TC1, OL1, U2 TC1, OL1, U2 125 50 / 60 125 / 250 50 / 60 125 / 250 50 / 60 50 / 60 1 - 50 --- --- 1000 TC1, OL1, U2 TC3, OL1, U3 --- --- 3000 TC1, 2, OL1, U2 TC1, 2, OL1, U2 Rocker 0.02 - 50 --- --- 3000 TC1, 2, OL1, U2 TC1, 2, OL1, U2 Handle 0.02 - 30 --- --- 1500 TC1, 2, OL0, U2 TC1, 2, OL0, U2 1 0.02 - 30 --- --- 3000 --- 3000 --- 1000 TC1, OL1, U2 TC3, OL1, U3 --- TC1, 2, OL1, C1 TC1, 2, OL1, C1 --- TC1, 2, OL1, C1 TC1, 2, OL1, C1 --- TC1, 2, OL1, C1 TC1, 2, OL1, C1 14 --1 - 50 --- 0.02 - 30 --- 5000 2 2000 1 TC1, OL1, U2 TC1, OL1, U2 31 - 50 --- 1 0.02 - 30 --- 5000 1 32 DC --- 0.02 - 50 --- --- 5000 TC1, OL1, U2 TC1, OL1, U2 65 DC --- 0.02 - 50 --- --- 7500 TC1, 2, OL1, U1 TC1, 2, OL1, U1 80 DC --- 0.02 - 30 --- --- 7500 TC1, 2, OL1, U1 TC1, 2, OL1, U1 --- 31 - 50 --- 7500 TC1, 2, OL0, U1 TC1, 2, OL0, U1 125 50 / 60 1 0.02 - 30 --- --- 3000 TC1, OL1, U2 TC1, OL1, U2 14 13 1 - 50 --- --- 2000 TC1, OL1, U2 TC1, OL1, U2 50 / 60 50 / 60 125 / 250 50 / 60 50 / 60 --- --- 1000 TC1, OL1, U2 TC3, OL1, U3 13 --- --- 3000 TC1, 2, OL1, U1 TC1, 2, OL1, U1 0.02 - 50 --- --- 3000 TC1, 2, OL1, U2 TC1, 2, OL1, U2 1 0.02 - 30 --- --- 1500 TC1, OL0, U2 TC1, OL0, U2 Single Pole 1 0.02 - 30 --- --- 3000 TC1, OL1, U2 TC1, OL1, U2 Two Pole 1 14 --- 31 - 50 --- 3000 --- 1000 TC1, OL1, U2 TC3, OL1, U3 --- TC1, 2, OL1, C1 TC1, 2, OL1, C1 --- TC1, 2, OL1, C1 TC1, 2, OL1, C1 --- TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 1 - 50 --- 0.02 - 30 --- 5000 2 2000 1 TC1, 2, OL0, U1 TC1, 2, OL0, U1 31 - 50 --- 1 0.02 - 30 --- 5000 1 80 DC --- 0.02 - 30 --- --- 7500 TC1, 2, OL1, U1 125 / 250 50 / 60 1 0.02 - 30 --- --- 3000 TC1, 2, OL1, U1 TC1, 2, OL1, U1 1 0.02 - 30 --- --- 3000 TC1, 2, OL1, U1 TC1, 2, OL1, U1 --- TC1, 2, OL1, C1 TC1, 2, OL1, C1 --- TC1, 2, OL1, C1 TC1, 2, OL1, C1 250 50 / 60 3 0.02 - 30 --- 277 50 / 60 1 0.02 - 30 --- 5000 2 5000 1 80 DC 0.02 - 30 --- --- 7500 TC1, 2, OL1, U1 TC1, 2, OL1, U1 125 / 250 50 / 60 --13 0.02 - 30 --- --- 3000 TC1, 2, OL1, U1 TC1, 2, OL1, U1 250 50 / 60 1 0.02 - 30 --- --- 3000 TC1, 2, OL1, U1 TC1, 2, OL1, U1 3 0.02 - 30 --- --- TC1, 2, OL1, C1 TC1, 2, OL1, C1 277 50 / 60 1 0.02 - 30 --- --- TC1, 2, OL1, C1 TC1, 2, OL1, C1 65 DC --- 0.02 - 50 --- 80 DC --- 0.02 - 30 --- 1 --- 31 - 50 3 0.02 - 50 --- 1 0.02 - 30 31 - 50 277 50 / 60 Rocker 0.02 - 30 50 / 60 50 / 60 Two Pole 0.02 - 30 277 250 Single Pole TC1, 2, OL0, U1 TC1, 2, OL0, U1 50 / 60 125 Rocker 0.02 - 30 277 125 / 250 Notes 13 13 3 Switch Only UL DC 250 Relay With Without Backup Fuse Backup Fuse Application Codes 32 3 Shunt UL / CSA 65 250 Dual Coil Full Load Amps General Purpose Amps Short Circuit Capacity (Amps) 5000 2 5000 1 not applicable Notes: 1 Requires branch circuit backup with a UL LISTED Type K5 or RK5 fuse (15A minimum) at no more than 4 times the rating of the protector. 2 Same as note 1, except that backup fuse is limited to 80 A maximum. 3 2 pole protector required (with one pole per power line) for: 125/250 VAC, 1 pole protector required for : 125 VAC, 1Ø Power System. 4 Satisfies the requirements of clause 11.2.8.2.5 of CSA STD C22.2 No 100 for the use of supplementary protectors with portable generators. Rocker Tech Specs Electrical Tables Table B: Lists UL Recognized, CSA Accepted, VDE & TUV Certified configurations & performance capabilities as a Component Supplementary Protector. Component Supplementary Protectors Voltage Circuit Configuration Current Rating Max Rating Frequency Phase 65 DC --- General Full Load With Purpose Amps Amps Backup Fuse 0.10 - 50 0.10 - 30 31 - 50 80 DC --- 0.10 - 30 31 - 32 Series 1 31 - 50 50 / 60 1 1 4 3 80 DC --1 250 50 / 60 3 80 DC --1 Shunt 250 50 / 60 3 --- --- 7500 --- 31 - 50 31 - 50 0.10 - 30 --- 31 - 50 31 - 50 --- 3000 0.10 - 30 1 - 50 --- 1000 0.10 - 30 5000 3 31 - 50 2000 2 0.10 - 30 0.10 - 30 30 - 50 0.10 - 30 31 - 50 --- 0.10 - 30 --- 30 - 50 31 - 50 0.10 - 30 31 - 50 --- --7500 --- 31 - 50 --- VDE Without (Inc) with Backup Backup Fuse Fuse --- 31 - 32 250 Dual Coil Short Circuit Capacity (Amps) UL / CSA 5000 3 2000 2 3000 --7500 --3000 5000 3 2000 2 --- 3000 (Icn) without Backup Fuse --- 1500 3000 1500 --- --- 6000 1500 --- --- 3000 Application Codes TUV 1500 3000 1500 --- --- 3000 1500 --- --- 3000 1500 --- --- 3000 1500 --- --- (Inc) (Icn) with without Backup Backup Fuse Fuse 5000 3000 3000 1500 5000 UL CSA TC1, 2, OL1, U1 TC1, 2, OL1, U1 3000 5000 1500 3000 3000 5000 3000 1500 TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL0, U1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 Rocker: 1-3 Poles Handle: 1 Pole TC1, 2, OL1, U1 TC1, 2, OL1, U1 Rocker: 2 Pole TC1, 2, OL0, U1 TC1, 2, OL0, U1 Rocker: 1 Pole TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL0, U1 TC1, 2, OL0, U1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, OL1, U2 TC1, OL1, U2 Rocker: 1-3 Poles Rocker: 2 Pole TC3, OL1, U3 TC1, 2, OL1, C1 TC1, 2, OL1, C1 Rocker: 1-3 Poles TC1, 2, OL1, C1 TC1, 2, OL1, C1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL0, U1 TC1, 2, OL0, U1 Rocker: 1-3 Poles TC1, 2, OL1, C1 TC1, 2, OL1, C1 TC1, 2, OL1, C1 TC1, 2, OL1, C1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL1, U1 Handle: 1 Pole TC1, 2, OL1, U1 TC1, 2, OL1, U1 TC1, 2, OL0, U1 TC1, 2, OL0, U1 Rocker: 1-3 Poles TC1, 2, OL1, C1 TC1, 2, OL1, C1 TC1, 2, OL1, C1 TC1, 2, OL1, C1 Notes: 1 General Purpose Ratings for UL/CSA Only. 2 Requires branch circuit backup with a UL LISTED Type K5 or RK5 fuse (15A minimum) at no more than 4 times the rating of the protector. 3 Same as note 2, except that backup fuse is limited to 80 A maximum. 4 Satisfies the requirements of clause 11.2.8.2.5 of CSA STD C22.2 No 100 for the use of supplementary protectors with portable generators. 04. World Market Breaker TUV only TC1, 2, OL0, U1 TC1, OL1, U2 3000 Notes Tech Specs Electrical Tables Table C: Lists UL Recognized, CSA Accepted configurations and performance capabilities as Protectors, Supplementary for Marine Electrical and Fuel Systems (Guide PEQZ2, File E75596). Ignition Protected per UL 1500. UL Classified Small Craft Electrical Devices, Marine in accordance with ISO 8846 (Guide UZMK, File MQ1515) as Marine Supplementary Protectors. UL1500 (Marine Ignition Protection) Circuit Configuration Max Rating 14 Current Rating Frequency Phase Full Load Without Amps Backup Fuse DC 5000 --- 65 0.02 - 50 125 1 125 / 250 50 / 60 3000 12 250 1 2 3 (Amps) 1 32 1 Series Short Circuit Capacity Voltage 1 0.02 - 30 1500 Application Codes UL CSA TC1, OL1, U1 TC1, OL1, U1 TC1, OL1, U2 TC1, OL1, U2 TC1, OL1, U1 TC1, OL1, U1 TC1, OL1, U2 TC1, OL1, U2 TC1, OL1, U2 TC1, OL1, U2 TC1, OL1, U1 TC1, OL1, U1 Notes: Available with special catalog number only (consult factory). 2 pole protector required (with one per power line) for 125 / 250 VAC. 1 pole protector required for 125 VAC 1 phase power system Table D: Lists UL Listed configurations and performance capabilities as Circuit Breakers for use in Communications Equipment UL489A (Communications Equipment) Circuit Configuration Series Voltage Max Rating Frequency 80 DC Current Rating Interrupting Capacity (Amps) General Purpose Amps without Backup Fuse 0.10 - 50 60 - 90 1 5000 Notes: 1 Parallel Pole Construction Time Delay Specs To view all hydraulic-magnetic circuit breaker time delay values, please visit www.carlingtech.com/sites/default/files/documents/Carling-HM-CB-Time-Delays.pdf Agency Approvals 05. UL 1077 Component Recognition Program as Protectors Supplementary (Guide CCN/QVNU2, File E75596) UL 508 Switches, Industrial Control (Guide CCN/NRNT2, File E148683) UL 1500 Protectors, Supplementary for Marine Electrical & Fuel Systems (Guide PEQZ2, File E75596) Ignition Protection UL 489A Communications Equipment (Guide CCN/DITT, File E189195) CSA Certified Component Supplementary Protector under Class 3215 30, File 047848 0 000 CSA Standard C22.2 No. 235 TUV Certified EN60934, under License No. R72103448 VDE Certified EN60934, VDE 0642 under File No. 10537 Ordering Scheme Sample Part Number A A 3 - B 0 - 10 -450 - 1 B 1 - C 1 Selection 2 3 4 5 1. SERIES A B S T 1 2 One Two 1 3 Three 4 Four 5 Five 6 Six 4. CIRCUIT A 2 Switch Only (No Coil) F 3 B Series Trip (Current) G 3 C Series Trip (Voltage) H 3,4 D 3 Shunt Trip (Current) E 3 Shunt Trip (Voltage) K 3,4 5. AUXILIARY / ALARM SWITCH 0 1 2 5 Relay Trip (Current) Relay Trip (Voltage) Dual Coil with Shunt Trip Voltage Coil Dual Coil with Relay Trip Voltage Coil 5 without Aux Switch 7 S.P.D.T., 0.093 Q.C. Term. S.P.D.T., 0.110 Q.C. Term. 8 S.P.S.T., 0.093 Q.C. Term. 9 (Gold Contacts) S.P.S.T., 0.110 Q.C. Term. (Gold Contacts) S.P.S.T., 0.187 Q.C. Term. S.P.D.T., 0.187 Q.C. Term. 6. FREQUENCY & DELAY 03 10 11 12 14 16 20 21 22 24 26 30 06. 7 8 9 10 CODE AMPERES Handle, one per pole Handle, one per multipole unit Mid-Trip Handle, one per pole Mid-Trip Handle, one per pole & Alarm Switch 3. POLES 6 11 7. CURRENT RATING (AMPERES) A 2. ACTUATOR Handle - UL 1077 Recognized DC 50/60Hz, Switch Only DC Instantaneous DC Ultra Short DC Short DC Medium DC Long 50/60Hz Instantaneous 50/60Hz Ultra Short 50/60Hz Short 50/60Hz Medium 50/60Hz Long DC, 50/60Hz Instantaneous 31 DC, 50/60Hz Ultra Short 32 DC, 50/60Hz Short 34 DC, 50/60Hz Medium 36 DC, 50/60Hz Long 7 42 50/60Hz Short, High-inrush 7 44 50/60Hz Medium, High-inrush 46 7 50/60Hz Long, High-inrush 52 7 DC, Short, High-inrush 54 7 DC, Medium, High-inrush 56 7 DC, Long, High-inrush Notes: 1 Actuator Code: A: Handle tie pin spacer(s) and retainers provided un-assembled with multi-pole units. B: Handle location as viewed from front of breaker: 2 pole - left pole 3 pole - center pole 4 pole - two handles at center poles 5 pole - three handles at center poles 6 pole - four handles at center poles S: Handle moves to mid-position only upon electrical trip of the breaker. Available with circuit codes B, C, D, E, F, G, H and K. T: Handle moves to mid-position and alarm switch activates only upon electrical trip of the breaker. Available with circuit codes B & C. 2 Switch Only circuits, rated up to 50 amps and 6 poles, and only available when tied to a protected pole (Circuit Code B, C, D or H.), For .02 to 30 amps, select Cur rent Code 630. For 35 - 50 amps, select Current Code 650. 3 Available with terminal Codes 1, 2 and 3. Current Rating limited to 50A amps maximum. 4 Consult factory for available Dual Coil options, as special catalog number is required. With Shunt construction, Dual Coils will trip instantaneously on line volt age. Dual coils require 30VA minimum power to trip and are rated for intermittent duty only. 5 Auxiliary Switch breakers with Series Trip & Switch Only circuits: ≤ 30A - supplied with standard half shells. 35-50A - supplied with extended boat (B-Style) half shells. On multi-pole breakers, one auxiliary switch is supplied, mounted in the extreme right pole. 6 Separate pole type voltage coils not rated for continuous duty. Available only with delay codes 10 and 20. 7 Available with Circuit Codes B & D only. VDE Certified to 30 amps. UL Recognized, CSA Accepted & TUV Certified to 50 amps. 8 VDE Certification available with single pole breakers with DC Delay only. UL Recog nition and CSA Accepted available in one and two pole breakers. 9 Screw Terminals are recommended on ratings greater than 20 amps. Ratings over 30 amps are only available with Terminal Codes 5, 9, G, H, M and Q. 10 Terminal Code 1: VDE Certification up to 25 amps and UL Recognition and CSA Certification up to 30 amps, but not recommended over 20 amps. 11 Terminal Codes 3, 5, E and H (Bus Type) with VDE, are supplied with Lock Washers, and Terminal Code M (M6 Threaded Stud) with VDE is supplied with Lock and Flat Washers. These breakers are only VDE Certified when the washers are used. 12 Terminal Code L: VDE Certified available up to 12A. UL Recognized & CSA Accepted available up to 30A. 13 Single pole breakers with Terminal Code P (Printed Circuit Board) are available up to 30 amps with VDE Certification and 50 amps with UL Recognition and CSA Accepted, with Circuit Codes A, B and C. Two pole breakers with Terminal Code P (Printed Circuit Board) are available up to 40 amps with UL Recognition and CSA Accepted with Circuit Codes A, B and C. 14 Terminal Code Q not available with VDE certification. 15 Single pole only. 020 0.020 225 0.250 420 2.000 025 0.025 230 0.300 522 2.250 030 0.030 235 0.350 527 2.750 035 0.035 240 0.400 430 3.000 040 0.040 245 0.450 435 3.500 045 0.045 250 0.500 440 4.000 050 0.050 255 0.550 445 4.500 055 0.055 260 0.600 450 5.000 060 0.060 265 0.650 455 5.500 065 0.065 270 0.700 460 6.000 070 0.070 275 0.750 465 6.500 075 0.075 280 0.800 470 7.000 080 0.080 285 0.850 475 7.500 085 0.085 290 0.900 480 8.000 090 0.090 295 0.950 485 8.500 095 0.095 410 1.000 490 9.000 210 0.100 512 1.250 495 9.500 215 0.150 415 1.500 610 10.000 220 0.200 517 1.750 710 10.500 OR VOLTAGE COIL (NORMAL RATED VOLTAGE) 6 A06 A12 A18 A24 6 DC 12 DC 18 DC 24 DC 8. TERMINAL A32 A48 A65 J06 32 DC 48 DC 65 DC 6 AC J12 J18 J24 J48 12 AC 18 AC 24 AC 48 AC 611 711 612 712 613 614 615 616 617 618 620 622 624 625 630 635 8 640 8 645 8 650 8 11.000 11.500 12.000 12.500 13.000 14.000 15.000 16.000 17.000 18.000 20.000 22.000 24.000 25.000 30.000 35.000 40.000 45.000 50.000 J65 K20 L40 65 AC 120 AC 240 AC 9 1 10 Push-On 0.250 Tab (Q.C.) 2 Screw 8-32 with upturned lugs 3 11 Screw 8-32 (Bus Type) 4 Screw 10-32 with upturned lugs 5 11 Screw 10-32 (Bus Type) 6 Screw 8-32 with upturned lugs & 30° bend 7 Screw 8-32 (Bus Type) & 30° bend 8 Screw 10-32 with upturned lugs & 30° bend 9 Screw 10-32 (Bus Type) & 30° bend B Screw M5 with upturned lugs C Screw, M4 with upturned lugs E 11 Screw M4 (Bus Type) F Screw M5 with upturned lugs & 30° bend G Screw M5 (Bus Type) & 30° bend H 11 Screw M5 (Bus Type) L 12 0.250 Q.C./ Solder Lug M 11 M6 Threaded Stud P 13 Printed Circuit Board Terminals Q 14 Push-In Stud R Screw, M4 with upturned lugs & 30° Bend S 13 Push-On 0.110 Tab (Q.C.) T 11 Screw, M4 with upturned lugs 9. ACTUATOR COLOR & LEGEND Actuator Color White Black Red Green Blue Yellow Gray Orange Black (short handle)15 I-O ON-OFF A B C D F G H J K L M N P Q R S T U Dual Legend 1 Black 2 White 3 White 4 White 5 White 6 Black 7 Black 8 Black 9 White 10. MOUNTING / BARRIERS 1 A 2 B 5 6 7 8 MOUNTING STYLE BARRIERS Threaded Insert, 2 per pole 6-32 x 0.195 inches no 6-32 x 0.195 inches yes ISO M3 x 5mm no ISO M3 x 5mm (multipole only) yes Front panel Snap-In, 0.75” wide bezel without Handleguard no without Handleguard (multipole only) yes Front panel Snap-In, 0.96” wide bezel without Handleguard, 1-pole 0.96” wide; no multipole units have .105” bezel overhang on all sides without Handleguard, 1-pole 0.96” wide; yes (multipole only) .105” bezel overhang on all sides 11. AGENCY APPROVAL C D E I UL Recognized & CSA Accepted VDE Certified, UL Recognized & CSA Accepted TUV Certified, UL Recognized & CSA Accepted UL Recognized STD 1077, UL Recognized 1500 (ignition protected), & CSA Accepted Configure Complete Part Number > Browse Standard Parts > Ordering Scheme Sample Part Number A A 1 - B 0 - 14 -450 - 1 B 1 - M T 1 Selection 2 3 4 5 6 1. SERIES 2. ACTUATOR 1 2 1 One 2 Two 10. MOUNTING / BARRIERS 3 Three 4 Four 4. CIRCUIT B Series Trip (Current) 5 AUXILIARY/ALARM SWITCH 0 1 2 5 2 without Aux Switch 7 S.P.D.T., 0.093 Q.C. Term. S.P.D.T., 0.110 Q.C. Term. 8 S.P.S.T., 0.093 Q.C. Term. 9 (Gold Contacts) 6. FREQUENCY & DELAY 11 12 14 16 DC Ultra Short DC Short DC Medium DC Long S.P.S.T., 0.110 Q.C. Term. (Gold Contacts) S.P.S.T., 0.187 Q.C. Term. S.P.D.T., 0.187 Q.C. Term. 52 3 DC, Short, High-inrush 54 3 DC, Medium, High-inrush 56 3 DC, Long, High-inrush CODE AMPERES 0.100 0.150 0.200 0.250 0.300 0.350 0.400 0.450 0.500 0.550 0.600 0.650 0.700 0.750 0.800 8. TERMINAL 285 290 295 410 512 415 517 420 522 527 430 435 440 445 450 0.850 0.900 0.950 1.000 1.250 1.500 1.750 2.000 2.250 2.750 3.000 3.500 4.000 4.500 5.000 1 6 Push-On 0.250 Tab (Q.C.) 2 Screw 8-32 with upturned lugs 3 7 Screw 8-32 (Bus Type) 4 Screw 10-32 with upturned lugs 5 7 Screw 10-32 (Bus Type) 6 Screw 8-32 with upturned lugs & 30° bend 7 Screw 8-32 (Bus Type) & 30° bend 8 Screw 10-32 with upturned lugs & 30° bend 07. 9 10 11 12 455 460 465 470 475 480 485 490 495 610 710 611 711 612 712 9 B F G H M 7 P 8 Q 9 5.500 6.000 6.500 7.000 7.500 8.000 8.500 9.000 9.500 10.000 10.500 11.000 11.500 12.000 12.500 613 614 615 616 617 618 620 622 624 625 630 635 3 640 3 645 3 650 3 13.000 14.000 15.000 16.000 17.000 18.000 20.000 22.000 24.000 25.000 30.000 35.000 40.000 45.000 50.000 Screw 10-32 (Bus Type) & 30° bend Screw M5 with upturned lugs Screw M5 with upturned lugs & 30° bend Screw M5 (Bus Type) & 30° bend Screw M5 (Bus Type) M6 Threaded Stud Printed Circuit Board Terminals Push-In Stud & 30° bend 9 MOUNTING STYLE BARRIERS Threaded Insert, 2 per pole 1 6-32 x 0.195 inches no A 6-32 x 0.195 inches yes 2 ISO M3 x 5mm no B ISO M3 x 5mm (multipole only) yes Front panel Snap-In, 0.75” wide bezel 5 without Handleguard no 6 without Handleguard (multipole only) yes Front panel Snap-In, 0.96” wide bezel 7 without Handleguard, 1-pole 0.96” wide; no multipole units have .105” bezel overhang on all sides 8 without Handleguard, 1-pole 0.96” wide; yes (multipole only) .105” bezel overhang on all sides 11. MAXIMUM APPLICATION RATING M 80 DC 12. AGENCY APPROVAL T K J 7. CURRENT RATING (AMPERES) 210 215 220 225 230 235 240 245 250 255 260 265 270 275 280 8 Actuator Color ON-OFF Dual Legend Color White B 1 Black Black D 2 White Red G 3 White Green J 4 White Blue L 5 White Yellow N 6 Black Gray Q 7 Black Orange S 8 Black Black (short handle) 10 U 9 White Handle, one per pole Mid-Trip Handle, one per pole Mid-Trip Handle, one per pole & Alarm Switch 3. POLES 7 9. ACTUATOR COLOR & LEGEND A A S T Handle - UL 489A Listed UL489A Listed UL489A Listed, VDE Certified UL489A Listed, TUV Certified Notes: 1 Actuator Code: A: Handle tie pin spacer(s) and retainers provided un-assembled with multi-pole units. S: Handle moves to mid-position only upon electrical trip of the breaker. T: Handle moves to mid-position and alarm switch activates only upon electrical trip of the breaker. 2 On multi-pole breakers, one auxiliary switch is supplied, mounted in the extreme right pole. 3 VDE Certified to 30 amps. UL489A Listed to 50 amps. 4 VDE Certification available with single pole breakers only. UL489A Listing available with one and two pole breakers. 5 Screw Terminals are recommended on ratings greater than 20 amps. Ratings over 30 amps are only available with Terminal Codes 5, 9 G, H, M and Q. 6 Terminal Code 1 (Push-On) available up to 25 amps with VDE Certification and 30 amps with UL489A Listing, but is not recommended over 20 amps. 7 Terminal Codes 3, 5 and H (Bus Type) with VDE, are supplied with Lock Washers, and Terminal Code M (M6 Threaded Stud) with VDE is supplied with Lock and Flat Washers. These breakers are only VDE Certified when the washers are used. 8 Single pole breakers with Terminal Code P (Printed Circuit Board) are available up to 30 amps with VDE Certification and 50 amps with UL489A Listing. 9 Terminal Code Q not available with VDE certification. 10 Single pole only. Configure Complete Part Number > Browse Standard Parts > A-Series Circuit Breaker - Handle WORLD – Ordering Scheme Ordering Scheme Sample Part Number A A 3 - B 0 - 14 -450 - 1 A 1 - P 1 Selection 2 3 4 5 1. SERIES A B S T 1 Handle, one per pole Handle, one per multipole unit Mid-Trip Handle, one per pole Mid-Trip Handle, one per pole & Alarm Switch 1 One 2 Two 3 Three 4 Four A 2 Switch Only (No Coil) D 3 B Series Trip (Current) E 3 C Series Trip (Voltage) H 3,4 5. AUXILIARY / ALARM SWITCH Shunt Trip (Current) Shunt Trip (Voltage) Dual Coil with Shunt Trip Voltage Coil 5 without Aux Switch S.P.D.T., 0.110 Q.C. Term. 6. FREQUENCY & DELAY DC 50/60Hz, Switch Only DC Instantaneous DC Ultra Short DC Short DC Medium DC Long 50/60Hz Instantaneous 50/60Hz Ultra Short 50/60Hz Short 50/60Hz Medium 50/60Hz Long 30 DC, 50/60Hz Instantaneous 31 DC, 50/60Hz Ultra Short 32 DC, 50/60Hz Short 34 DC, 50/60Hz Medium 36 DC, 50/60Hz Long 42 7 50/60Hz Short, High-inrush 44 7 50/60Hz Medium, High-inrush 46 7 50/60Hz Long, High-inrush 52 7 DC, Short, High-inrush 54 7 DC, Medium, High-inrush 56 7 DC, Long, High-inrush 7. CURRENT RATING (AMPERES) CODE AMPERES 210 0.100 285 0.850 455 5.500 215 0.150 290 0.900 460 6.000 220 0.200 295 0.950 465 6.500 225 0.250 410 1.000 470 7.000 230 0.300 512 1.250 475 7.500 235 0.350 415 1.500 480 8.000 240 0.400 517 1.750 485 8.500 245 0.450 420 2.000 490 9.000 250 0.500 522 2.250 495 9.500 255 0.550 527 2.750 610 10.000 260 0.600 430 3.000 710 10.500 265 0.650 435 3.500 611 11.000 270 0.700 440 4.000 711 11.500 275 0.750 445 4.500 612 12.000 280 0.800 450 5.000 712 12.500 OR VOLTAGE COIL (NORMAL RATED VOLTAGE) 6 A06 A12 A18 A24 6 DC 12 DC 18 DC 24 DC 8. TERMINAL A32 A48 A65 J06 32 DC 48 DC 65 DC 6 AC 1 10 Push-On 0.250 Tab (Q.C.) 2 Screw 8-32 with upturned lugs 3 11 Screw 8-32 (Bus Type) 4 Screw 10-32 with upturned lugs 5 11 Screw 10-32 (Bus Type) 6 Screw 8-32 with upturned lugs & 30° bend 7 Screw 8-32 (Bus Type) & 30° bend 8 Screw 10-32 with upturned lugs & 30° bend 08. 8 9 10 11 J12 J18 J24 J48 9 B C E 11 F G H 11 M R T 11 12 AC 18 AC 24 AC 48 AC 613 13.000 614 14.000 615 15.000 616 16.000 617 17.000 618 18.000 620 20.000 622 22.000 624 24.000 625 25.000 630 30.000 635 8 35.000 640 8 40.000 645 8 45.000 650 8 50.000 J65 K20 L40 I-O Dual Legend Color A 1 Black C 2 White F 3 White H 4 White K 5 White M 6 Black P 7 Black R 8 Black T 9 White 10. MOUNTING / BARRIERS 5 Five 6 Six 4. CIRCUIT 03 10 11 12 14 16 20 21 22 24 26 7 Actuator Color White Black Red Green Blue Yellow Gray Orange Black (short handle)15 3. POLES 0 2 6 9 ACTUATOR COLOR & LEGEND A 2. ACTUATOR Handle - World 65 AC 120 AC 240 AC Screw 10-32 (Bus Type) & 30° bend Screw M5 with upturned lugs Screw, M4 with upturned lugs Screw M4 (Bus Type) Screw M5 with upturned lugs & 30° bend Screw M5 (Bus Type) & 30° bend Screw M5 (Bus Type) M6 Threaded Stud Screw, M4 with upturned lugs & 30° Bend Screw, M4 with upturned lugs MOUNTING STYLE BARRIERS Threaded Insert, 2 per pole 1 6-32 x 0.195 inches no A 6-32 x 0.195 inches yes 2 ISO M3 x 5mm no B ISO M3 x 5mm (multipole only) yes Front panel Snap-In, 0.75” wide bezel 5 without Handleguard no 6 without Handleguard (multipole only) yes Front panel Snap-In, 0.96” wide bezel 7 without Handleguard, 1-pole 0.96” wide; no multipole units have .105” bezel overhang on all sides 8 without Handleguard, 1-pole 0.96” wide; yes (multipole only) .105” bezel overhang on all sides 11. AGENCY APPROVAL P TUV Certified, UL Recognized & CSA Accepted Q UL Recognized STD 1077, UL Recognized 1500 (ignition protected), & CSA Accepted Notes: 1 Actuator Code: A: Handle tie pin spacer(s) and retainers provided unassembled with multi-pole units. S: Handle moves to mid-position only upon electrical trip of the breaker. Available with circuit codes B, C, D, E, and H. T: Handle moves to mid-position and alarm switch activates only upon electrical trip of the breaker. Available with circuit codes B & C. 2 Switch Only circuits, rated up to 50 amps and 6 poles, and only available when tied to a protected pole (Circuit Code B, C, D or H.), For .01 to 30 amps, select Current Code 630. For 35 - 50 amps, select Current Code 650. 3 Available with terminal Codes 1, 2 and 3. Current Rating limited to 30 amps maximum. 4 Consult factory for available Dual Coil options, as special catalog number is required. With Shunt construction, Dual Coils will trip instantaneously on line volt age. Dual coils require 30VA minimum power to trip and are rated for intermittent duty only. 5 On multi-pole breakers, one auxiliary switch is supplied, mounted in the extreme right pole. 6 Separate pole type voltage coils not rated for continuous duty. Available only with delay codes 10, 20 & 30. 7 Available with Circuit Codes B & D only. VDE Certified to 30 amps. UL Recognized, CSA Accepted & TUV Certified to 50 amps. 8 Available up to two poles with AC or DC delays. 9 Screw Terminals are recommended on ratings greater than 20 amps. Ratings over 30 amps are only available with Terminal Codes 5, 9, G and H. 10 Terminal Code 1: TUV Certification up to 30 amps, but not recommended over 20 amps. 11 Terminal Codes 3, 5 , 7, 9, E, G and H (Bus Type) are supplied with Lock Washers. These breakers are only TUV Certified when the washers are used. 12 Single pole only. Configure Complete Part Number > Browse Standard Parts > Circuit & Terminal Diagrams Handle inches [millimeters] ANSI SWITCH ONLY (NO COIL) LINE CIRCUIT SCHEMATIC ANSI SERIES TRIP LINE LINE MAIN TERMINALS (SEE TABLE A) A LOAD 1.640 [41.66] BC LOAD 5 TERMINALS C .205 [5.21] 3 TERMINALS STANDARD AUX. SWITCH TERMINALS ALARM SWITCH TERMINALS & STD. AUX. VDE OR 30 AMPS Notes: 1 Tolerance ±.020 [.51] unless otherwise specified. 2 Alarm Switch available with .110 x .020 Q.C. & Solder Lug Terminals Only. TAB (Q.C.) TAB (Q.C.) LINE .093 [2.36] .110 [2.79] .050 DIA [ 1.27] .520 [13.21] 09. BC LINE DE LINE NC DUAL COIL; SERIES TRIP CURRENT COIL, RELAY TRIP VOLTAGE COIL LINE 4 0 LOAD SHUNT TRIP 1 BC SERIES TRIP WITH (3) AUXILIARY/ALARM SWITCH .520 [13.21] NC NO CIRCUIT CODE AUX SWITCH CODE CIRCUIT SCHEMATIC CIRCUIT BREAKER PROFILE CIRCUIT CODE AUX SWITCH CODE 2 TERMINALS 1.000 [25.40] .087 [2.20] .287 [7.29] TAB (Q.C.) LOAD .110 [2.80] Circuit & Terminal Diagrams Handle inches [millimeters] HANDLE POSITION VS. AUX/ALARM SWITCH MODE CIRCUIT BREAKER MODE MID TRIP C/B STANDARD C/B AUX. SWITCH MODE HANDLE POSITION OFF F F OF C NO NC 0 ON AUX. SWITH CODE (W/O ALARM SWITCH) 30 30 F OF HANDLE POSITION HANDLE POSITION ALARM SWITCH MODE 30 MID TRIP C/B 0 OF C NO NC ON 0 C NC NO NC NO C NC NO C ON ON 30 30 C NO NC 30 ELECTRICAL TRIP NO NC .375 [9.53] MID TRIP UPTURN LUG #8-32 30 AMP #10-32 30 AMP M5 30 AMP M4 30 AMP BUS .344 [8.74] QC SOLDER LUG #8-32 30 AMP #10-32 50 AMP .110 QC 30 AMP +.002 -.000 VOLTAGE COILS ONLY .392 [9.97] CENTERLINE OF PUSH-IN STUD CONTACT AREA .100 [2.54] .154 .750 [3.91]DIA [19.05] PUSH-IN STUF .405 [10.29] M6 STUD 50 AMP 50 AMP TABLE A TIGHTENING TORQUE SPECIFICATIONS [+.05] [-.00] .161 DIA [ 4.10] THREAD SIZE PUSH-IN STUD MATING HOLE #6-32 & M3 MOUNTING HARDWARE #8-32 & M4 THREAD TERMINAL SCREW #10-32 & M5 THREAD TERMINAL SCREW .520 [13.21] MAIN 2.000 [50.80] LOAD SHUNT,RELAY & DUAL COIL AUX. SWITCH* TAB (Q.C.) SCREW TYPE TAB (Q.C.) SCREW #8-32 W/UPTURNED LUGS .093 TAB (Q.C.) .110 TAB (Q.C.) SOLDER TYPE BARRIER FOR UL-RECOGNIZED MULTI-POLE BREAKERS TORQUE 7-9 IN-LBS [0.8-1.0 NM] 12-15 IN-LBS [1.4-1.7 NM] 15-20 IN-LBS [1.7-2.3 NM] TABLE B TERMINAL DESCRIPTION LINE DEPTH BEHIND PANEL 2.000[50.80] 2.032[51.60] 2.207[56.10] 2.364[60.05] 2.095[53.20] 2.189[55.60] 1.970[50.00] *AVAILABLE ON SERIES TRIP AND SWITCH ONLY CIRCUITS WHEN CALLED FOR ON MULTI-POLE UNITS, ONLY ONE AUX. SWITCH IS NORMALLY SUPPLIED, AS SHOWN IN MULTI-POLE INDENTIFICATION SHEME. .393 [9.96] REF SEE TABLE-B DEPTH BEHIND PANEL LINE (NETZ) ON MID TRIP 1.560 [39.62] TYP OFF O 1.640 [41.66] REF .032 [.81] TYP 1.350 [34.29] 1.936 [49.17] 30 2 PLCS 1.560 [39.62]TYP LOAD (LAST) .220 [5.59]TYP M6 STUD Notes: 1 Tolerance ±.020 [.51] unless otherwise specified. 2 Alarm Switch available with .110 x .020 QC & solder lug terminals only. 10. 1.000 [25.40] .750 [19.05] .361 [9.17] .110 [2.79] .250 [6.35] 90 C NO NC .093DIA [.76] 30 C 90 C .392 [9.96] .375 [9.53] DIA 30 AMP 0 .392 [9.96] .250 [6.35] TAB(Q.C.) O MID TRIP TERMINAL DIMENSIONAL DETAIL & RATING .360 [9.14] .069 [1.75] FF NO NC PUSH-IN STUD SCREW TERMINAL WITH 30 BEND Dimensional Specs Handle inches [millimeters] #6-32 [M3] THREAD X.195[4.95]DEEP 2 PLCS PER POLE .610 [15.49] 1.640 [41.66] .130 [3.30] SEE NOTE 3 TYP LINE ON 60 1-POLE (AA1) 1.560 [39.62] TYP OFF .170 [4.32] .690 [17.50] .250 [6.35] .755 [19.18] 2.000 [50.80] 2.032 [51.61] SHORT HANDLE MAX LOAD TAB (Q.C.) TYPE SCREW TYPE TYPICAL-OPTIONAL “ON-OFF” LEGEND 2-POLE (AA2) 2-POLE (AB2) .750 [19.05] 1.515 [38.48] 1.515 [38.48] MAX MAX 3-POLE (AA3) 3-POLE (AB3) .750 [19.05] 2.265 [57.53] 2.265 [57.53] TYP MAX MAX MULTI-POLE HANDLE TIE KIT SHIPPED BULK 4-POLE (AA4) 4-POLE (AB4) .750 [19.05] TYP 3.015 [76.05] 3.015 [76.58] MAX MAX [+.25] +.010 -.000 [-.00] .630 DIA [ 16.00] ONE PER POLE .156 DIA [ 3.96] 2 PLCS TYP PER POLE 1.660 [42.16] LINE .750 [19.05] TYP PER POLE AA1, AB2, AB3 LOAD POLE 1 POLE 2 POLE 3 POLE 4 MULTI-POLE INDENTIFICATION SCHEME AS VIEWED FROM TERMINAL END OF BREAKER. Notes: 1 Tolerance ± 0.20 [.51] unless otherwise specified. 2 For agency code P = .150 [3.81]. 11. 1.050 [26.67] AA2, AB4 AA3 AA4 PANEL CUTOUT DETAIL _ TOLERANCE _ +.005[+.12] UNLESS OTHERWISE SPECIFIED TAB (Q.C.) TYPE TERMINALS IN SERIES TRIP CONCUIT CONFIGURATION SHOWN. FOR OTHER CONFIGURATIONS SEE CIRCUIT & TERMINAL DIAGRAMS Dimensional Specs Handle inches [millimeters] 1.640 [41.66] TYP .125 [3.18] ON 2.598 [65.99] TYP 1 POLE (AA1) LINE 60 .250 [6.35] (SHORT HANDLE) .690 [17.50] 2.000 [50.80] TYP .755 [19.18] MAX BREAKER WIDTH 1.220 [31.00] TYP LOAD OFF .744 [18.90] 1.560 [39.62] TYP 2.000 [50.80] .250 TAB (Q.C.) TYPE 2.032 [51.61] SCREW TYPE TAB (Q.C.) TYPE TERMINALS IN SERIES TRIP CIRCUIT CONFIGURATION SHOWN. FOR OTHER CONFIGURATIONS, SEE CIRCUIT AND TERMINAL DIAGRAMS. .010 2 POLE (AA2) 3.030 [76.96][.25] .010 2 POLE (AB2) .010 .010 .770 [19.56][.25] 1.488 [37.80] 1.488 [37.80] 3 POLE (AA3) 2.280 [57.91] [.25] 1.530 [38.86][.25] .012 2.187 [55.55][.30] TYP 3 POLE (AB3) AA1 AA2, AB2 AA3, AB3 AA4, AB4 2.232 [56.69] 4 POLE (AA4) 2.323 [56.69] 4 POLE (AB4) 2.976 [75.59] MULTI-POLE HANDLE TIE KITSHIPPED BULK Notes: 1 Recommended panel thickness: .040 [1.02] to .100 [2.54]. 2 Tolerance ±.020 [.51] unless otherwise specified. 12. 2.976 [75.59] PANEL CUTOUT DETAIL Dimensional Specs Handle inches [millimeters] 1.640 [41.66] TYP ON 1 POLE (AA1) 2.598 [65.99] TYP LINE 60 OFF LOAD .960 [24.38] .755 [19.18] MAX BREAKER WIDTH 1.560 [39.62] TYP .250 [6.35] (SHORT HANDLE) .690 [17.50] 1.220 [31.00] TYP 2.000 [50.80] TYP 2.000 [50.80] .250 TAB (Q.C.) TYPE 2.032 [51.61] SCREW TYPE TAB (Q.C.) TYPE TERMINALS IN SERIES TRIP CIRCUIT CONFIGURATION SHOWN. FOR OTHER CONFIGURATIONS, SEE CIRCUIT AND TERMINAL DIAGRAMS. .010 3.030 [76.96][.25] 2 POLE (AA2) .010 2 POLE (AB2) 1.700 [43.18] .010 .010 .770 [19.56][.25] 1.700 [43.18] 3 POLE (AA3) 2.280 [57.91] [.25] 1.530 [38.86][.25] .012 2.187 [55.55][.30] TYP 3 POLE (AB3) AA1 AA2, AB2 AA3, AB3 AA4, AB4 2.450 [62.23] 4 POLE (AA4) 2.450 [62.23] 4 POLE (AB4) 3.190 [81.03] MULTI-POLE HANDLE TIE KIT SHIPPED BULK Notes: 1 Recommended panel thickness: .040 [1.02] to .100 [2.54]. 2 Tolerance ±.020 [.51] unless otherwise specified. 13. 3.190 [81.03] PANEL CUTOUT DETAIL A-Series Circuit Breaker - Handle Sealed Toggle WORLDUL – Ordering Recognized Scheme – Ordering Scheme Ordering Scheme Sample Part Number A M 1 - B 0 - 10 -450 - 1 0 1 - C 1 Selection 2 3 4 5 1 Sealed Toggle, one per unit 3. POLES 1 One 2 3 Two Three 4. CIRCUIT Switch Only (No Coil) F 3 A 2 B Series Trip (Current) G 3 C Series Trip (Voltage) H 3,4 D 3 Shunt Trip (Current) E 3 Shunt Trip (Voltage) K 3,4 5. AUXILIARY / ALARM SWITCH 0 1 2 5 Relay Trip (Current) Relay Trip (Voltage) Dual Coil with Shunt Trip Voltage Coil Dual Coil with Relay Trip Voltage Coil 5 without Aux Switch 7 S.P.D.T., 0.093 Q.C. Term. S.P.D.T., 0.110 Q.C. Term. 8 S.P.S.T., 0.093 Q.C. Term. 9 (Gold Contacts) S.P.S.T., 0.110 Q.C. Term. (Gold Contacts) S.P.S.T., 0.187 Q.C. Term. S.P.D.T., 0.187 Q.C. Term. DC 50/60Hz, Switch Only DC Instantaneous DC Ultra Short DC Short DC Medium DC Long 50/60Hz Instantaneous 50/60Hz Ultra Short 50/60Hz Short 50/60Hz Medium 50/60Hz Long 30 DC, 50/60Hz Instantaneous 31 DC, 50/60Hz Ultra Short 32 DC, 50/60Hz Short 34 DC, 50/60Hz Medium 36 DC, 50/60Hz Long 42 7 50/60Hz Short, High-inrush 44 7 50/60Hz Medium, High-inrush 46 7 50/60Hz Long, High-inrush 52 7 DC, Short, High-inrush 54 7 DC, Medium, High-inrush 56 7 DC, Long, High-inrush 7. CURRENT RATING (AMPERES) CODE AMPERES 020 0.020 230 0.300 425 2.500 025 0.025 235 0.350 527 2.750 030 0.030 240 0.400 430 3.000 035 0.035 245 0.450 435 3.500 040 0.040 250 0.500 440 4.000 045 0.045 255 0.550 445 4.500 050 0.050 260 0.600 450 5.000 055 0.055 265 0.650 455 5.500 060 0.060 270 0.700 460 6.000 065 0.065 275 0.750 465 6.500 070 0.070 280 0.800 470 7.000 075 0.075 285 0.850 475 7.500 080 0.080 290 0.900 480 8.000 085 0.085 295 0.950 485 8.500 090 0.090 410 1.000 490 9.000 095 0.095 512 1.250 495 9.500 210 0.100 415 1.500 610 10.000 215 0.150 517 1.750 710 10.500 220 0.200 420 2.000 611 11.000 225 0.250 522 2.250 711 11.500 OR VOLTAGE COIL (NORMAL RATED VOLTAGE) 6 A06 A12 A18 A24 14. 6 DC 12 DC 18 DC 24 DC A32 A48 A65 J06 32 DC 48 DC 65 DC 6 AC J12 J18 J24 J48 8 9 10 11 9 2 Screw 8-32 with upturned lugs 3 Screw 8-32 (Bus Type) 4 Screw 10-32 with upturned lugs 5 Screw 10-32 (Bus Type) 6 Screw 8-32 with upturned lugs & 30° bend 7 Screw 8-32 (Bus Type) & 30° bend 8 Screw 10-32 with upturned lugs & 30° bend 9 Screw 10-32 (Bus Type) & 30° bend B Screw M5 with upturned lugs C Screw, M4 with upturned lugs E Screw M4 (Bus Type) F Screw M5 with upturned lugs & 30° bend G Screw M5 (Bus Type) & 30° bend H Screw M5 (Bus Type) L 12 0.250 Q.C./ Solder Lug M M6 Threaded Stud P 12 Printed Circuit Board Terminals Q Push-In Stud R Screw, M4 with upturned lugs & 30° Bend S 17 Push-On 0.110 Tab (Q.C.) & 30° bend T Screw, M4 with upturned lugs 9. LEGEND PLATE 0 No legend plate 10. MOUNTING / BARRIERS MOUNTING STYLE BARRIERS 1 Standard Hex Nut no A Standard Hex Nut (multipole only) yes 11. AGENCY APPROVAL 6. FREQUENCY & DELAY 03 10 11 12 14 16 20 21 22 24 26 7 1 10 Push-On 0.250 Tab (Q.C.) A M 6 8. TERMINAL 1. SERIES 2. ACTUATOR Sealed Toggle 12 AC 18 AC 24 AC 48 AC 612 12.000 712 12.500 613 13.000 614 14.000 615 15.000 616 16.000 617 17.000 618 18.000 620 20.000 622 22.000 624 24.000 625 25.000 630 30.000 635 8 35.000 640 8 40.000 645 8 45.000 650 8 50.000 J65 K20 L40 65 AC 120 AC 240 AC C UL Recognized & CSA Accepted I UL Recognized STD 1077, UL Recognized 1500 (ignition protected), & CSA Accepted Notes: 1 Actuator Code M: Handle location as viewed from front of panel: 2 pole - right pole 3 pole - center pole 2 Switch Only circuits, rated up to 50 amps and 3 poles. Only available when tied to a protected pole. For .02 to 30 amps, select Current Code 630. For 35 - 50 amps, select Current Code 650. 3 Available with terminal Codes 1, 2 and 3. Current Rating limited to 30 amps maximum. 4 Consult factory for available Dual Coil options, as special catalog number is required. With Shunt construction, Dual Coils will trip instantaneously on line volt age. Dual coils require 30VA minimum power to trip and are rated for intermittent duty only. 5 Auxiliary Switch available on Series Trip & Switch Only circuits, limited to 30 amps. On multi-pole breakers, one auxiliary switch is supplied, mounted in the extreme right pole. 6 Voltage coils not rated for continuous duty. Available only with delay codes 10 and 20. 7 Available with Circuit Codes B & D only. VDE Certified to 30 amps. UL Recognized, CSA Accepted & TUV Certified to 50 amps. 8 UL Recognition and CSA Certification available on one and two pole breakers. 9 Screw Terminals are recommended on ratings greater than 20 amps. Ratings over 30 amps are only available with Terminal Codes 5, 9, B, F, G, H, M and Q. 10 Terminal Code 1: UL Recognition and CSA Certification up to 30 amps, but not recommended over 20 amps. 11 Terminal Code L : available up to 30A. 12 Single pole breakers with Terminal Code P (Printed Circuit Board) are available up to 50 amps, with Circuit Codes A, B and C. Two pole breakers with Terminal Code P (Printed Circuit Board) are available up to 40 amps with Circuit Codes A, B and C. Configure Complete Part Number > Browse Standard Parts > Dimensional Specs inches [millimeters] Notes: 1 Tolerance ±.020 [.51] unless otherwise specified. 15. Sealed Toggle Ordering Scheme Sample Part Number A F 1 - B 0 - 24-630 - 2 3 1 - D 1 Selection 2 3 4 5 6 1 ROCKER STYLE DESCRIPTIONS Two Color Visi-Rocker C Indicate ON, vertical legend D Indicate ON, horizontal legend F Indicate OFF, vertical legend G Indicate OFF, horizontal legend H Indicate OFF, no legend Push-To-Reset, Visi-Rocker N Indicate OFF, vertical legend O Indicate OFF, horizontal legend P Indicate OFF, no legend Single color J Vertical legend K Horizontal legend L No legend Push-To-Reset , Single color R Vertical legend U Horizontal legend V No legend HORIZONTAL STYLE INDICATE “ON” INDICATE “OFF” SINGLE COLOR VERTICAL STYLE LINE CODE “C” LINE CODE “D” INDICATE COLOR LOCATION CODE “G”, “O” CODE “F”, “N” LINE LINE CODE “k”, “U” CODE “J”, “R” LINE LINE 3. POLES 2 3 Two Three 4. CIRCUIT A 3 B C D 4 E 4 Switch Only (No Coil) G 4 Relay Trip (Voltage) Series Trip (Current) H 4,5 Dual Coil with Shunt Trip Series Trip (Voltage) Voltage Coil Shunt Trip (Current) K 4,5 Dual Coil with Relay Trip Shunt Trip (Voltage) Voltage Coil 5. AUXILIARY / ALARM SWITCH 0 1 2 5 without Aux Switch 7 S.P.D.T., 0.093 Q.C. Term. S.P.D.T., 0.110 Q.C. Term. 8 S.P.S.T., 0.093 Q.C. Term. 9 (Gold Contacts) 6. FREQUENCY & DELAY 03 10 11 12 14 16 20 21 22 24 26 5 DC 50/60Hz, Switch Only DC Instantaneous DC Ultra Short DC Short DC Medium DC Long 50/60Hz Instantaneous 50/60Hz Ultra Short 50/60Hz Short 50/60Hz Medium 50/60Hz Long S.P.S.T., 0.110 Q.C. Term. (Gold Contacts) S.P.S.T., 0.187 Q.C. Term. S.P.D.T., 0.187 Q.C. Term. 30 DC, 50/60Hz Instantaneous 31 DC, 50/60Hz Ultra Short 32 DC, 50/60Hz Short 34 DC, 50/60Hz Medium 36 DC, 50/60Hz Long 42 9 50/60Hz Short, High-inrush 44 9 50/60Hz Medium, High-inrush 46 9 50/60Hz Long, High-inrush 52 9 DC, Short, High-inrush 54 9 DC, Medium, High-inrush 56 9 DC, Long, High-inrush 7. CURRENT RATING (AMPERES) CODE AMPERES 020 0.020 225 0.250 420 2.000 025 0.025 230 0.300 522 2.250 030 0.030 235 0.350 527 2.750 035 0.035 240 0.400 430 3.000 040 0.040 245 0.450 435 3.500 045 0.045 250 0.500 440 4.000 050 0.050 255 0.550 445 4.500 055 0.055 260 0.600 450 5.000 060 0.060 265 0.650 455 5.500 065 0.065 270 0.700 460 6.000 070 0.070 275 0.750 465 6.500 075 0.075 280 0.800 470 7.000 080 0.080 285 0.850 475 7.500 085 0.085 290 0.900 480 8.000 090 0.090 295 0.950 485 8.500 095 0.095 410 1.000 490 9.000 210 0.100 512 1.250 495 9.500 215 0.150 415 1.500 610 10.000 220 0.200 517 1.750 710 10.500 OR VOLTAGE COIL (NORMAL RATED VOLTAGE) 8 A06 6 DC A32 32 DC J12 12 AC A12 12 DC A48 48 DC J18 18 AC A18 18 DC A65 65 DC J24 24 AC A24 24 DC J06 6 AC J48 48 AC 16. Configure Complete Part Number > 611 711 612 712 613 614 615 616 617 618 620 622 624 625 630 635 8 640 8 645 8 650 8 11.000 11.500 12.000 12.500 13.000 14.000 15.000 16.000 17.000 18.000 20.000 22.000 24.000 25.000 30.000 35.000 40.000 45.000 50.000 J65 K20 L40 65 AC 120 AC 240 AC Browse Standard Parts > 8 9 10 11 11 1 12 Push-On 0.250 Tab (Q.C.) A 1 One 7 8. TERMINAL 1. SERIES 2. ACTUATOR Rocker UL 1077 Recognized 2 Screw 8-32 with upturned lugs 3 13 Screw 8-32 (Bus Type) 4 Screw 10-32 with upturned lugs 5 13 Screw 10-32 (Bus Type) 6 Screw 8-32 with upturned lugs & 30° bend 7 Screw 8-32 (Bus Type) & 30° bend 8 Screw 10-32 with upturned lugs & 30° bend 9 Screw 10-32 (Bus Type) & 30° bend B Screw M5 with upturned lugs C Screw, M4 with upturned lugs E 13 Screw M4 (Bus Type) F Screw M5 with upturned lugs & 30° bend G Screw M5 (Bus Type) & 30° bend H 13 Screw M5 (Bus Type) L 14 0.250 Q.C./ Solder Lug M 13 M6 Threaded Stud P 15 Printed Circuit Board Terminals Q Push-In Stud R Screw, M4 with upturned lugs & 30° Bend S 17 Push-On 0.110 Tab (Q.C.) & 30° bend T Screw, M4 with upturned lugs 9. ACTUATOR COLOR & LEGEND Actuator or Marking: Marking Color Visi-Color 12 I-O ON-OFF Dual 12 Single Color Visi-Rocker White A B 1 Black White Black C D 2 White n/a Red F G 3 White Red Green H J 4 White Green Blue K L 5 White Blue Yellow M N 6 Black Yellow Gray P Q 7 Black Gray Orange R S 8 Black Orange 10. MOUNTING / BARRIERS 20 STANDARD ROCKER BEZEL Threaded Insert, 2 per pole BARRIERS 1 6-32 x 0.195 inches no A 6-32 X 0.195 inches (multi-pole units only) yes 2 ISO M3 x 5mm no B ISO M3 x 5mm (multi-pole units only) yes ROCKERGUARD & PUSH-TO-RESET BEZEL Threaded Insert, 2 per pole 3 6-32 x 0.195 inches no C 6-32 x 0.195 inches (multi-pole units only) yes 4 ISO M3 x 5mm no D ISO M3 x 5mm (multi-pole units only) yes FRONT PANEL SNAP-IN BRACKET, 0.744” [18.90mm] wide bezel 8 without Rockerguard (single pole units only) no H with Rockerguard (single pole units only) no FRONT PANEL SNAP-IN BRACKET, 0.96” [24.48mm] wide bezel 9 without Rockerguard (single pole units only) no J with Rockerguard (single pole units only) no 11. AGENCY APPROVAL C D E I UL Recognized & CSA Accepted VDE Certified, UL Recognized & CSA Accepted TUV Certified, UL Recognized & CSA Accepted UL Recognized STD 1077, UL Recognized 1500 (ignition protected), & CSA Accepted Notes: 1 Push-To-Reset actuators have OFF portion of rocker shrouded. 2 Multi-pole breakers have all breakers identical except when specifying Auxiliary switch and/or mixed poles, and have one rocker per breaker. 3 Switch Only circuits, rated up to 50 amps & 3 poles, are available only when tied to a protected pole (Circuit Code B, C, D or H.), For .02 to 30 amps, select Current Code 630. For 35 - 50 amps, select Current Code 650. 4 Available with terminal Codes 1, 2 and 3. Current Rating limited to 30 amps maximum. 5 Consult factory for Dual Coil options, as special catalog number is required. With Shunt construction, Dual Coils will trip instantaneously on line voltage. Dual coils require 30VA minimum power to trip and are rated for intermittent duty only. 6 Auxiliary Switch breakers with Series Trip & Switch Only circuits: ≤ 30A, are supplied with standard half shells. 30-50A are supplied with extended boat (B-Style) half shells. 7 On multi-pole breakers, one auxiliary switch is supplied, mounted in the right pole. 8 Separate pole type voltage coils not rated for continuous duty. Available only with delay codes 10 & 20. 9 Available with Circuit Codes B & D only. VDE Certified to 30 amps. UL Recognized, CSA Accepted & TUV Certified to 50 amps. 10 Series Trip current ratings: VDE Certification available with single pole breakers with DC Delay only. UL Recognition & CSA Accepted available in one and two pole breakers. 11 Screw Terminals are recommended on ratings greater than 20 amps. Ratings over 30 amps are only available with Terminal Codes 5, 9, G, H, M and Q. 12 Terminal Code 1: VDE Certification up to 25 amps and UL Recognition and CSA Accepted up to 30 amps, but not recommended over 20 amps. 13 Terminal Codes 3, 5 E & H (Bus Type) with VDE, are supplied with Lock Washers; Terminal Code M (M6 Threaded Stud) with VDE is supplied with Lock and Flat Washers. These breakers are only VDE Certified when the washers are used. 14 VDE Cert. available up to 12 amps. UL Rec. & CSA Accepted available up to 30 amps. 15 Single pole breakers with Terminal Code P (Printed Circuit Board) are available up to 30 amps with VDE Certification and 50 amps with UL Recognition and CSA Accepted, with Circuit Codes A, B & C.Two pole breakers with Terminal Code P (Printed Circuit Board) are available up to 40 amps with UL Recognition and CSA Certification with Circuit Codes A, B and C. 16 Terminal Code Q not available with VDE. 17 Terminal Code S used on voltage coil circuit constructions only. 18 Color shown is visi and legend with remainder of rocker black. 19 Dual = ON-OFF/I-O legend with actuator. None = no legend on actuator 20 Legend on Push-to-reset bezel/shroud is white with single color actuator codes R, & U. Legend on Push-to-reset bezel/shroud matches Visi-color of rocker with actuator codes N & O. Rockerguard available with actuator codes C through L. Ordering Scheme A F 1 - B 0 - 14 -450 - 1 3 1 - M T Sample Part Number 1 Selection 2 3 4 5 A 2. ACTUATOR 1 Two Color Visi-Rocker Push-To-Reset, Visi-Rocker C Indicate ON, vertical legend N Indicate OFF, D Indicate ON, horizontal legend vertical legend F Indicate OFF, vertical legend O Indicate OFF, horizontal G Indicate OFF, horizontal legend legend Single color Push-To-Reset , Single color J Vertical legend R Vertical legend K Horizontal legend U Horizontal legend ROCKER STYLE DESCRIPTIONS INDICATE “OFF” INDICATE COLOR LOCATION SINGLE COLOR CODE “F”, “N” CODE “C” LINE CODE “J”, “R” LINE LINE CODE “D” HORIZONTAL STYLE VERTICAL STYLE INDICATE “ON” LINE CODE “G”, “O” CODE “K”, “U” LINE LINE FIG.B 3. POLES 2 1 One 2 3 Two Three 4. CIRCUIT without Aux Switch 7 S.P.D.T., 0.093 Q.C. Term. S.P.D.T., 0.110 Q.C. Term. 8 S.P.S.T., 0.093 Q.C. Term. 9 (Gold Contacts) S.P.S.T., 0.110 Q.C. Term. (Gold Contacts) S.P.S.T., 0.187 Q.C. Term. S.P.D.T., 0.187 Q.C. Term. 52 DC, Short, High-inrush 54 DC, Medium, High-inrush 56 DC, Long, High-inrush DC Ultra Short DC Short DC Medium DC Long 7. CURRENT RATING (AMPERES) CODE AMPERES 210 215 220 225 230 235 240 245 250 255 260 265 270 275 280 0.100 0.150 0.200 0.250 0.300 0.350 0.400 0.450 0.500 0.550 0.600 0.650 0.700 0.750 0.800 8. TERMINAL 285 290 295 410 512 415 517 420 522 527 430 435 440 445 450 0.850 0.900 0.950 1.000 1.250 1.500 1.750 2.000 2.250 2.750 3.000 3.500 4.000 4.500 5.000 17. 455 460 465 470 475 480 485 490 495 610 710 611 711 612 712 5.500 6.000 6.500 7.000 7.500 8.000 8.500 9.000 9.500 10.000 10.500 11.000 11.500 12.000 12.500 613 13.000 614 14.000 615 15.000 616 16.000 617 17.000 618 18.000 620 20.000 622 22.000 624 24.000 625 25.000 630 30.000 6354 35.000 6404 40.000 6454 45.000 6504 50.000 5 1 6 Push-On 0.250 Tab (Q.C.) 2 Screw 8-32 with upturned lugs 3 7 Screw 8-32 (Bus Type) 4 Screw 10-32 with upturned lugs 5 7 Screw 10-32 (Bus Type) 6 Screw 8-32 with upturned lugs & 30° bend 7 Screw 8-32 (Bus Type) & 30° bend Actuator or Visi-Color 10 White Black Red Green Blue Yellow Gray Orange 8 9 10 11 12 Marking: Marking Color ON-OFF Dual 10 Single Color Visi-Rocker B 1 Black White D 2 White n/a G 3 White Red J 4 White Green L 5 White Blue N 6 Black Yellow Q 7 Black Gray S 8 Black Orange 10. MOUNTING / BARRIERS 20 STANDARD ROCKER BEZEL Threaded Insert, 2 per pole BARRIERS 1 6-32 x 0.195 inches no A 6-32 X 0.195 inches (multi-pole units only) yes 2 ISO M3 x 5mm no B ISO M3 x 5mm (multi-pole units only) yes ROCKERGUARD & PUSH-TO-RESET BEZEL Threaded Insert, 2 per pole 3 6-32 x 0.195 inches no C 6-32 x 0.195 inches (multi-pole units only) yes 4 ISO M3 x 5mm no D ISO M3 x 5mm (multi-pole units only) yes FRONT PANEL SNAP-IN BRACKET, 0.744” [18.90mm] wide bezel 8 without Rockerguard (single pole units only) no H with Rockerguard (single pole units only) no FRONT PANEL SNAP-IN BRACKET, 0.96” [24.48mm] wide bezel 9 without Rockerguard (single pole units only) no J with Rockerguard (single pole units only) no 11. MAXIMUM APPLICATION RATING M T K J 2 6. FREQUENCY & DELAY 11 12 14 16 7 80 DC 12. AGENCY APPROVAL Series Trip (Current) 5. AUXILIARY / ALARM SWITCH 0 1 2 5 6 9. ACTUATOR COLOR & LEGEND 1. SERIES B Rocker - UL 489A Listed 8 Screw 10-32 with upturned lugs & 30° bend 9 Screw 10-32 (Bus Type) & 30° bend B Screw M5 with upturned lugs F Screw M5 with upturned lugs G Screw M5 (Bus Type) & 30° bend H Screw M5 (Bus Type) M 7 M6 Threaded Stud P 8 Printed Circuit Board Terminals Q 9 Push-In Stud UL489A Listed UL489A Listed, VDE Certified UL489A Listed, TUV Certified Notes: 1 Push-To-Reset actuators have OFF portion of rocker shrouded. 2 Multi-pole breakers have all breakers identical except when specifying Auxiliary switch and/or mixed poles, and have one rocker per breaker. 3 Auxiliary Switch breakers with Series Trip circuits: ≤ 30A, are supplied with standard half shells. 30-50A are supplied with extended boat (B-Style) half shells. 4 VDE Certification available with single pole breakers only. UL489A Listing available with one and two pole breakers. 5 Screw Terminals are recommended on ratings greater than 20 amps. Ratings over 30 amps are only available with Terminal Codes 5, 9, G, H, M and Q. 6 Terminal Code 1 (Push-On) available up to 25 amps with TUV or VDE Certification and 30 amps with UL489A Listing, but is not recommended over 20 amps. 7 Terminal Codes 3, 5 and H (Bus Type) with TUV or VDE, are supplied with Lock Washers, and Terminal Code M (M6 Threaded Stud) with VDE is supplied with Lock and Flat Washers. These breakers are only TUV or VDE Certified when the washers are used. 8 Single pole breakers with Terminal Code P (Printed Circuit Board) are available up to 30 amps with VDE Certification and 50 amps with UL489A Listing. 9 Terminal Code Q not available with VDE certification. 10 Color shown is Visi and Legend with remainder of rocker black. Dual = ON-OFF/I- O legend. 11 Legend on Push-to-reset bezel/shroud is white with single color actuator codes R & U. Legend on Push-To-Reset bezel/shroud matches Visi-Color of rocker with actuator codes N & O. Rockerguard available with actuator codes C through K Configure Complete Part Number > Browse Standard Parts > Circuit & Terminal Diagrams Rocker inches [millimeters] IEC LINE LINE (NETZ) SWITCH ONLY (NO COIL) LINE CIRCUIT SCHEMATIC ANSI SERIES TRIP LINE MAIN TERMINALS (SEE TABLE A) A IEC LINE(NETZ) B C LOAD (LAST) LOAD .520 [13.21] .020 [.51] TYP NC C C NO AUX. SWITCH TERMINALS NC LOAD SWITCH ONLY (NO COIL) (4) WITH AUXILIARY SWITCH LINE SERIES TRIPSWITH (4) AUXILIARY SWITCH C C NO NO NC NC A LINE(NETZ) .390 [9.91] 4 TERMINALS LINE 1 (3) 2 D E 0 3 .390 [9.91] 4 RELAY TABLE B AUX. SWITCH* RELAY (RELAIS) TAB (Q.C.) SCREW TYPE LOAD (LAST) .520 [13.21] LINE 2.000 [50.80] 2.734[69.44] .093 TAB (Q.C.) 2.465[62.61] .110 TAB (Q.C.) SOLDER TYPE 2.559[65.00] 2.340[59.44] LOAD *AVAILABLE ON SERIES TRIP AND SWITCH ONLY CIRCUITS WHEN CALLED FOR ON MULTI-POLE UNITS, ONLY ONE AUX. SWITCH IS NORMALLY SUPPLIED, AS SHOWN IN MULTI-POLE INDENTIFICATION SHEME. BARRIER FOR UL-RECOGNIZED MULTI-POLE BREAKERS SEE TABLE-B DEPTH BEHIND PANEL .370 [9.40] REF 0 2 2.577[65.46] SCREW #8-32 W/UPTURNED LUGS K 4 2.370[60.20] 2.402[61.01] TAB (Q.C.) 0 VOLTAGE COIL 0 DEPTH BEHIND PANEL TERMINAL DESCRIPTION SHUNT,RELAY & DUAL COIL F G I> H U> LINE (3) (RELAIS) 1 LOAD RELAY 3 I> LOAD (LAST) LOAD 2 .780 [19.81] MAIN 3 NC I> 1 2 3 4 LINE(NETZ) LINE LOAD (LAST) RELAY (RELAIS) B C LOAD (LAST) VOLTAGE COIL RELAY TRIP 1 NO DUAL COIL; SERIES TRIP CURRENT COIL, SHUNT TRIP VOLTAGE COIL I> LOAD C NO LOAD SHUNT (NEBENSCHLUSS) SHUNT (3) C NC SHUNT TRIP LINE LINE(NETZ) 1 2 3 4 LOAD (LAST) LOAD 3 TERMINALS LOAD (LAST) LINE LINE(NETZ) ALARM SWITCH TERMINALS & STD. AUX. SW. WITH VDE OR >30 AMPS .205 [5.21] 4 0 I> 1.640 [41.66] NO (3) 0 LOAD 5 TERMINALS CIRCUIT CODE AUX SWITCH CODE CIRCUIT SCHEMATIC ANSI CIRCUIT CODE AUX SWITCH CODE CIRCUIT BREAKER PROFILE 2 TERMINALS .393 [9.96] REF .032 [.81] TYP LINE (NETZ) 1.560 [39.62] TYP 1.640 [41.66]REF 30 2 PLCS 1.560 [39.62]TYP LOAD (LAST) .220 [5.59]TYP Notes: 1 Tolerance ±.020 [.51] unless otherwise specified. 2 Schematic shown represents current trip circuit. 3 Circuits shown for >30 amps / VDE. 18. 1.350 [34.29] 1.936 [49.17] M6 STUD PUSH-IN STUD SCREW TERMINAL WITH 30 BEND Dimensional Specs Rocker inches [millimeters] INDICATE “ON” #6-32 [M3] THREAD X.195[4.95]DEEP 2 PLCS .945 [24.00] LOAD 1.560 [39.62] 2.000 [50.80] LINE LOAD .370 [9.40] REF ROCKER ADAPTER BRACKET WIDTH .432 [10.97] 1.640 [41.66] CENTER-LINE OF ROCKER,& PANEL CUT-OUT 2.370 [60.20] .945 [24.00] TAB TYPE 2.402 [61.20] SCREW TYPE AC1 OPTIONAL “ROCKER GUARD” BREAKER WIDTH 1.245 [31.62] .208 [5.27] .745 [18.92] (INDICATE “OFF” SHOWN) MAX LINE 2.156 [54.76] 1.660 [42.16] INDICATE “OFF” & SINGLE COLOR .755 [19.18] .420 [10.67] .120 [3.05] .432 [10.97] LINE TAB (Q.C.) TYPE TERMINALS IN SERIES TRIP CONCUIT CONFIGURATION SHOWN> FOR OTHER CONFIGURATIONS SEE CIRCUIT & TERMINAL DIAGRAMS OPTIONAL “PUSH-TO RESET” ACTUATOR LOAD AF1 2.309 [58.65] 1.245 [31.62] LOAD AC2 .220 [5.59] TYP 1.515 [38.48] + .005 -.000 LOAD .750 [19.05] TYP .055x.205 SLOTTED HOLE (ROCKER OFF ACTUATION) [+ _ .25] [+ _ .00] .750 [19.05] TYP TYP PANEL CUT-OUT DETAIL LINE 1.660 [42.16] 1.660 [42.16] LINE OPTIONAL “ROCKER GUARD” SHOWN IN DASHED LINES _ + .005 1.260 [32.00] _ .13] [+ AF2 ROCKER SHROUDED ON “OFF” POSITION SIDE, SHOWN IN DASHED LINES 1.660 [42.16] _ + .005 .200 [5.08] LOAD .156 DIA[ 3.96] 2 HOLES _ .13] [+ LINE MAX AC3 AF3 LINE LOAD 2.265 [57.53] MAX P(1) P(2) P(3) (SEE NOTE 2) REAR VIEW OF INDICATE “ON” SERIES TRIP W/AUX SWITCH CIRCUIT CONFIGURATION Notes: 1 Dimensions apply to all variations shown. Notice that circuit breaker line & load terminal orientation on indicate OFF is opposite of indicate ON. 2 For pole orientation with horizontal legend, rotate front view clockwise 90°. 3 Tolerance ± 0.20 [.51] unless otherwise specified. 19. .465 [11.81] P(1) P(2) P(3) (SEE NOTE 2) REAR VIEW OF INDICATE “OFF” SERIES TRIP W/AUX SWITCH CIRCUIT CONFIGURATION 1.010 [25.65] Dimensional Specs Rocker Snap-In Bracket inches [millimeters] INDICATE “ON” FRONT PANEL SNAP-IN BRACKET , 0.96”[24.48 mm] wide bezel .410 [10.41] AC1 .483 [12.27] .755 [19.18] .125 [3.18] .125 [3.18] MAX BREAKER WIDTH LINE 1.560 [39.62] 2.598 [65.99] 2.000 [50.80] LOAD .960 [24.38] 1.640 [41.66] 2.370 [58.93] .320 [8.13] MAX TAB TYPE ROCKER ADAPTER BREAKER WIDTH .320 [8.13] TAB (Q.C.) TYPE TERMINALS IN SERIES TRIP CONCUIT CONFIGURATION SHOWN. FOR OTHER CONFIGURATIONS SEE CIRCUIT & TERMINAL DIAGRAMS 2.352 [59.74] SCREW TYPE OPTIONAL”ROCKER GUARD” SHOWN IN DASHED LINES FRONT PANEL SNAP-IN BRACKET , 0.744”[18.90 mm] wide bezel AC1 2.598 [65.99] .744 [18.90] MAX ROCKER ADAPTER BREAKER WIDTH INDICATE “OFF” FRONT PANEL SNAP-IN BRACKET , 0.96 ”[24.48 mm] wide bezel .755 [19.18] MAX .320 [8.13] 1.640 [41.66] ROCKER ADAPTER BREAKER WIDTH .483 [12.27] .125 [3.18] AF1 LOAD 2.000 [50.80] 1.560 [39.62] 2.98 [65.99] LINE .125 [3.18] .410 [10.41] .320 [8.13] .960 [24.38] MAX ROCKER ADAPTER BREAKER WIDTH FRONT PANEL SNAP-IN BRACKET , 0.744 ”[18.90 mm] wide bezel OPTIONAL “ROCKER GUARD” SHOWN IN DASHED LINES AF1 _ .010 + LOAD 2.598 [65.99] LINE .770 [19.56] _ .25] [+ _ + .012 .744 [18.90] 2.187 [55.55] _ [+ .30] MAX Notes: 1 Dimensions apply to all variations shown. Notice that circuit breaker line & load terminal 2 For pole orientation with horizontal legend, rotate front view clockwise 90°. Orientation on indicate “OFF” is opposite of indicate “ON” 3 Recommended panel thickness: .04 0 [1.02] to .100 [2.54] 4 Tolerance ±.020 [.51] unless otherwise specified. 20. ROCKER ADAPTER BREAKER WIDTH PANEL CUTOUT DETAIL PC Terminal Diagrams inches [millimeters] A-SERIES ROCKER .125 [3.17] TYP 2.122 [53.90] .475 [12.07] .375 [9.53] .145 [3.68] TYP .370 [9.40] 3 PL .145 [3.68] .1640 [41.66] REF .120 [3.05] 3 PL .221 [5.61] .520 [13.21] LOAD 2.309 [58.65] 2.000 [50.80] 1.245 [31.62] NC NO 1.558 [39.57] C LINE .050 DIA[ 1.27] .755 [19.18] MAX BREAKER WIDTH _ +.003 (2 PL) .745 [18.92] .420 [10.67] 1.010 [25.65] MAX .030 [.762] .0427 [1.19] TYP .632 [16.05] FIBER 2 PL A-SERIES HANDLE 2.122 [53.90] .125 [3.17] TYP .375 [9.53] TYP .096 [2.44] 1.640 [41.66] .693 [17.50] (2 PL) .221 [5.61] .590 DIA [ 14.99] LOAD OFF 1.558 [39.57] .050 DIA[ 1.27] (2 PL) 2.000 [50.80] ON LINE .745 [18.92] (2 PL) .096 [2.44] (2 PL) .544 [13.82] .060 DIA[ 1.52] 14 THRU HOLES 2.122 [53.90] 1.528 [38.81] .100 [2.54] TYP P.C. FOOT PRINT Notes: 1 Drawing illustrates A-Series with VDE certification. 2 Tolerance ± 0.20 [.51] unless otherwise specified 21. .755 [19.18] MAX BREAKER WIDTH .030 [.762] TYP .632 [16.05] .130 [3.30] MAX .096 [2.44] +.003 .544 [13.82] .050 [1.27] 2.122 [53.90] .295 [7.49] .295 [7.49] 1.528 [38.81] P.C. FOOT PRINT WITH AUX. SWITCH .060 DIA[ 1.52] 17 THRU HOLES .100 [2.54] TYP Ordering Scheme A Sample Part Number 1 1 Selection 1 - B 0 - 24-630 - 2 3 1 - E 2 3 4 5 A 2. ACTUATOR 1 ROCKER STYLE DESCRIPTIONS Two Color Visi-Rocker 1 Indicate OFF, vertical legend 2 Indicate OFF, horizontal legend Single color 3 Vertical legend 4 Horizontal legend Push-To-Reset, Visi-Rocker 5 Indicate OFF, vertical legend 6 Indicate OFF, horizontal legend Push-To-Reset , Single color 7 Vertical legend 8 Horizontal legend INDICATE”OFF” SINGLE COLOR CODE “3” , “7” VERTICAL STYLE CODE “1” , “5” INDICATE COLOR LOCATION LINE LINE CODE “4” , “8” HORIZONTAL STYLE CODE “2” , “6” LINE LINE 2 3 Two Three 4. CIRCUIT Switch Only (No Coil) G 4 Relay Trip (Voltage) Series Trip (Current) H 4,5 Dual Coil with Shunt Trip Series Trip (Voltage) Voltage Coil Shunt Trip (Current) K 4,5 Dual Coil with Relay Trip Shunt Trip (Voltage) Voltage Coil Relay Trip (Current) 5. AUXILIARY / ALARM SWITCH 0 1 2 5 6,7 without Aux Switch 7 S.P.D.T., 0.093 Q.C. Term. S.P.D.T., 0.110 Q.C. Term. 8 S.P.S.T., 0.093 Q.C. Term. 9 (Gold Contacts) 6. FREQUENCY & DELAY 03 DC 50/60Hz, Switch Only 10 6 DC Instantaneous 11 DC Ultra Short 12 DC Short 14 DC Medium 16 DC Long 20 6 50/60Hz Instantaneous 21 50/60Hz Ultra Short 22 50/60Hz Short 24 50/60Hz Medium 26 50/60Hz Long 30 DC, 50/60Hz Instantaneous S.P.S.T., 0.110 Q.C. Term. (Gold Contacts) S.P.S.T., 0.187 Q.C. Term. S.P.D.T., 0.187 Q.C. Term. 31 DC, 50/60Hz Ultra Short 32 DC, 50/60Hz Short 34 DC, 50/60Hz Medium 36 DC, 50/60Hz Long 42 9 50/60Hz Short, High-inrush 44 9 50/60Hz Medium, High-inrush 46 9 50/60Hz Long, High-inrush 52 9 DC, Short, High-inrush 54 9 DC, Medium, High-inrush 56 DC, Long, High-inrush 7. CURRENT RATING (AMPERES) CODE AMPERES 020 0.020 225 0.250 420 2.000 025 0.025 230 0.300 522 2.250 030 0.030 235 0.350 527 2.750 035 0.035 240 0.400 430 3.000 040 0.040 245 0.450 435 3.500 045 0.045 250 0.500 440 4.000 050 0.050 255 0.550 445 4.500 055 0.055 260 0.600 450 5.000 060 0.060 265 0.650 455 5.500 065 0.065 270 0.700 460 6.000 070 0.070 275 0.750 465 6.500 075 0.075 280 0.800 470 7.000 080 0.080 285 0.850 475 7.500 085 0.085 290 0.900 480 8.000 090 0.090 295 0.950 485 8.500 095 0.095 410 1.000 490 9.000 210 0.100 512 1.250 495 9.500 215 0.150 415 1.500 610 10.000 220 0.200 517 1.750 710 10.500 OR VOLTAGE COIL (NORMAL RATED VOLTAGE) 8 A06 A12 A18 A24 6 DC 12 DC 18 DC 24 DC A32 A48 A65 J06 32 DC 48 DC 65 DC 6 AC J12 J18 J24 J48 Configure Complete Part Number > 22. 7 12 AC 18 AC 24 AC 48 AC 611 11.000 711 11.500 612 12.000 712 12.500 613 13.000 614 14.000 615 15.000 616 16.000 617 17.000 618 18.000 620 20.000 622 22.000 624 24.000 625 25.000 630 30.000 635 8 35.000 640 8 40.000 645 8 45.000 650 8 50.000 J65 K20 L40 8 9 10 11 11 1 12 Push-On 0.250 Tab (Q.C.) 2 Screw 8-32 with upturned lugs 3 13 Screw 8-32 (Bus Type) 4 Screw 10-32 with upturned lugs 5 13 Screw 10-32 (Bus Type) 6 Screw 8-32 with upturned lugs & 30° bend 7 Screw 8-32 (Bus Type) & 30° bend 8 Screw 10-32 with upturned lugs & 30° bend 9 Screw 10-32 (Bus Type) & 30° bend B Screw M5 with upturned lugs C Screw, M4 with upturned lugs E 13 Screw M4 (Bus Type) F Screw M5 with upturned lugs & 30° bend G Screw M5 (Bus Type) & 30° bend H 13 Screw M5 (Bus Type) L 14 0.250 Q.C./ Solder Lug M 13 M6 Threaded Stud P 15 Printed Circuit Board Terminals Q Push-In Stud R Screw, M4 with upturned lugs & 30° Bend S 16 Push-On 0.110 Tab (Q.C.) & 30° bend T Screw, M4 with upturned lugs 9. ACTUATOR COLOR & LEGEND 2 1 One A 3 B C D 4 E 4 F 4 6 8. TERMINAL 1. SERIES 3. POLES Flat Rocker - UL 1077 Recognized 65 AC 120 AC 240 AC Browse Standard Parts > Actuator or Visi-Color 17 White Black Red Green Blue Yellow Gray Orange Marking: Marking Color ON-OFF Dual 17 Single Color Visi-Rocker B 1 Black White D 2 White n/a G 3 White Red J 4 White Green L 5 White Blue N 6 Black Yellow Q 7 Black Gray S 8 Black Orange 10. MOUNTING / BARRIERS 18 STANDARD ROCKER BEZEL Threaded Insert, 2 per pole BARRIERS FLAT ROCKER ACTUATOR 1 6-32 x 0.195 inches no A 6-32 X 0.195 inches (multi-pole units only) yes 2 ISO M3 x 5mm no B ISO M3 x 5mm (multi-pole units only) yes RECESSED OFF SIDE ROCKER ACTUATOR 19 5 6-32 x 0.195 inches no E 6-32 x 0.195 inches (multi-pole units only)yes 6 ISO M3 x 5mm no F ISO M3 x 5mm (multi-pole units only) yes PUSH-TO-RESET BEZEL,Threaded Insert, 2 per pole 3 6-32 x 0.195 inches no C 6-32 x 0.195 inches (multi-pole units only) yes 4 ISO M3 x 5mm no D ISO M3 x 5mm (multi-pole units only) yes 11. AGENCY APPROVAL C E I UL Recognized & CSA Accepted TUV Certified, UL Recognized & CSA Accepted UL Recognized STD 1077, UL Recognized 1500 (ignition protected), & CSA Accepted Notes: 1 Push-To-Reset actuators have OFF portion of rocker shrouded. 2 Multi-pole breakers have all breakers identical except when specifying Auxiliary switch and/or mixed poles, and have one rocker per breaker. 3 Switch Only circuits, rated up to 50 amps & 3 poles. Only available when tied to a protected pole. For .02 to 30 amps, select Current Code 630. For 35 - 50 amps, select Current Code 650. 4 Available with terminal Codes 1, 2 and 3. Current Rating limited to 30 amps maximum. 5 Consult factory for Dual Coil options, as special catalog number is required. With Shunt construction, Dual Coils will trip instantaneously on line voltage. Dual coils require 30VA minimum power to trip and are rated for intermittent duty only. 6 Auxiliary Switch breakers with Series Trip & Switch Only circuits: ≤ 30A, are supplied with standard half shells. 30-50A are supplied with extended boat (B-Style) half shells. 7 On multi-pole breakers, one auxiliary switch is supplied, mounted in the extreme right pole. 8 Separate pole type voltage coils not rated for continuous duty. Available only with delay codes 10 & 20. 9 Available with Circuit Codes B & D only. UL Recognized, CSA Accepted & TUV Certified to 50 amps. 10 UL Recognition, CSA Acceptance & TUV Certification available in one and two pole breakers. 11 Screw Terminals are recommended on ratings greater than 20 amps. Ratings over 30 amps are only available with Terminal Codes 5, 9, G, H, M and Q. 12 Terminal Code 1: Available up to 30 amps, but not recommended over 20 amps. 13 Terminal Codes 3, 5 E & H (Bus Type) with TUV, are supplied with Lock Washers; Terminal Code M (M6 Threaded Stud) with TUV is supplied with Lock and Flat Washers. These breakers are only TUV Certified when the washers are used. 14 TUV Cert. available up to 12 amps. UL Rec. & CSA Accepted available up to 30 amps. 15 Single pole breakers with Terminal Code P (Printed Circuit Board) are available up to 50 amps with UL Recognition, CSA Accepted & TUV Certification, with Circuit Codes A, B and C. Two pole breakers with Terminal Code P (Printed Circuit Board) are avail able up to 40 amps with UL Recognition and CSA Accepted with Circuit Codes A, B & C. 16 Terminal Code S used on voltage coil circuit constructions only. 17 Color shown is visi & legend with remainder of rocker black, Dual = ON-OFF/I-O legend. 18 Legend on Push-to-reset bezel/shroud is white with single color actuator codes 7 & 8. Legend on Push-To-Reset bezel/shroud matches Visi-Color of rocker with actuator codes 5 & 6. 19 Recessed “off-side” available with actuator codes 1, 2, 3 & 4. Legends on rocker are available in ink stamping only. Ordering Scheme Sample Part Number A 1 1 - B 0 - 14 -630 - 2 3 1 - M T 1 Selection 2 3 4 5 6 A 1 ROCKER STYLE DESCRIPTIONS INDICATE”OFF” SINGLE COLOR CODE “3” , “7” CODE “1” , “5” VERTICAL STYLE Two Color Visi-Rocker 1 Indicate OFF, vertical legend 2 Indicate OFF, horizontal legend Single color 3 Vertical legend 4 Horizontal legend Push-To-Reset, Visi-Rocker 5 Indicate OFF, vertical legend 6 Indicate OFF, horizontal legend Push-To-Reset , Single color 7 Vertical legend 8 Horizontal legend INDICATE COLOR LOCATION LINE LINE CODE “4” , “8” CODE “2” , “6” HORIZONTAL STYLE 2. ACTUATOR LINE LINE 2 1 One 2 3 Two Three 4. CIRCUIT B Series Trip (Current) 5. AUXILIARY / ALARM SWITCH 0 1 2 without Aux Switch 7 S.P.D.T., 0.093 Q.C. Term. S.P.D.T., 0.110 Q.C. Term. 8 9 6. FREQUENCY & DELAY 11 12 14 16 DC Ultra Short DC Short DC Medium DC Long 52 54 56 3 S.P.S.T., 0.110 Q.C. Term. (Gold Contacts) S.P.S.T., 0.187 Q.C. Term. S.P.D.T., 0.187 Q.C. Term. DC, Short, High-inrush DC, Medium, High-inrush DC, Long, High-inrush 7. CURRENT RATING (AMPERES) CODE AMPERES 020 025 030 035 040 045 050 055 060 065 070 075 080 085 090 095 210 215 220 0.020 0.025 0.030 0.035 0.040 0.045 0.050 0.055 0.060 0.065 0.070 0.075 0.080 0.085 0.090 0.095 0.100 0.150 0.200 8. TERMINAL 225 230 235 240 245 250 255 260 265 270 275 280 285 290 295 410 512 415 517 0.250 0.300 0.350 0.400 0.450 0.500 0.550 0.600 0.650 0.700 0.750 0.800 0.850 0.900 0.950 1.000 1.250 1.500 1.750 420 522 527 430 435 440 445 450 455 460 465 470 475 480 485 490 495 610 710 2.000 2.250 2.750 3.000 3.500 4.000 4.500 5.000 5.500 6.000 6.500 7.000 7.500 8.000 8.500 9.000 9.500 10.000 10.500 611 11.000 711 11.500 612 12.000 712 12.500 613 13.000 614 14.000 615 15.000 616 16.000 617 17.000 618 18.000 620 20.000 622 22.000 624 24.000 625 25.000 630 30.000 6354 35.000 6404 40.000 6454 45.000 6504 50.000 11 2 Screw 8-32 with upturned lugs 3 7 Screw 8-32 (Bus Type) 4 Screw 10-32 with upturned lugs 5 7 Screw 10-32 (Bus Type) 6 Screw 8-32 with upturned lugs & 30° bend 8 Screw 10-32 with upturned lugs & 30° bend 23. 7 8 9 10 11 12 9. ACTUATOR COLOR & LEGEND 1. SERIES 3. POLES Flat Rocker - UL 489A Listed 9 Screw 10-32 (Bus Type) & 30° bend B Screw M5 with upturned lugs F Screw M5 with upturned lugs G Screw M5 (Bus Type) & 30° bend H Screw M5 (Bus Type) M 7 M6 Threaded Stud P 8 Printed Circuit Board Terminals Q 9 Push-In Stud Actuator or Visi-Color 11 White Black Red Green Blue Yellow Gray Orange Marking: Marking Color ON-OFF Dual 11 Single Color Visi-Rocker B 1 Black White D 2 White n/a G 3 White Red J 4 White Green L 5 White Blue N 6 Black Yellow Q 7 Black Gray S 8 Black Orange 10. MOUNTING / BARRIERS 1 A 2 B 5 E 6 F 3 C 4 D 12 STANDARD ROCKER BEZEL BARRIERS Threaded Insert, 2 per pole FLAT ROCKER ACTUATOR 6-32 x 0.195 inches no 6-32 X 0.195 inches (multi-pole units only) yes ISO M3 x 5mm no ISO M3 x 5mm (multi-pole units only) yes RECESSED OFF SIDE ROCKER ACTUATOR 6-32 x 0.195 inches no 6-32 x 0.195 inches (multi-pole units only) yes ISO M3 x 5mm no ISO M3 x 5mm (multi-pole units only) yes PUSH-TO-RESET BEZEL,Threaded Insert, 2 per pole 6-32 x 0.195 inches no 6-32 x 0.195 inches (multi-pole units only) yes ISO M3 x 5mm no ISO M3 x 5mm (multi-pole units only) yes 11. MAXIMUM APPLICATION RATING M 80 DC 12.AGENCY APPROVAL T J UL489A Listed UL489A Listed, TUV Certified Notes: 1 Push-To-Reset actuators have OFF portion of rocker shrouded. 2 Multi-pole breakers have all breakers identical except when specifying Auxiliary switch and/or mixed poles, and have one rocker per breaker. 3 Auxiliary Switch breakers with Series Trip circuits: ≤ 30A, are supplied with standard half shells. 30-50A are supplied with extended boat (B-Style) half shells. 4 VDE Certification available with single pole breakers only. UL489A Listing avail able with one and two pole breakers. 5 Screw Terminals are recommended on ratings greater than 20 amps. Ratings over 30 amps are only available with Terminal Codes 5, 9, G, H, M and Q. 6 Terminal Code 1 (Push-On) available up to 25 amps with TUV or VDE Certification and 30 amps with UL489A Listing, but is not recommended over 20 amps. 7 Terminal Codes 3, 5 and H (Bus Type) with TUV or VDE, are supplied with Lock Washers, and Terminal Code M (M6 Threaded Stud) with VDE is supplied with Lock and Flat Washers. These breakers are only TUV or VDE Certified when the washers are used. 8 Single pole breakers with Terminal Code P (Printed Circuit Board) are available up to 30 amps with VDE Certification and 50 amps with UL489A Listing. 9 Terminal Code Q not available with VDE certification. 10 Color shown is Visi and Legend with remainder of rocker black. Dual = ON-OFF/I- O legend. 11 Legend on Push-to-reset bezel/shroud is white with single color actuator codes R & U. 12 Legend on Push-To-Reset bezel/shroud matches Visi-Color of rocker with actua tor codes N & O. Rockerguard available with actuator codes C through K Configure Complete Part Number > Browse Standard Parts > Dimensional Specs Flat Rocker inches [millimeters] INDICATE “OFF” & SINGLE COLOR (INDICATE “OFF” SHOWN) 2.402 [61.01] SCREW TYPE .755 [19.18] 2.370 [60.20] A11 .370 [9.40] TAB TYPE BREAKER WIDTH LOAD 2.000 [50.80] .208 [5.27] 1.560 [39.62] 2.309 [58.65] 1.245 [31.62] .120 [3.05] TAB (Q.C.) TYPE TERMINALS IN SERIES TRIP CONCUIT CONFIGURATION SHOWN. FOR OTHER CONFIGURATIONS SEE CIRCUIT & TERMINAL DIAGRAMS .750 [19.05] TYP + .005 -.000 [+ _ .25] [+ _ .00] .750 [19.05] 1.660 [42.16] _ + .005 1.260 [32.00] _ .13] [+ LINE _ + .005 .220 [5.59] 1.515 [38.48] MAX ROCKER ADAPTER BRACKET WIDTH PANEL CUT-OUT DETAIL 1.660 [42.16] TYP .745 [18.92] .397 [10.08] CENTER-LINEOF ROCKER &PANEL CUT-OUT LOAD 1.660 [42.16] 1.660 [42.16] 1.010 [25.65] LINE A12 #6-32 [M3] THREAD X.195[4.95]DEEP 2 PLCS REF 1.640 [41.66] MAX TYP _ .13] [+ SIDE VIEW OF BREAKER IN THE “ON” POSITION .156 DIA[ 3.96] 2 HOLES .200 [5.08] MAX PUSH-TO-RESET ACTUATOR A13 LOAD 1.245 [31.62] A51 LOAD 2.309 [58.65] .515 [13.08] LINE 2.265 [57.53] MAX P(1) P(2) P(3) (SEE NOTE 2) REAR VIEW OF INDICATE “OFF” SERIES TRIP W/AUX SWITCH CIRCUIT CONFIGURATION .055x.205 SLOTTED HOLE (ROCKER OFF ACTUATION) LINE 1.010 [25.65] ROCKER SHROUDED ON “OFF” POSITION SIDE, SHOWN IN DASHED LINES ACTUATOR SIDE VIEW (SURFACE CONTOURS) Notes: 1 For pole orientation with horizontal legend, rotate front view clockwise 90°. 2 Tolerance ± 0.20 [.51] unless otherwise specified. 24. FLAT ROCKER RECESSED OFF SIDE ROCKER Ordering Scheme Sample Part Number A Y 1 - B 0 - 14 -630 - 2 3 1 - M T 1 Selection 2 3 4 5 6 A 2. ACTUATOR 1 Single Color Recessed Paddle Actuator with Vertical Legends 3. POLES 2 1 One 2 3 Two Three 4. CIRCUIT A B C D E Switch-Only (No Coil) Series Trip (Current) Series Trip (Voltage) Shunt Trip (Current) Shunt Trip (Voltage) F Relay Trip (Current) G Relay Trip (Voltage) H Dual Coil with Shunt Trip Voltage Coil K Dual Coil with Shunt Trip Current Coil without Aux Switch S.P.D.T. with 0.093 Q.C. Terminals S.P.D.T. with 0.110 Q.C. Terminals S.P.D.T. with 0.139 Solder Lug Terminals S.P.D.T. with 0.093 Q.C. Terminals (Gold Contacts) S.P.S.T.-N.O. with 0.139 Solder Lug Terminals S.P.S.T.-N.O. with 0.110 Q.C. Terminals (Gold Contacts) S.P.S.T.-N.O. with 0.187 Q.C. Terminals S.P.D.T. with 0.187 Q.C. Terminals 6. FREQUENCY & DELAY 3 10 11 12 14 16 20 21 22 DC, 50/60 Hz Switch Only DC Instantaneous DC Ultra Short DC Short DC Medium DC Long 50/60 Hz Instantaneous 50/60 Hz Ultra Short 50/60 Hz Short 24 26 42 44 46 52 54 56 50/60 Hz Medium 50/60 Hz Long 50/60 Hz Short High-inrush 50/60 Hz Medium High-inrush 50/60 Hz Long High-inrush DC, Short, High-inrush DC, Medium, High-inrush DC, Long, High-inrush 4 CODE AMPERES 020 0.020 225 0.250 420 2.000 025 0.025 230 0.300 522 2.250 030 0.030 235 0.350 527 2.750 035 0.035 240 0.400 430 3.000 040 0.040 245 0.450 435 3.500 045 0.045 250 0.500 440 4.000 050 0.050 255 0.550 445 4.500 055 0.055 260 0.600 450 5.000 060 0.060 265 0.650 455 5.500 065 0.065 270 0.700 460 6.000 070 0.070 275 0.750 465 6.500 075 0.075 280 0.800 470 7.000 080 0.080 285 0.850 475 7.500 085 0.085 290 0.900 480 8.000 090 0.090 295 0.950 485 8.500 095 0.095 410 1.000 490 9.000 210 0.100 512 1.250 495 9.500 215 0.150 415 1.500 610 10.000 220 0.200 517 1.750 710 10.500 OR VOLTAGE COIL (NORMAL RATED VOLTAGE) 25. 9 A32 32 DC A48 48 DC A65 65 DC J06 6 AC J12 12 AC J18 18 AC J24 24 AC J48 48 AC 611 711 612 712 613 614 615 616 617 618 620 622 624 625 630 635 640 645 650 10 11 12 B Screw M5 with upturned lugs C Screw, M4 with upturned lugs F Screw M5 with upturned lugs G Screw M5 (Bus Type) & 30° bend H Screw M5 (Bus Type) M M6 Threaded Stud P Printed Circuit Board Terminals Q Push-In Stud R Screw, M4 with upturned lugs & 30° Bend S Screw, M5 with upturned lugs T Screw, M4 with upturned lugs 9. ACTUATOR COLOR & LEGEND 5 I-O ON-OFF A B C D F G H J K L M N P Q R S Dual Legend Color 1 Black 2 White 3 White 4 White 5 White 6 Black 7 Black 8 Black 10. MOUNTING / BARRIERS 3 7. CURRENT RATING (AMPERES) A06 6 DC A12 12 DC A18 18 DC A24 24 DC 8 1 Push-On 0.250 Tab (Q.C.) 2 Screw 8-32 with upturned lugs 3 7 Screw 8-32 (Bus Type) 4 Screw 10-32 with upturned lugs 5 7 Screw 10-32 (Bus Type) 6 Screw 8-32 with upturned lugs & 30° bend 7 Screw 8-32 (Bus Type) & 30° bend 8 Screw 10-32 with upturned lugs & 30° bend 9 Screw 10-32 (Bus Type) & 30° bend Actuator Color White Black Red Green Blue Yellow Gray Orange 5. AUXILIARY SWITCH 0 1 2 3 5 6 7 8 9 7 8. TERMINAL 1. SERIES Y Recessed Paddle 11.000 11.500 12.000 12.500 13.000 14.000 15.000 16.000 17.000 18.000 20.000 22.000 24.000 25.000 30.000 35.000 40.000 45.000 50.000 J65 65 AC K20 120 AC L40 240 AC 1 A 2 B 6-32 x 0.195 inches 6-32 X 0.195 inches (multi-pole units only) ISO M3 x 5mm ISO M3 x 5mm (multi-pole units only) 11. MAXIMUM APPLICATION RATING A C K M 6 65 VDC 120/240 VAC (Available only on 2 or 3-Pole units) 120 VAC 80 DC 12.AGENCY APPROVAL A C T BARRIERS no yes no yes 7 Without Approvals UL Recognized and CSA Accepted UL 489A Notes: 1 All standard catalog numbers are supplied with Vertical Legends. For Horizontal or other non-standard legends, choose “X” and order as a special catalog number. 2 For rating (T) 2 & 3 Pole not available. 3 Frequency and Time Delay ratings of (03, 20, 21, 22, 24, 26, 42, 44, 46) not available with approval T. 4 Voltage Coil Ratings starting with (J, K, or L) not available with approval T. 5 “OFF and/or “O” Legends are on Bracket and are only visible when the Paddle Actuator is in the off position. 6 Maximum Application Ratings (C & K) not available with approval T. 7 Not all approvals are available in all constructions. Consult factory for details. Configure Complete Part Number > Browse Standard Parts > Dimensional Specs Recessed Paddle inches [millimeters] #6-32 [M3] THREAD X .105 [4.95] DEEP 2 PLCS 2.10 [5.33] .755 [19.18] .243 [6.17] MAX LOAD 1.660 [42.16] 1.240 [31.50] 1.560 [39.62] 2.000 [50.80] LINE .745 [18.92] MAX .380 [9.65] 2.010 [51.05] 2.378 [60.40] TAB TYPE 2.410 [61.21] SCREW TYPE .750 [19.05] .750 [19.05] BREAKER SHOWN IN THE OFF POSITION BREAKER SHOWN IN THE OFF POSITION TYP .848 [21.54] TYP 1.515 [38.48] 2.888 [73.36] MAX PANEL CUT-OUT DETAIL .750 + .010 -.000 + .25 - .00 [ 19.05 1.260 + - .005 [32.00+ - .12] 1.660 [42.16] .200 [5.08] 2.265 [57.53] MAX Notes: 1 Tolerance ± 0.20 [.51] unless otherwise specified 26. .156 + - .005 [3.96 + - .12] 2 HOLES ] Authorized Sales Representatives and Distributors Click on a region of the map below to find your local representatives and distributors or visit www.carlingtech.com/findarep. CANADA EUROPE USA MIDDLE EAST MEXICO AFRICA ASIA-PACIFIC OCEANIA SOUTH AMERICA About Carling Founded in 1920, Carling Technologies is a leading manufacturer of electrical and electronic switches and assemblies, circuit breakers, electronic controls, power distribution units, and multiplexed power distribution systems. With six ISO9001 and IATF16949 registered manufacturing facilities and technical sales offices worldwide, Carling Technologies Sales, Service and Engineering teams do much more than manufacture electrical components, they engineer powerful solutions! To learn more about Carling please visit www.carlingtech.com/company-profile. To view all of Carling’s environmental, quality, health & safety certifications please visit www.carlingtech.com/environmental-certifications. 27. © Carling Technologies, Inc. Carling, Visi-Rocker are registered trademarks of Carling Technologies, Inc. in the U.S. and other countries.
AB2-B0-26-620-6D1-C 价格&库存
很抱歉,暂时无法提供与“AB2-B0-26-620-6D1-C”相匹配的价格&库存,您可以联系我们找货
AB2-B0-26-620-6D1-C
  • 1+775.829021+100.14420
  • 5+643.571765+83.07240
  • 10+605.2188710+78.12180
  • 50+504.3490650+65.10150
  • 100+470.63980100+60.75030
