Thermal Overcurrent Circuit Breaker 127-...
Description
Single pole thermal circuit breaker with push-to-reset, tease-free,
trip-free, snap action mechanism (R-type TO CBE to EN 60934; M-type
when fitted with optional manual release feature). Available in versions
for plug-in or integral mounting, track mounting, or with a frame for
snap-in panel mounting. The optional -KF housing is particularly suited
to high humidity and other damp conditions.
Approved to CBE standard EN 60934 (IEC 60934).
Typical applications
Motors, transformers, solenoids, battery chargers, extra low voltage
systems.
Ordering information
127-P10-H-KF
127-T12-H
Technical data
Type No.
127
Mounting options
leave blank for integral/plug-in option
T12 track mounting with screw terminals M4
Terminal design (for use with and without flange -F)
P10 blade terminals A6.3-0.8 (QC .250)
Manual release
H manual release facility
Special housing
KF for tropical and high humidity conditions
Current ratings
0.05...25 A
127 - F - P10 - H - KF - 10 A ordering example
Please be informed that we have minimum ordering quantities to be observed.
Standard current ratings and typical internal resistance values
Current
rating (A)
Internal
resistance (Ω)
Current
rating (A)
Internal
resistance (Ω)
0.05
280
1.5
0.6
0.08
100
1.8
0.4
0.1
110
2
0.3
0.15
56
2.5
0.2
0.2
29
3
0.1
0.25
18
3.5
0.06
0.3
14
4
0.06
0.35
9.8
4.5
0.05
0.4
7
5
0.05
0.45
5.9
6
0.02
0.5
4.9
7
0.02
0.6
3.4
8
0.02
0.7
2.5
10
< 0.02
0.8
1.8
15
< 0.02
0.9
1.5
16
< 0.02
1
1.2
< 0.02
1.2
0.8
25
< 0.02
1833
1
For further details please see: www.e-t-a.de/ti_e
Voltage rating
AC 250 V; DC 28 V
(UL: AC 250 V; DC 50 V)
Current ratings
0.05...25 A
Typical life
0.05...16 A 5,000 operations at 2 x IN, inductive
17...25 A 5,000 operations at 2 x IN, resistive
Ambient temperature
-20...+60 °C (-4...+140 °F)
Insulation co-ordination rated impulse
pollution
(IEC 60664 and 60664 A) withstand voltage
degree
2.5 kV
2
reinforced insulation in operating area
Dielectric strength
(IEC 60664 and 60664A) test voltage
operating area
AC 3,000 V
Insulation resistance
> 100 MΩ (DC 500 V)
Interrupting capacity Icn 0.05...2.5 A
8 x IN
3...5 A
20 x IN
6...12 A
200 A
13...25 A
300 A
IN
UN
(UL 1077)
0.05...20 A
AC 250 V 2,000 A
0.05...25 A
DC 50 V 2,500 A
Degree of protection
operating area IP40
(IEC 60529/DIN 40050)
terminal area IP00
Vibration
8 g (57-500 Hz) ± 0.61 mm (10-57 Hz)
to IEC 60068-2-6, test Fc,
10 frequency cycles/axis
Shock
25 g (11 ms), to IEC 60068-2-27, test Ea
Corrosion
96 hours at 5 % salt mist,
to IEC 60068-2-11, test Ka
Humidity
240 hours at 95 % RH
to IEC 60068-2-78, test Cab
Mass
127-P10-..: approx. 20 g
127-T..-: approx. 35 g
Approvals
Authority
Standard
Rated voltage
Current ratings
VDE
IEC / EN 60934
AC 250 V
DC 28 V
0.05 A…25 A
0.05 A…25 A
UL
UL 1077
AC 250 V
DC 50 V
0.05 A…20 A
0.05 A…25 A
CSA
C22.2 No 235
AC 250 V
DC 50 V
0.05 A…20 A
0.05 A…25 A
CQC
GB 17701
AC 250 V
DC 28 V
0.05 A…25 A
0.05 A…25 A
www.e-t-a.de
1
Dimensions
Internal connection diagram
127-P10-H-KF
1
OFF
0.05...25 A
8
.315
13.5
.531
ON
ø4
.157
2
45
1.77
1
Typical time/current characteristics at +23 °C/+73.4 °F
32
10000
19.8
.780
31
1.22
25 A
1000
31
1.22
11.5
.453
6
.236
12
.472
1
13
.512
47
1.85
63
2.48
52
2.05
100
10
OFF
ø4
.157
0.05 - 2.7 A
2.8 - 23 A
ON
127-T12-H
11.5
.453
blade terminal
DIN 46244-A6.3-0.8
(QC .250)
Trip time in seconds
9.4
.370
1
7
.276
M4
44
1.73
54
2.13
tightening torque
for M4 max. 1.2 Nm
14
.551
0.1
1
2
4 6
8 10
... times rated current
The time/current characteristic curve depends on the ambient temperature
prevailing. In order to eliminate nuisance tripping, please multiply the
circuit breaker current ratings by the derating factor shown below. See also
section Technical information.
spacing
G profile
EN 50035-G...
Ambient temperature °F
°C
-4
-20
+14
-10
+32
+23
+104
+40
+122
+50
+140
+60
Derating factor
0.76
0.84
0.92
1
1.08
1.16
1.24
34
1.34
1
.039
53
2.09
25
.984
35
1.38
operating area
max. 2
max .079
max. 2
max .079
53
2.09
35
1.38
127-T12-H
max. 2
max .079
Installation drawings
mounting area
This is a metric design and millimeter dimensions take precedence ( mm )
inch
2
www.e-t-a.de
1833
Accessories
12
22
11
21
68
2.68
Mounting sockets
10F-P10 (up to 16 A max. load)
8
.315
blade terminals
DIN 46244-A6.3-0.8 (QC .250)
max. tightening torque
of mounting screw: 2.5 Nm
1
10F-K10 (up to 20 A max. load)
12
22
21
12
.472
30
1.18
11
5.6
.220
9.5
.374
50
1.97
1
.039
wire corss sectional areas
2 x max. 2.5 mm2 (AWG14) stranded
2 x max. 4 mm2 (AWG12) solid
max. tightening torque of terminal screw: 1.2 Nm
12
1
.472
.039
6
.236
75
15
.591
45
1.77
75
2.95
7.5
.296
13
.512
7
.276
10F-A10 (up to 16 A max. load)
12
22
11
21
59
2.32
blade terminals DIN 46244-A6.3-0.8 (QC .250)
8
.315
7
.276
8.5
.335
4.2
.165
12.5
.492
7.9
.311
2.9
.114
Accessories for sockets (up to 20 A max. load)
2-way bus bar Y 301 166 02 4-way bus bar Y 301 166 01
15
.591
22.9
.902
thickness = 0.8 mm
.031 in.
15
15
15
.591 .591 .591
52.9
2.08
Connector bus links -K10
X 210 589 01/2.5 mm2 (AWG 14), black (up to 20 A max. load)
X 210 589 02/1.5 mm2 (AWG 16), brown (up to 13 A max. load)
50 pin lugs to DIN 46230
tinned copper
~70
~2.76
ø2.5
.099
Connector bus links -P10
X 210 588 01/1.5 mm2 (AWG 16), brown (up to 13 A max. load)
X 210 588 02/2.5 mm2 (AWG 14), black (up to 20 A max. load)
X 210 588 03/2.5 mm2 (AWG 14), red (up to 20 A max. load)
X 210 588 04/2.5 mm2 (AWG 14), blue (up to 20 A max. load)
~70
~2.76
100 quick-connect tabs 6.3 (.250)
DIN 46247 tinned brass,
insulated
inch
All dimensions without tolerances are for reference only. In the interest of improved design,
performance and cost effectiveness the right to make changes in these specifications
without notice is reserved.Product markings may not be exactly as the ordering codes.
Errors and omissions excepted.
1833
www.e-t-a.de
3
1
4
www.e-t-a.de
1833
很抱歉,暂时无法提供与“127-T12-H-10A”相匹配的价格&库存,您可以联系我们找货
